[GRASS-SVN] r46905 - grass/trunk/vector/v.net
Fri Jul 1 04:56:31 EDT 2011
Author: mmetz
Date: 2011-07-01 01:56:30 -0700 (Fri, 01 Jul 2011)
New Revision: 46905
   grass/trunk/vector/v.net/connect.c
   grass/trunk/vector/v.net/main.c
   grass/trunk/vector/v.net/nodes.c
remove bounding boxes from vector topology (Radim's TODO): update v.net module
Modified: grass/trunk/vector/v.net/connect.c
--- grass/trunk/vector/v.net/connect.c	2011-07-01 08:55:08 UTC (rev 46904)
+++ grass/trunk/vector/v.net/connect.c	2011-07-01 08:56:30 UTC (rev 46905)
@@ -1,6 +1,7 @@
 #include <stdlib.h>
 #include <grass/gis.h>
 #include <grass/vector.h>
+#include <grass/glocale.h>
 #include "proto.h"
@@ -59,12 +60,15 @@
 				 WITHOUT_Z, &px, &py, &pz, &dist, &spdist,
 				 NULL);
+	if (seg == 0)
+	    G_fatal_error(_("Failed to find intersection segment"));
 	/* break the line */
 	Vect_reset_line(Pout);
 	for (i = 0; i < seg; i++) {
 	    Vect_append_point(Pout, Pline->x[i], Pline->y[i], Pline->z[i]);
 	Vect_append_point(Pout, px, py, pz);
+	Vect_line_prune(Pout);
 	Vect_rewrite_line(Out, line, ltype, Pout, Cline);
@@ -72,6 +76,7 @@
 	for (i = seg; i < Pline->n_points; i++) {
 	Vect_write_line(Out, ltype, Pout, Cline);
 	if (dist > 0.0) {
Modified: grass/trunk/vector/v.net/main.c
--- grass/trunk/vector/v.net/main.c	2011-07-01 08:55:08 UTC (rev 46904)
+++ grass/trunk/vector/v.net/main.c	2011-07-01 08:56:30 UTC (rev 46905)
@@ -28,7 +28,7 @@
     struct GModule *module;
     struct opt opt;
-    struct Map_info *In, *Out, *Points;
+    struct Map_info *In = NULL, *Out = NULL, *Points = NULL;
     FILE *file_arcs;
Modified: grass/trunk/vector/v.net/nodes.c
--- grass/trunk/vector/v.net/nodes.c	2011-07-01 08:55:08 UTC (rev 46904)
+++ grass/trunk/vector/v.net/nodes.c	2011-07-01 08:56:30 UTC (rev 46905)
@@ -36,7 +36,7 @@
     cat++;
-    /* Go thorough all nodes in old map and write a new point if missing */
+    /* Go through all nodes in old map and write a new point if missing */
     nnodes = Vect_get_num_nodes(In);
     count = 0;
     for (node = 1; node <= nnodes; node++) {
