[GRASS-SVN] r49431 - grass/trunk/gui/wxpython/gmodeler
Wed Nov 30 06:11:59 EST 2011
Author: martinl
Date: 2011-11-30 03:11:59 -0800 (Wed, 30 Nov 2011)
New Revision: 49431
   grass/trunk/gui/wxpython/gmodeler/dialogs.py
   grass/trunk/gui/wxpython/gmodeler/model.py
   grass/trunk/gui/wxpython/gmodeler/model_file.py
wxGUI/gmodeler: fix loading models
Modified: grass/trunk/gui/wxpython/gmodeler/dialogs.py
--- grass/trunk/gui/wxpython/gmodeler/dialogs.py	2011-11-30 10:54:45 UTC (rev 49430)
+++ grass/trunk/gui/wxpython/gmodeler/dialogs.py	2011-11-30 11:11:59 UTC (rev 49431)
@@ -31,6 +31,7 @@
 from gui_core.dialogs     import ElementDialog, MapLayersDialog
 from gui_core.ghelp       import SearchModuleWindow
 from gui_core.prompt      import GPromptSTC
+from gui_core.forms       import CmdPanel
 from grass.script import task as gtask
@@ -430,7 +431,7 @@
         task.flags  = params['flags']
         task.params = params['params']
-        panel = menuform.cmdPanel(parent = self, id = wx.ID_ANY, task = task)
+        panel = CmdPanel(parent = self, id = wx.ID_ANY, task = task)
         self.tasks.append(task)
         return panel
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py	2011-11-30 10:54:45 UTC (rev 49430)
+++ grass/trunk/gui/wxpython/gmodeler/model.py	2011-11-30 11:11:59 UTC (rev 49431)
@@ -25,6 +25,7 @@
 import getpass
 import copy
 import re
+import mimetypes
 try:
     import xml.etree.ElementTree as etree
 except ImportError:
@@ -33,9 +34,13 @@
 import wx
 from wx.lib import ogl
-from core.globalvar   import ETCWXDIR
-from core.gcmd        import GMessage, GException, GError, RunCommand
-from gmodeler.dialogs import ModelParamDialog
+from core.globalvar      import ETCWXDIR
+from core.gcmd           import GMessage, GException, GError, RunCommand
+from gmodeler.dialogs    import ModelParamDialog
+from gmodeler.model_file import ProcessModelFile
+from core.utils          import CmdToTuple
+from core.settings       import UserSettings
+from gui_core.forms      import GUI
 from grass.script import core as grass
@@ -358,7 +363,7 @@
         for action in self.GetItems(objType = ModelAction):
             cmd = action.GetLog(string = False)
-            task = menuform.GUI(show = None).ParseCommand(cmd = cmd)
+            task = GUI(show = None).ParseCommand(cmd = cmd)
             errList += map(lambda x: cmd[0] + ': ' + x, task.get_cmd_error())
             # check also variables
@@ -581,9 +586,10 @@
                 condVar, condText = map(lambda x: x.strip(), re.split('\s*in\s*', cond))
                 pattern = re.compile('%' + condVar)
                 ### for vars()[condVar] in eval(condText): ?
+                vlist = list()
                 if condText[0] == '`' and condText[-1] == '`':
                     # run command
-                    cmd, dcmd = utils.CmdToTuple(condText[1:-1].split(' '))
+                    cmd, dcmd = CmdToTuple(condText[1:-1].split(' '))
                     ret = RunCommand(cmd,
                                      read = True,
                                      **dcmd)
Modified: grass/trunk/gui/wxpython/gmodeler/model_file.py
--- grass/trunk/gui/wxpython/gmodeler/model_file.py	2011-11-30 10:54:45 UTC (rev 49430)
+++ grass/trunk/gui/wxpython/gmodeler/model_file.py	2011-11-30 11:11:59 UTC (rev 49431)
@@ -20,6 +20,7 @@
 import time
 import re
+from core           import utils
 from core.gcmd      import GWarning, EncodeString
