[GRASS-SVN] r48094 - grass/trunk/scripts/r.blend
Sat Sep 3 08:27:59 EDT 2011
Author: neteler
Date: 2011-09-03 05:27:59 -0700 (Sat, 03 Sep 2011)
New Revision: 48094
   grass/trunk/scripts/r.blend/r.blend.html
   grass/trunk/scripts/r.blend/r.blend.py
fix broken script; added NC example
Modified: grass/trunk/scripts/r.blend/r.blend.html
--- grass/trunk/scripts/r.blend/r.blend.html	2011-09-03 12:19:45 UTC (rev 48093)
+++ grass/trunk/scripts/r.blend/r.blend.html	2011-09-03 12:27:59 UTC (rev 48094)
@@ -1,19 +1,31 @@
-<H2>DESCRIPTION</H2>
+<h2>DESCRIPTION</h2>
-<EM>r.blend</EM> blends color components of 2 raster maps by a
+<em>r.blend</em> blends color components of 2 raster maps by a
 specificed percentage of the first map.
-<H2>SEE ALSO</H2>
+<h2>EXAMPLE</h2>
-<EM>
-<A HREF="g.region.html">g.region</A>,
-<A HREF="r.mapcalc.html">r.mapcalc</A>,
-<A HREF="r.colors.html">r.colors</A>,
-<A HREF="r.support.html">r.support</A>,
-</EM>
+Blending the aspect map with the elevation map for a shaded map
+(North Carolina sample dataset):
+<p>
+<div class="code"><pre>
+g.region rast=aspect -p
+r.blend first=aspect second=elevation output_prefix=elev_shade_blend
+d.mon wx0
+d.rgb blue=elev_shade_blend.b green=elev_shade_blend.g red=elev_shade_blend.r
-<H2>AUTHOR</H2>
+<h2>SEE ALSO</h2>
+<em>
+<a href="d.shadedmap.html">d.shadedmap</a>,
+<a href="g.region.html">g.region</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.colors.html">r.colors</a>,
+<a href="r.support.html">r.support</a>
+</em>
+<h2>AUTHOR</h2>
 Unknown: probably CERL<br>
 Updated to GRASS 5.7 by Michael Barton, Arizona State University
Modified: grass/trunk/scripts/r.blend/r.blend.py
--- grass/trunk/scripts/r.blend/r.blend.py	2011-09-03 12:19:45 UTC (rev 48093)
+++ grass/trunk/scripts/r.blend/r.blend.py	2011-09-03 12:27:59 UTC (rev 48094)
@@ -50,7 +50,7 @@
 def main():
     first = options['first']
     second = options['second']
-    output = options['output']
+    output = options['output_prefix']
     percent = options['percent']
     mapset = grass.gisenv()['MAPSET']
