[GRASS-SVN] r48095 - grass/trunk/scripts/i.oif
Sat Sep 3 08:28:46 EDT 2011
Author: neteler
Date: 2011-09-03 05:28:46 -0700 (Sat, 03 Sep 2011)
New Revision: 48095
   grass/trunk/scripts/i.oif/i.oif.html
NC examples added
Modified: grass/trunk/scripts/i.oif/i.oif.html
--- grass/trunk/scripts/i.oif/i.oif.html	2011-09-03 12:27:59 UTC (rev 48094)
+++ grass/trunk/scripts/i.oif/i.oif.html	2011-09-03 12:28:46 UTC (rev 48095)
@@ -1,18 +1,16 @@
-<H2>DESCRIPTION</H2>
+<h2>DESCRIPTION</h2>
-<EM>i.oif</EM> calculates the Optimum Index Factor for LANDSAT TM bands 1,2,3,4,5 and 7.
-<P>
+<em>i.oif</em> calculates the Optimum Index Factor for LANDSAT TM bands 1,2,3,4,5 and 7.
+<p>
 The Optimum Index Factor is calculated to determine the band combination which
 shows the maximum information when combined into a composite image. The bands
-comprising the highest scoring combination from <EM>i.oif</EM> are used as the
-three color channels required for <EM><A HREF="d.rgb.html">d.rgb</A></EM> or
-<EM><A HREF="r.composite.html">r.composite</A></EM>.
-<P>
+comprising the highest scoring combination from <em>i.oif</em> are used as the
+three color channels required for <em>d.rgb</em> or <em>r.composite</em>.
+<p>
 The analysis is saved to a file in the current directory called "i.oif.result".
+<h2>NOTES</h2>
-<H2>NOTES</H2>
 Colour Composites in BGR order: important band combinations (example:
 234 in BGR order means: B=2, G=3, R=4):
@@ -40,22 +38,31 @@
 <li> 457: shows soil texture classes (clay, loam, sandy).
 </ul>
+<h2>EXAMPLE</h2>
-<H2>REFERENCES</H2>
+North Carolina sample dataset:
+<div class="code"><pre>
+g.region rast=lsat7_2002_10 -p
+i.oif image1=lsat7_2002_10 image2=lsat7_2002_20 image3=lsat7_2002_30 \
+      image4=lsat7_2002_40 image5=lsat7_2002_50 image7=lsat7_2002_70
+</pre></div>
-Jensen, 1996. Introductory digital image processing, p.98. ISBN 0-13-205840-5
+<h2>REFERENCE</h2>
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.rgb.html">d.rgb</A></EM><BR>
-<EM><A HREF="r.composite.html">r.composite</A></EM><BR>
-<EM><A HREF="r.covar.html">r.covar</A></EM><BR>
-<EM><A HREF="r.univar.html">r.univar</A></EM><BR>
-<BR>
+Jensen, 1996. Introductory digital image processing. Prentice Hall, p.98. ISBN 0-13-205840-5
+<h2>SEE ALSO</h2>
-<H2>AUTHOR</H2>
+<em>
+<a href="d.rgb.html">d.rgb</a>,
+<a href="r.composite.html">r.composite</a>,
+<a href="r.covar.html">r.covar</a>,
+<a href="r.univar.html">r.univar</a>
+</em>
+<h2>AUTHOR</h2>
 Markus Neteler, ITC-Irst, Trento, Italy<br>
 Updated to GRASS 5.7 by Michael Barton, Arizona State University
