[GRASS-SVN] r48190 - grass-addons/grass7/gui/wxpython/wx.wms
Wed Sep 7 13:30:51 EDT 2011
Author: marisn
Date: 2011-09-07 10:30:51 -0700 (Wed, 07 Sep 2011)
New Revision: 48190
   grass-addons/grass7/gui/wxpython/wx.wms/addserver.py
Strip provided WMS URL query parameters from service URL
Modified: grass-addons/grass7/gui/wxpython/wx.wms/addserver.py
--- grass-addons/grass7/gui/wxpython/wx.wms/addserver.py	2011-09-07 17:27:22 UTC (rev 48189)
+++ grass-addons/grass7/gui/wxpython/wx.wms/addserver.py	2011-09-07 17:30:51 UTC (rev 48190)
@@ -1,3 +1,4 @@
+# -*- coding: utf-8 -*-
 @package addserver.py
@@ -17,15 +18,15 @@
 @author: Maris Nartiss (maris.nartiss gmail.com)
 @author: Sudeep Singh Walia (Indian Institute of Technology, Kharagpur , sudeep495 at gmail.com)
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# generated by wxGlade 0.6.3 on Thu Jul 14 06:22:35 2011
 import wx
 import os
 import popen2
 import uuid
 from urllib2 import Request, urlopen, URLError, HTTPError
+import urlparse
+import urllib
 from grass.script import core as grass
 from wx.lib.pubsub import Publisher
 from BeautifulSoup import BeautifulSoup, Tag, NavigableString, BeautifulStoneSoup
@@ -82,12 +83,12 @@
         #sudeep code starts
-        if( not loadConfigFile(self)):
-            grass.fatal_error('Config File Error, Unable to start application...')
+        if not loadConfigFile(self):
+            grass.fatal_error(_('Configuration file error. Unable to start application.'))
             self.Close()
         self.soup, open = initServerInfoBase('ServersList.xml')
-        if(not open):
+        if not open:
             return
         self.Bind(wx.EVT_CLOSE, self.OnQuit)
         self.__populate_URL_List(self.ServerList)
@@ -154,55 +155,111 @@
         self.SetSizer(sizer_1)
         self.Layout()
         # end wxGlade
     def valueExists(self,dict, newServerName):
         try:
             for key, value in dict.items():
-                if(value.servername == newServerName):
+                if value.servername == newServerName:
                     return True
             return False
         except:
             return False
+    def parse_WMS_URL(self, full_url):
+        '''!Strips any WMS parts from url for easy reuse.
+        Strips all WMS 1.1.1 and 1.3.0 parts from URL.
+        This could be moved to some separate WxS support procedure file.
+        @param full_url user provided WMS URL.
+        @return URL as dict suitable for storage or None if provided URL isn't a valid WMS URL.
+        WMS_13_parameters = (
+            'VERSION',
+            'SERVICE',
+            'REQUEST',
+            'FORMAT',
+            'UPDATESEQUENCE',
+            'LAYERS',
+            'STYLES',
+            'CRS',
+            'BBOX',
+            'WIDTH',
+            'HEIGHT',
+            'TRANSPARENT',
+            'BGCOLOR',
+            'EXCEPTIONS',
+            'TIME',
+            'ELEVATION',
+            'QUERY_LAYERS',
+            'INFO_FORMAT',
+            'FEATURE_COUNT',
+            'I',
+            'J')
+        url = urlparse.urlparse(full_url)
+        final_url = {'scheme': url.scheme, 'hostname': url.hostname, 'port': url.port, 'path': url.path, 'params': url.params, 'username': url.username, 'password': url.password, 'netloc': url.netloc}
+        # WMS supports only http or https
+        if final_url['scheme'] not in ('http','https'):
+            # URL without scheme is not a valid one. http is a good guess.
+            if url.scheme == '':
+                return self.parse_WMS_URL('http://'+full_url)
+            return None
+        # If URL lacks host, it's not valid
+        if not final_url['hostname']:
+            return None
+        # Leave any non-WMS query parts
+        query = urlparse.parse_qs(url.query)
+        for k in query.keys():
+            if k.upper() in WMS_13_parameters:
+                del query[k]
+        final_url['query'] = urllib.urlencode(query)
+        return urlparse.urlunparse((final_url['scheme'], final_url['netloc'], final_url['path'], final_url['params'], final_url['query'], None))
     def OnSave(self, event): # wxGlade: ServerAdd.<event_handler>
         newServerName = unicode(self.ServerNameText.GetValue())
         newUrl = self.URLText.GetValue()
         newUserName = self.UsernameText.GetValue()
         newPassword = self.PasswordText.GetValue()
-        if(not self.allFieldsValid(newServerName, newUrl, newUserName, newPassword)):
+        newUrl = self.parse_WMS_URL(newUrl.strip())
+        if not newUrl:
+            message = _("Provided WMS URL is not valid.")
+            self.ShowMessage(message, _('Error'))
+            grass.warning(message)
             return
-        if(self.selectedUid == None):
+        if self.selectedUid == None:
             update = False
         else:
             update = True
         serverData = ServerData()
-        if(len(newUrl) != 0 and len(newServerName) != 0):
-            if(self.selectedServer is not None):
-                if(not self.selectedServer.servername == newServerName):
-                    if(self.valueExists(self.servers, newServerName)):
-                        message = "ServerName already exists. Please enter a different ServerName"
-                        self.ShowMessage(message, 'Warning')
+        if len(newServerName) != 0 :
+            if self.selectedServer is not None:
+                if not self.selectedServer.servername == newServerName:
+                    if self.valueExists(self.servers, newServerName):
+                        message = _("Server name already exists. Please enter a different server name")
+                        self.ShowMessage(message, _('Warning'))
                         StatusBar_fields = [message]
                         self.StatusBar.SetStatusText(StatusBar_fields[0], 0)
                         return
-            if(not newUrl.startswith('http://')):
-                newUrl = 'http://'+newUrl
             validUrl, message = self.validateUrl(newUrl)
-            if(not validUrl):
-                message = "Unable to validate URL ("+message+")"
+            if not validUrl:
+                message = _("Unable to validate URL (%s)") % message
             else:
-                message = "Url validated ("+message+")"
+                message = _("Url validated (%s)") % message
             serverData.servername = newServerName
@@ -210,16 +267,16 @@
             serverData.username = newUserName
             serverData.password = newPassword
-            if(update):
-                if(updateServerInfo(self.soup, self.soup.serverinfo, self.selectedUid, newServerName, newUrl, newUserName, newPassword)):
-                    if(not self.saveXMLData()):
+            if update:
+                if updateServerInfo(self.soup, self.soup.serverinfo, self.selectedUid, newServerName, newUrl, newUserName, newPassword):
+                    if not self.saveXMLData():
                         oldInfo = self.servers[self.selectedUid]
-                        if(updateServerInfo(self.soup, self.soup.serverinfo, self.selectedUid, oldInfo.servername, oldInfo.url, oldInfo.username, oldInfo.password)):
-                            message = 'Unable to SaveXML, changes reverted back'
+                        if updateServerInfo(self.soup, self.soup.serverinfo, self.selectedUid, oldInfo.servername, oldInfo.url, oldInfo.username, oldInfo.password):
+                            message = _('Unable to save XML, changes reverted back')
                             return
                         else:
-                            message = 'Unable to SaveXML, changes will be reverted back on restart'
+                            message = _('Unable to save XML, changes will be reverted back on restart')
                             return
                     message = 'update save successful'
@@ -234,27 +291,27 @@
                     msg = self.map_servernameTouid
                     Publisher().sendMessage(("update.map_servernameTouid"), msg)
-                    message = "Server Info Updated"
+                    message = _("Server Info Updated")
                     grass.message(message)
                     self.setModified(False)
                 else:
-                    message = "Update not Successful"
+                    message = _("Update not Successful")
             else:
                 uid = str(uuid.uuid4())
-                if(addServerInfo(self.soup, self.soup.serverinfo, uid, newServerName, newUrl, newUserName, newPassword)):
-                        if(removeServerInfo(self.soup, uid)):
-                            message = 'Unable to SaveXML, Info not saved'
+                if addServerInfo(self.soup, self.soup.serverinfo, uid, newServerName, newUrl, newUserName, newPassword):
+                        if removeServerInfo(self.soup, uid):
+                            message = _('Unable to save XML. Info not saved')
                             return
                         else:
+                            message = _('Unable to save XML. Changes will be reverted back on restart')
                             return
                     message = 'soup save successfully'
@@ -282,21 +339,20 @@
             self.selectedURL = newUrl
             self.__update_URL_List()
         else:
-            message = "Please fill servername and url fields"
+            message = _("Please fill in server name")
         self.editOn = False
         if(event):
             event.Skip()
     def OnRemove(self, event): # wxGlade: ServerAdd.<event_handler>
-            message = "No Server selected....Remove Unsuccessful"
+            message = _("No server selected. Remove unsuccessful")
@@ -446,18 +502,18 @@
         try:
             TMP = grass.tempfile()
             if TMP is None:
-                grass.fatal_error("Unable to create temporary files")
+                grass.fatal_error(_("Unable to create temporary files"))
             f = open(TMP,'w')
             f.write(xml)
             f.close()
         except:
-            message = 'Unable to write in '+TMP+' file, Save not successful'
+            message = _('Unable to write in %s file. Save not successful') % TMP
             return False
-        try:
-            copyCommand = "cp "+TMP+" ServersList.xml"
+        try:
+            copyCommand = "cp "+TMP+" ServersList.xml" # FIXME
             r, w, e = popen2.popen3(copyCommand)
-            if(len(e.readlines())!=0):
+            if len(e.readlines()) != 0:
                 message = 'Copy failed, raising excpetion in savexml()'
                 r.close()
@@ -473,7 +529,9 @@
         return True
     def allFieldsValid(self, newServerName, newUrl, newUserName, newPassword):
-        if(newServerName.count(self.name_url_delimiter)>0):
+        # FIXME All texts should be encoded and accept all characters!
+        # Šitajam vajadzētu pazust, ja izmanto XML, kas automātiski kodē tekstus.
+        if newServerName.count(self.name_url_delimiter) > 0:
                 message = "Warning: UserName cannot consist of "+self.name_url_delimiter
@@ -481,7 +539,7 @@
                 return False
-        if(newUrl.count(self.name_url_delimiter)>0):
+        if newUrl.count(self.name_url_delimiter) > 0:
                 message = "Warning: URL cannot consist of "+self.name_url_delimiter
                 StatusBar_fields = ["Warning: URL Delimiter conflict. Edit config file"]
@@ -518,8 +576,8 @@
         return True
-    def validateUrl(self,url):
-        message = 'Validating Url...'
+    def validateUrl(self, url):
+        message = _('Validating URL...')
         req = Request(url)
@@ -541,7 +599,7 @@
             message = 'urlopen exception, unable to fetch data for getcapabilities'
             message = str(e)
-        if(not message=='Successful'):
+        if not message == 'Successful':
             return False, message
         else:
             return True, message
