[GRASS-SVN] r50811 - grass/trunk/vector/v.surf.bspline
Tue Feb 14 04:19:32 EST 2012
Author: hamish
Date: 2012-02-14 01:19:32 -0800 (Tue, 14 Feb 2012)
New Revision: 50811
   grass/trunk/vector/v.surf.bspline/crosscorr.c
cross-validation table cosmetics;
spelling in comments; whitespace  (merge from devbr6)
Modified: grass/trunk/vector/v.surf.bspline/crosscorr.c
--- grass/trunk/vector/v.surf.bspline/crosscorr.c	2012-02-14 08:48:19 UTC (rev 50810)
+++ grass/trunk/vector/v.surf.bspline/crosscorr.c	2012-02-14 09:19:32 UTC (rev 50811)
@@ -31,7 +31,7 @@
 int cross_correlation(struct Map_info *Map, double passWE, double passNS)
-       Map: Map in which cross crorrelation will take values
+       Map: Vector map from which cross-crorrelation will take values
        passWE: spline step in West-East direction
        passNS: spline step in North-South direction
@@ -46,6 +46,9 @@
     /* double lambda[PARAM_LAMBDA] = { 0.0001, 0.001, 0.01, 0.1, 1.0, 10.0 }; */	/* Fixed values (by the moment) */
     double lambda[PARAM_LAMBDA] = { 0.0001, 0.001, 0.005, 0.01, 0.02, 0.05 };	/* Fixed values (by the moment) */
+    /* a more exhaustive search:
+    #define PARAM_LAMBDA 11
+    double lambda[PARAM_LAMBDA] = { 0.0001, 0.0005, 0.001, 0.005, 0.01, 0.05, 0.1, 0.5, 1.0, 5.0, 10.0 }; */
     double *TN, *Q, *parVect;	/* Interpolation and least-square vectors */
     double **N, **obsVect;	/* Interpolation and least-square matrix */
@@ -92,7 +95,7 @@
 	int BW;
 	double mean_reg, *obs_mean;
-	int nrec, ctype = 0;
+	int nrec, ctype = 0, verbosity;
 	struct field_info *Fi;
 	dbDriver *driver_cats;
@@ -100,6 +103,8 @@
 	rms = G_alloc_vector(PARAM_LAMBDA);	/* number of parameter used used for cross validation */
 	stdev = G_alloc_vector(PARAM_LAMBDA);
+	verbosity = G_verbose(); /* store for later reset */
 	/* Working with attributes */
 	if (bspline_field > 0) {
 	    db_CatValArray_init(&cvarr);
@@ -154,30 +159,31 @@
 	TN = G_alloc_vector(nparam_spl);	/* vector */
 	parVect = G_alloc_vector(nparam_spl);	/* Parameters vector */
 	obsVect = G_alloc_matrix(ndata, 3);	/* Observation vector */
-	Q = G_alloc_vector(ndata);	/* "a priori" var-cov matrix */
+	Q = G_alloc_vector(ndata);		/* "a priori" var-cov matrix */
 	obs_mean = G_alloc_vector(ndata);
 	stat_vect = alloc_Stats(ndata);
 	for (lbd = 0; lbd < PARAM_LAMBDA; lbd++) {	/* For each lambda value */
-	    G_message(_("Begining cross validation with "
-			"lambda_i=%.4f..."), lambda[lbd]);
+	    G_message(_("Beginning cross validation with "
+		        "lambda_i=%.4f ... (%d of %d)"), lambda[lbd],
+		      lbd+1, PARAM_LAMBDA);
-	       How cross correlation algorithm is done:
-	       For each cicle, only the first ndata-1 "observ" elements are considered for the
+	       How the cross correlation algorithm is done:
+	       For each cycle, only the first ndata-1 "observ" elements are considered for the
 	       interpolation. Within every interpolation mean is calculated to lowering edge
-	       errors. The point let out will be used for an estimation. The error between the
+	       errors. The point left out will be used for an estimation. The error between the
 	       estimation and the observation is recorded for further statistics.
-	       At the end of the cicle, the last point, that is, the ndata-1 index, and the point
+	       At the end of the cycle, the last point, that is, the ndata-1 index, and the point
 	       with j index are swapped.
 	    for (j = 0; j < ndata; j++) {	/* Cross Correlation will use all ndata points */
-		double out_x, out_y, out_z;	/* This point is let out */
+		double out_x, out_y, out_z;	/* This point is left out */
 		for (i = 0; i < ndata; i++) {	/* Each time, only the first ndata-1 points */
-		    double dval;	/* are considered in the interpolation */
+		    double dval;		/* are considered in the interpolation */
 		    /* Setting obsVect vector & Q matrix */
 		    Q[i] = 1;	/* Q=I */
@@ -228,7 +234,7 @@
 		    obsVect[i][2] -= mean_reg;
-		/* This is let out */
+		/* This is left out */
 		out_x = observ[ndata - 1].coordX;
 		out_y = observ[ndata - 1].coordY;
 		out_z = obsVect[ndata - 1][2];
@@ -252,7 +258,9 @@
 		   if (bilin) interpolation (&interp, P_BILINEAR);
 		   else interpolation (&interp, P_BICUBIC);
+		G_set_verbose(G_verbose_min());
 		G_math_solver_cholesky_sband(N, parVect, TN, nparam_spl, BW);
+		G_set_verbose(verbosity);
 		/* Estimation of j-point */
 		if (bilin)
@@ -267,12 +275,15 @@
 					     nsplx, nsply, region.west,
 					     region.south, parVect);
-		/*Difference between estimated and observated i-point */
+		/* Difference between estimated and observated i-point */
 		stat_vect.error[j] = out_z - stat_vect.estima[j];
 		G_debug(1, "CrossCorrelation: stat_vect.error[%d]  =  %lf", j,
 			stat_vect.error[j]);
-		observ = swap(observ, j, ndata - 1);	/* Once the last value is let out, it is swap with j-value */
+		/* Once the last value is left out, it is swaped with j-value */
+		observ = swap(observ, j, ndata - 1);
+		G_percent(j, ndata, 2);
 	    mean[lbd] = calc_mean(stat_vect.error, stat_vect.n_points);
@@ -282,8 +293,9 @@
 		calc_standard_deviation(stat_vect.error, stat_vect.n_points);
 	    G_message(_("Mean = %.5lf"), mean[lbd]);
-	    G_message(_("Root Means Square (RMS) = %.5lf"),
+	    G_message(_("Root Mean Square (RMS) = %.5lf"),
 		      rms[lbd]);
+	    G_message("---");
 	}			/* ENDFOR each lambda value */
 	G_free_matrix(N);
@@ -293,7 +305,7 @@
 	G_free_vector(parVect);
 #ifdef nodef
 	/*TODO: if the minimum lambda is wanted, the function declaration must be changed */
-	/*At this moment, consider rms only */
+	/* At this moment, consider rms only */
 	rms_min = find_minimum(rms, &lbd_min);
 	stdev_min = find_minimum(stdev, &lbd_min);
@@ -308,11 +320,11 @@
 	*lambda_min = lambda[lbd_min];
 #endif
-	G_message(_("Results into a table:"));
-	G_message(_(" lambda    | mean        | rms         |"));
+	G_message(_("Table of results:"));
+	fprintf(stdout, _("    lambda |       mean |        rms |\n"));
-	    G_message(_(" %-10.5f| %-12.4f| %-12.4f|"), lambda[lbd],
-		      mean[lbd], rms[lbd]);
+	    fprintf(stdout, " %9.5f | %10.4f | %10.4f |\n", lambda[lbd],
+		    mean[lbd], rms[lbd]);
 	G_free_vector(mean);
@@ -428,8 +440,8 @@
 struct Point *swap(struct Point *point, int a, int b)
-    SWAP(point[a].coordX, point[b].coordX);	/* Once the last value is let out, it is swap with j-value */
+    SWAP(point[a].coordX, point[b].coordX);
     SWAP(point[a].coordY, point[b].coordY);
     SWAP(point[a].coordZ, point[b].coordZ);
     SWAP(point[a].cat, point[b].cat);
