[GRASS-SVN] r50812 - in grass-addons/grass6/display: . d.zoom.keys
Tue Feb 14 05:23:30 EST 2012
Author: amuriy
Date: 2012-02-14 02:23:30 -0800 (Tue, 14 Feb 2012)
New Revision: 50812
Added:
   grass-addons/grass6/display/d.zoom.keys/
   grass-addons/grass6/display/d.zoom.keys/Makefile
   grass-addons/grass6/display/d.zoom.keys/d.zoom.keys
   grass-addons/grass6/display/d.zoom.keys/description.html
<d.zoom.keys> added to grass6/display
Added: grass-addons/grass6/display/d.zoom.keys/Makefile
--- grass-addons/grass6/display/d.zoom.keys/Makefile	                        (rev 0)
+++ grass-addons/grass6/display/d.zoom.keys/Makefile	2012-02-14 10:23:30 UTC (rev 50812)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = d.zoom.keys
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass6/display/d.zoom.keys/d.zoom.keys
--- grass-addons/grass6/display/d.zoom.keys/d.zoom.keys	                        (rev 0)
+++ grass-addons/grass6/display/d.zoom.keys/d.zoom.keys	2012-02-14 10:23:30 UTC (rev 50812)
@@ -0,0 +1,343 @@
+#!/bin/sh
+# MODULE:       d.zoom.keys
+# AUTHOR(S):    Alexander Muriy
+#               (Institute of Environmental Geoscience, Moscow, Russia)
+#               e-mail: amuriy AT gmail DOT com
+# PURPOSE:      Allows to change the current geographic region settings interactively, with a keyboard.
+# COPYRIGHT:    (C) 02/2012 Alexander Muriy / GRASS Development Team
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+#%Module
+#%  description: Allows to change the current geographic region settings interactively, with a keyboard. Use arrow keys to navigate, "-" to make futher, "+" (without "Shift") to make closer.
+#%  keywords: display, zoom
+#%End
+#%Option
+#%  key: mon
+#%  type: string
+#%  required: no
+#%  key_desc: name
+#%  description: Name of graphics monitor to select (default is currently selected monitor).
+#%End
+#%Option
+#%  key: magn
+#%  type: double
+#%  required: no
+#%  multiple: no
+#%  key_desc: number
+#%  description: Magnification: default is "1" (1/10 of current region). "magn" > 1 gives positive magnification, "magn" < 1 gives negative one.
+#%End
+#%Flag
+#% key: t
+#% description: Use navigation from terminal
+#%End
+#%Flag
+#% key: x
+#% description: Use navigation in X-monitor (requires <xev> and <xdotool>)
+#%End
+#%Flag
+#% key: r
+#% description: Decrease region resolution during navigation
+#%End
+if [ -z "$GISBASE" ] ; then
+    echo "You must be in GRASS GIS to run this program." 1>&2
+    exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+    exec g.parser "$0" "$@"
+fi
+## set environment so that awk works properly in all languages ##
+unset LC_ALL
+export LC_NUMERIC=C
+cleanup()
+    rm -f "$TMP*"
+    if [ "$GIS_FLAG_T" -eq 1 ]; then
+	stty "$tty_save"
+    fi
+    if [ "$GIS_FLAG_R" -eq 1 ]; then
+	g.region nsres="$OLD_NSRES" ewres="$OLD_EWRES"
+	d.redraw --q
+    fi
+## what to do in case of user break:
+exitprocedure()
+    echo ""
+    echo "User break!"
+    cleanup
+    exit 1
+## shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
+## check for <xev>
+if [ "$GIS_FLAG_X" -eq 1 ] && [ ! -x "$(which xev)" ] ; then
+    g.message -e "<xev> required, please install it first"
+    exit 1
+fi
+## check for <xdotool>
+if [ "$GIS_FLAG_X" -eq 1 ] && [ ! -x "$(which xdotool)" ] ; then
+    g.message -e "<xdotool> required, please install it first"
+    exit 1
+fi
+## check for <awk>
+if [ ! -x "$(which awk)" ] ; then
+    g.message -e "<awk> required, please install <awk> or <gawk> first"
+    exit 1
+fi
+## setup temporary files
+TMP="$(g.tempfile pid=$$)"
+if [ "$?" -ne 0 ] || [ -z "$TMP" ] ; then
+    g.message -e "ERROR: Unable to create temporary files."
+    exit 1
+fi
+## DO IT
+if [ "$(d.mon -p | cut -f1 -d' ')" != "Currently" ] ; then
+    g.message -e "No active monitors. Please start <d.mon ...> first"
+    exit 1
+fi
+if [ "$GIS_FLAG_X" -eq 0 ] && [ "$GIS_FLAG_T" -eq 0 ]; then
+    g.message -e "Please select method of navigation: flag \"-t\" from terminal or flag \"-x\" from X-monitor"
+    exit 1
+fi
+if [ "$GIS_FLAG_X" -eq 1 ] && [ "$GIS_FLAG_T" -eq 1 ]; then
+    g.message -e "Please select one method of navigation: flag \"-t\" from terminal or flag \"-x\" from X-monitor"
+    exit 1
+fi
+MAGN_NEGAT=$(echo "$GIS_OPT_MAGN" | grep "-")
+if [ "$MAGN_NEGAT" ]; then
+    g.message -e "Magnification should be a positive number: default is "1" (1/10 of current region). "magn" > 1 gives positive magnification, "magn" < 1 gives negative one."
+    exit 1
+fi
+## region stuff
+if [ "$GIS_FLAG_R" -eq 1 ]; then
+    eval $(g.region -g)
+    OLD_NSRES="$nsres"
+    OLD_EWRES="$ewres"
+    curr_res=$(echo "$nsres" "$ewres" | awk '{x=($1+$2)/2; print x}')
+    tmp_res=$(echo "$curr_res" | awk '{x=$1*3; print x}')
+    g.region res="$tmp_res"
+fi
+eval $(g.region -eg)
+ns_extent_round=$(printf "%.0f\n" $ns_extent)
+ew_extent_round=$(printf "%.0f\n" $ew_extent)
+if [ -z "$GIS_OPT_MAGN" ]; then
+    MAGN=1
+else
+    MAGN="$GIS_OPT_MAGN"
+fi
+east_step=$(echo $ew_extent_round "$MAGN" | awk '{e=($1/10)*$2; print e}')
+north_step=$(echo $ns_extent_round "$MAGN" | awk '{n=($1/10)*$2; print n}')
+## monitors stuff
+curr_mon=$(d.mon -p | cut -d':' -f2 | sed 's/^ //g')
+if [ -z "$GIS_OPT_MON" ]; then
+    MON="$curr_mon"
+else
+    MON="$GIS_OPT_MON"
+fi
+NOT_RUN=$(d.mon -L | grep "$MON" | grep "not running")
+if [ -z "$NOT_RUN" ]; then
+    d.mon select="$MON"
+else
+    g.message -e "Monitor <"$MON"> is not running. Please run or select it first"
+    exit 1
+fi
+####  navigation in X-monitor
+if [ "$GIS_FLAG_X" -eq 1 ]; then
+### make actions scripts for AWK
+    for ACTIONS in up down left right closer futher; do
+	SCRIPT="${TMP}_"$ACTIONS".sh"
+	echo '#!/bin/sh' > $SCRIPT
+	case "$ACTIONS" in
+	    up)
+		echo "g.region n=n-"$north_step" s=s-"$north_step"" >> $SCRIPT
+		echo "d.redraw --q" >> $SCRIPT
+	    down)
+		echo "g.region n=n+"$north_step" s=s+"$north_step"" >> $SCRIPT
+	    left)
+		echo "g.region w=w+"$east_step" e=e+"$east_step"" >> $SCRIPT
+	    right)
+		echo "g.region w=w-"$east_step" e=e-"$east_step"" >> $SCRIPT
+	    closer)
+		echo "g.region w=w+"$east_step" e=e-"$east_step" n=n-"$north_step" s=s+"$north_step"" >> $SCRIPT
+	    futher)
+		echo "g.region w=w-"$east_step" e=e+"$east_step" n=n+"$north_step" s=s-"$north_step"" >> $SCRIPT
+	esac
+    done
+    eval $(g.gisenv)
+    GRASS_version=$(g.version -g | grep "version" | cut -d'=' -f2)
+    window_search="GRASS "${GRASS_version}" - Monitor: "${MON}" - Location: "${LOCATION_NAME}""
+    GRASS_wid=$(xdotool search --title "${window_search}")
+    xdotool windowactivate "${GRASS_wid}"
+    xev -id "${GRASS_wid}" | awk '/keycode/ {print $4; fflush()}' | while read -r xev_code; do
+	awk -v TMP="$TMP" -v xev="${xev_code}" 'NR % 2 { next }
+          if ($0 == 111)
+          system ("sh "TMP"_up.sh")
+          else if ($0 == 116)
+          system ("sh "TMP"_down.sh")
+          else if ($0 == 113)
+          system ("sh "TMP"_left.sh")
+          else if ($0 == 114)
+          system ("sh "TMP"_right.sh")
+          else if ($0 == 20)
+          system ("sh "TMP"_futher.sh")
+          else if ($0 == 21)
+          system ("sh "TMP"_closer.sh")
+    done
+fi
+#### navigation in terminal
+if [ "$GIS_FLAG_T" -eq 1 ]; then
+    tty_save=$(stty -g)
+    get_odx()
+	od -t o1 | awk '{ for (i=2; i<=NF; i++)
+                        printf("%s%s", i==2 ? "" : " ", $i)
+                        exit }'
+# Grab terminal capabilities
+    tty_cuu1=$(tput cuu1 2>&1 | get_odx)            # up arrow
+    tty_kcuu1=$(tput kcuu1 2>&1 | get_odx)
+    tty_cud1=$(tput cud1 2>&1 | get_odx)            # down arrow
+    tty_kcud1=$(tput kcud1 2>&1 | get_odx)
+    tty_cub1=$(tput cub1 2>&1 | get_odx)            # left arrow
+    tty_kcub1=$(tput kcud1 2>&1 | get_odx)
+    tty_cuf1=$(tput cuf1 2>&1 | get_odx)            # right arrow
+    tty_kcuf1=$(tput kcud1 2>&1 | get_odx)
+# Some terminals send the wrong code for certain arrow keys
+    if [ "$tty_cuu1" = "033 133 101" -o "$tty_kcuu1" = "033 133 101" ]; then
+	tty_cudx="033 133 102"
+	tty_cufx="033 133 103"
+	tty_cubx="033 133 104"
+    fi
+    stty cs8 -icanon -echo min 10 time 1
+    stty intr '' susp ''
+    while true; do
+	keypress=$(dd bs=10 count=1 2> /dev/null | get_odx)
+	case "$keypress" in
+	    "$tty_cuu1"|"$tty_kcuu1")
+		g.region n=n-"$north_step" s=s-"$north_step"
+		d.redraw --q
+	    "$tty_cud1"|"$tty_kcud1"|"$tty_cudx")
+		g.region n=n+"$north_step" s=s+"$north_step"
+		d.redraw --q
+	    "$tty_cub1"|"$tty_kcub1"|"$tty_cubx")
+		g.region w=w+"$east_step" e=e+"$east_step"
+		d.redraw --q
+	    "$tty_cuf1"|"$tty_kcuf1"|"$tty_cufx")
+		g.region w=w-"$east_step" e=e-"$east_step"
+		d.redraw --q
+	    055)
+		g.region w=w-"$east_step" e=e+"$east_step" n=n+"$north_step" s=s-"$north_step"
+		d.redraw --q
+	    075)
+		g.region w=w+"$east_step" e=e-"$east_step" n=n-"$north_step" s=s+"$north_step"
+		d.redraw --q
+	    003)
+		stty $tty_save;
+		break
+	esac
+    done
+fi
+cleanup
+exit 0
Property changes on: grass-addons/grass6/display/d.zoom.keys/d.zoom.keys
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass6/display/d.zoom.keys/description.html
--- grass-addons/grass6/display/d.zoom.keys/description.html	                        (rev 0)
+++ grass-addons/grass6/display/d.zoom.keys/description.html	2012-02-14 10:23:30 UTC (rev 50812)
@@ -0,0 +1,48 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>GRASS GIS manual: d.zoom.keys</title>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<body bgcolor="white">
+<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
+<h2>NAME</h2>
+<em><b>d.zoom.keys</b></em>  - Allows to change the current geographic region settings interactively, with a keyboard. Use arrow keys to navigate, "-" to make futher, "+" (without "Shift") to make closer.
+<h2>KEYWORDS</h2>
+display, zoom
+<h2>SYNOPSIS</h2>
+<b>d.zoom.keys</b><br>
+<b>d.zoom.keys help</b><br>
+<b>d.zoom.keys</b> [-<b>txr</b>]  [<b>mon</b>=<em>name</em>]   [<b>magn</b>=<em>number</em>]   [--<b>verbose</b>]  [--<b>quiet</b>]
+<h3>Flags:</h3>
+<DL>
+<DT><b>-t</b></DT>
+<DD>Use navigation from terminal</DD>
+<DT><b>-x</b></DT>
+<DD>Use navigation in X-monitor (requires <xev> and <xdotool>)</DD>
+<DT><b>-r</b></DT>
+<DD>Decrease region resolution during navigation</DD>
+<DT><b>--verbose</b></DT>
+<DD>Verbose module output</DD>
+<DT><b>--quiet</b></DT>
+<DD>Quiet module output</DD>
+</DL>
+<h3>Parameters:</h3>
+<DL>
+<DT><b>mon</b>=<em>name</em></DT>
+<DD>Name of graphics monitor to select (default is currently selected monitor).</DD>
+<DT><b>magn</b>=<em>number</em></DT>
+<DD>Magnification: default is "1" (1/10 of current region). "magn" &gt; 1 gives positive magnification, "magn" &lt; 1 gives negative one.</DD>
+</DL>
+</body>
+</html>
