[GRASS-SVN] r50445 - grass/trunk/vector/v.info
Wed Jan 25 09:42:31 EST 2012
Author: huhabla
Date: 2012-01-25 06:42:31 -0800 (Wed, 25 Jan 2012)
New Revision: 50445
   grass/trunk/vector/v.info/print.c
Print timestamp from the first layer
Modified: grass/trunk/vector/v.info/print.c
--- grass/trunk/vector/v.info/print.c	2012-01-25 14:20:48 UTC (rev 50444)
+++ grass/trunk/vector/v.info/print.c	2012-01-25 14:42:31 UTC (rev 50445)
@@ -235,7 +235,7 @@
     struct bound_box box;
     /*Check the Timestamp */
-    time_ok = G_read_vector_timestamp(Vect_get_name(Map), "", &ts);
+    time_ok = G_read_vector_timestamp(Vect_get_name(Map), NULL, "", &ts);
     /*Check for valid entries, show none if no timestamp available */
     if (time_ok == 1) {
 	if (ts.count > 0)
@@ -299,10 +299,10 @@
     /*This shows the TimeStamp */
     if (time_ok  == 1 && (first_time_ok || second_time_ok)) {
         G_format_timestamp(&ts, timebuff);
-        sprintf(line, "%-17s%s", _("Timestamp: "), timebuff);
+        sprintf(line, "%-17s%s", _("Timestamp first layer: "), timebuff);
     else {
-        sprintf(line, "%-17s%s", _("Timestamp: none"), timebuff);
+        sprintf(line, "%-17s%s", _("Timestamp first layer: none"), timebuff);
     printline(line);
