[GRASS-SVN] r50444 - in grass/trunk: include/defs lib/gis vector/v.timestamp vector/v.timestamp/test_suite
Wed Jan 25 09:20:48 EST 2012
Author: huhabla
Date: 2012-01-25 06:20:48 -0800 (Wed, 25 Jan 2012)
New Revision: 50444
   grass/trunk/include/defs/gis.h
   grass/trunk/lib/gis/timestamp.c
   grass/trunk/vector/v.timestamp/main.c
   grass/trunk/vector/v.timestamp/test_suite/test.v.timestamp.sh
Timestamp support for vector layers added.
Modified: grass/trunk/include/defs/gis.h
--- grass/trunk/include/defs/gis.h	2012-01-25 14:06:13 UTC (rev 50443)
+++ grass/trunk/include/defs/gis.h	2012-01-25 14:20:48 UTC (rev 50444)
@@ -624,10 +624,10 @@
 int G_read_raster_timestamp(const char *, const char *, struct TimeStamp *);
 int G_write_raster_timestamp(const char *, const struct TimeStamp *);
 int G_remove_raster_timestamp(const char *);
-int G_has_vector_timestamp(const char *, const char *);
-int G_read_vector_timestamp(const char *, const char *, struct TimeStamp *);
-int G_write_vector_timestamp(const char *, const struct TimeStamp *);
-int G_remove_vector_timestamp(const char *);
+int G_has_vector_timestamp(const char *, const char *, const char *);
+int G_read_vector_timestamp(const char *, const char *, const char *, struct TimeStamp *);
+int G_write_vector_timestamp(const char *, const char *, const struct TimeStamp *);
+int G_remove_vector_timestamp(const char *, const char *);
 int G_has_raster3d_timestamp(const char *, const char *);
 int G_read_raster3d_timestamp(const char *, const char *, struct TimeStamp *);
 int G_remove_raster3d_timestamp(const char *);
Modified: grass/trunk/lib/gis/timestamp.c
--- grass/trunk/lib/gis/timestamp.c	2012-01-25 14:06:13 UTC (rev 50443)
+++ grass/trunk/lib/gis/timestamp.c	2012-01-25 14:20:48 UTC (rev 50444)
@@ -411,19 +411,28 @@
   \brief Check if timestamp for vector map exists
   \param name map name
+  \param layer The layer names, in case of NULL, layer one is assumed
   \param mapset mapset name
   \return 1 on success
   \return 0 no timestamp present
-int G_has_vector_timestamp(const char *name, const char *mapset)
+int G_has_vector_timestamp(const char *name, const char *layer, const char *mapset)
     char dir[GPATH_MAX];
     char path[GPATH_MAX + GNAME_MAX];
+    char ele[GNAME_MAX];
+    if(layer != NULL)
+        G_snprintf(ele, GNAME_MAX, "%s_%s", GV_TIMESTAMP_ELEMENT, layer);
+    else
+        G_snprintf(ele, GNAME_MAX, "%s_1", GV_TIMESTAMP_ELEMENT);
     G_snprintf(dir, GPATH_MAX, "%s/%s", GV_DIRECTORY, name);
-    G_file_name(path, dir, GV_TIMESTAMP_ELEMENT, mapset);
+    G_file_name(path, dir, ele, mapset);
+    G_debug(1, "Check for timestamp <%s>", path);
     if (access(path, R_OK) != 0)
 	return 0;
@@ -434,6 +443,7 @@
   \brief Read timestamp from vector map
   \param[out] ts TimeStamp struct to populate
@@ -442,19 +452,28 @@
   \return -1 Unable to open file
   \return -2 invalid time stamp
-int G_read_vector_timestamp(const char *name, const char *mapset,
-			    struct TimeStamp *ts)
+int G_read_vector_timestamp(const char *name, const char *layer,
+                            const char *mapset, struct TimeStamp *ts)
     FILE *fd;
     int stat;
     /* In case no timestamp file is present return 0 */
-    if (G_has_vector_timestamp(name, mapset) != 1)
+    if (G_has_vector_timestamp(name, layer, mapset) != 1)
 	return 0;
+    if(layer != NULL)
+    else
-    fd = G_fopen_old(dir, GV_TIMESTAMP_ELEMENT, mapset);
+    G_debug(1, "Read timestamp <%s/%s>", dir, ele);
+    fd = G_fopen_old(dir, ele, mapset);
     if (fd == NULL) {
 	G_warning(_("Unable to open timestamp file for vector map <%s@%s>"),
@@ -475,6 +494,7 @@
   \brief Write timestamp of vector map
@@ -482,15 +502,23 @@
   \return -2 error - invalid datetime in ts
-int G_write_vector_timestamp(const char *name, const struct TimeStamp *ts)
+int G_write_vector_timestamp(const char *name, const char *layer, const struct TimeStamp *ts)
     FILE *fd;
     int stat;
+    if(layer != NULL)
+    else
-    fd = G_fopen_new(dir, GV_TIMESTAMP_ELEMENT);
+    G_debug(1, "Write timestamp <%s/%s>", dir, ele);
+    fd = G_fopen_new(dir, ele);
     if (fd == NULL) {
 	G_warning(_("Unable to create timestamp file for vector map <%s@%s>"),
@@ -513,17 +541,24 @@
   Only timestamp files in current mapset can be removed.
   \return 0 if no file
   \return -1 on failure
-int G_remove_vector_timestamp(const char *name)
+int G_remove_vector_timestamp(const char *name, const char *layer)
+    if(layer)
+    else
-    return G_remove(dir, GV_TIMESTAMP_ELEMENT);
+    return G_remove(dir, ele);
Modified: grass/trunk/vector/v.timestamp/main.c
--- grass/trunk/vector/v.timestamp/main.c	2012-01-25 14:06:13 UTC (rev 50443)
+++ grass/trunk/vector/v.timestamp/main.c	2012-01-25 14:20:48 UTC (rev 50444)
@@ -24,7 +24,7 @@
 int main(int argc, char *argv[])
     struct GModule *module;
-    struct Option *map, *date;
+    struct Option *map, *layer, *date;
     struct TimeStamp ts;
     char *name;
     const char *mapset;
@@ -40,6 +40,7 @@
     module->description = _("Print/add/remove a timestamp for a vector map.");
     map = G_define_standard_option(G_OPT_V_MAP);
+    layer = G_define_standard_option(G_OPT_V_FIELD);
     date = G_define_option();
     date->key = "date";
@@ -68,7 +69,7 @@
     if (!modify) {
-	if (G_read_vector_timestamp(name, "", &ts) == 1) {
+	if (G_read_vector_timestamp(name, layer->answer, "", &ts) == 1) {
 	    G__write_timestamp(stdout, &ts);
 	    exit(EXIT_SUCCESS);
@@ -76,14 +77,14 @@
 	    exit(EXIT_FAILURE);
     if (strcmp(date->answer, "none") == 0) {
-	G_remove_vector_timestamp(name);
+	G_remove_vector_timestamp(name, layer->answer);
 	exit(EXIT_SUCCESS);
     if(G_scan_timestamp(&ts, date->answer) != 1)
         G_fatal_error("Timestamp format is invalid");
-    G_write_vector_timestamp(name, &ts);
+    G_write_vector_timestamp(name, layer->answer, &ts);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.timestamp/test_suite/test.v.timestamp.sh
--- grass/trunk/vector/v.timestamp/test_suite/test.v.timestamp.sh	2012-01-25 14:06:13 UTC (rev 50443)
+++ grass/trunk/vector/v.timestamp/test_suite/test.v.timestamp.sh	2012-01-25 14:20:48 UTC (rev 50444)
@@ -12,24 +12,30 @@
 # The first @test uses several different absolute datum formats
 v.timestamp map=map date=none
 v.timestamp map=map
-v.timestamp map=map date="2003"
-v.timestamp map=map date="Jul 2003"
+v.timestamp map=map layer=1 date="2003"
+v.timestamp map=map layer=2 date="Jul 2003"
 v.timestamp map=map date="14 Jul 2003"
 v.timestamp map=map
 v.timestamp map=map date="14 Jul 2003 10"
 v.timestamp map=map
-v.timestamp map=map date="14 Jul 2003 10:30 +0700"
-v.timestamp map=map date="14 Jul 2003 10:30:25"
+v.timestamp map=map layer=3 date="14 Jul 2003 10:30 +0700"
+v.timestamp map=map layer=4 date="14 Jul 2003 10:30:25"
 v.timestamp map=map date="14 Jul 2003 10:30:25 +0700 / 15 Jul 2003 11:35:12 +0700"
 v.timestamp map=map
 v.timestamp map=map date="14 Jul 2003 10:30:25 +0700 / 15 Jul 2003"
 v.timestamp map=map
+v.timestamp map=map layer=2 date=none
+v.timestamp map=map layer=3 date=none
+v.timestamp map=map layer=4 date=none
 v.timestamp map=map
 # The second @test uses several different relative datum formats
@@ -38,15 +44,19 @@
 v.timestamp map=map
 v.timestamp map=map date="2 years 3 months"
 v.timestamp map=map
-v.timestamp map=map date="5 days"
-v.timestamp map=map date="3 hours"
+v.timestamp map=map layer=1 date="5 days"
+v.timestamp map=map layer=2 date="3 hours"
 v.timestamp map=map date="5 minutes 30 seconds"
 v.timestamp map=map
 v.timestamp map=map date="2 years 2 months / 5 years 8 months"
+v.timestamp map=map date=none
 v.timestamp map=map
-v.timestamp map=map date=none
 # The third @test to check @failure with wrong time stamps
 v.timestamp map=map date="2 years 3 months 8 days"
