[GRASS-SVN] r52451 - grass-addons/grass7/imagery/i.segment
Wed Jul 25 09:49:57 PDT 2012
Author: momsen
Date: 2012-07-25 09:49:57 -0700 (Wed, 25 Jul 2012)
New Revision: 52451
   grass-addons/grass7/imagery/i.segment/create_isegs.c
   grass-addons/grass7/imagery/i.segment/iseg.h
   grass-addons/grass7/imagery/i.segment/open_files.c
   grass-addons/grass7/imagery/i.segment/parse_args.c
find_neighbors() returns only one pixel per bordering segment, added (quickly tested) option to limit merges to one per pass
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c	2012-07-25 15:29:10 UTC (rev 52450)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c	2012-07-25 16:49:57 UTC (rev 52451)
@@ -42,13 +42,14 @@
     /* processing loop for polygon/boundary constraints */
+    if (files->bounds_map != NULL)
+	G_message(_("Running region growing algorithm, the percent completed is based the range of values in the boundary constraints map"));
     for (files->current_bound = lower_bound;
 	 files->current_bound <= upper_bound; files->current_bound++) {
-	if (files->bounds_map == NULL)
-	    G_message(_("Running region growing algorithm, the percent completed is based the range of values in the boundary constraints map"));
-	G_percent(files->current_bound - lower_bound,
-		  upper_bound - lower_bound, 1);
+	    G_percent(files->current_bound - lower_bound,
+		      upper_bound - lower_bound, 1);
 	/* *** check the processing window *** */
@@ -148,7 +149,8 @@
     int row, col;
     /* from speed.c to test speed of malloc vs. memory manager */
-    register int i;
+    long int i;
+    register int j, s;
     struct link_head *head;
     struct pixels *p;
@@ -157,17 +159,78 @@
     /*    G_verbose_message("writing fake data to segmentation file"); */
     G_verbose_message("writing scaled input (layer 1) to output file");
     G_verbose_message("weighted flag = %d", files->weighted);
+    //~ for (row = 0; row < files->nrows; row++) {
+    //~ for (col = 0; col < files->ncols; col++) {
+    //~ /*files->out_val[0] = files->out_val[0]; *//*segment number *//* just copying the map for testing. */
+    //~ /* files->out_val[0] = col + row; */
+    //~ segment_get(&files->bands_seg, (void *)files->bands_val, row,
+    //~ col);
+    //~ files->iseg[row][col] = files->bands_val[0] * 100;      /*pushing DCELL into CELL */
+    //~ G_percent(row, files->nrows, 1);
+    /* Trying out peano ordering */
+    /* idea is for large maps, if the width of SEG tiles in RAM is less than the width of the map, this should avoid a lot of I/O */
+    /* this is probably closer to a z-order curve then peano order. */
+    /*blank slate */
-	    /*files->out_val[0] = files->out_val[0]; *//*segment number *//* just copying the map for testing. */
-	    /* files->out_val[0] = col + row; */
-	    segment_get(&files->bands_seg, (void *)files->bands_val, row,
-			col);
-	    files->iseg[row][col] = files->bands_val[0] * 100;	/*pushing DCELL into CELL */
+	    files->iseg[row][col] = -1;
-	G_percent(row, files->nrows, 1);
+    s = 0;
+    //~ for(i=1; i<9; i++)
+    //~ G_message("i: %d", i);
+    //~ for(j=4; j>=0; j--){
+    //~ G_message("\tj=%d, 1 & (i >> j) = %d", j, 1 & (i >> j));
+    for (i = 0; i < 16; i++) {	// if square and power of 2: files->nrows*files->ncols
+	row = col = 0;
+	/*bit wise construct row and col from i */
+	for (j = 8 * sizeof(long int) - 1; j > 1; j--) {
+	    row = row | (1 & (i >> j));
+	    row = row << 1;
+	    j--;
+	    col = col | (1 & (i >> j));
+	    col = col << 1;
+	j--;
+	G_message("Done: i: %li, row: %d, col: %d", i, row, col);
+	files->iseg[row][col] = s;
+	s++;
+    //~ for(i=0; i<8; i++){ //files->nrows*files->ncols
+    //              G_message("i: %d", i);
+    //~ row=col=0;
+    //~ /*bit wise construct row and col from i*/
+    //~ for(j=4; j>0; j=j-2){  //8*sizeof(int)
+    //                      G_message("j: %d", j);
+    //~ row = row | ( i & (1 << (2 * j))); /* row | a[rmax-r]; */
+    //~ row = row << 1;
+    //~ col = col | ( i & (1 << (2 * j + 1)));
+    //~ col = col << 1;
+    //~ G_message("j: %d, row: %d, col: %d", j, row, col);
+    //~ col = col | ( i & (1 << ((2 * j) + 1)));
+    //~ G_message("(1 << ((2 * j) + 1)) = %d", (1 << ((2 * j) + 1)));
+    //~ G_message("Done: i: %d, row: %d, col: %d", i, row, col);
+    //~ files->iseg[row][col] = s;
+    //~ s++;
     /*speed test... showed a difference of 1min 9s for G_malloc and 34s for linkm. (with i < 2000000000   */
 #ifdef LINKM
@@ -677,9 +740,9 @@
     double threshold, Ri_similarity, Rk_similarity, tempsim;
     int endflag;		/* =TRUE if there were no merges on that processing iteration */
     int pathflag;		/* =TRUE if we didn't find mutual neighbors, and should continue with Rk */
-    struct pixels *Ri_head, *Rk_head, *Rin_head, *Rkn_head, *current,
-	*newpixel, *Ri_bestn;
-    int Ri_count, Rk_count;	/* number of pixels/cells in Ri and Rk */
+    struct pixels *Ri_head, *Rk_head, *Rin_head, *Rkn_head, *Rclose_head,
+	*Rc_head, *Rc_tail, *Rcn_head, *current, *newpixel, *Ri_bestn;
+    int Ri_count, Rk_count, Rc_count;	/* number of pixels/cells in Ri and Rk */
     /* files->token has the "link_head" for linkm: linked list memory allocation.
@@ -703,6 +766,9 @@
     Rin_head = NULL;
     Rkn_head = NULL;
     Ri_bestn = NULL;
+    Rclose_head = NULL;
+    Rc_head = NULL;
+    Rcn_head = NULL;
     /* do while loop until no merges are made, or until t reaches maximum number of iterations */
     do {
@@ -735,6 +801,7 @@
 		    my_dispose_list(files->token, &Rk_head);
 		    my_dispose_list(files->token, &Rin_head);
 		    my_dispose_list(files->token, &Rkn_head);
+		    my_dispose_list(files->token, &Rclose_head);
 		    Rk_count = 0;
 		    /* First pixel in Ri is current row/col pixel.  We may add more later if it is part of a segment */
@@ -747,8 +814,9 @@
 		    pathflag = TRUE;
-		    while (pathflag == TRUE && files->candidate_count > 0) {	/*if don't find mutual neighbors on first try, will use Rk as next Ri. */
+		    while (pathflag == TRUE) {	/*if don't find mutual neighbors on first try, will use Rk as next Ri. */
+			//TODO: do I need this && part?  remove candidate_count completely?  Is there a way this loop could get stuck iterating forever???
+			//&& files->candidate_count > 0
 			G_debug(4, "Next starting pixel: row, %d, col, %d",
 				Ri_head->row, Ri_head->col);
@@ -793,6 +861,17 @@
 					"simularity = %g for neighbor : row: %d, col %d.",
 					tempsim, current->row, current->col);
+				/* if very close, will merge, but continue checking other neighbors */
+				//~ if (tempsim < functions->very_close * threshold){
+				//~ /* add to Rclose list */
+				//~ newpixel = (struct pixels *)link_new(files->token);
+				//~ newpixel->next = Rclose_head;
+				//~ newpixel->row = current->row;
+				//~ newpixel->col = current->col;
+				//~ Rclose_head = newpixel;
+				/* If "sort of" close, merge only if it is the mutually most similar */
+				//~ else
 				if (tempsim < Ri_similarity) {
 				    Ri_similarity = tempsim;
 				    Ri_bestn = current;
@@ -803,12 +882,48 @@
 			    }	/* finished similiarity check for all neighbors */
+			    /* *** merge all the "very close" pixels/segments *** */
+			    /* doing this after checking all Rin, so we don't change the bands_val between similarity comparisons
+			     * TODO... but that leaves the possibility that we have the wrong best Neighbor after doing these merges...
+			     * but it seems we can't put this merge after the Rk/Rkn portion of the loop, because we are changing the available neighbors
+			     * ...maybe this extra "very close" idea has to be done completely differently or dropped???  */
+			    for (current = Rclose_head; current != NULL;
+				 current = current->next) {
+				my_dispose_list(files->token, &Rc_head);
+				my_dispose_list(files->token, &Rcn_head);
+				/* get membership of neighbor segment */
+				Rc_count = 1;
+				newpixel =
+				    (struct pixels *)link_new(files->token);
+				newpixel->next = NULL;
+				newpixel->row = current->row;
+				newpixel->col = current->col;
+				Rc_head = Rc_tail = newpixel;
+				find_segment_neighbors(&Rc_head, &Rcn_head, &Rc_count, files, functions);	/* just to get members, not looking at neighbors now */
+				merge_values(Ri_head, Rc_head, Ri_count,
+					     Rc_count, files);
+				/* Add Rc pixels to Ri */
+				Rc_tail->next = Ri_head;
+				Ri_head = Rc_head;
+				//todo, recurse?  Check all Rcn neighbors if they are very close?
+				// not needed if the combining works...   my_dispose_list(files->token, &Rc_head);
+				Rc_head = NULL;
+			    /* check if we have a bestn that is valid to use to look at Rk */
 			    if (Ri_bestn != NULL) {
 				G_debug(4,
 					"Lowest Ri_similarity = %g, for neighbor pixel row: %d col: %d",
 					Ri_similarity, Ri_bestn->row,
 					Ri_bestn->col);
-				if (!
+				//todo this "limited" flag will probably be removed?  Then this entire if section could be removed if we always allow multiple merges per pass?
+				if (functions->limited && !
 				    (FLAG_GET
 				     (files->candidate_flag, Ri_bestn->row,
 				      Ri_bestn->col))) {
@@ -820,7 +935,6 @@
 			    if (Ri_bestn != NULL && Ri_similarity < threshold) {	/* small TODO: should this be < or <= for threshold? */
 				/* Rk starts from Ri's best neighbor */
 				Rk_count = 1;
 				newpixel =
@@ -894,6 +1008,7 @@
 					"3b Ri's best neighbor was not valid candidate, or their similarity was > threshold");
 				pathflag = FALSE;
 			}	/* end if(Rin_head != NULL) */
 			else {	/* Ri didn't have a neighbor */
 			    G_debug(4, "Segment had no neighbors");
@@ -951,7 +1066,7 @@
     if (functions->min_segment_size > 1 && t > 2) {	/* NOTE: added t > 2, it doesn't make sense to force merges if no merges were made on the original pass.  Something should be adjusted first */
-	G_verbose_message
+	G_message
 	    (_("Final iteration, forcing merges for small segments, percent complete based on rows."));
 	/* for the final forced merge, the candidate flag is just to keep track if we have confirmed if:
@@ -1212,17 +1327,21 @@
 		else {		/* segment id's were different */
-		    //TODO: if current ID not found in known neighbors list
-		    //add to known neighbors list
-		    /* put pixel_neighbor[n] in Rin */
-		    G_debug(5, "Put in neighbors_head");
-		    newpixel = (struct pixels *)link_new(files->token);
-		    newpixel->next = *neighbors_head;	/*point the new pixel to the current first pixel */
-		    newpixel->row = pixel_neighbors[n][0];
-		    newpixel->col = pixel_neighbors[n][1];
-		    *neighbors_head = newpixel;	/*change the first pixel to be the new pixel. */
+		    if (!rbtree_find(known_iseg, &current_seg_ID)) {	/* we don't have any neighbors yet from this segment */
+			/* add to known neighbors list */
+			rbtree_insert(known_iseg, &current_seg_ID);	/* todo: could I just try to insert it, if it fails I know it is already there?
+									 * I guess it would depend on how much faster the find() is, and what fraction of the
+									 * neighbors are in a duplicate segment... */
+			/* put pixel_neighbor[n] in Rin */
+			G_debug(5, "Put in neighbors_head");
+			newpixel = (struct pixels *)link_new(files->token);
+			newpixel->next = *neighbors_head;	/*point the new pixel to the current first pixel */
+			newpixel->row = pixel_neighbors[n][0];
+			newpixel->col = pixel_neighbors[n][1];
+			*neighbors_head = newpixel;	/*change the first pixel to be the new pixel. */
@@ -1333,7 +1452,7 @@
     int n;
     struct pixels *current;
-    /*get input values *//*TODO polish, confirm if we can assume we already have bands_val for Ri, so don't need to segment_get() again? */
+    /*get input values *//*TODO polish, confirm if we can assume we already have bands_val for Ri, so don't need to segment_get() again?  note...current very_close implementation requires getting this value again... */
     segment_get(&files->bands_seg, (void *)files->bands_val, Ri_head->row,
 		Ri_head->col);
     segment_get(&files->bands_seg, (void *)files->second_val,
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h	2012-07-25 15:29:10 UTC (rev 52450)
+++ grass-addons/grass7/imagery/i.segment/iseg.h	2012-07-25 16:49:57 UTC (rev 52451)
@@ -84,6 +84,13 @@
     /* todo remove when decide on pathflag */
     int path;
+    /* todo remove when decide on allowing multiple merges per pass */
+    int limited;
+    /* todo: should this be an option, set at a specific value, or left out. */
+    //    double very_close;        /* segments with very_close similarity will be merged without changing or checking the candidate flag.  The algorithm will continue looking for the "most similar" neighbor that isn't "very close". */
+    // todo... tried this out briefly, but realized that we need to find the segment membership, might be some faster ways to do this, but first tries actually slowed down the processing.
Modified: grass-addons/grass7/imagery/i.segment/open_files.c
--- grass-addons/grass7/imagery/i.segment/open_files.c	2012-07-25 15:29:10 UTC (rev 52450)
+++ grass-addons/grass7/imagery/i.segment/open_files.c	2012-07-25 16:49:57 UTC (rev 52451)
@@ -96,7 +96,7 @@
     scols = 64;
     /* TODO: make calculations for this, check i.cost and i.watershed */
-    nseg = 10000;
+    nseg = 16;
     /* ******* create temporary segmentation files ********* */
@@ -161,25 +161,10 @@
-    /* keep original copy of null flag if we have boundary constraints */
-    if (files->bounds_map != NULL) {
-	for (row = 0; row < files->nrows; row++) {
-	    for (col = 0; col < files->ncols; col++) {
-		if (FLAG_GET(files->null_flag, row, col))
-		    FLAG_SET(files->orig_null_flag, row, col);
-		else		/* todo polish, flags are initialized to zero... could just skip this else? */
-		    FLAG_UNSET(files->orig_null_flag, row, col);
     /* number of initial segments, will decrement when merge */
     files->nsegs = s - 1;
     /* bounds/constraints */
-    /* TODO: You should also handle NULL cells in the bounds
-     * raster map, I would suggest to replace NULL with min(bounds) - 1 or
-     +* max(bounds) + 1. */
 	if (segment_open
 	    (&files->bounds_seg, G_tempfile(), files->nrows, files->ncols,
@@ -194,15 +179,29 @@
 		files->bounds_val = boundsbuf[col];
 		segment_put(&files->bounds_seg, &files->bounds_val, row, col);
+		if (Rast_is_c_null_value(&boundsbuf[col]) == TRUE) {
+		    FLAG_SET(files->null_flag, row, col);
 	Rast_close(bounds_fd);
 	G_free(boundsbuf);
+	/* keep original copy of null flag if we have boundary constraints */
+	for (row = 0; row < files->nrows; row++) {
+	    for (col = 0; col < files->ncols; col++) {
+		if (FLAG_GET(files->null_flag, row, col))
+		    FLAG_SET(files->orig_null_flag, row, col);
+		else		/* todo polish, flags are initialized to zero... could just skip this else? */
+		    FLAG_UNSET(files->orig_null_flag, row, col);
+    }				/* end: if (files->bounds_map != NULL) */
     else {
 	G_debug(1, "no boundary constraint supplied.");
     /* other info */
     files->candidate_count = 0;	/* counter for remaining candidate pixels */
Modified: grass-addons/grass7/imagery/i.segment/parse_args.c
--- grass-addons/grass7/imagery/i.segment/parse_args.c	2012-07-25 15:29:10 UTC (rev 52450)
+++ grass-addons/grass7/imagery/i.segment/parse_args.c	2012-07-25 16:49:57 UTC (rev 52451)
@@ -13,9 +13,11 @@
     /* reference: http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing */
     struct Option *group, *seeds, *bounds, *output, *method, *threshold, *min_segment_size, *endt;	/* Establish an Option pointer for each option */
-    struct Flag *diagonal, *weighted, *path;	/* Establish a Flag pointer for each option */
+    struct Flag *diagonal, *weighted, *path, *limited;	/* Establish a Flag pointer for each option */
     struct Option *outband;	/* TODO scrub: put all outband code inside of #ifdef DEBUG */
+    //~ struct Option *very_close;
     /* required parameters */
     group = G_define_standard_option(G_OPT_I_GROUP);	/* TODO? Polish, consider giving the option to process just one raster directly, without creating an image group. */
@@ -50,6 +52,14 @@
     min_segment_size->description =
 	_("The final iteration will ignore the threshold for any segments with fewer pixels.");
+    //~ very_close = G_define_option();
+    //~ very_close->key = "very_close";
+    //~ very_close->type = TYPE_DOUBLE;
+    //~ very_close->required = YES;
+    //~ very_close->answer = "0";
+    //~ very_close->options = "0-1";
+    //~ very_close->description = _("For testing:  very close segments will be merged, the focus segment will not be changed.");
     /* optional parameters */
     diagonal = G_define_flag();
@@ -91,12 +101,19 @@
     path->description =
 	_("temporary option, pathflag, select to use Rk as next Ri if not mutually best neighbors.");
+    limited = G_define_flag();
+    limited->key = 'l';
+    limited->description =
+	_("temporary option, limit to one merge to pass, if *not* selected a segment can be included in multiple merges in one pass.");
     outband = G_define_standard_option(G_OPT_R_OUTPUT);
     outband->key = "final_mean";
     outband->required = NO;
     outband->description =
 	_("debug - save band mean, currently implemented for only 1 band.");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -135,6 +152,8 @@
     G_debug(1, "segmentation method: %d", functions->method);
+    //~ functions->very_close = atof(very_close->answer);
     functions->min_segment_size = atoi(min_segment_size->answer);
     if (diagonal->answer == FALSE) {
@@ -185,6 +204,8 @@
     functions->path = path->answer;	/* default/0 for no pathflag, but selected/1 to use Rk as next Ri if not mutually best neighbors. */
+    functions->limited = limited->answer;
     if (outband->answer == NULL)
 	files->out_band = NULL;
     else {
