[GRASS-SVN] r52452 - grass-addons/grass7/imagery/i.segment
    svn_grass at osgeo.org
    Wed Jul 25 14:47:00 PDT 2012
Author: momsen
Date: 2012-07-25 14:46:59 -0700 (Wed, 25 Jul 2012)
New Revision: 52452
   grass-addons/grass7/imagery/i.segment/create_isegs.c
   grass-addons/grass7/imagery/i.segment/iseg.h
   grass-addons/grass7/imagery/i.segment/open_files.c
   grass-addons/grass7/imagery/i.segment/parse_args.c
added initial attempt to grow from seeds, untested...
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c	2012-07-25 16:49:57 UTC (rev 52451)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c	2012-07-25 21:46:59 UTC (rev 52452)
@@ -389,7 +389,7 @@
 	G_message("estimate of tokens created %d", count + 15);
 	/*dispose tokens */
 	while (Rin_head != NULL) {
-	    current = Rin_head;	/* rememer "old" head */
+	    current = Rin_head;	/* remember "old" head */
 	    Rin_head = Rin_head->next;	/* move head to next pixel */
 	    link_dispose(files->token, (VOID_T *) current);	/* remove "old" head */
@@ -921,9 +921,11 @@
 					"Lowest Ri_similarity = %g, for neighbor pixel row: %d col: %d",
 					Ri_similarity, Ri_bestn->row,
 					Ri_bestn->col);
+//if bounds map, can't check if it is a candidate.  TODO better way to include this check after decide on using the candidate flag here.
+if(files->seeds_map == NULL){
 				//todo this "limited" flag will probably be removed?  Then this entire if section could be removed if we always allow multiple merges per pass?
-				if (functions->limited && !
+				if ((functions->limited == TRUE) && !
 				    (FLAG_GET
 				     (files->candidate_flag, Ri_bestn->row,
 				      Ri_bestn->col))) {
@@ -933,7 +935,7 @@
 				    pathflag = FALSE;
 			    if (Ri_bestn != NULL && Ri_similarity < threshold) {	/* small TODO: should this be < or <= for threshold? */
 				/* Rk starts from Ri's best neighbor */
 				Rk_count = 1;
@@ -1583,6 +1585,8 @@
     int row, col;
+	if(files->seeds_map == NULL) { /* entire map is considered as candidates */
     //~ if (files->bounds_map == NULL) {        /* process entire raster */
     for (row = files->minrow; row < files->maxrow; row++) {
 	for (col = files->mincol; col < files->maxcol; col++) {
@@ -1611,7 +1615,22 @@
+	else { /* seeds were provided */
+	for (row = files->minrow; row < files->maxrow; row++) {
+	for (col = files->mincol; col < files->maxcol; col++) {
+	    if ((FLAG_GET(files->seeds_flag, row, col))) {
+		FLAG_SET(files->candidate_flag, row, col);
+		files->candidate_count++; //TODO, how deal with this...
+	    else
+		FLAG_UNSET(files->candidate_flag, row, col); //todo maybe can skip this...
     return TRUE;
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h	2012-07-25 16:49:57 UTC (rev 52451)
+++ grass-addons/grass7/imagery/i.segment/iseg.h	2012-07-25 21:46:59 UTC (rev 52452)
@@ -40,8 +40,7 @@
     /* files */
     char *out_name;		/* name of output raster map */
-    const char *seeds, *bounds_map;
-    const char *bounds_mapset;	/* optional segment seeds and polygon constraints/boundaries */
+    const char *seeds_map, *seeds_mapset, *bounds_map, *bounds_mapset;		/* optional segment seeds and polygon constraints/boundaries */
     char *out_band;		/* for debug */
     /* file processing */
@@ -58,7 +57,7 @@
     int nsegs;			/* number of segments */
     /* processing flags */
-    FLAG *candidate_flag, *null_flag, *orig_null_flag;
+    FLAG *candidate_flag, *null_flag, *orig_null_flag, *seeds_flag;
     /* memory management, linked lists */
     struct link_head *token;	/* for linkm.h linked list memory management. */
Modified: grass-addons/grass7/imagery/i.segment/open_files.c
--- grass-addons/grass7/imagery/i.segment/open_files.c	2012-07-25 16:49:57 UTC (rev 52451)
+++ grass-addons/grass7/imagery/i.segment/open_files.c	2012-07-25 21:46:59 UTC (rev 52452)
@@ -10,10 +10,12 @@
 int open_files(struct files *files)
     struct Ref Ref;		/* group reference list */
-    int *in_fd, bounds_fd, null_check, out_fd, mean_fd;
+    int *in_fd, seeds_fd, bounds_fd, null_check, out_fd, mean_fd;
     int i, n, s, row, col, srows, scols, inlen, nseg;
     DCELL **inbuf;		/* buffer array, to store lines from each of the imagery group rasters */
     CELL *boundsbuf;
+    void *seedsbuf;		/* todo. correct data type when allowing any data type? */
+    RASTER_MAP_TYPE data_type;
     struct FPRange *fp_range;	/* for getting min/max values on each input raster */
     DCELL *min, *max;
@@ -37,6 +39,8 @@
     files->candidate_flag = flag_create(files->nrows, files->ncols);
     if (files->bounds_map != NULL)
 	files->orig_null_flag = flag_create(files->nrows, files->ncols);
+	if (files->seeds_map != NULL)
+	files->seeds_flag = flag_create(files->nrows, files->ncols);
     /* references for segmentation library: i.cost r.watershed/seg and http://grass.osgeo.org/programming7/segmentlib.html */
@@ -164,6 +168,30 @@
     /* number of initial segments, will decrement when merge */
     files->nsegs = s - 1;
+	/* starting seeds */
+	/* save as flag, will reset candidate flags to match seed flags on each iteration */
+	if (files->seeds_map != NULL) {
+		seeds_fd = Rast_open_old(files->seeds_map, "");
+		data_type = Rast_get_map_type(seeds_fd);
+		seedsbuf = Rast_allocate_buf(data_type);
+		for (row = 0; row < files->nrows; row++) {
+			Rast_get_row(seeds_fd, seedsbuf, row, data_type);
+			for (col = 0; col < files->ncols; col++) {
+			if (Rast_is_null_value(&seedsbuf[col], data_type) == TRUE) { /* TODO, compiler warnings:
+																		  * open_files.c:182:37: warning: dereferencing ‘void *’ pointer [enabled by default]
+																		  * open_files.c:182:27: warning: taking address of expression of type ‘void’ [enabled by default]
+				FLAG_SET(files->seeds_flag, row, col);
+		Rast_close(seeds_fd);
+		G_free(seedsbuf);
     /* bounds/constraints */
     if (files->bounds_map != NULL) {
 	if (segment_open
Modified: grass-addons/grass7/imagery/i.segment/parse_args.c
--- grass-addons/grass7/imagery/i.segment/parse_args.c	2012-07-25 16:49:57 UTC (rev 52451)
+++ grass-addons/grass7/imagery/i.segment/parse_args.c	2012-07-25 21:46:59 UTC (rev 52452)
@@ -172,7 +172,20 @@
     functions->calculate_similarity = &calculate_euclidean_similarity;	/* TODO add user input for this */
-    files->seeds = seeds->answer;
+    if (seeds->answer == NULL) {	/* no starting seeds, will use all pixels as seeds */
+	files->seeds_map = NULL;
+    else {			/* polygon constraints given */
+	files->seeds_map = seeds->answer;
+	if ((files->seeds_mapset =
+	     G_find_raster2(files->seeds_map, "")) == NULL) {
+	    G_fatal_error(_("Starting seeds map not found."));
+	//~ if (Rast_map_type(files->seeds_map, files->seeds_mapset) !=
+	    //~ CELL_TYPE) {
+	    //~ G_fatal_error(_("Starting seeds map must be CELL type (integers)"));
+	//~ }  //todo: don't need this check, want it for polygon constraints, but for seeds we are just looking for null vs. not null
     if (bounds->answer == NULL) {	/*no polygon constraints */
 	files->bounds_map = NULL;
