[GRASS-SVN] r51928 - grass/branches/develbranch_6/display/d.vect
Sat Jun 2 01:01:09 PDT 2012
Author: mmetz
Date: 2012-06-02 01:01:08 -0700 (Sat, 02 Jun 2012)
New Revision: 51928
   grass/branches/develbranch_6/display/d.vect/attr.c
   grass/branches/develbranch_6/display/d.vect/label.c
   grass/branches/develbranch_6/display/d.vect/local_proto.h
   grass/branches/develbranch_6/display/d.vect/main.c
   grass/branches/develbranch_6/display/d.vect/plot1.c
   grass/branches/develbranch_6/display/d.vect/topo.c
d.vect: display area labels also when centroids are not displayed (backport from trunk)
Modified: grass/branches/develbranch_6/display/d.vect/attr.c
--- grass/branches/develbranch_6/display/d.vect/attr.c	2012-06-02 07:28:14 UTC (rev 51927)
+++ grass/branches/develbranch_6/display/d.vect/attr.c	2012-06-02 08:01:08 UTC (rev 51928)
@@ -54,7 +54,7 @@
 	else if (ltype == -2)
 	    break;
-	if (!(type & ltype))
+	if (!(type & ltype) && !((type & GV_AREA) && (ltype & GV_CENTROID)))
 	    continue;		/* used for both lines and labels */
 	R_RGB_color(lattr->color.R, lattr->color.G, lattr->color.B);
Modified: grass/branches/develbranch_6/display/d.vect/label.c
--- grass/branches/develbranch_6/display/d.vect/label.c	2012-06-02 07:28:14 UTC (rev 51927)
+++ grass/branches/develbranch_6/display/d.vect/label.c	2012-06-02 08:01:08 UTC (rev 51928)
@@ -5,7 +5,7 @@
 #include <grass/glocale.h>
 #include "plot.h"
-int label(struct Map_info *Map, int type, int do_area,
+int label(struct Map_info *Map, int type,
 	  struct cat_list *Clist, LATTR * lattr, int chcat)
     int i, ltype;
@@ -30,7 +30,7 @@
 	    return 0;
+	if (!(type & ltype)&& !((type & GV_AREA) && (ltype & GV_CENTROID)))
Modified: grass/branches/develbranch_6/display/d.vect/local_proto.h
--- grass/branches/develbranch_6/display/d.vect/local_proto.h	2012-06-02 07:28:14 UTC (rev 51927)
+++ grass/branches/develbranch_6/display/d.vect/local_proto.h	2012-06-02 08:01:08 UTC (rev 51928)
@@ -2,12 +2,12 @@
 FILE *open_vect(char *, char *);
 int close_vect(FILE *);
-int plot1(struct Map_info *, int, int, struct cat_list *,
+int plot1(struct Map_info *, int, struct cat_list *,
 	  const struct color_rgb *, const struct color_rgb *, int, char *,
 	  double, char *, char *, int, int, int, char *, int, char *, double,
 	  int, char *);
-int label(struct Map_info *, int, int, struct cat_list *, LATTR *, int);
-int topo(struct Map_info *, int, int, LATTR *);
+int label(struct Map_info *, int, struct cat_list *, LATTR *, int);
+int topo(struct Map_info *, int, LATTR *);
 int dir(struct Map_info *, int, struct cat_list *, int);
 int darea(struct Map_info *, struct cat_list *, const struct color_rgb *,
 	  const struct color_rgb *, int, int, int, int, struct Cell_head *,
Modified: grass/branches/develbranch_6/display/d.vect/main.c
--- grass/branches/develbranch_6/display/d.vect/main.c	2012-06-02 07:28:14 UTC (rev 51927)
+++ grass/branches/develbranch_6/display/d.vect/main.c	2012-06-02 08:01:08 UTC (rev 51928)
@@ -34,7 +34,7 @@
     char *mapset;
     int ret, level;
-    int i, stat = 0, type, area, display;
+    int i, stat = 0, type, display;
     int chcat = 0;
     int r, g, b;
     int has_color, has_fcolor;
@@ -494,32 +494,7 @@
 	    G_warning(_("%d errors in cat option"), ret);
-    i = 0;
-    type = 0;
-    area = FALSE;
-    while (type_opt->answers[i]) {
-	switch (type_opt->answers[i][0]) {
-	case 'p':
-	    type |= GV_POINT;
-	    break;
-	case 'l':
-	    type |= GV_LINE;
-	    break;
-	case 'b':
-	    type |= GV_BOUNDARY;
-	    break;
-	case 'f':
-	    type |= GV_FACE;
-	    break;
-	case 'c':
-	    type |= GV_CENTROID;
-	    break;
-	case 'a':
-	    area = TRUE;
-	    break;
-	i++;
+    type = Vect_option_to_types(type_opt);
     i = 0;
     display = 0;
@@ -630,7 +605,7 @@
 	if (!wcolumn_opt->answer)
 	    D_line_width(default_width);
-	if (area) {
+	if (type & GV_AREA) {
 	    if (level >= 2) {
 		if (display & DISP_SHAPE) {
 		    stat = darea(&Map, Clist,
@@ -655,7 +630,7 @@
 		G_warning(_("Unable to display lines by id, topology not available"));
 	    else {
-		stat = plot1(&Map, type, area, Clist,
+		stat = plot1(&Map, type, Clist,
 			     has_color ? &color : NULL,
 			     has_fcolor ? &fcolor : NULL, chcat, icon_opt->answer,
 			     size, sizecolumn_opt->answer, rotcolumn_opt->answer,
@@ -682,7 +657,7 @@
 	    R_line_width(0);
 	if (display & DISP_CAT)
-	    stat = label(&Map, type, area, Clist, &lattr, chcat);
+	    stat = label(&Map, type, Clist, &lattr, chcat);
 	if (display & DISP_ATTR)
 	    stat =
@@ -693,7 +668,7 @@
 	if (display & DISP_TOPO) {
 	    if (level >= 2)
-		stat = topo(&Map, type, area, &lattr);
+		stat = topo(&Map, type, &lattr);
 	    else
 		G_warning(_("Unable to display topology, not available"));
Modified: grass/branches/develbranch_6/display/d.vect/plot1.c
--- grass/branches/develbranch_6/display/d.vect/plot1.c	2012-06-02 07:28:14 UTC (rev 51927)
+++ grass/branches/develbranch_6/display/d.vect/plot1.c	2012-06-02 08:01:08 UTC (rev 51928)
@@ -126,7 +126,7 @@
-int plot1(struct Map_info *Map, int type, int area, struct cat_list *Clist,
+int plot1(struct Map_info *Map, int type, struct cat_list *Clist,
 	  const struct color_rgb *color, const struct color_rgb *fcolor,
 	  int chcat, char *symbol_name, double size, char *size_column,
 	  char *rot_column, int id_flag, int table_colors_flag,
Modified: grass/branches/develbranch_6/display/d.vect/topo.c
--- grass/branches/develbranch_6/display/d.vect/topo.c	2012-06-02 07:28:14 UTC (rev 51927)
+++ grass/branches/develbranch_6/display/d.vect/topo.c	2012-06-02 08:01:08 UTC (rev 51928)
@@ -5,7 +5,7 @@
 #include "plot.h"
-int topo(struct Map_info *Map, int type, int do_area, LATTR * lattr)
+int topo(struct Map_info *Map, int type, LATTR * lattr)
     int i, ltype, num, el;
     double xl, yl;
