[GRASS-SVN] r51929 - grass/trunk/db/db.select
Sat Jun 2 02:15:41 PDT 2012
Author: martinl
Date: 2012-06-02 02:15:40 -0700 (Sat, 02 Jun 2012)
New Revision: 51929
   grass/trunk/db/db.select/db.select.html
   grass/trunk/db/db.select/main.c
db.select: force `sql=-` for reading stdin
Modified: grass/trunk/db/db.select/db.select.html
--- grass/trunk/db/db.select/db.select.html	2012-06-02 08:01:08 UTC (rev 51928)
+++ grass/trunk/db/db.select/db.select.html	2012-06-02 09:15:40 UTC (rev 51929)
@@ -8,8 +8,8 @@
 If parameters for database connection are already set with
 <em><a href="db.connect.html">db.connect</a></em>, they are taken as
-default values and do not need to be spcified each time. Output will
-be displayed to stdout or can be directed to a file.
+default values and do not need to be specified each time. Output will
+be displayed to standard output or can be directed to a file (option <b>output</b>).
 <h2>EXAMPLES</h2>
@@ -78,4 +78,3 @@
 <p>
 <i>Last changed: $Date$</i>
Modified: grass/trunk/db/db.select/main.c
--- grass/trunk/db/db.select/main.c	2012-06-02 08:01:08 UTC (rev 51928)
+++ grass/trunk/db/db.select/main.c	2012-06-02 09:15:40 UTC (rev 51929)
@@ -9,7 +9,7 @@
  *               Markus Neteler <neteler itc.it>
  *               Stephan Holl
  * PURPOSE:      Process one sql select statement
- * COPYRIGHT:    (C) 2002-2010 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2002-2010, 2012 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include <string.h>
+#include <errno.h>
 #include <grass/gis.h>
 #include <grass/dbmi.h>
@@ -49,11 +50,12 @@
     parse_command_line(argc, argv);
+    errno = 0;
     if (parms.input) {
 	fd = fopen(parms.input, "r");
 	if (fd == NULL) {
-	    perror(parms.input);
-	    exit(ERROR);
+	    G_fatal_error(_("Unable to open file <%s>: %s"),
+                          parms.input, strerror(errno));
     else
@@ -72,21 +74,24 @@
 	G_fatal_error(_("Unable to open database <%s>"), parms.database);
     if (parms.sql) {
-	db_set_string(&stmt, parms.sql);
-	stat = sel(driver, &stmt);
+        if (strcmp(parms.sql, "-") == 0) {
+            /* read stdin */
+            stat = OK;
+            while (stat == OK && get_stmt(fd, &stmt)) {
+                if (!stmt_is_empty(&stmt))
+                    stat = sel(driver, &stmt);
+        else {
+            db_set_string(&stmt, parms.sql);
     else if (parms.table) {
 	db_set_string(&stmt, "select * from ");
 	db_append_string(&stmt, parms.table);
-    else {			/* read stdin */
-	stat = OK;
-	while (stat == OK && get_stmt(fd, &stmt)) {
-	    if (!stmt_is_empty(&stmt))
     if(parms.test_only)
 	G_verbose_message(_("Test %s."), stat ? _("failed") : _("succeeded"));
@@ -190,7 +195,7 @@
     sql->key = "sql";
     sql->type = TYPE_STRING;
     sql->required = NO;
-    sql->label = _("SQL select statement");
+    sql->label = _("SQL select statement ('-' for standard input)");
     sql->description =
 	_("For example: 'select * from rybniky where kapri = 'hodne'");
     sql->guisection = _("Query");
@@ -201,7 +206,7 @@
     input->guisection = _("Query");
     table = G_define_standard_option(G_OPT_DB_TABLE);
-    table->guisection = _("Connection");
+    table->guisection = _("Query");
     database = G_define_standard_option(G_OPT_DB_DATABASE);
     if ((db = db_get_default_database_name()))
@@ -290,10 +295,15 @@
     if (!parms.fs)
 	parms.fs = "";
     if (parms.input && *parms.input == 0) {
 	G_usage();
 	exit(EXIT_FAILURE);
+    if (!parms.input && !parms.sql && !parms.table)
+        G_fatal_error(_("You must provide one of these options: <%s>, <%s>, or <%s>"),
+                      sql->key, input->key, table->key);
