[GRASS-SVN] r51986 - grass-addons/grass7/imagery/i.segment
Wed Jun 6 07:28:32 PDT 2012
Author: momsen
Date: 2012-06-06 07:28:31 -0700 (Wed, 06 Jun 2012)
New Revision: 51986
   grass-addons/grass7/imagery/i.segment/write_output.c
working I/O.
Modified: grass-addons/grass7/imagery/i.segment/write_output.c
--- grass-addons/grass7/imagery/i.segment/write_output.c	2012-06-06 13:54:08 UTC (rev 51985)
+++ grass-addons/grass7/imagery/i.segment/write_output.c	2012-06-06 14:28:31 UTC (rev 51986)
@@ -27,7 +27,7 @@
     G_debug(1, "preparing output raster");
     /* open output raster map */
-    out_fd = Rast_open_new(files->out_name, files->data_type);	/* I assume even if it already exists, this will overwrite it... */
+    out_fd = Rast_open_new(files->out_name, CELL_TYPE);	/* I assume even if it already exists, this will overwrite it... */
     G_debug(1, "start data transfer from segmentation file to raster");
     /* transfer data from segmentation file to raster */
@@ -51,9 +51,9 @@
     /* close segmentation files and output raster */
     G_debug(1, "closing files");
-    segment_release(&files->bands_seg);
-    segment_release(&files->out_seg);
-    close(out_fd);
+    segment_close(&files->bands_seg);
+    segment_close(&files->out_seg);
+    Rast_close(out_fd);
     /* TODO Note: The Segment Library does not know the name of the segment file. It does not attempt to remove the file. If the file is only temporary, the programmer should remove the file after closing it. */
