[GRASS-SVN] r51987 - grass/trunk/lib/vector/Vlib
Wed Jun 6 07:47:06 PDT 2012
Author: martinl
Date: 2012-06-06 07:47:05 -0700 (Wed, 06 Jun 2012)
New Revision: 51987
   grass/trunk/lib/vector/Vlib/open_ogr.c
   grass/trunk/lib/vector/Vlib/open_pg.c
vlib/pg: don't try to read fidx file for vector maps (PostGIS topology access)
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c	2012-06-06 14:28:31 UTC (rev 51986)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c	2012-06-06 14:47:05 UTC (rev 51987)
@@ -369,8 +369,8 @@
     dig_file_init(&fp);
     fp.file = G_fopen_old(elem, GV_FIDX_ELEMENT, Map->mapset);
     if (fp.file == NULL) {
-	G_warning(_("Unable to open fidx file for vector map <%s>"),
-		  Vect_get_full_name(Map));
+        G_debug(1, "unable to open fidx file for vector map <%s>",
+                Vect_get_full_name(Map));
 	return -1;
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c	2012-06-06 14:28:31 UTC (rev 51986)
+++ grass/trunk/lib/vector/Vlib/open_pg.c	2012-06-06 14:47:05 UTC (rev 51987)
@@ -38,7 +38,7 @@
 static int create_table(struct Format_info_pg *, const struct field_info *);
 static void connect_db(struct Format_info_pg *);
 static int check_topo(struct Format_info_pg *, struct Plus_head *);
-static int parse_bbox(const char *, struct bound_box *, int);
+static int parse_bbox(const char *, struct bound_box *);
 static int num_of_records(const struct Format_info_pg *, const char *);
 static int read_p_node(struct Plus_head *, int, int, struct Format_info_pg *);
 static int read_p_line(struct Plus_head *, int, const struct edge_data *);
@@ -68,6 +68,8 @@
     struct Format_info_pg *pg_info;
+    G_debug(2, "V1_open_old_pg(): update = %d", update);
     pg_info = &(Map->fInfo.pg);
     if (!pg_info->conninfo) {
         G_warning(_("Connection string not defined"));
@@ -151,14 +153,21 @@
 int V2_open_old_pg(struct Map_info *Map)
 #ifdef HAVE_POSTGRES
+    struct Format_info_pg *pg_info;
     G_debug(3, "V2_open_old_pg(): name = %s mapset = %s", Map->name,
             Map->mapset);
-    if (Vect_open_fidx(Map, &(Map->fInfo.pg.offset)) != 0) {
+    pg_info = &(Map->fInfo.pg);
+    if (pg_info->toposchema_name)
+        /* no fidx file needed for PostGIS topology access */
+        return 0;
+    if (Vect_open_fidx(Map, &(pg_info->offset)) != 0) {
         G_warning(_("Unable to open feature index file for vector map <%s>"),
-        G_zero(&(Map->fInfo.pg.offset), sizeof(struct Format_info_offset));
+        G_zero(&(pg_info->offset), sizeof(struct Format_info_offset));
     return 0;
@@ -190,6 +199,8 @@
     PGresult *res;
+    G_debug(2, "V1_open_new_pg(): name = %s with_z = %d", name, with_z);
@@ -851,7 +862,7 @@
   \return 0 on success
   \return -1 on error
-int parse_bbox(const char *value, struct bound_box *bbox, int with_z)
+int parse_bbox(const char *value, struct bound_box *bbox)
     unsigned int i;
     size_t length, prefix_length;
@@ -1219,7 +1230,7 @@
             PQclear(res);
         return -1;
-    if (parse_bbox(PQgetvalue(res, 0, 0), &(plus->box), plus->with_z) != 0) {
+    if (parse_bbox(PQgetvalue(res, 0, 0), &(plus->box)) != 0) {
         G_warning(_("Unable to parse map bounding box:\n%s"),
                   PQgetvalue(res, 0, 0));
         return -1;
