[GRASS-SVN] r51988 - grass/trunk/lib/vector/Vlib
Wed Jun 6 08:05:03 PDT 2012
Author: martinl
Date: 2012-06-06 08:05:02 -0700 (Wed, 06 Jun 2012)
New Revision: 51988
   grass/trunk/lib/vector/Vlib/open_pg.c
vlib/pg: print PostgreSQL NOTICE messages only on verbose level
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c	2012-06-06 14:47:05 UTC (rev 51987)
+++ grass/trunk/lib/vector/Vlib/open_pg.c	2012-06-06 15:05:02 UTC (rev 51988)
@@ -44,6 +44,7 @@
 static int read_p_line(struct Plus_head *, int, const struct edge_data *);
 static int read_p_area(struct Plus_head *, int, int, struct Format_info_pg *);
 static int load_plus_head(struct Format_info_pg *, struct Plus_head *);
+static void notice_processor(void *, const char *);
 #endif
@@ -216,13 +217,8 @@
             pg_info->conninfo, pg_info->table_name);
     /* connect database */
-    pg_info->conn = PQconnectdb(pg_info->conninfo);
-    G_debug(2, "   PQconnectdb(): %s", pg_info->conninfo);
-    if (PQstatus(pg_info->conn) == CONNECTION_BAD)
-        G_fatal_error("%s\n%s",
-                      _("Connection ton PostgreSQL database failed."),
-                      PQerrorMessage(pg_info->conn));
+    connect_db(pg_info);
     /* get DB name */
     pg_info->db_name = G_store(PQdb(pg_info->conn));
     if (!pg_info->db_name) {
@@ -763,6 +759,8 @@
     /* create index ? */
     if (spatial_index) {
+        G_verbose_message(_("Building spatial index on <%s>..."),
+                          pg_info->geom_column);
         sprintf(stmt,
                 "CREATE INDEX %s_%s_idx ON \"%s\".\"%s\" USING GIST (%s)",
                 pg_info->table_name, pg_info->geom_column,
@@ -797,6 +795,10 @@
+    /* print notice messages only on verbose level */
+    PQsetNoticeProcessor(pg_info->conn, notice_processor, NULL);
@@ -1445,4 +1447,16 @@
     return 0;
+  \brief PostgreSQL notice processor
+  Print out NOTICE message only on verbose level
+void notice_processor(void *arg, const char *message)
+    if (G_verbose() > G_verbose_std()) {
+        fprintf(stderr, "%s", message);
 #endif
