[GRASS-SVN] r51214 - grass/branches/develbranch_6/locale/po
Fri Mar 30 18:59:13 EDT 2012
Author: neteler
Date: 2012-03-30 15:59:13 -0700 (Fri, 30 Mar 2012)
New Revision: 51214
   grass/branches/develbranch_6/locale/po/grasslibs_ar.po
   grass/branches/develbranch_6/locale/po/grasslibs_cs.po
   grass/branches/develbranch_6/locale/po/grasslibs_de.po
   grass/branches/develbranch_6/locale/po/grasslibs_el.po
   grass/branches/develbranch_6/locale/po/grasslibs_es.po
   grass/branches/develbranch_6/locale/po/grasslibs_fr.po
   grass/branches/develbranch_6/locale/po/grasslibs_hi.po
   grass/branches/develbranch_6/locale/po/grasslibs_it.po
   grass/branches/develbranch_6/locale/po/grasslibs_ja.po
   grass/branches/develbranch_6/locale/po/grasslibs_ko.po
   grass/branches/develbranch_6/locale/po/grasslibs_lv.po
   grass/branches/develbranch_6/locale/po/grasslibs_ml.po
   grass/branches/develbranch_6/locale/po/grasslibs_mr.po
   grass/branches/develbranch_6/locale/po/grasslibs_pl.po
   grass/branches/develbranch_6/locale/po/grasslibs_pt.po
   grass/branches/develbranch_6/locale/po/grasslibs_pt_br.po
   grass/branches/develbranch_6/locale/po/grasslibs_ru.po
   grass/branches/develbranch_6/locale/po/grasslibs_sl.po
   grass/branches/develbranch_6/locale/po/grasslibs_th.po
   grass/branches/develbranch_6/locale/po/grasslibs_tr.po
   grass/branches/develbranch_6/locale/po/grasslibs_vi.po
   grass/branches/develbranch_6/locale/po/grasslibs_zh.po
fix typo
Modified: grass/branches/develbranch_6/locale/po/grasslibs_ar.po
--- grass/branches/develbranch_6/locale/po/grasslibs_ar.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_ar.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3609,7 +3609,7 @@
 #: ../lib/gis/parser.c:637
 #, fuzzy
-msgid "Name to input file"
+msgid "Name of input file"
 msgstr "اسم الملف المفتوح %s\n"
 #: ../lib/gis/parser.c:645
Modified: grass/branches/develbranch_6/locale/po/grasslibs_cs.po
--- grass/branches/develbranch_6/locale/po/grasslibs_cs.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_cs.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3613,7 +3613,7 @@
 #, fuzzy
 msgstr "Název vstupního souboru %s"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_de.po
--- grass/branches/develbranch_6/locale/po/grasslibs_de.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_de.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3597,7 +3597,7 @@
 msgstr "Objekt-IDs"
 msgstr "Name der  Eingabedatei"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_el.po
--- grass/branches/develbranch_6/locale/po/grasslibs_el.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_el.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3616,7 +3616,7 @@
 #, fuzzy
 msgstr "¼íïìá áñ÷åßïõ åéóáãùãÞò"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_es.po
--- grass/branches/develbranch_6/locale/po/grasslibs_es.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_es.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3656,7 +3656,7 @@
 #, fuzzy
 msgstr "Ruta del archivo de entrada."
Modified: grass/branches/develbranch_6/locale/po/grasslibs_fr.po
--- grass/branches/develbranch_6/locale/po/grasslibs_fr.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_fr.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3673,7 +3673,7 @@
 #, fuzzy
 msgstr "Nom du fichier en entrée"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_hi.po
--- grass/branches/develbranch_6/locale/po/grasslibs_hi.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_hi.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3644,7 +3644,7 @@
 #, fuzzy
 msgstr "का"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_it.po
--- grass/branches/develbranch_6/locale/po/grasslibs_it.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_it.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3546,7 +3546,7 @@
 msgstr "Id delle feature"
 msgstr "Percorso al file di input"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_ja.po
--- grass/branches/develbranch_6/locale/po/grasslibs_ja.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_ja.po	2012-03-30 22:59:13 UTC (rev 51214)
 msgstr "フィーチャ ids"
 msgstr "入力するファイル名"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_ko.po
--- grass/branches/develbranch_6/locale/po/grasslibs_ko.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_ko.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3536,7 +3536,7 @@
 #, fuzzy
 msgstr "자동 MASK파일을 열 수 없습니다"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_lv.po
--- grass/branches/develbranch_6/locale/po/grasslibs_lv.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_lv.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3625,7 +3625,7 @@
 #, fuzzy
 msgstr "Atvērtā faila nosaukums %s"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_ml.po
--- grass/branches/develbranch_6/locale/po/grasslibs_ml.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_ml.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3483,7 +3483,7 @@
 #, fuzzy
 msgstr "ഫയൽ തുറക്കൻ പറ്റുന്നില്ല %s"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_mr.po
--- grass/branches/develbranch_6/locale/po/grasslibs_mr.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_mr.po	2012-03-30 22:59:13 UTC (rev 51214)
 #, fuzzy
 msgstr "उघडलेल्या फाइलचे नाव %s\n"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_pl.po
--- grass/branches/develbranch_6/locale/po/grasslibs_pl.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_pl.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3577,7 +3577,7 @@
 msgstr "ID obiektów"
 msgstr "Ścieżka do pliku wejściowego"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_pt.po
--- grass/branches/develbranch_6/locale/po/grasslibs_pt.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_pt.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3651,7 +3651,7 @@
 #, fuzzy
 msgstr "Nome do arquivo de entrada"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_pt_br.po
--- grass/branches/develbranch_6/locale/po/grasslibs_pt_br.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_pt_br.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3612,7 +3612,7 @@
 #, fuzzy
Modified: grass/branches/develbranch_6/locale/po/grasslibs_ru.po
--- grass/branches/develbranch_6/locale/po/grasslibs_ru.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_ru.po	2012-03-30 22:59:13 UTC (rev 51214)
 #, fuzzy
 msgstr "Имя исходного файла"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_sl.po
--- grass/branches/develbranch_6/locale/po/grasslibs_sl.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_sl.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3641,7 +3641,7 @@
 #, fuzzy
 msgstr "Ime odprte datoteke %s\n"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_th.po
--- grass/branches/develbranch_6/locale/po/grasslibs_th.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_th.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3698,7 +3698,7 @@
 #, fuzzy
 msgstr "ชื่อไฟล์ที่จะนำเข้า"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_tr.po
--- grass/branches/develbranch_6/locale/po/grasslibs_tr.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_tr.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3513,7 +3513,7 @@
 #, fuzzy
 msgstr "Girdi dosyasının adı"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_vi.po
--- grass/branches/develbranch_6/locale/po/grasslibs_vi.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_vi.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3606,7 +3606,7 @@
 #, fuzzy
 msgstr "Tên của tập tin đầu vào"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_zh.po
--- grass/branches/develbranch_6/locale/po/grasslibs_zh.po	2012-03-30 22:58:02 UTC (rev 51213)
+++ grass/branches/develbranch_6/locale/po/grasslibs_zh.po	2012-03-30 22:59:13 UTC (rev 51214)
@@ -3743,7 +3743,7 @@
 #, fuzzy
 msgstr "打开文件的名称 %s"
