[GRASS-SVN] r51215 - grass/trunk/locale/po
Fri Mar 30 19:00:09 EDT 2012
Author: neteler
Date: 2012-03-30 16:00:09 -0700 (Fri, 30 Mar 2012)
New Revision: 51215
   grass/trunk/locale/po/grasslibs_ar.po
   grass/trunk/locale/po/grasslibs_cs.po
   grass/trunk/locale/po/grasslibs_de.po
   grass/trunk/locale/po/grasslibs_el.po
   grass/trunk/locale/po/grasslibs_es.po
   grass/trunk/locale/po/grasslibs_fr.po
   grass/trunk/locale/po/grasslibs_hi.po
   grass/trunk/locale/po/grasslibs_it.po
   grass/trunk/locale/po/grasslibs_ja.po
   grass/trunk/locale/po/grasslibs_ko.po
   grass/trunk/locale/po/grasslibs_lv.po
   grass/trunk/locale/po/grasslibs_ml.po
   grass/trunk/locale/po/grasslibs_mr.po
   grass/trunk/locale/po/grasslibs_pl.po
   grass/trunk/locale/po/grasslibs_pt.po
   grass/trunk/locale/po/grasslibs_pt_br.po
   grass/trunk/locale/po/grasslibs_ru.po
   grass/trunk/locale/po/grasslibs_sl.po
   grass/trunk/locale/po/grasslibs_th.po
   grass/trunk/locale/po/grasslibs_tr.po
   grass/trunk/locale/po/grasslibs_vi.po
   grass/trunk/locale/po/grasslibs_zh.po
fix typo
Modified: grass/trunk/locale/po/grasslibs_ar.po
--- grass/trunk/locale/po/grasslibs_ar.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_ar.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6645,7 +6645,7 @@
 #: ../lib/gis/parser_standard_options.c:482
 #, fuzzy
-msgid "Name to input file"
+msgid "Name of input file"
 msgstr "اسم الملف المفتوح %s\n"
 #: ../lib/gis/parser_standard_options.c:490
Modified: grass/trunk/locale/po/grasslibs_cs.po
--- grass/trunk/locale/po/grasslibs_cs.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_cs.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6734,7 +6734,7 @@
 #, fuzzy
 msgstr "Název vstupního souboru %s"
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_de.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6718,7 +6718,7 @@
 msgstr "Objekt-IDs"
 msgstr "Name der  Eingabedatei"
Modified: grass/trunk/locale/po/grasslibs_el.po
--- grass/trunk/locale/po/grasslibs_el.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_el.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6739,7 +6739,7 @@
 #, fuzzy
 msgstr "¼íïìá áñ÷åßïõ åéóáãùãÞò"
Modified: grass/trunk/locale/po/grasslibs_es.po
--- grass/trunk/locale/po/grasslibs_es.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_es.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6812,7 +6812,7 @@
 #, fuzzy
 msgstr "Ruta del archivo de entrada."
Modified: grass/trunk/locale/po/grasslibs_fr.po
--- grass/trunk/locale/po/grasslibs_fr.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_fr.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6793,7 +6793,7 @@
 #, fuzzy
 msgstr "Nom du fichier en entrée"
Modified: grass/trunk/locale/po/grasslibs_hi.po
--- grass/trunk/locale/po/grasslibs_hi.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_hi.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6628,7 +6628,7 @@
 #, fuzzy
 msgstr "का"
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_it.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6654,7 +6654,7 @@
 msgstr "Id delle feature"
 msgstr "Percorso al file di input"
Modified: grass/trunk/locale/po/grasslibs_ja.po
--- grass/trunk/locale/po/grasslibs_ja.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_ja.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6648,7 +6648,7 @@
 msgstr "フィーチャ ids"
 msgstr "入力するファイル名"
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_ko.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6506,7 +6506,7 @@
 #, fuzzy
 msgstr "자동 MASK파일을 열 수 없습니다"
Modified: grass/trunk/locale/po/grasslibs_lv.po
--- grass/trunk/locale/po/grasslibs_lv.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_lv.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6704,7 +6704,7 @@
 #, fuzzy
 msgstr "Atvērtā faila nosaukums %s"
Modified: grass/trunk/locale/po/grasslibs_ml.po
--- grass/trunk/locale/po/grasslibs_ml.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_ml.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6437,7 +6437,7 @@
 #, fuzzy
 msgstr "ഫയൽ തുറക്കൻ പറ്റുന്നില്ല %s"
Modified: grass/trunk/locale/po/grasslibs_mr.po
--- grass/trunk/locale/po/grasslibs_mr.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_mr.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6504,7 +6504,7 @@
 #, fuzzy
 msgstr "उघडलेल्या फाइलचे नाव %s\n"
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_pl.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6666,7 +6666,7 @@
 msgstr "ID obiektów"
 msgstr "Ścieżka do pliku wejściowego"
Modified: grass/trunk/locale/po/grasslibs_pt.po
--- grass/trunk/locale/po/grasslibs_pt.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_pt.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6763,7 +6763,7 @@
 #, fuzzy
 msgstr "Nome do arquivo de entrada"
Modified: grass/trunk/locale/po/grasslibs_pt_br.po
--- grass/trunk/locale/po/grasslibs_pt_br.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_pt_br.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6708,7 +6708,7 @@
 #, fuzzy
Modified: grass/trunk/locale/po/grasslibs_ru.po
--- grass/trunk/locale/po/grasslibs_ru.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_ru.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6738,7 +6738,7 @@
 #, fuzzy
 msgstr "Имя исходного файла"
Modified: grass/trunk/locale/po/grasslibs_sl.po
--- grass/trunk/locale/po/grasslibs_sl.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_sl.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6715,7 +6715,7 @@
 #, fuzzy
 msgstr "Ime odprte datoteke %s\n"
Modified: grass/trunk/locale/po/grasslibs_th.po
--- grass/trunk/locale/po/grasslibs_th.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_th.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6816,7 +6816,7 @@
 #, fuzzy
 msgstr "ชื่อไฟล์ที่จะนำเข้า"
Modified: grass/trunk/locale/po/grasslibs_tr.po
--- grass/trunk/locale/po/grasslibs_tr.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_tr.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6573,7 +6573,7 @@
 #, fuzzy
 msgstr "Girdi dosyasının adı"
Modified: grass/trunk/locale/po/grasslibs_vi.po
--- grass/trunk/locale/po/grasslibs_vi.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_vi.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6731,7 +6731,7 @@
 #, fuzzy
 msgstr "Tên của tập tin đầu vào"
Modified: grass/trunk/locale/po/grasslibs_zh.po
--- grass/trunk/locale/po/grasslibs_zh.po	2012-03-30 22:59:13 UTC (rev 51214)
+++ grass/trunk/locale/po/grasslibs_zh.po	2012-03-30 23:00:09 UTC (rev 51215)
@@ -6832,7 +6832,7 @@
 #, fuzzy
 msgstr "打开文件的名称 %s"
