[GRASS-SVN] r55234 - grass-addons/grass7/raster/r.geomorphon
Tue Feb 26 21:27:59 PST 2013
Author: hamish
Date: 2013-02-26 21:27:59 -0800 (Tue, 26 Feb 2013)
New Revision: 55234
   grass-addons/grass7/raster/r.geomorphon/geom.c
   grass-addons/grass7/raster/r.geomorphon/local_proto.h
   grass-addons/grass7/raster/r.geomorphon/main.c
   grass-addons/grass7/raster/r.geomorphon/memory.c
   grass-addons/grass7/raster/r.geomorphon/multires.c
   grass-addons/grass7/raster/r.geomorphon/pattern.c
run tools/grass_indent.sh
Modified: grass-addons/grass7/raster/r.geomorphon/geom.c
--- grass-addons/grass7/raster/r.geomorphon/geom.c	2013-02-27 05:22:05 UTC (rev 55233)
+++ grass-addons/grass7/raster/r.geomorphon/geom.c	2013-02-27 05:27:59 UTC (rev 55234)
@@ -1,252 +1,260 @@
 #include "local_proto.h"
-static double dirs[8]={0.7854,0.,5.4978,4.7124,3.9270,3.1416,2.3562,1.5708}; /* radians */
-static double sins[8]={0.7071067812,0,-0.7071067812,-1,-0.7071067812,0,0.7071067812,1}; /* sinus */
-static double coss[8]={0.7071067812,1,0.7071067812,0,-0.7071067812,-1,-0.7071067812,0}; /* cosinus */
+static double dirs[8] = { 0.7854, 0., 5.4978, 4.7124, 3.9270, 3.1416, 2.3562, 1.5708 };	/* radians */
+static double sins[8] = { 0.7071067812, 0, -0.7071067812, -1, -0.7071067812, 0, 0.7071067812, 1 };	/* sinus */
+static double coss[8] = { 0.7071067812, 1, 0.7071067812, 0, -0.7071067812, -1, -0.7071067812, 0 };	/* cosinus */
 /* DIRS in DEGREES from NORTH: 45,0,315,270,225,180,135,90 */
-unsigned int ternary_rotate (unsigned int value)
+unsigned int ternary_rotate(unsigned int value)
-/* this function returns rotated and mirrored
- * ternary code from any number
- * function is used to create lookup table with original
- * terrain patterns (6561) and its rotated and mirrored counterparts (498)*/
-unsigned char pattern[8];
-unsigned char rev_pattern[8];
-unsigned char tmp_pattern[8];
-unsigned char tmp_rev_pattern[8];
-unsigned int code=10000, tmp_code, rev_code=10000, tmp_rev_code;
-int power=1;
-int i,j,k;
-int res;
+    /* this function returns rotated and mirrored
+     * ternary code from any number
+     * function is used to create lookup table with original
+     * terrain patterns (6561) and its rotated and mirrored counterparts (498)*/
-for (i=0;i<8;i++) {
-	pattern[i]=value%3;
-	rev_pattern[7-i]=value%3;
-	value/=3;
+    unsigned char pattern[8];
+    unsigned char rev_pattern[8];
+    unsigned char tmp_pattern[8];
+    unsigned char tmp_rev_pattern[8];
+    unsigned int code = 10000, tmp_code, rev_code = 10000, tmp_rev_code;
+    int power = 1;
+    int i, j, k;
+    int res;
-for (j=0;j<8;j++) {
-	power=1;
-	tmp_code=0;
-	tmp_rev_code=0;
-	for (i=0;i<8;i++) {
-		k=(i-j)<0 ? j-8 : j;
-		tmp_pattern[i]=pattern[i-k];
-		tmp_rev_pattern[i]=rev_pattern[i-k];
-		tmp_code+=tmp_pattern[i]*power;
-		tmp_rev_code+=tmp_rev_pattern[i]*power;
-		power*=3;
+    for (i = 0; i < 8; i++) {
+	pattern[i] = value % 3;
+	rev_pattern[7 - i] = value % 3;
+	value /= 3;
+    for (j = 0; j < 8; j++) {
+	power = 1;
+	tmp_code = 0;
+	tmp_rev_code = 0;
+	    k = (i - j) < 0 ? j - 8 : j;
+	    tmp_pattern[i] = pattern[i - k];
+	    tmp_rev_pattern[i] = rev_pattern[i - k];
+	    tmp_code += tmp_pattern[i] * power;
+	    tmp_rev_code += tmp_rev_pattern[i] * power;
+	    power *= 3;
-	code=tmp_code<code ? tmp_code :code;
-	rev_code=tmp_rev_code<rev_code ? tmp_rev_code :rev_code;
+	code = tmp_code < code ? tmp_code : code;
+	rev_code = tmp_rev_code < rev_code ? tmp_rev_code : rev_code;
+    return code < rev_code ? code : rev_code;
-return code<rev_code ? code : rev_code;
 int determine_form(int num_minus, int num_plus)
-/* determine form according number of positives and negatives
- * simple approach to determine form pattern */
+    /* determine form according number of positives and negatives
+     * simple approach to determine form pattern */
-const FORMS forms[9][9] = {
-/* minus ------------- plus ----------------*/
-/*       0   1   2   3   4   5   6   7   8  */
-/* 0 */ {FL, FL, FL, FS, FS, VL, VL, VL, PT},
-/* 1 */ {FL, FL, FS, FS, FS, VL, VL, VL, __},
-/* 2 */ {FL, SH, SL, SL, CN, CN, VL, __, __},
-/* 3 */ {SH, SH, SL, SL, SL, CN, __, __, __},
-/* 4 */ {SH, SH, CV, SL, SL, __, __, __, __},
-/* 5 */ {RI, RI, CV, CV, __, __, __, __, __},
-/* 6 */ {RI, RI, RI, __, __, __, __, __, __},
-/* 7 */ {RI, RI, __, __, __, __, __, __, __},
-/* 8 */ {PK, __, __, __, __, __, __, __, __},
+    const FORMS forms[9][9] = {
+	/* minus ------------- plus ---------------- */
+	/*       0   1   2   3   4   5   6   7   8  */
+	/* 0 */ {FL, FL, FL, FS, FS, VL, VL, VL, PT},
+	/* 1 */ {FL, FL, FS, FS, FS, VL, VL, VL, __},
+	/* 2 */ {FL, SH, SL, SL, CN, CN, VL, __, __},
+	/* 3 */ {SH, SH, SL, SL, SL, CN, __, __, __},
+	/* 4 */ {SH, SH, CV, SL, SL, __, __, __, __},
+	/* 5 */ {RI, RI, CV, CV, __, __, __, __, __},
+	/* 6 */ {RI, RI, RI, __, __, __, __, __, __},
+	/* 7 */ {RI, RI, __, __, __, __, __, __, __},
+	/* 8 */ {PK, __, __, __, __, __, __, __, __},
-/* legend:
-  FL,  flat
-  PK,  peak, summit
-  RI,  ridge
-  SH,  shoulder
-  CV,  convex
-  SL,  slope
-  CN,  concave
-  FS,  footslope
-  VL,  valley
-  PT,  pit, depression
-  __  error, impossible
- return forms[num_minus][num_plus];
+    /* legend:
+       FL,  flat
+       PK,  peak, summit
+       RI,  ridge
+       SH,  shoulder
+       CV,  convex
+       SL,  slope
+       CN,  concave
+       FS,  footslope
+       VL,  valley
+       PT,  pit, depression
+       __  error, impossible
+    return forms[num_minus][num_plus];
-int determine_binary(int* pattern, int sign)
+int determine_binary(int *pattern, int sign)
-/* extract binary pattern for zenith (+) or nadir (-) from unrotated ternary pattern */
-int n, i;
-unsigned char binary=0, result=255, test=0;
+    /* extract binary pattern for zenith (+) or nadir (-) from unrotated ternary pattern */
+    int n, i;
+    unsigned char binary = 0, result = 255, test = 0;
-		for (i=0,n=1;i<8;i++,n*=2)
-	binary+= (pattern[i]==sign) ? n : 0;
-	/* rotate */
-	for(i=0;i<8;++i) {
-		if ((i &= 7) == 0)
-	test= binary;
-		else
-	test = (binary << i) | (binary >> (8 - i));
-	result = (result<test) ? result : test;
-return (int)result;
+    for (i = 0, n = 1; i < 8; i++, n *= 2)
+	binary += (pattern[i] == sign) ? n : 0;
+    /* rotate */
+    for (i = 0; i < 8; ++i) {
+	if ((i &= 7) == 0)
+	    test = binary;
+	else
+	    test = (binary << i) | (binary >> (8 - i));
+	result = (result < test) ? result : test;
+    return (int)result;
 int rotate(unsigned char binary)
-	int i;
-	unsigned char result=255, test=0;
-		/* rotate */
-	test= binary;
-		else
+    int i;
+    unsigned char result = 255, test = 0;
+    /* rotate */
+	    test = binary;
+	else
-int determine_ternary(int* pattern)
+int determine_ternary(int *pattern)
-/* extract rotated and mirrored ternary pattern form unrotated ternary pattern */
-unsigned ternary_code=0;
-int power, i;
+    /* extract rotated and mirrored ternary pattern form unrotated ternary pattern */
+    unsigned ternary_code = 0;
+    int power, i;
-	for(i=0,power=1;i<8;++i,power*=3)
-ternary_code+=(pattern[i]+1)*power;
-return global_ternary_codes[ternary_code];
+    for (i = 0, power = 1; i < 8; ++i, power *= 3)
+	ternary_code += (pattern[i] + 1) * power;
+    return global_ternary_codes[ternary_code];
-float intensity(float* elevation, int pattern_size)
+float intensity(float *elevation, int pattern_size)
-/* calculate relative elevation of the central cell against its visibility surround */
-float sum_elevation=0.;
-int i;
+    /* calculate relative elevation of the central cell against its visibility surround */
+    float sum_elevation = 0.;
+    int i;
-	for (i=0;i<8;i++)
-sum_elevation-=elevation[i];
+	sum_elevation -= elevation[i];
-return sum_elevation/(float)pattern_size;
+    return sum_elevation / (float)pattern_size;
-float exposition(float* elevation)
+float exposition(float *elevation)
-/* calculate relative elevation of the central cell against its visibility */
-float max=0.;
-int i;
-	for (i=0;i<8;i++)
-max=fabs(elevation[i])>fabs(max)?elevation[i]:max;
-return -max;
+    /* calculate relative elevation of the central cell against its visibility */
+    float max = 0.;
+    int i;
+	max = fabs(elevation[i]) > fabs(max) ? elevation[i] : max;
+    return -max;
-float range(float* elevation)
+float range(float *elevation)
-/* calculate relative difference in visible range of central cell */
-float max=-90000000000., min=9000000000000.; /* should be enough */
-int i;
+    /* calculate relative difference in visible range of central cell */
+    float max = -90000000000., min = 9000000000000.;	/* should be enough */
+    int i;
-	max=elevation[i]>max?elevation[i]:max;
-	min=elevation[i]<min?elevation[i]:min;
+	max = elevation[i] > max ? elevation[i] : max;
+	min = elevation[i] < min ? elevation[i] : min;
-return max-min;
+    return max - min;
-float variance(float* elevation, int pattern_size)
+float variance(float *elevation, int pattern_size)
-/* calculate relative variation of the visible neighbourhood of the cell  */
-float sum_elevation=0;
-float variance=0;
-int i;
+    /* calculate relative variation of the visible neighbourhood of the cell  */
+    float sum_elevation = 0;
+    float variance = 0;
+    int i;
-	for (i=0;i<8;i++)
-sum_elevation+=elevation[i];
-sum_elevation/=(float)pattern_size;
-	for (i=0;i<8;i++)
-variance+=((sum_elevation-elevation[i])*(sum_elevation-elevation[i]));
+	sum_elevation += elevation[i];
+    sum_elevation /= (float)pattern_size;
+	variance +=
+	    ((sum_elevation - elevation[i]) * (sum_elevation - elevation[i]));
-return variance/(float)pattern_size;
+    return variance / (float)pattern_size;
-int radial2cartesian(PATTERN* pattern)
+int radial2cartesian(PATTERN * pattern)
-/* this function converts radial coordinates of geomorphon
- * (assuming center as 0,0) to cartezian coordinates
- * with the begining in the central cell of geomorphon */
-int i;
+    /* this function converts radial coordinates of geomorphon
+     * (assuming center as 0,0) to cartezian coordinates
+     * with the begining in the central cell of geomorphon */
+    int i;
-	for(i=0;i<8;++i)
-if(pattern->distance>0) {
-	pattern->x[i]=pattern->distance[i]*sins[i];
-	pattern->y[i]=pattern->distance[i]*coss[i];
-} else {
-	pattern->x[i]=0;
-	pattern->y[i]=0;
+	if (pattern->distance > 0) {
+	    pattern->x[i] = pattern->distance[i] * sins[i];
+	    pattern->y[i] = pattern->distance[i] * coss[i];
+	else {
+	    pattern->x[i] = 0;
+	    pattern->y[i] = 0;
+    return 0;
-return 0;
-float extends(PATTERN* pattern, int pattern_size)
+float extends(PATTERN * pattern, int pattern_size)
-int i,j;
-float area=0;
-for(i=0,j=1;i<8;++i,++j) {
-	j=j<8?j:0;
-	area+=(pattern->x[i]*pattern->y[j]-pattern->x[j]*pattern->y[i]);
+    int i, j;
+    float area = 0;
+    for (i = 0, j = 1; i < 8; ++i, ++j) {
+	j = j < 8 ? j : 0;
+	area +=
+	    (pattern->x[i] * pattern->y[j] - pattern->x[j] * pattern->y[i]);
+    return fabs(area) / 2.;
-return fabs(area)/2.;
-int shape(PATTERN* pattern, int pattern_size, float* azimuth, float* elongation, float* width)
+int shape(PATTERN * pattern, int pattern_size, float *azimuth,
+	  float *elongation, float *width)
-/* calculates azimuth, elongation and width of geomorphon's polygon */
-int i;
-double avg_x=0, avg_y=0;
-double avg_x_y=0;
-double avg_x_square;
-double rx, ry;
-double sine, cosine;
-double result;
-double rxmin, rxmax, rymin, rymax;
+    /* calculates azimuth, elongation and width of geomorphon's polygon */
+    int i;
+    double avg_x = 0, avg_y = 0;
+    double avg_x_y = 0;
+    double avg_x_square;
+    double rx, ry;
+    double sine, cosine;
+    double result;
+    double rxmin, rxmax, rymin, rymax;
-for (i=0;i<8;++i) {
 	avg_y += pattern->y[i];
 	avg_x += pattern->x[i];
-	avg_x_square += pattern->x[i]*pattern->x[i];
-	avg_x_y += pattern->x[i]*pattern->y[i];
-avg_y /= (float)pattern_size;
-avg_x /= (float)pattern_size;
-avg_x_y /= (float)pattern_size;
-avg_x_square /= (float)pattern_size;
-result=(avg_x_y - avg_x * avg_y) / (avg_x_square - avg_x * avg_x);
-result=atan(result);
-*azimuth=(float)RAD2DEGREE(PI2-result);
+	avg_x_square += pattern->x[i] * pattern->x[i];
+	avg_x_y += pattern->x[i] * pattern->y[i];
+    avg_y /= (float)pattern_size;
+    avg_x /= (float)pattern_size;
+    avg_x_y /= (float)pattern_size;
+    avg_x_square /= (float)pattern_size;
+    result = (avg_x_y - avg_x * avg_y) / (avg_x_square - avg_x * avg_x);
+    result = atan(result);
+    *azimuth = (float)RAD2DEGREE(PI2 - result);
-/* rotation */
-sine=sin(result);
-cosine=cos(result);
-	rx=pattern->x[i]*cosine-pattern->y[i]*sine;
-	ry=pattern->x[i]*sine+pattern->y[i]*cosine;
-	rxmin= rx<rxmin ? rx : rxmin;
-	rxmax= rx>rxmax ? rx : rxmax;
-	rymin= ry<rymin ? ry : rymin;
-	rymax= ry>rymax ? ry : rymax;
+    /* rotation */
+    sine = sin(result);
+    cosine = cos(result);
+	rx = pattern->x[i] * cosine - pattern->y[i] * sine;
+	ry = pattern->x[i] * sine + pattern->y[i] * cosine;
+	rxmin = rx < rxmin ? rx : rxmin;
+	rxmax = rx > rxmax ? rx : rxmax;
+	rymin = ry < rymin ? ry : rymin;
+	rymax = ry > rymax ? ry : rymax;
+    rx = (rxmax - rxmin);
+    ry = (rymax - rymin);
+    *elongation = rx > ry ? (float)rx / ry : (float)ry / rx;
+    *width = rx > ry ? ry : rx;
+    return 0;
-rx=(rxmax-rxmin);
-ry=(rymax-rymin);
-*elongation=rx>ry?(float)rx/ry:(float)ry/rx;
-*width=rx>ry?ry:rx;
-return 0;
\ No newline at end of file
Modified: grass-addons/grass7/raster/r.geomorphon/local_proto.h
--- grass-addons/grass7/raster/r.geomorphon/local_proto.h	2013-02-27 05:22:05 UTC (rev 55233)
+++ grass-addons/grass7/raster/r.geomorphon/local_proto.h	2013-02-27 05:27:59 UTC (rev 55234)
@@ -6,39 +6,39 @@
 #include <grass/raster.h>
 #ifdef MAIN
-#  define GLOBAL
+#define GLOBAL
 #else
-#  define GLOBAL extern
+#define GLOBAL extern
 #endif
-#ifndef PI2 /* PI/2 */
-  #define PI2 (2*atan(1))
+#ifndef PI2			/* PI/2 */
+#define PI2 (2*atan(1))
 #endif
-#ifndef PI4 /* PI/4 */
-  #define PI4 (atan(1))
+#ifndef PI4			/* PI/4 */
+#define PI4 (atan(1))
 #endif
 #ifndef PI
-  #define PI (4*atan(1))
+#define PI (4*atan(1))
 #endif
-#ifndef M2PI /* 2*PI */
-  #define M2PI (8*atan(1))
+#ifndef M2PI			/* 2*PI */
+#define M2PI (8*atan(1))
 #endif
 #ifndef GRADE
-  #define GRADE (atan(1)/45)
+#define GRADE (atan(1)/45)
 #endif
 #ifndef PI2PERCENT
-  #define PI2PERCENT (50/atan(1))
+#define PI2PERCENT (50/atan(1))
 #endif
 #ifndef UNKNOWN
-  #define UNKNOWN -1
+#define UNKNOWN -1
 #endif
@@ -49,72 +49,79 @@
 #define MAX(a,b) ((a) > (b) ? (a) : (b))
 #define MIN(a,b) ((a) < (b) ? (a) : (b))
-typedef char* STRING;
+typedef char *STRING;
-typedef struct {
-  char elevname[150];
-  RASTER_MAP_TYPE raster_type;
-  FCELL **elev;
-  int fd; /* file descriptor */
+typedef struct
+    char elevname[150];
+    RASTER_MAP_TYPE raster_type;
+    FCELL **elev;
+    int fd;			/* file descriptor */
 } MAPS;
-typedef struct { /* struct is used both for interface and output */
-	char* name;
-	int required;
-	char* description;
-	char* gui;
-	RASTER_MAP_TYPE out_data_type;
-	int fd;
-	void* buffer;
+typedef struct
+{				/* struct is used both for interface and output */
+    char *name;
+    int required;
+    char *description;
+    char *gui;
+    RASTER_MAP_TYPE out_data_type;
+    int fd;
+    void *buffer;
 } IO;
-typedef struct {
-	char name[100];
-	int fd;
-	CELL* forms_buffer;
+typedef struct
+    char name[100];
+    int fd;
+    CELL *forms_buffer;
 } MULTI;
-typedef struct {
-	int num_positives;
-	int num_negatives;
-	unsigned char positives;
-	unsigned char negatives;
-	int pattern[8];
-	float elevation[8];
-	double distance[8];
-	double x[8],y[8]; /* cartesian coordinates of geomorphon */
+typedef struct
+    int num_positives;
+    int num_negatives;
+    unsigned char positives;
+    unsigned char negatives;
+    int pattern[8];
+    float elevation[8];
+    double distance[8];
+    double x[8], y[8];		/* cartesian coordinates of geomorphon */
 } PATTERN;
-typedef enum {
-  ZERO, /* zero cats do not accept zero category */
-  FL, /* flat */
-  PK, /* peak, summit */
-  RI, /* ridge */
-  SH, /* shoulder */
-  CV, /* convex slope */
-  SL, /* slope */
-  CN, /* concave slope */
-  FS, /* footslope */
-  VL, /* valley */
-  PT, /* pit, depression */
-  __, /* error */
-  CNT /* counter */
+typedef enum
+    ZERO,			/* zero cats do not accept zero category */
+    FL,				/* flat */
+    PK,				/* peak, summit */
+    RI,				/* ridge */
+    SH,				/* shoulder */
+    CV,				/* convex slope */
+    SL,				/* slope */
+    CN,				/* concave slope */
+    FS,				/* footslope */
+    VL,				/* valley */
+    PT,				/* pit, depression */
+    __,				/* error */
+    CNT				/* counter */
 } FORMS;
-typedef struct {
-  int cat;
-  int r;
-  int g;
-  int b;
-  char* label;
+typedef struct
+    int cat;
+    int r;
+    int g;
+    int b;
+    char *label;
 } CATCOLORS;
-typedef struct {
-  double cat;
-  int r;
-  int g;
-  int b;
-  char* label;
+typedef struct
+    double cat;
+    int r;
+    int g;
+    int b;
+    char *label;
 } FCOLORS;
 /* variables */
@@ -123,9 +130,9 @@
 GLOBAL int search_cells, skip_cells, step_cells, start_cells;
 GLOBAL int num_of_steps;
 GLOBAL double search_distance, skip_distance, flat_distance;
-GLOBAL double start_distance, step_distance; /* multiresolution mode */
+GLOBAL double start_distance, step_distance;	/* multiresolution mode */
 GLOBAL double flat_threshold, flat_threshold_height;
-GLOBAL double H,V;
+GLOBAL double H, V;
 GLOBAL struct Cell_head window;
 GLOBAL int cell_step;
@@ -133,30 +140,32 @@
 unsigned int global_ternary_codes[6562];
 /* memory */
-int open_map(MAPS* rast);
+int open_map(MAPS * rast);
 int create_maps(void);
 int shift_buffers(int row);
-int get_cell (int col, float* buf_row, void* buf, RASTER_MAP_TYPE raster_type);
-int free_map(FCELL **map, int n);
-int write_form_cat_colors (char* raster, CATCOLORS* ccolors);
+int get_cell(int col, float *buf_row, void *buf, RASTER_MAP_TYPE raster_type);
+int free_map(FCELL ** map, int n);
+int write_form_cat_colors(char *raster, CATCOLORS * ccolors);
 /*geom */
-int calc_pattern(PATTERN* pattern, int row, int cur_row, int col);
-unsigned int ternary_rotate (unsigned int value);
+int calc_pattern(PATTERN * pattern, int row, int cur_row, int col);
+unsigned int ternary_rotate(unsigned int value);
 int determine_form(int num_plus, int num_minus);
-int determine_binary(int* pattern, int sign);
-int determine_ternary(int* pattern);
+int determine_binary(int *pattern, int sign);
+int determine_ternary(int *pattern);
 int rotate(unsigned char binary);
-float intensity(float* elevation, int pattern_size);
-float exposition(float* elevation);
-float range(float* elevation);
-float variance(float* elevation, int n);
-int shape(PATTERN* pattern, int pattern_size, float* azimuth, float* elongation, float* width);
-float extends(PATTERN* pattern, int pattern_size);
+float intensity(float *elevation, int pattern_size);
+float exposition(float *elevation);
+float range(float *elevation);
+float variance(float *elevation, int n);
+	  float *elongation, float *width);
+float extends(PATTERN * pattern, int pattern_size);
 /* multires */
 int reset_multi_patterns(void);
 int calc_multi_patterns(int row, int cur_row, int col);
 int update_pattern(int k, int i,
-									 double zenith_height, double zenith_distance, double zenith_angle,
-									 double nadir_height, double nadir_distance, double nadir_angle);
+		   double zenith_height, double zenith_distance,
+		   double zenith_angle, double nadir_height,
+		   double nadir_distance, double nadir_angle);
Modified: grass-addons/grass7/raster/r.geomorphon/main.c
--- grass-addons/grass7/raster/r.geomorphon/main.c	2013-02-27 05:22:05 UTC (rev 55233)
+++ grass-addons/grass7/raster/r.geomorphon/main.c	2013-02-27 05:27:59 UTC (rev 55234)
@@ -1,89 +1,106 @@
-* MODULE:			r.geomorphon
+* MODULE:	r.geomorphon
 * AUTHOR(S):	Jarek Jasiewicz jarekj amu.edu.pl with collaboration of Tom Stepinski stepintz uc.edu based on idea of Tomasz Stepinski and Jaroslaw Jasiewicz
-* PURPOSE:		Calculate terrain forms using machine-vison technique called geomorphons
-*							This module allow to calculate standard set of terrain forms
-*							using look-up table proposed by authors, calculate patterns (binary and ternary)
-*							for every pixel as well as several geomorphometrical parameters
-*							This technology is currently capable of "experimental" stage.
+* PURPOSE:	Calculate terrain forms using machine-vison technique called geomorphons
+*		This module allow to calculate standard set of terrain forms
+*		using look-up table proposed by authors, calculate patterns (binary and ternary)
+*		for every pixel as well as several geomorphometrical parameters
+*		This technology is currently capable of "experimental" stage.
 * COPYRIGHT:	(C) 2002,2012 by the GRASS Development Team
-*							(C) Scientific idea of geomotrphon copyrighted to authors.
+*		(C) Scientific idea of geomotrphon copyrighted to authors.
-*							This program is free software under the GNU General Public
-*							License (>=v2). Read the file COPYING that comes with GRASS
-*							for details.
+*		This program is free software under the GNU General Public
+*		License (>=v2). Read the file COPYING that comes with GRASS
+*		for details.
 #define MAIN
-typedef enum {i_dem, o_forms, o_ternary, o_positive, o_negative, o_intensity, o_exposition,
-	o_range, o_variance, o_elongation, o_azimuth, o_extend, o_width, io_size} outputs;
+typedef enum
+{ i_dem, o_forms, o_ternary, o_positive, o_negative, o_intensity,
+	o_exposition,
+    o_range, o_variance, o_elongation, o_azimuth, o_extend, o_width, io_size
+} outputs;
 int main(int argc, char **argv)
-	IO rasters[] = { /* rasters stores output buffers */
-		{"dem",YES,"Input dem","input",UNKNOWN,-1,NULL}, /* WARNING: this one map is input */
-		{"forms",NO,"Most common geomorphic forms","patterns",CELL_TYPE,-1,NULL},
-		{"ternary",NO,"code of ternary patterns","patterns",CELL_TYPE,-1,NULL},
-		{"positive",NO,"code of binary positive patterns","patterns",CELL_TYPE,-1,NULL},
-		{"negative",NO,"code of binary negative patterns","patterns",CELL_TYPE,-1,NULL},
-		{"intensity",NO,"rasters containing mean relative elevation of the form","geometry",FCELL_TYPE,-1,NULL},
-		{"exposition",NO,"rasters containing maximum difference between extend and central cell","geometry",FCELL_TYPE,-1,NULL},
-		{"range",NO,"rasters containing difference between max and min elevation of the form extend","geometry",FCELL_TYPE,-1,NULL},
-		{"variance",NO,"rasters containing variance of form boundary","geometry",FCELL_TYPE,-1,NULL},
-		{"elongation",NO,"rasters containing local elongation","geometry",FCELL_TYPE,-1,NULL},
-		{"azimuth",NO,"rasters containing local azimuth of the elongation","geometry",FCELL_TYPE,-1,NULL},
-		{"extend",NO,"rasters containing local extend (area) of the form","geometry",FCELL_TYPE,-1,NULL},
-		{"width",NO,"rasters containing local width of the form","geometry",FCELL_TYPE,-1,NULL}
-	}; /* adding more maps change IOSIZE macro */
-	CATCOLORS ccolors[CNT]={ /* colors and cats for forms */
-		{ZERO, 0, 0, 0, "forms"},
-		{FL, 220, 220, 220, "flat"},
-		{PK, 56, 0, 0, "summit"},
-		{RI, 200, 0, 0, "ridge"},
-		{SH, 255, 80, 20, "shoulder"},
-		{CV, 250, 210, 60, "spur"},
-		{SL, 255, 255, 60, "slope"},
-		{CN, 180, 230, 20, "hollow"},
-		{FS, 60, 250, 150, "footslope"},
-		{VL, 0, 0, 255, "valley"},
-		{PT, 0, 0, 56, "depression"},
-		{__, 255, 0, 255, "ERROR"}};
+    IO rasters[] = {		/* rasters stores output buffers */
+	{"dem", YES, "Input dem", "input", UNKNOWN, -1, NULL},	/* WARNING: this one map is input */
+	{"forms", NO, "Most common geomorphic forms", "patterns", CELL_TYPE,
+	 -1, NULL},
+	{"ternary", NO, "code of ternary patterns", "patterns", CELL_TYPE, -1,
+	 NULL},
+	{"positive", NO, "code of binary positive patterns", "patterns",
+	 CELL_TYPE, -1, NULL},
+	{"negative", NO, "code of binary negative patterns", "patterns",
+	{"intensity", NO,
+	 "rasters containing mean relative elevation of the form", "geometry",
+	 FCELL_TYPE, -1, NULL},
+	{"exposition", NO,
+	 "rasters containing maximum difference between extend and central cell",
+	 "geometry", FCELL_TYPE, -1, NULL},
+	{"range", NO,
+	 "rasters containing difference between max and min elevation of the form extend",
+	{"variance", NO, "rasters containing variance of form boundary",
+	{"elongation", NO, "rasters containing local elongation", "geometry",
+	{"azimuth", NO, "rasters containing local azimuth of the elongation",
+	{"extend", NO, "rasters containing local extend (area) of the form",
+	{"width", NO, "rasters containing local width of the form",
+    };				/* adding more maps change IOSIZE macro */
-struct GModule *module;
-	struct Option
-					*opt_input,
-					*opt_output[io_size],
-					*par_search_radius,
-					*par_skip_radius,
-					*par_flat_treshold,
-					*par_flat_distance,
-					*par_multi_prefix,
-					*par_multi_step,
-					*par_multi_start;
-	struct Flag *flag_units,
-							*flag_extended;
+    CATCOLORS ccolors[CNT] = {	/* colors and cats for forms */
+	{ZERO, 0, 0, 0, "forms"},
+	{FL, 220, 220, 220, "flat"},
+	{PK, 56, 0, 0, "summit"},
+	{RI, 200, 0, 0, "ridge"},
+	{SH, 255, 80, 20, "shoulder"},
+	{CV, 250, 210, 60, "spur"},
+	{SL, 255, 255, 60, "slope"},
+	{CN, 180, 230, 20, "hollow"},
+	{FS, 60, 250, 150, "footslope"},
+	{VL, 0, 0, 255, "valley"},
+	{PT, 0, 0, 56, "depression"},
+	{__, 255, 0, 255, "ERROR"}
-	struct History history;
+    struct GModule *module;
+    struct Option
+	*opt_input,
+	*opt_output[io_size],
+	*par_search_radius,
+	*par_skip_radius,
+	*par_flat_treshold,
+	*par_flat_distance,
+	*par_multi_prefix, *par_multi_step, *par_multi_start;
+    struct Flag *flag_units, *flag_extended;
-	int i,j, n;
-	int meters=0, multires=0, extended=0; /* flags */
-	int row,cur_row,col,radius;
-	int pattern_size;
-	double max_resolution;
-	char prefix[20];
+    struct History history;
-	G_gisinit(argv[0]);
+    int i, j, n;
+    int meters = 0, multires = 0, extended = 0;	/* flags */
+    int row, cur_row, col, radius;
+    int pattern_size;
+    double max_resolution;
+    char prefix[20];
-{  /* interface  parameters */
+    G_gisinit(argv[0]);
+    {				/* interface  parameters */
 	module = G_define_module();
 	module->description =
-	_("Calculate geomorphons (terrain forms)and associated geometry using machine vision approach");
+	    _("Calculate geomorphons (terrain forms)and associated geometry using machine vision approach");
 	G_add_keyword("Geomorphons");
 	G_add_keyword("Terrain patterns");
 	G_add_keyword("Machine vision geomorphometry");
@@ -93,13 +110,13 @@
 	opt_input->required = rasters[0].required;
 	opt_input->description = _(rasters[0].description);
-		for (i=1;i<io_size;++i) { /* WARNING: loop starts from one, zero is for input */
-	opt_output[i] = G_define_standard_option(G_OPT_R_OUTPUT);
-	opt_output[i]->key = rasters[i].name;
-	opt_output[i]->required = NO;
-	opt_output[i]->description = _(rasters[i].description);
-	opt_output[i]->guisection = _(rasters[i].gui);
+	for (i = 1; i < io_size; ++i) {	/* WARNING: loop starts from one, zero is for input */
+	    opt_output[i] = G_define_standard_option(G_OPT_R_OUTPUT);
+	    opt_output[i]->key = rasters[i].name;
+	    opt_output[i]->required = NO;
+	    opt_output[i]->description = _(rasters[i].description);
+	    opt_output[i]->guisection = _(rasters[i].gui);
 	par_search_radius = G_define_option();
 	par_search_radius->key = "search";
@@ -127,339 +144,410 @@
 	par_flat_distance->type = TYPE_DOUBLE;
 	par_flat_distance->answer = "0";
 	par_flat_distance->required = YES;
-	par_flat_distance->description = _("Flatenss distance, zero for none");
+	par_flat_distance->description =
+	    _("Flatenss distance, zero for none");
 	par_multi_prefix = G_define_option();
 	par_multi_prefix->key = "prefix";
 	par_multi_prefix->type = TYPE_STRING;
-	par_multi_prefix->description = _("prefix for maps resulting from multiresolution approach");
+	par_multi_prefix->description =
+	    _("prefix for maps resulting from multiresolution approach");
 	par_multi_prefix->guisection = _("multires");
 	par_multi_step = G_define_option();
 	par_multi_step->key = "step";
 	par_multi_step->type = TYPE_DOUBLE;
 	par_multi_step->answer = "0";
-	par_multi_step->description = _("distance step for every iteration (zero to omit)");
+	par_multi_step->description =
+	    _("distance step for every iteration (zero to omit)");
 	par_multi_step->guisection = _("multires");
 	par_multi_start = G_define_option();
 	par_multi_start->key = "start";
 	par_multi_start->type = TYPE_DOUBLE;
 	par_multi_start->answer = "0";
-	par_multi_start->description = _("distance where serch will start in multiple mode (zero to omit)");
+	par_multi_start->description =
+	    _("distance where serch will start in multiple mode (zero to omit)");
 	par_multi_start->guisection = _("multires");
 	flag_units = G_define_flag();
 	flag_units->key = 'm';
-	flag_units->description = _("Use meters to define search units (default is cells)");
+	flag_units->description =
+	    _("Use meters to define search units (default is cells)");
 	flag_extended = G_define_flag();
 	flag_extended->key = 'e';
 	flag_extended->description = _("Use extended form correction");
-		if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
+	if (G_parser(argc, argv))
+	    exit(EXIT_FAILURE);
-{	/* calculate parameters */
-	int num_outputs=0;
+    {				/* calculate parameters */
+	int num_outputs = 0;
 	double search_radius, skip_radius, start_radius, step_radius;
 	double ns_resolution;
-	multires=(par_multi_prefix->answer)?1:0;
-			for (i=1;i<io_size;++i) /* check for outputs */
-	if(opt_output[i]->answer) {
-			if (G_legal_filename(opt_output[i]->answer) < 0)
-		G_fatal_error(_("<%s> is an illegal file name"), opt_output[i]->answer);
+	multires = (par_multi_prefix->answer) ? 1 : 0;
+	for (i = 1; i < io_size; ++i)	/* check for outputs */
+	    if (opt_output[i]->answer) {
+		if (G_legal_filename(opt_output[i]->answer) < 0)
+		    G_fatal_error(_("<%s> is an illegal file name"),
+				  opt_output[i]->answer);
 		num_outputs++;
-		if(!num_outputs && !multires)
-	G_fatal_error(_("At least one output is required"));
+	if (!num_outputs && !multires)
+	    G_fatal_error(_("At least one output is required"));
-	meters=(flag_units->answer != 0);
-	extended=(flag_extended->answer != 0);
+	meters = (flag_units->answer != 0);
+	extended = (flag_extended->answer != 0);
 	nrows = Rast_window_rows();
 	ncols = Rast_window_cols();
 	Rast_get_window(&window);
 	G_begin_distance_calculations();
-	if(G_projection()==PROJECTION_LL)	{ /* for LL max_res should be NS */
-		ns_resolution=G_distance(0,Rast_row_to_northing(0, &window),0,Rast_row_to_northing(1, &window));
-		max_resolution=ns_resolution;
-	} else {
-		max_resolution=MAX(window.ns_res,window.ew_res); /* max_resolution MORE meters per cell */
-		ns_resolution=window.ns_res;
+	if (G_projection() == PROJECTION_LL) {	/* for LL max_res should be NS */
+	    ns_resolution =
+		G_distance(0, Rast_row_to_northing(0, &window), 0,
+			   Rast_row_to_northing(1, &window));
+	    max_resolution = ns_resolution;
+	else {
+	    max_resolution = MAX(window.ns_res, window.ew_res);	/* max_resolution MORE meters per cell */
+	    ns_resolution = window.ns_res;
 	/* search distance */
-	search_radius=atof(par_search_radius->answer);
-	search_cells=meters?(int)(search_radius/max_resolution):search_radius;
-		if(search_cells<1)
-	G_fatal_error(_("Search radius size must cover at least 1 cell"));
-	row_radius_size=meters?ceil(search_radius/ns_resolution):search_radius;
-	row_buffer_size=row_radius_size*2+1;
-	search_distance=(meters)?search_radius:ns_resolution*search_cells;
+	search_radius = atof(par_search_radius->answer);
+	search_cells =
+	    meters ? (int)(search_radius / max_resolution) : search_radius;
+	if (search_cells < 1)
+	    G_fatal_error(_("Search radius size must cover at least 1 cell"));
+	row_radius_size =
+	    meters ? ceil(search_radius / ns_resolution) : search_radius;
+	row_buffer_size = row_radius_size * 2 + 1;
+	search_distance =
+	    (meters) ? search_radius : ns_resolution * search_cells;
 	/* skip distance */
-	skip_radius=atof(par_skip_radius->answer);
-	skip_cells=meters?(int)(skip_radius/max_resolution):skip_radius;
-		if(skip_cells>=search_cells)
-	G_fatal_error(_("Skip radius size must be at least 1 cell lower than radius"));
-	skip_distance=(meters)?skip_radius:ns_resolution*skip_cells;
+	skip_radius = atof(par_skip_radius->answer);
+	skip_cells =
+	    meters ? (int)(skip_radius / max_resolution) : skip_radius;
+	if (skip_cells >= search_cells)
+	    G_fatal_error(_("Skip radius size must be at least 1 cell lower than radius"));
+	skip_distance = (meters) ? skip_radius : ns_resolution * skip_cells;
 	/* flatness parameters */
-	flat_threshold=atof(par_flat_treshold->answer);
-		if(flat_threshold<=0.)
-	G_fatal_error(_("Flatenss treshold must be grater than 0"));
-	flat_threshold=DEGREE2RAD(flat_threshold);
+	flat_threshold = atof(par_flat_treshold->answer);
+	if (flat_threshold <= 0.)
+	    G_fatal_error(_("Flatenss treshold must be grater than 0"));
+	flat_threshold = DEGREE2RAD(flat_threshold);
-	flat_distance=atof(par_flat_distance->answer);
-	flat_distance=(meters)?flat_distance:ns_resolution*flat_distance;
-	flat_threshold_height=tan(flat_threshold)*flat_distance;
-	if((flat_distance>0&&flat_distance<=skip_distance)||flat_distance>=search_distance) {
-		G_warning(_("Flatenss distance should be between skip and search radius. Otherwise ignored"));
-		flat_distance=0;
+	flat_distance = atof(par_flat_distance->answer);
+	flat_distance =
+	    (meters) ? flat_distance : ns_resolution * flat_distance;
+	flat_threshold_height = tan(flat_threshold) * flat_distance;
+	if ((flat_distance > 0 && flat_distance <= skip_distance) ||
+	    flat_distance >= search_distance) {
+	    G_warning(_("Flatenss distance should be between skip and search radius. Otherwise ignored"));
+	    flat_distance = 0;
-	if(multires) {
-		start_radius=atof(par_multi_start->answer);
-		start_cells=meters?(int)(start_radius/max_resolution):start_radius;
-			if(start_cells<=skip_cells)
-		start_cells=skip_cells+1;
-		start_distance=(meters)?start_radius:ns_resolution*start_cells;
+	if (multires) {
+	    start_radius = atof(par_multi_start->answer);
+	    start_cells =
+		meters ? (int)(start_radius / max_resolution) : start_radius;
+	    if (start_cells <= skip_cells)
+		start_cells = skip_cells + 1;
+	    start_distance =
+		(meters) ? start_radius : ns_resolution * start_cells;
-		step_radius=atof(par_multi_step->answer);
-		step_cells=meters?(int)(step_radius/max_resolution):step_radius;
-		step_distance=(meters)?step_radius:ns_resolution*step_cells;
-			if(step_distance<ns_resolution)
+	    step_radius = atof(par_multi_step->answer);
+	    step_cells =
+		meters ? (int)(step_radius / max_resolution) : step_radius;
+	    step_distance =
+		(meters) ? step_radius : ns_resolution * step_cells;
+	    if (step_distance < ns_resolution)
 		G_fatal_error(_("For multiresolution mode step must be greater than or equal to resolution of one cell"));
-			if (G_legal_filename(par_multi_prefix->answer) < 0 ||strlen(par_multi_prefix->answer)>19)
-		G_fatal_error(_("<%s> is an incorrect prefix"), par_multi_prefix->answer);
-		strcpy(prefix,par_multi_prefix->answer);
-		strcat(prefix,"_");
-		num_of_steps=(int)ceil(search_distance/step_distance);
-	} /* end multires preparation */
+	    if (G_legal_filename(par_multi_prefix->answer) < 0 ||
+		strlen(par_multi_prefix->answer) > 19)
+		G_fatal_error(_("<%s> is an incorrect prefix"),
+			      par_multi_prefix->answer);
+	    strcpy(prefix, par_multi_prefix->answer);
+	    strcat(prefix, "_");
+	    num_of_steps = (int)ceil(search_distance / step_distance);
+	}			/* end multires preparation */
 	/* print information about distances */
-	G_message("Search distance m: %f, cells: %d", search_distance, search_cells);
-	G_message("Skip distance m: %f, cells: %d", skip_distance, skip_cells);
-	G_message("Flat threshold distance m: %f, height: %f",flat_distance, flat_threshold_height);
-	G_message("%s version",(extended)?"extended":"basic");
-		if(multires) {
-	G_message("Multiresolution mode: search start at: m: %f, cells: %d", start_distance, start_cells);
-	G_message("Multiresolution mode: search step is: m: %f, number of steps %d", step_distance,num_of_steps);
-	G_message("Prefix for output: %s",prefix);
+	G_message("Search distance m: %f, cells: %d", search_distance,
+		  search_cells);
+	G_message("Skip distance m: %f, cells: %d", skip_distance,
+		  skip_cells);
+	G_message("Flat threshold distance m: %f, height: %f", flat_distance,
+		  flat_threshold_height);
+	G_message("%s version", (extended) ? "extended" : "basic");
+	if (multires) {
+	    G_message
+		("Multiresolution mode: search start at: m: %f, cells: %d",
+		 start_distance, start_cells);
+	    G_message
+		("Multiresolution mode: search step is: m: %f, number of steps %d",
+		 step_distance, num_of_steps);
+	    G_message("Prefix for output: %s", prefix);
-	/* generate global ternary codes */
-		for(i=0;i<6561;++i)
-	global_ternary_codes[i]=ternary_rotate(i);
+    /* generate global ternary codes */
+    for (i = 0; i < 6561; ++i)
+	global_ternary_codes[i] = ternary_rotate(i);
-	/* open DEM */
-	strcpy(elevation.elevname,opt_input->answer);
-	open_map(&elevation);
+    /* open DEM */
+    strcpy(elevation.elevname, opt_input->answer);
+    open_map(&elevation);
-if(!multires)
-	PATTERN* pattern;
+    if (!multires) {
+	PATTERN *pattern;
 	PATTERN patterns[4];
-	void* pointer_buf;
+	void *pointer_buf;
 	int formA, formB, formC;
-	double search_dist=search_distance;
-	double skip_dist=skip_distance;
-	double flat_dist=flat_distance;
-	double area_of_octagon=4*(search_distance*search_distance)*sin(DEGREE2RAD(45.));
+	double search_dist = search_distance;
+	double skip_dist = skip_distance;
+	double flat_dist = flat_distance;
+	double area_of_octagon =
+	    4 * (search_distance * search_distance) * sin(DEGREE2RAD(45.));
-	cell_step=1;
+	cell_step = 1;
 	/* prepare outputs */
-		rasters[i].fd=Rast_open_new(opt_output[i]->answer,rasters[i].out_data_type);
-		rasters[i].buffer=Rast_allocate_buf(rasters[i].out_data_type);
+		rasters[i].fd =
+		    Rast_open_new(opt_output[i]->answer,
+				  rasters[i].out_data_type);
+		rasters[i].buffer =
+		    Rast_allocate_buf(rasters[i].out_data_type);
 	/* main loop */
-	for(row=0;row<nrows;++row) {
-		G_percent(row, nrows, 2);
-		cur_row = (row < row_radius_size)?row:
-			((row >= nrows-row_radius_size-1) ? row_buffer_size - (nrows-row-1) : row_radius_size);
-			if(row>(row_radius_size) && row<nrows-(row_radius_size+1))
+	for (row = 0; row < nrows; ++row) {
+	    G_percent(row, nrows, 2);
+	    cur_row = (row < row_radius_size) ? row :
+		((row >=
+		  nrows - row_radius_size - 1) ? row_buffer_size - (nrows -
+								    row -
+								    1) :
+		 row_radius_size);
+	    if (row > (row_radius_size) &&
+		row < nrows - (row_radius_size + 1))
 		shift_buffers(row);
-		for (col=0;col<ncols;++col) {
+	    for (col = 0; col < ncols; ++col) {
 		/* on borders forms ussualy are innatural. */
-			if(row<(skip_cells+1) || row>nrows-(skip_cells+2) ||
-				col<(skip_cells+1) || col>ncols-(skip_cells+2) ||
-				Rast_is_f_null_value(&elevation.elev[cur_row][col])) {
-/* set outputs to NULL and do nothing if source value is null	or border*/
-						pointer_buf=rasters[i].buffer;
-						switch (rasters[i].out_data_type) {
-						case CELL_TYPE:
-							Rast_set_c_null_value(&((CELL*)pointer_buf)[col],1);
-							break;
-						case FCELL_TYPE:
-							Rast_set_f_null_value(&((FCELL*)pointer_buf)[col],1);
-							break;
-						case DCELL_TYPE:
-							Rast_set_d_null_value(&((DCELL*)pointer_buf)[col],1);
-							break;
-						default:
-							G_fatal_error(_("Unknown output data type"));
-					continue;
-			} /* end null value */
-	int cur_form, small_form;
-	search_distance=search_dist;
-	skip_distance=skip_dist;
-	flat_distance=flat_dist;
-	pattern_size=calc_pattern(&patterns[0],row,cur_row,col);
-	pattern=&patterns[0];
-	cur_form=determine_form(pattern->num_negatives,pattern->num_positives);
+		if (row < (skip_cells + 1) || row > nrows - (skip_cells + 2)
+		    || col < (skip_cells + 1) ||
+		    col > ncols - (skip_cells + 2) ||
+		    Rast_is_f_null_value(&elevation.elev[cur_row][col])) {
+		    /* set outputs to NULL and do nothing if source value is null   or border */
+			    pointer_buf = rasters[i].buffer;
+			    switch (rasters[i].out_data_type) {
+			    case CELL_TYPE:
+				Rast_set_c_null_value(&((CELL *) pointer_buf)
+						      [col], 1);
+				break;
+			    case FCELL_TYPE:
+				Rast_set_f_null_value(&((FCELL *) pointer_buf)
+						      [col], 1);
+				break;
+			    case DCELL_TYPE:
+				Rast_set_d_null_value(&((DCELL *) pointer_buf)
+						      [col], 1);
+				break;
+			    default:
+				G_fatal_error(_("Unknown output data type"));
+		    continue;
+		}		/* end null value */
+		    int cur_form, small_form;
-	/* correction of forms */
-	if(extended && search_distance>10*max_resolution) {
-		/* 1) remove extensive innatural forms: ridges, peaks, shoulders and footslopes */
-		if((cur_form==4||cur_form==8||cur_form==2||cur_form==3)) {
-			search_distance=(search_dist/2.<4*max_resolution)? 4*max_resolution : search_dist/2.;
-			skip_distance=0;
-			flat_distance=0;
-			pattern_size=calc_pattern(&patterns[1],row,cur_row,col);
-			pattern=&patterns[1];
-			small_form=determine_form(pattern->num_negatives,pattern->num_positives);
-				if(cur_form==4||cur_form==8)
-			cur_form=(small_form==1)? 1 : cur_form;
-				if(cur_form==2||cur_form==3)
-			cur_form=small_form;
+		    search_distance = search_dist;
+		    skip_distance = skip_dist;
+		    flat_distance = flat_dist;
+		    pattern_size =
+			calc_pattern(&patterns[0], row, cur_row, col);
+		    pattern = &patterns[0];
+		    cur_form =
+			determine_form(pattern->num_negatives,
+				       pattern->num_positives);
+		    /* correction of forms */
+		    if (extended && search_distance > 10 * max_resolution) {
+			/* 1) remove extensive innatural forms: ridges, peaks, shoulders and footslopes */
+			if ((cur_form == 4 || cur_form == 8 || cur_form == 2
+			     || cur_form == 3)) {
+			    search_distance =
+				(search_dist / 2. <
+				 4 * max_resolution) ? 4 *
+				max_resolution : search_dist / 2.;
+			    skip_distance = 0;
+			    pattern_size =
+				calc_pattern(&patterns[1], row, cur_row, col);
+			    pattern = &patterns[1];
+			    small_form =
+			    if (cur_form == 4 || cur_form == 8)
+				cur_form = (small_form == 1) ? 1 : cur_form;
+			    if (cur_form == 2 || cur_form == 3)
+				cur_form = small_form;
+			/* 3) Depressions */
+		    }		/* end of correction */
+		    if (opt_output[o_forms]->answer)
+			((CELL *) rasters[o_forms].buffer)[col] = cur_form;
-		/* 3) Depressions */
- } /* end of correction */
-		if(opt_output[o_forms]->answer)
-	((CELL*)rasters[o_forms].buffer)[col]=cur_form;
-				if(opt_output[o_ternary]->answer)
-			((CELL*)rasters[o_ternary].buffer)[col]=determine_ternary(pattern->pattern);
-				if(opt_output[o_positive]->answer)
-			((CELL*)rasters[o_positive].buffer)[col]=rotate(pattern->positives);
-				if(opt_output[o_negative]->answer)
-			((CELL*)rasters[o_negative].buffer)[col]=rotate(pattern->negatives);
-				if(opt_output[o_intensity]->answer)
-			((FCELL*)rasters[o_intensity].buffer)[col]=intensity(pattern->elevation,pattern_size);
-				if(opt_output[o_exposition]->answer)
-			((FCELL*)rasters[o_exposition].buffer)[col]=exposition(pattern->elevation);
-				if(opt_output[o_range]->answer)
-			((FCELL*)rasters[o_range].buffer)[col]=range(pattern->elevation);
-				if(opt_output[o_variance]->answer)
-			((FCELL*)rasters[o_variance].buffer)[col]=variance(pattern->elevation, pattern_size);
+		if (opt_output[o_ternary]->answer)
+		    ((CELL *) rasters[o_ternary].buffer)[col] =
+			determine_ternary(pattern->pattern);
+		if (opt_output[o_positive]->answer)
+		    ((CELL *) rasters[o_positive].buffer)[col] =
+			rotate(pattern->positives);
+		if (opt_output[o_negative]->answer)
+		    ((CELL *) rasters[o_negative].buffer)[col] =
+			rotate(pattern->negatives);
+		if (opt_output[o_intensity]->answer)
+		    ((FCELL *) rasters[o_intensity].buffer)[col] =
+			intensity(pattern->elevation, pattern_size);
+		if (opt_output[o_exposition]->answer)
+		    ((FCELL *) rasters[o_exposition].buffer)[col] =
+			exposition(pattern->elevation);
+		if (opt_output[o_range]->answer)
+		    ((FCELL *) rasters[o_range].buffer)[col] =
+			range(pattern->elevation);
+		if (opt_output[o_variance]->answer)
+		    ((FCELL *) rasters[o_variance].buffer)[col] =
+			variance(pattern->elevation, pattern_size);
-//			 used only for next four shape functions
-			if(opt_output[o_elongation]->answer ||opt_output[o_azimuth]->answer||
-				opt_output[o_extend]->answer || opt_output[o_width]->answer) {
-				float azimuth,elongation,width;
-				radial2cartesian(pattern);
-				shape(pattern, pattern_size,&azimuth,&elongation,&width);
-					if(opt_output[o_azimuth]->answer)
-				((FCELL*)rasters[o_azimuth].buffer)[col]=azimuth;
-					if(opt_output[o_elongation]->answer)
-				((FCELL*)rasters[o_elongation].buffer)[col]=elongation;
-					if(opt_output[o_width]->answer)
-				((FCELL*)rasters[o_width].buffer)[col]=width;
-				if(opt_output[o_extend]->answer)
-			((FCELL*)rasters[o_extend].buffer)[col]=extends(pattern, pattern_size)/area_of_octagon;
+		//                       used only for next four shape functions
+		if (opt_output[o_elongation]->answer ||
+		    opt_output[o_azimuth]->answer ||
+		    opt_output[o_extend]->answer ||
+		    opt_output[o_width]->answer) {
+		    float azimuth, elongation, width;
-		} /* end for col */
+		    radial2cartesian(pattern);
+		    shape(pattern, pattern_size, &azimuth, &elongation,
+			  &width);
+		    if (opt_output[o_azimuth]->answer)
+			((FCELL *) rasters[o_azimuth].buffer)[col] = azimuth;
+		    if (opt_output[o_elongation]->answer)
+			((FCELL *) rasters[o_elongation].buffer)[col] =
+			    elongation;
+		    if (opt_output[o_width]->answer)
+			((FCELL *) rasters[o_width].buffer)[col] = width;
+		if (opt_output[o_extend]->answer)
+		    ((FCELL *) rasters[o_extend].buffer)[col] =
+			extends(pattern, pattern_size) / area_of_octagon;
-		/* write existing outputs */
-		Rast_put_row(rasters[i].fd, rasters[i].buffer, rasters[i].out_data_type);
+	    }			/* end for col */
+	    /* write existing outputs */
+		    Rast_put_row(rasters[i].fd, rasters[i].buffer,
-	G_percent(row, nrows, 2); /* end main loop */
+	G_percent(row, nrows, 2);	/* end main loop */
 	/* finish and close */
-	free_map(elevation.elev, row_buffer_size+1);
+	free_map(elevation.elev, row_buffer_size + 1);
 		G_free(rasters[i].buffer);
 		Rast_close(rasters[i].fd);
 		Rast_short_history(opt_output[i]->answer, "raster", &history);
 		Rast_command_history(&history);
 		Rast_write_history(opt_output[i]->answer, &history);
-	write_form_cat_colors(opt_output[o_forms]->answer,ccolors);
-	write_contrast_colors(opt_output[o_intensity]->answer);
-	write_contrast_colors(opt_output[o_exposition]->answer);
-	write_contrast_colors(opt_output[o_range]->answer);
+	    write_form_cat_colors(opt_output[o_forms]->answer, ccolors);
+	    write_contrast_colors(opt_output[o_intensity]->answer);
+	    write_contrast_colors(opt_output[o_exposition]->answer);
+	    write_contrast_colors(opt_output[o_range]->answer);
-G_message("Done!");
-exit(EXIT_SUCCESS);
-} /* end of multiresolution */
+	G_message("Done!");
+	exit(EXIT_SUCCESS);
+    }				/* end of multiresolution */
-if(multires)
-	PATTERN* multi_patterns;
-	MULTI multiple_output[5]; /* ten form maps + all forms */
-	char* postfixes[]= {"scale_300","scale_100","scale_50","scale_20""scale_10"}; /* in pixels */
-	num_of_steps=5;
-multi_patterns=G_malloc(num_of_steps*sizeof(PATTERN));
+    if (multires) {
+	PATTERN *multi_patterns;
+	MULTI multiple_output[5];	/* ten form maps + all forms */
+	char *postfixes[] = { "scale_300", "scale_100", "scale_50", "scale_20" "scale_10" };	/* in pixels */
+	num_of_steps = 5;
+	multi_patterns = G_malloc(num_of_steps * sizeof(PATTERN));
-	for(i=0;i<5;++i) {
-		multiple_output[i].forms_buffer=Rast_allocate_buf(CELL_TYPE);
-		strcpy(multiple_output[i].name,prefix);
-		strcat(multiple_output[11].name,postfixes[i]);
-		multiple_output[i].fd=Rast_open_new(multiple_output[i].name,CELL_TYPE);
+	for (i = 0; i < 5; ++i) {
+	    multiple_output[i].forms_buffer = Rast_allocate_buf(CELL_TYPE);
+	    strcpy(multiple_output[i].name, prefix);
+	    strcat(multiple_output[11].name, postfixes[i]);
+	    multiple_output[i].fd =
+		Rast_open_new(multiple_output[i].name, CELL_TYPE);
 	/* main loop */
+		((row >=
+								    row -
+								    1) :
+		 row_radius_size);
 		shift_buffers(row);
-						for(i=0;i<num_of_steps;++i)
-					Rast_set_c_null_value(&multiple_output[i].forms_buffer[col],1);
-					continue;
-			cell_step=10;
-			calc_pattern(&multi_patterns[0], row, cur_row, col);
+		    for (i = 0; i < num_of_steps; ++i)
+			Rast_set_c_null_value(&multiple_output[i].
+					      forms_buffer[col], 1);
+		    continue;
+		cell_step = 10;
+		calc_pattern(&multi_patterns[0], row, cur_row, col);
-	Rast_put_row(multiple_output[i].fd, multiple_output[i].forms_buffer, CELL_TYPE);
+		Rast_put_row(multiple_output[i].fd,
+			     multiple_output[i].forms_buffer, CELL_TYPE);
-	for(i=0;i<num_of_steps;++i) {
-		G_free(multiple_output[i].forms_buffer);
-		Rast_close(multiple_output[i].fd);
-		Rast_short_history(multiple_output[i].name, "raster", &history);
-		Rast_command_history(&history);
-		Rast_write_history(multiple_output[i].name, &history);
+	for (i = 0; i < num_of_steps; ++i) {
+	    G_free(multiple_output[i].forms_buffer);
+	    Rast_close(multiple_output[i].fd);
+	    Rast_short_history(multiple_output[i].name, "raster", &history);
+	    Rast_command_history(&history);
+	    Rast_write_history(multiple_output[i].name, &history);
-G_message("Multiresolution Done!");
+	G_message("Multiresolution Done!");
Modified: grass-addons/grass7/raster/r.geomorphon/memory.c
--- grass-addons/grass7/raster/r.geomorphon/memory.c	2013-02-27 05:22:05 UTC (rev 55233)
+++ grass-addons/grass7/raster/r.geomorphon/memory.c	2013-02-27 05:27:59 UTC (rev 55234)
@@ -1,126 +1,136 @@
-int open_map(MAPS* rast) {
-	int row, col;
-	int fd;
-	char* mapset;
-	struct Cell_head cellhd;
-	int bufsize;
-	void* tmp_buf;
-    mapset = (char*)G_find_raster2(rast->elevname, "");
-	    if (mapset == NULL)
-		G_fatal_error(_("Raster map <%s> not found"), rast->elevname);
-		rast->fd = Rast_open_old(rast->elevname, mapset);
-		Rast_get_cellhd(rast->elevname, mapset, &cellhd);
-		rast->raster_type = Rast_map_type(rast->elevname, mapset);
+    int row, col;
+    int fd;
+    char *mapset;
+    struct Cell_head cellhd;
+    int bufsize;
+    void *tmp_buf;
+    mapset = (char *)G_find_raster2(rast->elevname, "");
+    if (mapset == NULL)
+	G_fatal_error(_("Raster map <%s> not found"), rast->elevname);
+    rast->fd = Rast_open_old(rast->elevname, mapset);
+    Rast_get_cellhd(rast->elevname, mapset, &cellhd);
+    rast->raster_type = Rast_map_type(rast->elevname, mapset);
     if (window.ew_res < cellhd.ew_res || window.ns_res < cellhd.ns_res)
 	G_warning(_("Region resolution shoudn't be lesser than map %s resolution. Run g.region rast=%s to set proper resolution"),
-		      rast->elevname, rast->elevname);
+		  rast->elevname, rast->elevname);
-		tmp_buf=Rast_allocate_buf(rast->raster_type);
-		rast->elev = (FCELL**) G_malloc((row_buffer_size+1) * sizeof(FCELL*));
-	for (row = 0; row < row_buffer_size+1; ++row) {
-		rast->elev[row] = Rast_allocate_buf(FCELL_TYPE);
-		Rast_get_row(rast->fd, tmp_buf,row, rast->raster_type);
-			get_cell(col, rast->elev[row], tmp_buf, rast->raster_type);
-  } /* end elev */
+    tmp_buf = Rast_allocate_buf(rast->raster_type);
+    rast->elev = (FCELL **) G_malloc((row_buffer_size + 1) * sizeof(FCELL *));
-G_free(tmp_buf);
-return 0;
+    for (row = 0; row < row_buffer_size + 1; ++row) {
+	rast->elev[row] = Rast_allocate_buf(FCELL_TYPE);
+	Rast_get_row(rast->fd, tmp_buf, row, rast->raster_type);
+	    get_cell(col, rast->elev[row], tmp_buf, rast->raster_type);
+    }				/* end elev */
+    G_free(tmp_buf);
+    return 0;
-int get_cell(int col, float* buf_row, void* buf, RASTER_MAP_TYPE raster_type) {
-	switch (raster_type) {
+    switch (raster_type) {
-			case CELL_TYPE:
-					if (Rast_is_null_value(&((CELL *) buf)[col],CELL_TYPE))
-				Rast_set_f_null_value(&buf_row[col],1);
-					else
-				buf_row[col] =  (FCELL) ((CELL *) buf)[col];
-				break;
+    case CELL_TYPE:
+	if (Rast_is_null_value(&((CELL *) buf)[col], CELL_TYPE))
+	    Rast_set_f_null_value(&buf_row[col], 1);
+	else
+	    buf_row[col] = (FCELL) ((CELL *) buf)[col];
+	break;
-			case FCELL_TYPE:
-					if (Rast_is_null_value(&((FCELL *) buf)[col],FCELL_TYPE))
-					else
-				buf_row[col] =  (FCELL) ((FCELL *) buf)[col];
-				break;
-			case DCELL_TYPE:
-					if (Rast_is_null_value(&((DCELL *) buf)[col],DCELL_TYPE))
-					else
-				buf_row[col] =  (FCELL) ((DCELL *) buf)[col];
-				break;
+    case FCELL_TYPE:
+	if (Rast_is_null_value(&((FCELL *) buf)[col], FCELL_TYPE))
+	else
+	    buf_row[col] = (FCELL) ((FCELL *) buf)[col];
+	break;
-return 0;
+    case DCELL_TYPE:
+	if (Rast_is_null_value(&((DCELL *) buf)[col], DCELL_TYPE))
+	else
+	    buf_row[col] = (FCELL) ((DCELL *) buf)[col];
+	break;
+    return 0;
-int i;
-int col;
-void* tmp_buf;
-FCELL* tmp_elev_buf, *slope_tmp, *aspect_tmp;
+    int i;
+    int col;
+    void *tmp_buf;
+    FCELL *tmp_elev_buf, *slope_tmp, *aspect_tmp;
-tmp_buf=Rast_allocate_buf(elevation.raster_type);
-tmp_elev_buf=elevation.elev[0];
-	for (i = 1; i < row_buffer_size+1; ++i)
-elevation.elev[i - 1] = elevation.elev[i];
+    tmp_buf = Rast_allocate_buf(elevation.raster_type);
+    tmp_elev_buf = elevation.elev[0];
-elevation.elev[row_buffer_size]=tmp_elev_buf;
-Rast_get_row(elevation.fd, tmp_buf,row+row_radius_size+1, elevation.raster_type);
+    for (i = 1; i < row_buffer_size + 1; ++i)
+	elevation.elev[i - 1] = elevation.elev[i];
-get_cell(col, elevation.elev[row_buffer_size], tmp_buf, elevation.raster_type);
+    elevation.elev[row_buffer_size] = tmp_elev_buf;
+    Rast_get_row(elevation.fd, tmp_buf, row + row_radius_size + 1,
+		 elevation.raster_type);
-G_free(tmp_buf);
-return 0;
+	get_cell(col, elevation.elev[row_buffer_size], tmp_buf,
+    G_free(tmp_buf);
+    return 0;
-int free_map (FCELL **map, int n) {
-	int i;
-		for (i=0;i<n;++i)
+    int i;
+    for (i = 0; i < n; ++i)
 	G_free(map[i]);
-	G_free(map);
-	return 0;
+    G_free(map);
+    return 0;
-int write_form_cat_colors (char* raster, CATCOLORS* ccolors) {
-struct Colors colors;
-struct Categories cats;
-int i;
-Rast_init_colors(&colors);
+    struct Colors colors;
+    struct Categories cats;
+    int i;
-	for(i=1;i<CNT;++i)
-Rast_add_color_rule(
-	&ccolors[i].cat, ccolors[i].r, ccolors[i].g, ccolors[i].b,
-	&colors, CELL_TYPE);
-Rast_write_colors(raster, G_mapset(), &colors);
-Rast_free_colors(&colors);
-Rast_init_cats("Forms", &cats);
-Rast_set_cat(&ccolors[i].cat, &ccolors[i].cat, ccolors[i].label, &cats, CELL_TYPE);
-Rast_write_cats(raster, &cats);
-Rast_free_cats(&cats);
-return 0;
+    Rast_init_colors(&colors);
+    for (i = 1; i < CNT; ++i)
+	Rast_add_color_rule(&ccolors[i].cat, ccolors[i].r, ccolors[i].g,
+			    ccolors[i].b, &ccolors[i].cat, ccolors[i].r,
+			    ccolors[i].g, ccolors[i].b, &colors, CELL_TYPE);
+    Rast_write_colors(raster, G_mapset(), &colors);
+    Rast_free_colors(&colors);
+    Rast_init_cats("Forms", &cats);
+	Rast_set_cat(&ccolors[i].cat, &ccolors[i].cat, ccolors[i].label,
+		     &cats, CELL_TYPE);
+    Rast_write_cats(raster, &cats);
+    Rast_free_cats(&cats);
+    return 0;
-int write_contrast_colors (char* raster) {
-FCOLORS  fcolors[9]={ /* colors for positive openness */
+int write_contrast_colors(char *raster)
+    FCOLORS fcolors[9] = {	/* colors for positive openness */
 	{-2500, 0, 0, 50, NULL},
 	{-100, 0, 0, 56, NULL},
 	{-15, 0, 56, 128, NULL},
@@ -129,24 +139,25 @@
 	{3, 255, 128, 0, NULL},
 	{15, 128, 56, 0, NULL},
 	{100, 56, 0, 0, NULL},
-	{2500, 50, 0, 0, NULL}};
-int i;
+	{2500, 50, 0, 0, NULL}
+    int i;
-	for(i=0;i<8;++i)
-Rast_add_d_color_rule(
-	&fcolors[i].cat, fcolors[i].r, fcolors[i].g, fcolors[i].b,
-	&fcolors[i+1].cat, fcolors[i+1].r, fcolors[i+1].g, fcolors[i+1].b,
-	&colors);
-	for(i=0;i<8;++i)
-return 0;
+	Rast_add_d_color_rule(&fcolors[i].cat, fcolors[i].r, fcolors[i].g,
+			      fcolors[i].b, &fcolors[i + 1].cat,
+			      fcolors[i + 1].r, fcolors[i + 1].g,
+			      fcolors[i + 1].b, &colors);
+       for(i=0;i<8;++i)
+       Rast_set_cat(&ccolors[i].cat, &ccolors[i].cat, ccolors[i].label, &cats, CELL_TYPE);
+    return 0;
Modified: grass-addons/grass7/raster/r.geomorphon/multires.c
--- grass-addons/grass7/raster/r.geomorphon/multires.c	2013-02-27 05:22:05 UTC (rev 55233)
+++ grass-addons/grass7/raster/r.geomorphon/multires.c	2013-02-27 05:27:59 UTC (rev 55234)
@@ -3,23 +3,23 @@
-int pattern_matching(int* pattern)
+int pattern_matching(int *pattern)
-int n, i;
-unsigned char source=32;
-int sign=-1;
+    int n, i;
+    unsigned char source = 32;
+    int sign = -1;
-	/* rotate */
-	test= binary;
-		else
-return (result & source == source)? 1:0;
+    /* rotate */
+	    test = binary;
+	else
+    return (result & source == source) ? 1 : 0;
Modified: grass-addons/grass7/raster/r.geomorphon/pattern.c
--- grass-addons/grass7/raster/r.geomorphon/pattern.c	2013-02-27 05:22:05 UTC (rev 55233)
+++ grass-addons/grass7/raster/r.geomorphon/pattern.c	2013-02-27 05:27:59 UTC (rev 55234)
@@ -3,121 +3,142 @@
  * 3|2|1
  * 4|0|8
  * 5|6|7 */
-static int nextr[8] = {-1, -1, -1, 0, 1, 1, 1, 0 };
-static int nextc[8] = {1, 0, -1, -1, -1, 0, 1, 1 };
+static int nextr[8] = { -1, -1, -1, 0, 1, 1, 1, 0 };
+static int nextc[8] = { 1, 0, -1, -1, -1, 0, 1, 1 };
-/* calculate parameters of geomorphons and store it in the struct pattern */
-int i,j,pattern_size=0;
-double zenith_angle, nadir_angle, angle;
-double nadir_threshold, zenith_threshold;
-double zenith_height, nadir_height, zenith_distance, nadir_distance;
-double cur_northing, cur_easting, target_northing, target_easting;
-double cur_distance;
-double center_height, height;
+    /* calculate parameters of geomorphons and store it in the struct pattern */
+    int i, j, pattern_size = 0;
+    double zenith_angle, nadir_angle, angle;
+    double nadir_threshold, zenith_threshold;
+    double zenith_height, nadir_height, zenith_distance, nadir_distance;
+    double cur_northing, cur_easting, target_northing, target_easting;
+    double cur_distance;
+    double center_height, height;
-/* use distance calculation */
-cur_northing=Rast_row_to_northing(row+0.5, &window);
-cur_easting=Rast_col_to_easting(col+0.5, &window);
-center_height=elevation.elev[cur_row][col];
-pattern->num_positives=0;
-pattern->num_negatives=0;
-pattern->positives=0;
-pattern->negatives=0;
+    /* use distance calculation */
+    cur_northing = Rast_row_to_northing(row + 0.5, &window);
+    cur_easting = Rast_col_to_easting(col + 0.5, &window);
+    center_height = elevation.elev[cur_row][col];
+    pattern->num_positives = 0;
+    pattern->num_negatives = 0;
+    pattern->positives = 0;
+    pattern->negatives = 0;
-for(i=0;i<8;++i) {
-/* reset patterns */
-	pattern->pattern[i]=0;
-	pattern->elevation[i]=0.;
-	pattern->distance[i]=0.;
-	j=skip_cells+1;
-	zenith_angle=-(PI2);
-	nadir_angle=PI2;
+	/* reset patterns */
+	pattern->pattern[i] = 0;
+	pattern->elevation[i] = 0.;
+	pattern->distance[i] = 0.;
+	j = skip_cells + 1;
+	zenith_angle = -(PI2);
+	nadir_angle = PI2;
-		if(cur_row+j*nextr[i]<0 || cur_row+j*nextr[i]>row_buffer_size-1 ||
-			col+j*nextc[i]<0 || col+j*nextc[i] > ncols-1)
-	continue; /* border: current cell is on the end of DEM */
-		if(Rast_is_f_null_value(&elevation.elev[cur_row+nextr[i]][col+nextc[i]]))
-	continue; /* border: next value is null, line-of-sight does not exists */
-	pattern_size++; /* line-of-sight exists, continue calculate visibility*/
+	if (cur_row + j * nextr[i] < 0 ||
+	    cur_row + j * nextr[i] > row_buffer_size - 1 ||
+	    col + j * nextc[i] < 0 || col + j * nextc[i] > ncols - 1)
+	    continue;		/* border: current cell is on the end of DEM */
+	if (Rast_is_f_null_value
+	    (&elevation.elev[cur_row + nextr[i]][col + nextc[i]]))
+	    continue;		/* border: next value is null, line-of-sight does not exists */
+	pattern_size++;		/* line-of-sight exists, continue calculate visibility */
-	target_northing=Rast_row_to_northing(row+j*nextr[i]+0.5, &window);
-	target_easting=Rast_col_to_easting(col+j*nextc[i]+0.5, &window);
-	cur_distance=G_distance(cur_easting, cur_northing, target_easting,target_northing);
+	target_northing =
+	    Rast_row_to_northing(row + j * nextr[i] + 0.5, &window);
+	target_easting =
+	    Rast_col_to_easting(col + j * nextc[i] + 0.5, &window);
+	cur_distance =
+	    G_distance(cur_easting, cur_northing, target_easting,
+		       target_northing);
-	while (cur_distance<search_distance) {
-		break; /* reached end of DEM (cols) or buffer (rows) */
+	while (cur_distance < search_distance) {
+		break;		/* reached end of DEM (cols) or buffer (rows) */
-		height=elevation.elev[cur_row+j*nextr[i]][col+j*nextc[i]]-center_height;
-		angle=atan2(height,cur_distance);
+	    height =
+		elevation.elev[cur_row + j * nextr[i]][col + j * nextc[i]] -
+		center_height;
+	    angle = atan2(height, cur_distance);
-		if(angle>zenith_angle) {
-			zenith_angle=angle;
-			zenith_height=height;
-			zenith_distance=cur_distance;
-		if(angle<nadir_angle) {
-			nadir_angle=angle;
-			nadir_height=height;
-			nadir_distance=cur_distance;
-			j+=cell_step;
-//		j++; /* go to next cell */
-	} /* end line of sight */
+	    if (angle > zenith_angle) {
+		zenith_angle = angle;
+		zenith_height = height;
+		zenith_distance = cur_distance;
+	    if (angle < nadir_angle) {
+		nadir_angle = angle;
+		nadir_height = height;
+		nadir_distance = cur_distance;
+	    j += cell_step;
+	    //              j++; /* go to next cell */
+	    target_northing =
+	    target_easting =
+	    cur_distance =
+			   target_northing);
+	}			/* end line of sight */
-/* original paper version */
-/*	zenith_angle=PI2-zenith_angle;
-  nadir_angle=PI2+nadir_angle;
-	if(fabs(zenith_angle-nadir_angle) > flat_treshold) {
-		if((nadir_angle-zenith_angle) > 0) {
-			patterns->pattern[i]=1;
-			patterns->elevation[i]=nadir_height;
-			patterns->distance[i]=nadir_distance;
-			patterns->num_positives++;
-		} else {
-			patterns->pattern[i]=-1;
-			patterns->elevation[i]=zenith_height;
-			patterns->distance[i]=zenith_distance;
-			patterns->num_negatives++;
-	} else {
-		patterns->distance[i]=search_distance;
-	/* this is used to lower flat threshold if distance exceed flat_distance parameter*/
-	zenith_threshold=(flat_distance>0&&flat_distance<zenith_distance)?
-		atan2(flat_threshold_height,zenith_distance):flat_threshold;
-	nadir_threshold=(flat_distance>0&&flat_distance<nadir_distance)?
-		atan2(flat_threshold_height,nadir_distance):flat_threshold;
+	/* original paper version */
+	/*      zenith_angle=PI2-zenith_angle;
+	   nadir_angle=PI2+nadir_angle;
+	   if(fabs(zenith_angle-nadir_angle) > flat_treshold) {
+	   if((nadir_angle-zenith_angle) > 0) {
+	   patterns->pattern[i]=1;
+	   patterns->elevation[i]=nadir_height;
+	   patterns->distance[i]=nadir_distance;
+	   patterns->num_positives++;
+	   } else {
+	   patterns->pattern[i]=-1;
+	   patterns->elevation[i]=zenith_height;
+	   patterns->distance[i]=zenith_distance;
+	   patterns->num_negatives++;
+	   } else {
+	   patterns->distance[i]=search_distance;
+	/* this is used to lower flat threshold if distance exceed flat_distance parameter */
+	zenith_threshold = (flat_distance > 0 &&
+			    flat_distance <
+			    zenith_distance) ? atan2(flat_threshold_height,
+						     zenith_distance) :
+	    flat_threshold;
+	nadir_threshold = (flat_distance > 0 &&
+			   flat_distance <
+			   nadir_distance) ? atan2(flat_threshold_height,
+						   nadir_distance) :
+	    flat_threshold;
-		if(zenith_angle>zenith_threshold)
-	pattern->positives+=i;
-		if(nadir_angle<-nadir_threshold)
-	pattern->negatives+=i;
+	if (zenith_angle > zenith_threshold)
+	    pattern->positives += i;
+	if (nadir_angle < -nadir_threshold)
+	    pattern->negatives += i;
-	if(fabs(zenith_angle)>zenith_threshold||fabs(nadir_angle)>nadir_threshold) {
-		if(fabs(nadir_angle)<fabs(zenith_angle)) {
-			pattern->pattern[i]=1;
-			pattern->elevation[i]=zenith_height; //ZMIANA!
-			pattern->distance[i]=zenith_distance;
-			pattern->num_positives++;
-		if(fabs(nadir_angle)>fabs(zenith_angle)) {
-			pattern->pattern[i]=-1;
-			pattern->elevation[i]=nadir_height; //ZMIANA!
-			pattern->distance[i]=nadir_distance;
-			pattern->num_negatives++;
-	} else {
-		pattern->distance[i]=search_distance;
+	if (fabs(zenith_angle) > zenith_threshold ||
+	    fabs(nadir_angle) > nadir_threshold) {
+	    if (fabs(nadir_angle) < fabs(zenith_angle)) {
+		pattern->pattern[i] = 1;
+		pattern->elevation[i] = zenith_height;	//ZMIANA!
+		pattern->distance[i] = zenith_distance;
+		pattern->num_positives++;
+	    if (fabs(nadir_angle) > fabs(zenith_angle)) {
+		pattern->pattern[i] = -1;
+		pattern->elevation[i] = nadir_height;	//ZMIANA!
+		pattern->distance[i] = nadir_distance;
+		pattern->num_negatives++;
+	else {
+	    pattern->distance[i] = search_distance;
-} /* end for */
-return pattern_size;
+    }				/* end for */
+    return pattern_size;
