[GRASS-SVN] r55235 - grass-addons/grass7/raster/r.geomorphon
Tue Feb 26 21:30:57 PST 2013
Author: hamish
Date: 2013-02-26 21:30:57 -0800 (Tue, 26 Feb 2013)
New Revision: 55235
   grass-addons/grass7/raster/r.geomorphon/local_proto.h
+ missing fn def
Modified: grass-addons/grass7/raster/r.geomorphon/local_proto.h
--- grass-addons/grass7/raster/r.geomorphon/local_proto.h	2013-02-27 05:27:59 UTC (rev 55234)
+++ grass-addons/grass7/raster/r.geomorphon/local_proto.h	2013-02-27 05:30:57 UTC (rev 55235)
@@ -146,8 +146,9 @@
 int get_cell(int col, float *buf_row, void *buf, RASTER_MAP_TYPE raster_type);
 int free_map(FCELL ** map, int n);
 int write_form_cat_colors(char *raster, CATCOLORS * ccolors);
+int write_contrast_colors(char *);
-/*geom */
+/* geom */
 int calc_pattern(PATTERN * pattern, int row, int cur_row, int col);
 unsigned int ternary_rotate(unsigned int value);
 int determine_form(int num_plus, int num_minus);
@@ -161,6 +162,7 @@
 int shape(PATTERN * pattern, int pattern_size, float *azimuth,
 	  float *elongation, float *width);
 float extends(PATTERN * pattern, int pattern_size);
+int radial2cartesian(PATTERN *);
 /* multires */
 int reset_multi_patterns(void);
