[GRASS-SVN] r56399 - grass/trunk/lib/vector/Vlib
Fri May 24 05:56:51 PDT 2013
Author: martinl
Date: 2013-05-24 05:56:51 -0700 (Fri, 24 May 2013)
New Revision: 56399
   grass/trunk/lib/vector/Vlib/write_pg.c
vlib/pg: faces are exported as 3D polygons (simple features)
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c	2013-05-24 12:05:12 UTC (rev 56398)
+++ grass/trunk/lib/vector/Vlib/write_pg.c	2013-05-24 12:56:51 UTC (rev 56399)
@@ -648,6 +648,9 @@
     case (SF_POLYGON):
         geom_type = "POLYGON";
         break;
+    case (SF_POLYGON25D):
+        geom_type = "POLYGONZ";
+        break;
     default:
         G_warning(_("Unsupported feature type %d"), pg_info->feature_type);
         Vect__execute_pg(pg_info->conn, "ROLLBACK");
@@ -906,6 +909,9 @@
     case GV_BOUNDARY:
         pg_info->feature_type = SF_POLYGON;
         break;
+    case GV_FACE:
+        pg_info->feature_type = SF_POLYGON25D;
+        break;
     default:
         G_warning(_("Unsupported geometry type (%d)"), type);
         return -1;
@@ -1552,7 +1558,7 @@
         wkb_data = point_to_wkb(byte_order, points[0], with_z, &nbytes);
     else if (type == GV_LINE)
         wkb_data = linestring_to_wkb(byte_order, points[0], with_z, &nbytes);
-    else if (type == GV_BOUNDARY) {
+    else if (type & (GV_BOUNDARY | GV_FACE)) {
         if (!pg_info->toposchema_name) {
             /* PostGIS simple feature access */
             wkb_data = polygon_to_wkb(byte_order, points, nparts,
