[GRASS-SVN] r56400 - in grass/trunk/raster: r.basins.fill r.water.outlet r.watershed/front
Fri May 24 12:28:08 PDT 2013
Author: neteler
Date: 2013-05-24 12:28:08 -0700 (Fri, 24 May 2013)
New Revision: 56400
   grass/trunk/raster/r.basins.fill/main.c
   grass/trunk/raster/r.basins.fill/r.basins.fill.html
   grass/trunk/raster/r.water.outlet/main.c
   grass/trunk/raster/r.water.outlet/r.water.outlet.html
   grass/trunk/raster/r.watershed/front/main.c
watershed keyword (for index); cross-references added
Modified: grass/trunk/raster/r.basins.fill/main.c
--- grass/trunk/raster/r.basins.fill/main.c	2013-05-24 12:56:51 UTC (rev 56399)
+++ grass/trunk/raster/r.basins.fill/main.c	2013-05-24 19:28:08 UTC (rev 56400)
@@ -53,6 +53,7 @@
     module = G_define_module();
     G_add_keyword(_("raster"));
     G_add_keyword(_("hydrology"));
+    G_add_keyword(_("watershed"));
     module->description =
 	_("Generates watershed subbasins raster map.");
Modified: grass/trunk/raster/r.basins.fill/r.basins.fill.html
--- grass/trunk/raster/r.basins.fill/r.basins.fill.html	2013-05-24 12:56:51 UTC (rev 56399)
+++ grass/trunk/raster/r.basins.fill/r.basins.fill.html	2013-05-24 19:28:08 UTC (rev 56400)
@@ -36,9 +36,11 @@
 See Appendix A of the <b>GRASS</b> <a
 href="http://grass.osgeo.org/gdp/raster/r.watershed.ps">Tutorial:
 r.watershed</a> for further details on the combined use of
-<em>r.basins.fill</em> and <em><a href="r.watershed.html">r.watershed</a></em>.
+<em>r.basins.fill</em> and <em>r.watershed</em>.
+<p>
 <em>
+  <a href="r.water.outlet.html">r.water.outlet</a>,
   <a href="r.watershed.html">r.watershed</a>,
   <a href="wxGUI.Vector_Digitizer.html">wxGUI vector digitizer</a>
 </em>
Modified: grass/trunk/raster/r.water.outlet/main.c
--- grass/trunk/raster/r.water.outlet/main.c	2013-05-24 12:56:51 UTC (rev 56399)
+++ grass/trunk/raster/r.water.outlet/main.c	2013-05-24 19:28:08 UTC (rev 56400)
@@ -64,6 +64,7 @@
     module->description = _("Creates watershed basins.");
     opt1 = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/raster/r.water.outlet/r.water.outlet.html
--- grass/trunk/raster/r.water.outlet/r.water.outlet.html	2013-05-24 12:56:51 UTC (rev 56399)
+++ grass/trunk/raster/r.water.outlet/r.water.outlet.html	2013-05-24 19:28:08 UTC (rev 56400)
@@ -72,6 +72,7 @@
 <em>
 <a href="d.where.html">d.where</a>,
+<a href="r.basins.fill.html">r.basins.fill</a>,
 <a href="r.topidx.html">r.topidx</a>
 </em>
Modified: grass/trunk/raster/r.watershed/front/main.c
--- grass/trunk/raster/r.watershed/front/main.c	2013-05-24 12:56:51 UTC (rev 56399)
+++ grass/trunk/raster/r.watershed/front/main.c	2013-05-24 19:28:08 UTC (rev 56400)
@@ -71,6 +71,7 @@
     module->description = _("Calculates hydrological parameters and RUSLE factors.");
     opt1 = G_define_standard_option(G_OPT_R_ELEV);
