[GRASS-SVN] r58126 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Wed Oct 30 14:41:04 PDT 2013
Author: neteler
Date: 2013-10-30 14:41:04 -0700 (Wed, 30 Oct 2013)
New Revision: 58126
grass/branches/develbranch_6/locale/po/grasslibs_fr.po
grass/branches/develbranch_6/locale/po/grassmods_fr.po
grass/branches/develbranch_6/locale/po/grasswxpy_fr.po
Sylvain Maillard: FR translation cont'ed
Modified: grass/branches/develbranch_6/locale/po/grasslibs_fr.po
--- grass/branches/develbranch_6/locale/po/grasslibs_fr.po 2013-10-30 21:32:06 UTC (rev 58125)
+++ grass/branches/develbranch_6/locale/po/grasslibs_fr.po 2013-10-30 21:41:04 UTC (rev 58126)
@@ -12,7 +12,7 @@
"Project-Id-Version: grasslibs_fr\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2013-10-30 22:18+0100\n"
-"PO-Revision-Date: 2013-08-12 08:33+0100\n"
+"PO-Revision-Date: 2013-10-27 19:18+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: French <grass-translations at lists.osgeo.org>\n"
"Language: fr\n"
@@ -31,7 +31,7 @@
#: ../lib/nviz/position.c:56
msgid "Unable to set focus"
-msgstr ""
+msgstr "Impossible de définir le focus"
#: ../lib/nviz/map_obj.c:59
msgid "Maximum surfaces loaded!"
@@ -79,11 +79,8 @@
#: ../lib/symbol/read.c:259
#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Nom du symbole incorrect: '%s' (devrait être group/nom ou groupe/"
-"nom at jeudedonnées)"
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "Nom du symbole incorrect: '%s' (devrait être group/nom ou groupe/nom at jeudedonnées)"
#: ../lib/symbol/read.c:283
#, c-format
@@ -118,12 +115,8 @@
msgstr "Erreur de mémoire dans l'attribution d'horodatage"
#: ../lib/sites/sites.c:348 ../lib/sites/sites.c:478
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
-msgstr ""
-"Note du dev : librairie sites adaptée utilisée pour le vecteur de points. "
-"(le module devrait être mis à jour vers la librairie vecteur GRASS 6)"
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+msgstr "Note du dev : librairie sites adaptée utilisée pour le vecteur de points. (le module devrait être mis à jour vers la librairie vecteur GRASS 6)"
#: ../lib/sites/sites.c:372 ../lib/vector/neta/utils.c:116
#: ../lib/vector/neta/timetables.c:133 ../lib/vector/Vlib/map.c:272
@@ -164,14 +157,12 @@
msgstr "Nombre maximal d'étiquettes atteint !"
#: ../lib/ogsf/gk.c:322
-#, fuzzy
msgid "Need at least 3 keyframes for spline"
-msgstr "Besoin d'un minimum de 3 keyframe pour une spline"
+msgstr "Besoin d'un minimum de 3 images-clef pour une spline"
#: ../lib/ogsf/gk.c:624
-#, fuzzy
msgid "Need at least 2 keyframes for interpolation"
-msgstr "Besoin de au moins 2 keyframes pour l'interpolation"
+msgstr "Besoin de au moins 2 images-clef pour l'interpolation"
#: ../lib/ogsf/GS2.c:1207
#, c-format
@@ -186,8 +177,7 @@
#: ../lib/ogsf/GS2.c:1651
#, c-format
msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
-"La carte raster <%s> est en dehors de la région courante. Chargement échoué."
+msgstr "La carte raster <%s> est en dehors de la région courante. Chargement échoué."
#: ../lib/ogsf/GS2.c:1729 ../lib/ogsf/GS2.c:1735 ../lib/ogsf/GS2.c:1743
#: ../lib/ogsf/GS2.c:1752 ../lib/ogsf/GS2.c:1760 ../lib/ogsf/GS2.c:1770
@@ -201,7 +191,7 @@
#: ../lib/ogsf/GS2.c:1850
msgid "Error finding range"
-msgstr ""
+msgstr "Erreur de détermination de la plage"
#: ../lib/ogsf/Gvl3.c:39 ../lib/ogsf/gvl_file.c:428
#: ../lib/gpde/N_arrays_io.c:296
@@ -211,7 +201,7 @@
#: ../lib/ogsf/gs_bm.c:124
msgid "Bitmap mismatch"
-msgstr ""
+msgstr "Les bitmap diffèrent"
#: ../lib/ogsf/Gv3.c:57 ../lib/ogsf/Gp3.c:109
#: ../lib/vector/Vlib/legal_vname.c:118 ../lib/vector/Vlib/legal_vname.c:121
@@ -228,8 +218,7 @@
#: ../lib/ogsf/Gv3.c:249
#, c-format
msgid "No features from vector map <%s> fall within current region"
-msgstr ""
-"Aucune entité de la carte vecteur <%s> ne tombe dans la région courante"
+msgstr "Aucune entité de la carte vecteur <%s> ne tombe dans la région courante"
#: ../lib/ogsf/Gv3.c:254
#, c-format
@@ -263,18 +252,14 @@
msgstr "Carte vecteur <%s> chargée (%d points)"
#: ../lib/ogsf/gsd_prim.c:146
-#, c-format
+#, fuzzy, c-format
msgid "Color Material: %d"
-msgstr ""
+msgstr "Couleur de matériel : %d"
#: ../lib/ogsf/gsd_prim.c:630
#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot(): %c est une spécification d'axe non valide. Rotation ignorée. "
-"Merci d'avertir les développeurs GRASS de cette erreur"
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot(): %c est une spécification d'axe non valide. Rotation ignorée. Merci d'avertir les développeurs GRASS de cette erreur"
#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/GK2.c:219
#: ../lib/ogsf/gsd_img_ppm.c:53 ../lib/ogsf/gsd_img_ppm.c:96
@@ -319,9 +304,8 @@
msgstr "Allocation mémoire pour l'image temporaire impossible"
#: ../lib/ogsf/gsd_img_mpeg.c:283
-#, fuzzy
msgid "Error while writing video frame"
-msgstr "Erreur lors de l'écriture du fichier vidéo"
+msgstr "Erreur lors de l'écriture de la vidéo"
#: ../lib/ogsf/gsd_img_mpeg.c:329
#, c-format
@@ -330,9 +314,7 @@
#: ../lib/ogsf/gsd_img_mpeg.c:341
msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-"Impossible de déduire le format de sortie de l'extension du fichier: "
-"utilisation de MPEG"
+msgstr "Impossible de déduire le format de sortie de l'extension du fichier: utilisation de MPEG"
#: ../lib/ogsf/gsd_img_mpeg.c:349
msgid "Unable to find suitable output format"
@@ -383,7 +365,7 @@
#: ../lib/ogsf/gsd_legend.c:268
#, c-format
msgid "Unable to read fp range of raster map <%s>"
-msgstr "Impossible de lire la couche vectorielle <%s>"
+msgstr "Impossible de lire la plage fp de la carte raster <%s>"
#: ../lib/ogsf/gsd_legend.c:280
#, c-format
@@ -392,11 +374,12 @@
#: ../lib/ogsf/gsd_legend.c:294
msgid "Range request error for legend"
-msgstr ""
+msgstr "Erreur de récupération de la plage pour la légende"
#: ../lib/ogsf/gsd_legend.c:384
+#, fuzzy
msgid "Unable to show discrete FP range (use list"
-msgstr ""
+msgstr "Impossible d'afficher une plage FP discrète (utilisation d'une liste"
#: ../lib/ogsf/gsd_legend.c:500
msgid "Too many categories to show as discrete!"
@@ -426,9 +409,8 @@
msgstr "Impossible de fermer la carte raster 3D <%s>"
#: ../lib/ogsf/GK2.c:275 ../lib/ogsf/GK2.c:288
-#, fuzzy
msgid "Check no. of frames requested and keyframes marked"
-msgstr "Vérifier le numéro des frames demandées et les keyframes marquées"
+msgstr "Vérifier le numéro des images demandées et les images-clefs marquées"
#: ../lib/ogsf/Gs3.c:133 ../lib/ogsf/Gs3.c:208 ../lib/ogsf/Gs3.c:366
#: ../lib/ogsf/Gs3.c:482 ../lib/ogsf/Gs3.c:587
@@ -450,9 +432,7 @@
#: ../lib/ogsf/Gs3.c:647
#, c-format
msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-"L'étendue de la table de couleur ne correspond pas aux données (mincol=%d, "
-"maxcol=%d"
+msgstr "L'étendue de la table de couleur ne correspond pas aux données (mincol=%d, maxcol=%d"
#: ../lib/ogsf/Gs3.c:709 ../lib/ogsf/Gs3.c:781
#, c-format
@@ -482,11 +462,8 @@
#: ../lib/proj/convert.c:127
#, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR ne peut pas analyser la chaîne de paramètre PROJ.4: %s (Le code erreur "
-"OGR était %d)"
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR ne peut pas analyser la chaîne de paramètre PROJ.4: %s (Le code erreur OGR était %d)"
#: ../lib/proj/convert.c:133
#, c-format
@@ -495,9 +472,7 @@
#: ../lib/proj/convert.c:390
msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
-"Aucun nom de projection ! Projection de paramètres susceptibles d'être vide "
-"de sens."
+msgstr "Aucun nom de projection ! Projection de paramètres susceptibles d'être vide de sens."
#: ../lib/proj/convert.c:426
#, c-format
@@ -506,21 +481,13 @@
#: ../lib/proj/convert.c:442
#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"La date <% s> est apparemment reconnue par GRASS mais aucun paramètre "
-"trouvé. Vous devez examiner."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "La date <% s> est apparemment reconnue par GRASS mais aucun paramètre trouvé. Vous devez examiner."
#: ../lib/proj/convert.c:446
#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-"Numéro de transformation %d invalide ; la plage valide est de 1 à %d. "
-"Paramètres datum de la transformation laissés non spécifiés."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "Numéro de transformation %d invalide ; la plage valide est de 1 à %d. Paramètres datum de la transformation laissés non spécifiés."
#: ../lib/proj/datum.c:250
msgid "Unable to open temporary file"
@@ -593,13 +560,11 @@
#: ../lib/proj/ellipse.c:98
msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr ""
-"Pas de descripteur secondaire (rf, es or b) d'ellipsoïde dans le fichier"
+msgstr "Pas de descripteur secondaire (rf, es or b) d'ellipsoïde dans le fichier"
#: ../lib/proj/ellipse.c:102
msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr ""
-"Descripteurs de l'ellipsoïde (a, rf, es ou b) invalides dans le fichier"
+msgstr "Descripteurs de l'ellipsoïde (a, rf, es ou b) invalides dans le fichier"
#: ../lib/proj/ellipse.c:115
msgid "No ellipsoid info given in file"
@@ -618,8 +583,7 @@
#: ../lib/proj/ellipse.c:269 ../lib/gis/get_ellipse.c:336
#, c-format
msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr ""
-"Les lignes%s du fichier <%s> de la table de l'ellipsoïde sont invalides"
+msgstr "Les lignes%s du fichier <%s> de la table de l'ellipsoïde sont invalides"
#: ../lib/g3d/g3dparam.c:52
msgid "Data type used in the output file"
@@ -627,8 +591,7 @@
#: ../lib/g3d/g3dparam.c:61
msgid "Precision used in the output file (default, max, or 0 to 52)"
-msgstr ""
-"Précision utilisée dans le fichier de sortie (par défaut, max, ou 0 à 52)"
+msgstr "Précision utilisée dans le fichier de sortie (par défaut, max, ou 0 à 52)"
#: ../lib/g3d/g3dparam.c:71
msgid "The compression method used in the output file"
@@ -676,9 +639,7 @@
#: ../lib/g3d/g3dopen.c:124
msgid "G3d_openCellOld: projection does not match window projection"
-msgstr ""
-"G3d_openCellOld: la projection ne correspond pas à la projection de la "
-"fenêtre"
+msgstr "G3d_openCellOld: la projection ne correspond pas à la projection de la fenêtre"
#: ../lib/g3d/g3dopen.c:128
msgid "G3d_openCellOld: zone does not match window zone"
@@ -732,16 +693,12 @@
#: ../lib/init/lock.c:42
msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
-"Le verrouillage concurrent de jeux de cartes n'est pas pris en charge dans "
-"Windows"
+msgstr "Le verrouillage concurrent de jeux de cartes n'est pas pris en charge dans Windows"
#: ../lib/init/lock.c:60
#, c-format
msgid "Unable to write lockfile %s (disk full? Permissions?)"
-msgstr ""
-"Impossible d'écrire le fichier de verrouillage %s (disque plein ? "
-"permissions ?)"
+msgstr "Impossible d'écrire le fichier de verrouillage %s (disque plein ? permissions ?)"
#: ../lib/raster/io_sock.c:63
msgid "No graphics monitor has been selected for output."
@@ -831,26 +788,18 @@
#: ../lib/imagery/sigsetfile.c:41
#, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
-msgstr ""
-"Impossible de créer le fichier de signatures <%s> pour le sous-groupe <%s> "
-"du groupe <%s> - <%s> n'est pas le jeux de cartes courant"
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
+msgstr "Impossible de créer le fichier de signatures <%s> pour le sous-groupe <%s> du groupe <%s> - <%s> n'est pas le jeux de cartes courant"
#: ../lib/imagery/sigsetfile.c:57
#, c-format
msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr ""
-"du groupe <%s>"
+msgstr "Impossible de créer le fichier de signatures <%s> pour le sous-groupe <%s> du groupe <%s>"
#: ../lib/imagery/sigsetfile.c:86
#, c-format
msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier de signatures <%s> pour le sous-groupe <%s>du "
-"groupe <%s@%s>"
+msgstr "Impossible d'ouvrir le fichier de signatures <%s> pour le sous-groupe <%s>du groupe <%s@%s>"
#: ../lib/imagery/fopen.c:23
#, c-format
@@ -870,21 +819,17 @@
#: ../lib/imagery/fopen.c:79
#, c-format
msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossible de créer le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
+msgstr "Impossible de créer le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
#, c-format
msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossible d'ouvrir le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
+msgstr "Impossible d'ouvrir le fichier [%s] du sous-groupe [%s] du groupe [%s de %s]"
#: ../lib/imagery/fopen.c:116
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossible de trouver le fichier [%s] pour le sous-groupe [%s] du groupe [%s "
-"de %s]"
+msgstr "Impossible de trouver le fichier [%s] pour le sous-groupe [%s] du groupe [%s de %s]"
#: ../lib/imagery/list_subgp.c:36
#, c-format
@@ -894,8 +839,7 @@
#: ../lib/imagery/list_subgp.c:48
#, c-format
msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-"Le sous-groupe <%s> du groupe <%s>référence les cartes raster suivantes\n"
+msgstr "Le sous-groupe <%s> du groupe <%s>référence les cartes raster suivantes\n"
#: ../lib/imagery/target.c:38
#, c-format
@@ -905,23 +849,17 @@
#: ../lib/imagery/points.c:124
#, c-format
msgid "Unable to open control point file for group [%s in %s]"
-msgstr ""
-"Impossible d'ouvrir le fichier de points de contrôle pour le groupe [%s dans "
-"%s]"
+msgstr "Impossible d'ouvrir le fichier de points de contrôle pour le groupe [%s dans %s]"
#: ../lib/imagery/points.c:132
#, c-format
msgid "Bad format in control point file for group [%s in %s]"
-msgstr ""
-"Mauvais format dans le fichier de points de contrôle pour le groupe [%s dans "
-"%s]"
+msgstr "Mauvais format dans le fichier de points de contrôle pour le groupe [%s dans %s]"
#: ../lib/imagery/points.c:159
#, c-format
msgid "Unable to create control point file for group [%s in %s]"
-msgstr ""
-"Impossible de créer le fichier de points de contrôle pour le groupe [%s dans "
-"%s]"
+msgstr "Impossible de créer le fichier de points de contrôle pour le groupe [%s dans %s]"
#: ../lib/gmath/la.c:60 ../lib/gmath/la.c:116
msgid "Matrix dimensions out of range"
@@ -1013,8 +951,7 @@
#: ../lib/gmath/la.c:746
msgid "Specified matrix column index is outside range"
-msgstr ""
-"L'index de colonne de la matrice spécifié est en dehors de l'intervalle"
+msgstr "L'index de colonne de la matrice spécifié est en dehors de l'intervalle"
#: ../lib/gmath/la.c:751 ../lib/gmath/la.c:792 ../lib/gmath/la.c:1105
#: ../lib/gmath/la.c:1157 ../lib/gmath/la.c:1232
@@ -1395,9 +1332,7 @@
#: ../lib/driver/parse_ftcap.c:32
#, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s: Impossible de lire le fichier de définition de police, utilisation de "
-"celle par défaut"
+msgstr "%s: Impossible de lire le fichier de définition de police, utilisation de celle par défaut"
#: ../lib/driver/parse_ftcap.c:38
#, c-format
@@ -1419,38 +1354,24 @@
msgstr "Moniteur: get_command: Fermeture de fichier prématurée"
#: ../lib/gpde/N_parse_options.c:59
-msgid ""
-"The type of solver which should solve the symmetric linear equation system"
-msgstr ""
-"Le type de solveur qui devrait résoudre le système d'équations linéaires "
-"symétrique"
+msgid "The type of solver which should solve the symmetric linear equation system"
+msgstr "Le type de solveur qui devrait résoudre le système d'équations linéaires symétrique"
#: ../lib/gpde/N_parse_options.c:71
msgid "The type of solver which should solve the linear equation system"
-msgstr ""
-"Le type de solveur qui devrait permettre de résoudre le système d'équations "
-"linéaires"
+msgstr "Le type de solveur qui devrait permettre de résoudre le système d'équations linéaires"
#: ../lib/gpde/N_parse_options.c:80
msgid "Maximum number of iteration used to solver the linear equation system"
-msgstr ""
-"Nombre maximum d'itérations utilisées pour le solutionneur du système "
-"d'équations linéaires"
+msgstr "Nombre maximum d'itérations utilisées pour le solutionneur du système d'équations linéaires"
#: ../lib/gpde/N_parse_options.c:89
-msgid ""
-"Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
-msgstr ""
-"Erreur de critères pour le solveur par itération (Jacobi, sor, cg ou "
-"bicgstab)"
+msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+msgstr "Erreur de critères pour le solveur par itération (Jacobi, sor, cg ou bicgstab)"
#: ../lib/gpde/N_parse_options.c:98
-msgid ""
-"The relaxation parameter used by the jacobi and sor solver for speedup or "
-"stabilizing"
-msgstr ""
-"Les paramètres utilisés par le solveur pour les méthodes jacobi et sor pour "
-"accélérer ou stabiliser"
+msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
+msgstr "Les paramètres utilisés par le solveur pour les méthodes jacobi et sor pour accélérer ou stabiliser"
#: ../lib/gpde/N_parse_options.c:106
msgid "The calculation time in seconds"
@@ -1790,7 +1711,7 @@
#: ../lib/arraystats/class.c:21
msgid "Discont algorithm currently not available because of bugs"
-msgstr ""
+msgstr "L'algorithme discont n'est actuellement pas disponible à cause d'un bug"
#: ../lib/arraystats/class.c:23
#, c-format
@@ -1804,10 +1725,8 @@
#: ../lib/arraystats/class.c:221
#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgstr "Il y a des ruptures de classes en dehors de la plage min-max. Nombre de classes réduites à %i, mais utilisation des probabilités sur %i classes."
#: ../lib/vector/neta/utils.c:221
#, fuzzy, c-format
@@ -1842,17 +1761,14 @@
msgstr "Calcul des plus courts chemins pour toutes les paires..."
#: ../lib/vector/neta/spanningtree.c:104
+#, fuzzy
msgid "Computing minimum spanning tree..."
-msgstr ""
+msgstr "Calcul de l'arbre couvrant de poids minimal ..."
#: ../lib/vector/diglib/plus_node.c:217
#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-"Tentative de lire l'angle d'une ligne qui n'est pas connectée au noeud: "
-"noeud %d, ligne %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "Tentative de lire l'angle d'une ligne qui n'est pas connectée au noeud: noeud %d, ligne %d"
#: ../lib/vector/diglib/file.c:157
msgid "Writing to file loaded to memory not supported"
@@ -1973,20 +1889,17 @@
#: ../lib/vector/diglib/plus_area.c:394
#, c-format
msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"Centroïde mort %d enregistré pour une surface (bug dans la librairie vecteur)"
+msgstr "Centroïde mort %d enregistré pour une surface (bug dans la librairie vecteur)"
#: ../lib/vector/diglib/plus_area.c:418
#, c-format
msgid "Attempt to delete area %d info from dead isle %d"
-msgstr ""
-"Tentative de suppression des information de la surface %d de l'île morte %d"
+msgstr "Tentative de suppression des information de la surface %d de l'île morte %d"
#: ../lib/vector/diglib/plus_area.c:773
#, c-format
msgid "Attempt to delete isle %d info from dead area %d"
-msgstr ""
-"Tentative de suppression des informations de l'île % de la surface morte %d"
+msgstr "Tentative de suppression des informations de l'île % de la surface morte %d"
#: ../lib/vector/Vlib/write_nat.c:50 ../lib/vector/Vlib/write_nat.c:83
#, c-format
@@ -2004,36 +1917,27 @@
#: ../lib/vector/Vlib/legal_vname.c:48
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Ne doit contenir ni '.', ni 'NULL'."
+msgstr "Nom de couche vectorielle illégale <%s>. Ne doit contenir ni '.', ni 'NULL'."
#: ../lib/vector/Vlib/legal_vname.c:55
#, c-format
msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Doit commencer par une lettre."
+msgstr "Nom de couche vectorielle illégale <%s>. Doit commencer par une lettre."
#: ../lib/vector/Vlib/legal_vname.c:63
#, c-format
msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Le caractère '%c' n'est pas "
-"autorisé."
+msgstr "Nom de couche vectorielle illégale <%s>. Le caractère '%c' n'est pas autorisé."
#: ../lib/vector/Vlib/legal_vname.c:70
#, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"Nom de couche vectorielle illégale <%s>. Les mot-clefs SQL ne peut pas être "
-"utilisés comme nom de carte vectorielle."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "Nom de couche vectorielle illégale <%s>. Les mot-clefs SQL ne peut pas être utilisés comme nom de carte vectorielle."
#: ../lib/vector/Vlib/legal_vname.c:101 ../lib/vector/Vlib/legal_vname.c:105
#, c-format
msgid "Output vector map name <%s> is not valid map name"
-msgstr ""
-"Le nom de sortie de la couche vectorielle <%s> n'est pas un nom de couche "
-"vectorielle valide"
+msgstr "Le nom de sortie de la couche vectorielle <%s> n'est pas un nom de couche vectorielle valide"
#: ../lib/vector/Vlib/legal_vname.c:142 ../lib/vector/Vlib/legal_vname.c:146
#, c-format
@@ -2051,21 +1955,24 @@
msgstr "%d nouveaux contours"
#: ../lib/vector/Vlib/snap.c:148
+#, fuzzy
msgid "Snap vertices Pass 1: select points"
-msgstr ""
+msgstr "Accrochage des sommets passe 1 : sélection des points"
#: ../lib/vector/Vlib/snap.c:202
+#, fuzzy
msgid "Snap vertices Pass 2: assign anchor vertices"
-msgstr ""
+msgstr "Accrochage des sommets passe 2 : assignation des ancrages de sommets"
#: ../lib/vector/Vlib/snap.c:271
+#, fuzzy
msgid "Snap vertices Pass 3: snap to assigned points"
-msgstr ""
+msgstr "Accrochage des sommets pass 3 : accrochage sur les points assignés"
#: ../lib/vector/Vlib/snap.c:451
-#, c-format
+#, fuzzy, c-format
msgid "Snapped vertices: %d"
-msgstr ""
+msgstr "Sommets accrochés : %d"
#: ../lib/vector/Vlib/snap.c:452
#, c-format
@@ -2190,11 +2097,11 @@
#: ../lib/vector/Vlib/overlay.c:123
msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr ""
+msgstr "Supperposer : types ligne/contour non supportés par l'opérateur AND"
#: ../lib/vector/Vlib/overlay.c:126
msgid "Overlay: area x area types not supported by AND operator"
-msgstr ""
+msgstr "Supperposer : type surface x surface non supporté par l'opérateur AND"
#: ../lib/vector/Vlib/level.c:38
msgid "Map structure was never initialized"
@@ -2338,12 +2245,8 @@
#: ../lib/vector/Vlib/geos.c:56
#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line_geos(): l'id d'objet %d n'est pas plausible (nombre maxi "
-"d'objets dans la carte vecteur <%s>: %d)"
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line_geos(): l'id d'objet %d n'est pas plausible (nombre maxi d'objets dans la carte vecteur <%s>: %d)"
#: ../lib/vector/Vlib/geos.c:61
msgid "only native format supported"
@@ -2357,8 +2260,7 @@
#: ../lib/vector/Vlib/geos.c:105
#, c-format
msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-"Vect_read_area_geos(): impossible de lire l'île d'id %d de la surface d'id %d"
+msgstr "Vect_read_area_geos(): impossible de lire l'île d'id %d de la surface d'id %d"
#: ../lib/vector/Vlib/geos.c:203
#, c-format
@@ -2377,12 +2279,8 @@
#: ../lib/vector/Vlib/read.c:102
#, c-format
-msgid ""
-"Vect_read_line(): feature id %d is not reasonable (max features in vector "
-"map <%s>: %d)"
-msgstr ""
-"Vect_read_line(): l'id de l'entité %d n'est pas plausible (nombre maxi "
+msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line(): l'id de l'entité %d n'est pas plausible (nombre maxi d'objets dans la carte vecteur <%s>: %d)"
#: ../lib/vector/Vlib/sindex.c:97
msgid "not implemented"
@@ -2394,12 +2292,8 @@
msgstr "Impossible de supprimer l'élément d'id %d de l'index spatial"
#: ../lib/vector/Vlib/sindex.c:127
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topo level 2"
-msgstr ""
-"Impossible de construire l'index spatial à partir de la topologie, la carte "
-"vecteur n'est pas ouverte au niveau topo 2"
+msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
+msgstr "Impossible de construire l'index spatial à partir de la topologie, la carte vecteur n'est pas ouverte au niveau topo 2"
#: ../lib/vector/Vlib/sindex.c:168
msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
@@ -2433,11 +2327,8 @@
msgstr "La construction partielle pour OGR n'est pas prise en charge"
#: ../lib/vector/Vlib/build_ogr.c:342
-msgid ""
-"Random read is not supported by OGR for this layer, cannot build support"
-msgstr ""
-"Lecture aléatoire non supportée par OGR pour cette couche, impossible de "
-"construire les fichiers support"
+msgid "Random read is not supported by OGR for this layer, cannot build support"
+msgstr "Lecture aléatoire non supportée par OGR pour cette couche, impossible de construire les fichiers support"
#: ../lib/vector/Vlib/build_ogr.c:349
msgid "Feature: "
@@ -2478,8 +2369,7 @@
#: ../lib/vector/Vlib/net.c:367
#, c-format
msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
-"Type de données de la colonne <%s> non pris en charge (doit être numeric)"
+msgstr "Type de données de la colonne <%s> non pris en charge (doit être numeric)"
#: ../lib/vector/Vlib/net.c:227
msgid "Registering arcs..."
@@ -2487,21 +2377,13 @@
#: ../lib/vector/Vlib/net.c:255
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
-msgstr ""
-"L'enregistrement de la base de données de la ligne %d (cat = %d, avant/"
-"toutes directions) introuvable (avant/toutes directions de la ligne sautée)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgstr "L'enregistrement de la base de données de la ligne %d (cat = %d, avant/toutes directions) introuvable (avant/toutes directions de la ligne sautée)"
#: ../lib/vector/Vlib/net.c:274
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not "
-"found(direction of line skipped)"
-msgstr ""
-"L'enregistrement de la base de données de la ligne %d (cat = %d, direction "
-"arrière) introuvable (direction de la ligne sautée)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr "L'enregistrement de la base de données de la ligne %d (cat = %d, direction arrière) introuvable (direction de la ligne sautée)"
#: ../lib/vector/Vlib/net.c:323
msgid "Cannot add network arc"
@@ -2514,9 +2396,7 @@
#: ../lib/vector/Vlib/net.c:403
#, c-format
msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"L'enregistrement de la base de données pour le noeud %d (cat = %d) n'a pas "
-"été trouvé (coût fixé à 0)"
+msgstr "L'enregistrement de la base de données pour le noeud %d (cat = %d) n'a pas été trouvé (coût fixé à 0)"
#: ../lib/vector/Vlib/net.c:430
msgid "Flattening the graph..."
@@ -2548,8 +2428,9 @@
msgstr "Surface de taille = 0.0 ignorée"
#: ../lib/vector/Vlib/build_nat.c:148
+#, fuzzy
msgid "Request to find area outside nonexistent isle"
-msgstr ""
+msgstr "Requête pour trouver des surfaces à l'extérieur d'une île non-existante"
#: ../lib/vector/Vlib/build_nat.c:514
msgid "Registering primitives..."
@@ -2619,40 +2500,23 @@
#: ../lib/vector/Vlib/open_ogr.c:157
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
-"Le format d'index %d.%d n'est pas supporté par cette version. Essayez de "
-"reconstruire la topologie ou de mettre à jour GRASS."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr "Le format d'index %d.%d n'est pas supporté par cette version. Essayez de reconstruire la topologie ou de mettre à jour GRASS."
#: ../lib/vector/Vlib/open_ogr.c:162
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-"Votre version de GRASS ne supporte pas complétement le format d'index %d.%d "
-"pour le vecteur. Reconstruisez la topologie ou faites une mise à jour de "
-"GRASS."
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Votre version de GRASS ne supporte pas complétement le format d'index %d.%d pour le vecteur. Reconstruisez la topologie ou faites une mise à jour de GRASS."
#: ../lib/vector/Vlib/open_nat.c:145
#, c-format
-msgid ""
-"Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
-msgstr ""
-"Le fichier de coordonnées de la carte vecteur <%s@%s> est plus long qu'il ne "
-"devrait être (excès de %ld bytes)"
+msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+msgstr "Le fichier de coordonnées de la carte vecteur <%s@%s> est plus long qu'il ne devrait être (excès de %ld bytes)"
#: ../lib/vector/Vlib/open_nat.c:149
#, c-format
-msgid ""
-"Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-"missing)."
-msgstr ""
-"Le fichier de coordonnées de la carte vecteur <%s@%s> est plus court qu'il "
-"ne devrait être (excès de %ld bytes)"
+msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr "Le fichier de coordonnées de la carte vecteur <%s@%s> est plus court qu'il ne devrait être (excès de %ld bytes)"
#: ../lib/vector/Vlib/open.c:100
#, c-format
@@ -2660,21 +2524,14 @@
msgstr "Le programmeur a demandé un open level inconnu %d"
#: ../lib/vector/Vlib/open.c:179
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-"Une couche vectorielle qui n'est pas dans le jeu de données courant ne peut "
-"pas être ouverte pour une mise à jour"
+msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgstr "Une couche vectorielle qui n'est pas dans le jeu de données courant ne peut pas être ouverte pour une mise à jour"
#: ../lib/vector/Vlib/open.c:211 ../lib/vector/Vlib/open.c:279
#: ../lib/vector/Vlib/open.c:299
#, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
-msgstr ""
-"Impossible d'ouvrir la carte vectorielle <%s> au niveau %d. Essayez de "
-"reconstruire la topologie avec v.build."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
+msgstr "Impossible d'ouvrir la carte vectorielle <%s> au niveau %d. Essayez de reconstruire la topologie avec v.build."
#: ../lib/vector/Vlib/open.c:214
msgid "Unable to read head file"
@@ -2683,21 +2540,17 @@
#: ../lib/vector/Vlib/open.c:236
#, c-format
msgid "Unable to open topology file for vector map <%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier topologique pour la couche vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier topologique pour la couche vectorielle <%s>"
#: ../lib/vector/Vlib/open.c:262
#, c-format
msgid "Unable to open category index file for vector map <%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier des catégories d'index pour la couche "
-"vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier des catégories d'index pour la couche vectorielle <%s>"
#: ../lib/vector/Vlib/open.c:353 ../lib/vector/Vlib/open.c:576
#, c-format
msgid "Unable to open history file for vector map <%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier d'historique pour la couche vectorielle <%s>"
+msgstr "Impossible d'ouvrir le fichier d'historique pour la couche vectorielle <%s>"
#: ../lib/vector/Vlib/open.c:531
#, c-format
@@ -2716,9 +2569,7 @@
#: ../lib/vector/Vlib/open.c:731
msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"La taille du fichier 'coord' est différente de la valeur sauvegardée dans le "
-"fichier de topologie"
+msgstr "La taille du fichier 'coord' est différente de la valeur sauvegardée dans le fichier de topologie"
#: ../lib/vector/Vlib/open.c:742
#, c-format
@@ -2752,15 +2603,12 @@
#: ../lib/vector/Vlib/cats.c:131
#, c-format
msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr ""
-"Trop de catégories (%d), dans l'impossibilité de mettre en cat %d (couche %d)"
+msgstr "Trop de catégories (%d), dans l'impossibilité de mettre en cat %d (couche %d)"
#: ../lib/vector/Vlib/cats.c:410
#, c-format
msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-"Impossible de convertir les catégories de caractères '%s' (de '%s') en "
-"intervalle de catégorie"
+msgstr "Impossible de convertir les catégories de caractères '%s' (de '%s') en intervalle de catégorie"
#: ../lib/vector/Vlib/graph.c:143
msgid "Unable to add network arc"
@@ -2776,8 +2624,7 @@
#: ../lib/vector/Vlib/intersect.c:407
msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-"Vect_segment_intersection() ERREUR (segments verticaux non colinéaires)"
+msgstr "Vect_segment_intersection() ERREUR (segments verticaux non colinéaires)"
#: ../lib/vector/Vlib/intersect.c:1059 ../lib/vector/Vlib/intersect.c:1065
#: ../lib/vector/Vlib/intersect.c:1067 ../lib/vector/Vlib/intersect.c:1115
@@ -2799,8 +2646,9 @@
msgstr "La ligne ne boucle pas"
#: ../lib/vector/Vlib/buffer2.c:598 ../lib/vector/Vlib/buffer2.c:609
+#, fuzzy
msgid "Next edge was visited but it is not the first one !!! breaking loop"
-msgstr ""
+msgstr "Le somment suivant a déjà été visité mais n'est pas le premier !!! rupture de la boucle"
#: ../lib/vector/Vlib/buffer2.c:657
msgid "side != 0 feature not implemented"
@@ -2835,9 +2683,7 @@
#: ../lib/vector/Vlib/array.c:294
#, c-format
msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr ""
-"Impossible de sélectionner un enregistrement depuis la table <%s> (clef %s, "
-"où %s)"
+msgstr "Impossible de sélectionner un enregistrement depuis la table <%s> (clef %s, où %s)"
#: ../lib/vector/Vlib/write.c:27 ../lib/vector/Vlib/write.c:33
#: ../lib/vector/Vlib/write.c:39 ../lib/vector/Vlib/write.c:46
@@ -2863,19 +2709,13 @@
#: ../lib/vector/Vlib/write.c:219
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Impossible de supprimer l'entité %d, la carte vectorielle <%s> n'est pas "
-"ouverte au niveau topologique"
+msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr "Impossible de supprimer l'entité %d, la carte vectorielle <%s> n'est pas ouverte au niveau topologique"
#: ../lib/vector/Vlib/write.c:225
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Impossible de supprimer l'entité %d, la carte vecotirelle <%s> n'est pas "
-"ouverte en mode « écriture »"
+msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Impossible de supprimer l'entité %d, la carte vecotirelle <%s> n'est pas ouverte en mode « écriture »"
#: ../lib/vector/Vlib/write.c:239
#, c-format
@@ -2884,19 +2724,13 @@
#: ../lib/vector/Vlib/write.c:265
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Impossible de restaurer l'entité %d, la carte vectorielle <%s> n'est pas "
+msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr "Impossible de restaurer l'entité %d, la carte vectorielle <%s> n'est pas ouverte au niveau topologique"
#: ../lib/vector/Vlib/write.c:271
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
+msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Impossible de restaurer l'entité %d, la carte vectorielle <%s> n'est pas ouverte en mode « écriture »"
#: ../lib/vector/Vlib/write.c:285
#, c-format
@@ -2942,9 +2776,7 @@
#: ../lib/vector/Vlib/cindex.c:512
#, c-format
msgid "Unable to open category index file for vector map <%s@%s>"
-msgstr ""
-"Impossible d'ouvrir le fichier d'index de catégorie pour la couche "
-"vectorielle <%s@%s>"
+msgstr "Impossible d'ouvrir le fichier d'index de catégorie pour la couche vectorielle <%s@%s>"
#: ../lib/vector/Vlib/field.c:93
msgid "Layer number must be 1 or greater"
@@ -2952,9 +2784,7 @@
#: ../lib/vector/Vlib/field.c:98
msgid "Unable to add database link, map is not opened in WRITE mode"
-msgstr ""
-"Impossible d'ajouter un lien base de données, la carte n'est pas ouverte en "
-"mode ÉCRITURE"
+msgstr "Impossible d'ajouter un lien base de données, la carte n'est pas ouverte en mode ÉCRITURE"
#: ../lib/vector/Vlib/field.c:104
msgid "Unable to add database link"
@@ -2998,12 +2828,8 @@
msgstr "Impossible d'ouvrir le pilote OGR DBMI"
#: ../lib/vector/Vlib/field.c:551
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-"Tous les tests FID ont échoués. Ni 'FID' ni 'ogc_fid' ni 'ogr_fid' ni 'gid' "
-"ne sont disponibles dans la table OGR DB"
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "Tous les tests FID ont échoués. Ni 'FID' ni 'ogc_fid' ni 'ogr_fid' ni 'gid' ne sont disponibles dans la table OGR DB"
#: ../lib/vector/Vlib/field.c:606
#, c-format
@@ -3018,15 +2844,11 @@
#: ../lib/vector/Vlib/field.c:709
#, c-format
msgid "Unable to open vector database definition file '%s'"
-msgstr ""
-"impossible d'ouvrir le fichier de définition de base de données pour le "
-"vecteur '%s'"
+msgstr "impossible d'ouvrir le fichier de définition de base de données pour le vecteur '%s'"
#: ../lib/vector/Vlib/field.c:804
msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-"Bug: tentative de mise à jour d'une couche qui n'est pas dans le jeu de "
-"cartes courant"
+msgstr "Bug: tentative de mise à jour d'une couche qui n'est pas dans le jeu de cartes courant"
#: ../lib/vector/Vlib/remove_areas.c:96
msgid "Area is composed of dead boundary"
@@ -3070,18 +2892,12 @@
msgstr "Outil de recherche inconnu"
#: ../lib/rst/interp_float/segmen2d.c:111
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"Recherche de points pour l'interpolation trop longue -- merci de changer la "
-"région pour la zone où se trouvent vos points. Poursuite des calculs ..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "Recherche de points pour l'interpolation trop longue -- merci de changer la région pour la zone où se trouvent vos points. Poursuite des calculs ..."
#: ../lib/rst/interp_float/interp2d.c:212
#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
msgstr ""
#: ../lib/rst/interp_float/input2d.c:47
@@ -3146,8 +2962,7 @@
#: ../lib/rst/interp_float/vinput2d.c:328
#, c-format
msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-"il y a des points en-dehors de la région 2D/3D spécifiée - %d points ignorés"
+msgstr "il y a des points en-dehors de la région 2D/3D spécifiée - %d points ignorés"
#: ../lib/rst/interp_float/vinput2d.c:331
#, c-format
@@ -3156,12 +2971,8 @@
#: ../lib/rst/interp_float/vinput2d.c:335
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
-msgstr ""
-"%d points donnés pour l'interpolation (après squelettisation) est moins que "
-"le NPMIN=% donnéd"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "%d points donnés pour l'interpolation (après squelettisation) est moins que le NPMIN=% donnéd"
#: ../lib/rst/interp_float/vinput2d.c:340
msgid "Zero points in the given region"
@@ -3169,22 +2980,13 @@
#: ../lib/rst/interp_float/vinput2d.c:345
#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-"Paramètres de segmentation invalides: npmin= %d, segmax= %d pour une bonne "
-"connexion des segments, npmin > segmax (voir le manuel)"
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Paramètres de segmentation invalides: npmin= %d, segmax= %d pour une bonne connexion des segments, npmin > segmax (voir le manuel)"
#: ../lib/rst/interp_float/vinput2d.c:351
#, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Il y a moins de %d poitns pour l'interpolation. Aucune segmentation n'est "
-"nécessaire, pour faire tourner le programme plus vite, paramétrez segmax=%d "
-"(voir manuel)"
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Il y a moins de %d poitns pour l'interpolation. Aucune segmentation n'est nécessaire, pour faire tourner le programme plus vite, paramétrez segmax=%d (voir manuel)"
#: ../lib/rst/interp_float/vinput2d.c:355
#, c-format
@@ -3394,15 +3196,11 @@
#: ../lib/gis/history.c:263
msgid "Not enough room in history file to record command line."
-msgstr ""
-"Mémoire unsuffisante dans le fichier d'historique pour enregistrer la ligne "
-"de commande"
+msgstr "Mémoire unsuffisante dans le fichier d'historique pour enregistrer la ligne de commande"
#: ../lib/gis/history.c:285
msgid "Not enough room in history file for command line (truncated)."
-msgstr ""
-"de commande (tronquée)"
+msgstr "Mémoire unsuffisante dans le fichier d'historique pour enregistrer la ligne de commande (tronquée)"
#: ../lib/gis/put_title.c:29
#, c-format
@@ -3427,8 +3225,7 @@
#: ../lib/gis/put_title.c:72
#, c-format
msgid "can't write category information for [%s] in [%s]"
-msgstr ""
-"impossible d'écrire les informations de la catégorie pour [%s] dans [%s]"
+msgstr "impossible d'écrire les informations de la catégorie pour [%s] dans [%s]"
#: ../lib/gis/legal_name.c:39
#, c-format
@@ -3443,8 +3240,7 @@
#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
#, c-format
msgid "Output raster map name <%s> is not valid map name"
-msgstr ""
-"Le nom <%s> de la carte raster en sortie n'est pas un nom de carte valide"
+msgstr "Le nom <%s> de la carte raster en sortie n'est pas un nom de carte valide"
#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
#, c-format
@@ -3476,12 +3272,8 @@
#: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:90
#, fuzzy
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
-msgstr ""
-"Version de librairie incompatible pour le module. Vous devez reconstruire "
-"GRASS ou gérer les versions multiples."
+msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
+msgstr "Version de librairie incompatible pour le module. Vous devez recompiler GRASS ou gérer les versions multiples."
#: ../lib/gis/gisinit.c:63
#, c-format
@@ -3500,8 +3292,7 @@
#: ../lib/gis/color_read.c:116
#, c-format
msgid "color support for [%s] in mapset [%s] %s"
-msgstr ""
-"support de la couleur pour [%s] dans le jeu de données (mapset) [%s] %s"
+msgstr "support de la couleur pour [%s] dans le jeu de données (mapset) [%s] %s"
#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
#, fuzzy
@@ -3545,9 +3336,7 @@
#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:247
#, c-format
msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr ""
-"Ajustement d'une légère erreur d'arrondi sur la valeur de la limite Nord (%g>"
-"%g)"
+msgstr "Ajustement d'une légère erreur d'arrondi sur la valeur de la limite Nord (%g>%g)"
#: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:252
msgid "Illegal latitude for North"
@@ -3556,9 +3345,7 @@
#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:258
#, c-format
msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
-"justement d'une légère erreur d'arrondi sur la valeur de la limite Sud (%g>"
-"%g)"
+msgstr "justement d'une légère erreur d'arrondi sur la valeur de la limite Sud (%g>%g)"
#: ../lib/gis/adj_cellhd.c:95 ../lib/gis/adj_cellhd.c:263
msgid "Illegal latitude for South"
@@ -3567,16 +3354,12 @@
#: ../lib/gis/adj_cellhd.c:107 ../lib/gis/adj_cellhd.c:275
#, c-format
msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
-"Erreur dans les méthodes de fixation des données d'entrée à la frontière "
-"Ouest (%g>%g)"
+msgstr "Erreur dans les méthodes de fixation des données d'entrée à la frontière Ouest (%g>%g)"
#: ../lib/gis/adj_cellhd.c:118 ../lib/gis/adj_cellhd.c:286
#, c-format
msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
-"Erreur dans les méthodes de fixation des données d'entrée à la frontière Est "
-"(%g>%g)"
+msgstr "Erreur dans les méthodes de fixation des données d'entrée à la frontière Est (%g>%g)"
#: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:299
msgid "North must be north of South"
@@ -3799,12 +3582,8 @@
msgstr "Numéro de la couche"
#: ../lib/gis/parser.c:596
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use."
-msgstr ""
-"Une seule carte vectorielle peut être connectée à plusieurs tables de base "
-"de données. Ce nombre détermine la table à utiliser."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+msgstr "Une seule carte vectorielle peut être connectée à plusieurs tables de base de données. Ce nombre détermine la table à utiliser."
#: ../lib/gis/parser.c:605
msgid "Category value"
@@ -3865,15 +3644,11 @@
#: ../lib/gis/parser.c:926
msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-"Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --verbose "
-"supposé."
+msgstr "Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --verbose supposé."
#: ../lib/gis/parser.c:940
msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-"Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --quiet "
-"supposé."
+msgstr "Utiliser le drapeau soit --quiet soit --verbose, pas les deux ; --quiet supposé."
#: ../lib/gis/parser.c:971
#, c-format
@@ -4205,12 +3980,8 @@
"projection invalide\n"
#: ../lib/gis/set_window.c:76
-msgid ""
-"G_set_window(): projection/zone differs from that of currently open raster "
-"maps"
-msgstr ""
-"G_set_window(): projection/zone diffèrent de ceux présents dans le fichier "
-"matriciel actuellement ouvert"
+msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window(): projection/zone diffèrent de ceux présents dans le fichier matriciel actuellement ouvert"
#: ../lib/gis/home.c:39
msgid "unable to determine user's home directory"
@@ -4253,30 +4024,22 @@
#: ../lib/gis/timestamp.c:282
#, c-format
msgid "Can't create timestamp file for %s map %s in mapset %s"
-msgstr ""
-"Impossible de créer le fichier d'étiquettes date&heure (timestamp) pour la "
-"couche %s %s dans le jeu de données (mapset) %s"
+msgstr "Impossible de créer le fichier d'étiquettes date&heure (timestamp) pour la couche %s %s dans le jeu de données (mapset) %s"
#: ../lib/gis/timestamp.c:291
#, c-format
msgid "Invalid timestamp specified for %s map %s in mapset %s"
-msgstr ""
-"L'étiquette date&heure (timestamp) spécifiée pour la couche %s %s est "
-"invalide dans le jeu de données (mapset) %s"
+msgstr "L'étiquette date&heure (timestamp) spécifiée pour la couche %s %s est invalide dans le jeu de données (mapset) %s"
#: ../lib/gis/timestamp.c:313
#, c-format
msgid "Can't open timestamp file for %s map %s in mapset %s"
-msgstr ""
-"Impossible d'ouvrir le fichier d'étiquettes date&heure (timestamp) pour la "
+msgstr "Impossible d'ouvrir le fichier d'étiquettes date&heure (timestamp) pour la couche %s %s dans le jeu de données (mapset) %s"
#: ../lib/gis/timestamp.c:322
#, c-format
msgid "Invalid timestamp file for %s map %s in mapset %s"
-msgstr ""
-"Fichier d'étiquette date&heure (timestamp) invalide pour la couche %s %s "
-"dans le jeu de données (mapset) %s"
+msgstr "Fichier d'étiquette date&heure (timestamp) invalide pour la couche %s %s dans le jeu de données (mapset) %s"
#: ../lib/gis/reclass.c:145
#, c-format
@@ -4286,9 +4049,7 @@
#: ../lib/gis/reclass.c:148
#, c-format
msgid "Illegal reclass format in header file for [%s in %s]"
-msgstr ""
-"Format de reclassification illégal dans l'en-tête de fichier pour [%s dans "
-"%s]"
+msgstr "Format de reclassification illégal dans l'en-tête de fichier pour [%s dans %s]"
#: ../lib/gis/reclass.c:238
msgid "Illegal reclass request"
@@ -4311,9 +4072,7 @@
#: ../lib/gis/get_row.c:46 ../lib/gis/get_row.c:1049
#, c-format
msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-"La lecture de la carte raster <%s@%s> demande la ligne %d en dehors de la "
-"région"
+msgstr "La lecture de la carte raster <%s@%s> demande la ligne %d en dehors de la région"
#: ../lib/gis/get_row.c:324
#, c-format
@@ -4437,8 +4196,7 @@
#: ../lib/gis/put_row.c:215
#, c-format
msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
-msgstr ""
-"G_put_map_row: %s n'est pas un entier! Utiliser G_put_[f/d]_raster_row() !"
+msgstr "G_put_map_row: %s n'est pas un entier! Utiliser G_put_[f/d]_raster_row() !"
#: ../lib/gis/put_row.c:251
#, c-format
@@ -4503,9 +4261,7 @@
#: ../lib/gis/cats.c:417
#, c-format
msgid "category support for vector map [%s] in mapset [%s] %s"
-msgstr ""
-"support de la catégorie pour le fichier vecteur [%s] dans le jeu de données "
-"(mapset) [%s] %s"
+msgstr "support de la catégorie pour le fichier vecteur [%s] dans le jeu de données (mapset) [%s] %s"
#: ../lib/gis/ask.c:341
msgid "to cancel request"
@@ -4617,8 +4373,7 @@
#: ../lib/gis/get_datum_name.c:57
#, c-format
msgid "or 'custom' if you wish to enter custom parameters\n"
-msgstr ""
-"ou 'personnalisé' si vous souhaitez entrer des paramètres personnalisés\n"
+msgstr "ou 'personnalisé' si vous souhaitez entrer des paramètres personnalisés\n"
#: ../lib/gis/get_datum_name.c:97
#, c-format
@@ -4641,34 +4396,23 @@
#: ../lib/gis/opencell.c:188
#, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
-msgstr ""
-"Impossible d'ouvrir la carte raster <%s@%s> car il s'agit d'une "
-"reclassification de la carte raster <%s@%s> qui n'existe pas"
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "Impossible d'ouvrir la carte raster <%s@%s> car il s'agit d'une reclassification de la carte raster <%s@%s> qui n'existe pas"
#: ../lib/gis/opencell.c:212
#, c-format
msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr ""
-"Carte raster <%s@%s>: format de champ invalide dans le fichier d'en-tête"
+msgstr "Carte raster <%s@%s>: format de champ invalide dans le fichier d'en-tête"
#: ../lib/gis/opencell.c:219
#, c-format
-msgid ""
-"Raster map <%s@%s> is in different projection than current region. Found "
-"raster map <%s@%s>, should be <%s>."
-msgstr ""
-"Carte raster <%s@%s> dans une projection différente de la région courante. "
-"La carte raster <%s@%s>, devrait être <%s>."
+msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
+msgstr "Carte raster <%s@%s> dans une projection différente de la région courante. La carte raster <%s@%s>, devrait être <%s>."
#: ../lib/gis/opencell.c:226
#, c-format
msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-msgstr ""
-"Carte raster <%s@%s> est dans une zone différentes (%d) de la région "
-"courante (%d)"
+msgstr "Carte raster <%s@%s> est dans une zone différentes (%d) de la région courante (%d)"
#: ../lib/gis/opencell.c:233
#, c-format
@@ -4678,8 +4422,7 @@
#: ../lib/gis/opencell.c:262
#, c-format
msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
-"la carte <%s@%s> est un lien GDAL mais GRASS est compilé sans le support GDAL"
+msgstr "la carte <%s@%s> est un lien GDAL mais GRASS est compilé sans le support GDAL"
#: ../lib/gis/opencell.c:642
#, c-format
@@ -4701,17 +4444,12 @@
msgstr "G__open_raster_new(): pas de fichiers temporaires disponibles"
#: ../lib/gis/opencell.c:736
-msgid ""
-"Unable to write embedded null values for raster map open for random access"
-msgstr ""
-"Impossible d'écrire les valeurs nulles intégrées pour une carte raster "
-"ouverte en accès aléatoire"
+msgid "Unable to write embedded null values for raster map open for random access"
+msgstr "Impossible d'écrire les valeurs nulles intégrées pour une carte raster ouverte en accès aléatoire"
#: ../lib/gis/opencell.c:941
msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr ""
-"G_set_fp_type(): ne peut être appellé que pour des FCELL_TYPE ou des "
-"DCELL_TYPE"
+msgstr "G_set_fp_type(): ne peut être appellé que pour des FCELL_TYPE ou des DCELL_TYPE"
#: ../lib/gis/opencell.c:976 ../lib/gis/opencell.c:1064
#, c-format
@@ -4744,11 +4482,8 @@
msgstr "La carte raster <%s> n'est pas xdr: byte_order: %s"
#: ../lib/gis/opencell.c:1179
-msgid ""
-"G_set_quant_rules() can be called only for raster maps opened for reading"
-msgstr ""
-"G_set_quant_rules() ne peut être appellé que pour des cartes raster ouvertes "
-"en lecture"
+msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
+msgstr "G_set_quant_rules() ne peut être appellé que pour des cartes raster ouvertes en lecture"
#: ../lib/gis/sample.c:71
msgid "Unknown interpolation type"
@@ -4908,8 +4643,7 @@
msgstr ""
"\n"
"\n"
-"La table des couleurs est nécessaire pour le fichier |%s] dans le jeu de "
-"données (mapset) [%s].\n"
+"La table des couleurs est nécessaire pour le fichier |%s] dans le jeu de données (mapset) [%s].\n"
#: ../lib/gis/make_colr.c:51
#, c-format
@@ -5007,9 +4741,7 @@
#: ../lib/gis/get_cellhd.c:105
#, c-format
msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-msgstr ""
-" C'est une reclassification de la carte raster <%s@%s> dont l'en-tête est "
-"invalide."
+msgstr " C'est une reclassification de la carte raster <%s@%s> dont l'en-tête est invalide."
#: ../lib/gis/get_cellhd.c:109
#, c-format
@@ -5034,17 +4766,12 @@
#: ../lib/gis/view.c:546
#, c-format
msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-"La fenêtre sauvegardée dans \"%s\" est complètement en dehors de la fenêtre "
-"GRASS courante."
+msgstr "La fenêtre sauvegardée dans \"%s\" est complètement en dehors de la fenêtre GRASS courante."
#: ../lib/gis/view.c:550
#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" Seulement %d%% de la fenêtre sauvegardée dans \"%s\" chevauche(nt) la "
-"fenêtre GRASS courante."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Seulement %d%% de la fenêtre sauvegardée dans \"%s\" chevauche(nt) la fenêtre GRASS courante."
#: ../lib/gis/ask_cell.c:54 ../lib/gis/ask_cell.c:72 ../lib/gis/ask_cell.c:91
#: ../lib/gis/ask_cell.c:96
@@ -5110,9 +4837,7 @@
#: ../lib/gis/closecell.c:261
#, c-format
msgid "Error writing floating point format file for map %s"
-msgstr ""
-"Erreur lors de l'écriture en virgule flottante dans le fichier au format de "
-"la couche %s"
+msgstr "Erreur lors de l'écriture en virgule flottante dans le fichier au format de la couche %s"
#: ../lib/gis/closecell.c:272
#, fuzzy
@@ -5164,8 +4889,7 @@
#: ../lib/gis/closecell.c:444
#, fuzzy
msgid "Unable to write f_format file for CELL maps"
-msgstr ""
-"pas en mesure d'écrire des fichiers f_format pour des couches de cellules"
+msgstr "pas en mesure d'écrire des fichiers f_format pour des couches de cellules"
#: ../lib/gis/mapset.c:39
msgid "MAPSET is not set"
@@ -5178,12 +4902,8 @@
#: ../lib/gis/distance.c:160
#, c-format
-msgid ""
-"G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,"
-"%f)(%f,%f)"
-msgstr ""
-"G_distance_point_to_line_segment: ne devrait pas arriver: code=%d P=(%f,%f) "
-"S=(%f,%f)(%f,%f)"
+msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgstr "G_distance_point_to_line_segment: ne devrait pas arriver: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
#: ../lib/gis/debug.c:74
#, c-format
@@ -5193,8 +4913,7 @@
#: ../lib/gis/find_file.c:74
#, c-format
msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
-msgstr ""
-"'%s/%s' trouvé dans plusieurs jeux de cartes (également trouvé dans <%s>)"
+msgstr "'%s/%s' trouvé dans plusieurs jeux de cartes (également trouvé dans <%s>)"
#: ../lib/gis/find_file.c:82
#, c-format
@@ -5287,17 +5006,14 @@
#: ../lib/db/dbmi_base/legal_dbname.c:43
#, c-format
msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-msgstr ""
-"Nom de couche table illégal <%s>. Le caractère <%c> n'est pas autorisé.\n"
+msgstr "Nom de couche table illégal <%s>. Le caractère <%c> n'est pas autorisé.\n"
#: ../lib/db/dbmi_base/default_name.c:127
msgid "Programmer error"
msgstr "Erreur de programmation"
#~ msgid "The gauss elimination solver does not work with sparse matrices"
-#~ msgstr ""
-#~ "La résolution par la méthode de Gauss ne fonctionne pas avec les matrices "
-#~ "creuses"
+#~ msgstr "La résolution par la méthode de Gauss ne fonctionne pas avec les matrices creuses"
#~ msgid "The linear equation system is not quadratic"
#~ msgstr "Le système d'équations linéaires n'est pas quadratique"
@@ -5353,5 +5069,7 @@
#~ msgstr "pas en mesure d'écrire le fichier!"
#~ msgid "unable to write f_format file for CELL maps"
-#~ msgstr ""
-#~ "pas en mesure d'écrire des fichiers f_format pour des couches de cellules"
+#~ msgstr "pas en mesure d'écrire des fichiers f_format pour des couches de cellules"
+#~ msgid " The raster map %s@%s is empty"
+#~ msgstr "La couche raster %s@%s est vide"
Modified: grass/branches/develbranch_6/locale/po/grassmods_fr.po
--- grass/branches/develbranch_6/locale/po/grassmods_fr.po 2013-10-30 21:32:06 UTC (rev 58125)
+++ grass/branches/develbranch_6/locale/po/grassmods_fr.po 2013-10-30 21:41:04 UTC (rev 58126)
@@ -98,18 +98,12 @@
#: ../raster/r.out.tiff/r.out.tiff.c:144 ../raster/r.out.mat/main.c:90
#: ../raster/r.in.mat/main.c:125 ../display/d.vect/main.c:367
#: ../display/d.mon/pgms/release.c:36
-msgid ""
-"The '-v' flag is superseded and will be removed in future. Please use '--"
-"verbose' instead."
-msgstr ""
-"Le drapeau '-v' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--"
-"verbose' à la place."
+msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
+msgstr "Le drapeau '-v' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--verbose' à la place."
#: ../visualization/nviz/src/nviz_init.c:155
msgid "Number of elevation files does not match number of colors files"
-msgstr ""
-"Le nombre de fichiers d'altitudes ne correspond pas au nombre de fichiers de "
-"couleur"
+msgstr "Le nombre de fichiers d'altitudes ne correspond pas au nombre de fichiers de couleur"
#: ../visualization/nviz/src/nviz_init.c:166
msgid "Loading data failed"
@@ -181,8 +175,7 @@
#: ../visualization/ximgview/color.c:269
#: ../visualization/xganim/Clr_table.c:273
msgid "Using private colormap for DirectColor visual."
-msgstr ""
-"Utilisation d'une table de couleur privée pour la visualisation DirectColor"
+msgstr "Utilisation d'une table de couleur privée pour la visualisation DirectColor"
#: ../visualization/xganim/main.c:362
#, fuzzy, c-format
@@ -669,8 +662,7 @@
#: ../vector/v.to.rast/support.c:435 ../vector/v.to.rast/vect2rast.c:51
#, fuzzy, c-format
msgid "Database connection not defined for layer %d"
-msgstr ""
-"La connexion à la base de données n'a pas été définie pour la couche <%d>"
+msgstr "La connexion à la base de données n'a pas été définie pour la couche <%d>"
# c-format
#: ../doc/vector/v.example/main.c:123 ../display/d.vect/main.c:470
@@ -765,12 +757,8 @@
msgstr "raster3d, voxel, import"
#: ../raster3d/r3.in.v5d/main.c:193
-msgid ""
-"Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 "
-"time step)."
-msgstr ""
-"Importe des fichiers 3D Vis5D (c.-à-d. des fichiers V5D avec une variable et "
-"un pas de temps)."
+msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
+msgstr "Importe des fichiers 3D Vis5D (c.-à-d. des fichiers V5D avec une variable et un pas de temps)."
# c-format
#: ../raster3d/r3.in.v5d/main.c:213 ../raster3d/r3.in.ascii/main.c:281
@@ -790,13 +778,11 @@
#: ../raster3d/r3.gwflow/main.c:57
msgid "Input 3D raster map with initial piezometric heads in [m]"
-msgstr ""
-"Carte raster 3D d'entrée avec les niveaux piezométriques initiaux en [m]"
+msgstr "Carte raster 3D d'entrée avec les niveaux piezométriques initiaux en [m]"
#: ../raster3d/r3.gwflow/main.c:65
msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
-msgstr ""
-"Le status de chaque cellule, = 0 - inactive, 1 - active, 2 - dirichlet"
+msgstr "Le status de chaque cellule, = 0 - inactive, 1 - active, 2 - dirichlet"
#: ../raster3d/r3.gwflow/main.c:73
msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
@@ -823,9 +809,7 @@
msgstr ""
#: ../raster3d/r3.gwflow/main.c:118
-msgid ""
-"The piezometric head result of the numerical calculation will be written to "
-"this map"
+msgid "The piezometric head result of the numerical calculation will be written to this map"
msgstr ""
#: ../raster3d/r3.gwflow/main.c:125
@@ -841,8 +825,7 @@
msgstr "Utilisez le masque raster 3D (s'il existe) sur la couche en entrée"
#: ../raster3d/r3.gwflow/main.c:142
-msgid ""
-"Use a sparse linear equation system, only available with iterative solvers"
+msgid "Use a sparse linear equation system, only available with iterative solvers"
msgstr ""
#: ../raster3d/r3.gwflow/main.c:172 ../raster3d/r3.mkdspf/main.c:75
@@ -853,9 +836,7 @@
msgstr ""
#: ../raster3d/r3.gwflow/main.c:174
-msgid ""
-"Calculates numerically transient, confined groundwater flow in three "
-"dimensions."
+msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
msgstr ""
#: ../raster3d/r3.gwflow/main.c:191
@@ -879,12 +860,8 @@
msgstr ""
#: ../raster3d/r3.mkdspf/main.c:77
-msgid ""
-"Creates a display file from an existing grid3 file according to specified "
-"threshold levels."
-msgstr ""
-"Crée un affichage à partir d'une couche raster 3D existante à partir de "
-"seuils de valeur spécifiée"
+msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
+msgstr "Crée un affichage à partir d'une couche raster 3D existante à partir de seuils de valeur spécifiée"
#: ../raster3d/r3.mkdspf/main.c:85
msgid "Name of an existing 3d raster map"
@@ -908,8 +885,7 @@
#: ../raster3d/r3.mkdspf/main.c:116
msgid "Positive increment between isosurface levels"
-msgstr ""
-"Dénivelé (de valeur positive) entre les courbes de niveau des iso-surfaces"
+msgstr "Dénivelé (de valeur positive) entre les courbes de niveau des iso-surfaces"
#: ../raster3d/r3.mkdspf/main.c:123
msgid "Number of isosurface threshold levels"
@@ -1033,9 +1009,7 @@
#: ../raster3d/base/r3.info.main.c:80
msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr ""
-"Obtenir des informations générales à propos d'une couche raster 3D spécifiée "
-"par l'utilisateur."
+msgstr "Obtenir des informations générales à propos d'une couche raster 3D spécifiée par l'utilisateur."
#: ../raster3d/base/r3.info.main.c:87
msgid "Name of input 3D raster map"
@@ -1047,9 +1021,7 @@
#: ../raster3d/base/r3.info.main.c:96
msgid "Print 3D raster map resolution (NS-res, EW-res, TB-res) only"
-msgstr ""
-"Écrire uniquement la résolution de la couche raster 3D (NS-res, EW-res, Haut-"
-"Bas-res)"
+msgstr "Écrire uniquement la résolution de la couche raster 3D (NS-res, EW-res, Haut-Bas-res)"
#: ../raster3d/base/r3.info.main.c:100
msgid "Print 3D raster map type (float/double) only"
@@ -1066,9 +1038,7 @@
#: ../raster3d/base/r3.info.main.c:113
msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr ""
-"Afficher seulement l'étiquette date&heure du raster 3D (sous la forme jour."
-"mois.année heure:minute:secondes)"
+msgstr "Afficher seulement l'étiquette date&heure du raster 3D (sous la forme jour.mois.année heure:minute:secondes)"
#: ../raster3d/base/r3.info.main.c:121
#, fuzzy, c-format
@@ -1088,9 +1058,7 @@
#: ../raster3d/base/r3.info.main.c:321 ../raster3d/base/r3.info.main.c:334
#: ../raster/r.info/main.c:307 ../raster/r.info/main.c:433
msgid "Cannot allocate memory for string"
-msgstr ""
-"Impossible de calculer le centroïde de la surface (problème d'allocation "
-"mémoire)"
+msgstr "Impossible de calculer le centroïde de la surface (problème d'allocation mémoire)"
#: ../raster3d/base/r3.info.main.c:287 ../raster3d/base/r3.info.main.c:349
#, c-format
@@ -1120,9 +1088,7 @@
#: ../raster3d/base/r3.null.main.c:125
msgid "modifyNull: error opening tmp file"
-msgstr ""
-"modifyNull (modification des valeurs nulles) : erreur d'ouverture du fichier "
-"temporaire"
+msgstr "modifyNull (modification des valeurs nulles) : erreur d'ouverture du fichier temporaire"
#: ../raster3d/base/r3.null.main.c:174
msgid "modifyNull: error flushing tiles in cube"
@@ -1140,9 +1106,7 @@
#: ../raster3d/base/r3.null.main.c:190
#, fuzzy
msgid "modifyNull: Unable to close tmp file"
-msgstr ""
-"modifyNull (modification des valeurs nulles) : erreur dans la fermeture du "
-"fichier temporaire"
+msgstr "modifyNull (modification des valeurs nulles) : erreur dans la fermeture du fichier temporaire"
#: ../raster3d/base/r3.null.main.c:207
msgid "Explicitly create the 3D NULL-value bitmap file."
@@ -1151,9 +1115,7 @@
#: ../raster3d/base/r3.timestamp.main.c:45
#, fuzzy
msgid "Print/add/remove a timestamp for a 3D raster map"
-msgstr ""
-"Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une "
-"couche raster 3D"
+msgstr "Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une couche raster 3D"
#: ../raster3d/base/r3.timestamp.main.c:52
msgid "Input grid3 filename"
@@ -1262,12 +1224,8 @@
msgstr "Racine du nom des tranches rasters créées"
#: ../raster3d/r3.to.rast/main.c:95
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D outputmaps, "
-"independent of the current region settings"
-msgstr ""
-"Utiliser la même résolution que la carte raster 3D en entrée pour les cartes "
-"2D en sortie, indépendamment des réglages de la région courante"
+msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
+msgstr "Utiliser la même résolution que la carte raster 3D en entrée pour les cartes 2D en sortie, indépendamment des réglages de la région courante"
#: ../raster3d/r3.to.rast/main.c:152 ../raster3d/r3.to.rast/main.c:159
#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.cross.rast/main.c:237
@@ -1296,12 +1254,8 @@
msgstr ""
#: ../raster3d/r3.to.rast/main.c:267 ../raster3d/r3.out.vtk/main.c:451
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
-msgstr ""
-"Les réglages de région 2D et 3D sont différents. Utilisation des réglages de "
-"la fenêtre 2D pour ajuster la partie 2D de la région 3D."
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
+msgstr "Les réglages de région 2D et 3D sont différents. Utilisation des réglages de la fenêtre 2D pour ajuster la partie 2D de la région 3D."
#: ../raster3d/r3.to.rast/main.c:299 ../raster/r.gwflow/main.c:347
#: ../raster/r.to.rast3/main.c:236 ../raster/r.li/r.li.daemon/list.c:49
@@ -1357,9 +1311,7 @@
#: ../raster3d/r3.to.rast/main.c:313
#, fuzzy, c-format
msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-msgstr ""
-"Couche raster %i le nom de fichier %s existe déjà. Ce fichier va être "
-"écrasé!\n"
+msgstr "Couche raster %i le nom de fichier %s existe déjà. Ce fichier va être écrasé!\n"
#: ../raster3d/r3.cross.rast/main.c:91
msgid "Input 3D raster map for cross section."
@@ -1380,20 +1332,12 @@
#: ../raster3d/r3.cross.rast/main.c:272
#, fuzzy
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map."
-msgstr ""
-"Crée une couche raster de coupe 2D à partir du raster volumique G3D à partir "
-"d'une couche de relief 2D"
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
+msgstr "Crée une couche raster de coupe 2D à partir du raster volumique G3D à partir d'une couche de relief 2D"
#: ../raster3d/r3.cross.rast/main.c:298
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
-msgstr ""
-"carte 3D pour ajuster la région 2D."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
+msgstr "Les réglages de région 2D et 3D sont différents. Utilisation des réglages de carte 3D pour ajuster la région 2D."
# c-format
#: ../raster3d/r3.cross.rast/main.c:333
@@ -1425,8 +1369,7 @@
#: ../raster3d/r3.cross.rast/main.c:399
#, fuzzy
msgid "Wrong 3D raster map datatype! Unable to create raster map."
-msgstr ""
-"Erreur sur le type de raster G3D! Impossible de créer la couche raster."
+msgstr "Erreur sur le type de raster G3D! Impossible de créer la couche raster."
#: ../raster3d/r3.out.vtk/errorHandling.c:52
msgid "Unable to close input raster map"
@@ -1458,9 +1401,7 @@
#: ../raster3d/r3.out.vtk/writeVTKData.c:462
#, fuzzy
msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-msgstr ""
-"Valeurs de couches G3D erronées! Les valeurs doivent être comprises entre 0 "
-"et 255!\n"
+msgstr "Valeurs de couches G3D erronées! Les valeurs doivent être comprises entre 0 et 255!\n"
#: ../raster3d/r3.out.vtk/parameters.c:30
msgid "G3D map(s) to be converted to VTK-ASCII data format"
@@ -1476,9 +1417,7 @@
#: ../raster3d/r3.out.vtk/parameters.c:47
msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
-"Créer des données points VTK à la place de données cellules VTK (par défaut, "
-"cellules)"
+msgstr "Créer des données points VTK à la place de données cellules VTK (par défaut, cellules)"
#: ../raster3d/r3.out.vtk/parameters.c:56
msgid "top surface 2D raster map"
@@ -1489,27 +1428,18 @@
msgstr "couche raster de surface 2D (couche inférieure)"
#: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3d elevation output with a top and a bottom surface, both raster maps "
-"are required."
-msgstr ""
-"Crée une sortie 3D en relief à partir de surface de dessus et de fond, les "
-"deux couches rasters sont requises."
+msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
+msgstr "Crée une sortie 3D en relief à partir de surface de dessus et de fond, les deux couches rasters sont requises."
#: ../raster3d/r3.out.vtk/parameters.c:82
#, fuzzy
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
-"3 couches rasters g3d (r,g,b) utilisées pour créer les valeurs RGB [redmap,"
-"greenmap,bluemap]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr "3 couches rasters g3d (r,g,b) utilisées pour créer les valeurs RGB [redmap,greenmap,bluemap]"
#: ../raster3d/r3.out.vtk/parameters.c:92
#, fuzzy
msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
#: ../raster3d/r3.out.vtk/parameters.c:99 ../raster/r.out.vtk/parameters.c:93
#: ../vector/v.out.vtk/main.c:75
@@ -1570,12 +1500,8 @@
#: ../raster3d/r3.out.vtk/main.c:178
#, fuzzy
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided. Will only write the "
-"geometry"
-msgstr ""
-"Aucune données g3d, couches RGB ou vecteur xyz n'ont été indiquées! On "
-"écrira uniquement la géométrie."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
+msgstr "Aucune données g3d, couches RGB ou vecteur xyz n'ont été indiquées! On écrira uniquement la géométrie."
#: ../raster3d/r3.out.vtk/main.c:211
#, fuzzy
@@ -1613,9 +1539,7 @@
#: ../raster3d/r3.out.vtk/main.c:546
#, fuzzy
msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr ""
-"Erreur de fermeture de la couche de données G3D, le fichier VTK risque "
-"d'être incomplet."
+msgstr "Erreur de fermeture de la couche de données G3D, le fichier VTK risque d'être incomplet."
# c-format
#: ../raster3d/r3.out.vtk/main.c:561
@@ -1645,9 +1569,7 @@
#: ../raster3d/r3.in.ascii/main.c:90
msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-"Chaîne représentant les cellules de données NULL (utilisez 'none' si toutes "
-"les valeurs sont définies)"
+msgstr "Chaîne représentant les cellules de données NULL (utilisez 'none' si toutes les valeurs sont définies)"
#: ../raster3d/r3.in.ascii/main.c:175
#, c-format
@@ -1665,16 +1587,12 @@
#: ../raster3d/r3.in.ascii/main.c:222
#, c-format
-msgid ""
-"Data exists in input file after fully importing expected data. [%.4f ...]"
-msgstr ""
-"Des données subsistent dans le fichier en entrée après l'importation "
-"complète des données attendues. [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data. [%.4f ...]"
+msgstr "Des données subsistent dans le fichier en entrée après l'importation complète des données attendues. [%.4f ...]"
#: ../raster3d/r3.in.ascii/main.c:255
#, fuzzy
-msgid ""
-"Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
msgstr "Convertir un fichier raster ASCII en couche raster 3D (binaire)."
# c-format
@@ -1694,9 +1612,7 @@
#: ../raster3d/r3.stats/main.c:580
#, fuzzy
msgid "Number of subranges to collect stats from"
-msgstr ""
-"Nombres de chiffres après la virgule à prendre en compte pour constituer les "
-"statistiques"
+msgstr "Nombres de chiffres après la virgule à prendre en compte pour constituer les statistiques"
#: ../raster3d/r3.stats/main.c:586
msgid "Calculate statistics based on equal value groups"
@@ -2056,11 +1972,8 @@
msgstr ""
#: ../misc/m.nviz.image/args.c:783
-msgid ""
-"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
-msgstr ""
-"no ; bordure Nord-Ouest ; ne ; bordure Nord-Est ; so ; bordure Sud-Ouest ; "
-"se ; bordure Sud-Est"
+msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr "no ; bordure Nord-Ouest ; ne ; bordure Nord-Est ; so ; bordure Sud-Ouest ; se ; bordure Sud-Est"
#: ../misc/m.nviz.image/args.c:787
msgid "Fringe edges"
@@ -2080,9 +1993,7 @@
msgstr ""
#: ../misc/m.nviz.image/args.c:815
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
msgstr ""
#: ../misc/m.nviz.image/args.c:817 ../misc/m.nviz.image/args.c:826
@@ -2202,24 +2113,18 @@
msgstr ""
#: ../misc/m.nviz.image/main.c:51
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
-msgstr ""
-"Restitue en 3D des surfaces (données raster), des données vecteur 2D/3D, et "
-"des volumes (données raster 3D)."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+msgstr "Restitue en 3D des surfaces (données raster), des données vecteur 2D/3D, et des volumes (données raster 3D)."
#: ../misc/m.nviz.image/main.c:134
#, c-format
msgid "Vertical exaggeration not given, using calculated value %.0f"
-msgstr ""
-"Exagération verticale non fournie, utilisation de la valeur calculée %.0f"
+msgstr "Exagération verticale non fournie, utilisation de la valeur calculée %.0f"
#: ../misc/m.nviz.image/main.c:146
#, c-format
msgid "Viewpoint height not given, using calculated value %.0f"
-msgstr ""
-"Hauteur de point de vue non fournie, utilisation de la valeur calculée %.0f"
+msgstr "Hauteur de point de vue non fournie, utilisation de la valeur calculée %.0f"
#: ../misc/m.nviz.image/main.c:229
msgid "Unsupported output format"
@@ -2259,12 +2164,8 @@
msgstr ""
#: ../misc/m.cogo/main.c:228
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
-msgstr ""
-"Un utilitaire simple pour convertir des mesures de gisement et distance en "
-"coordonnées et vice versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgstr "Un utilitaire simple pour convertir des mesures de gisement et distance en coordonnées et vice versa."
#: ../misc/m.cogo/main.c:230
msgid "It assumes a cartesian coordinate system"
@@ -2316,12 +2217,8 @@
#: ../raster/r.external/main.c:83 ../raster/r.in.gdal/main.c:341
#, fuzzy
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
-msgstr ""
-"Impossible de convertir l'information de projection de la couche de données "
-"au format GRASS pour vérification"
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
+msgstr "Impossible de convertir l'information de projection de la couche de données au format GRASS pour vérification"
#: ../raster/r.external/main.c:99 ../raster/r.in.gdal/main.c:357
#: ../vector/v.in.ogr/main.c:518
@@ -2352,38 +2249,28 @@
#, fuzzy
msgid ""
"\n"
-"You can use the -o flag to r.external to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
"Vous pouvez utiliser le drapeau -o de %s pour sauter cette vérification.\n"
#: ../raster/r.external/main.c:175 ../raster/r.in.gdal/main.c:444
#, fuzzy
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
-msgstr ""
-"Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' "
-"des données en entrée.\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
+msgstr "Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' des données en entrée.\n"
#: ../raster/r.external/main.c:180 ../raster/r.in.gdal/main.c:449
#: ../vector/v.in.ogr/main.c:601
#, fuzzy
msgid "Projection of input dataset and current location appear to match"
msgstr ""
-"La projection des données en entrée et le Secteur (location) courant "
-"semblent correspondre.\n"
+"La projection des données en entrée et le Secteur (location) courant semblent correspondre.\n"
"Poursuite de la procédure d'importation...\n"
#: ../raster/r.external/main.c:202
#, fuzzy
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
-msgstr ""
-"La carte raster en entrée est pivotée - importation impossible. Vous pouvez "
-"utiliser 'gdalwarp' pour transformer la carte en \"North up\""
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "La carte raster en entrée est pivotée - importation impossible. Vous pouvez utiliser 'gdalwarp' pour transformer la carte en \"North up\""
#: ../raster/r.external/main.c:264 ../raster/r.in.gdal/main.c:633
#: ../vector/v.in.ogr/main.c:1263
@@ -2617,12 +2504,8 @@
#: ../raster/r.bilinear/main.c:54 ../raster/r.bilinear/main.c:61
#, fuzzy
-msgid ""
-"Specific input value to be assigned to the north and/or south poles for "
-"longitude-latitude grids"
-msgstr ""
-"valeurs spécifiques qui seront assignées aux pôles nord et/ou sud pour des "
-"grilles données en latitude-longitude"
+msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
+msgstr "valeurs spécifiques qui seront assignées aux pôles nord et/ou sud pour des grilles données en latitude-longitude"
#: ../raster/r.bilinear/main.c:67
msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
@@ -2643,12 +2526,8 @@
msgstr ""
#: ../raster/r.mode/main.c:52
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"Trouve la mode des valeurs d'une couche de couverture pour les zones "
-"définies par les catégories d'une couche de base."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Trouve la mode des valeurs d'une couche de couverture pour les zones définies par les catégories d'une couche de base."
#: ../raster/r.mode/main.c:58
msgid "Base map to be reclassified"
@@ -2694,14 +2573,11 @@
#: ../raster/r.profile/main.c:55
msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Sort les valeurs de la couche raster à partir de ligne(s) définies par "
-"l'utilisateur"
+msgstr "Sort les valeurs de la couche raster à partir de ligne(s) définies par l'utilisateur"
#: ../raster/r.profile/main.c:66
msgid "Name of file for output (use output=- for stdout)"
-msgstr ""
-"Nom du fichier en sortie (utilisez output=- pour le flux de sortie stdout)"
+msgstr "Nom du fichier en sortie (utilisez output=- pour le flux de sortie stdout)"
#: ../raster/r.profile/main.c:74
#, fuzzy
@@ -2710,9 +2586,7 @@
#: ../raster/r.profile/main.c:81
msgid "Resolution along profile (default = current region resolution)"
-msgstr ""
-"Résolution utilisée pour le profil (par défaut = la résolution de la région "
-"courante)"
+msgstr "Résolution utilisée pour le profil (par défaut = la résolution de la région courante)"
#: ../raster/r.profile/main.c:88
msgid "Character to represent no data cell"
@@ -2720,14 +2594,11 @@
#: ../raster/r.profile/main.c:92
msgid "Interactively select End-Points"
-msgstr ""
-"Sélectionner de façon interactive les points de début et de fin du profil"
+msgstr "Sélectionner de façon interactive les points de début et de fin du profil"
#: ../raster/r.profile/main.c:97 ../raster/r.transect/main.c:97
msgid "Output easting and northing in first two columns of four column output"
-msgstr ""
-"Sortie X et Y dans les deux premières colonnes d'un tableau de sortie à "
-"quatre colonnes"
+msgstr "Sortie X et Y dans les deux premières colonnes d'un tableau de sortie à quatre colonnes"
#: ../raster/r.profile/main.c:102
msgid "Output RRR:GGG:BBB color values for each profile point"
@@ -2842,23 +2713,8 @@
msgstr ""
#: ../raster/r.sun2/main.c:230 ../raster/r.sun/main.c:176
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
-msgstr ""
-"Calcule des couches de rayonnement solaire direct (beam), diffus et réfléchi "
-"pour un jour donné, une latitude; des propriétés de surface et des "
-"conditions atmosphériques. Les paramètres solaires (par exemple, le lever du "
-"soleil, le coucher du soleil, la déclinaison, les radiations extra-"
-"terrestres, la durée du jour) sont sauvegardées dans un fichier texte local. "
-"Sinon, une heure locale peut être indiquée pour calculer des angles "
-"d'incidence ou d'irradiance du rayonnement solaire. Les effets d'ombres "
-"portées par la topographie peuvent être pris en compte de façon optionnelle."
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr "Calcule des couches de rayonnement solaire direct (beam), diffus et réfléchi pour un jour donné, une latitude; des propriétés de surface et des conditions atmosphériques. Les paramètres solaires (par exemple, le lever du soleil, le coucher du soleil, la déclinaison, les radiations extra-terrestres, la durée du jour) sont sauvegardées dans un fichier texte local. Sinon, une heure locale peut être indiquée pour calculer des angles d'incidence ou d'irradiance du rayonnement solaire. Les effets d'ombres portées par la topographie peuvent être pris en compte de façon optionnelle."
#: ../raster/r.sun2/main.c:244 ../raster/r.sun/main.c:206
#: ../raster/r.horizon/main.c:225
@@ -2887,35 +2743,24 @@
msgstr ""
#: ../raster/r.sun2/main.c:253 ../raster/r.sun/main.c:215
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
-msgstr ""
-"Nom de la couche d'aspect source (aspect du terrain ou azimut du panneau "
-"solaire) [degrés décimaux]"
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
+msgstr "Nom de la couche d'aspect source (aspect du terrain ou azimut du panneau solaire) [degrés décimaux]"
#: ../raster/r.sun2/main.c:262
msgid "A single value of the orientation (aspect), 270 is south"
msgstr ""
#: ../raster/r.sun2/main.c:271 ../raster/r.sun/main.c:225
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
-msgstr ""
-"Nom de la couche raster source de pente (pente du terrain ou inclinaison du "
-"panneau solaire) [degrés décimaux]"
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
+msgstr "Nom de la couche raster source de pente (pente du terrain ou inclinaison du panneau solaire) [degrés décimaux]"
#: ../raster/r.sun2/main.c:279
msgid "A single value of inclination (slope)"
msgstr ""
#: ../raster/r.sun2/main.c:288 ../raster/r.sun/main.c:234
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr ""
-"Nom de la couche raster source pour le coefficient atmosphérique d'opacité "
-"de Linke"
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr "Nom de la couche raster source pour le coefficient atmosphérique d'opacité de Linke"
#: ../raster/r.sun2/main.c:298 ../raster/r.sun/main.c:245
msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
@@ -2940,15 +2785,12 @@
#: ../raster/r.sun2/main.c:346
#, fuzzy
-msgid ""
-"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
-"[0-1]"
+msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
msgstr "Couche raster du coefficient de rayonnement en plein ciel [-]"
#: ../raster/r.sun2/main.c:355
#, fuzzy
-msgid ""
-"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
msgstr "Couche raster du coefficient de rayonnement diffus en plein ciel [-]"
#: ../raster/r.sun2/main.c:363
@@ -2982,43 +2824,25 @@
msgstr ""
#: ../raster/r.sun2/main.c:389 ../raster/r.sun/main.c:320
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Fichier raster en sortie pour le rayonnement solaire [W.m-2] (mode 1) ou "
-"l'irradiation [Wh.m-2.day-1] (mode 2)"
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Fichier raster en sortie pour le rayonnement solaire [W.m-2] (mode 1) ou l'irradiation [Wh.m-2.day-1] (mode 2)"
#: ../raster/r.sun2/main.c:398 ../raster/r.sun/main.c:329
msgid "Output insolation time raster map [h] (mode 2 only)"
-msgstr ""
-"Couche raster en sortie pour la durée d'ensoleillement [h] (mode 2 "
-"uniquement)"
+msgstr "Couche raster en sortie pour la durée d'ensoleillement [h] (mode 2 uniquement)"
#: ../raster/r.sun2/main.c:407 ../raster/r.sun/main.c:338
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Couche raster en sortie pour le rayonnement diffus [W.m-2] (mode 1) ou "
-"l'irradiation diffuse [Wh.m-2.day-1] (mode 2)"
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Couche raster en sortie pour le rayonnement diffus [W.m-2] (mode 1) ou l'irradiation diffuse [Wh.m-2.day-1] (mode 2)"
#: ../raster/r.sun2/main.c:416 ../raster/r.sun/main.c:347
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Couche raster en sortie pour le rayonnement réfléchi [W.m-2] (mode 1) ou "
-"l'irradiation réfléchie [Wh.m-2.day-1] (mode 2)"
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Couche raster en sortie pour le rayonnement réfléchi [W.m-2] (mode 1) ou l'irradiation réfléchie [Wh.m-2.day-1] (mode 2)"
#: ../raster/r.sun2/main.c:425
#, fuzzy
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
-"irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
#: ../raster/r.sun2/main.c:432 ../raster/r.sun/main.c:354
msgid "No. of day of the year (1-365)"
@@ -3026,21 +2850,15 @@
#: ../raster/r.sun2/main.c:441 ../raster/r.sun/main.c:362
msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr ""
-"Pas temporel pour calculer le rayonnement total sur une journée [heures "
-"décimales]"
+msgstr "Pas temporel pour calculer le rayonnement total sur une journée [heures décimales]"
#: ../raster/r.sun2/main.c:448 ../raster/r.sun/main.c:369
msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr ""
-"Valeur de la déclinaison (écrase la valeur calculée de façon interne) "
-"[radians]"
+msgstr "Valeur de la déclinaison (écrase la valeur calculée de façon interne) [radians]"
#: ../raster/r.sun2/main.c:456 ../raster/r.sun/main.c:377
msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
-msgstr ""
-"Temps (solaire) local (à indiquer pour le mode 1 seulement) [heures "
-"décimales]"
+msgstr "Temps (solaire) local (à indiquer pour le mode 1 seulement) [heures décimales]"
#: ../raster/r.sun2/main.c:479 ../raster/r.horizon/main.c:317
msgid "Sampling distance step coefficient (0.5-1.5)"
@@ -3113,11 +2931,8 @@
msgstr "%s = %s -- doit être supérieur à zéro"
#: ../raster/r.sun2/main.c:610
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr ""
-"Si vous utilisez l'option horizon vous devez aussi fournir le paramètre "
-"'horizonstep'"
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
+msgstr "Si vous utilisez l'option horizon vous devez aussi fournir le paramètre 'horizonstep'"
#: ../raster/r.sun2/main.c:616
#, fuzzy
@@ -3126,12 +2941,8 @@
#: ../raster/r.sun2/main.c:618
#, fuzzy
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
-msgstr ""
-"Mode 1 : angle d'incidence solaire instantanné & irradiance pour une heure "
-"locale donnée"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
+msgstr "Mode 1 : angle d'incidence solaire instantanné & irradiance pour une heure locale donnée"
#: ../raster/r.sun2/main.c:623 ../raster/r.sun/main.c:422
msgid "incidout requires time parameter to be set"
@@ -3146,29 +2957,21 @@
msgstr ""
#: ../raster/r.sun2/main.c:683
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
-msgstr ""
-"Si vous souhaitez économiser de la mémoire et utiliser les ombres, vous "
-"devez utiliser des horizons pré-calculés."
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
+msgstr "Si vous souhaitez économiser de la mémoire et utiliser les ombres, vous devez utiliser des horizons pré-calculés."
#: ../raster/r.sun2/main.c:728 ../display/d.where/main.c:93
#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
#: ../general/g.region/printwindow.c:622
msgid "Can't get projection info of current location"
-msgstr ""
-"Impossible d'obtenir les informations de projection pour le Secteur "
-"(location) courant"
+msgstr "Impossible d'obtenir les informations de projection pour le Secteur (location) courant"
#: ../raster/r.sun2/main.c:732 ../raster/r.sun/main.c:475
#: ../raster/r.horizon/main.c:475 ../display/d.where/main.c:96
#: ../general/g.region/printwindow.c:250 ../general/g.region/printwindow.c:506
#: ../general/g.region/printwindow.c:625
msgid "Can't get projection units of current location"
-msgstr ""
-"Impossible d'obtenir les unités de projection pour le Secteur (location) "
-"courant"
+msgstr "Impossible d'obtenir les unités de projection pour le Secteur (location) courant"
#: ../raster/r.sun2/main.c:736 ../raster/r.sun/main.c:479
#: ../raster/r.horizon/main.c:479 ../ps/ps.map/do_geogrid.c:271
@@ -3176,9 +2979,7 @@
#: ../general/g.region/printwindow.c:253 ../general/g.region/printwindow.c:509
#: ../general/g.region/printwindow.c:628
msgid "Can't get projection key values of current location"
-msgstr ""
-"Impossible d'obtenir les valeurs clefs de projection pour le Secteur "
+msgstr "Impossible d'obtenir les valeurs clefs de projection pour le Secteur (location) courant"
#: ../raster/r.sun2/main.c:746 ../raster/r.sun/main.c:489
#: ../raster/r.horizon/main.c:489 ../ps/ps.map/do_geogrid.c:277
@@ -3238,8 +3039,7 @@
msgid "SECTION 1b (of %1d): Determining Offmap Flow."
msgstr ""
"\n"
-"SECTION 1b (de %1d): Détermination du courant hors carte. Achevé "
-"(pourcentage): "
+"SECTION 1b (de %1d): Détermination du courant hors carte. Achevé (pourcentage): "
#: ../raster/r.watershed/ram/sg_factor.c:13
#: ../raster/r.watershed/seg/sg_factor.c:12
@@ -3306,40 +3106,22 @@
#, c-format
msgid ""
"USAGE for basin delineation:\n"
-"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
-"[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
"\n"
"USAGE for ARMSED FILE creation:\n"
-"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
-"ha=half_basin_map ar=ARMSED_file_name\n"
+"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
"\n"
"USAGE for slope length determination:\n"
-"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
-"[de=depression_map] [ac=accumulation_map] [di=display_map] "
-"[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
-"LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
+"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
msgstr ""
"USAGE pour la délimitation du bassin versant:\n"
-"%s -4 el=couche_altitude t=seuil_depression_marecageuse [ov=couche_courants] "
-"[dr=couche_direction_drainage] [de=couche_depression] "
-"[ac=couche_accumulation] [di=couche_affichage] ba=couche_bassin_versant "
-"[se=couche_segment_cours_d_eau]\n"
+"%s -4 el=couche_altitude t=seuil_depression_marecageuse [ov=couche_courants] [dr=couche_direction_drainage] [de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] ba=couche_bassin_versant [se=couche_segment_cours_d_eau]\n"
"\n"
"USAGE pour la création du fichier ARMSED:\n"
-"%s [-4] el=couche_altitude t=seuil_depression_marecageuse "
-"[ov=couche_courants] [dr=couche_direction_drainage] [de=couche_depression] "
-"[ac=couche_accumulation] [di=couche_affichage] [ba=couche_bassin_versant] "
-"[se=couche_segment_cours_d_eau] ha=couche_demi_bassin ar=nom_fichier_ARMSED\n"
+"%s [-4] el=couche_altitude t=seuil_depression_marecageuse [ov=couche_courants] [dr=couche_direction_drainage] [de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] [ba=couche_bassin_versant] [se=couche_segment_cours_d_eau] ha=couche_demi_bassin ar=nom_fichier_ARMSED\n"
"\n"
"USAGE pour la détermination de longueur de pentes:\n"
-"[ac=couche_accumulation] [di=couche_affichage] [ms=longueur_max_pente] "
-"[ob=couche_obstacles] [S=couche_escarpement_pente] LS=couche_longueur_pentes "
-"[r=couche_erosion_ruissellement] [sd=depot_pente valeur ou couche]"
+"%s [-4] el=couche_altitude t=seuil_depression_marecageuse [dr=couche_direction_drainage] [de=couche_depression] [ac=couche_accumulation] [di=couche_affichage] [ms=longueur_max_pente] [ob=couche_obstacles] [S=couche_escarpement_pente] LS=couche_longueur_pentes [r=couche_erosion_ruissellement] [sd=depot_pente valeur ou couche]"
#: ../raster/r.watershed/ram/close_maps.c:30
#: ../raster/r.watershed/ram/close_maps.c:165
@@ -3384,11 +3166,8 @@
"SECTION 1 démarrage: initialisation des variables. %d du total des sections."
#: ../raster/r.watershed/seg/init_vars.c:150
-msgid ""
-"Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
-msgstr ""
-"La mémoire maximale allouée était inférieure à 3 MB, fixée par défaut à 300 "
-"MB."
+msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
+msgstr "La mémoire maximale allouée était inférieure à 3 MB, fixée par défaut à 300 MB."
#: ../raster/r.watershed/seg/close_maps.c:52
#, fuzzy
@@ -3420,13 +3199,11 @@
#: ../raster/r.watershed/shed/com_line.c:30
msgid "in the fast mode, the computer will finish about 10 times faster"
-msgstr ""
-"En mode express, l'ordinateur bouclera l'exécution environ 10 fois plus vite"
+msgstr "En mode express, l'ordinateur bouclera l'exécution environ 10 fois plus vite"
#: ../raster/r.watershed/shed/com_line.c:31
msgid "than in the slow mode, but will not allow other programs to run"
-msgstr ""
-"qu'en mode lent, mais il ne permettra pas l'exécution d'autres programmes"
+msgstr "qu'en mode lent, mais il ne permettra pas l'exécution d'autres programmes"
#: ../raster/r.watershed/shed/com_line.c:32
msgid "at the same time. The fast mode also places all of the data into"
@@ -3434,26 +3211,19 @@
#: ../raster/r.watershed/shed/com_line.c:33
msgid "RAM, which limits the size of window that can be run. The slow"
-msgstr ""
-"RAM, ce qui limite la taille de la fenêtre que l'on peut utiliser. Le mode "
-"lent"
+msgstr "RAM, ce qui limite la taille de la fenêtre que l'on peut utiliser. Le mode lent"
#: ../raster/r.watershed/shed/com_line.c:34
msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr ""
-"utilise l'espace disque sur la même partition du disque dur que celle où "
-"GRASS est"
+msgstr "utilise l'espace disque sur la même partition du disque dur que celle où GRASS est"
#: ../raster/r.watershed/shed/com_line.c:35
msgid "stored. Thus, if the program does not work in the slow mode, you will"
-msgstr ""
-"installé. Par conséquent, si le programme ne fonctionne pas bien en mode "
-"lent, vous devrez"
+msgstr "installé. Par conséquent, si le programme ne fonctionne pas bien en mode lent, vous devrez"
#: ../raster/r.watershed/shed/com_line.c:36
msgid "need to remove unnecessary files from that partition. The slow mode"
-msgstr ""
-"enlever tous les fichiers superflus stockés sur cette partition. Le mode lent"
+msgstr "enlever tous les fichiers superflus stockés sur cette partition. Le mode lent"
#: ../raster/r.watershed/shed/com_line.c:37
#, c-format
@@ -3485,41 +3255,28 @@
"Une des options de %s est une cartes de dépressions. Une"
#: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
-msgstr ""
-"carte de dépressions indique tous les endroits dans la fenêtre courante où"
+msgid "depression map indicates all the locations in the current map window where"
+msgstr "carte de dépressions indique tous les endroits dans la fenêtre courante où"
#: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
-msgstr ""
-"l'eau s'accumule et n'est pas draînée sur un des bords de la carte. Les lacs "
-"sans"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
+msgstr "l'eau s'accumule et n'est pas draînée sur un des bords de la carte. Les lacs sans"
#: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'. If you wish to"
-msgstr ""
-"cours d'eau de sortie ni drainage souterrain sont des exemples de "
-"'dépressions'. Si vous souhaitez"
+msgid "outlet streams and sinkholes are examples of `depressions'. If you wish to"
+msgstr "cours d'eau de sortie ni drainage souterrain sont des exemples de 'dépressions'. Si vous souhaitez"
#: ../raster/r.watershed/shed/com_line.c:86
msgid "have a depression map, prepare a map where non-zero values indicate the"
-msgstr ""
-"construire une carte de dépressions, préparez une carte où les valeurs non "
-"nulles indiquent les"
+msgstr "construire une carte de dépressions, préparez une carte où les valeurs non nulles indiquent les"
#: ../raster/r.watershed/shed/com_line.c:87
msgid "locations where depressions occur.\n"
msgstr "emplacement des dépressions réelles.\n"
#: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
-msgstr ""
-"Tapez juste <entrée> pour la question suivante s'il n'y a pas de carte de "
-"dépressions."
+msgid "Hit <return> by itself for the next question if there is no depression map."
+msgstr "Tapez juste <entrée> pour la question suivante s'il n'y a pas de carte de dépressions."
#: ../raster/r.watershed/shed/com_line.c:99
#, c-format
@@ -3531,81 +3288,50 @@
"Le programme %s divisera la couche de relief en une série de"
#: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins. The number of watershed basins is indirectly determined"
-msgstr ""
-"bassins versants. Le nombre de bassins versants est déterminé de façon "
-"indirecte"
+msgid "watershed basins. The number of watershed basins is indirectly determined"
+msgstr "bassins versants. Le nombre de bassins versants est déterminé de façon indirecte"
#: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value. The basin threshold is the area necessary "
-"for"
-msgstr ""
-"par la valeur de `seuil de bassin'. Le seuil de bassin correspond à la "
-"valeur nécessaire pour"
+msgid "by the `basin threshold' value. The basin threshold is the area necessary for"
+msgstr "par la valeur de `seuil de bassin'. Le seuil de bassin correspond à la valeur nécessaire pour"
#: ../raster/r.watershed/shed/com_line.c:103
#, c-format
msgid "%s to define a unique watershed basin. This area only applies to"
-msgstr ""
-"que %s définisse un unique bassin versant. Cette zone s'applique uniquement "
-"aux"
+msgstr "que %s définisse un unique bassin versant. Cette zone s'applique uniquement aux"
#: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'. An exterior drainage basin does not have any"
-msgstr ""
-"'bassins de drainage exogènes'. Un bassin de drainage exogène ne possède "
-"aucun autre"
+msgid "`exterior drainage basins'. An exterior drainage basin does not have any"
+msgstr "'bassins de drainage exogènes'. Un bassin de drainage exogène ne possède aucun autre"
#: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it. Interior drainage basin size is determined"
-msgstr ""
-"bassin de drainage interconnecté avec lui. La taille d'un bassin de drainage "
-"intérieur est déterminée"
+msgid "drainage basins flowing into it. Interior drainage basin size is determined"
+msgstr "bassin de drainage interconnecté avec lui. La taille d'un bassin de drainage intérieur est déterminée"
#: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
-msgstr ""
-"par le courant de surface dans les tronçons de cours d'eau entre les "
-"confluences."
+msgid "by the surface flow going into stream segments between stream interceptions."
+msgstr "par le courant de surface dans les tronçons de cours d'eau entre les confluences."
#: ../raster/r.watershed/shed/com_line.c:108
#, c-format
msgid "Thus interior drainage basins can be of any size. The %s program"
-msgstr ""
-"Par conséquent, les bassins de drainage peuvent être de taille quelconque. "
-"Le programme %s"
+msgstr "Par conséquent, les bassins de drainage peuvent être de taille quelconque. Le programme %s"
#: ../raster/r.watershed/shed/com_line.c:110
msgid "also allows the user to relate basin size to potential overland flow"
-msgstr ""
-"permet aussi à l'utilisateur de mette en relation la taille du bassin au "
-"courant terrestre potentiel"
+msgstr "permet aussi à l'utilisateur de mette en relation la taille du bassin au courant terrestre potentiel"
#: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
-msgstr ""
-"(i.e., les zones avec de faibles capacités d'infiltration auront besoin de "
-"zones plus petites pour"
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
+msgstr "(i.e., les zones avec de faibles capacités d'infiltration auront besoin de zones plus petites pour"
#: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration rates)."
-msgstr ""
-"développer des cours d'eau que les zones voisines possédant des taux élevés "
-"d'infiltration)."
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
+msgstr "développer des cours d'eau que les zones voisines possédant des taux élevés d'infiltration)."
#: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
-msgstr ""
-"L'utilisateur peut créer une couche avec des valeurs de courant "
-"potentielles, et"
+msgid "The user can create a map layer with potential overland flow values, and"
+msgstr "L'utilisateur peut créer une couche avec des valeurs de courant potentielles, et"
#: ../raster/r.watershed/shed/com_line.c:114
#, c-format
@@ -3635,8 +3361,7 @@
"How large an area (or how many overland flow units) must a drainage basin"
msgstr ""
"\n"
-"De quelle dimension (ou de combien d'unités de débit) doit être un bassin de "
-"drainage"
+"De quelle dimension (ou de combien d'unités de débit) doit être un bassin de drainage"
#: ../raster/r.watershed/shed/com_line.c:132
#, c-format
@@ -3725,8 +3450,7 @@
msgstr "une représentation de la couche d'accumulation). %s peut aussi"
#: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
msgstr "générer différentes variables dans le Revised Universal Soil Loss"
#: ../raster/r.watershed/shed/com_line.c:297
@@ -3744,22 +3468,15 @@
#: ../raster/r.watershed/shed/com_line.c:349
#, c-format
msgid "disturbed land. %s reflects this with an optional map layer or value"
-msgstr ""
-"un terrain accidenté. %s tient compte de cela grâce à une couche optionnelle "
-"ou une valeur"
+msgstr "un terrain accidenté. %s tient compte de cela grâce à une couche optionnelle ou une valeur"
#: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
-msgstr ""
-"dans laquelle la valeur indique le pourcentage de terrain accidenté à "
-"l'intérieur de cette cellule."
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
+msgstr "dans laquelle la valeur indique le pourcentage de terrain accidenté à l'intérieur de cette cellule."
#: ../raster/r.watershed/shed/com_line.c:352
msgid "Type <return> if you do not have a disturbed land map layer."
-msgstr ""
-"Tapez <entrée> si vous ne disposez pas d'une couche montrant la topographie"
+msgstr "Tapez <entrée> si vous ne disposez pas d'une couche montrant la topographie"
#: ../raster/r.watershed/shed/com_line.c:364
msgid ""
@@ -3767,8 +3484,7 @@
"Type the value indicating the percent of disturbed land. This value will"
msgstr ""
"\n"
-"Tapez la valeur indiquant le pourcentage de terrain accidenté. Cette valeur "
-"va"
+"Tapez la valeur indiquant le pourcentage de terrain accidenté. Cette valeur va"
#: ../raster/r.watershed/shed/com_line.c:365
msgid "be used for every cell in the current region."
@@ -3789,32 +3505,25 @@
"Overland surface flow only occurs for a set distance before swales form."
msgstr ""
"\n"
-"Le courant de surface ne parcourt qu'une distance définie avant que ne se "
-"forment des dépressions marécageuses."
+"Le courant de surface ne parcourt qu'une distance définie avant que ne se forment des dépressions marécageuses."
#: ../raster/r.watershed/shed/com_line.c:380
#, c-format
msgid "Because of digital terrain model limitations, %s cannot pick up"
-msgstr ""
-"A cause d'insuffisances du Modèle Numérique de Terrain, %s ne peut distinguer"
+msgstr "A cause d'insuffisances du Modèle Numérique de Terrain, %s ne peut distinguer"
#: ../raster/r.watershed/shed/com_line.c:382
#, c-format
msgid "these swales. %s allows for an input (warning: kludge factor)"
-msgstr ""
-"ces dépressions marécageuses. %s permet d'ajouter une entrée (attention : "
-"facteur kludge)"
+msgstr "ces dépressions marécageuses. %s permet d'ajouter une entrée (attention : facteur kludge)"
#: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long. Normally,"
+msgid "that prevents the surface flow distance from getting too long. Normally,"
msgstr "qui empêche le parcours du courant d'être trop long. Normalement,"
#: ../raster/r.watershed/shed/com_line.c:385
msgid "maximum slope length is around 600 feet (about 183 meters)."
-msgstr ""
-"la longueur maximale de la pente est d'environ 600 pieds (soit à peu près "
-"183 mètres)."
+msgstr "la longueur maximale de la pente est d'environ 600 pieds (soit à peu près 183 mètres)."
#: ../raster/r.watershed/shed/com_line.c:400
msgid ""
@@ -3822,26 +3531,19 @@
"Roads, ditches, changes in ground cover, and other factors will stop"
msgstr ""
"\n"
-"Les routes, fossés, changements dans la couverture végétale, et d'autres "
-"facteurs vont interrompre"
+"Les routes, fossés, changements dans la couverture végétale, et d'autres facteurs vont interrompre"
#: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length. You may input a raster map indicating the locations of these"
-msgstr ""
-"la pente. Vous pouvez inclure une couche raster contenant les emplacements "
-"de ces"
+msgid "slope length. You may input a raster map indicating the locations of these"
+msgstr "la pente. Vous pouvez inclure une couche raster contenant les emplacements de ces"
#: ../raster/r.watershed/shed/com_line.c:402
msgid "blocking factors.\n"
msgstr "différents facteurs d'interruption.\n"
#: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
-msgstr ""
-"Tapez juste <entrée> à la question suivante s'il n'y a pas de couche "
-"contenant des éléments d'interruption de pente."
+msgid "Hit <return> by itself for the next question if there is no blocking map."
+msgstr "Tapez juste <entrée> à la question suivante s'il n'y a pas de couche contenant des éléments d'interruption de pente."
#: ../raster/r.watershed/shed/basin_maps.c:12
msgid ""
@@ -3855,20 +3557,16 @@
#: ../raster/r.watershed/shed/basin_maps.c:13
msgid "parameter hydrologic/soil erosion model. Continue inputing cell map"
-msgstr ""
-"dans le modèle d'érosion sols/hydrologie. Poursuivez le chargement de "
-"couches raster"
+msgstr "dans le modèle d'érosion sols/hydrologie. Poursuivez le chargement de couches raster"
#: ../raster/r.watershed/shed/basin_maps.c:14
msgid "layers, one at a time, until all desired map layers are in."
-msgstr ""
-"une par une, jusqu'à ce que toutes les couches nécessaires soient chargées."
+msgstr "une par une, jusqu'à ce que toutes les couches nécessaires soient chargées."
#: ../raster/r.watershed/shed/basin_maps.c:15
#, c-format
msgid "You can have %s include a list of categories in each."
-msgstr ""
-"%s peut vous fournir une liste des catégories de chacune d'entre elles."
+msgstr "%s peut vous fournir une liste des catégories de chacune d'entre elles."
#: ../raster/r.watershed/shed/basin_maps.c:17
#, c-format
@@ -3890,15 +3588,11 @@
#: ../raster/r.watershed/shed/basin_maps.c:38
msgid "basins. There are two possible methods of tabulating the information:"
-msgstr ""
-"bassins versants. Il existe deux méthodes possibles de mise en table de "
-"l'information :"
+msgstr "bassins versants. Il existe deux méthodes possibles de mise en table de l'information :"
#: ../raster/r.watershed/shed/basin_maps.c:39
msgid "1) by only including data pertaining to the basin itself, or 2) using"
-msgstr ""
-"1) en incluant seulement les données appartenant au bassin lui-même, ou 2) "
-"en utilisant"
+msgstr "1) en incluant seulement les données appartenant au bassin lui-même, ou 2) en utilisant"
#: ../raster/r.watershed/shed/basin_maps.c:40
msgid "data from the basin, and all basins upstream of it."
@@ -3957,9 +3651,7 @@
#: ../raster/r.watershed/shed/intro.c:10
#, c-format
msgid "%s also allows the user to prepare a report of map layers for each"
-msgstr ""
-"%s permet aussi à l'utilisateur de préparer un rapport sous forme de couches "
-"de données pour chaque"
+msgstr "%s permet aussi à l'utilisateur de préparer un rapport sous forme de couches de données pour chaque"
#: ../raster/r.watershed/shed/intro.c:12
#, c-format
@@ -3974,8 +3666,7 @@
#: ../raster/r.watershed/shed/intro.c:16
#, c-format
msgid "%s program. %s will then ask for map layers that will be"
-msgstr ""
-"programme %s. %s demandera alors les couches de données qui seront affectées"
+msgstr "programme %s. %s demandera alors les couches de données qui seront affectées"
#: ../raster/r.watershed/shed/intro.c:18
#, c-format
@@ -3997,8 +3688,7 @@
#: ../raster/r.watershed/shed/main.c:41
msgid "Slow version of water analysis program starting now"
-msgstr ""
-"Début de l'exécution du programme d'analyse hydrologique en version lente"
+msgstr "Début de l'exécution du programme d'analyse hydrologique en version lente"
#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
#, c-format
@@ -4061,8 +3751,7 @@
msgstr "couche d'entrée : terrain bloquant l'écoulement de surface, pour USLE"
#: ../raster/r.watershed/front/main.c:88
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
msgstr ""
#: ../raster/r.watershed/front/main.c:94
@@ -4077,8 +3766,7 @@
#: ../raster/r.watershed/front/main.c:95
#, fuzzy
msgid "Number of cells that drain through each cell"
-msgstr ""
-"Couche de sortie : nombre de cellules qui s'écoulent dans d'autres cellules"
+msgstr "Couche de sortie : nombre de cellules qui s'écoulent dans d'autres cellules"
#: ../raster/r.watershed/front/main.c:97
#: ../raster/r.watershed/front/main.c:103
@@ -4146,8 +3834,7 @@
#: ../raster/r.watershed/front/main.c:129
#, fuzzy
-msgid ""
-"Name for output raster map useful for visual display of results (DEPRECATED)"
+msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
msgstr "Couche de sortie : pratique pour visualiser les résultats"
#: ../raster/r.watershed/front/main.c:135
@@ -4162,9 +3849,7 @@
#: ../raster/r.watershed/front/main.c:137
#, fuzzy
msgid "Slope length and steepness (LS) factor for USLE"
-msgstr ""
-"Couche de sortie : facteur de longueur de la pente et d'escarpement (LS) "
-"pour USLE"
+msgstr "Couche de sortie : facteur de longueur de la pente et d'escarpement (LS) pour USLE"
#: ../raster/r.watershed/front/main.c:143
#, fuzzy
@@ -4220,24 +3905,16 @@
msgstr "Activer l'option de mémoire étendue : le calcul est lent"
#: ../raster/r.watershed/front/main.c:197
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
-msgstr ""
-"Seulement nécessaire si les besoins de mémoire excèdent la RAM disponible ; "
-"voir le manuel pour calculer les besoins mémoire"
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
+msgstr "Seulement nécessaire si les besoins de mémoire excèdent la RAM disponible ; voir le manuel pour calculer les besoins mémoire"
#: ../raster/r.watershed/front/main.c:202
msgid "Use positive flow accumulation even for likely underestimates"
-msgstr ""
-"Utiliser une accumulation d'écoulement positive même pour les sous-"
-"estimations manifestes"
+msgstr "Utiliser une accumulation d'écoulement positive même pour les sous-estimations manifestes"
#: ../raster/r.watershed/front/main.c:204
msgid "See manual for a detailed description of flow accumulation output"
-msgstr ""
-"Voir le manuel pour une description détaillée de la sortie d'accumulation "
-"d'écoulement"
+msgstr "Voir le manuel pour une description détaillée de la sortie d'accumulation d'écoulement"
#: ../raster/r.watershed/front/main.c:221
#, fuzzy
@@ -4255,8 +3932,7 @@
msgstr ""
"\n"
"Désolé, si aucune des options suivantes n'est fixée:\n"
-"\tbasin (bassin), stream (courant), half.basin (demi-bassin), slope (pente), "
-"ou 1s\n"
+"\tbasin (bassin), stream (courant), half.basin (demi-bassin), slope (pente), ou 1s\n"
"\tvous DEVEZ fournir une valeur pour le seuil du bassin (basin.threshold)."
#: ../raster/r.watershed/front/main.c:392
@@ -4313,9 +3989,7 @@
msgstr ""
#: ../raster/r.drain/main.c:131
-msgid ""
-"Output drain vector map (recommended for cost surface made using knight's "
-"move)"
+msgid "Output drain vector map (recommended for cost surface made using knight's move)"
msgstr ""
#: ../raster/r.drain/main.c:139
@@ -4347,9 +4021,7 @@
msgstr "Compter le nombre de cellules traversées"
#: ../raster/r.drain/main.c:163
-msgid ""
-"The input surface is a cost surface (if checked, a direction surface must "
-"also be specified"
+msgid "The input surface is a cost surface (if checked, a direction surface must also be specified"
msgstr ""
#: ../raster/r.drain/main.c:175
@@ -4361,9 +4033,7 @@
msgstr ""
#: ../raster/r.drain/main.c:184
-msgid ""
-"Direction raster not specified, if direction flag is on, a direction raster "
-"must be given"
+msgid "Direction raster not specified, if direction flag is on, a direction raster must be given"
msgstr ""
# c-format
@@ -4408,9 +4078,7 @@
#: ../raster/r.drain/main.c:316
#, fuzzy, c-format
msgid "Starting vector map <%s> contains no points in the current region"
-msgstr ""
-"La couche vectorielle de départ %s ne contient aucun point dans la région "
-"courante"
+msgstr "La couche vectorielle de départ %s ne contient aucun point dans la région courante"
#: ../raster/r.drain/main.c:322
msgid "No start/stop point(s) specified"
@@ -4482,14 +4150,8 @@
#: ../raster/r.param.scale/interface.c:56
#, fuzzy
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
-msgstr ""
-"Extrait les paramètres de terrain d'un Modèle Numérique d'Elévation (MNE). "
-"Utilise une approche multi-échelle en prenant des paramètres quadratiques "
-"sur une fenêtre de dimensions quelconques (par la méthode des moindres "
-"carrés)"
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+msgstr "Extrait les paramètres de terrain d'un Modèle Numérique d'Elévation (MNE). Utilise une approche multi-échelle en prenant des paramètres quadratiques sur une fenêtre de dimensions quelconques (par la méthode des moindres carrés)"
#: ../raster/r.param.scale/interface.c:74
msgid "Output raster layer containing morphometric parameter"
@@ -4522,8 +4184,7 @@
#: ../raster/r.param.scale/interface.c:120
msgid "Constrain model through central window cell"
-msgstr ""
-"Contrainte du modèle pour la cellule centrale de la fenêtre de traitement"
+msgstr "Contrainte du modèle pour la cellule centrale de la fenêtre de traitement"
#: ../raster/r.param.scale/interface.c:163
#, fuzzy
@@ -4541,8 +4202,7 @@
#: ../raster/r.in.gridatb/main.c:43
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
-msgstr ""
-"Importer des fichiers GRIDATB.FOR (TOPMODEL) dans des couches raster GRASS"
+msgstr "Importer des fichiers GRIDATB.FOR (TOPMODEL) dans des couches raster GRASS"
#: ../raster/r.in.gridatb/main.c:47 ../raster/r.out.gridatb/main.c:57
msgid "GRIDATB i/o map file"
@@ -4628,15 +4288,12 @@
#: ../raster/r.support/modhead/modhead.c:86
#, c-format
msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-msgstr ""
-"[%s] est une reclassification de [%s] - impossible d'éditer l'en-tête! "
-"Exécutez r.support sur [%s]."
+msgstr "[%s] est une reclassification de [%s] - impossible d'éditer l'en-tête! Exécutez r.support sur [%s]."
#: ../raster/r.support/modhead/modhead.c:90
#, c-format
msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-msgstr ""
-"[%s] est une reclassification de [%s in %s] - impossible d'éditer l'en-tête!"
+msgstr "[%s] est une reclassification de [%s in %s] - impossible d'éditer l'en-tête!"
# c-format
#: ../raster/r.support/modhead/modhead.c:96
@@ -4713,12 +4370,8 @@
#: ../raster/r.support/modhead/modhead.c:271
#, c-format
-msgid ""
-"Header indicates %d row%s in the raster map, but the actual file format "
-"indicates %d row%s"
-msgstr ""
-"L'en-tête indique %d ligne%s dans le fichier de cellule, mais le format de "
-"fichier actuel indique %d ligne%s"
+msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
+msgstr "L'en-tête indique %d ligne%s dans le fichier de cellule, mais le format de fichier actuel indique %d ligne%s"
# c-format
#: ../raster/r.support/modhead/modhead.c:303
@@ -4755,9 +4408,7 @@
#: ../raster/r.support/modhead/ask_format.c:51
#, fuzzy, c-format
msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-msgstr ""
-"Lignes * colonnes * bits par cellule doivent être identique à la taille de "
-"fichier (%ld)"
+msgstr "Lignes * colonnes * bits par cellule doivent être identique à la taille de fichier (%ld)"
#: ../raster/r.support/modhead/ask_format.c:55
msgid "If you need help figuring them out, just hit ESC"
@@ -4838,9 +4489,7 @@
#: ../raster/r.support/front/front.c:55
msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"Permet la création et/ou la modification des fichiers de gestion des couches "
-"rasters"
+msgstr "Permet la création et/ou la modification des fichiers de gestion des couches rasters"
#: ../raster/r.support/front/front.c:65
#, fuzzy
@@ -4849,8 +4498,7 @@
#: ../raster/r.support/front/front.c:73
msgid "Text to append to the next line of the map's metadata file"
-msgstr ""
-"Texte à ajoute à la dernière ligne du fichier de métadonnées de la couche"
+msgstr "Texte à ajoute à la dernière ligne du fichier de métadonnées de la couche"
#: ../raster/r.support/front/front.c:79
#, fuzzy
@@ -4947,22 +4595,18 @@
" it are treated by GRASS application programs as no data."
msgstr ""
"\n"
-"le fichier null de [%s] semble indiquer que certaines cellules ne "
-"contiennent\n"
-" pas de données. Si le fichier null de [%s] n'existe pas, les cellules de "
-"valeur zéro\n"
+"le fichier null de [%s] semble indiquer que certaines cellules ne contiennent\n"
+" pas de données. Si le fichier null de [%s] n'existe pas, les cellules de valeur zéro\n"
" sont traitées par les programmes GRASS comme sans données."
#: ../raster/r.support/front/front.c:308
#, c-format
msgid ""
"\n"
-"Do you want to create/reset the null file for [%s] so that null cell values "
-"are considered valid data? "
+"Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
msgstr ""
"\n"
-"Voulez-vous créer/réinitialiser le fichir null de [%s] pour que les cellules "
-"de valeur null soient considérées comme des données valides? "
+"Voulez-vous créer/réinitialiser le fichir null de [%s] pour que les cellules de valeur null soient considérées comme des données valides? "
#: ../raster/r.support/front/front.c:317 ../raster/r.support/front/front.c:354
#, c-format
@@ -5133,8 +4777,7 @@
#: ../raster/r.topmodel/main.c:120
#, fuzzy
msgid "Name of rainfall and potential evapotranspiration data file"
-msgstr ""
-"(i) Fichier de données de précipitations et d'évapo-transpiration prévue"
+msgstr "(i) Fichier de données de précipitations et d'évapo-transpiration prévue"
#: ../raster/r.topmodel/main.c:123 ../raster/r.out.mpeg/main.c:412
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:8
@@ -5169,12 +4812,8 @@
msgstr "%s : ÉTAPE 1..."
#: ../raster/r.cross/main.c:77
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-"Crée le produit cartésien des valeurs de catégorie de plusieurs couches "
-"raster."
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr "Crée le produit cartésien des valeurs de catégorie de plusieurs couches raster."
#: ../raster/r.cross/main.c:86
#, c-format
@@ -5209,12 +4848,8 @@
#: ../raster/r.neighbors/main.c:292 ../raster/r.texture/main.c:221
#: ../raster/r.covar/main.c:75 ../vector/v.mkgrid/main.c:141
#: ../vector/v.qcount/main.c:117
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"Le drapeau '-q' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--"
-"quiet' à la place."
+msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
+msgstr "Le drapeau '-q' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--quiet' à la place."
#: ../raster/r.cross/main.c:122
#, fuzzy, c-format
@@ -5258,8 +4893,7 @@
#: ../raster/r.distance/main.c:40
msgid "Locates the closest points between objects in two raster maps."
-msgstr ""
-"Trouve les points les plus proches entre objets dans deux couches raster"
+msgstr "Trouve les points les plus proches entre objets dans deux couches raster"
#: ../raster/r.distance/parse.c:41
msgid "Maps for computing inter-class distances"
@@ -5357,13 +4991,8 @@
msgstr "Importation vecteur complète"
#: ../raster/r.patch/main.c:55
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Crée une couche raster composite en utilisant des valeurs de catégories "
-"connues pour une (ou davantage) de couches raster afin de renseigner les "
-"zones de \"données nulles\" dans une autre couche raster"
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "Crée une couche raster composite en utilisant des valeurs de catégories connues pour une (ou davantage) de couches raster afin de renseigner les zones de \"données nulles\" dans une autre couche raster"
#: ../raster/r.patch/main.c:62
msgid "Name of raster maps to be patched together"
@@ -5375,8 +5004,7 @@
#: ../raster/r.patch/main.c:77
msgid "Use zero (0) for transparency instead of NULL"
-msgstr ""
-"Utiliser la valeur zéro (0) pour la transparence à la place de la valeur NULL"
+msgstr "Utiliser la valeur zéro (0) pour la transparence à la place de la valeur NULL"
#: ../raster/r.patch/main.c:102
#, fuzzy
@@ -5409,9 +5037,7 @@
#: ../raster/r.quant/main.c:43
#, fuzzy
msgid "Produces the quantization file for a floating-point map."
-msgstr ""
-"Cette routine produit un fichier de quantification pour une couche raster en "
-"virgule flottante."
+msgstr "Cette routine produit un fichier de quantification pour une couche raster en virgule flottante."
#: ../raster/r.quant/main.c:51
msgid "Base map to take quant rules from"
@@ -5533,14 +5159,8 @@
#: ../raster/r.cost/main.c:130
#, fuzzy
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Produit une couche raster montrant le coût cumulé d'un déplacement entre "
-"différentes positions géographiques à partir d'une couche raster où la "
-"valeur de catégorie des cellules représente le coût."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Produit une couche raster montrant le coût cumulé d'un déplacement entre différentes positions géographiques à partir d'une couche raster où la valeur de catégorie des cellules représente le coût."
#: ../raster/r.cost/main.c:137
msgid "Name of raster map containing grid cell cost information"
@@ -5592,8 +5212,7 @@
#: ../raster/r.cost/main.c:201 ../raster/r.walk/main.c:260
msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-"Coût assigné aux cellules vides. Par défaut, les cellules vides sont ignorées"
+msgstr "Coût assigné aux cellules vides. Par défaut, les cellules vides sont ignorées"
#: ../raster/r.cost/main.c:210 ../raster/r.walk/main.c:268
#: ../raster/r.in.xyz/main.c:235
@@ -5602,9 +5221,7 @@
#: ../raster/r.cost/main.c:215 ../raster/r.walk/main.c:310
msgid "Use the 'Knight's move'; slower, but more accurate"
-msgstr ""
-"Utiliser le \"mouvement du cavalier (aux échecs)\"; plus lent, mais plus "
-"précis"
+msgstr "Utiliser le \"mouvement du cavalier (aux échecs)\"; plus lent, mais plus précis"
#: ../raster/r.cost/main.c:219
#, fuzzy
@@ -5628,9 +5245,7 @@
#: ../raster/r.cost/main.c:290
msgid "Must specify exactly one of start_points, start_rast or coordinate"
-msgstr ""
-"Vous devez précisément exactement des points de départ, un raster de départ "
-"ou des coordonnées"
+msgstr "Vous devez précisément exactement des points de départ, un raster de départ ou des coordonnées"
#: ../raster/r.cost/main.c:295 ../raster/r.cost/main.c:614
#: ../raster/r.cost/main.c:720
@@ -5650,9 +5265,7 @@
#: ../raster/r.cost/main.c:324
#, fuzzy
msgid "Assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"Attention : coût négatif assigné aux cellules vides. Les cellules vides sont "
-"ignorées"
+msgstr "Attention : coût négatif assigné aux cellules vides. Les cellules vides sont ignorées"
#: ../raster/r.cost/main.c:402 ../raster/r.walk/main.c:682
#, fuzzy
@@ -5671,9 +5284,7 @@
#: ../raster/r.cost/main.c:461 ../raster/r.cost/main.c:479
#: ../raster/r.cost/main.c:498
#, c-format
-msgid ""
-"Negative cell value found at row %d, col %d. Setting negative value to "
-"null_cost value"
+msgid "Negative cell value found at row %d, col %d. Setting negative value to null_cost value"
msgstr ""
#: ../raster/r.cost/main.c:517
@@ -5699,8 +5310,7 @@
#: ../raster/r.cost/main.c:735 ../raster/r.walk/main.c:982
#, fuzzy
msgid "Specified starting location outside database window"
-msgstr ""
-"Secteur de départ spécifié en dehors de la fenêtre de la base de donnée"
+msgstr "Secteur de départ spécifié en dehors de la fenêtre de la base de donnée"
#: ../raster/r.cost/main.c:751
#, fuzzy
@@ -5739,14 +5349,11 @@
#: ../raster/r.cost/main.c:1216 ../raster/r.walk/main.c:1704
#, c-format
msgid "Warning, ignoring point outside window: %.4f,%.4f"
-msgstr ""
-"Avertissement, on ignore un point situé en dehors de la fenêtre : %.4f,%.4f"
+msgstr "Avertissement, on ignore un point situé en dehors de la fenêtre : %.4f,%.4f"
#: ../raster/r.grow2/main.c:130
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"Produit une couche raster où les aires contiguës ont été agrandies d'une "
-"cellule."
+msgstr "Produit une couche raster où les aires contiguës ont été agrandies d'une cellule."
#: ../raster/r.grow2/main.c:141
msgid "Radius of buffer in raster cells"
@@ -5846,9 +5453,7 @@
#: ../raster/r.out.vtk/writeascii.c:429
msgid "Wrong map values! Values should in between 0 and 255!\n"
-msgstr ""
-"Valeurs de couches erronnées! Les valeurs doivent être comprises entre 0 et "
-"255!\n"
+msgstr "Valeurs de couches erronnées! Les valeurs doivent être comprises entre 0 et 255!\n"
#: ../raster/r.out.vtk/writeascii.c:459
#, fuzzy
@@ -5869,26 +5474,18 @@
msgstr "Altitude (si aucune couche d'altitude n'est fournie)"
#: ../raster/r.out.vtk/parameters.c:66
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr ""
-"Crée des données points VTK à la place des données cellules VTK (si aucune "
-"couche d'altitude n'est donnée)"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgstr "Crée des données points VTK à la place des données cellules VTK (si aucune couche d'altitude n'est donnée)"
#: ../raster/r.out.vtk/parameters.c:76
#, fuzzy
-msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr ""
-"3 couches rasters g3d (r,g,b) utilisées pour créer les valeurs RGB [redmap,"
-"greenmap,bluemap]"
+msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgstr "3 couches rasters g3d (r,g,b) utilisées pour créer les valeurs RGB [redmap,greenmap,bluemap]"
#: ../raster/r.out.vtk/parameters.c:86
#, fuzzy
msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
#: ../raster/r.out.vtk/parameters.c:111
msgid "Use structured grid for elevation (not recommended)"
@@ -5896,21 +5493,15 @@
#: ../raster/r.out.vtk/parameters.c:117
msgid "Use polydata-trianglestrips for elevation grid creation"
-msgstr ""
-"Utiliser une triangulation-polydonnées pour la création de la grille "
-"d'altitude"
+msgstr "Utiliser une triangulation-polydonnées pour la création de la grille d'altitude"
#: ../raster/r.out.vtk/parameters.c:123
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
-msgstr ""
-"Utiliser des arcs-polydonnées pour la création d'une grille d'altitude (afin "
-"d'utiliser vtkDelauny2D)"
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgstr "Utiliser des arcs-polydonnées pour la création d'une grille d'altitude (afin d'utiliser vtkDelauny2D)"
#: ../raster/r.out.vtk/parameters.c:129
msgid "Scale factor effects the origin (if no elevation map is given)"
-msgstr ""
-"Facteur d'échelle à l'origine (si aucune couche d'altitude n'est donnée)"
+msgstr "Facteur d'échelle à l'origine (si aucune couche d'altitude n'est donnée)"
#: ../raster/r.out.vtk/main.c:79
#, fuzzy, c-format
@@ -5959,9 +5550,7 @@
#: ../raster/r.out.vtk/main.c:334
msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr ""
-"Couches RGB erronées. Les couches doivent être de même type! La sortie RGB "
-"n'est pas créée!"
+msgstr "Couches RGB erronées. Les couches doivent être de même type! La sortie RGB n'est pas créée!"
#: ../raster/r.out.vtk/main.c:371
msgid "Writing VTK Vector Data\n"
@@ -5969,11 +5558,8 @@
#: ../raster/r.out.vtk/main.c:381
#, fuzzy
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
-msgstr ""
-"n'est pas créée!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
#: ../raster/r.out.vtk/main.c:393
msgid "Error closing VTK-ASCII file"
@@ -6149,15 +5735,11 @@
#: ../raster/r.statistics/main.c:73 ../raster/r.average/main.c:66
msgid "Cover values extracted from the category labels of the cover map"
-msgstr ""
-"Valeurs de la couche de couverture extraites des étiquettes de catégorie de "
-"la couche de couverture"
+msgstr "Valeurs de la couche de couverture extraites des étiquettes de catégorie de la couche de couverture"
#: ../raster/r.statistics/main.c:82 ../raster/r.statistics/main.c:88
msgid "This module currently only works for integer (CELL) maps"
-msgstr ""
-"Pour le moment ce module ne fonctionne qu'avec des cartes de valeurs(CELL) "
-"entières"
+msgstr "Pour le moment ce module ne fonctionne qu'avec des cartes de valeurs(CELL) entières"
#: ../raster/r.statistics/main.c:100 ../raster/r.proj.seg/main.c:240
#: ../raster/r.neighbors/main.c:226 ../raster/r.proj/main.c:210
@@ -6198,12 +5780,8 @@
#: ../raster/r.rescale.eq/main.c:54
#, fuzzy
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-"Rééchelonne l'histogramme (ajusté sur l'étendue des valeurs de catégories) "
-"de la couche de données raster"
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr "Rééchelonne l'histogramme (ajusté sur l'étendue des valeurs de catégories) de la couche de données raster"
#: ../raster/r.rescale.eq/main.c:64 ../raster/r.rescale/main.c:61
msgid "The name of the raster map to be rescaled"
@@ -6211,9 +5789,7 @@
#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:69
msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr ""
-"Intervalle de données à rééchelonner en entrée (par défaut : l'ensemble de "
-"la couche en entrée)"
+msgstr "Intervalle de données à rééchelonner en entrée (par défaut : l'ensemble de la couche en entrée)"
#: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:76
msgid "The resulting raster map name"
@@ -6291,11 +5867,8 @@
msgstr ""
#: ../raster/r.los/main.c:245
-msgid ""
-"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
-msgstr ""
-"Problème pour obtenir les paramètres de l'ellipsoïde courant, utilisation "
-"d'une sphère (6370997.0)"
+msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr "Problème pour obtenir les paramètres de l'ellipsoïde courant, utilisation d'une sphère (6370997.0)"
#: ../raster/r.los/main.c:250
#, fuzzy, c-format
@@ -6320,12 +5893,8 @@
#: ../raster/r.his/main.c:65
#, fuzzy
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-"Générer des couches raster de couche rouge, verte et bleue en combinant des "
-"couches raster de teinte, intensité et saturation."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Générer des couches raster de couche rouge, verte et bleue en combinant des couches raster de teinte, intensité et saturation."
#: ../raster/r.his/main.c:74 ../display/d.his/main.c:76
msgid "Name of layer to be used for HUE"
@@ -6389,12 +5958,8 @@
msgstr "couche raster source"
#: ../raster/r.buffer/main.c:71
-msgid ""
-"Creates a raster map layer showing buffer zones surrounding cells that "
-"contain non-NULL category values."
-msgstr ""
-"Créer une couche raster montrant des zones tampons entourant les cellules "
-"qui contiennent des valeurs de catégorie non NULL"
+msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Créer une couche raster montrant des zones tampons entourant les cellules qui contiennent des valeurs de catégorie non NULL"
#: ../raster/r.buffer/main.c:83
msgid "Distance zone(s)"
@@ -6406,9 +5971,7 @@
#: ../raster/r.buffer/main.c:96
msgid "Ignore zero (0) data cells instead of NULL cells"
-msgstr ""
-"Ignore les cellules contenant la valeur zéro (0) au lieu des cellules "
-"contenant NULL"
+msgstr "Ignore les cellules contenant la valeur zéro (0) au lieu des cellules contenant NULL"
#: ../raster/r.buffer/main.c:149
#, fuzzy
@@ -6472,9 +6035,7 @@
#: ../raster/r.circle/dist.c:53
#, fuzzy
msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-"Crée une couche raster contenant des cercles concentriques autour d'un point "
-"donné"
+msgstr "Crée une couche raster contenant des cercles concentriques autour d'un point donné"
#: ../raster/r.circle/dist.c:63
msgid "The coordinate of the center (east,north)"
@@ -6506,17 +6067,8 @@
msgstr ""
#: ../raster/r.walk/main.c:179
-msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
-msgstr ""
-"Produit une couche raster montrant le coût cumulé anisotropique d'un "
-"déplacement entre différentes positions géographiques à partir d'une couche "
-"raster d'altitude où la valeur de catégorie des cellules représente "
-"l'altitude combinée avec une couche raster dont la valeur correspond au coût "
-"de rugosité."
+msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
+msgstr "Produit une couche raster montrant le coût cumulé anisotropique d'un déplacement entre différentes positions géographiques à partir d'une couche raster d'altitude où la valeur de catégorie des cellules représente l'altitude combinée avec une couche raster dont la valeur correspond au coût de rugosité."
#: ../raster/r.walk/main.c:191
msgid "Name of elevation input raster map"
@@ -6560,14 +6112,11 @@
#: ../raster/r.walk/main.c:296
msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr ""
-"Coefficients lambda pour combiner l'énergie de marche et le coût de rugosité"
+msgstr "Coefficients lambda pour combiner l'énergie de marche et le coût de rugosité"
#: ../raster/r.walk/main.c:305
msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
-"Facteur de pente qui détermine le coût d'énergie du déplacement en fonction "
-"d'un pas de hauteur"
+msgstr "Facteur de pente qui détermine le coût d'énergie du déplacement en fonction d'un pas de hauteur"
#: ../raster/r.walk/main.c:314
msgid "Keep null values in output map"
@@ -6626,9 +6175,7 @@
#: ../raster/r.walk/main.c:512
msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"ignorées"
# c-format
#: ../raster/r.walk/main.c:584 ../raster/r.walk/main.c:586
@@ -6712,14 +6259,12 @@
#: ../raster/r.walk/main.c:917
#, fuzzy, c-format
msgid "Raster output map <%s> not found (no start_points given)"
-msgstr ""
-"Couche raster en sortie %s - introuvable (aucun point de départ spécifié)"
+msgstr "Couche raster en sortie %s - introuvable (aucun point de départ spécifié)"
#: ../raster/r.walk/main.c:932
#, c-format
msgid "Memory allocation error on reading start points from raster map %s"
-msgstr ""
-"Erreur d'allocation mémoire à la lecture des points de la couche raster %s"
+msgstr "Erreur d'allocation mémoire à la lecture des points de la couche raster %s"
# c-format
#: ../raster/r.walk/main.c:935
@@ -6743,8 +6288,7 @@
#: ../raster/r.walk/main.c:1501
msgid "Will copy input map null values into output map"
-msgstr ""
-"Copier les cellules null de la couche en entrée dans la couche de sortie"
+msgstr "Copier les cellules null de la couche en entrée dans la couche de sortie"
#: ../raster/r.walk/main.c:1508
msgid ""
@@ -6782,9 +6326,7 @@
#: ../raster/r.what/main.c:93
msgid "Queries raster map layers on their category values and category labels."
-msgstr ""
-"Requète les couches raster sur les valeurs des catégories et les étiquettes "
-"des catégories"
+msgstr "Requète les couches raster sur les valeurs des catégories et les étiquettes des catégories"
#: ../raster/r.what/main.c:101
msgid "Name of existing raster map(s) to query"
@@ -6825,8 +6367,7 @@
#: ../raster/r.what/main.c:143
msgid "Output integer category values, not cell values"
-msgstr ""
-"Produire des valeurs de catégorie entières au lieu de valeurs de cellule"
+msgstr "Produire des valeurs de catégorie entières au lieu de valeurs de cellule"
#: ../raster/r.what/main.c:147
msgid "Turn on cache reporting"
@@ -6845,8 +6386,7 @@
#: ../raster/r.contour/main.c:92
#, fuzzy
msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-"Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
+msgstr "Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
#: ../raster/r.contour/main.c:104
msgid "List of contour levels"
@@ -6873,9 +6413,7 @@
msgstr "Supprimer les messages d'erreur de croisement simple"
#: ../raster/r.contour/main.c:147
-msgid ""
-"The '-q' and '-n' flag is superseded and will be removed in future. Please "
-"use '--quiet' instead."
+msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
msgstr ""
#: ../raster/r.contour/main.c:152
@@ -6981,12 +6519,8 @@
msgstr "couche raster à échantillonner"
#: ../raster/r.series/main.c:133
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"Calcule chaque valeur de cellule en sortie comme une fonction des valeurs "
-"des cellules correspondantes dans les couches d'entrée."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Calcule chaque valeur de cellule en sortie comme une fonction des valeurs des cellules correspondantes dans les couches d'entrée."
#: ../raster/r.series/main.c:147
msgid "Aggregate operation"
@@ -7131,8 +6665,7 @@
#: ../raster/r.random.surface/main.c:45
msgid "Generates random surface(s) with spatial dependence."
-msgstr ""
-"Générer des valeurs de surface aléatoire ayant une interdépendance spatiale"
+msgstr "Générer des valeurs de surface aléatoire ayant une interdépendance spatiale"
#: ../raster/r.random.surface/main.c:57 ../raster/r.random.cells/init.c:115
#, fuzzy, c-format
@@ -7145,9 +6678,7 @@
#: ../raster/r.in.xyz/main.c:161
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
msgstr ""
#: ../raster/r.in.xyz/main.c:165
@@ -7172,9 +6703,7 @@
#: ../raster/r.in.xyz/main.c:196
#, fuzzy
msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr ""
-"Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) "
-"en mode points"
+msgstr "Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) en mode points"
#: ../raster/r.in.xyz/main.c:204
msgid "Column number of y coordinates in input file"
@@ -7199,9 +6728,7 @@
msgstr "Format de sortie pour la pente"
#: ../raster/r.in.xyz/main.c:251
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
msgstr ""
#: ../raster/r.in.xyz/main.c:256
@@ -7247,11 +6774,8 @@
msgstr "impossible d'ouvrir le fichier en entrée <%s>"
#: ../raster/r.in.xyz/main.c:477
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
-msgstr ""
-"Si l'entrée ne provient pas d'un fichier, il n'est possible de réaliser "
-"qu'une seule passe."
+msgid "If input is not from a file it is only possible to perform a single pass."
+msgstr "Si l'entrée ne provient pas d'un fichier, il n'est possible de réaliser qu'une seule passe."
#: ../raster/r.in.xyz/main.c:483
msgid "zrange will not be taken into account during scan"
@@ -7271,12 +6795,10 @@
#: ../raster/r.in.xyz/main.c:1103 ../raster/r.in.xyz/main.c:1111
#, c-format
msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
"[%s]"
msgstr ""
-"Pas assez de colonnes de données. Séparateur ou nombre de colonne "
-"incorrect ? trouvé les caractères suivants dans la ligne %lu:\n"
+"Pas assez de colonnes de données. Séparateur ou nombre de colonne incorrect ? trouvé les caractères suivants dans la ligne %lu:\n"
"[%s]"
#: ../raster/r.in.xyz/main.c:603 ../raster/r.in.xyz/main.c:1107
@@ -7332,10 +6854,8 @@
#: ../raster/r.composite/main.c:74
#, fuzzy
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-"Combiner des couches rouges, vertes et bleues en une seule couche composite."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
+msgstr "Combiner des couches rouges, vertes et bleues en une seule couche composite."
#: ../raster/r.composite/main.c:88 ../raster/r.out.ppm3/main.c:65
#, c-format
@@ -7386,18 +6906,12 @@
msgstr "Valeur raster"
#: ../raster/r.volume/main.c:59
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
-msgstr ""
-"Calcul le volume de données \"flaques\" et produit (en option) une couche "
-"vectorielle point GRASS contenant les centroïdes de ces 'flaques'"
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Calcul le volume de données \"flaques\" et produit (en option) une couche vectorielle point GRASS contenant les centroïdes de ces 'flaques'"
#: ../raster/r.volume/main.c:69
msgid "Existing raster map representing data that will be summed within clumps"
-msgstr ""
-"Couche de données raster existante représentant les données à additionner à "
-"l'intérieur des 'flaques'"
+msgstr "Couche de données raster existante représentant les données à additionner à l'intérieur des 'flaques'"
#: ../raster/r.volume/main.c:77
msgid "Existing raster map, preferably the output of r.clump"
@@ -7405,8 +6919,7 @@
#: ../raster/r.volume/main.c:84
msgid "Vector points map to contain clump centroids"
-msgstr ""
-"Couche vectoriel de points qui doit contenir les centroïdes de 'flaques'"
+msgstr "Couche vectoriel de points qui doit contenir les centroïdes de 'flaques'"
#: ../raster/r.volume/main.c:88
msgid "Generate unformatted report"
@@ -7529,9 +7042,7 @@
msgstr ""
#: ../raster/r.gwflow/main.c:191
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
msgstr ""
#: ../raster/r.gwflow/main.c:201 ../raster/r.topidx/main.c:50
@@ -7574,9 +7085,7 @@
#: ../raster/r.topidx/main.c:39
#, fuzzy
msgid "Creates topographic index map from elevation raster map."
-msgstr ""
-"Crée une couche d'indice topographique ln(a/tan(beta)) à partir d'une couche "
-"d'altitude."
+msgstr "Crée une couche d'indice topographique ln(a/tan(beta)) à partir d'une couche d'altitude."
# c-format
#: ../raster/r.topidx/file_io.c:21 ../raster/r.out.tiff/r.out.tiff.c:169
@@ -7590,10 +7099,7 @@
#: ../raster/r.topidx/file_io.c:37
#, c-format
-msgid ""
-"The current region resolution [%s x %s] is finer than the input map's "
-"resolution [%s x %s]. The current region resolution must be identical to, or "
-"coarser than, the input map's resolution."
+msgid "The current region resolution [%s x %s] is finer than the input map's resolution [%s x %s]. The current region resolution must be identical to, or coarser than, the input map's resolution."
msgstr ""
#: ../raster/r.topidx/file_io.c:44 ../raster/r.fill.dir/main.c:188
@@ -7608,11 +7114,8 @@
#: ../raster/r.in.arc/main.c:61
#, fuzzy
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-"map layer."
-msgstr ""
-"Convertir un fichier raster ESRI ARC/INFO ASCII GRID en une couche raster."
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+msgstr "Convertir un fichier raster ESRI ARC/INFO ASCII GRID en une couche raster."
#: ../raster/r.in.arc/main.c:69
#, fuzzy
@@ -7698,12 +7201,8 @@
#: ../raster/r.fill.dir/main.c:86
#, fuzzy
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"Filtrer et générer une couche d'altitude sans dépressions et une couche de "
-"direction d'écoulement depuis une couche d'altitude donnée"
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr "Filtrer et générer une couche d'altitude sans dépressions et une couche de direction d'écoulement depuis une couche d'altitude donnée"
#: ../raster/r.fill.dir/main.c:90
#, fuzzy
@@ -7832,9 +7331,7 @@
#: ../raster/r.mfilter/main.c:104 ../raster/r.mfilter.fp/main.c:109
#: ../raster/r.kappa/main.c:125 ../raster/r.out.ppm/main.c:81
-msgid ""
-"quiet' instead"
+msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
msgstr ""
#: ../raster/r.mfilter/main.c:133 ../raster/r.mfilter.fp/main.c:138
@@ -7974,12 +7471,8 @@
#: ../raster/r.clump/main.c:51
#, fuzzy
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Reclasser les données dans une couche raster en regroupant les cellules qui "
-"forment des zones physiques discrètes."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Reclasser les données dans une couche raster en regroupant les cellules qui forment des zones physiques discrètes."
#: ../raster/r.clump/main.c:120
#, fuzzy, c-format
@@ -8032,8 +7525,7 @@
#: ../raster/r.colors/main.c:216
msgid "Only write new color table if one doesn't already exist"
-msgstr ""
-"N'écrire une nouvelle table de couleur que s'il n'en existe pas déjà une"
+msgstr "N'écrire une nouvelle table de couleur que s'il n'en existe pas déjà une"
#: ../raster/r.colors/main.c:220
#, fuzzy
@@ -8070,16 +7562,11 @@
#: ../raster/r.colors/main.c:278
#, fuzzy
-msgid ""
-"One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be "
-"specified!"
-msgstr ""
-"L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
+msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
+msgstr "L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
#: ../raster/r.colors/main.c:281
-msgid ""
-"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
-"options"
+msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
msgstr ""
#: ../raster/r.colors/main.c:288
@@ -8089,9 +7576,7 @@
#: ../raster/r.colors/main.c:299
#, fuzzy
msgid "-g and -a flags are mutually exclusive"
-msgstr ""
-"les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
-"qu'un seul."
+msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
# c-format
#: ../raster/r.colors/main.c:309
@@ -8112,23 +7597,17 @@
#: ../raster/r.colors/main.c:343
#, fuzzy
msgid "Color table 'random' is not supported for floating point raster map"
-msgstr ""
-"Impossible de construire une table de couleurs aléatoire pour les couches en "
-"valeurs flottantes"
+msgstr "Impossible de construire une table de couleurs aléatoire pour les couches en valeurs flottantes"
#: ../raster/r.colors/main.c:348
#, fuzzy
msgid "Color table 'grey.eq' is not supported for floating point raster map"
-msgstr ""
-"Impossible de construire une table en valeurs de gris pour les couches en "
+msgstr "Impossible de construire une table en valeurs de gris pour les couches en valeurs flottantes"
#: ../raster/r.colors/main.c:355
#, fuzzy
msgid "Color table 'grey.log' is not supported for floating point raster map"
-msgstr ""
#: ../raster/r.colors/main.c:368
#, fuzzy, c-format
@@ -8149,9 +7628,7 @@
#: ../raster/r.colors/rules.c:42
#, c-format
msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
-msgstr ""
-"Entrez une règle, \"end\" une fois terminé, \"help\" si vous en avez "
-"besoin.\n"
+msgstr "Entrez une règle, \"end\" une fois terminé, \"help\" si vous en avez besoin.\n"
#: ../raster/r.colors/rules.c:51
#, fuzzy, c-format
@@ -8252,12 +7729,8 @@
#: ../raster/r.to.rast3/main.c:222 ../raster/r.to.rast3elev/main.c:462
#, fuzzy
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
-msgstr ""
-"Les réglages de région 2D et 3D sont différents. Utilisation des réglages de "
-"carte 3D pour ajuster la région 2D."
+msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
+msgstr "Les réglages de région 2D et 3D sont différents. Utilisation des réglages de carte 3D pour ajuster la région 2D."
#: ../raster/r.to.rast3/main.c:260
#, fuzzy
@@ -8267,15 +7740,11 @@
#: ../raster/r.to.rast3/main.c:268
#, c-format
msgid "Open raster map %s - one time for each depth (%d/%d)"
-msgstr ""
-"Ouvrir la couche raster %s - une couche pour chaque niveau de profondeur (%d/"
-"%d)"
+msgstr "Ouvrir la couche raster %s - une couche pour chaque niveau de profondeur (%d/%d)"
#: ../raster/r.to.rast3/main.c:281
msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
-msgstr ""
-"Les couches en entrée doivent être composées du même type de données : soit "
-"CELL, FCELL ou DCELL!"
+msgstr "Les couches en entrée doivent être composées du même type de données : soit CELL, FCELL ou DCELL!"
#: ../raster/r.to.rast3/main.c:285 ../raster/r.to.rast3elev/main.c:498
#, fuzzy
@@ -8316,20 +7785,12 @@
msgstr "time et insol_time ne sont pas compatibles"
#: ../raster/r.sun/main.c:417
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance given a set local "
-"time"
-msgstr ""
-"Mode 1 : angle d'incidence solaire instantanné & irradiance pour une heure "
-"locale donnée"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
+msgstr "Mode 1 : angle d'incidence solaire instantanné & irradiance pour une heure locale donnée"
#: ../raster/r.sun/main.c:472 ../raster/r.horizon/main.c:471
-msgid ""
-"Can't get projection info of current location: please set latitude via 'lat' "
-"or 'latin' option!"
-msgstr ""
-"Impossible de récupérer les infos de projection du Secteur courant : "
-"veuillez régler la latitude grâce à 'lat' ou à l'option 'latin'!"
+msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
+msgstr "Impossible de récupérer les infos de projection du Secteur courant : veuillez régler la latitude grâce à 'lat' ou à l'option 'latin'!"
# c-format
#: ../raster/r.sun/main.c:527
@@ -8426,16 +7887,11 @@
msgstr ""
#: ../raster/r.le/r.le.patch/main.c:49
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
msgstr ""
#: ../raster/r.le/r.le.trace/main.c:58
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
msgstr ""
#: ../raster/r.le/r.le.trace/user_input.c:35
@@ -8457,9 +7913,7 @@
msgstr "Nom du fichier où stocker le résultat"
#: ../raster/r.le/r.le.setup/main.c:63
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
msgstr ""
#: ../raster/r.le/r.le.setup/main.c:67
@@ -8477,9 +7931,7 @@
msgstr "Impossible de lire la couche vecteur"
#: ../raster/r.le/r.le.pixel/main.c:47
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
msgstr ""
#: ../raster/r.digit/get_label.c:31
@@ -8497,19 +7949,12 @@
msgstr "C'est bon?"
#: ../raster/r.digit/main.c:47
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
-msgstr ""
-"Outil interactif pour dessiner et sauvegarder des objets vecteurs à l'écran "
-"en utilisant un périphérique de pointage (souris) et de sauvegarder une "
-"couche vectorielle."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
+msgstr "Outil interactif pour dessiner et sauvegarder des objets vecteurs à l'écran en utilisant un périphérique de pointage (souris) et de sauvegarder une couche vectorielle."
#: ../raster/r.digit/main.c:56 ../vector/v.digit/main.c:120
msgid "Display commands to be used for canvas backdrop (separated by ';')"
-msgstr ""
-"Commandes d'affichage à utiliser pour l'arrière-plan de numérisation "
-"(séparée par ';')"
+msgstr "Commandes d'affichage à utiliser pour l'arrière-plan de numérisation (séparée par ';')"
#: ../raster/r.digit/main.c:79
msgid "No graphics device selected!"
@@ -8573,17 +8018,11 @@
#: ../raster/r.surf.contour/main.c:72
msgid "Unused; retained for compatibility purposes, will be removed in future"
-msgstr ""
-"Inutile; conservé pour des questions de compatibilité, sera supprimé dans le "
-"futur"
+msgstr "Inutile; conservé pour des questions de compatibilité, sera supprimé dans le futur"
#: ../raster/r.surf.contour/main.c:77
-msgid ""
-"Invoke slow, but memory frugal operation (generally not needed, will be "
-"removed in future)"
-msgstr ""
-"Lance une opération lente, mais économe en mémoire (généralement ce n'est "
-"pas nécessaire, sera supprimé dans le futur)"
+msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
+msgstr "Lance une opération lente, mais économe en mémoire (généralement ce n'est pas nécessaire, sera supprimé dans le futur)"
#: ../raster/r.in.bin/main.c:49 ../raster/r.in.bin/main.c:58
#: ../raster/r.in.bin/main.c:510
@@ -8604,8 +8043,7 @@
#: ../raster/r.in.bin/main.c:246
#, fuzzy
msgid "Import as double-precision floating-point data (default: integer)"
-msgstr ""
-"Importer comme virgule flottante en double précision (par défaut : entier)"
+msgstr "Importer comme virgule flottante en double précision (par défaut : entier)"
#: ../raster/r.in.bin/main.c:250
msgid "Signed data (two's complement)"
@@ -8714,16 +8152,12 @@
#: ../raster/r.in.bin/main.c:366
#, fuzzy
msgid "order= and -b are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.in.bin/main.c:381
#, fuzzy
msgid "-f and -d are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.in.bin/main.c:385
#, c-format
@@ -8787,9 +8221,7 @@
#: ../raster/r.in.bin/main.c:464
#, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign east= and west= correctly?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
msgstr ""
#: ../raster/r.in.bin/main.c:487
@@ -8812,12 +8244,8 @@
msgstr "impossible d'ouvrir le fichier 3dview <%s> dans <%s>"
#: ../raster/r.kappa/main.c:69
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"Calculer la matrice d'erreur et le paramètre kappa pour estimer la précision "
-"de la classification obtenue."
+msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr "Calculer la matrice d'erreur et le paramètre kappa pour estimer la précision de la classification obtenue."
#: ../raster/r.kappa/main.c:75
#, fuzzy
@@ -8950,14 +8378,8 @@
#: ../raster/r.resamp.rst/main.c:158
#, fuzzy
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"Ré-interpole et fait une analyse topographique depuis une couche raster vers "
-"une nouvelle couche raster (probablement avec une résolution différente) en "
-"utilisant des splines régularisées avec tension et lissage."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr "Ré-interpole et fait une analyse topographique depuis une couche raster vers une nouvelle couche raster (probablement avec une résolution différente) en utilisant des splines régularisées avec tension et lissage."
#: ../raster/r.resamp.rst/main.c:169
msgid "Desired east-west resolution"
@@ -9030,8 +8452,7 @@
#: ../raster/r.resamp.rst/main.c:286 ../vector/v.surf.rst/main.c:209
msgid "Output partial derivatives instead of topographic parameters"
-msgstr ""
-"Affiche les dérivées partielles à la place des paramètres topographiques"
+msgstr "Affiche les dérivées partielles à la place des paramètres topographiques"
#: ../raster/r.resamp.rst/main.c:293 ../general/g.setproj/main.c:140
msgid "Retrieving and setting region failed"
@@ -9067,9 +8488,7 @@
#: ../raster/r.resamp.rst/main.c:343
msgid "When using anisotropy both theta and scalex must be specified"
-msgstr ""
-"Quand vous utilisez l'anisotropie, les paramètres theta et scalex doivent "
-"être spécifiés"
+msgstr "Quand vous utilisez l'anisotropie, les paramètres theta et scalex doivent être spécifiés"
#: ../raster/r.resamp.rst/main.c:366 ../vector/v.surf.rst/main.c:520
msgid "Not enough memory for az"
@@ -9106,9 +8525,7 @@
#: ../raster/r.resamp.rst/main.c:431
msgid "Input map resolution differs from current region resolution!"
-msgstr ""
-"Résolution de la couche en entrée ne correspond pas à la résolution de la "
-"région courante!"
+msgstr "Résolution de la couche en entrée ne correspond pas à la résolution de la région courante!"
#: ../raster/r.resamp.rst/main.c:451
msgid "Processing all selected output files will require"
@@ -9334,9 +8751,7 @@
#: ../raster/r.proj.seg/main.c:143 ../raster/r.proj/main.c:132
#, fuzzy
msgid "Re-projects a raster map from one location to the current location."
-msgstr ""
-"Re-projeter une couche raster depuis un Secteur (location) vers le Secteur "
-"courant."
+msgstr "Re-projeter une couche raster depuis un Secteur (location) vers le Secteur courant."
#: ../raster/r.proj.seg/main.c:146 ../raster/r.proj/main.c:135
#, fuzzy
@@ -9412,10 +8827,8 @@
#: ../raster/r.proj.seg/main.c:222
#, fuzzy
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
-msgstr ""
-"Affiche les paramètres de la région courante (à la façon d'un script shell)"
+msgid "Print input map's bounds in the current projection and exit (shell style)"
+msgstr "Affiche les paramètres de la région courante (à la façon d'un script shell)"
#: ../raster/r.proj.seg/main.c:247 ../raster/r.proj/main.c:217
#: ../vector/v.proj/main.c:132
@@ -9436,23 +8849,17 @@
#: ../raster/r.proj.seg/main.c:265 ../raster/r.proj/main.c:228
#, fuzzy
msgid "Unable to get projection info of output raster map"
-msgstr ""
-"Impossible d'obtenir les informations de projection pour le Secteur "
-"(location) courant"
+msgstr "Impossible d'obtenir les informations de projection pour le Secteur (location) courant"
#: ../raster/r.proj.seg/main.c:268 ../raster/r.proj/main.c:231
#, fuzzy
msgid "Unable to get projection units of output raster map"
-msgstr ""
-"Impossible d'obtenir les unités de projection pour le Secteur (location) "
-"courant"
+msgstr "Impossible d'obtenir les unités de projection pour le Secteur (location) courant"
#: ../raster/r.proj.seg/main.c:271 ../raster/r.proj/main.c:234
#, fuzzy
msgid "Unable to get projection key values of output raster map"
-msgstr ""
-"Impossible d'obtenir les valeurs clefs de projection pour le Secteur "
+msgstr "Impossible d'obtenir les valeurs clefs de projection pour le Secteur (location) courant"
#: ../raster/r.proj.seg/main.c:280 ../raster/r.proj/main.c:243
#, fuzzy, c-format
@@ -9495,23 +8902,17 @@
#: ../raster/r.proj.seg/main.c:312 ../raster/r.proj/main.c:275
#, fuzzy
msgid "Unable to get projection info of input map"
-msgstr ""
#: ../raster/r.proj.seg/main.c:315 ../raster/r.proj/main.c:278
#, fuzzy
msgid "Unable to get projection units of input map"
-msgstr ""
-"courant"
#: ../raster/r.proj.seg/main.c:318 ../raster/r.proj/main.c:281
#, fuzzy
msgid "Unable to get projection key values of input map"
-msgstr ""
#: ../raster/r.proj.seg/main.c:332 ../raster/r.proj/main.c:296
msgid "Unable to work with unprojected data (xy location)"
@@ -9704,12 +9105,8 @@
#: ../raster/r.random/main.c:53
#, fuzzy
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Crée une couche raster et une couche vectorielle contenant des points placés "
-"au hasard."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Crée une couche raster et une couche vectorielle contenant des points placés au hasard."
#: ../raster/r.random/main.c:57 ../raster/r.out.bin/main.c:289
#: ../imagery/i.zc/main.c:69
@@ -9802,21 +9199,11 @@
#: ../raster/wildfire/r.spread/main.c:103
#, fuzzy
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr ""
-"Simule une propagation elliptique anisotropique sur une fenêtre graphique et "
-"génère une couche raster pour le temps cumulé de propagation, à partir de "
-"couches rasters contenant des taux de propagation (ROS), les directions ROS, "
-"et l'origine du foyer. En option, produit des couches raster contenant des "
-"coordonnées UTM pour retracer le parcours de propagation du feu"
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
+msgstr "Simule une propagation elliptique anisotropique sur une fenêtre graphique et génère une couche raster pour le temps cumulé de propagation, à partir de couches rasters contenant des taux de propagation (ROS), les directions ROS, et l'origine du foyer. En option, produit des couches raster contenant des coordonnées UTM pour retracer le parcours de propagation du feu"
#: ../raster/wildfire/r.spread/main.c:108
-msgid ""
-"It optionally produces raster maps to contain backlink UTM coordinates for "
-"tracing spread paths."
+msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
msgstr ""
#: ../raster/wildfire/r.spread/main.c:116
@@ -9832,8 +9219,7 @@
#: ../raster/wildfire/r.spread/main.c:118
msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
-msgstr ""
-"Nom de la couche raster de taux de propagation MAXimal (ROS) (en cm/min)"
+msgstr "Nom de la couche raster de taux de propagation MAXimal (ROS) (en cm/min)"
#: ../raster/wildfire/r.spread/main.c:127
msgid "Name of raster map containing DIRections of max ROS (degree)"
@@ -9848,37 +9234,24 @@
msgstr "Nom de la couche raster des foyers de départ de feu"
#: ../raster/wildfire/r.spread/main.c:153
-msgid ""
-"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
-msgstr ""
-"Nom de la couche raster de DISTance maximale d'ESSAIMAGE (en m) (nécessite "
-"w/ -s)"
+msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgstr "Nom de la couche raster de DISTance maximale d'ESSAIMAGE (en m) (nécessite w/ -s)"
#: ../raster/wildfire/r.spread/main.c:161
-msgid ""
-"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
-msgstr ""
-"Nom de la couche raster de VITESSE du Vent au sol (en pieds/min) (nécessite "
-"w/ -s)"
+msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgstr "Nom de la couche raster de VITESSE du Vent au sol (en pieds/min) (nécessite w/ -s)"
#: ../raster/wildfire/r.spread/main.c:169
-msgid ""
-"Name of raster map containing fine Fuel MOISture of the cell receiving a "
-"spotting firebrand (%) (required w/ -s)"
-msgstr ""
-"Nom de la couche raster du taux d'HUMIDITE du combustible de la cellule "
-"recevant un brandon de départ de foyer secondaire (%) (nécessite w/ -s) "
+msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
+msgstr "Nom de la couche raster du taux d'HUMIDITE du combustible de la cellule recevant un brandon de départ de foyer secondaire (%) (nécessite w/ -s) "
#: ../raster/wildfire/r.spread/main.c:177
msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
-msgstr ""
-"TAILLE de la fenêtre d'échantillonnage de base pour atteindre une précision "
-"suffisante (3)"
+msgstr "TAILLE de la fenêtre d'échantillonnage de base pour atteindre une précision suffisante (3)"
#: ../raster/wildfire/r.spread/main.c:184
msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
-msgstr ""
-"Echantillonnage de DENSité pour des CALCULS supplémentaires (0.0 - 1.0 (0.5))"
+msgstr "Echantillonnage de DENSité pour des CALCULS supplémentaires (0.0 - 1.0 (0.5))"
#: ../raster/wildfire/r.spread/main.c:191
msgid "INITial TIME for current simulation (0) (min)"
@@ -9901,8 +9274,7 @@
#: ../raster/wildfire/r.spread/main.c:214
msgid "Name of raster map to contain OUTPUT spread time (min)"
-msgstr ""
-"Nom de la couche raster en SORTIE pour le temps de propagation (en min)"
+msgstr "Nom de la couche raster en SORTIE pour le temps de propagation (en min)"
#: ../raster/wildfire/r.spread/main.c:222
#, fuzzy
@@ -9924,9 +9296,7 @@
#: ../raster/wildfire/r.spread/main.c:243
msgid "For wildfires: consider SPOTTING effect"
-msgstr ""
-"Pour les feux de forêts : prendre en compte l'ESSAIMAGE du foyer initial en "
-"foyers secondaires"
+msgstr "Pour les feux de forêts : prendre en compte l'ESSAIMAGE du foyer initial en foyers secondaires"
# c-format
#: ../raster/wildfire/r.spread/main.c:384
@@ -9945,16 +9315,8 @@
msgstr "Lecture du fichier %s..."
#: ../raster/wildfire/r.ros/main.c:214
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
-msgstr ""
-"Génère trois ou quatre couches raster montrant 1) la base (orthogonale) de "
-"la 'vitesse de propagation du feu' (ROS), 2)le ROS maximum (progression du "
-"feu), 3) la direction du ROS maximum et en option 4) la distance maximale "
-"prévue pour l'essaimage du foyer initial (c.f. escarbilles/brandons)"
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
+msgstr "Génère trois ou quatre couches raster montrant 1) la base (orthogonale) de la 'vitesse de propagation du feu' (ROS), 2)le ROS maximum (progression du feu), 3) la direction du ROS maximum et en option 4) la distance maximale prévue pour l'essaimage du foyer initial (c.f. escarbilles/brandons)"
#: ../raster/wildfire/r.ros/main.c:224
msgid "Name of raster map containing fuel MODELs"
@@ -9962,18 +9324,15 @@
#: ../raster/wildfire/r.ros/main.c:231
msgid "Name of raster map containing the 1-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Nom de la couche raster du taux d'HUMIDITE du combustible sur 1 heure (%)"
+msgstr "Nom de la couche raster du taux d'HUMIDITE du combustible sur 1 heure (%)"
#: ../raster/wildfire/r.ros/main.c:238
msgid "Name of raster map containing the 10-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Nom de la couche raster du taux d'HUMIDITE du combustible sur 10 heures (%)"
+msgstr "Nom de la couche raster du taux d'HUMIDITE du combustible sur 10 heures (%)"
#: ../raster/wildfire/r.ros/main.c:245
msgid "Name of raster map containing the 100-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Nom de la couche raster du taux d'HUMIDITE du combustible sur 100 heures (%)"
+msgstr "Nom de la couche raster du taux d'HUMIDITE du combustible sur 100 heures (%)"
#: ../raster/wildfire/r.ros/main.c:253
msgid "Name of raster map containing LIVE fuel MOISTURE (%)"
@@ -9993,9 +9352,7 @@
#: ../raster/wildfire/r.ros/main.c:281
msgid "Name of raster map containing ASPECT (degree, anti-clockwise from E)"
-msgstr ""
-"Nom de la couche raster d'ASPECT (en degrés, dans le sens anti-horaire en "
-"partant de l'E)"
+msgstr "Nom de la couche raster d'ASPECT (en degrés, dans le sens anti-horaire en partant de l'E)"
#: ../raster/wildfire/r.ros/main.c:288
msgid "Name of raster map containing ELEVATION (m) (required w/ -s)"
@@ -10003,8 +9360,7 @@
#: ../raster/wildfire/r.ros/main.c:296
msgid "Name of raster map to contain results (several new layers)"
-msgstr ""
-"Nom de la couche raster des résultats en sortie (plusieurs nouvelles couches)"
+msgstr "Nom de la couche raster des résultats en sortie (plusieurs nouvelles couches)"
#: ../raster/wildfire/r.ros/main.c:305
msgid "Also produce maximum SPOTTING distance"
@@ -10016,25 +9372,17 @@
msgstr "Pourcentage effectué..."
#: ../raster/wildfire/r.spreadpath/main.c:74
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Trace de façon récursive le plus court chemin vers les cellules pour lequel "
-"le coût cumulé est déterminé"
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "Trace de façon récursive le plus court chemin vers les cellules pour lequel le coût cumulé est déterminé"
#: ../raster/wildfire/r.spreadpath/main.c:83
msgid "Name of raster map containing back-path easting information"
-msgstr ""
-"Nom de la couche raster pour les informations X de plus court chemin pour la "
-"propagation du foyer"
+msgstr "Nom de la couche raster pour les informations X de plus court chemin pour la propagation du foyer"
#: ../raster/wildfire/r.spreadpath/main.c:91
#, fuzzy
msgid "Name of raster map containing back-path northing information"
-msgstr ""
-"Nom de la couche raster pour les informations Y de plus court chemin pour la "
+msgstr "Nom de la couche raster pour les informations Y de plus court chemin pour la propagation du foyer"
#: ../raster/wildfire/r.spreadpath/main.c:99
msgid "The map E and N grid coordinates of starting points"
@@ -10109,11 +9457,8 @@
msgstr ""
#: ../raster/r.univar2/r.univar_main.c:105
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
-msgstr ""
-"Calcule des statistiques univariées à partir des cellules non vides d'une "
-"couche raster."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
+msgstr "Calcule des statistiques univariées à partir des cellules non vides d'une couche raster."
# c-format
#: ../raster/r.univar2/r.univar_main.c:116
@@ -10137,12 +9482,8 @@
#: ../raster/r.univar2/r3.univar_main.c:102
#, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
-msgstr ""
-"couche raster."
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
#: ../raster/r.univar2/r3.univar_main.c:163
#, fuzzy
@@ -10152,9 +9493,7 @@
#: ../raster/r.grow.distance/main.c:150
#, fuzzy
msgid "Generates a raster map containing distances to nearest raster features."
-msgstr ""
-"cellule."
#: ../raster/r.grow.distance/main.c:157
#, fuzzy
@@ -10222,12 +9561,8 @@
#: ../raster/r.report/parse.c:46
#, fuzzy
-msgid ""
-"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
-"cover"
-msgstr ""
-"mi(les), me(tres), k(ilomètres), a(cres), h(ectares), c(ellules_nombre), "
-"p(ourcentage_couverture)"
+msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
+msgstr "mi(les), me(tres), k(ilomètres), a(cres), h(ectares), c(ellules_nombre), p(ourcentage_couverture)"
#: ../raster/r.report/parse.c:57
msgid "Character representing no data cell value"
@@ -10251,15 +9586,11 @@
#: ../raster/r.report/parse.c:84
#, fuzzy
msgid "If no output given report is printed to standard output"
-msgstr ""
-"Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
-"prendreles paramètres saisis en ligne de commande"
+msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
#: ../raster/r.report/parse.c:94 ../raster/r.stats/main.c:136
msgid "Number of fp subranges to collect stats from"
-msgstr ""
-"Nombres de chiffres après la virgule à prendre en compte pour constituer les "
-"statistiques"
+msgstr "Nombres de chiffres après la virgule à prendre en compte pour constituer les statistiques"
#: ../raster/r.report/parse.c:95 ../raster/r.report/parse.c:127
#: ../raster/r.report/parse.c:133
@@ -10288,15 +9619,11 @@
#: ../raster/r.report/parse.c:126 ../raster/r.stats/main.c:196
msgid "Report for cats fp ranges (fp maps only)"
-msgstr ""
-"Examen des catégories en nombres à virgule flottante (couches en virgule "
-"flottante uniquement)"
+msgstr "Examen des catégories en nombres à virgule flottante (couches en virgule flottante uniquement)"
#: ../raster/r.report/parse.c:132 ../raster/r.stats/main.c:200
msgid "Read fp map as integer (use map's quant rules)"
-msgstr ""
-"Lire une couche en virgule flottante comme une couche de valeurs entières "
-"(en utilisant les règles de quantification de la couche)"
+msgstr "Lire une couche en virgule flottante comme une couche de valeurs entières (en utilisant les règles de quantification de la couche)"
#: ../raster/r.report/parse.c:176
#, fuzzy
@@ -10362,8 +9689,7 @@
#: ../raster/r.out.pov/main.c:193
#, c-format
msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr ""
-"La couche raster est trop grande! Elle dépasse %d colonnes ou %d lignes"
+msgstr "La couche raster est trop grande! Elle dépasse %d colonnes ou %d lignes"
#: ../raster/r.out.pov/main.c:214
msgid "Negative elevation values in input"
@@ -10400,8 +9726,7 @@
msgid ""
"Warning, ignoring point outside window: \n"
" %.4f,%.4f\n"
-msgstr ""
#: ../raster/r.water.outlet/main.c:113
#, fuzzy
@@ -10439,17 +9764,12 @@
msgstr "Traitement des lignes..."
#: ../raster/r.carve/enforce_ds.c:173
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr ""
-"Le vecteur sort et ré-entre dans la région - ce cas particulier n'est pas "
-"encore implémenté."
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
+msgstr "Le vecteur sort et ré-entre dans la région - ce cas particulier n'est pas encore implémenté."
#: ../raster/r.carve/lobf.c:74
msgid "trying to divide by zero...no unique solution for system...skipping..."
-msgstr ""
-"Tentative de division par zéro... pas de solution unique pour le modèle... "
-"on passe..."
+msgstr "Tentative de division par zéro... pas de solution unique pour le modèle... on passe..."
#: ../raster/r.carve/main.c:78
msgid "Generates stream channels."
@@ -10457,12 +9777,8 @@
#: ../raster/r.carve/main.c:79
#, fuzzy
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
-msgstr ""
-"Prends les données vectorielles de cours d'eau, les transforme en raster, et "
-"soustrait la profondeur du modèle de terrain en sortie"
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgstr "Prends les données vectorielles de cours d'eau, les transforme en raster, et soustrait la profondeur du modèle de terrain en sortie"
#: ../raster/r.carve/main.c:84
msgid "Name of input raster elevation map"
@@ -10512,12 +9828,8 @@
msgstr "Projection lat/long non gérée pour le moment."
#: ../raster/r.out.tiff/r.out.tiff.c:101
-msgid ""
-"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-"resolution of the currently defined region."
-msgstr ""
-"Exporte une couche Raster GRASS en un fichier TIFF 8/24 bits à la résolution "
-"de la région actuelle."
+msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
+msgstr "Exporte une couche Raster GRASS en un fichier TIFF 8/24 bits à la résolution de la région actuelle."
#: ../raster/r.out.tiff/r.out.tiff.c:111
#, fuzzy
@@ -10550,20 +9862,12 @@
#: ../raster/r.out.tiff/r.out.tiff.c:177
#, fuzzy, c-format
-msgid ""
-"Raster map <%s> in mapset <%s> is a floating point map. Decimal values will "
-"be rounded to integer!"
-msgstr ""
-"La couche <%s> du jeu de données <%s> est une couche en point flottant. Les "
-"valeurs décimales seront arrondies à l'entier!"
+msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
+msgstr "La couche <%s> du jeu de données <%s> est une couche en point flottant. Les valeurs décimales seront arrondies à l'entier!"
#: ../raster/r.out.tiff/r.out.tiff.c:183
-msgid ""
-"Color map for palette must have less than 256 colors for the available range "
-"of data"
-msgstr ""
-"La table de couleur pour la palette doit compter moins de 256 couleurs pour "
-"l'intervalle disponible de données"
+msgid "Color map for palette must have less than 256 colors for the available range of data"
+msgstr "La table de couleur pour la palette doit compter moins de 256 couleurs pour l'intervalle disponible de données"
# c-format
#: ../raster/r.out.tiff/r.out.tiff.c:198
@@ -10630,9 +9934,7 @@
#: ../raster/r.null/null.c:123
#, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
msgstr ""
#: ../raster/r.null/null.c:129
@@ -10746,11 +10048,8 @@
#: ../raster/r.surf.idw2/main.c:80
#, fuzzy
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr ""
-"Les bases de données en latitude/longitude ne sont pas supportées par r."
-"flow. Veuillez à utiliser 'r.watershed' pour calculer la crue."
+msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr "Les bases de données en latitude/longitude ne sont pas supportées par r.flow. Veuillez à utiliser 'r.watershed' pour calculer la crue."
#: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:141
#, c-format
@@ -10798,8 +10097,7 @@
#: ../raster/r.stats/main.c:162
msgid "Print APPROXIMATE percents (total percent may not be 100%)"
-msgstr ""
-"Affiche des pourcentages APPROCHÉS (le total peut être différent de 100%)"
+msgstr "Affiche des pourcentages APPROCHÉS (le total peut être différent de 100%)"
#: ../raster/r.stats/main.c:167
msgid "Print category labels"
@@ -10815,9 +10113,7 @@
#: ../raster/r.stats/main.c:182
msgid "Print raw indexes of fp ranges (fp maps only)"
-msgstr ""
-"Affiche les index brutes de valeurs en nombres à virgule flottante (couches "
-"en nombre à virgule flottante uniquement)"
+msgstr "Affiche les index brutes de valeurs en nombres à virgule flottante (couches en nombre à virgule flottante uniquement)"
#: ../raster/r.stats/main.c:187 ../raster/r.describe/main.c:94
msgid "Suppress reporting of any NULLs"
@@ -10825,8 +10121,7 @@
#: ../raster/r.stats/main.c:192
msgid "Suppress reporting of NULLs when all values are NULL"
-msgstr ""
-"Supprime l'affichage des valeurs NULL lorsque toutes les valeurs sont NULL"
+msgstr "Supprime l'affichage des valeurs NULL lorsque toutes les valeurs sont NULL"
#: ../raster/r.stats/main.c:214
#, fuzzy, c-format
@@ -10841,30 +10136,18 @@
#: ../raster/r.stats/main.c:284
#, fuzzy, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
-msgstr ""
-"%s: -i signifie lire %s comme entier! le drapeau -C et/ou l'option nsteps "
-"vont être ignorés."
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgstr "%s: -i signifie lire %s comme entier! le drapeau -C et/ou l'option nsteps vont être ignorés."
#: ../raster/r.stats/main.c:301
#, fuzzy, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
-msgstr ""
-"%s: cats de %s sont soit manquantes ou n'ont pas d'étiquette explicite. "
-"Utilisation de nsteps=%d"
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
+msgstr "%s: cats de %s sont soit manquantes ou n'ont pas d'étiquette explicite. Utilisation de nsteps=%d"
#: ../raster/r.stats/main.c:308
#, fuzzy, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
-msgstr ""
-"%s: le drapeau -C a été spécifié, utilisation cats fp (valeurs flottantes) "
-"intervalle de %s, l'option nsteps est ignorée"
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
+msgstr "%s: le drapeau -C a été spécifié, utilisation cats fp (valeurs flottantes) intervalle de %s, l'option nsteps est ignorée"
# c-format
#: ../raster/r.stats/main.c:342
@@ -10986,9 +10269,7 @@
#: ../raster/r.describe/main.c:61
msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-"Affiche une liste succinte des valeurs de catégorie trouvées dans une couche "
-"raster."
+msgstr "Affiche une liste succinte des valeurs de catégorie trouvées dans une couche raster."
#: ../raster/r.describe/main.c:80
#, fuzzy
@@ -11024,8 +10305,7 @@
#: ../raster/r.out.mat/main.c:65
msgid "Exports a GRASS raster to a binary MAT-File."
-msgstr ""
-"Exporte une couche raster GRASS vers un fichier binaire au format MAT-File"
+msgstr "Exporte une couche raster GRASS vers un fichier binaire au format MAT-File"
#: ../raster/r.out.mat/main.c:76
msgid "Name for the output binary MAT-File"
@@ -11117,42 +10397,28 @@
msgstr "%d points écrits dans la couche vecteur"
#: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
-msgstr ""
-"Impossible de calculer la position du soleil sur des secteur non projetés. "
-"Spécifier directement la position du soleil."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
+msgstr "Impossible de calculer la position du soleil sur des secteur non projetés. Spécifier directement la position du soleil."
#: ../raster/r.sunmask/g_solposition.c:88
#, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
-msgstr ""
-"Le point spécifié %f, %f est en dehors de la région courante, est-ce "
-"intentionnel ? Quoi qu'il en soit il sera utilisé."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
+msgstr "Le point spécifié %f, %f est en dehors de la région courante, est-ce intentionnel ? Quoi qu'il en soit il sera utilisé."
#: ../raster/r.sunmask/g_solposition.c:98
#, fuzzy
msgid "Unable to get projection info of current location"
-msgstr ""
#: ../raster/r.sunmask/g_solposition.c:101
#, fuzzy
msgid "Unable to get projection units of current location"
-msgstr ""
-"courant"
#: ../raster/r.sunmask/g_solposition.c:104
#, fuzzy
msgid "Unable to get projection key values of current location"
-msgstr ""
#: ../raster/r.sunmask/main.c:115 ../raster/r.horizon/main.c:177
#, fuzzy
@@ -11161,19 +10427,13 @@
#: ../raster/r.sunmask/main.c:116
#, fuzzy
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
msgstr "Calcule un <simple> index sur un fichier raster"
#: ../raster/r.sunmask/main.c:117
#, fuzzy
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
-msgstr ""
-"Calculer des zones d'ombre portée à partir de la position du soleil et d'un "
-"MNT. A : la position exacte du soleil est donnée. B : date/heure pour "
-"calculer la position du soleil grâce à r.sunmask."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
+msgstr "Calculer des zones d'ombre portée à partir de la position du soleil et d'un MNT. A : la position exacte du soleil est donnée. B : date/heure pour calculer la position du soleil grâce à r.sunmask."
#: ../raster/r.sunmask/main.c:131
#, fuzzy
@@ -11287,28 +10547,18 @@
#: ../raster/r.sunmask/main.c:282
#, fuzzy
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
-msgstr ""
-"Ni la position du soleil, ni les coordonnées E/N, ni la date/heure/fuseau "
-"n'ont été entièrement définies."
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
+msgstr "Ni la position du soleil, ni les coordonnées E/N, ni la date/heure/fuseau n'ont été entièrement définies."
#: ../raster/r.sunmask/main.c:286
#, fuzzy, c-format
msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
-msgstr ""
-"Calcul de la position du soleil en cours... (utilisation de solpos (V. %s) "
-"de NREL)\n"
+msgstr "Calcul de la position du soleil en cours... (utilisation de solpos (V. %s) de NREL)\n"
#: ../raster/r.sunmask/main.c:291
#, fuzzy
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
-msgstr ""
-"Utilisation de données d'azimut et d'altitude du soleil (ignore d'autres "
-"données éventuelles)\n"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
+msgstr "Utilisation de données d'azimut et d'altitude du soleil (ignore d'autres données éventuelles)\n"
#: ../raster/r.sunmask/main.c:397
#, fuzzy
@@ -11318,8 +10568,7 @@
#: ../raster/r.sunmask/main.c:411
#, fuzzy, c-format
msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
-msgstr ""
-"L'heure (%02i:%02i:%02i) est avant le lever du soleil (%02d:%02d:%02d) !\n"
+msgstr "L'heure (%02i:%02i:%02i) est avant le lever du soleil (%02d:%02d:%02d) !\n"
#: ../raster/r.sunmask/main.c:415
#, fuzzy, c-format
@@ -11333,8 +10582,7 @@
#: ../raster/r.sunmask/main.c:422
#, fuzzy, c-format
msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
-msgstr ""
-"L'heure (%02i:%02i:%02i) est après le coucher du soleil (%02d:%02d:%02d) !\n"
+msgstr "L'heure (%02i:%02i:%02i) est après le coucher du soleil (%02d:%02d:%02d) !\n"
#: ../raster/r.sunmask/main.c:426
#, fuzzy, c-format
@@ -11466,12 +10714,8 @@
msgstr "Couche pour le coefficient y"
#: ../raster/r.regression.line/main.c:59
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
-msgstr ""
-"fichier ASCII où stocker les coefficients de régression (sortie à l'écran si "
-"aucun fichier n'est spécifié)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
+msgstr "fichier ASCII où stocker les coefficients de régression (sortie à l'écran si aucun fichier n'est spécifié)."
#: ../raster/r.regression.line/main.c:63 ../general/g.region/main.c:150
#: ../locale/scriptstrings/i.oif_to_translate.c:9
@@ -11548,16 +10792,12 @@
#: ../raster/r.out.bin/main.c:366
#, fuzzy
msgid "order= and -s are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.out.bin/main.c:375
#, fuzzy
msgid "-i and -f are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.out.bin/main.c:394
msgid "Floating-point output requires bytes=4 or bytes=8"
@@ -11632,12 +10872,8 @@
#: ../raster/r.surf.random/main.c:46
#, fuzzy
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
-msgstr ""
-"Produit una couche raster de données aléatoires uniformément réparties dans "
-"un rang donné par l'utilisateur."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
+msgstr "Produit una couche raster de données aléatoires uniformément réparties dans un rang donné par l'utilisateur."
#: ../raster/r.surf.random/main.c:53
msgid "Minimum random value"
@@ -11824,11 +11060,8 @@
#: ../raster/r.li/r.li.patchnum/main.c:34
#, fuzzy
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
-"Calcule un index de densité de patch sur un fichier raster, en utilisant un "
-"algorithme de voisinage quatre"
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr "Calcule un index de densité de patch sur un fichier raster, en utilisant un algorithme de voisinage quatre"
#: ../raster/r.li/r.li.simpson/simpson.c:37
#, fuzzy
@@ -11856,12 +11089,8 @@
#: ../raster/r.li/r.li.mps/mps.c:39
#, fuzzy
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
#: ../raster/r.li/r.li.shannon/shannon.c:36
#, fuzzy
@@ -11883,11 +11112,8 @@
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:37
#, fuzzy
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
#: ../raster/r.li/r.li.padrange/padrange.c:37
#, fuzzy
@@ -12002,9 +11228,7 @@
#: ../raster/r.li/r.li.daemon/daemon.c:502
#, c-format
msgid "The configuration file can be used only with \t\t\t%s rasterfile"
-msgstr ""
-"Le fichier de configuration peut seulement être utilisé avec les fichiers "
-"raster \t\t\t%s"
+msgstr "Le fichier de configuration peut seulement être utilisé avec les fichiers raster \t\t\t%s"
#: ../raster/r.li/r.li.daemon/daemon.c:509
msgid "Illegal configuration file (sample area)"
@@ -12137,20 +11361,13 @@
#: ../raster/r.li/r.li.patchdensity/main.c:33
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
#: ../raster/r.out.ppm/main.c:56
#, fuzzy
-msgid ""
-"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
-"the currently defined region."
-msgstr ""
+msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
#: ../raster/r.out.ppm/main.c:64
#, fuzzy
@@ -12210,8 +11427,7 @@
#: ../raster/r.random.cells/main.c:37
msgid "Generates random cell values with spatial dependence."
-msgstr ""
-"Générer des valeurs de cellules aléatoires ayant une interdépendance spatiale"
+msgstr "Générer des valeurs de cellules aléatoires ayant une interdépendance spatiale"
#: ../raster/r.timestamp/main.c:35
#, fuzzy
@@ -12221,15 +11437,11 @@
#: ../raster/r.timestamp/main.c:36
#, fuzzy
msgid "Modifies a timestamp for a raster map."
-msgstr ""
-"Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une "
-"couche raster"
+msgstr "Affiche/ajoute/supprime une étiquette de date&heure (timestamp) pour une couche raster"
#: ../raster/r.timestamp/main.c:37
msgid "Print/add/remove a timestamp for a raster map."
-msgstr ""
-"couche raster"
#: ../raster/r.timestamp/main.c:46
#, fuzzy
@@ -12255,12 +11467,8 @@
msgstr "Nom de la couche ASCII à créer (utiliser out=- pour stdout)"
#: ../raster/r.out.ascii/main.c:92
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
-msgstr ""
-"Nombre de valeurs à produire avant de passer à la ligne (seulement pour les "
-"formats SURFER ou MODFLOW)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
+msgstr "Nombre de valeurs à produire avant de passer à la ligne (seulement pour les formats SURFER ou MODFLOW)"
#: ../raster/r.out.ascii/main.c:100
msgid "String to represent null cell (GRASS grid only)"
@@ -12315,12 +11523,8 @@
#: ../raster/r.cats/main.c:53
#, fuzzy
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
-msgstr ""
-"Afficher les étiquettes et valeurs de catégorie associées avec les couches "
-"raster demandées."
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr "Afficher les étiquettes et valeurs de catégorie associées avec les couches raster demandées."
#: ../raster/r.cats/main.c:66
#, fuzzy
@@ -12369,9 +11573,7 @@
#: ../raster/r.cats/main.c:268
msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr ""
-"La couche est en valeurs flottantes! La liste des cats est ignorée, la liste "
-"des vals est utilisée à la place"
+msgstr "La couche est en valeurs flottantes! La liste des cats est ignorée, la liste des vals est utilisée à la place"
#: ../raster/r.cats/main.c:285
msgid "vals argument is required for floating point map!"
@@ -12401,21 +11603,13 @@
#: ../raster/r.slope.aspect/main.c:156
#, fuzzy
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Produit des couches raster de pente, aspect, courbures et dérivées "
-"partielles à partir d'une couche raster de valeurs réelles d'altitude. "
-"L'aspect est calculé dans le sens contraire des aiguilles d'une montre à "
-"partir de l'est."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Produit des couches raster de pente, aspect, courbures et dérivées partielles à partir d'une couche raster de valeurs réelles d'altitude. L'aspect est calculé dans le sens contraire des aiguilles d'une montre à partir de l'est."
#: ../raster/r.slope.aspect/main.c:158
#, fuzzy
msgid "Aspect is calculated counterclockwise from east."
-msgstr ""
-"Angle de rotation (en degrés, sens inverse des aiguilles d'une montre en "
-"partant de l'Est)"
+msgstr "Angle de rotation (en degrés, sens inverse des aiguilles d'une montre en partant de l'Est)"
#: ../raster/r.slope.aspect/main.c:165
#, fuzzy
@@ -12455,19 +11649,13 @@
#: ../raster/r.slope.aspect/main.c:211
#, fuzzy
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
-msgstr ""
-"Nom de fichier de sortie pour la dérivée partielle d'ordre un en dx "
-"(gradient E-W)"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
+msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre un en dx (gradient E-W)"
#: ../raster/r.slope.aspect/main.c:218
#, fuzzy
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr ""
-"Nom de fichier de sortie pour la dérivée partielle d'ordre un en dy "
-"(gradient N-S)"
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr "Nom de fichier de sortie pour la dérivée partielle d'ordre un en dy (gradient N-S)"
#: ../raster/r.slope.aspect/main.c:225
#, fuzzy
@@ -12490,9 +11678,7 @@
#: ../raster/r.slope.aspect/main.c:254
msgid "Minimum slope val. (in percent) for which aspect is computed"
-msgstr ""
-"Valeur de pente minimale (en pourcentage) pour laquelle l'aspect doit être "
-"calculé"
+msgstr "Valeur de pente minimale (en pourcentage) pour laquelle l'aspect doit être calculé"
#: ../raster/r.slope.aspect/main.c:268
msgid "Do not align the current region to the elevation layer"
@@ -12510,12 +11696,8 @@
#: ../raster/r.slope.aspect/main.c:350
#, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s>, <%s> or <%s>"
-msgstr ""
-"Vous devez spécifier au moins un des paramètres : <%s>, <%s>, <%s>, <%s>, <"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr "Vous devez spécifier au moins un des paramètres : <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
# c-format
#: ../raster/r.slope.aspect/main.c:380
@@ -12685,9 +11867,7 @@
#: ../raster/r.to.vect/main.c:74
msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr ""
-"Utiliser les valeurs raster comme catégories à la place d'une séquence "
-"unique (uniquement pour les CELL)"
+msgstr "Utiliser les valeurs raster comme catégories à la place d'une séquence unique (uniquement pour les CELL)"
#: ../raster/r.to.vect/main.c:75 ../raster/r.to.vect/main.c:82
#: ../vector/v.in.ogr/main.c:196 ../vector/v.in.ogr/main.c:219
@@ -12702,18 +11882,12 @@
#: ../raster/r.to.vect/main.c:80
#, fuzzy
-msgid ""
-"Write raster values as z coordinate. Table is not created. Currently "
-"supported only for points."
-msgstr ""
-"Ecrit les valeurs rasters comme des coordonnées z. La table n'est pas créée. "
-"Pour le moment n'existe que pour les points."
+msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
+msgstr "Ecrit les valeurs rasters comme des coordonnées z. La table n'est pas créée. Pour le moment n'existe que pour les points."
#: ../raster/r.to.vect/main.c:87
msgid "Do not build vector topology (use with care for massive point export)"
-msgstr ""
-"Ne pas construire la topologie de vecteur (à utiliser avec précaution pour "
-"l'export massif de points)"
+msgstr "Ne pas construire la topologie de vecteur (à utiliser avec précaution pour l'export massif de points)"
#: ../raster/r.to.vect/main.c:92
msgid "Quiet - Do not show progress"
@@ -12725,9 +11899,7 @@
msgstr "Lister les formats gérés en sor"
#: ../raster/r.to.vect/main.c:124
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
msgstr ""
# c-format
@@ -12770,12 +11942,8 @@
msgstr "Écriture %s..."
#: ../raster/r.out.ppm3/main.c:59
-msgid ""
-"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-"resolution of the CURRENTLY DEFINED REGION."
-msgstr ""
-"Convertit trois couches raster R,G,B en un fichier image au format PPM, avec "
-"la résolution de la région actuelle."
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+msgstr "Convertit trois couches raster R,G,B en un fichier image au format PPM, avec la résolution de la région actuelle."
#: ../raster/r.out.ppm3/main.c:85
msgid "Name for new PPM file. (use out=- for stdout)"
@@ -12804,11 +11972,8 @@
msgstr "Nombre de points d'interpolation"
#: ../raster/r.transect/main.c:56
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-"Donne en sortie les valeurs de la couche raster situées le long du transect "
-"défini"
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgstr "Donne en sortie les valeurs de la couche raster situées le long du transect défini"
#: ../raster/r.transect/main.c:60
msgid "Raster map to be queried"
@@ -12850,12 +12015,8 @@
msgstr "Impossible de lire %s"
#: ../raster/r.median/main.c:48
-msgid ""
-"Finds the median of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"Trouve la médiane des valeurs d'une couche de couverture dans les zones "
-"définies par les catégories d'une couche de base."
+msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Trouve la médiane des valeurs d'une couche de couverture dans les zones définies par les catégories d'une couche de base."
#: ../raster/r.median/main.c:54
#, fuzzy
@@ -12871,8 +12032,7 @@
#: ../raster/r.median/main.c:79
#, fuzzy, c-format
msgid "Base map and output map <%s> must be different"
-msgstr ""
-"Les coordonnées des germes et la couche de sortie= doivent être fixées!"
+msgstr "Les coordonnées des germes et la couche de sortie= doivent être fixées!"
#: ../raster/r.median/main.c:82
#, fuzzy, c-format
@@ -12892,14 +12052,8 @@
msgstr "Échelle verticale"
#: ../raster/r.neighbors/main.c:110
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"Calcule pour chaque cellule une fonction des valeurs des cellules "
-"adjacentes, et sauvegarde les nouvelles valeurs de cellule dans une couche "
-"raster de sortie."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr "Calcule pour chaque cellule une fonction des valeurs des cellules adjacentes, et sauvegarde les nouvelles valeurs de cellule dans une couche raster de sortie."
#: ../raster/r.neighbors/main.c:133
msgid "Neighborhood operation"
@@ -12949,16 +12103,12 @@
#: ../raster/r.neighbors/main.c:189
#, fuzzy
msgid "weight= and -c are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.neighbors/main.c:201
#, fuzzy
msgid "weight= and gauss= are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../raster/r.neighbors/main.c:255
#, c-format
@@ -13032,9 +12182,7 @@
#: ../raster/r.info/main.c:111
msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr ""
-"Afficher l'étiquette date&heure de la couche raster (sous la forme jour.mois."
-"année heure:minute:secondes)"
+msgstr "Afficher l'étiquette date&heure de la couche raster (sous la forme jour.mois.année heure:minute:secondes)"
#: ../raster/r.info/main.c:142
#, fuzzy
@@ -13071,18 +12219,12 @@
#: ../raster/r.reclass/main.c:50
#, fuzzy
msgid "Reclassify raster map based on category values."
-msgstr ""
-"Requète les couches raster sur les valeurs des catégories et les étiquettes "
-"des catégories"
+msgstr "Requète les couches raster sur les valeurs des catégories et les étiquettes des catégories"
#: ../raster/r.reclass/main.c:52
#, fuzzy
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
-msgstr ""
-"Crée une nouvelle couche dont les catégories sont basées sur la "
-"reclassification des catégories d'une couche raster existante."
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+msgstr "Crée une nouvelle couche dont les catégories sont basées sur la reclassification des catégories d'une couche raster existante."
#: ../raster/r.reclass/main.c:57
msgid "Raster map to be reclassified"
@@ -13106,9 +12248,7 @@
#: ../raster/r.reclass/main.c:106
#, fuzzy, c-format
msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr ""
-"besoin.\n"
#: ../raster/r.reclass/main.c:108
#, fuzzy, c-format
@@ -13168,9 +12308,7 @@
#: ../raster/r.coin/main.c:68
#, fuzzy
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
msgstr "Rééchelonne l'étendue des valeurs de catégories pour une couche raster"
#: ../raster/r.coin/main.c:76
@@ -13189,9 +12327,7 @@
msgstr "Unités de distance"
#: ../raster/r.coin/main.c:91
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
msgstr ""
#: ../raster/r.coin/main.c:98
@@ -13229,8 +12365,7 @@
msgstr ""
#: ../raster/r.coin/inter.c:35
-msgid ""
-"This utility will allow you to compare the coincidence of two map layers\n"
+msgid "This utility will allow you to compare the coincidence of two map layers\n"
msgstr ""
#: ../raster/r.coin/inter.c:52
@@ -13300,8 +12435,7 @@
#: ../raster/r.coin/inter.c:117
#, c-format
-msgid ""
-"Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
msgstr ""
#: ../raster/r.coin/inter.c:126
@@ -13313,8 +12447,7 @@
#: ../raster/r.coin/inter.c:142
#, c-format
-msgid ""
-"Do you wish to run this report with a different unit of measure? (y/n) [y] "
+msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
msgstr ""
#: ../raster/r.coin/print_coin.c:44
@@ -13324,22 +12457,13 @@
#: ../raster/r.texture/h_measure.c:84
#, fuzzy
-msgid ""
-"Negative or no data pixel found. This module is not yet able to process no "
-"data holes in a map, please fill with r.fillnulls or other algorithms"
-msgstr ""
-"Valeur négative ou pixel sans données trouvé. Ce module n'est pour l'instant "
-"pas capable de traiter les trous de données dans une couche, veuillez "
-"compléter la couche avec r.fillbulls ou d'autres algorithmes."
+msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
+msgstr "Valeur négative ou pixel sans données trouvé. Ce module n'est pour l'instant pas capable de traiter les trous de données dans une couche, veuillez compléter la couche avec r.fillbulls ou d'autres algorithmes."
#: ../raster/r.texture/h_measure.c:88
#, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
-msgstr ""
-"Trop de catégories (trouvées: %i, max: %i). Essaye de rééchelonner ou de "
-"refaire la classification de la couche"
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
+msgstr "Trop de catégories (trouvées: %i, max: %i). Essaye de rééchelonner ou de refaire la classification de la couche"
#: ../raster/r.texture/h_measure.c:937
#, c-format
@@ -13457,9 +12581,7 @@
#: ../raster/r.in.gdal/main.c:113
msgid "Name of location to read projection from for GCPs transformation"
-msgstr ""
-"Nom du Secteur (location) où lire la projection pour la transformation des "
-"points de calage"
+msgstr "Nom du Secteur (location) où lire la projection pour la transformation des points de calage"
#: ../raster/r.in.gdal/main.c:128 ../vector/v.in.ogr/main.c:186
msgid "Name for new location to create"
@@ -13473,9 +12595,7 @@
#: ../raster/r.in.gdal/main.c:155
#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
msgid "Keep band numbers instead of using band color names"
-msgstr ""
-"Conserver les numéros de bande plutôt que d'utiliser les noms de couleur des "
-"bandes"
+msgstr "Conserver les numéros de bande plutôt que d'utiliser les noms de couleur des bandes"
#: ../raster/r.in.gdal/main.c:176
msgid "You have to specify a target location different from output location"
@@ -13496,32 +12616,20 @@
msgstr "Le vecteur '%s' existe déjà."
#: ../raster/r.in.gdal/main.c:250
-msgid ""
-"The polynomial rectification used in i.rectify does not work well with NOAA/"
-"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
-"(-tps)"
+msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
msgstr ""
#: ../raster/r.in.gdal/main.c:266
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
msgstr ""
#: ../raster/r.in.gdal/main.c:308
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them "
-"with r.region before going any further."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
msgstr ""
#: ../raster/r.in.gdal/main.c:328
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
-msgstr ""
-"Impossible de convertir la projection de la couche en entrée au format "
-"GRASS ; impossible de créer le nouveau Secteur"
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
+msgstr "Impossible de convertir la projection de la couche en entrée au format GRASS ; impossible de créer le nouveau Secteur"
# c-format
#: ../raster/r.in.gdal/main.c:334 ../general/g.proj/create.c:15
@@ -13533,8 +12641,7 @@
#, fuzzy
msgid ""
"\n"
-"You can use the -o flag to r.in.gdal to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
"Vous pouvez utiliser le drapeau -o de %s pour sauter cette vérification.\n"
@@ -13571,30 +12678,22 @@
#: ../raster/r.in.gdal/main.c:664
#, fuzzy
msgid "Unable to translate projection key values of input GCPs"
-msgstr ""
#: ../raster/r.in.gdal/main.c:680
#, fuzzy
msgid "Unable to get projection info of target location"
-msgstr ""
#: ../raster/r.in.gdal/main.c:682
#, fuzzy
msgid "Unable to get projection units of target location"
-msgstr ""
-"courant"
#: ../raster/r.in.gdal/main.c:684
#, fuzzy
msgid "Unable to get projection key values of target location"
-msgstr ""
#: ../raster/r.in.gdal/main.c:687 ../imagery/i.rectify/target.c:32
#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:31
@@ -13617,14 +12716,7 @@
msgstr ""
#: ../raster/r.horizon/main.c:181
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation: 1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction. The input for this is the angle (in "
-"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
+msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
msgstr ""
#: ../raster/r.horizon/main.c:234
@@ -13632,33 +12724,23 @@
msgstr ""
#: ../raster/r.horizon/main.c:250
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
msgstr ""
#: ../raster/r.horizon/main.c:258
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
msgstr ""
#: ../raster/r.horizon/main.c:266
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
msgstr ""
#: ../raster/r.horizon/main.c:274
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
msgstr ""
#: ../raster/r.horizon/main.c:282
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
msgstr ""
#: ../raster/r.horizon/main.c:290
@@ -13740,9 +12822,7 @@
#: ../raster/simwe/r.sim.sediment/main.c:113
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
msgstr ""
#: ../raster/simwe/r.sim.sediment/main.c:121
@@ -13907,9 +12987,8 @@
msgstr "Nom du fichier raster source"
#: ../raster/simwe/r.sim.water/main.c:177
-#, fuzzy
msgid "Manning's n unique value"
-msgstr "Nom du fichier raster source"
+msgstr ""
#: ../raster/simwe/r.sim.water/main.c:184
#, fuzzy
@@ -13978,9 +13057,7 @@
#: ../raster/simwe/simlib/input.c:409
#, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
-"to process"
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
msgstr ""
#: ../raster/simwe/simlib/input.c:541
@@ -14054,9 +13131,7 @@
#: ../raster/r.thin/main.c:57
#, fuzzy
msgid "Thins non-zero cells that denote linear features in a raster map."
-msgstr ""
-"'Amincit' les cellules de valeur non-nulles qui semblent appartenir à des "
-"entités linéaires dans une couche raster"
+msgstr "'Amincit' les cellules de valeur non-nulles qui semblent appartenir à des entités linéaires dans une couche raster"
#: ../raster/r.thin/main.c:69
msgid "Maximal number of iterations"
@@ -14127,11 +13202,8 @@
msgstr ""
#: ../raster/r.covar/main.c:55
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
-msgstr ""
-"Produit une matrice de covariance/correlation pour la couche raster choisie."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr "Produit une matrice de covariance/correlation pour la couche raster choisie."
#: ../raster/r.covar/main.c:62
msgid "Print correlation matrix"
@@ -14150,38 +13222,26 @@
#: ../raster/r.out.gdal/export_band.c:374
#, fuzzy
msgid "Unable to allocate buffer for reading raster map"
-msgstr ""
-"Impossible de calculer le centroïde de la surface (problème d'allocation "
-"mémoire)"
+msgstr "Impossible de calculer le centroïde de la surface (problème d'allocation mémoire)"
#: ../raster/r.out.gdal/export_band.c:187
#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will "
-"be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
msgstr ""
#: ../raster/r.out.gdal/export_band.c:192
#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will "
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
msgstr ""
#: ../raster/r.out.gdal/export_band.c:202
#, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
msgstr ""
#: ../raster/r.out.gdal/export_band.c:209
#, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
msgstr ""
# c-format
@@ -14303,9 +13363,7 @@
#: ../raster/r.out.gdal/main.c:190
#, fuzzy
msgid "Creation option(s) to pass to the output format driver"
-msgstr ""
-"option de création du pilote de format de sortie. De multiples options "
-"peuvent être disponibles"
+msgstr "option de création du pilote de format de sortie. De multiples options peuvent être disponibles"
#: ../raster/r.out.gdal/main.c:192
#: ../locale/scriptstrings/d.out.file_to_translate.c:21
@@ -14317,9 +13375,7 @@
msgstr ""
#: ../raster/r.out.gdal/main.c:201
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
msgstr ""
#: ../raster/r.out.gdal/main.c:210
@@ -14345,17 +13401,13 @@
#: ../raster/r.out.gdal/main.c:267
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
msgstr ""
#: ../raster/r.out.gdal/main.c:272
#, fuzzy
msgid "Unable to get in-memory raster driver"
-msgstr ""
-"mémoire)"
#: ../raster/r.out.gdal/main.c:276
#, c-format
@@ -14379,23 +13431,17 @@
#: ../raster/r.out.gdal/main.c:435
#, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
-"avoided by using %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
msgstr ""
#: ../raster/r.out.gdal/main.c:446
#, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
msgstr ""
#: ../raster/r.out.gdal/main.c:454
#, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
-"This can be avoided by using Float64"
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
msgstr ""
# c-format
@@ -14481,10 +13527,7 @@
#: ../raster/r.out.gdal/main.c:746 ../raster/r.out.gdal/main.c:759
#: ../raster/r.out.gdal/main.c:774
#, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
msgstr ""
#: ../raster/r.out.gdal/main.c:722 ../raster/r.out.gdal/main.c:749
@@ -14500,10 +13543,7 @@
#: ../raster/r.out.gdal/main.c:788
#, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
msgstr ""
#: ../raster/r.out.gdal/main.c:791
@@ -14531,14 +13571,12 @@
#: ../raster/r.lake/main.c:177
#, fuzzy
-msgid ""
-"Name of input raster map with given starting point(s) (at least 1 cell > 0)"
+msgid "Name of input raster map with given starting point(s) (at least 1 cell > 0)"
msgstr "Couche raster avec le germe (au moins 1 cellule > 0)"
#: ../raster/r.lake/main.c:183
msgid "Use negative depth values for lake raster map"
-msgstr ""
-"Utiliser des valeurs de profondeur négatives pour la couche raster du lac"
+msgstr "Utiliser des valeurs de profondeur négatives pour la couche raster du lac"
#: ../raster/r.lake/main.c:188
msgid "Overwrite seed map with result (lake) map"
@@ -14555,8 +13593,7 @@
#: ../raster/r.lake/main.c:200
msgid "Seed coordinates and output map lake= must be set!"
-msgstr ""
#: ../raster/r.lake/main.c:203
#, fuzzy
@@ -14579,9 +13616,7 @@
msgstr "get_img : mémoire insuffisante."
#: ../raster/r.lake/main.c:291
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level "
-"or move seed point."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
msgstr ""
#: ../raster/r.lake/main.c:374
@@ -14604,14 +13639,8 @@
msgstr ""
#: ../raster/r.surf.gauss/main.c:48
-msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
-msgstr ""
-"Module GRASS pour produire une couche raster de données gaussiennes dont la "
-"moyenne et l'écart-type peuvent être donnés par l'utilisateur. Utilise un "
-"générateur de nombres aléatoires gaussiens."
+msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
+msgstr "Module GRASS pour produire une couche raster de données gaussiennes dont la moyenne et l'écart-type peuvent être donnés par l'utilisateur. Utilise un générateur de nombres aléatoires gaussiens."
#: ../raster/r.surf.gauss/main.c:55
#, fuzzy
@@ -14649,9 +13678,7 @@
#: ../raster/r.in.poly/main.c:31
#, fuzzy
msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr ""
-"Créer des couches raster à partir de fichiers de données polygones/lignes "
-"dans le répertoire courant."
+msgstr "Créer des couches raster à partir de fichiers de données polygones/lignes dans le répertoire courant."
#: ../raster/r.in.poly/main.c:35
#, fuzzy
@@ -14685,11 +13712,8 @@
#: ../raster/r.in.ascii/main.c:74
#, fuzzy
-msgid ""
-"ASCII raster file to be imported. If not given reads from standard input"
-msgstr ""
+msgid "ASCII raster file to be imported. If not given reads from standard input"
#: ../raster/r.in.ascii/main.c:100
msgid "String representing NULL value data cell"
@@ -14861,9 +13885,7 @@
#: ../raster/r.surf.fractal/process.c:53
#, fuzzy
msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr ""
-"mémoire)"
#: ../raster/r.surf.fractal/spec_syn.c:61
msgid "Preliminary surface calculations..."
@@ -14897,12 +13919,8 @@
msgstr "Dimension fractale de la surface (2 < D < 3)"
#: ../raster/r.average/main.c:53
-msgid ""
-"Finds the average of values in a cover map within areas assigned the same "
-msgstr ""
-"Trouve la moyenne des valeurs d'une couche de couverture à partir des zones "
-"ayant la même catégorie dans une couche de base spécifiée par l'utilisateur."
+msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Trouve la moyenne des valeurs d'une couche de couverture à partir des zones ayant la même catégorie dans une couche de base spécifiée par l'utilisateur."
#: ../raster/r.average/main.c:93
#, c-format
@@ -14969,9 +13987,7 @@
#: ../raster/r.to.rast3elev/main.c:402
#, fuzzy
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-"Crée une couche raster de coupe 2D à partir du raster volumique G3D à partir "
-"d'une couche de relief 2D"
+msgstr "Crée une couche raster de coupe 2D à partir du raster volumique G3D à partir d'une couche de relief 2D"
#: ../raster/r.to.rast3elev/main.c:433
#, fuzzy
@@ -15212,13 +14228,8 @@
#: ../raster/r.flow/calc.c:414
#, fuzzy
-msgid ""
-"Construction of slope curves (flowlines), flowpath lengths, and flowline "
-"densities (upslope areas) from a raster digital elevation model (DEM)."
-msgstr ""
-"Constructon de courbes de terrain (lignes du courant), longueur des "
-"courants, et densité de lignes de courants (zones amont) à partir d'un "
-"modèle numérique de terrain (MNT) raster"
+msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
+msgstr "Constructon de courbes de terrain (lignes du courant), longueur des courants, et densité de lignes de courants (zones amont) à partir d'un modèle numérique de terrain (MNT) raster"
#: ../raster/r.flow/calc.c:453
#, fuzzy
@@ -15255,9 +14266,7 @@
#: ../raster/r.flow/calc.c:494
msgid "Compute upslope flowlines instead of default downhill flowlines"
-msgstr ""
-"Calculer les courants ascendants plutôt que les courants descendants par "
-"défaut"
+msgstr "Calculer les courants ascendants plutôt que les courants descendants par défaut"
#: ../raster/r.flow/calc.c:498
#, fuzzy
@@ -15270,17 +14279,12 @@
#: ../raster/r.flow/calc.c:520
msgid "You must select one or more output maps (flout, lgout, dsout)"
-msgstr ""
-"Vous devez sélectionner une couche de sortie ou plus (flout, lgout, dsout)"
+msgstr "Vous devez sélectionner une couche de sortie ou plus (flout, lgout, dsout)"
#: ../raster/r.flow/calc.c:536
#, fuzzy
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
-msgstr ""
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
# c-format
#: ../raster/r.flow/io.c:68
@@ -15296,9 +14300,7 @@
#: ../raster/r.flow/io.c:89
#, fuzzy
msgid "Elevation file's resolution differs from current region resolution"
-msgstr ""
-"Résolution de la couche en entrée ne correspond pas à la résolution de la "
-"région courante!"
+msgstr "Résolution de la couche en entrée ne correspond pas à la résolution de la région courante!"
# c-format
#: ../raster/r.flow/io.c:101
@@ -15309,9 +14311,7 @@
#: ../raster/r.flow/io.c:104
#, fuzzy
msgid "Resolution of aspect file differs from current region resolution"
-msgstr ""
-"région courante!"
#: ../raster/r.flow/io.c:118
msgid "Reading input files: barrier"
@@ -15492,8 +14492,7 @@
#: ../imagery/i.gensigset/openfiles.c:15
#, fuzzy, c-format
msgid "Unable to read REF file for subgroup <%s> in group <%s>"
-msgstr ""
-"Impossible de lire le fichier REF du sous-groupe [%s] dans le groupe [%s]"
+msgstr "Impossible de lire le fichier REF du sous-groupe [%s] dans le groupe [%s]"
#: ../imagery/i.smap/shapiro/read_sig.c:17
#: ../imagery/i.smap/shapiro/openfiles.c:19
@@ -15524,12 +14523,8 @@
msgstr "Nom de fichier du résultat de la classification"
#: ../imagery/i.smap/shapiro/main.c:40
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
-"Effectue une classification contextuelle de l'image en utilisant une "
-"estimation séquentielle maximum a posteriori (SMAP)."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
+msgstr "Effectue une classification contextuelle de l'image en utilisant une estimation séquentielle maximum a posteriori (SMAP)."
#: ../imagery/i.smap/shapiro/parse.c:21 ../imagery/i.maxlik/main.c:79
#, fuzzy
@@ -15547,9 +14542,7 @@
#: ../imagery/i.smap/shapiro/parse.c:39
msgid "Use maximum likelihood estimation (instead of smap)"
-msgstr ""
-"Utiliser l'estimation plus grande ressemblance 'maximum likelihood' (à la "
-"place de l'estimation SMAP)"
+msgstr "Utiliser l'estimation plus grande ressemblance 'maximum likelihood' (à la place de l'estimation SMAP)"
#: ../imagery/i.smap/shapiro/parse.c:58 ../imagery/i.maxlik/open.c:16
#: ../imagery/i.gensig/parse.c:41 ../imagery/i.gensigset/parse.c:47
@@ -15599,9 +14592,7 @@
#: ../imagery/i.landsat.acca/main.c:74
#, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
-"to radiance first)"
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
msgstr ""
#: ../imagery/i.landsat.acca/main.c:106
@@ -15662,8 +14653,7 @@
msgstr ""
#: ../imagery/i.landsat.acca/main.c:159
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
msgstr ""
#: ../imagery/i.landsat.acca/main.c:164
@@ -15806,21 +14796,13 @@
#: ../imagery/i.maxlik/main.c:67
#, fuzzy
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, i.class, or i.gensig."
-msgstr ""
-"Fonction d'imagerie qui fait une classification des réflectances spectrales "
-"des cellules de données images à partir des informations de signatures "
-"spectrales générées soit par i.cluster, i.class, ou i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
+msgstr "Fonction d'imagerie qui fait une classification des réflectances spectrales des cellules de données images à partir des informations de signatures spectrales générées soit par i.cluster, i.class, ou i.gensig."
#: ../imagery/i.maxlik/main.c:80
#, fuzzy
msgid "Generated by either i.cluster, i.class, or i.gensig"
-msgstr ""
#: ../imagery/i.maxlik/main.c:85
#, fuzzy
@@ -15834,18 +14816,14 @@
#: ../imagery/i.maxlik/open.c:26
#, fuzzy, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
msgstr ""
"Le sous-groupe [%s] du groupe [%s] ne contient aucun fichier.\n"
"Le sous-groupe doit contenir au moins 2 fichiers."
#: ../imagery/i.maxlik/open.c:29
#, fuzzy, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
msgstr ""
"Le sous-groupe [%s] du groupe [%s] ne contient qu'un fichier.\n"
@@ -15877,15 +14855,11 @@
msgstr "fichier 3dview <%s> non trouvé"
#: ../imagery/i.landsat.toar/main.c:67
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
msgstr ""
#: ../imagery/i.landsat.toar/main.c:69
-msgid ""
-"imagery, Landsat, radiance, reflectance, brightness temperature, atmospheric "
-"correction"
+msgid "imagery, Landsat, radiance, reflectance, brightness temperature, atmospheric correction"
msgstr ""
#: ../imagery/i.landsat.toar/main.c:81
@@ -15910,10 +14884,7 @@
msgstr ""
#: ../imagery/i.landsat.toar/main.c:101
-msgid ""
-"mss1;Landsat_1 MSS;mss2;Landsat_2 MSS;mss3;Landsat_3 MSS;mss4;Landsat_4 MSS;"
-"mss5;Landsat_5 MSS;tm4;Landsat_4 TM;tm5;Landsat_5 TM;tm7;Landsat_7 ETM+;oli8;"
-"Landsat_8 OLI/TIRS"
+msgid "mss1;Landsat_1 MSS;mss2;Landsat_2 MSS;mss3;Landsat_3 MSS;mss4;Landsat_4 MSS;mss5;Landsat_5 MSS;tm4;Landsat_4 TM;tm5;Landsat_5 TM;tm7;Landsat_7 ETM+;oli8;Landsat_8 OLI/TIRS"
msgstr ""
#: ../imagery/i.landsat.toar/main.c:118 ../imagery/i.landsat.toar/main.c:119
@@ -15968,8 +14939,7 @@
msgstr ""
#: ../imagery/i.landsat.toar/main.c:194
-msgid ""
-"Input raster maps use as extension the number of the band instead the code"
+msgid "Input raster maps use as extension the number of the band instead the code"
msgstr ""
#: ../imagery/i.landsat.toar/main.c:198
@@ -16041,8 +15011,7 @@
#: ../imagery/i.class/signature.c:113
#, c-format
msgid "prepare_signature: scan line %d has odd number of points."
-msgstr ""
-"prepare_signature : la ligne de scan %d a un nombre de points aberrant."
+msgstr "prepare_signature : la ligne de scan %d a un nombre de points aberrant."
#: ../imagery/i.class/signature.c:123
msgid "signature: perimeter points out of order."
@@ -16062,8 +15031,7 @@
#: ../imagery/i.class/signature.c:278
msgid "Unable to allocate the cell buffer in display_signature()."
-msgstr ""
-"Impossible d'allouer la mémoire tampon des cellules dans display_signature()."
+msgstr "Impossible d'allouer la mémoire tampon des cellules dans display_signature()."
#: ../imagery/i.class/signature.c:310
msgid "Did not find input cell map MASK."
@@ -16076,8 +15044,7 @@
#: ../imagery/i.class/add_point.c:22
#, c-format
msgid "Can't mark another point. Only %d points allowed. Sorry."
-msgstr ""
-"Impossible d'ajouter un autre point. Seulement %d points permis. Désolé."
+msgstr "Impossible d'ajouter un autre point. Seulement %d points permis. Désolé."
#: ../imagery/i.class/draw_reg.c:89
#, c-format
@@ -16131,21 +15098,13 @@
msgstr "Nom de fichier de signatures à utiliser pour la classification"
#: ../imagery/i.class/main.c:55
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
msgstr ""
#: ../imagery/i.class/main.c:58
#, fuzzy
-msgid ""
-"The resulting signature file can be used as input for i.maxlik or as a seed "
-"signature file for i.cluster."
-msgstr ""
-"Une fonction de traitement d'images qui génère des signatures spectrales "
-"pour une image en permettant à l'utilisateur de sélectionner des zones "
-"d'intérêt. Le fichier de signatures en sortie peut être utilisé en entrée de "
-"i.maxlik ou comme fichier germe pour i.cluster."
+msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
+msgstr "Une fonction de traitement d'images qui génère des signatures spectrales pour une image en permettant à l'utilisateur de sélectionner des zones d'intérêt. Le fichier de signatures en sortie peut être utilisé en entrée de i.maxlik ou comme fichier germe pour i.cluster."
#: ../imagery/i.class/main.c:62 ../display/d.rast/main.c:57
#, fuzzy
@@ -16205,8 +15164,7 @@
#: ../imagery/i.class/main.c:232
#, fuzzy
msgid "Unable to read cell header for first band file"
-msgstr ""
-"Impossible de lire l'en-tête de cellule pour le fichier de première bande"
+msgstr "Impossible de lire l'en-tête de cellule pour le fichier de première bande"
#: ../imagery/i.class/main.c:237
msgid ""
@@ -16263,8 +15221,7 @@
#: ../imagery/i.class/complete_reg.c:12
msgid "Too few points for region. Must have at least 3 points."
-msgstr ""
-"Trop peu de points pour cette région. Vous devez entrer au moins 3 points."
+msgstr "Trop peu de points pour cette région. Vous devez entrer au moins 3 points."
#: ../imagery/i.class/complete_reg.c:14
msgid "Area already completed."
@@ -16427,9 +15384,7 @@
#: ../imagery/i.gensig/get_train.c:53 ../imagery/i.gensigset/get_train.c:57
#, fuzzy, c-format
msgid "Training class %d only has one cell - this class will be ignored"
-msgstr ""
-"La classe d'apprentissage [%d] n'a qu'une cellule - cette classe sera "
-"ignorée."
+msgstr "La classe d'apprentissage [%d] n'a qu'une cellule - cette classe sera ignorée."
#: ../imagery/i.gensig/get_train.c:58 ../imagery/i.gensigset/get_train.c:62
#, fuzzy
@@ -16479,9 +15434,7 @@
msgstr "Affiche l'information topologique (déboguage)"
#: ../imagery/i.his.rgb/h2rmain.c:47
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
msgstr ""
#: ../imagery/i.his.rgb/h2rmain.c:53
@@ -16576,12 +15529,8 @@
#: ../imagery/i.rectify/main.c:92
#, fuzzy
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-"Recale une image en calculer la transformation de coordonnées pour chaque "
-"pixel de l'image basée sur des points d'amer"
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr "Recale une image en calculer la transformation de coordonnées pour chaque pixel de l'image basée sur des points d'amer"
#: ../imagery/i.rectify/main.c:106
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:100
@@ -16607,11 +15556,8 @@
#: ../imagery/i.rectify/main.c:141
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:134
#, fuzzy
-msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
-msgstr ""
-"Utiliser les paramètres de la région courante dans le Secteur en sortie (déf."
-"= calculer la plus petite surface)"
+msgid "Use current region settings in target location (def.=calculate smallest area)"
+msgstr "Utiliser les paramètres de la région courante dans le Secteur en sortie (déf.= calculer la plus petite surface)"
#: ../imagery/i.rectify/main.c:145
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:138
@@ -16780,8 +15726,7 @@
#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:13
#, fuzzy, c-format
msgid "Target information for group <%s> missing"
-msgstr ""
-"Information sur l'intervalle des valeurs pour [%s] n'est pas disponible"
+msgstr "Information sur l'intervalle des valeurs pour [%s] n'est pas disponible"
#: ../imagery/i.rectify/target.c:20
#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:19
@@ -16807,8 +15752,7 @@
#: ../imagery/i.target/main.c:67
msgid "Set current location and mapset as target for of imagery group"
-msgstr ""
-"Règle le Secteur courant et le jeu de donnée comme cible du groupe d'images"
+msgstr "Règle le Secteur courant et le jeu de donnée comme cible du groupe d'images"
#: ../imagery/i.target/main.c:89 ../imagery/i.target/main.c:106
#: ../imagery/i.target/main.c:115
@@ -16828,8 +15772,7 @@
" OR\n"
" manually enter the variables"
msgstr ""
-"Vous devez utiliser le drapeau pour utiliser le jeu de données et le Secteur "
-"courants(-c)\n"
+"Vous devez utiliser le drapeau pour utiliser le jeu de données et le Secteur courants(-c)\n"
" OU\n"
" entrer les variables à la main."
@@ -16839,9 +15782,7 @@
msgstr "Impossible de lire le symbole, impossible d'afficher les points"
#: ../imagery/i.vpoints/main.c:96
-msgid ""
-"Set registration points for an imagery group from a vector map or keyboard "
-"entry."
+msgid "Set registration points for an imagery group from a vector map or keyboard entry."
msgstr ""
#: ../imagery/i.topo.corr/correction.c:100
@@ -16940,21 +15881,16 @@
#: ../imagery/i.ifft/ifftmain.c:101
#, fuzzy
-msgid ""
-"Unable to open real-image in the 'cell_misc' directory. Raster map probably "
-"wasn't created by i.fft"
+msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
msgstr ""
"Impossible d'ouvrir l'image (partie réelle) dans le répertoire cell_misc.\n"
"La couche en entrée n'a pas été créée par i.fft"
#: ../imagery/i.ifft/ifftmain.c:111
#, fuzzy
-msgid ""
-"Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
-"probably wasn't created by i.fft"
+msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
msgstr ""
-"Impossible d'ouvrir l'image (partie imaginaire) dans le répertoire "
-"cell_misc.\n"
+"Impossible d'ouvrir l'image (partie imaginaire) dans le répertoire cell_misc.\n"
#: ../imagery/i.ifft/ifftmain.c:134
@@ -17011,9 +15947,7 @@
#: ../imagery/i.fft/fftmain.c:115
msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
-msgstr ""
-"MASK raster trouvé, penser à le supprimer (voir la page du manuel). "
-"Poursuite..."
+msgstr "MASK raster trouvé, penser à le supprimer (voir la page du manuel). Poursuite..."
#: ../imagery/i.fft/fftmain.c:129
#, fuzzy
@@ -17037,9 +15971,7 @@
#: ../imagery/i.fft/fftmain.c:231
#, fuzzy
msgid "Writing viewable versions of transformed data..."
-msgstr ""
-"Ecriture des versions visualisables des données transformées dans les "
-"fichiers..."
+msgstr "Ecriture des versions visualisables des données transformées dans les fichiers..."
#: ../imagery/i.fft/fftmain.c:274
msgid " "
@@ -17080,10 +16012,7 @@
msgstr "Nom de la couche source"
#: ../imagery/i.modis.qc/main.c:110
-msgid ""
-"mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;"
-"surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;"
-"LST 1Km 8-days (Day/Night);"
+msgid "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);"
msgstr ""
#: ../imagery/i.modis.qc/main.c:122
@@ -17092,27 +16021,7 @@
msgstr "Nom de la couche raster plane à créer."
#: ../imagery/i.modis.qc/main.c:123
-msgid ""
-"adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;"
-"cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;"
-"diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;"
-"modland_qa_bits;mod09: MODIS Land General Quality Assessment;"
-"mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;"
-"data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;"
-"mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average "
-"LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality "
-"Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;"
-"mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;"
-"lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: "
-"StateQA Internal Snow Mask;brdf_correction_performed;mod09A1s: StateQA "
-"Internal Snow Mask;cirrus_detected;mod09A1s: StateQA Internal Snow Mask;"
-"cloud_shadow;mod09A1s: StateQA Internal Snow Mask;cloud_state;mod09A1s: "
-"StateQA Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA "
-"Internal Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow "
-"Mask;internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;"
-"mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA "
-"Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow "
-"Mask;"
+msgid "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa_bits;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Mask;brdf_correction_performed;mod09A1s: StateQA Internal Snow Mask;cirrus_detected;mod09A1s: StateQA Internal Snow Mask;cloud_shadow;mod09A1s: StateQA Internal Snow Mask;cloud_state;mod09
A1s: StateQA Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Mask;"
msgstr ""
#: ../imagery/i.modis.qc/main.c:157
@@ -17120,10 +16029,7 @@
msgstr ""
#: ../imagery/i.modis.qc/main.c:158
-msgid ""
-"1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;"
-"mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;"
-"mod09A1 Band 7: SWIR 3;"
+msgid "1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;mod09A1 Band 7: SWIR 3;"
msgstr ""
#: ../imagery/i.modis.qc/main.c:181
@@ -17223,8 +16129,7 @@
#: ../imagery/i.cca/main.c:86
msgid "Canonical components analysis (cca) program for image processing."
-msgstr ""
-"Programme de traitement d'image en analyse en composante canonique (cca)"
+msgstr "Programme de traitement d'image en analyse en composante canonique (cca)"
#: ../imagery/i.cca/main.c:99
#, fuzzy
@@ -17274,17 +16179,12 @@
#: ../imagery/i.cca/main.c:140
msgid "Need at least two signatures in signature file."
-msgstr ""
-"Il faut au moins deux signatures dans le fichier de signatures spectrales."
+msgstr "Il faut au moins deux signatures dans le fichier de signatures spectrales."
#: ../imagery/i.cca/main.c:240
#, fuzzy, c-format
-msgid ""
-"The output cell map <%s.%d> has values outside the 0-255 range. Min: %d Max: "
-"%d"
-msgstr ""
-"La couche de sortie <%s.%d> possède des valeurs en dehors de l'intervalle "
-"0-255.\n"
+msgid "The output cell map <%s.%d> has values outside the 0-255 range. Min: %d Max: %d"
+msgstr "La couche de sortie <%s.%d> possède des valeurs en dehors de l'intervalle 0-255.\n"
#: ../imagery/i.cca/transform.c:24
msgid "Unable to allocate cell buffers."
@@ -17440,21 +16340,13 @@
#: ../imagery/i.cluster/main.c:82
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
msgstr ""
#: ../imagery/i.cluster/main.c:85
#, fuzzy
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
-msgstr ""
-"Fonction de traitement d'image qui génère des signatures spectrales pour les "
-"types de couverture du sol dans une image en utilisant un algorithme à "
-"cluster. Le fichier de signature résultat est utilisé en entrée pour i."
-"maxlik, pour générer une classification d'image non-supervisée."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
+msgstr "Fonction de traitement d'image qui génère des signatures spectrales pour les types de couverture du sol dans une image en utilisant un algorithme à cluster. Le fichier de signature résultat est utilisé en entrée pour i.maxlik, pour générer une classification d'image non-supervisée."
#: ../imagery/i.cluster/main.c:105
msgid "Initial number of classes"
@@ -17467,9 +16359,7 @@
#: ../imagery/i.cluster/main.c:121
msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
-msgstr ""
-"Intervalle d'échantillonnage (par ligne et colonne); par défaut: ~10,000 "
-"pixels"
+msgstr "Intervalle d'échantillonnage (par ligne et colonne); par défaut: ~10,000 pixels"
#: ../imagery/i.cluster/main.c:128
msgid "Maximum number of iterations"
@@ -17664,8 +16554,7 @@
#: ../imagery/i.cluster/main.c:298
#, fuzzy
msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr ""
-"Mémoire insuffisante. Rééxécuter en choisissant un échantillon plus petit."
+msgstr "Mémoire insuffisante. Rééxécuter en choisissant un échantillon plus petit."
#: ../imagery/i.cluster/main.c:304
#, c-format
@@ -17674,19 +16563,13 @@
#: ../imagery/i.cluster/main.c:307
#, fuzzy
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
-msgstr ""
-"Points échantillonnées insuffisants. Rééxécuter en choisissant un plus large "
-"échantillon."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
+msgstr "Points échantillonnées insuffisants. Rééxécuter en choisissant un plus large échantillon."
#: ../imagery/i.cluster/main.c:311
#, fuzzy
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
-msgstr ""
-"Echantillon insuffisant de points de données non-nuls. Vérifiez votre région "
-"courante (et le masque appliqué)"
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr "Echantillon insuffisant de points de données non-nuls. Vérifiez votre région courante (et le masque appliqué)"
#: ../imagery/i.cluster/main.c:324
#, c-format
@@ -17705,9 +16588,7 @@
#: ../imagery/i.cluster/main.c:336
#, fuzzy, c-format
msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr ""
-"Impossible d'écrire le fichier de signature <%s> pour le groupe <%s>, sous-"
-"groupe <%s>"
+msgstr "Impossible d'écrire le fichier de signature <%s> pour le groupe <%s>, sous-groupe <%s>"
#: ../imagery/i.cluster/main.c:341
#, c-format
@@ -17790,8 +16671,7 @@
#: ../imagery/i.pca/main.c:67
#, fuzzy
msgid "Principal components analysis (PCA) for image processing."
-msgstr ""
#: ../imagery/i.pca/main.c:72
#, fuzzy
@@ -17858,9 +16738,7 @@
msgstr "Calcul des moyennes de classes..."
#: ../imagery/i.rgb.his/r2hmain.c:47
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
msgstr ""
#: ../imagery/i.rgb.his/r2hmain.c:53
@@ -17936,9 +16814,7 @@
msgstr "groupes d'images"
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:88
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
msgstr ""
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:129
@@ -18062,8 +16938,7 @@
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:91
#, fuzzy, c-format
msgid "Target information for group [%s] missing\n"
-msgstr ""
# c-format
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:98
@@ -18245,9 +17120,7 @@
msgstr "groupe [%s] ciblé dans le Secteur [%s], jeu de données [%s]\n"
#: ../imagery/i.ortho.photo/i.photo.init/main.c:46
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
msgstr ""
#: ../imagery/i.ortho.photo/i.photo.init/main.c:64
@@ -18259,8 +17132,7 @@
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:54
#, fuzzy
msgid "Creates control points on an image to be ortho-rectified."
-msgstr ""
-"Placer des points de contrôle sur une image pour le recalage de l'orthophoto."
+msgstr "Placer des points de contrôle sur une image pour le recalage de l'orthophoto."
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:66
#, fuzzy
@@ -18269,10 +17141,8 @@
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:72
#, fuzzy
-msgid ""
-"Name of a map from target mapset which will be initially drawn on screen"
-msgstr ""
-"Nom de la couche de données du jeu de données cible à afficher à l'écran."
+msgid "Name of a map from target mapset which will be initially drawn on screen"
+msgstr "Nom de la couche de données du jeu de données cible à afficher à l'écran."
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:114
#: ../imagery/i.ortho.photo/i.photo.2image/main.c:98
@@ -18329,8 +17199,7 @@
#: ../imagery/i.ortho.photo/i.photo.camera/main.c:57
#, fuzzy
-msgid ""
-"Interactively select and modify the imagery group camera reference file."
+msgid "Interactively select and modify the imagery group camera reference file."
msgstr "Sélectionner de façon interactive l'itinéraire"
#: ../imagery/i.ortho.photo/i.photo.camera/main.c:68
@@ -18417,9 +17286,7 @@
#: ../ps/ps.map/ps_vlines.c:123
#, fuzzy, c-format
msgid "Invalid RGB color definition in column <%s> for category [%d]"
-msgstr ""
-"Erreur dans la colonne de définition de couleur (%s), entité surfacique %d "
-"avec la catégorie %d"
+msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d"
#: ../ps/ps.map/r_instructions.c:57
#, fuzzy
@@ -18538,9 +17405,7 @@
#: ../vector/v.label.sa/labels.c:81
#, fuzzy
msgid "Unable to get layer info for vector map"
-msgstr ""
-"Impossible de récupérer les informations de la couche pour cette couche "
-"vectorielle"
+msgstr "Impossible de récupérer les informations de la couche pour cette couche vectorielle"
# c-format
#: ../ps/ps.map/catval.c:64
@@ -18586,9 +17451,7 @@
#: ../ps/ps.map/r_vpoints.c:243
#, c-format
-msgid ""
-"The mapping instruction <%s> will be renamed to <%s> in future versions of "
-"GRASS. Please use <%s> instead."
+msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
msgstr ""
#: ../ps/ps.map/ps_outline.c:41
@@ -18661,9 +17524,7 @@
#: ../ps/ps.map/ps_fclrtbl.c:63
#, fuzzy
msgid "A floating point colortable must contain a range of values"
-msgstr ""
-"Une table de couleurs en valeurs flottante doit contenir un ensemble de "
-"valeurs"
+msgstr "Une table de couleurs en valeurs flottante doit contenir un ensemble de valeurs"
#: ../ps/ps.map/ps_fclrtbl.c:68 ../ps/ps.map/ps_clrtbl.c:43
msgid "Unable to read colors for colorbar"
@@ -18672,16 +17533,12 @@
#: ../ps/ps.map/ps_fclrtbl.c:91 ../ps/ps.map/ps_fclrtbl.c:96
#: ../ps/ps.map/ps_clrtbl.c:68
msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-"Emplacement vertical (y) de la légende couleur en dehors des limites de la "
-"page. Ajustement automatique."
+msgstr "Emplacement vertical (y) de la légende couleur en dehors des limites de la page. Ajustement automatique."
#: ../ps/ps.map/ps_fclrtbl.c:102 ../ps/ps.map/ps_fclrtbl.c:107
#: ../ps/ps.map/ps_clrtbl.c:74
msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-"Emplacement horizontal (x) de la légende couleur en dehors des limites de la "
+msgstr "Emplacement horizontal (x) de la légende couleur en dehors des limites de la page. Ajustement automatique."
#: ../ps/ps.map/getgrid.c:94 ../ps/ps.map/getgrid.c:205
#, fuzzy
@@ -18734,8 +17591,7 @@
#: ../ps/ps.map/do_labels.c:42
#, c-format
msgid "Can't open label file <%s> in mapset <%s>"
-msgstr ""
-"impossible d'ouvrir le fichier d'étiquettes <%s> dans le jeu de données <%s>"
+msgstr "impossible d'ouvrir le fichier d'étiquettes <%s> dans le jeu de données <%s>"
# c-format
#: ../ps/ps.map/do_labels.c:46
@@ -18756,9 +17612,7 @@
#: ../ps/ps.map/do_labels.c:160
msgid "Text labels: 'fontsize' given so ignoring 'size'"
-msgstr ""
-"Etiquettes texte : 'fontsize' (taille de police) spécifiée, on ignore donc "
-"le paramètre 'size'"
+msgstr "Etiquettes texte : 'fontsize' (taille de police) spécifiée, on ignore donc le paramètre 'size'"
#: ../ps/ps.map/main.c:77
msgid "postscript, map, printing"
@@ -18776,9 +17630,7 @@
#: ../ps/ps.map/main.c:88
#, fuzzy
msgid "List paper formats (name width height left right top bottom(margin))"
-msgstr ""
-"Afficher le format papier (nom largeur hauteur gauche droite haut bas "
-"(marges) )"
+msgstr "Afficher le format papier (nom largeur hauteur gauche droite haut bas (marges) )"
#: ../ps/ps.map/main.c:89 ../ps/ps.map/main.c:101
msgid "Utility"
@@ -18786,13 +17638,10 @@
#: ../ps/ps.map/main.c:94
msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
-msgstr ""
-"Créer un EPS (Encapsulated PostScript) à la place du fichier PostScript"
+msgstr "Créer un EPS (Encapsulated PostScript) à la place du fichier PostScript"
#: ../ps/ps.map/main.c:100
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
msgstr ""
#: ../ps/ps.map/main.c:104
@@ -18811,9 +17660,7 @@
#: ../ps/ps.map/main.c:119
msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-msgstr ""
-"Echelle de la carte en sortie, par exemple 1:25000 (par défaut, ajusté à la "
-"page)"
+msgstr "Echelle de la carte en sortie, par exemple 1:25000 (par défaut, ajusté à la page)"
#: ../ps/ps.map/main.c:126
msgid "Number of copies to print"
@@ -18827,13 +17674,8 @@
#: ../ps/ps.map/main.c:206
#, fuzzy, c-format
-msgid ""
-"Using <%s> from the command line is depreciated. Please use the <%s> mapping "
-"instruction instead. The parameter <%s> will be removed in future versions "
-"of GRASS."
-msgstr ""
-"Utiliser \"scale\" à partir de la console est obsolète. Veuillez utilisez "
-"l'instruction de mise en page cartographique \"scale\" à la place."
+msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
+msgstr "Utiliser \"scale\" à partir de la console est obsolète. Veuillez utilisez l'instruction de mise en page cartographique \"scale\" à la place."
#: ../ps/ps.map/main.c:232 ../vector/v.univar/main.c:149
#, fuzzy, c-format
@@ -18891,15 +17733,8 @@
#: ../ps/ps.map/ps_clrtbl.c:53
#, fuzzy
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
-msgstr ""
-"Votre fichier cats/ est invalide. Un fichier cats/ avec catégories et "
-"étiquettes est requis pour la table de couleurs en utilisant les rasters "
-"CELL. Aucune table de couleurs ne seraassignée au fichier postscript en "
-"sortie."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
+msgstr "Votre fichier cats/ est invalide. Un fichier cats/ avec catégories et étiquettes est requis pour la table de couleurs en utilisant les rasters CELL. Aucune table de couleurs ne seraassignée au fichier postscript en sortie."
#: ../ps/ps.map/do_plt.c:40
#, fuzzy
@@ -18917,11 +17752,8 @@
msgstr "Afficher l'index"
#: ../display/d.paint.labels/main.c:48
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
-msgstr ""
-"Affiche des étiquettes de texte (créées avec v.label) dans le moniteur actif"
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
+msgstr "Affiche des étiquettes de texte (créées avec v.label) dans le moniteur actif"
#: ../display/d.paint.labels/main.c:54
msgid "Ignore rotation setting and draw horizontally"
@@ -18933,13 +17765,11 @@
#: ../display/d.paint.labels/main.c:68
msgid "Minimum region size (diagonal) when labels are displayed"
-msgstr ""
-"Taille minimum de la région (diagonale) quand les étiquettes sont affichées"
+msgstr "Taille minimum de la région (diagonale) quand les étiquettes sont affichées"
#: ../display/d.paint.labels/main.c:75
msgid "Maximum region size (diagonal) when labels are displayed"
-msgstr ""
-"Taille maximum de la région (diagonale) quand les étiquettes sont affichées"
+msgstr "Taille maximum de la région (diagonale) quand les étiquettes sont affichées"
# c-format
#: ../display/d.paint.labels/main.c:87
@@ -18949,13 +17779,11 @@
#: ../display/d.paint.labels/main.c:102 ../display/d.vect/main.c:387
msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
-"La taille de la région est plus petite que minreg, rien n'a été affiché."
+msgstr "La taille de la région est plus petite que minreg, rien n'a été affiché."
#: ../display/d.paint.labels/main.c:111 ../display/d.vect/main.c:396
msgid "Region size is greater than maxreg, nothing displayed."
-msgstr ""
-"La taille de la région est plus grande que maxreg, rien n'a été affiché."
+msgstr "La taille de la région est plus grande que maxreg, rien n'a été affiché."
# c-format
#: ../display/d.paint.labels/main.c:121 ../vector/v.lrs/v.lrs.label/main.c:299
@@ -19014,12 +17842,8 @@
msgstr "Statistiques de transition de classe."
#: ../display/d.histogram/main.c:73
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
-msgstr ""
-"Affiche un histogramme sous forme de diagramme en barre ou d'un diagramme "
-"camembert pour un fichier raster spécifié par l'utilisateur."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
+msgstr "Affiche un histogramme sous forme de diagramme en barre ou d'un diagramme camembert pour un fichier raster spécifié par l'utilisateur."
#: ../display/d.histogram/main.c:77
msgid "Raster map for which histogram will be displayed"
@@ -19027,8 +17851,7 @@
#: ../display/d.histogram/main.c:81
msgid "Indicate if a pie or bar chart is desired"
-msgstr ""
-"Indique si l'on a besoin d'un diagramme en barre ou d'un diagramme camembert"
+msgstr "Indique si l'on a besoin d'un diagramme en barre ou d'un diagramme camembert"
#: ../display/d.histogram/main.c:90
#, fuzzy
@@ -19041,9 +17864,7 @@
#: ../display/d.histogram/main.c:108
msgid "Number of steps to divide the data range into (fp maps only)"
-msgstr ""
-"Nombre d'étapes pour la division des intervalles de données (couches en "
-"points flottants seulement)"
+msgstr "Nombre d'étapes pour la division des intervalles de données (couches en points flottants seulement)"
#: ../display/d.histogram/main.c:115
msgid "Display information for null cells"
@@ -19055,9 +17876,7 @@
#: ../display/d.histogram/main.c:124
msgid "Report for ranges defined in cats file (fp maps only)"
-msgstr ""
-"Examen des catégories en nombres à virgule flottante (couches en virgule "
-"flottante uniquement)"
+msgstr "Examen des catégories en nombres à virgule flottante (couches en virgule flottante uniquement)"
#: ../display/d.histogram/main.c:149
#, c-format
@@ -19071,8 +17890,7 @@
#: ../display/d.histogram/main.c:171 ../display/d.legend/main.c:508
#, fuzzy, c-format
msgid "Range information for <%s> not available"
-msgstr ""
#: ../display/d.vect/dir.c:31 ../display/d.vect/attr.c:53
#: ../display/d.vect/label.c:28
@@ -19116,20 +17934,14 @@
#: ../display/d.vect/main.c:79
#, fuzzy
msgid "Displays user-specified vector map in the active graphics frame."
-msgstr ""
-"Afficher trois couches rasters spécifiées par l'utilisateur comme calques "
-"rouge, vert, bleu superposés dans le moniteur actif."
+msgstr "Afficher trois couches rasters spécifiées par l'utilisateur comme calques rouge, vert, bleu superposés dans le moniteur actif."
#: ../display/d.vect/main.c:91
msgid "Display"
msgstr "Afficher"
#: ../display/d.vect/main.c:92
-msgid ""
-"shape;Display geometry of features;cat;Display category numbers of features;"
-"topo;Display topology information (nodes, edges);dir;Display direction of "
-"linear features;attr;Display selected attribute based on 'attrcol';zcoor;"
-"Display z-coordinate of features (only for 3D vector maps)"
+msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
msgstr ""
#: ../display/d.vect/main.c:103 ../display/d.vect/main.c:109
@@ -19197,9 +18009,7 @@
#: ../display/d.vect/main.c:239 ../display/d.vect/main.c:249
#, fuzzy
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr ""
-"Couleur de fond, soit une couleur GRASS standard, soit un triplet R:G:B, "
-"soit aucune \"none\""
+msgstr "Couleur de fond, soit une couleur GRASS standard, soit un triplet R:G:B, soit aucune \"none\""
#: ../display/d.vect/main.c:132
msgid "Area fill color"
@@ -19207,16 +18017,12 @@
#: ../display/d.vect/main.c:141
msgid "Name of color definition column (for use with -a flag)"
-msgstr ""
-"Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -"
-"a)"
+msgstr "Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -a)"
#: ../display/d.vect/main.c:149
#, fuzzy
msgid "Type of color table (for use with -z flag)"
-msgstr ""
-"a)"
#: ../display/d.vect/main.c:158 ../display/d.vect/main.c:163
#: ../display/d.vect/main.c:171
@@ -19229,9 +18035,7 @@
#: ../display/d.vect/main.c:165
msgid "Name of column for line widths (these values will be scaled by wscale)"
-msgstr ""
-"Nom de la colonne pour l'épaisseur de la ligne (ces valeurs seront mise à "
-"l'échelle par wscale)"
+msgstr "Nom de la colonne pour l'épaisseur de la ligne (ces valeurs seront mise à l'échelle par wscale)"
#: ../display/d.vect/main.c:172
msgid "Scale factor for wcolumn"
@@ -19319,44 +18123,28 @@
msgstr "Justification verticale des étiquettes"
#: ../display/d.vect/main.c:285
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
-msgstr ""
-"Taille minimum de la région (hauteur et largeur moyenne) quand la couche est "
-"affichée"
+msgid "Minimum region size (average from height and width) when map is displayed"
+msgstr "Taille minimum de la région (hauteur et largeur moyenne) quand la couche est affichée"
#: ../display/d.vect/main.c:293
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
-msgstr ""
-"Taille maximum de la région (hauteur et largeur moyenne) quand la couche est "
-"affichée"
+msgid "Maximum region size (average from height and width) when map is displayed"
+msgstr "Taille maximum de la région (hauteur et largeur moyenne) quand la couche est affichée"
#: ../display/d.vect/main.c:303 ../display/d.thematic.area/main.c:157
msgid "Rendering method for filled polygons"
msgstr ""
#: ../display/d.vect/main.c:305
-msgid ""
-"g;use the libgis render functions (features: clipping);r;use the raster "
-"graphics library functions (features: polylines);d;use the display library "
-"basic functions (features: polylines);c;use the display library clipping "
-"functions (features: clipping);l;use the display library culling functions "
-"(features: culling, polylines)"
+msgid "g;use the libgis render functions (features: clipping);r;use the raster graphics library functions (features: polylines);d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
msgstr ""
#: ../display/d.vect/main.c:321
msgid "Get colors from map table column (of form RRR:GGG:BBB)"
-msgstr ""
-"Prendre les couleurs dans la table de la couche (sous forme RRR:GGG:BBB)"
+msgstr "Prendre les couleurs dans la table de la couche (sous forme RRR:GGG:BBB)"
#: ../display/d.vect/main.c:327
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is "
-"given)"
-msgstr ""
-"Couleurs aléatoires en fonction du code de catégorie (ou du code de la "
-"couche si 'layer=-1' "
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
+msgstr "Couleurs aléatoires en fonction du code de catégorie (ou du code de la couche si 'layer=-1' "
#: ../display/d.vect/main.c:334
#, fuzzy
@@ -19364,21 +18152,15 @@
msgstr "Utilisez les valeurs de l'option 'cats' comme ID ligne"
#: ../display/d.vect/main.c:339
-msgid ""
-"Don't add to list of vectors and commands in monitor (it won't be drawn if "
-"the monitor is refreshed)"
-msgstr ""
-"Ne pas ajouter la liste des vecteurs dans le moniteur (cela ne sera pas "
-"afficher sile moniteur est rafraîchi"
+msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
+msgstr "Ne pas ajouter la liste des vecteurs dans le moniteur (cela ne sera pas afficher sile moniteur est rafraîchi"
#: ../display/d.vect/main.c:344
msgid "Colorize polygons according to z height"
msgstr ""
#: ../display/d.vect/main.c:411
-msgid ""
-"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
-"ignored!"
+msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
msgstr ""
# c-format
@@ -19428,17 +18210,13 @@
#: ../display/d.vect/main.c:591 ../display/d.thematic.area/main.c:408
#, fuzzy
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
-msgstr ""
-"Les limites de la couche sont en-dehors de la région courante, rien n'a été "
-"affiché.\n"
+msgid "The bounding box of the map is outside the current region, nothing drawn."
+msgstr "Les limites de la couche sont en-dehors de la région courante, rien n'a été affiché.\n"
#: ../display/d.vect/main.c:625
#, fuzzy
msgid "Unable to display areas, topology not available"
-msgstr ""
-"Impossible d'afficher les entités surfaciques, topologie non disponible"
+msgstr "Impossible d'afficher les entités surfaciques, topologie non disponible"
#: ../display/d.vect/main.c:630
#, fuzzy
@@ -19456,14 +18234,8 @@
#: ../display/d.vect/area.c:83 ../display/d.vect/plot1.c:233
#, fuzzy, c-format
-msgid ""
-"Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:"
-"BBB' where RGB values range 0-255. You can use '%s' module to define color "
-"rules. Unable to colorize features."
-msgstr ""
-"La colonne de définition de couleur (%s) n'est pas une chaîne de caractère."
-"La colonne doit être de la forme RRR:GGG:BBB ou les valeurs RGB sont "
-"comprises dans l'intervalle 0-255."
+msgid "Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to define color rules. Unable to colorize features."
+msgstr "La colonne de définition de couleur (%s) n'est pas une chaîne de caractère.La colonne doit être de la forme RRR:GGG:BBB ou les valeurs RGB sont comprises dans l'intervalle 0-255."
#: ../display/d.vect/area.c:93 ../display/d.vect/area.c:136
#: ../display/d.vect/plot1.c:243 ../display/d.vect/plot1.c:284
@@ -19487,27 +18259,19 @@
#: ../display/d.vect/area.c:302
#, c-format
-msgid ""
-"Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
-msgstr ""
-"avec la catégorie %d: code couleur [%s]"
+msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
+msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d: code couleur [%s]"
#: ../display/d.vect/area.c:308
#, c-format
msgid "Error in color definition column (%s), area %d with cat %d"
-msgstr ""
#: ../display/d.vect/area.c:369 ../display/d.vect/plot1.c:587
#: ../display/d.thematic.area/plot1.c:444
#, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
-msgstr ""
-"Erreur dans la colonne de définition de couleur (%s), élément %d avec la "
-"catégorie %d: largeur de ligne [%d]"
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgstr "Erreur dans la colonne de définition de couleur (%s), élément %d avec la catégorie %d: largeur de ligne [%d]"
#: ../display/d.vect/plot1.c:222 ../display/d.thematic.area/plot1.c:210
#, fuzzy
@@ -19554,34 +18318,23 @@
#: ../display/d.vect/plot1.c:511
#, fuzzy, c-format
-msgid ""
-"Error in color definition column '%s', feature id %d with cat %d: "
-"colorstring '%s'"
-msgstr ""
+msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
#: ../display/d.vect/plot1.c:519
#, fuzzy, c-format
msgid "Error in color definition column '%s', feature id %d with cat %d"
-msgstr ""
#: ../display/d.vect/plot1.c:641
#, fuzzy, c-format
-msgid ""
-"Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
-msgstr ""
+msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
#: ../display/d.vect/plot1.c:729
#, fuzzy, c-format
msgid "Error in color definition column '%s': %d features affected"
-msgstr ""
#: ../display/d.mapgraph/main.c:48 ../display/d.text/main.c:66
#: ../display/d.linegraph/linegraph.c:113 ../display/d.vect.chart/main.c:63
@@ -19593,28 +18346,16 @@
msgstr "affichage, cartoraphie"
#: ../display/d.mapgraph/main.c:50
-msgid ""
-"Generates and displays simple graphics on map layers drawn in the active "
-"graphics monitor display frame."
-msgstr ""
-"Génére et affiche des graphiques sur les couches de données affichées dans "
-"le moniteur actif."
+msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
+msgstr "Génére et affiche des graphiques sur les couches de données affichées dans le moniteur actif."
#: ../display/d.mapgraph/main.c:57
-msgid ""
-"Unix file containg graphing instructions, if not given reads from standard "
-"input"
-msgstr ""
-"Le fichier Unix contient les instruction de dessin, s'il n'y en a pas partir "
-"des instructions de la ligne de commande"
+msgid "Unix file containg graphing instructions, if not given reads from standard input"
+msgstr "Le fichier Unix contient les instruction de dessin, s'il n'y en a pas partir des instructions de la ligne de commande"
#: ../display/d.mapgraph/main.c:67
-msgid ""
-"Color to draw with, either a standard GRASS color or R:G:B triplet "
-"(separated by colons)"
-msgstr ""
-"Couleur de traçage, soit une couleur GRASS standard soit un triplet R:G:B "
-"(séparé par le signe :)"
+msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+msgstr "Couleur de traçage, soit une couleur GRASS standard soit un triplet R:G:B (séparé par le signe :)"
#: ../display/drivers/XDRIVER/Get_w_pointer.c:21
#: ../display/drivers/XDRIVER/Get_w_line.c:35
@@ -19665,12 +18406,8 @@
#: ../display/d.rhumbline/main.c:47
#, fuzzy
-msgid ""
-"Displays the rhumbline joining two user-specified points, in the active "
-"frame on the user's graphics monitor."
-msgstr ""
-"Superpose une grille dont le pas est spécifié par l'utilisateur dans le "
-"moniteuractif."
+msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
+msgstr "Superpose une grille dont le pas est spécifié par l'utilisateur dans le moniteuractif."
#: ../display/d.rhumbline/main.c:55 ../display/d.geodesic/main.c:56
#: ../display/d.path/main.c:66
@@ -19715,12 +18452,8 @@
#: ../display/d.where/main.c:44
-msgid ""
-"Identifies the geographic coordinates associated with point locations in the "
-"active frame on the graphics monitor."
-msgstr ""
-"Identifie les coordonnées géographiques associées à l'emplacement d'un point "
-"dans le moniteur actif."
+msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
+msgstr "Identifie les coordonnées géographiques associées à l'emplacement d'un point dans le moniteur actif."
#: ../display/d.where/main.c:49
msgid "One mouse click only"
@@ -19735,12 +18468,8 @@
msgstr "Sortie latitude/longitude référencée sur l'ellipsoïde courant"
#: ../display/d.where/main.c:63
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
-msgstr ""
-"Sortie de latitude/longitude référencée sur l'ellipsoïde WGS84 en utilisant "
-"les paramètres de transformation de datum du Secteur courant (si disponible)"
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
+msgstr "Sortie de latitude/longitude référencée sur l'ellipsoïde WGS84 en utilisant les paramètres de transformation de datum du Secteur courant (si disponible)"
#: ../display/d.where/main.c:69
msgid "Output frame coordinates of current display monitor (percentage)"
@@ -19903,12 +18632,8 @@
msgstr "attention: %s - fichier de vecteur introuvable\n"
#: ../display/d.what.vect/main.c:56
-msgid ""
-"Allows the user to interactively query a vector map layer at user-selected "
-"locations within the current geographic region."
-msgstr ""
-"Permet à l'utilisateur de requêter de façon interactive la couche vectoriel "
-"sur des lieux choisis dans la région géographique courante."
+msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
+msgstr "Permet à l'utilisateur de requêter de façon interactive la couche vectoriel sur des lieux choisis dans la région géographique courante."
#: ../display/d.what.vect/main.c:74 ../display/d.what.rast/main.c:94
msgid "Identify just one location"
@@ -19950,9 +18675,7 @@
msgstr "Construction de l'index spatial ..."
#: ../display/d.text/main.c:68 ../display/d.text.new/main.c:144
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
msgstr "Trace du texte dans le moniteur actif en utilisant la police courante"
#: ../display/d.text/main.c:77 ../display/d.text.new/main.c:159
@@ -19969,18 +18692,13 @@
msgstr "Numéro de ligne de l'écran sur laquelle on va tracer le début du texte"
#: ../display/d.text/main.c:103 ../display/d.text.new/main.c:192
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
-msgstr ""
-"Position de l'écran à partir de laquelle on va commencer à tracer le texte "
-"(en pourcentage, [0,0] est en bas à gauche)"
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
+msgstr "Position de l'écran à partir de laquelle on va commencer à tracer le texte (en pourcentage, [0,0] est en bas à gauche)"
#: ../display/d.text/main.c:110 ../display/d.text.freetype/main.c:217
#: ../display/d.text.new/main.c:208
msgid "Rotation angle in degrees (counter-clockwise)"
-msgstr ""
-"Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
+msgstr "Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
#: ../display/d.text/main.c:114 ../display/d.text.freetype/main.c:236
#: ../display/d.text.new/main.c:251
@@ -20004,23 +18722,18 @@
#: ../display/d.save/main.c:81
#, fuzzy
msgid "Creates a list of commands for recreating screen graphics."
-msgstr ""
-"Créer une liste de commande pour recréer les effets graphiques à l'écran"
+msgstr "Créer une liste de commande pour recréer les effets graphiques à l'écran"
#: ../display/d.save/main.c:86
msgid "Name of frame(s) to save"
msgstr "Nom du/des cadre(s) graphique(s) à sauvegarder"
#: ../display/d.save/main.c:126
-msgid ""
-"List of object numbers to remove which are displayed after \"#\". -1 for the "
-"last object."
+msgid "List of object numbers to remove which are displayed after \"#\". -1 for the last object."
msgstr ""
#: ../display/d.save/main.c:134
-msgid ""
-"List of object numbers to move (\"from\" to \"to\"). remove= option will be "
-"done first, if any."
+msgid "List of object numbers to move (\"from\" to \"to\"). remove= option will be done first, if any."
msgstr ""
#: ../display/d.save/main.c:143
@@ -20070,12 +18783,8 @@
#: ../display/d.linegraph/linegraph.c:115
#, fuzzy
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
-msgstr ""
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
#: ../display/d.linegraph/linegraph.c:119
#, fuzzy
@@ -20194,8 +18903,7 @@
"\n"
"\n"
"Use mouse to choose action"
-msgstr ""
-"Utiliser la souris pour dimensionner et positionner le cartouche de légende"
+msgstr "Utiliser la souris pour dimensionner et positionner le cartouche de légende"
#: ../display/d.profile/main.c:199 ../display/d.profile/main.c:393
msgid "Use 'd.frame -e' to remove left over frames"
@@ -20241,9 +18949,7 @@
msgstr "Faire pivoter le cartouche de légende"
#: ../display/d.ask/main.c:38
-msgid ""
-"Prompts the user to select a GRASS data base file from among files displayed "
-"in a menu on the graphics monitor."
+msgid "Prompts the user to select a GRASS data base file from among files displayed in a menu on the graphics monitor."
msgstr ""
#: ../display/d.ask/main.c:46
@@ -20270,14 +18976,8 @@
msgstr "Vous cliquez en dehors de la couche"
#: ../display/d.what.rast/main.c:54
-msgid ""
-"Allows the user to interactively query the category contents of multiple "
-"raster map layers at user specified locations within the current geographic "
-"region."
-msgstr ""
-"Permet à l'utilisateur de requêter de façon interactive les contenus de "
-"catégories de multiples couches rasters sur des lieux choisis par "
-"l'utilisateur dans la région géographique courante."
+msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
+msgstr "Permet à l'utilisateur de requêter de façon interactive les contenus de catégories de multiples couches rasters sur des lieux choisis par l'utilisateur dans la région géographique courante."
#: ../display/d.what.rast/main.c:89
msgid "Field separator (terse mode only)"
@@ -20285,9 +18985,7 @@
#: ../display/d.what.rast/main.c:103
msgid "Print out col/row for the entire map in grid resolution of the region"
-msgstr ""
-"Affiche la colonne/ligne pour la couche entière en fonction de la résolution "
-"de la région"
+msgstr "Affiche la colonne/ligne pour la couche entière en fonction de la résolution de la région"
#: ../display/d.what.rast/main.c:119 ../display/d.his/main.c:120
msgid "No current graphics window"
@@ -20343,10 +19041,8 @@
#: ../display/d.vect.chart/main.c:65
#, fuzzy
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
-msgstr ""
-"Afficher des diagrammes de données vectorielles GRASS dans le moniteur actif"
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
+msgstr "Afficher des diagrammes de données vectorielles GRASS dans le moniteur actif"
#: ../display/d.vect.chart/main.c:82
msgid "Chart type"
@@ -20370,9 +19066,7 @@
#: ../display/d.vect.chart/main.c:104
msgid "Size of chart (diameter for pie, total width for bar)"
-msgstr ""
-"Taille du diagramme (diamètre pour le diagramme camembert, largeur totale "
-"pour le diagramme en barres)"
+msgstr "Taille du diagramme (diamètre pour le diagramme camembert, largeur totale pour le diagramme en barres)"
#: ../display/d.vect.chart/main.c:111
msgid "Scale for size (to get size in pixels)"
@@ -20405,8 +19099,7 @@
#: ../display/d.barscale/main.c:60
msgid "Use mouse to interactively place scale"
-msgstr ""
-"Utilisez la souris pour positionner l'échelle graphique de façon interactive"
+msgstr "Utilisez la souris pour positionner l'échelle graphique de façon interactive"
#: ../display/d.barscale/main.c:64
msgid "Use feet/miles instead of meters"
@@ -20414,9 +19107,7 @@
#: ../display/d.barscale/main.c:68
msgid "Draw a line scale instead of a bar scale"
-msgstr ""
-"Afficher une échelle graphique sous forme de ligne, plutôt que sous forme de "
-"barre"
+msgstr "Afficher une échelle graphique sous forme de ligne, plutôt que sous forme de barre"
#: ../display/d.barscale/main.c:72
msgid "Write text on top of the scale, not to the right"
@@ -20433,9 +19124,7 @@
#: ../display/d.barscale/main.c:96
#, fuzzy
msgid "Screen coordinates of the rectangle's top-left corner"
-msgstr ""
-"Les coordonnées écran pour le coin supérieur gauche de l'étiquette ([0,0] "
-"est le coin supérieurgauche du cadre graphique)"
+msgstr "Les coordonnées écran pour le coin supérieur gauche de l'étiquette ([0,0] est le coin supérieurgauche du cadre graphique)"
#: ../display/d.barscale/main.c:97
msgid "(0,0) is top-left of the display frame"
@@ -20468,16 +19157,11 @@
#: ../display/d.erase/main.c:34
msgid "Erase the contents of the active display frame with user defined color"
-msgstr ""
-"Efface le contenu du moniteur actif avec la couleur choisie par l'utilisateur"
+msgstr "Efface le contenu du moniteur actif avec la couleur choisie par l'utilisateur"
#: ../display/d.erase/main.c:42
-msgid ""
-"Color to erase with, either a standard GRASS color or R:G:B triplet "
-msgstr ""
-"Couleur pour effacer, soit une couleur GRASS standard soit un triplet R:G:"
-"B(séparé par le signe :)"
+msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+msgstr "Couleur pour effacer, soit une couleur GRASS standard soit un triplet R:G:B(séparé par le signe :)"
#: ../display/d.erase/main.c:47 ../display/d.frame/frame.c:74
msgid "Remove all frames and erase the screen"
@@ -20503,12 +19187,8 @@
#: ../display/d.zoom/main.c:59
-msgid ""
-"Allows the user to change the current geographic region settings "
-"interactively, with a mouse."
-msgstr ""
-"Permet à l'utilisateur de changer les réglages de la région géographique "
-"courante de manière interactive, à l'aide de la souris."
+msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
+msgstr "Permet à l'utilisateur de changer les réglages de la région géographique courante de manière interactive, à l'aide de la souris."
#: ../display/d.zoom/main.c:90 ../display/d.legend/main.c:92
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:4
@@ -20538,9 +19218,7 @@
#: ../display/d.zoom/main.c:130
msgid "Just redraw given maps using default colors"
-msgstr ""
-"Redessiner simplement les couches concernées en utilisant les couleurs par "
-"défaut"
+msgstr "Redessiner simplement les couches concernées en utilisant les couleurs par défaut"
#: ../display/d.zoom/main.c:134
msgid "Return to previous zoom"
@@ -20618,8 +19296,7 @@
#: ../display/d.zoom/zoom.c:42
#, c-format
msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
-msgstr ""
-"Note: lancer 'd.erase' pour la nouvelle région pour modifier l'affichage.\n"
+msgstr "Note: lancer 'd.erase' pour la nouvelle région pour modifier l'affichage.\n"
#: ../display/d.zoom/pan.c:18
#, fuzzy, c-format
@@ -20632,12 +19309,8 @@
msgstr " Droite: quitter\n"
#: ../display/d.rast.num/number.c:86
-msgid ""
-"Overlays cell category values on a raster map layer displayed to the "
-msgstr ""
-"Superpose les valeurs de catégorie des cellules sur la couche raster "
-"affichée dans lemoniteur."
+msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
+msgstr "Superpose les valeurs de catégorie des cellules sur la couche raster affichée dans lemoniteur."
#: ../display/d.rast.num/number.c:100
msgid "Color for drawing grid, or \"none\""
@@ -20649,8 +19322,7 @@
#: ../display/d.rast.num/number.c:124
msgid "Get text color from cell color value"
-msgstr ""
-"Choisir la couleur du texte en fonction de la valeur de couleur de la cellule"
+msgstr "Choisir la couleur du texte en fonction de la valeur de couleur de la cellule"
#: ../display/d.rast.num/number.c:138
msgid "No raster map exists in current window"
@@ -20660,24 +19332,18 @@
#, fuzzy, c-format
msgid ""
"Current region size: %d rows X %d cols\n"
-"Your current region setting may be too large. Cells displayed on your "
-"graphics window may be too small for cell category number to be visible."
+"Your current region setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
msgstr ""
"\n"
-"Votre fenêtre courante semble trop grande. Les cellules affichées dans votre "
-"moniteur graphique risque d'être trop petites pour que le code de catégorie "
-"soit visible."
+"Votre fenêtre courante semble trop grande. Les cellules affichées dans votre moniteur graphique risque d'être trop petites pour que le code de catégorie soit visible."
#: ../display/d.rast.num/number.c:216
msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
msgstr ""
#: ../display/d.text.freetype/main.c:140
-msgid ""
-"Draws text in the graphics monitor's active display frame using TrueType "
-"fonts."
-msgstr ""
-"Affiche du texte dans le moniteur actif en utilisant des polices TrueType"
+msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
+msgstr "Affiche du texte dans le moniteur actif en utilisant des polices TrueType"
#: ../display/d.text.freetype/main.c:146 ../display/d.text.new/main.c:150
msgid "Text to display"
@@ -20686,9 +19352,7 @@
#: ../display/d.text.freetype/main.c:154
#, fuzzy
msgid "Screen position (percentage, [0,0] is bottom left)"
-msgstr ""
-"Les coordonnées sont en pourcentage du cadre graphique ([0,0] est en bas à "
-"gauche)"
+msgstr "Les coordonnées sont en pourcentage du cadre graphique ([0,0] est en bas à gauche)"
#: ../display/d.text.freetype/main.c:176
msgid "Path to TrueType font (including file name)"
@@ -20696,9 +19360,7 @@
#: ../display/d.text.freetype/main.c:201
msgid "Height of letters (in percent of available frame height)"
-msgstr ""
-"Hauteur des caractères (en pourcentage de la hauteur disponible du cadre "
-"graphique)"
+msgstr "Hauteur des caractères (en pourcentage de la hauteur disponible du cadre graphique)"
#: ../display/d.text.freetype/main.c:209 ../display/d.text.new/main.c:200
msgid "Text alignment"
@@ -20720,8 +19382,7 @@
#: ../display/d.text.freetype/main.c:240 ../display/d.text.new/main.c:255
msgid "Use radians instead of degrees for rotation"
-msgstr ""
-"Utilisez des radians à la place de degrés pour définir l'angle de rotation"
+msgstr "Utilisez des radians à la place de degrés pour définir l'angle de rotation"
#: ../display/d.text.freetype/main.c:244 ../display/d.text.new/main.c:259
msgid "Font size is height in pixels"
@@ -20787,9 +19448,7 @@
#: ../display/d.text.freetype/main.c:645
#, c-format
msgid "%s: Unable to read FreeType definition file; use the default"
-msgstr ""
-"%s : impossible de lire le fichier de définition FreeType; on utilise les "
-"paramètres par défaut"
+msgstr "%s : impossible de lire le fichier de définition FreeType; on utilise les paramètres par défaut"
#: ../display/d.text.freetype/main.c:651
#, c-format
@@ -20831,12 +19490,8 @@
msgstr "Erreur dans pj_do_proj6"
#: ../display/d.grid/main.c:54
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
-msgstr ""
-"moniteuractif."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
#: ../display/d.grid/main.c:62
msgid "Size of grid to be drawn"
@@ -20903,23 +19558,17 @@
#: ../display/d.grid/main.c:126
#, fuzzy
msgid "Draw '+' marks instead of grid lines"
-msgstr ""
-"barre"
#: ../display/d.grid/main.c:130
#, fuzzy
msgid "Draw '.' marks instead of grid lines"
-msgstr ""
-"barre"
#: ../display/d.grid/main.c:134
#, fuzzy
msgid "Draw fiducial marks instead of grid lines"
-msgstr ""
-"barre"
#: ../display/d.grid/main.c:138
msgid "Disable grid drawing"
@@ -21064,8 +19713,7 @@
#: ../display/d.text.new/main.c:239
#, fuzzy
msgid "Use mouse to interactively place text"
-msgstr ""
#: ../display/d.text.new/main.c:263
#, fuzzy
@@ -21112,12 +19760,8 @@
#: ../display/d.his/main.c:67
#, fuzzy
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(his) values from user-specified input raster map layers."
-msgstr ""
-"Générer des couches raster de couche rouge, verte et bleue en combinant des "
-"couches raster de teinte, intensité et saturation."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
+msgstr "Générer des couches raster de couche rouge, verte et bleue en combinant des couches raster de teinte, intensité et saturation."
#: ../display/d.his/main.c:95
msgid "Percent to brighten intensity channel"
@@ -21139,9 +19783,7 @@
msgstr "Erreur de lecture de la couche Saturation"
#: ../display/d.geodesic/main.c:47
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
msgstr ""
#: ../display/d.geodesic/main.c:70
@@ -21211,8 +19853,7 @@
#: ../display/d.mon/cmd/main.c:51
msgid "To establish and control use of a graphics display monitor."
-msgstr ""
-"Pour gérer et contrôler l'utilisation des moniteurs graphiques d'affichage"
+msgstr "Pour gérer et contrôler l'utilisation des moniteurs graphiques d'affichage"
#: ../display/d.mon/cmd/main.c:57
msgid "Name of graphics monitor to start"
@@ -21285,16 +19926,12 @@
#: ../display/d.colortable/main.c:118
#, c-format
-msgid ""
-"<%s> is a floating point map. Ignoring [lines] and drawing continuous color "
-"ramp"
+msgid "<%s> is a floating point map. Ignoring [lines] and drawing continuous color ramp"
msgstr ""
#: ../display/d.colortable/main.c:132
#, c-format
-msgid ""
-"<%s> is a floating point map. Ignoring [cols] and drawing continuous color "
-"ramp"
+msgid "<%s> is a floating point map. Ignoring [cols] and drawing continuous color ramp"
msgstr ""
#: ../display/d.colortable/main.c:141
@@ -21315,9 +19952,7 @@
#: ../display/d.rast/main.c:52
#, fuzzy
msgid "Displays user-specified raster map in the active graphics frame."
-msgstr ""
#: ../display/d.rast/main.c:65
msgid "List of categories to be displayed (INT maps)"
@@ -21350,9 +19985,7 @@
#: ../display/d.rast/main.c:119
msgid "Ignoring catlist: map is floating point (please use 'val=')"
-msgstr ""
-"Catlist ignorée : la couche est en valeurs flottantes (veuillez utiliser "
-"'val=')"
+msgstr "Catlist ignorée : la couche est en valeurs flottantes (veuillez utiliser 'val=')"
#: ../display/d.rast/main.c:125
msgid "Ignoring vallist: map is integer (please use 'cat=')"
@@ -21360,9 +19993,7 @@
#: ../display/d.thematic.area/main.c:80
#, fuzzy
-msgid ""
-"Displays a thematic vector area map in the active frame on the graphics "
-"monitor."
+msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
msgstr "Afficher les données vectorielles GRASS dans le moniteur actif"
#: ../display/d.thematic.area/main.c:90
@@ -21379,9 +20010,7 @@
msgstr "Nom de fichier de signatures à utiliser pour la classification"
#: ../display/d.thematic.area/main.c:106 ../vector/v.class/main.c:69
-msgid ""
-"int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable "
-"(normal distribution);"
+msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
msgstr ""
#: ../display/d.thematic.area/main.c:117 ../vector/v.class/main.c:80
@@ -21413,10 +20042,7 @@
msgstr "Couleur de la bordure"
#: ../display/d.thematic.area/main.c:159
-msgid ""
-"d;use the display library basic functions (features: polylines);c;use the "
-"display library clipping functions (features: clipping);l;use the display "
-"library culling functions (features: culling, polylines)"
+msgid "d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
msgstr ""
#: ../display/d.thematic.area/main.c:167
@@ -21424,9 +20050,7 @@
msgstr ""
#: ../display/d.thematic.area/main.c:178
-msgid ""
-"When printing legend info , include extended statistical info from "
-"classification algorithm"
+msgid "When printing legend info , include extended statistical info from classification algorithm"
msgstr ""
#: ../display/d.thematic.area/main.c:182
@@ -21456,9 +20080,7 @@
msgstr "La clef primaire doit être un entier"
#: ../display/d.thematic.area/main.c:328
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
msgstr ""
#: ../display/d.thematic.area/main.c:365
@@ -21511,37 +20133,22 @@
#: ../display/d.thematic.area/plot1.c:220
#, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
-"BBB where RGB values range 0-255."
-msgstr ""
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
#: ../display/d.thematic.area/plot1.c:369
#, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
-msgstr ""
-"catégorie %d: code couleur [%s]"
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
+msgstr "Erreur dans la colonne de définition de couleur (%s), élément %d avec la catégorie %d: code couleur [%s]"
#: ../display/d.thematic.area/plot1.c:376
#, c-format
msgid "Error in color definition column (%s), element %d with cat %d"
-msgstr ""
-"catégorie %d"
+msgstr "Erreur dans la colonne de définition de couleur (%s), élément %d avec la catégorie %d"
#: ../display/d.font.freetype/main.c:61 ../display/d.font/main.c:48
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
-msgstr ""
-"Sélectionnez la police à utiliser pour afficher le texte sur le moniteur "
-"graphique."
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
+msgstr "Sélectionnez la police à utiliser pour afficher le texte sur le moniteur graphique."
#: ../display/d.font.freetype/main.c:68
#, fuzzy
@@ -21577,25 +20184,16 @@
msgstr "Problem pour interpréter la commande [%s]"
#: ../display/d.graph/main.c:56
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
-msgstr ""
-"Programme pour générer et afficher de simples graphiques dans le moniteur "
-"actif."
+msgid "Program for generating and displaying simple graphics on the display monitor."
+msgstr "Programme pour générer et afficher de simples graphiques dans le moniteur actif."
#: ../display/d.graph/main.c:63
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
-msgstr ""
-"Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les "
-"prendre à partirde la ligne de commande"
+msgid "Name of file containing graphics commands, if not given reads from standard input"
+msgstr "Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les prendre à partirde la ligne de commande"
#: ../display/d.graph/main.c:71
msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-"Couleur pour le traçage, soit une couleur GRASS standard, soit un triplet R:"
-"G:B"
+msgstr "Couleur pour le traçage, soit une couleur GRASS standard, soit un triplet R:G:B"
#: ../display/d.graph/main.c:78
msgid "Coordinates are given in map units"
@@ -21614,12 +20212,8 @@
#: ../display/d.rgb/main.c:56
#, fuzzy
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
-msgstr ""
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
#: ../display/d.rgb/main.c:71
#, fuzzy, c-format
@@ -21779,12 +20373,8 @@
msgstr " Distance jusqu'au réseau = %f, distance depuis le réseau = %f\n"
#: ../display/d.rast.arrow/arrow.c:112
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
-msgstr ""
-"Tracer des flèches représentant la direction d'aspect des cellules pour une "
-"couche rastercontenant des données d'aspect."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
+msgstr "Tracer des flèches représentant la direction d'aspect des cellules pour une couche rastercontenant des données d'aspect."
#: ../display/d.rast.arrow/arrow.c:121
msgid "Name of raster aspect map to be displayed"
@@ -21817,8 +20407,7 @@
#: ../display/d.rast.arrow/arrow.c:177
msgid "Raster map containing values used for arrow length"
-msgstr ""
-"Couche raster contenant les valeurs utilisées pour la longueur des flèches"
+msgstr "Couche raster contenant les valeurs utilisées pour la longueur des flèches"
#: ../display/d.rast.arrow/arrow.c:184
msgid "Scale factor for arrows (magnitude map)"
@@ -21858,21 +20447,15 @@
#: ../display/d.extract/extract.c:45
msgid " - L: draw box with left mouse button to select"
-msgstr ""
-" - L : dessiner la boîte avec le bouton gauche de la souris pour la "
-"sélectionner"
+msgstr " - L : dessiner la boîte avec le bouton gauche de la souris pour la sélectionner"
#: ../display/d.extract/extract.c:46
msgid " - M: draw box with middle mouse button to remove from display"
-msgstr ""
-" - M : dessiner la boîte avec le bouton du milieu de la souris pour la "
-"supprimer de l'affichage"
+msgstr " - M : dessiner la boîte avec le bouton du milieu de la souris pour la supprimer de l'affichage"
#: ../display/d.extract/extract.c:47
msgid " - R: quit and save selected vectors to new map\n"
-msgstr ""
-" - R : quitter et enregistrer les couches vectorielles sélectionnées dans "
-"une nouvelle zone d'affichage\n"
+msgstr " - R : quitter et enregistrer les couches vectorielles sélectionnées dans une nouvelle zone d'affichage\n"
#: ../display/d.extract/extract.c:49
#, fuzzy
@@ -21881,9 +20464,7 @@
#: ../display/d.extract/main.c:52
msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr ""
-"Sélectionne et extraits des couches vectorielles avec la souris dans une "
-"nouvelle couche vectorielle."
+msgstr "Sélectionne et extraits des couches vectorielles avec la souris dans une nouvelle couche vectorielle."
#: ../display/d.extract/main.c:117
#, fuzzy
@@ -21896,30 +20477,23 @@
msgstr "Impossible de lire les informations de liaison à la base de données"
#: ../display/d.legend/main.c:88
-msgid ""
-"Displays a legend for a raster map in the active frame of the graphics "
-"monitor."
+msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
msgstr "Affiche la légende de la couche raster du moniteur actif."
#: ../display/d.legend/main.c:103
msgid "Number of text lines (useful for truncating long legends)"
-msgstr ""
-"Nombre de lignes de texte (pratique pour tronquer les longs textes de "
-"légende)"
+msgstr "Nombre de lignes de texte (pratique pour tronquer les longs textes de légende)"
#: ../display/d.legend/main.c:112
msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
-msgstr ""
-"Facteur de discrétisation (thinning) (thin=10 donne les catégories "
-"0,10,20...)"
+msgstr "Facteur de discrétisation (thinning) (thin=10 donne les catégories 0,10,20...)"
#: ../display/d.legend/main.c:120
msgid "Number of text labels for smooth gradient legend"
msgstr "Nombre d'étiquette texte pour la légende du gradient lissé"
#: ../display/d.legend/main.c:130
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
msgstr ""
#: ../display/d.legend/main.c:140
@@ -21928,14 +20502,11 @@
#: ../display/d.legend/main.c:150
msgid "Use a subset of the map range for the legend (min,max)"
-msgstr ""
-"Utiliser un sous-ensemble de l'intervalle des valeurs de la carte pour la "
-"légende (min, max)"
+msgstr "Utiliser un sous-ensemble de l'intervalle des valeurs de la carte pour la légende (min, max)"
#: ../display/d.legend/main.c:156
msgid "Use mouse to size & place legend"
-msgstr ""
#: ../display/d.legend/main.c:160
msgid "Do not show category labels"
@@ -21961,22 +20532,17 @@
#: ../display/d.legend/main.c:331
msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr ""
-"Le cartouche de légende dépasse du cadre. Il est possible que le texte ne "
-"s'affiche pas correctement"
+msgstr "Le cartouche de légende dépasse du cadre. Il est possible que le texte ne s'affiche pas correctement"
#: ../display/d.legend/main.c:335
#, fuzzy
msgid "Drawing horizontal legend as box width exceeds height"
-msgstr ""
-"Disposition horizontale de la légende car la largeur du cartouche dépasse la "
-"hauteur.\n"
+msgstr "Disposition horizontale de la légende car la largeur du cartouche dépasse la hauteur.\n"
#: ../display/d.legend/main.c:346
#, fuzzy, c-format
msgid "Range information for <%s> not available (run r.support)"
-msgstr ""
-"Information sur l'intervalle de [%s] non disponible (exécutez r.support)"
+msgstr "Information sur l'intervalle de [%s] non disponible (exécutez r.support)"
#: ../display/d.legend/main.c:351
#, fuzzy
@@ -21985,38 +20551,30 @@
#: ../display/d.legend/main.c:364 ../display/d.legend/main.c:522
msgid "Color range exceeds lower limit of actual data"
-msgstr ""
-"Les valeurs de couleurs excède la limite plancher des données actuelles"
+msgstr "Les valeurs de couleurs excède la limite plancher des données actuelles"
#: ../display/d.legend/main.c:370 ../display/d.legend/main.c:526
msgid "Color range exceeds upper limit of actual data"
-msgstr ""
-"Les valeurs de couleurs dépassent la limite plafond des données actuelles"
+msgstr "Les valeurs de couleurs dépassent la limite plafond des données actuelles"
#: ../display/d.legend/main.c:427
#, fuzzy, c-format
msgid "use=%s out of range [%d,%d] (extend with range= ?)"
-msgstr ""
-"utilisation=%s hors de l'intervalle [%d,%d]. (étendre à l'intervalle= ?)"
+msgstr "utilisation=%s hors de l'intervalle [%d,%d]. (étendre à l'intervalle= ?)"
#: ../display/d.legend/main.c:468
msgid "Nothing to draw! (no categories with labels? out of range?)"
-msgstr ""
-"Rien à dessiner! (pas de catégories liées aux étiquettes? valeurs hors "
-"intervalles?"
+msgstr "Rien à dessiner! (pas de catégories liées aux étiquettes? valeurs hors intervalles?"
#: ../display/d.legend/main.c:478
#, fuzzy
msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr ""
-"Utilisation forcée d'une légende simplifiée : trop de catégories pour la "
-"taille courante de la fenêtre.\n"
+msgstr "Utilisation forcée d'une légende simplifiée : trop de catégories pour la taille courante de la fenêtre.\n"
#: ../display/d.legend/main.c:533
#, fuzzy, c-format
msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
-msgstr ""
-"utilisation=%s hors de l'intervalle [%.3f, %.3f]. (étendre à l'intervalle= ?)"
+msgstr "utilisation=%s hors de l'intervalle [%.3f, %.3f]. (étendre à l'intervalle= ?)"
#: ../display/d.legend/main.c:895
msgid "Nothing to draw! (no categories with labels?)"
@@ -22029,8 +20587,7 @@
#: ../display/d.menu/main.c:68
#, fuzzy
-msgid ""
-"Creates and displays a menu within the active frame on the graphics monitor."
+msgid "Creates and displays a menu within the active frame on the graphics monitor."
#: ../display/d.menu/main.c:77
@@ -22067,12 +20624,8 @@
#: ../display/d.measure/main.c:51
-msgid ""
-"Measures the lengths and areas of features drawn by the user in the active "
-"display frame on the graphics monitor."
-msgstr ""
-"Mesure les longueurs et les surfaces des objets dessinés par l'utilisateur "
-"dans le cadre actif du moniteur graphique."
+msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
+msgstr "Mesure les longueurs et les surfaces des objets dessinés par l'utilisateur dans le cadre actif du moniteur graphique."
#: ../display/d.measure/main.c:57
msgid "Line color 1"
@@ -22182,12 +20735,8 @@
msgstr ""
#: ../display/d.nviz/main.c:537
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
-msgstr ""
-"Ce point est ignoré, il est en dehors de la région. Peut-être que la "
-"distance focale de la caméra le place au-delà du bord?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
+msgstr "Ce point est ignoré, il est en dehors de la région. Peut-être que la distance focale de la caméra le place au-delà du bord?"
#: ../display/d.extend/main.c:52
#, fuzzy
@@ -22195,8 +20744,7 @@
msgstr "Nom de la couche raster d'aspect à afficher"
#: ../display/d.title/main.c:47
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
msgstr ""
#: ../display/d.title/main.c:58
@@ -22263,8 +20811,7 @@
#: ../display/d.font/main.c:126
#, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
msgstr ""
#: ../general/g.filename/main.c:39 ../general/g.access/main.c:37
@@ -22311,10 +20858,7 @@
msgstr ""
#: ../general/g.gui/main.c:45
-msgid ""
-"wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager "
-"(gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command "
-"line interface only"
+msgid "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command line interface only"
msgstr ""
#: ../general/g.gui/main.c:54
@@ -22386,9 +20930,7 @@
#: ../general/g.transform/main.c:322
#, fuzzy
msgid "Computes a coordinate transformation based on the control points."
-msgstr ""
-"Recale une image en calculer la transformation de coordonnées pour chaque "
-"pixel de l'image basée sur des points d'amer"
+msgstr "Recale une image en calculer la transformation de coordonnées pour chaque pixel de l'image basée sur des points d'amer"
#: ../general/g.transform/main.c:331
#, fuzzy
@@ -22396,11 +20938,7 @@
msgstr "Ordre du polynome de recalage (1-3)"
#: ../general/g.transform/main.c:339
-msgid ""
-"idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
-"forward coordinates (destination);rev;reverse coordinates (source);fxy;"
-"forward coordinates difference (destination);rxy;reverse coordinates "
-"difference (source);fd;forward error (destination);rd;reverse error (source)"
+msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
msgstr ""
#: ../general/g.transform/main.c:349 ../vector/v.out.ascii/out.c:63
@@ -22528,9 +21066,7 @@
#: ../general/g.findfile/main.c:79
#, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
-"%s> does not correspond"
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
msgstr ""
# c-format
@@ -22573,18 +21109,11 @@
#: ../general/g.proj/create.c:36
#, fuzzy, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)."
-msgstr ""
-"Vous devez sélectionner le jeu de données PERMANENT avant de mettre à jour "
-"la projectiondu Secteur courant. (Le jeu de données courant est %s)"
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)."
+msgstr "Vous devez sélectionner le jeu de données PERMANENT avant de mettre à jour la projectiondu Secteur courant. (Le jeu de données courant est %s)"
#: ../general/g.proj/create.c:63
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
msgstr ""
#: ../general/g.proj/create.c:67
@@ -22602,9 +21131,7 @@
#: ../general/g.proj/main.c:66
#, fuzzy
-msgid ""
-"Prints and manipulates GRASS projection information files (in various co-"
-"ordinate system descriptions)."
+msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
msgstr "Affiche et manipule les fichiers d'information de projection GRASS"
#: ../general/g.proj/main.c:69
@@ -22628,19 +21155,15 @@
#: ../general/g.proj/main.c:91
msgid "Verify datum information and print transformation parameters"
-msgstr ""
-"Vérifier l'information de datum et afficher les paramètres de transformation"
+msgstr "Vérifier l'information de datum et afficher les paramètres de transformation"
#: ../general/g.proj/main.c:97
msgid "Print projection information in PROJ.4 format"
msgstr "Afficher l'information de projection au format PROJ.4"
#: ../general/g.proj/main.c:103
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
-msgstr ""
-"Afficher une sortie 'à plat' sans sauts de ligne (s'applique à la sortie WKT "
-"et PROJ.4)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgstr "Afficher une sortie 'à plat' sans sauts de ligne (s'applique à la sortie WKT et PROJ.4)"
#: ../general/g.proj/main.c:113
msgid "Print projection information in WKT format"
@@ -22664,16 +21187,12 @@
#: ../general/g.proj/main.c:136
#, fuzzy
msgid "Name of ASCII file containing a WKT projection description"
-msgstr ""
-"Fichier ASCII contenant une description de projection WKT en une ligne (- "
-"pour stdin)"
+msgstr "Fichier ASCII contenant une description de projection WKT en une ligne (- pour stdin)"
#: ../general/g.proj/main.c:138 ../general/g.proj/main.c:147
#, fuzzy
msgid "'-' for standard input"
-msgstr ""
-"Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
-"prendreles paramètres saisis en ligne de commande"
+msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
#: ../general/g.proj/main.c:146
#, fuzzy
@@ -22701,25 +21220,20 @@
#: ../general/g.proj/main.c:178
#, fuzzy
msgid "Index number of datum transform parameters"
-msgstr ""
#: ../general/g.proj/main.c:179
msgid "\"0\" for unspecified or \"-1\" to list and exit"
msgstr ""
#: ../general/g.proj/main.c:185
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
+msgid "Force override of datum transformation information in input co-ordinate system"
msgstr ""
#: ../general/g.proj/main.c:191
#, fuzzy
msgid "Create new projection files (modifies current location)"
-msgstr ""
-"Impossible d'obtenir les unités de projection pour le Secteur (location) "
-"courant"
+msgstr "Impossible d'obtenir les unités de projection pour le Secteur (location) courant"
#: ../general/g.proj/main.c:199 ../general/g.mapset/main.c:82
#: ../locale/scriptstrings/r.mask_to_translate.c:4
@@ -22792,17 +21306,12 @@
#: ../general/g.proj/input.c:254
#, fuzzy, c-format
msgid "Could not read georeferenced file %s using either OGR nor GDAL"
-msgstr ""
-"Impossible de lire le fichier géoréférencé %s à l'aide de GDAL ni d'OGR"
+msgstr "Impossible de lire le fichier géoréférencé %s à l'aide de GDAL ni d'OGR"
#: ../general/g.proj/input.c:259
#, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
-msgstr ""
-"La lecture du fichier %s a fonctionné, mais elle ne contenait pas "
-"d'information de projection. 'XY (sans projection)' va être utilisé"
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgstr "La lecture du fichier %s a fonctionné, mais elle ne contenait pas d'information de projection. 'XY (sans projection)' va être utilisé"
#: ../general/g.proj/output.c:182
#, c-format
@@ -22868,9 +21377,7 @@
#: ../general/g.mremove/main.c:60 ../general/manage/cmd/remove.c:101
msgid "Removes data base element files from the user's current mapset."
-msgstr ""
-"Supprimer les fichiers éléments de base de données du jeu de données courant "
-"de l'utilisateur"
+msgstr "Supprimer les fichiers éléments de base de données du jeu de données courant de l'utilisateur"
#: ../general/g.mremove/main.c:66 ../general/g.mlist/main.c:128
#, fuzzy
@@ -22901,9 +21408,7 @@
#: ../general/g.mremove/main.c:104 ../general/g.mlist/main.c:163
#, fuzzy
msgid "-r and -e are mutually exclusive"
-msgstr ""
-"les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir "
-"qu'un seul."
+msgstr "les drapeaux -B & - C sont mutuellement exclusifs. Veuillez n'en choisir qu'un seul."
#: ../general/g.mremove/main.c:107
msgid "The following files would be deleted:"
@@ -22932,8 +21437,7 @@
msgstr "Sauvegarder cadre graphique actif"
#: ../general/g.mapset/main.c:50
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
+msgid "Optionally create new mapset or list available mapsets in given location."
msgstr ""
#: ../general/g.mapset/main.c:57
@@ -22946,8 +21450,7 @@
msgstr ""
#: ../general/g.mapset/main.c:75
-msgid ""
-"GIS data directory (full path to the directory where the new location is)"
+msgid "GIS data directory (full path to the directory where the new location is)"
msgstr ""
#: ../general/g.mapset/main.c:80
@@ -22977,8 +21480,7 @@
#: ../general/g.mapset/main.c:156
#, fuzzy
msgid "The mapset does not exist. Use -c flag to create it."
-msgstr ""
-"La couche n'existe pas. Ajouter le drapeau -n pour créer la nouvelle couche."
+msgstr "La couche n'existe pas. Ajouter le drapeau -n pour créer la nouvelle couche."
#: ../general/g.mapset/main.c:165
#, fuzzy
@@ -22987,9 +21489,7 @@
#: ../general/g.mapset/main.c:179
#, c-format
-msgid ""
-"%s is currently running GRASS in selected mapset or lock file cannot be "
-"checked"
+msgid "%s is currently running GRASS in selected mapset or lock file cannot be checked"
msgstr ""
# c-format
@@ -23028,19 +21528,13 @@
#: ../general/g.mlist/main.c:67
#, fuzzy
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"Lister les fichiers de base de données GRASS disponibles du type spécifié "
-"par l'utilisateur vers la sortie standard."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "Lister les fichiers de base de données GRASS disponibles du type spécifié par l'utilisateur vers la sortie standard."
#: ../general/g.mlist/main.c:97
#, fuzzy
msgid "Map name search pattern (default: all)"
-msgstr ""
-"motif à recherche dans le nom de couche, doit être entre simples guillemets "
-"(par défaut: tous)"
+msgstr "motif à recherche dans le nom de couche, doit être entre simples guillemets (par défaut: tous)"
#: ../general/g.mlist/main.c:98 ../general/g.mlist/main.c:106
#: ../general/g.mlist/main.c:129 ../general/g.mlist/main.c:135
@@ -23051,9 +21545,7 @@
#: ../general/g.mlist/main.c:105
#, fuzzy
msgid "Map name exclusion pattern (default: none)"
-msgstr ""
#: ../general/g.mlist/main.c:115
msgid "One-character output separator, newline, comma, space, or tab"
@@ -23114,9 +21606,7 @@
#: ../general/g.gisenv/main.c:40
msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr ""
-"Affiche et modifie les réglages actuels de l'utilisateur pour les variables "
-"GRASS"
+msgstr "Affiche et modifie les réglages actuels de l'utilisateur pour les variables GRASS"
#: ../general/g.gisenv/main.c:45
msgid "GRASS variable to get"
@@ -23160,9 +21650,7 @@
#: ../general/g.gisenv/main.c:81
#, fuzzy
msgid "-s and -n are mutually exclusive"
-msgstr ""
-"qu'un seul."
#: ../general/manage/cmd/remove.c:106
#, fuzzy
@@ -23182,9 +21670,7 @@
#: ../general/manage/cmd/rename.c:42
msgid "Renames data base element files in the user's current mapset."
-msgstr ""
-"Renommer les fichiers éléments de la base de données dans le jeu de données "
-"courant de l'utilisateur"
+msgstr "Renommer les fichiers éléments de la base de données dans le jeu de données courant de l'utilisateur"
#: ../general/manage/cmd/rename.c:58
#, c-format
@@ -23205,9 +21691,7 @@
#: ../general/manage/cmd/rename.c:98
#, fuzzy, c-format
msgid "%s=%s,%s: files could be the same, no rename possible"
-msgstr ""
-"%s=%s,%s: les fichiers sont identiques, il n'est pas nécessaire de les "
-"renommer\n"
+msgstr "%s=%s,%s: les fichiers sont identiques, il n'est pas nécessaire de les renommer\n"
# c-format
#: ../general/manage/cmd/rename.c:108
@@ -23218,19 +21702,11 @@
#: ../general/manage/cmd/list.c:43
#, fuzzy
msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr ""
#: ../general/manage/cmd/copy.c:41
-msgid ""
-"Copies available data files in the user's current mapset search path and "
-"location to the appropriate element directories under the user's current "
-"mapset."
-msgstr ""
-"Copier les fichiers de données disponibles dans le chemin de recherche et le "
-"Secteur vers le répertoire approprié sous le jeu de données courant de "
-"l'utilisateur."
+msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
+msgstr "Copier les fichiers de données disponibles dans le chemin de recherche et le Secteur vers le répertoire approprié sous le jeu de données courant de l'utilisateur."
#: ../general/manage/cmd/copy.c:59
#, c-format
@@ -23246,9 +21722,7 @@
#: ../general/manage/cmd/copy.c:88
#, fuzzy, c-format
msgid "%s=%s,%s: files are the same, no copy required"
-msgstr ""
-"copier\n"
+msgstr "%s=%s,%s: les fichiers sont identiques, il n'est pas nécessaire de les copier\n"
#: ../general/manage/cmd/copy.c:93
#, fuzzy, c-format
@@ -23258,8 +21732,7 @@
#: ../general/g.region/main.c:74
#, fuzzy
msgid "Manages the boundary definitions for the geographic region."
-msgstr ""
-"Définition de l'emprise de la région géographique pour une couche raster."
+msgstr "Définition de l'emprise de la région géographique pour une couche raster."
#: ../general/g.region/main.c:81 ../general/g.region/main.c:87
#: ../general/g.region/main.c:175 ../general/g.region/main.c:182
@@ -23284,9 +21757,7 @@
#: ../general/g.region/main.c:96
#, fuzzy
msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr ""
-"Afficher la région courante en latitude/longitude à partir de l'ellipsoïde/"
-"datum courants"
+msgstr "Afficher la région courante en latitude/longitude à partir de l'ellipsoïde/datum courants"
#: ../general/g.region/main.c:102
msgid "Print the current region extent"
@@ -23315,9 +21786,7 @@
msgstr ""
#: ../general/g.region/main.c:133
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
msgstr ""
#: ../general/g.region/main.c:139
@@ -23327,18 +21796,12 @@
#: ../general/g.region/main.c:145
#, fuzzy
msgid "Print the maximum bounding box in lat/long on WGS84"
-msgstr ""
-"Affiche la boîte englobante maximale en latitude/longitude en WGS84 "
-"(seulement en mode -g)"
+msgstr "Affiche la boîte englobante maximale en latitude/longitude en WGS84 (seulement en mode -g)"
#: ../general/g.region/main.c:156
#, fuzzy
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
-msgstr ""
-"Ajuster la région à la résolution (par défaut, alignement sur les limites de "
-"l'emprise,fonctionne seulement pour la résolution 2D)"
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
+msgstr "Ajuster la région à la résolution (par défaut, alignement sur les limites de l'emprise,fonctionne seulement pour la résolution 2D)"
#: ../general/g.region/main.c:162
msgid "Do not update the current region"
@@ -23356,9 +21819,7 @@
#: ../general/g.region/main.c:189
msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-msgstr ""
-"Ajuster l'emprise de la région sur cette couche raster 3D (pour les valeurs "
-"2D et 3D)"
+msgstr "Ajuster l'emprise de la région sur cette couche raster 3D (pour les valeurs 2D et 3D)"
#: ../general/g.region/main.c:256
msgid "Value for the top edge"
@@ -23497,19 +21958,12 @@
msgstr ""
#: ../general/g.region/printwindow.c:412
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
msgstr ""
#: ../general/g.region/printwindow.c:637
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
-msgstr ""
-"Impossible de projeter les données en WGS84 étant donné que ce Secteur ne "
-"possède pas deparamètres de transformation de datume. Essayez de lancer g."
-"setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgstr "Impossible de projeter les données en WGS84 étant donné que ce Secteur ne possède pas deparamètres de transformation de datume. Essayez de lancer g.setproj."
#: ../general/g.region/printwindow.c:783
msgid "Lat/Long calculations are not possible from a simple XY system"
@@ -23599,8 +22053,7 @@
#: ../general/g.setproj/main.c:249
#, fuzzy
msgid "Do you wish to change the datum (or datum transformation parameters)?"
-msgstr ""
#: ../general/g.setproj/main.c:257
#, fuzzy
@@ -23657,10 +22110,7 @@
msgstr "Les informations de projection ne seront pas mises à jour."
#: ../general/g.setproj/main.c:488
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
msgstr ""
#: ../general/g.setproj/main.c:493
@@ -23848,8 +22298,7 @@
msgstr "Afficher également les paramètres 3D"
#: ../general/g.message/main.c:35
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
msgstr ""
#: ../general/g.message/main.c:37
@@ -23938,13 +22387,8 @@
#: ../general/g.mapsets/main.c:61
#, fuzzy
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
-msgstr ""
-"l'utilisateur."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
#: ../general/g.mapsets/main.c:69
#, fuzzy
@@ -24060,9 +22504,7 @@
msgstr ""
#: ../vector/v.random/main.c:121
-msgid ""
-"If type is not given then DOUBLE PRECISION is used. Writes Z data to column "
-"instead of 3D vector."
+msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
msgstr ""
#: ../vector/v.random/main.c:127 ../vector/v.in.ogr/main.c:214
@@ -24100,9 +22542,7 @@
msgstr ""
#: ../vector/v.random/main.c:234
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
msgstr ""
# c-format
@@ -24121,10 +22561,7 @@
msgstr "Importation vecteur complète"
#: ../vector/v.net.iso/main.c:75
-msgid ""
-"Splits net to bands between cost isolines (direction from centre). Centre "
-"node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation."
+msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
msgstr ""
#: ../vector/v.net.iso/main.c:99 ../vector/v.net.alloc/main.c:92
@@ -24142,9 +22579,7 @@
msgstr "Nombre de colonnes"
#: ../vector/v.net.iso/main.c:113
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated. "
-"Layer for this categories is given by nlayer option."
+msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
msgstr ""
#: ../vector/v.net.iso/main.c:122
@@ -24201,9 +22636,7 @@
msgstr "Calcul des moyennes de classes..."
#: ../vector/v.net.centrality/main.c:97
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
msgstr ""
#: ../vector/v.net.centrality/main.c:115 ../vector/v.net.allpairs/main.c:77
@@ -24352,12 +22785,8 @@
#: ../vector/v.voronoi/vo_main.c:124
#, fuzzy
-msgid ""
-"Creates a Voronoi diagram from an input vector map containing points or "
-"centroids."
-msgstr ""
-"Crée une couche raster et une couche vectorielle contenant des points placés "
-"au hasard."
+msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+msgstr "Crée une couche raster et une couche vectorielle contenant des points placés au hasard."
#: ../vector/v.voronoi/vo_main.c:139
msgid "Output tessellation as a graph (lines), not areas"
@@ -24411,12 +22840,8 @@
#: ../vector/v.voronoi/dt_main.c:47 ../vector/v.delaunay2/main.c:87
#, fuzzy
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"au hasard."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
#: ../vector/v.voronoi/dt_main.c:55 ../vector/v.delaunay2/main.c:95
#, fuzzy
@@ -24454,9 +22879,7 @@
msgstr ""
#: ../vector/v.net.steiner/main.c:349
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal"
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
msgstr ""
#: ../vector/v.net.steiner/main.c:369
@@ -24492,8 +22915,7 @@
#: ../vector/v.net.steiner/main.c:527
#, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
msgstr ""
#: ../vector/v.net.steiner/main.c:532
@@ -24622,23 +23044,13 @@
#: ../vector/v.overlay/main.c:103
#, fuzzy
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
msgstr ""
-"Opérateur qui définit la relation requise entre objets. Un objet est écrit "
-"dansla couche de sortie si le résultat de l'opération 'ainput opérateur "
-"binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de "
-"la couche est définie.\n"
+"Opérateur qui définit la relation requise entre objets. Un objet est écrit dansla couche de sortie si le résultat de l'opération 'ainput opérateur binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de la couche est définie.\n"
"\t recouvrement : les objets se recouvrent totalement ou partiellement"
#: ../vector/v.overlay/main.c:108
-msgid ""
-"and;also known as 'intersection' in GIS;or;also known as 'union' in GIS "
-"(only for atype=area);not;features from ainput not overlayed by features "
-"from binput;xor;features from either ainput or binput but not those from "
-"ainput overlayed by binput (only for atype=area)"
+msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
msgstr ""
#: ../vector/v.overlay/main.c:119
@@ -24676,9 +23088,7 @@
#: ../vector/v.overlay/main.c:293
#, fuzzy, c-format
msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
-msgstr ""
-"%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. "
-"Vérifiez le paramètre 'type'"
+msgstr "%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.overlay/main.c:327
#, fuzzy
@@ -24729,14 +23139,8 @@
#: ../vector/v.kernel/main.c:108
#, fuzzy
-msgid ""
-"Generates a raster density map from vector point data using a moving kernel "
-"or optionally generates a vector density map on a vector network."
-msgstr ""
-"Génère une couche de densité raster à partir de données vecteurs points en "
-"utilisantun noyau Gaussien isotropique mobile 2D et génère de façon "
-"optionnelle une carte vectorielle de densitésur le réseau vectoriel avec un "
-"noyau 1D"
+msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
+msgstr "Génère une couche de densité raster à partir de données vecteurs points en utilisantun noyau Gaussien isotropique mobile 2D et génère de façon optionnelle une carte vectorielle de densitésur le réseau vectoriel avec un noyau 1D"
#: ../vector/v.kernel/main.c:112
msgid "Input vector with training points"
@@ -24782,9 +23186,7 @@
msgstr "Méthode inconnue <%s>"
#: ../vector/v.kernel/main.c:168
-msgid ""
-"none;No method applied at nodes with more than 2 arcs;split;Equal split "
-"(Okabe 2009) applied at nodes;"
+msgid "none;No method applied at nodes with more than 2 arcs;split;Equal split (Okabe 2009) applied at nodes;"
msgstr ""
#: ../vector/v.kernel/main.c:175
@@ -24793,23 +23195,15 @@
msgstr "Type inconnu"
#: ../vector/v.kernel/main.c:183
-msgid ""
-"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
-"maximum (experimental)"
-msgstr ""
-"Tente de calculer un écart-type optimal avec 'stddeviation' comme maximum "
-"'expérimental'"
+msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
+msgstr "Tente de calculer un écart-type optimal avec 'stddeviation' comme maximum 'expérimental'"
#: ../vector/v.kernel/main.c:188
msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr ""
-"Calculer seulement l'écart-type optimal et quitte (aucune couche n'est "
-"écrite)"
+msgstr "Calculer seulement l'écart-type optimal et quitte (aucune couche n'est écrite)"
#: ../vector/v.kernel/main.c:193
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
msgstr ""
#: ../vector/v.kernel/main.c:198
@@ -24832,15 +23226,11 @@
#: ../vector/v.kernel/main.c:249
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
msgstr ""
#: ../vector/v.kernel/main.c:253
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function "
-"'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
msgstr ""
#: ../vector/v.kernel/main.c:290
@@ -24856,12 +23246,8 @@
#: ../vector/v.kernel/main.c:345
#, fuzzy, c-format
-msgid ""
-"Automatic choice of smoothing parameter (standard deviation), maximum "
-"possible value of standard deviation is set to %f"
-msgstr ""
-"Choix automatique du paramètre de lissage (écart-type), maximumvaleur "
-"possible de l'écart type si elle était fixée à %f"
+msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
+msgstr "Choix automatique du paramètre de lissage (écart-type), maximumvaleur possible de l'écart type si elle était fixée à %f"
# c-format
#: ../vector/v.kernel/main.c:352
@@ -24882,12 +23268,8 @@
#: ../vector/v.kernel/main.c:370
#, fuzzy, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
-msgstr ""
-"distances entre tous les points en-dessous de %e (4 * écart-type), "
-"impossiblede calculer la valeur optimale."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+msgstr "distances entre tous les points en-dessous de %e (4 * écart-type), impossiblede calculer la valeur optimale."
#: ../vector/v.kernel/main.c:381
#, c-format
@@ -24972,9 +23354,7 @@
#: ../vector/v.in.ogr/main.c:131
#, fuzzy
msgid "OGR layer name. If not given, all available layers are imported"
-msgstr ""
-"Couche vectorielle cible, si elle n'est pas indiquée, les couches "
-"disponibles seront seulement affichées"
+msgstr "Couche vectorielle cible, si elle n'est pas indiquée, les couches disponibles seront seulement affichées"
#: ../vector/v.in.ogr/main.c:133
#, fuzzy
@@ -25000,9 +23380,7 @@
#: ../vector/v.in.ogr/main.c:146
#, fuzzy
msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
-msgstr ""
-"Importer la sous-région seulement (xmin,ymin,xmax,ymax - habituellement O,S,"
-"E,N)"
+msgstr "Importer la sous-région seulement (xmin,ymin,xmax,ymax - habituellement O,S,E,N)"
#: ../vector/v.in.ogr/main.c:157
msgid "Minimum size of area to be imported (square units)"
@@ -25015,10 +23393,7 @@
#: ../vector/v.in.ogr/main.c:159
#, fuzzy
msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
-msgstr ""
-"Taille minimale des entités surfaciques à importer (en unités au carré). Les "
-"entités plus petites et les îles sont ignorées. Elle doit être supérieure à "
-"snap^2"
+msgstr "Taille minimale des entités surfaciques à importer (en unités au carré). Les entités plus petites et les îles sont ignorées. Elle doit être supérieure à snap^2"
#: ../vector/v.in.ogr/main.c:165
#, fuzzy
@@ -25027,9 +23402,7 @@
#: ../vector/v.in.ogr/main.c:167
#, fuzzy
-msgid ""
-"point;import area centroids as points;line;import area boundaries as lines;"
-"boundary;import lines as area boundaries;centroid;import points as centroids"
+msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
msgstr ""
"Option de modification du type en entrée par défaut:\n"
"\t point -> importe les centroïdes d'entités surfaciques comme points\n"
@@ -25042,12 +23415,8 @@
msgstr ""
#: ../vector/v.in.ogr/main.c:194
-msgid ""
-"List of column names to be used instead of original names, first is used for "
-"category column"
-msgstr ""
-"Liste de noms de colonnes à utiliser à la place des noms originaux, le "
-"premier correspondà la colonne de catégorie"
+msgid "List of column names to be used instead of original names, first is used for category column"
+msgstr "Liste de noms de colonnes à utiliser à la place des noms originaux, le premier correspondà la colonne de catégorie"
#: ../vector/v.in.ogr/main.c:201
msgid "List available layers in data source and exit"
@@ -25112,20 +23481,12 @@
#: ../vector/v.in.ogr/main.c:491
#, fuzzy
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location"
-msgstr ""
-"Impossible de convertir la projection de la couche en entrée au format "
-"GRASS ; impossible de créer le nouveau Secteur"
+msgid "Unable to convert input map projection to GRASS format; cannot create new location"
+msgstr "Impossible de convertir la projection de la couche en entrée au format GRASS ; impossible de créer le nouveau Secteur"
#: ../vector/v.in.ogr/main.c:503
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
-msgstr ""
-"Impossible de convertir l'information de projection de la couche de données "
-"au format GRASS pour vérification"
+msgid "Unable to convert input map projection information to GRASS format for checking"
+msgstr "Impossible de convertir l'information de projection de la couche de données au format GRASS pour vérification"
# c-format
#: ../vector/v.in.ogr/main.c:533
@@ -25144,12 +23505,8 @@
#: ../vector/v.in.ogr/main.c:596
#, fuzzy
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
-msgstr ""
-"Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' "
-"des données en entrée.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
+msgstr "Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' des données en entrée.\n"
# c-format
#: ../vector/v.in.ogr/main.c:619
@@ -25170,25 +23527,17 @@
#: ../vector/v.in.ogr/main.c:735
#, fuzzy, c-format
msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr ""
-"Ecriture de la colonne <%s> de longueur fixée à 40 caractères (possible "
-"troncature des données)"
+msgstr "Ecriture de la colonne <%s> de longueur fixée à 40 caractères (possible troncature des données)"
#: ../vector/v.in.ogr/main.c:758
#, fuzzy, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
-msgstr ""
-"Largeur de la colonne '%s' fixée à 255 (non spécifiée par OGR), des chaînes "
-"risquent d'être tronquées"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
+msgstr "Largeur de la colonne '%s' fixée à 255 (non spécifiée par OGR), des chaînes risquent d'être tronquées"
#: ../vector/v.in.ogr/main.c:770
#, fuzzy, c-format
msgid "Writing column %s with fixed length %d chars (may be truncated)"
-msgstr ""
# c-format
#: ../vector/v.in.ogr/main.c:774
@@ -25282,15 +23631,8 @@
#: ../vector/v.in.ogr/main.c:1152
#, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table. "
-"The number of features for those areas is stored as category in layer %d"
-msgstr ""
-"les entités surfaciques %d comprennent des objets se recouvrant, étant donné "
-"que les polygones se recouvrent dans les couches en entrée. De telles "
-"entités sont liées à plus d'un tuple de la table attributaire. Le nombre "
-"d'objets de ces entités est stocké comme une catégorie de la couche %d"
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
+msgstr "les entités surfaciques %d comprennent des objets se recouvrant, étant donné que les polygones se recouvrent dans les couches en entrée. De telles entités sont liées à plus d'un tuple de la table attributaire. Le nombre d'objets de ces entités est stocké comme une catégorie de la couche %d"
#: ../vector/v.in.ogr/main.c:1162
#, fuzzy, c-format
@@ -25349,13 +23691,8 @@
#: ../vector/v.in.ogr/main.c:1270
#, fuzzy
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, use -z flag to "
-"import 3D vector"
-msgstr ""
-"Les données en entrée contiennent des objets 3D. Les objets vecteurs créés "
-"sont uniquement 2D utilisez le drapeau -z pour importer des objets "
-"vectoriels 3D"
+msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
+msgstr "Les données en entrée contiennent des objets 3D. Les objets vecteurs créés sont uniquement 2D utilisez le drapeau -z pour importer des objets vectoriels 3D"
# c-format
#: ../vector/v.in.ogr/geom.c:195
@@ -25428,12 +23765,7 @@
msgstr "région <%s> non trouvée"
#: ../vector/v.net/main.c:71
-msgid ""
-"nodes;new point is placed on each node (line end) if doesn't exist;connect;"
-"connect still unconnected points to vector network by inserting new line(s);"
-"report;print to standard output {line_category start_point_category "
-"end_point_category};nreport;print to standard output {point_category "
-"line_category[,line_category...]}"
+msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
msgstr ""
#: ../vector/v.net/main.c:97
@@ -25443,8 +23775,7 @@
#: ../vector/v.net/main.c:101
#, fuzzy
msgid "Assign unique categories to new points"
-msgstr ""
-"Assignation de catégories uniques aux nouveaux points (opération=noeuds)"
+msgstr "Assignation de catégories uniques aux nouveaux points (opération=noeuds)"
#: ../vector/v.net/main.c:102
#, fuzzy
@@ -25509,9 +23840,7 @@
#: ../vector/v.proj/main.c:64
#, fuzzy
msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-"Re-projeter une couche raster depuis un Secteur (location) vers le Secteur "
-"courant."
+msgstr "Re-projeter une couche raster depuis un Secteur (location) vers le Secteur courant."
#: ../vector/v.proj/main.c:76
#, fuzzy
@@ -25634,9 +23963,7 @@
#: ../vector/v.label/main.c:138
msgid "Space between letters for curled labels (in map-units)"
-msgstr ""
-"Espacement entre caractères pour les étiquettes courbes (en unités de la "
-"carte)"
+msgstr "Espacement entre caractères pour les étiquettes courbes (en unités de la carte)"
#: ../vector/v.label/main.c:145
msgid "Label size (in points)"
@@ -25645,8 +23972,7 @@
#: ../vector/v.label/main.c:157
#, fuzzy
msgid "Rotation angle (degrees counter-clockwise)"
-msgstr ""
-"Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
+msgstr "Angle de rotation en degrés (dans le sens inverse des aiguilles d'une montre)"
#: ../vector/v.label/main.c:167
#, fuzzy
@@ -25664,15 +23990,11 @@
#: ../vector/v.label/main.c:201 ../vector/v.label.sa/main.c:181
msgid "Opaque to vector (only relevant if background color is selected)"
-msgstr ""
-"Vecteurs opaques (pertinent seulement si la couleur de fond est sélectionnée)"
+msgstr "Vecteurs opaques (pertinent seulement si la couleur de fond est sélectionnée)"
#: ../vector/v.label/main.c:252
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
-msgstr ""
-"les options de taille et d'espace sont très mal assorties, le résultat "
-"risque d'être mauvais"
+msgid "size and space options vary significantly which may lead to crummy output"
+msgstr "les options de taille et d'espace sont très mal assorties, le résultat risque d'être mauvais"
#: ../vector/v.label/main.c:260
msgid "Too many parameters for <reference>"
@@ -25700,11 +24022,8 @@
#: ../vector/v.buffer2/main.c:152 ../vector/v.buffer/main.c:153
#, fuzzy
-msgid ""
-"Creates a buffer around features of given type (areas must contain centroid)."
-msgstr ""
-"crée une zone-tampon autour d'objet d'un type donné (les entités surfaciques "
-"doivent contenir un centroïde)."
+msgid "Creates a buffer around features of given type (areas must contain centroid)."
+msgstr "crée une zone-tampon autour d'objet d'un type donné (les entités surfaciques doivent contenir un centroïde)."
#: ../vector/v.buffer2/main.c:170
#, fuzzy
@@ -25738,17 +24057,11 @@
#: ../vector/v.buffer2/main.c:209 ../vector/v.parallel/main.c:64
#: ../vector/v.buffer/main.c:200
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of "
-"buffer"
-msgstr ""
-"Distance maximale entre l'arc de cercle théorique et les segments de "
-"polygones comme multiples du buffer"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
+msgstr "Distance maximale entre l'arc de cercle théorique et les segments de polygones comme multiples du buffer"
#: ../vector/v.buffer2/main.c:225
-msgid ""
-"This is an alias to the distance option. It is retained for backwards "
-"compatibility"
+msgid "This is an alias to the distance option. It is retained for backwards compatibility"
msgstr ""
#: ../vector/v.buffer2/main.c:227 ../vector/v.buffer/main.c:175
@@ -25768,10 +24081,7 @@
msgstr ""
#: ../vector/v.buffer2/main.c:251
-msgid ""
-"The bufcol option may contain bugs during the cleaning step. If you "
-"encounter problems, use the debug option or clean manually with v.clean "
-"tool=break; v.category step=0; v.extract -d type=area"
+msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
msgstr ""
#: ../vector/v.buffer2/main.c:262
@@ -25780,16 +24090,13 @@
msgstr "L'option échelle requiert une couche de magnitude"
#: ../vector/v.buffer2/main.c:265
-msgid ""
-"The buffer option has been replaced by the distance option and will be "
-"removed in future."
+msgid "The buffer option has been replaced by the distance option and will be removed in future."
msgstr ""
#: ../vector/v.buffer2/main.c:268
#, fuzzy
msgid "Use the distance option instead of the buffer option."
-msgstr ""
#: ../vector/v.buffer2/main.c:272
#, fuzzy
@@ -25821,9 +24128,7 @@
msgstr "Type de colonne non géré"
#: ../vector/v.buffer2/main.c:380 ../vector/v.buffer/main.c:292
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
+msgid "No features available for buffering. Check type option and features available in the input vector."
msgstr ""
#: ../vector/v.buffer2/main.c:394
@@ -25902,12 +24207,8 @@
#: ../vector/v.univar/main.c:95
#, fuzzy
-msgid ""
-"Calculates univariate statistics for attribute. Variance and standard "
-"deviation is calculated only for points if specified."
-msgstr ""
-"Calcule des statistiques univariées pour un attribut. La variance et l'écart-"
-"type sont calculés uniquement pour les points si cela est spécifié."
+msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
+msgstr "Calcule des statistiques univariées pour un attribut. La variance et l'écart-type sont calculés uniquement pour les points si cela est spécifié."
#: ../vector/v.univar/main.c:111
msgid "Column name"
@@ -25921,17 +24222,11 @@
#: ../vector/v.univar/main.c:144
#, fuzzy, c-format
msgid "The '-%c' flag is currently broken, please use v.distance instead."
-msgstr ""
-"Le drapeau '-v' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--"
-"verbose' à la place."
+msgstr "Le drapeau '-v' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--verbose' à la place."
#: ../vector/v.univar/main.c:175
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
-msgstr ""
-"Type de vecteur spécifié incompatible, seuls le nombre d'objet, le minimum, "
-"le maximum et l'intervalle de valeur peuvent être calculés"
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
+msgstr "Type de vecteur spécifié incompatible, seuls le nombre d'objet, le minimum, le maximum et l'intervalle de valeur peuvent être calculés"
#: ../vector/v.univar/main.c:180
#, fuzzy
@@ -25946,8 +24241,7 @@
#: ../vector/v.univar/main.c:311
#, fuzzy, c-format
msgid " Database connection not defined for layer <%s>"
-msgstr ""
-"La connexion à la base de données n'a pas été définie pour la couche <%d>"
+msgstr "La connexion à la base de données n'a pas été définie pour la couche <%d>"
#: ../vector/v.univar/main.c:605
#, fuzzy
@@ -25961,15 +24255,11 @@
#: ../vector/v.net.distance/main.c:62
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
+msgid "Computes shortest distance via the network between the given sets of features."
msgstr ""
#: ../vector/v.net.distance/main.c:65
-msgid ""
-"Finds the shortest paths from a point 'from' to every feature 'to' and "
-"various information about this relation are uploaded to the attribute table."
+msgid "Finds the shortest paths from a point 'from' to every feature 'to' and various information about this relation are uploaded to the attribute table."
msgstr ""
#: ../vector/v.net.distance/main.c:74
@@ -26049,9 +24339,7 @@
#: ../vector/v.lrs/v.lrs.segment/main.c:72
#, fuzzy
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
msgstr "Créer des points le long des lignes en entrée."
#: ../vector/v.lrs/v.lrs.segment/main.c:76
@@ -26101,9 +24389,7 @@
#: ../vector/v.lrs/v.lrs.segment/main.c:112 ../vector/v.segment/main.c:71
#, fuzzy
msgid "Name of file containing segment rules. If not given, read from stdin."
-msgstr ""
#: ../vector/v.lrs/v.lrs.segment/main.c:151
#: ../vector/v.lrs/v.lrs.where/main.c:145
@@ -26229,9 +24515,7 @@
msgstr "%d points écrits vers la couche cible\n"
#: ../vector/v.lrs/v.lrs.where/main.c:60
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
msgstr ""
#: ../vector/v.lrs/v.lrs.where/main.c:69
@@ -26305,8 +24589,7 @@
msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:180
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:189
@@ -26341,9 +24624,7 @@
#: ../vector/v.lrs/v.lrs.create/main.c:280
#, fuzzy
msgid "Cannot get layer info for points"
-msgstr ""
-"Impossible de récupérer les informations de la couche pour cette couche "
-"vectorielle"
+msgstr "Impossible de récupérer les informations de la couche pour cette couche vectorielle"
# c-format
#: ../vector/v.lrs/v.lrs.create/main.c:315
@@ -26506,8 +24787,7 @@
#: ../vector/v.lrs/v.lrs.label/main.c:247
#, fuzzy
msgid "Only relevant if background color is selected"
-msgstr ""
#: ../vector/v.lrs/v.lrs.label/main.c:338
#, fuzzy, c-format
@@ -26562,14 +24842,11 @@
#: ../vector/v.out.ascii/out.c:47
#, fuzzy
msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-msgstr ""
-"Convertit une couche vecteur binaire GRASS en couche vecteur ASCII GRASS"
+msgstr "Convertit une couche vecteur binaire GRASS en couche vecteur ASCII GRASS"
#: ../vector/v.out.ascii/out.c:54
msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
-msgstr ""
-"Chemin vers le fichier ASCII résultat ou nom du fichier vecteur ASCII si '-"
-"o' est défini"
+msgstr "Chemin vers le fichier ASCII résultat ou nom du fichier vecteur ASCII si '-o' est défini"
#: ../vector/v.out.ascii/out.c:66
#, fuzzy
@@ -26615,9 +24892,7 @@
#: ../vector/v.out.ascii/out.c:152
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Areas will not be "
-"processed."
+msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
#: ../vector/v.out.ascii/out.c:190
@@ -26644,9 +24919,7 @@
msgstr ""
#: ../vector/v.parallel/main.c:76 ../vector/v.parallel2/main.c:85
-msgid ""
-"left;Parallel line is on the left;right;Parallel line is on the right;both;"
-"Parallel lines on both sides"
+msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
msgstr ""
#: ../vector/v.support/main.c:40
@@ -26698,12 +24971,10 @@
#: ../vector/v.support/main.c:110
#, fuzzy
msgid "Text to append to the comment line of the map's metadata file"
-msgstr ""
-"Texte à ajoute à la dernière ligne du fichier de métadonnées de la couche"
+msgstr "Texte à ajoute à la dernière ligne du fichier de métadonnées de la couche"
#: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
msgstr ""
#: ../vector/v.support/main.c:122
@@ -26742,9 +25013,7 @@
msgstr ""
#: ../vector/v.build/main.c:55
-msgid ""
-"build;build topology;dump;write topology to stdout;sdump;write spatial index "
-"to stdout;cdump;write category index to stdout"
+msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
msgstr ""
#: ../vector/v.edit/args.c:40
@@ -26842,16 +25111,12 @@
#: ../vector/v.edit/args.c:105
#, fuzzy
msgid "ASCII file to be converted to binary vector map"
-msgstr ""
#: ../vector/v.edit/args.c:107
#, fuzzy
msgid "If not given (or \"-\") reads from standard input"
-msgstr ""
#: ../vector/v.edit/args.c:117
msgid "Difference in x,y direction for moving feature or vertex"
@@ -26890,9 +25155,7 @@
msgstr ""
#: ../vector/v.edit/args.c:175
-msgid ""
-"length;Select only lines or boundaries shorter/longer than threshold "
-"distance;dangle;Select dangles shorter/longer than threshold distance"
+msgid "length;Select only lines or boundaries shorter/longer than threshold distance;dangle;Select dangles shorter/longer than threshold distance"
msgstr ""
#: ../vector/v.edit/args.c:183
@@ -26901,15 +25164,11 @@
msgstr "Nom de la couche vecteur"
#: ../vector/v.edit/args.c:190
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
msgstr ""
#: ../vector/v.edit/args.c:192
-msgid ""
-"no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to "
-"vertex"
+msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
msgstr ""
#: ../vector/v.edit/args.c:200
@@ -26972,9 +25231,7 @@
msgstr "Couche vecteur à supprimer"
#: ../vector/v.edit/main.c:57
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
msgstr ""
#: ../vector/v.edit/main.c:66
@@ -27000,9 +25257,7 @@
#: ../vector/v.edit/main.c:154
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
#: ../vector/v.edit/main.c:169
@@ -27021,9 +25276,7 @@
#: ../vector/v.edit/main.c:229
#, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
msgstr ""
# c-format
@@ -27098,9 +25351,7 @@
#: ../vector/v.edit/main.c:347
#, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
msgstr ""
# c-format
@@ -27205,8 +25456,7 @@
#: ../vector/v.in.dwg/main.c:84 ../vector/v.in.dxf/main.c:88
msgid "Invert selection by layers (don't import layers in list)"
-msgstr ""
-"Inverser la sélection de couches (ne pas importer les couches dans la liste)"
+msgstr "Inverser la sélection de couches (ne pas importer les couches dans la liste)"
#: ../vector/v.in.dwg/main.c:88 ../vector/v.in.ascii/in.c:141
#, fuzzy
@@ -27555,9 +25805,7 @@
msgstr "Impossible d'accorder des privilèges sur la table : %s"
#: ../vector/v.digit/c_face.c:312
-msgid ""
-"Cannot add database link to vector, link for given field probably already "
-"exists."
+msgid "Cannot add database link to vector, link for given field probably already exists."
msgstr ""
#: ../vector/v.digit/attr.c:94
@@ -27658,9 +25906,7 @@
#: ../vector/v.digit/attr.c:668
#, c-format
-msgid ""
-"There are no more features with category %d (layer %d) in the map, but there "
-"is record in the table. Delete this record?"
+msgid "There are no more features with category %d (layer %d) in the map, but there is record in the table. Delete this record?"
msgstr ""
#: ../vector/v.digit/attr.c:680
@@ -27685,8 +25931,7 @@
#: ../vector/v.digit/generate.c:110
#, fuzzy, c-format
-msgid ""
-"Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
+msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
#: ../vector/v.digit/generate.c:121
@@ -27723,10 +25968,8 @@
#: ../vector/v.digit/main.c:165
#, fuzzy, c-format
-msgid ""
-"Map <%s> does not exist in current mapset. Add flag -n to create a new map."
-msgstr ""
+msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
#: ../vector/v.digit/centre.c:54
#, fuzzy
@@ -27808,15 +26051,11 @@
msgstr ""
#: ../vector/v.net.alloc/main.c:65
-msgid ""
-"Centre node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation"
+msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
msgstr ""
#: ../vector/v.net.alloc/main.c:110
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
+msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
msgstr ""
#: ../vector/v.net.alloc/main.c:186
@@ -27849,9 +26088,7 @@
#: ../vector/v.kcv/main.c:174
#, fuzzy, c-format
msgid "Unable to get layer info for vector map <%s>"
-msgstr ""
-"vectorielle"
#: ../vector/v.kcv/main.c:198
#, fuzzy, c-format
@@ -27869,9 +26106,7 @@
#: ../vector/v.extract/main.c:93
-msgid ""
-"Selects vector objects from an existing vector map and creates a new map "
-"containing only the selected objects."
+msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
msgstr ""
#: ../vector/v.extract/main.c:98
@@ -27890,11 +26125,8 @@
#: ../vector/v.extract/main.c:122
#, fuzzy
-msgid ""
-"Layer number (if -1, all features in all layers of given type are extracted)"
-msgstr ""
-"Code de couche. Si fixé à -1, tous les objets de toutes les couches du type "
-"donné sont extraites."
+msgid "Layer number (if -1, all features in all layers of given type are extracted)"
+msgstr "Code de couche. Si fixé à -1, tous les objets de toutes les couches du type donné sont extraites."
#: ../vector/v.extract/main.c:136
#, fuzzy
@@ -27904,9 +26136,7 @@
#: ../vector/v.extract/main.c:137
#, fuzzy
msgid "If '-' given reads from standard input"
-msgstr ""
#: ../vector/v.extract/main.c:145
msgid "Number of random categories matching vector objects to extract"
@@ -27919,18 +26149,14 @@
#: ../vector/v.extract/main.c:156
#, fuzzy
msgid "Enter -1 to keep original categories or the desired NEW category value"
-msgstr ""
-"Saisir -1 pour conserver la catégorie originale ou la valeur de la NOUVELLE "
-"catégorie souhaitée. Si la nouvelle est >= 0, la table n'est pas copiée."
+msgstr "Saisir -1 pour conserver la catégorie originale ou la valeur de la NOUVELLE catégorie souhaitée. Si la nouvelle est >= 0, la table n'est pas copiée."
#: ../vector/v.extract/main.c:157
msgid "If new >= 0, table is not copied"
msgstr ""
#: ../vector/v.extract/main.c:175
-msgid ""
-"List, file, where and random options are exclusive. Please specify only one "
-"of them"
+msgid "List, file, where and random options are exclusive. Please specify only one of them"
msgstr ""
#: ../vector/v.extract/main.c:204 ../vector/v.drape/main.c:220
@@ -27970,9 +26196,7 @@
msgstr "%d catégories chargées depuis la table"
#: ../vector/v.extract/main.c:313
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
msgstr ""
#: ../vector/v.extract/main.c:319
@@ -27982,16 +26206,12 @@
#: ../vector/v.extract/main.c:323
#, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
msgstr ""
#: ../vector/v.extract/main.c:346
#, c-format
-msgid ""
-"Random category count is larger or equal to uniq \"%s\" feature category "
-"count %d"
+msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
msgstr ""
# c-format
@@ -28035,9 +26255,7 @@
#: ../vector/v.db.connect/main.c:52
#, fuzzy
msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Affiche/configure la connexion à la base de données de la couche vecteur "
-"vers une table attributaire"
+msgstr "Affiche/configure la connexion à la base de données de la couche vecteur vers une table attributaire"
#: ../vector/v.db.connect/main.c:72
#, fuzzy
@@ -28074,9 +26292,7 @@
#: ../vector/v.db.connect/main.c:108
msgid "Print types/names of table columns for specified layer and exit"
-msgstr ""
-"Affiche les types/noms des colonnes de la table pour une couche spécifiée et "
-"quitte"
+msgstr "Affiche les types/noms des colonnes de la table pour une couche spécifiée et quitte"
#: ../vector/v.db.connect/main.c:115
msgid "Overwrite connection parameter for certain layer"
@@ -28094,9 +26310,7 @@
#: ../vector/v.db.connect/main.c:161 ../vector/v.info/main.c:200
#, c-format
msgid "Database connection for map <%s> is not defined in DB file"
-msgstr ""
-"La connexion à la base de données pour la couche <%s> n'a pas été définie "
-"dans le fichier Base de données"
+msgstr "La connexion à la base de données pour la couche <%s> n'a pas été définie dans le fichier Base de données"
#: ../vector/v.db.connect/main.c:170
#, fuzzy, c-format
@@ -28105,8 +26319,7 @@
#: ../vector/v.db.connect/main.c:198
#, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
msgstr ""
#: ../vector/v.db.connect/main.c:261
@@ -28133,24 +26346,16 @@
#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
#, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
-msgstr ""
-"La table <%s> fait à présent partie de la couche vectorielle <%s> et risque "
-"d'être effacée ou écrasée par les modules GRASS"
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
+msgstr "La table <%s> fait à présent partie de la couche vectorielle <%s> et risque d'être effacée ou écrasée par les modules GRASS"
#: ../vector/v.db.connect/main.c:339
msgid "Select privileges were granted on the table"
msgstr "Des droits de sélection ont été accordés sur cette table"
#: ../vector/v.db.connect/main.c:346
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
-msgstr ""
-"Pour définir une nouvelle connexion vous devez spécifier ces paramètres : "
-"pilote, base de données, table [, clef [, couche]]"
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
+msgstr "Pour définir une nouvelle connexion vous devez spécifier ces paramètres : pilote, base de données, table [, clef [, couche]]"
#: ../vector/v.delaunay2/main.c:141
#, fuzzy
@@ -28196,16 +26401,12 @@
#: ../vector/v.in.ascii/in.c:50
#, fuzzy
msgid "Creates a vector map from ASCII points file or ASCII vector file."
-msgstr ""
-"Convertit une couche vecteur binaire GRASS en la combinant avec d'autres "
-"couches vectorielles binaires."
+msgstr "Convertit une couche vecteur binaire GRASS en la combinant avec d'autres couches vectorielles binaires."
#: ../vector/v.in.ascii/in.c:56
#, fuzzy
msgid "ASCII file to be imported, if not given reads from standard input"
-msgstr ""
#: ../vector/v.in.ascii/in.c:67
msgid "point;simple x,y[,z] list;standard;GRASS vector ASCII format"
@@ -28225,9 +26426,7 @@
#: ../vector/v.in.ascii/in.c:83
#, fuzzy
msgid "Number of header lines to skip at top of input file (points mode)"
-msgstr ""
-"Nombre de lignes d'en-tête à sauter au début du fichier source (écrit dans "
-"l'historique de la carte)"
+msgstr "Nombre de lignes d'en-tête à sauter au début du fichier source (écrit dans l'historique de la carte)"
#: ../vector/v.in.ascii/in.c:92
msgid "Column definition in SQL style (points mode)"
@@ -28235,9 +26434,7 @@
#: ../vector/v.in.ascii/in.c:93
#, fuzzy
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name "
-"varchar(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
msgstr ""
"Définition des colonnes en mode points en SQL, par exemple:\n"
"'x double précision, y double précision, cat int, name varchar(10)'"
@@ -28249,40 +26446,27 @@
#: ../vector/v.in.ascii/in.c:114
#, fuzzy
msgid "Number of column used as y coordinate (points mode)"
-msgstr ""
-"Nombre de colonnes utilisées comme coordonnées y (la première colonne est 1) "
-"en mode points"
+msgstr "Nombre de colonnes utilisées comme coordonnées y (la première colonne est 1) en mode points"
#: ../vector/v.in.ascii/in.c:124
#, fuzzy
msgid "Number of column used as z coordinate (points mode)"
-msgstr ""
-"Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) "
-"en mode points"
+msgstr "Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) en mode points"
#: ../vector/v.in.ascii/in.c:125
#, fuzzy
msgid "First column is 1. If 0, z coordinate is not used"
-msgstr ""
-"en mode pointsSi la valeur est 0, les coordonnées z ne sont pas utilisées."
+msgstr "Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) en mode pointsSi la valeur est 0, les coordonnées z ne sont pas utilisées."
#: ../vector/v.in.ascii/in.c:135
#, fuzzy
msgid "Number of column used as category (points mode)"
-msgstr ""
-"en mode points"
#: ../vector/v.in.ascii/in.c:137
#, fuzzy
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written "
-"to new column 'cat'"
-msgstr ""
-"Nombre de colonne utilisé comme catégorie (la première colonne est 1) en "
-"mode pointsSi la valeur est 0, une catégorie unique est assignée à chaque "
-"ligne et écrit dans la nouvelle colonne 'cat'."
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
+msgstr "Nombre de colonne utilisé comme catégorie (la première colonne est 1) en mode pointsSi la valeur est 0, une catégorie unique est assignée à chaque ligne et écrit dans la nouvelle colonne 'cat'."
#: ../vector/v.in.ascii/in.c:146
#, fuzzy
@@ -28357,16 +26541,14 @@
#: ../vector/v.in.ascii/in.c:271
#, fuzzy
-msgid ""
-"z column number > minimum last column number (incorrect field separator?)"
+msgid "z column number > minimum last column number (incorrect field separator?)"
msgstr ""
"numéro de colonne z > numéro de dernière colonne\n"
"(séparateur de champ erroné?)"
#: ../vector/v.in.ascii/in.c:276
#, fuzzy
-msgid ""
-"cat column number > minimum last column number (incorrect field separator?)"
+msgid "cat column number > minimum last column number (incorrect field separator?)"
msgstr ""
"numéro de colonne cat > numéro de dernière colonne\n"
@@ -28393,24 +26575,18 @@
#: ../vector/v.in.ascii/in.c:417
#, fuzzy, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
-msgstr ""
-"Le nombre de colonne défini (%d) ne correspond pas au nombre de colonnes "
-"(%d)de la source."
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
+msgstr "Le nombre de colonne défini (%d) ne correspond pas au nombre de colonnes (%d)de la source."
#: ../vector/v.in.ascii/in.c:445
#, fuzzy, c-format
msgid "Column number %d <%s> defined as double has only integer values"
-msgstr ""
-"La colonne %d définie comme double ne contient que des valeurs entières"
+msgstr "La colonne %d définie comme double ne contient que des valeurs entières"
#: ../vector/v.in.ascii/in.c:450
#, fuzzy, c-format
msgid "Column number %d <%s> defined as string has only integer values"
-msgstr ""
-"La colonne %d définie comme chaîne de caractères ne contient que des valeurs "
-"entières"
+msgstr "La colonne %d définie comme chaîne de caractères ne contient que des valeurs entières"
#: ../vector/v.in.ascii/in.c:458
#, fuzzy, c-format
@@ -28435,9 +26611,7 @@
#: ../vector/v.in.ascii/in.c:483
#, fuzzy, c-format
msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
-msgstr ""
-"La longeur de la colonne %d (%d) est inférieure à la longueur de la plus "
-"grande valeur (%d)"
+msgstr "La longeur de la colonne %d (%d) est inférieure à la longueur de la plus grande valeur (%d)"
#: ../vector/v.in.ascii/in.c:523
#, fuzzy
@@ -28445,9 +26619,7 @@
msgstr "Rotation des données ... "
#: ../vector/v.in.ascii/in.c:530
-msgid ""
-"Could not close attribute table. The DBMI driver did not accept all "
-"attributes"
+msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
msgstr ""
# c-format
@@ -28550,9 +26722,7 @@
#: ../vector/v.sample/main.c:98
msgid "Vector map attribute column to use for comparison"
-msgstr ""
-"Nom du champ attributaire de la couche vectorielle à utiliser pour la "
-"comparaison"
+msgstr "Nom du champ attributaire de la couche vectorielle à utiliser pour la comparaison"
#: ../vector/v.sample/main.c:101
msgid "Vector map to store differences"
@@ -28563,12 +26733,8 @@
msgstr "couche raster à échantillonner"
#: ../vector/v.sample/main.c:113
-msgid ""
-"Option scaling factor for values read from raster map. Sampled values will "
-"be multiplied by this factor"
-msgstr ""
-"Option de facteur d'échelle pour les valeurs lues dans la couche raster. Les "
-"valeurs échantillonnées seront multipliées par ce facteur"
+msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
+msgstr "Option de facteur d'échelle pour les valeurs lues dans la couche raster. Les valeurs échantillonnées seront multipliées par ce facteur"
#: ../vector/v.sample/main.c:119
#, fuzzy
@@ -28578,15 +26744,12 @@
#: ../vector/v.sample/main.c:124
#, fuzzy
msgid "Cubic convolution interpolation (default is nearest neighbor)"
-msgstr ""
-"Outil d'interpolation par convolution cubique [par défaut plus proche voisin]"
+msgstr "Outil d'interpolation par convolution cubique [par défaut plus proche voisin]"
#: ../vector/v.sample/main.c:142
#, fuzzy
msgid "Flags -b & -c are mutually exclusive. Choose only one."
-msgstr ""
-"qu'un seul."
# c-format
#: ../vector/v.sample/main.c:181
@@ -28612,9 +26775,7 @@
msgstr "Vérification des points vecteurs..."
#: ../vector/v.distance/main.c:116
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
msgstr ""
#: ../vector/v.distance/main.c:120
@@ -28667,19 +26828,11 @@
msgstr ""
#: ../vector/v.distance/main.c:181
-msgid ""
-"cat;category of the nearest feature;dist;minimum distance to nearest feature;"
-"to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate "
-"of the nearest point on the 'to' feature;to_along;distance to the nearest "
-"point on the 'to' feature along that linear feature;to_angle;angle along the "
-"nearest linear feature in the 'to' map, measured CCW from the +x axis, in "
-"radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature "
-"given by to_column option"
+msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate of the nearest point on the 'to' feature;to_along;distance to the nearest point on the 'to' feature along that linear feature;to_angle;angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature given by to_column option"
msgstr ""
#: ../vector/v.distance/main.c:202
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
msgstr ""
#: ../vector/v.distance/main.c:203
@@ -28708,9 +26861,7 @@
msgstr ""
#: ../vector/v.distance/main.c:228
-msgid ""
-"Output is written to stdout but may be uploaded to a new table created by "
-"this module; multiple 'upload' options may be used."
+msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
msgstr ""
#: ../vector/v.distance/main.c:280
@@ -28841,9 +26992,7 @@
#: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
#, fuzzy, c-format
msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr ""
-"La connexion à la base de données n'a pas été définie pour la couche <%d>. "
-"Utilisez d'abord v.db.connect."
+msgstr "La connexion à la base de données n'a pas été définie pour la couche <%d>. Utilisez d'abord v.db.connect."
# c-format
#: ../vector/v.to.db/query.c:93
@@ -28853,9 +27002,7 @@
#: ../vector/v.to.db/query.c:108
#, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
msgstr ""
#: ../vector/v.to.db/query.c:145
@@ -28897,9 +27044,7 @@
#: ../vector/v.to.db/parse.c:38
#, fuzzy
msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr ""
-"Type d'éléments (pour les coord point/centroïde valide, pour la longueur "
-"ligne/contour valide)"
+msgstr "Type d'éléments (pour les coord point/centroïde valide, pour la longueur ligne/contour valide)"
#: ../vector/v.to.db/parse.c:42
#, fuzzy
@@ -28924,8 +27069,7 @@
#: ../vector/v.to.db/parse.c:87
#, fuzzy
-msgid ""
-"mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
+msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
msgstr "mi(les), f(pieds), me(tres), k(ilomètres), a(cres), h(ectares)"
#: ../vector/v.to.db/parse.c:93
@@ -28936,9 +27080,7 @@
#: ../vector/v.to.db/parse.c:94
#, fuzzy
msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
-msgstr ""
-"Lancer une requête sur la colonne par l'option 'query'. Par exemple, 'cat', "
-"'count(*)', 'sum(val)'"
+msgstr "Lancer une requête sur la colonne par l'option 'query'. Par exemple, 'cat', 'count(*)', 'sum(val)'"
#: ../vector/v.to.db/parse.c:103
#, fuzzy
@@ -28952,8 +27094,7 @@
#: ../vector/v.to.db/parse.c:114
msgid "In print mode prints totals for options: length,area,count"
-msgstr ""
-"En mode affichage, affiche les totaux des options : longueur, aire, comptage"
+msgstr "En mode affichage, affiche les totaux des options : longueur, aire, comptage"
#: ../vector/v.to.db/parse.c:153
msgid "This option requires one column"
@@ -29105,8 +27246,7 @@
#: ../vector/v.mkgrid/main.c:111
#, fuzzy
msgid "Angle of rotation (in degrees counter-clockwise)"
-msgstr ""
# c-format
#: ../vector/v.mkgrid/main.c:119
@@ -29182,10 +27322,7 @@
msgstr "Nom de colonne de catégorie"
#: ../vector/v.build.polylines/main.c:123
-msgid ""
-"no;Do not assign any category number to polyline;first;Assign category "
-"number of first line to polyline;multi;Assign multiple category numbers to "
-"polyline"
+msgid "no;Do not assign any category number to polyline;first;Assign category number of first line to polyline;multi;Assign multiple category numbers to polyline"
msgstr ""
# c-format
@@ -29252,13 +27389,7 @@
msgstr "Icone à supprimer"
#: ../vector/v.category/main.c:87
-msgid ""
-"add;add a new category;del;delete all categories of given layer;chlayer;"
-"change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the "
-"value specified by cat option to the current category value;report;print "
-"report (statistics), in shell style: layer type count min max;print;print "
-"category values, more cats in the same layer are separated by '/';layers;"
-"print only layer numbers"
+msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/';layers;print only layer numbers"
msgstr ""
#: ../vector/v.category/main.c:104
@@ -29279,14 +27410,11 @@
msgstr ""
#: ../vector/v.category/main.c:139
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
+msgid "Database connection and attribute tables for concerned layers are not changed"
msgstr ""
#: ../vector/v.category/main.c:184
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
msgstr ""
#: ../vector/v.category/main.c:193
@@ -29505,8 +27633,7 @@
#: ../vector/v.buffer/main.c:433 ../vector/v.buffer/main.c:583
#, c-format
msgid "The tolerance was reset to %g (map units). [category %d]"
-msgstr ""
-"La tolérance a été réinitialisée à %g (en unités cartes). [catégorie %d]"
+msgstr "La tolérance a été réinitialisée à %g (en unités cartes). [catégorie %d]"
#: ../vector/v.buffer/main.c:450
#, fuzzy
@@ -29535,22 +27662,13 @@
msgstr "Nombre de points d'interpolation"
#: ../vector/v.surf.rst/main.c:166
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
-msgstr ""
-"Ré-interpole de façon approchée et fait une analyse topographique depuis une "
-"couche vecteur de points ou d'isolignes vers une nouvelle couche raster (en "
-"valeurs flottantes) en utilisant des splines régularisées avec tension et "
-"lissage."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr "Ré-interpole de façon approchée et fait une analyse topographique depuis une couche vecteur de points ou d'isolignes vers une nouvelle couche raster (en valeurs flottantes) en utilisant des splines régularisées avec tension et lissage."
#: ../vector/v.surf.rst/main.c:192
#, fuzzy
msgid "Use z-coordinates (3D vector only)"
-msgstr ""
-"Valeur du champ. Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D "
-"seulement)"
+msgstr "Valeur du champ. Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D seulement)"
#: ../vector/v.surf.rst/main.c:198
msgid "Perform cross-validation procedure without raster approximation"
@@ -29594,8 +27712,7 @@
#: ../vector/v.surf.rst/main.c:272
msgid "Output cross-validation errors vector point file"
-msgstr ""
-"Fichier en sortie de validation croisée des erreurs sur vecteurs points"
+msgstr "Fichier en sortie de validation croisée des erreurs sur vecteurs points"
#: ../vector/v.surf.rst/main.c:279
msgid "Output vector map showing quadtree segmentation"
@@ -29610,12 +27727,8 @@
msgstr "Nom de la couche raster utilisée comme masque (MASK)"
#: ../vector/v.surf.rst/main.c:300
-msgid ""
-"Name of the attribute column with values to be used for approximation (if "
-"layer>0)"
-msgstr ""
-"Nom de la colonne attributaire où prendre les valeurs à utiliser pour "
-"calculer les valeurs approchées(si couche>0)"
+msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
+msgstr "Nom de la colonne attributaire où prendre les valeurs à utiliser pour calculer les valeurs approchées(si couche>0)"
#: ../vector/v.surf.rst/main.c:308 ../vector/v.vol.rst/main.c:260
msgid "Tension parameter"
@@ -29639,16 +27752,11 @@
#: ../vector/v.surf.rst/main.c:349 ../vector/v.vol.rst/main.c:336
msgid "Minimum distance between points (to remove almost identical points)"
-msgstr ""
-"Distance minimum entre les points en unités carte (pour supprimer les points "
-"quasi-identiques)"
+msgstr "Distance minimum entre les points en unités carte (pour supprimer les points quasi-identiques)"
#: ../vector/v.surf.rst/main.c:358
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
-msgstr ""
-"Distance maximum entre les points des courbes de niveau en unités carte "
-"(pour insérer des points supplémentaires)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
+msgstr "Distance maximum entre les points des courbes de niveau en unités carte (pour insérer des points supplémentaires)"
#: ../vector/v.surf.rst/main.c:367
msgid "Conversion factor for values used for approximation"
@@ -29656,9 +27764,7 @@
#: ../vector/v.surf.rst/main.c:375
msgid "Anisotropy angle (in degrees counterclockwise from East)"
-msgstr ""
-"Angle d'anisotropie (en degrés, sens inverse des aiguilles d'une montre en "
-"partant de l'Est)"
+msgstr "Angle d'anisotropie (en degrés, sens inverse des aiguilles d'une montre en partant de l'Est)"
#: ../vector/v.surf.rst/main.c:408 ../vector/v.surf.rst/main.c:413
#: ../vector/v.surf.rst/main.c:418 ../vector/v.surf.rst/main.c:423
@@ -29672,20 +27778,12 @@
msgstr "Vous ne fabriquez aucun fichier raster ou vecteur en sortie"
#: ../vector/v.surf.rst/main.c:456
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
-msgstr ""
-"Vous devez spécifier les deux options de validation croisée (drapeau -c et "
-"sortie vecteur cvdev)"
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
+msgstr "Vous devez spécifier les deux options de validation croisée (drapeau -c et sortie vecteur cvdev)"
#: ../vector/v.surf.rst/main.c:459
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or "
-"devi file"
-msgstr ""
-"La validation croisée ne peut être calculée simultanément avec la sortie "
-"raster ou la sortie du fichier devi"
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
+msgstr "La validation croisée ne peut être calculée simultanément avec la sortie raster ou la sortie du fichier devi"
#: ../vector/v.surf.rst/main.c:462
msgid "Both z-coordinate and zcol attribute defined, only one is allowed"
@@ -29701,15 +27799,11 @@
#: ../vector/v.surf.rst/main.c:492
msgid "Both smatt and smooth options specified - using constant"
-msgstr ""
-"Les options smatt et smooth sont toutes deux spécifiées - utilisation de "
-"constante"
+msgstr "Les options smatt et smooth sont toutes deux spécifiées - utilisation de constante"
#: ../vector/v.surf.rst/main.c:502
msgid "The computation will last too long - lower npmin is suggested"
-msgstr ""
-"Le calcul risque de durer trop longtemps - nous vous suggérons de choisir "
-"une npmin plus basse"
+msgstr "Le calcul risque de durer trop longtemps - nous vous suggérons de choisir une npmin plus basse"
#: ../vector/v.surf.rst/main.c:549
msgid "Cannot create quaddata"
@@ -29740,9 +27834,7 @@
#: ../vector/v.surf.rst/main.c:796
msgid "Cannot write raster maps -- try to increase resolution"
-msgstr ""
-"Impossible d'écrire les fichiers de cellules -- essayez d'augmenter la "
-"résolution"
+msgstr "Impossible d'écrire les fichiers de cellules -- essayez d'augmenter la résolution"
#: ../vector/v.transform/get_coor.c:36
#, fuzzy
@@ -29788,9 +27880,7 @@
#: ../vector/v.transform/main.c:75
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
msgstr ""
#: ../vector/v.transform/main.c:82
@@ -29820,12 +27910,8 @@
#: ../vector/v.transform/main.c:103
#, fuzzy
-msgid ""
-"Instead of points use transformation parameters (xshift, yshift, zshift, "
-"xscale, yscale, zscale, zrot)"
-msgstr ""
-"A la place des points, utilisez les options de transformation (xshift, "
-"yshift, zshift, xscale, yscale, zscale, zrot)"
+msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
+msgstr "A la place des points, utilisez les options de transformation (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
#: ../vector/v.transform/main.c:117
#, fuzzy
@@ -29834,12 +27920,8 @@
#: ../vector/v.transform/main.c:118
#, fuzzy
-msgid ""
-"If not given, transformation parameters (xshift, yshift, zshift, xscale, "
-"yscale, zscale, zrot) are used instead"
-msgstr ""
+msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
#: ../vector/v.transform/main.c:129
msgid "Shifting value for x coordinates"
@@ -29867,9 +27949,7 @@
#: ../vector/v.transform/main.c:184
msgid "Rotation around z axis in degrees counterclockwise"
-msgstr ""
-"Angle de rotation autour de l'axe z en degrés (dans le sens inverse des "
-"aiguilles d'une montre)"
+msgstr "Angle de rotation autour de l'axe z en degrés (dans le sens inverse des aiguilles d'une montre)"
#: ../vector/v.transform/main.c:190
#, fuzzy
@@ -29887,19 +27967,13 @@
#: ../vector/v.transform/main.c:217
#, c-format
-msgid ""
-"The '%c' flag is deprecated and will be removed in future. Transformation "
-"parameters are used automatically when no pointsfile is given."
+msgid "The '%c' flag is deprecated and will be removed in future. Transformation parameters are used automatically when no pointsfile is given."
msgstr ""
#: ../vector/v.transform/main.c:223
#, fuzzy, c-format
-msgid ""
-"The '%c' flag is deprecated and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"Couche raster %i le nom de fichier %s existe déjà. Ce fichier va être "
-"écrasé!\n"
+msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
+msgstr "Couche raster %i le nom de fichier %s existe déjà. Ce fichier va être écrasé!\n"
#: ../vector/v.transform/main.c:232
#, c-format
@@ -29912,9 +27986,7 @@
msgstr ""
#: ../vector/v.transform/main.c:242
-msgid ""
-"Name of table and name for output vector map must be different. Otherwise "
-"the table is overwritten."
+msgid "Name of table and name for output vector map must be different. Otherwise the table is overwritten."
msgstr ""
#: ../vector/v.transform/main.c:259
@@ -29961,16 +28033,13 @@
#: ../vector/v.transform/trans_digit.c:125
#, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
msgstr ""
#: ../vector/v.transform/trans_digit.c:136
#, fuzzy
msgid "No category number defined. Using default transformation parameters."
-msgstr ""
-"Vérifier l'information de datum et afficher les paramètres de transformation"
+msgstr "Vérifier l'information de datum et afficher les paramètres de transformation"
#: ../vector/lidar/v.outlier/main.c:74
#, fuzzy
@@ -29988,9 +28057,7 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:86
#: ../vector/lidar/v.lidar.correction/main.c:81
#: ../vector/lidar/v.surf.bspline/main.c:96
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
msgstr ""
#: ../vector/lidar/v.outlier/main.c:92
@@ -30241,9 +28308,7 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:396
#, fuzzy
msgid "Allocating memory for bilinear interpolation"
-msgstr ""
-"Impossible de calculer le centroïde de la surface (problème d'allocation "
-"mémoire)"
+msgstr "Impossible de calculer le centroïde de la surface (problème d'allocation mémoire)"
#: ../vector/lidar/v.lidar.edgedetection/main.c:429
#, fuzzy
@@ -30272,9 +28337,7 @@
msgstr ""
#: ../vector/lidar/v.lidar.correction/main.c:75
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
msgstr ""
#: ../vector/lidar/v.lidar.correction/main.c:85
@@ -30367,9 +28430,7 @@
msgstr ""
#: ../vector/lidar/v.surf.bspline/main.c:90
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
msgstr ""
#: ../vector/lidar/v.surf.bspline/main.c:104
@@ -30396,9 +28457,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:159
msgid "Attribute table column with values to interpolate (if layer>0)"
-msgstr ""
-"Colonne de la table attributaire avec les valeurs à interpoler (si la "
-"couche>0)"
+msgstr "Colonne de la table attributaire avec les valeurs à interpoler (si la couche>0)"
#: ../vector/lidar/v.surf.bspline/main.c:172
msgid "Choose either vector or raster output, not both"
@@ -30416,9 +28475,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:231
#, fuzzy
msgid "Layer but not column with z values given"
-msgstr ""
-"couche>0)"
#: ../vector/lidar/v.surf.bspline/main.c:254
msgid "Cross validation didn't finish correctly"
@@ -30436,9 +28493,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:285
#, c-format
-msgid ""
-"Sorry, <%s> driver is not allowed for vector output in this module. Try with "
-"a raster output or other driver."
+msgid "Sorry, <%s> driver is not allowed for vector output in this module. Try with a raster output or other driver."
msgstr ""
#: ../vector/lidar/v.surf.bspline/main.c:307
@@ -30468,9 +28523,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:392
#, fuzzy
-msgid ""
-"Cannot allocate memory for auxiliar matrix.Consider changing region "
-"resolution"
+msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
msgstr "Impossible d'allouer de la mémoire"
#: ../vector/lidar/v.surf.bspline/main.c:590
@@ -30500,9 +28553,7 @@
msgstr "%d points en dehors de la région courante"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:93
-msgid ""
-"Maybe, it takes too long. It will depend on how many points you are "
-"considering."
+msgid "Maybe, it takes too long. It will depend on how many points you are considering."
msgstr ""
#: ../vector/lidar/v.surf.bspline/crosscorr.c:124
@@ -30517,8 +28568,7 @@
#: ../vector/lidar/v.surf.bspline/crosscorr.c:156
#, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
msgstr ""
#: ../vector/lidar/v.surf.bspline/crosscorr.c:174
@@ -30544,15 +28594,12 @@
#: ../vector/lidar/v.surf.bspline/crosscorr.c:318
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
msgstr ""
#: ../vector/lidar/v.surf.bspline/crosscorr.c:320
#, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
msgstr ""
#: ../vector/lidar/v.surf.bspline/crosscorr.c:328
@@ -30578,9 +28625,7 @@
msgstr ""
#: ../vector/lidar/v.lidar.growing/main.c:81
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
msgstr ""
#: ../vector/lidar/v.lidar.growing/main.c:86
@@ -30638,9 +28683,7 @@
msgstr "Ne pas créer de table attributaire"
#: ../vector/v.reclass/main.c:66
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
msgstr ""
#: ../vector/v.reclass/main.c:83
@@ -30912,16 +28955,12 @@
#: ../vector/v.external/main.c:60
#, fuzzy
msgid "Creates a new vector as a read-only link to OGR layer."
-msgstr ""
#: ../vector/v.external/main.c:75
#, fuzzy
msgid "Output vector. If not given, available layers are printed only."
-msgstr ""
-"Couche vectorielle cible, si elle n'est pas indiquée, les couches "
-"disponibles seront seulement affichées"
+msgstr "Couche vectorielle cible, si elle n'est pas indiquée, les couches disponibles seront seulement affichées"
#: ../vector/v.external/main.c:83
msgid ""
@@ -30929,8 +28968,7 @@
"\t\tESRI Shapefile: shapefile name\n"
"\t\tMapInfo File: mapinfo file name"
msgstr ""
-"nom de la couche OGR. Si elle n'est pas indiquée, les couches disponibles "
-"seront seulement affichées. Exemples:\n"
+"nom de la couche OGR. Si elle n'est pas indiquée, les couches disponibles seront seulement affichées. Exemples:\n"
"\t\tShapefile ESRI : nom du shapefile\n"
"\t\tFichier MapInfo : nom du fichier mapinfo"
@@ -30962,9 +29000,7 @@
#: ../vector/v.out.ogr/main.c:107
#, fuzzy
-msgid ""
-"Feature type(s). Combinations not supported by all output formats. Default: "
-"first type found in input."
+msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
msgstr "Type d'objet. Le mélange de types n'est pas géré par tous les format."
#: ../vector/v.out.ogr/main.c:115
@@ -31014,35 +29050,25 @@
#: ../vector/v.out.ogr/main.c:163
#, fuzzy
msgid "Open an existing datasource for update"
-msgstr ""
-"Nettoyer les données existantes qui se trouvent dans le répertoire de "
-"téléchargement"
+msgstr "Nettoyer les données existantes qui se trouvent dans le répertoire de téléchargement"
#: ../vector/v.out.ogr/main.c:168
msgid "Skip export of GRASS category ID ('cat') attribute"
msgstr ""
#: ../vector/v.out.ogr/main.c:172
-msgid ""
-"Export features with category (labeled) only. Otherwise all features are "
-"exported"
-msgstr ""
-"Exporter seulement les objets dotés de catégorie (étiquette). Sinon tous les "
-"objets sontexportés"
+msgid "Export features with category (labeled) only. Otherwise all features are exported"
+msgstr "Exporter seulement les objets dotés de catégorie (étiquette). Sinon tous les objets sontexportés"
#: ../vector/v.out.ogr/main.c:177
#, fuzzy
msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-"Utiliser le format de fichier .prj de style ESRI (ne s'applique qu'aux "
-"sorties sous forme de SHAPE)"
+msgstr "Utiliser le format de fichier .prj de style ESRI (ne s'applique qu'aux sorties sous forme de SHAPE)"
#: ../vector/v.out.ogr/main.c:182
#, fuzzy
msgid "Create 3D output if input is 3D (applies to Shapefile output only)"
-msgstr ""
#: ../vector/v.out.ogr/main.c:187
msgid "Export lines as polygons"
@@ -31069,143 +29095,88 @@
msgstr "Le mélange de types n'est pas géré par tous les formats."
#: ../vector/v.out.ogr/main.c:327
-msgid ""
-"The map contains islands. To preserve them in the output map, use the -c flag"
+msgid "The map contains islands. To preserve them in the output map, use the -c flag"
msgstr ""
#: ../vector/v.out.ogr/main.c:332
#, fuzzy, c-format
-msgid ""
-"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Point(s) trouvé(s), mais impossible de les exporter. Vérifiez le "
-"paramètre 'type'"
+msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Point(s) trouvé(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:337
#, fuzzy, c-format
-msgid ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Ligne(s) trouvée(s), mais impossible de les exporter. Vérifiez le "
-"paramètre 'type'"
+msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Ligne(s) trouvée(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:343
#, fuzzy, c-format
-msgid ""
-"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Contours(s) trouvé(s), mais impossible de les exporter. Vérifiez le "
-"paramètre 'type'"
+msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Contours(s) trouvé(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:349
#, fuzzy, c-format
-msgid ""
-"%d centroid(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Centroïde(s) trouvé(s), mais impossible de les exporter. Vérifiez le "
-"paramètre 'type'"
+msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Centroïde(s) trouvé(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:354
#, fuzzy, c-format
-msgid ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. "
-"Vérifiez le paramètre 'type'"
+msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Entités surfacique(s) trouvée(s), mais impossible de les exporter. Vérifiez le paramètre 'type'"
#: ../vector/v.out.ogr/main.c:358
#, fuzzy, c-format
-msgid ""
-"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
+msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
#: ../vector/v.out.ogr/main.c:364
#, fuzzy, c-format
-msgid ""
-"%d kernel(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"paramètre 'type'"
+msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
#: ../vector/v.out.ogr/main.c:369
#, fuzzy, c-format
-msgid ""
-"%d volume(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"paramètre 'type'"
+msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
#: ../vector/v.out.ogr/main.c:375
#, fuzzy
-msgid ""
-"No points found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"paramètre 'type'"
+msgid "No points found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:384
#, fuzzy
-msgid ""
-"No lines found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"paramètre 'type'"
+msgid "No lines found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:394
#, fuzzy
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this geometry "
-"type."
-msgstr ""
-"paramètre 'type'"
+msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:403
#, fuzzy
-msgid ""
-"No areas found, but requested to be exported. Will skip this geometry type."
-msgstr ""
+msgid "No areas found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:413
#, fuzzy
-msgid ""
-"No centroids found, but requested to be exported. Will skip this geometry "
-"type."
-msgstr ""
-"paramètre 'type'"
+msgid "No centroids found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:422
#, fuzzy
-msgid ""
-"No faces found, but requested to be exported. Will skip this geometry type."
-msgstr ""
+msgid "No faces found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:431
#, fuzzy
-msgid ""
-"No kernels found, but requested to be exported. Will skip this geometry type."
-msgstr ""
+msgid "No kernels found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:440
#, fuzzy
-msgid ""
-"No volumes found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"paramètre 'type'"
+msgid "No volumes found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:451
#, fuzzy
@@ -31240,16 +29211,12 @@
#: ../vector/v.out.ogr/main.c:584
#, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
-"'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
msgstr ""
#: ../vector/v.out.ogr/main.c:591
#, c-format
-msgid ""
-"'lco') to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
msgstr ""
#: ../vector/v.out.ogr/main.c:604
@@ -31259,9 +29226,7 @@
#: ../vector/v.out.ogr/main.c:614
msgid "No attribute table found -> using only category numbers as attributes"
-msgstr ""
-"Aucune table attributaire trouvée -> on utilise les identifiants de "
-"catégories comme attributs"
+msgstr "Aucune table attributaire trouvée -> on utilise les identifiants de catégories comme attributs"
#: ../vector/v.out.ogr/main.c:618
msgid "Exporting 'cat' anyway, as it is the only attribute table field"
@@ -31341,20 +29306,15 @@
#: ../vector/v.patch/main.c:69
#, fuzzy
msgid "Create a new vector map layer by combining other vector map layers."
-msgstr ""
#: ../vector/v.patch/main.c:80
#, fuzzy
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
msgstr "Nom de la couche en sortie où les erreurs seront écrites"
#: ../vector/v.patch/main.c:84
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
+msgid "Append files to existing file (overwriting existing files must be activated)"
msgstr ""
#: ../vector/v.patch/main.c:89
@@ -31365,9 +29325,7 @@
#: ../vector/v.patch/main.c:91
#, fuzzy
msgid "Only the table of layer 1 is currently supported"
-msgstr ""
-"Copie égalment la table attributaire. Seule la table de la couche 1 est "
-"prise en compte pour le moment"
+msgstr "Copie égalment la table attributaire. Seule la table de la couche 1 est prise en compte pour le moment"
#: ../vector/v.patch/main.c:189
msgid "Missing table"
@@ -31417,9 +29375,7 @@
#: ../vector/v.patch/main.c:322
#, fuzzy, c-format
msgid "Error reading vector map <%s> - some data may not be correct"
-msgstr ""
-"Erreur de lecture du fichier '%s'. Certaines données ne seront pas "
-"correctes\n"
+msgstr "Erreur de lecture du fichier '%s'. Certaines données ne seront pas correctes\n"
#: ../vector/v.patch/main.c:364
#, fuzzy, c-format
@@ -31429,16 +29385,12 @@
#: ../vector/v.patch/main.c:370
#, fuzzy
msgid "Intersections at borders will have to be snapped"
-msgstr ""
-"Les intersections aux limites doivent faire l'objet d'une opération de "
-"capture."
+msgstr "Les intersections aux limites doivent faire l'objet d'une opération de capture."
#: ../vector/v.patch/main.c:371
#, fuzzy
msgid "Lines common between files will have to be edited"
-msgstr ""
-"Les lignes communes aux deux fichiers devront faire l'objet d'une session "
-"d'édition."
+msgstr "Les lignes communes aux deux fichiers devront faire l'objet d'une session d'édition."
#: ../vector/v.patch/main.c:372
#, fuzzy
@@ -31498,15 +29450,9 @@
#: ../vector/v.select/args.c:47
#, fuzzy
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
msgstr ""
-"Opérateur qui définit la relation requise entre objets. Un objet est écrit "
-"dansla couche de sortie si le résultat de l'opération 'ainput opérateur "
-"binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de "
-"la couche est définie.\n"
+"Opérateur qui définit la relation requise entre objets. Un objet est écrit dansla couche de sortie si le résultat de l'opération 'ainput opérateur binput' est vrai. Un objeten entrée est considéré vrai, si la catégorie de la couche est définie.\n"
"\t recouvrement : les objets se recouvrent totalement ou partiellement"
#: ../vector/v.select/args.c:53
@@ -31514,15 +29460,7 @@
msgstr ""
#: ../vector/v.select/args.c:58
-msgid ""
-"overlap;features partially or completely overlap;equals;features are "
-"spatially equals (using GEOS);disjoint;features do not spatially intersect "
-"(using GEOS);intersects;features spatially intersect (using GEOS);touches;"
-"features spatially touches (using GEOS);crosses;features spatially crosses "
-"(using GEOS);within;feature A is completely inside feature B (using GEOS);"
-"contains;feature B is completely inside feature A (using GEOS);overlaps;"
-"features spatially overlap (using GEOS);relate;feature A is spatially "
-"related to feature B (using GEOS, requires 'relate' option);"
+msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
msgstr ""
#: ../vector/v.select/args.c:75
@@ -31542,8 +29480,7 @@
#: ../vector/v.select/main.c:54
#, fuzzy
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
msgstr "Sélectionne les objets de ainput à partir des objets de binput"
#: ../vector/v.select/main.c:87
@@ -31559,9 +29496,7 @@
#: ../vector/v.select/main.c:172
#, fuzzy, c-format
msgid "Unable to read line id %d from vector map <%s>"
-msgstr ""
-"vectorielle"
#: ../vector/v.select/main.c:278
#, fuzzy
@@ -31604,8 +29539,7 @@
#: ../vector/v.convert/att.c:36
#, fuzzy
msgid "No category labels (dig_cats) found, no table created"
-msgstr ""
-"Aucune étiquette de catégorie (dig_cats) trouvée, aucune table créée.\n"
+msgstr "Aucune étiquette de catégorie (dig_cats) trouvée, aucune table créée.\n"
# c-format
#: ../vector/v.convert/att.c:41
@@ -31683,13 +29617,8 @@
#: ../vector/v.convert/read.c:99
#, fuzzy
-msgid ""
-"Input file is not portable. We will attempt to convert anyway but conversion "
-"may fail. Please read manual for detail information."
-msgstr ""
-"ATTENTION: Le format de fichier d'entrée n'est pas supporté. Nous allons "
-"essayer de le convertir quand même mais la conversion peut échouer. Veuillez "
-"lire le manuel pour plus d'informations."
+msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
+msgstr "ATTENTION: Le format de fichier d'entrée n'est pas supporté. Nous allons essayer de le convertir quand même mais la conversion peut échouer. Veuillez lire le manuel pour plus d'informations."
#: ../vector/v.convert/read.c:185
#, fuzzy, c-format
@@ -31829,9 +29758,7 @@
#: ../vector/v.in.sites/main.c:59
#, fuzzy
msgid "Converts a GRASS site_lists file into a vector map."
-msgstr ""
-"Convertit le fichier GRASS ascii ou le fichier points en couche vectorielle "
-"binaire"
+msgstr "Convertit le fichier GRASS ascii ou le fichier points en couche vectorielle binaire"
#: ../vector/v.in.sites/main.c:83
#, fuzzy, c-format
@@ -31916,31 +29843,12 @@
msgstr ""
#: ../vector/v.clean/main.c:66
-msgid ""
-"break;break lines at each intersection;rmdupl;remove duplicate geometry "
-"features (pay attention to categories!);rmdangle;remove dangles, threshold "
-"ignored if < 0;chdangle;change the type of boundary dangle to line, "
-"threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges "
-"connecting area and island or 2 islands;chbridge;change the type of bridges "
-"connecting area and island or 2 islands from boundary to line;snap;snap "
-"lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' "
-"option ignored);bpol;break (topologically clean) polygons (imported from non "
-"topological format, like ShapeFile). Boundaries are broken on each point "
-"shared between 2 and more polygons where angles of segments are different;"
-"prune;remove vertices in threshold from lines and boundaries, boundary is "
-"pruned only if topology is not damaged (new intersection, changed attachment "
-"of centroid), first and last segment of the boundary is never changed;rmarea;"
-"remove small areas, the longest boundary with adjacent area is removed;"
-"rmline;remove all lines or boundaries of zero length, threshold is ignored;"
-"rmsa;remove small angles between lines at nodes"
+msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachment of centroid), first and last segment of the boundary is never changed;rmarea;remove small ar
eas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
msgstr ""
#: ../vector/v.clean/main.c:94
-msgid ""
-"Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-msgstr ""
-"Seuillage en unités de la carte, une valeur pour chaque outil (par défaut : "
-"0.0[,0.0,...])"
+msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+msgstr "Seuillage en unités de la carte, une valeur pour chaque outil (par défaut : 0.0[,0.0,...])"
#: ../vector/v.clean/main.c:100
#, fuzzy
@@ -32130,9 +30038,7 @@
#: ../vector/v.perturb/main.c:75
msgid "Random location perturbations of GRASS vector points"
-msgstr ""
-"Génère des perturbations aléatoires sur la position de points vectoriels "
-"GRASS"
+msgstr "Génère des perturbations aléatoires sur la position de points vectoriels GRASS"
#: ../vector/v.perturb/main.c:78
msgid "Vector points to be spatially perturbed"
@@ -32143,14 +30049,8 @@
msgstr "Distribution de la perturbation"
#: ../vector/v.perturb/main.c:96
-msgid ""
-"Parameter(s) of distribution. If the distribution is uniform, only one "
-"parameter, the maximum, is needed. For a normal distribution, two "
-"parameters, the mean and standard deviation, are required."
-msgstr ""
-"Paramètre(s) de distribution. Si la distribution est uniforme, seul un "
-"paramètre, le maximum, est nécessaire. Pour une distribution normale, deux "
-"paramètres, la moyenne et l'écart-type, sont nécessaires."
+msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
+msgstr "Paramètre(s) de distribution. Si la distribution est uniforme, seul un paramètre, le maximum, est nécessaire. Pour une distribution normale, deux paramètres, la moyenne et l'écart-type, sont nécessaires."
#: ../vector/v.perturb/main.c:106
msgid "Minimum deviation in map units"
@@ -32166,13 +30066,11 @@
#: ../vector/v.perturb/main.c:140
msgid "Maximum of uniform distribution must be >= zero"
-msgstr ""
-"Le maximum d'une distribution uniforme doit être supérieure ou égale à zéro"
+msgstr "Le maximum d'une distribution uniforme doit être supérieure ou égale à zéro"
#: ../vector/v.perturb/main.c:147
msgid "Standard deviation of normal distribution must be >= zero"
-msgstr ""
-"L'écart-type d'une distribution normale doit être supérieur ou égal à zéro"
+msgstr "L'écart-type d'une distribution normale doit être supérieur ou égal à zéro"
#: ../vector/v.perturb/main.c:232
msgid "Cannot get db link info"
@@ -32185,9 +30083,7 @@
#: ../vector/v.vect.stats/main.c:129
#, fuzzy
msgid "Count points in areas, calculate statistics."
-msgstr ""
-"Nom de la colonne sur laquelle calculée les statistiques (le type doit être "
-"numérique)"
+msgstr "Nom de la colonne sur laquelle calculée les statistiques (le type doit être numérique)"
#: ../vector/v.vect.stats/main.c:133
#, fuzzy
@@ -32230,9 +30126,7 @@
msgstr "Les noms de colonne sont différents."
#: ../vector/v.vect.stats/main.c:187
-msgid ""
-"Column to hold points count, must be of type integer, will be created if not "
-"existing"
+msgid "Column to hold points count, must be of type integer, will be created if not existing"
msgstr ""
#: ../vector/v.vect.stats/main.c:194
@@ -32241,9 +30135,7 @@
#: ../vector/v.vect.stats/main.c:196
-msgid ""
-"Column to hold statistics, must be of type double, will be created if not "
-"existing"
+msgid "Column to hold statistics, must be of type double, will be created if not existing"
msgstr ""
#: ../vector/v.vect.stats/main.c:206
@@ -32326,10 +30218,7 @@
msgstr ""
#: ../vector/v.class/main.c:166
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
msgstr ""
#: ../vector/v.class/main.c:193
@@ -32380,9 +30269,7 @@
#: ../vector/v.info/main.c:66
#, fuzzy
msgid "Outputs basic information about a user-specified vector map."
-msgstr ""
-"Afficher des informations générales à propos d'une couche vecteur spécifiée "
-"par l'utilisateur."
+msgstr "Afficher des informations générales à propos d'une couche vecteur spécifiée par l'utilisateur."
#: ../vector/v.info/main.c:75
msgid "Print vector history instead of info"
@@ -32390,9 +30277,7 @@
#: ../vector/v.info/main.c:81
msgid "Print types/names of table columns for specified layer instead of info"
-msgstr ""
-"Afficher les types/noms des colonnes de la table pour une couche spécifiée à "
-"la place des informations"
+msgstr "Afficher les types/noms des colonnes de la table pour une couche spécifiée à la place des informations"
#: ../vector/v.info/main.c:96
#, fuzzy
@@ -32603,9 +30488,7 @@
#: ../vector/v.to.3d/trans2.c:113
#, fuzzy, c-format
msgid "Unable to get height for feature category %d"
-msgstr ""
-"Impossible de récupérer les informations de la couche pour cette couche "
-"vectorielle"
+msgstr "Impossible de récupérer les informations de la couche pour cette couche vectorielle"
#: ../vector/v.to.3d/main.c:37
#, fuzzy
@@ -32683,8 +30566,7 @@
msgstr "Indicateur de valeur vide ('null')"
#: ../vector/v.db.select/main.c:89
-msgid ""
-"Print minimal region extent of selected vector features instead of attributes"
+msgid "Print minimal region extent of selected vector features instead of attributes"
msgstr ""
#: ../vector/v.db.select/main.c:93 ../db/base/select.c:250
@@ -32697,9 +30579,7 @@
#: ../vector/v.db.select/main.c:152
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
# c-format
@@ -32737,9 +30617,7 @@
#: ../vector/v.in.dxf/main.c:62
msgid "Converts files in DXF format to GRASS vector map format."
-msgstr ""
-"Convertir les fichiers au formats DXF vers le format de fichier vectoriel "
-"GRASS"
+msgstr "Convertir les fichiers au formats DXF vers le format de fichier vectoriel GRASS"
#: ../vector/v.in.dxf/main.c:66
msgid "Ignore the map extent of DXF file"
@@ -32815,9 +30693,7 @@
#: ../vector/v.in.dxf/write_vect.c:230
#, fuzzy, c-format
msgid "Unable to add database link for vector map <%s>"
-msgstr ""
-"vectorielle"
#: ../vector/v.split/main.c:43
msgid "Split lines to shorter segments."
@@ -32842,14 +30718,11 @@
#: ../vector/v.what.rast/main.c:83
#, fuzzy
msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-"Charge les valeurs raster dans la table aux positions des points vecteurs"
+msgstr "Charge les valeurs raster dans la table aux positions des points vecteurs"
#: ../vector/v.what.rast/main.c:88
msgid "Name of input vector points map for which to edit attribute table"
-msgstr ""
-"Nom de la couche de points vecteurs en entrée pour laquelle mettre à jour la "
-"table attributaire"
+msgstr "Nom de la couche de points vecteurs en entrée pour laquelle mettre à jour la table attributaire"
#: ../vector/v.what.rast/main.c:92
msgid "Name of existing raster map to be queried"
@@ -32872,9 +30745,7 @@
#: ../vector/v.what.rast/main.c:169
msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr ""
-"Le type de raster est flottant et le type de colonne est entier, des données "
-"vont être perdues!!"
+msgstr "Le type de raster est flottant et le type de colonne est entier, des données vont être perdues!!"
# c-format
#: ../vector/v.what.rast/main.c:249
@@ -32927,9 +30798,7 @@
msgstr ""
#: ../vector/v.net.salesman/main.c:131
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
msgstr ""
#: ../vector/v.net.salesman/main.c:149
@@ -33041,8 +30910,7 @@
#: ../vector/v.extrude/main.c:71
#, fuzzy
msgid "Extrudes flat vector object to 3D with defined height."
-msgstr ""
-"Mettre en relief des objets vecteurs plats en fonction d'une hauteur définie"
+msgstr "Mettre en relief des objets vecteurs plats en fonction d'une hauteur définie"
#: ../vector/v.extrude/main.c:75
msgid "Trace elevation"
@@ -33317,9 +31185,7 @@
#: ../vector/v.what/main.c:70
#, fuzzy
msgid "If not given reads from standard input"
-msgstr ""
-"Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
-"prendreles paramètres saisis en ligne de commande"
+msgstr "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué prendreles paramètres saisis en ligne de commande"
#: ../vector/v.what/main.c:77
msgid "Query threshold distance"
@@ -33395,9 +31261,7 @@
msgstr "Suppression des centroïdes en doublons..."
#: ../vector/v.generalize/main.c:77
-msgid ""
-"vector, generalization, simplification, smoothing, displacement, network "
-"generalization"
+msgid "vector, generalization, simplification, smoothing, displacement, network generalization"
msgstr ""
#: ../vector/v.generalize/main.c:78
@@ -33406,16 +31270,7 @@
#: ../vector/v.generalize/main.c:95
-msgid ""
-"douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
-"Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
-"reduction;Vertex Reduction Algorithm eliminates points close to each other;"
-"reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;"
-"sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;"
-"McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;"
-"Interpolation by Cubic Hermite Splines;snakes;Snakes method for line "
-"smoothing;network;Network generalization;displacement;Displacement of lines "
-"close to each other;"
+msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
msgstr ""
#: ../vector/v.generalize/main.c:109
@@ -33513,8 +31368,7 @@
#: ../vector/v.generalize/main.c:495
#, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
+msgid "%d boundaries were not modified because modification would damage topology"
msgstr ""
#: ../vector/v.generalize/main.c:498
@@ -33536,9 +31390,7 @@
msgstr ""
#: ../vector/v.vol.rst/main.c:204
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
msgstr ""
#: ../vector/v.vol.rst/main.c:237
@@ -33572,8 +31424,7 @@
#: ../vector/v.vol.rst/main.c:345
msgid "Conversion factor for w-values used for interpolation"
-msgstr ""
-"Facteur de conversion pour les valeurs w utilisées dans l'interpolation"
+msgstr "Facteur de conversion pour les valeurs w utilisées dans l'interpolation"
#: ../vector/v.vol.rst/main.c:353
msgid "Conversion factor for z-values"
@@ -33613,8 +31464,7 @@
#: ../vector/v.vol.rst/main.c:430
msgid "Perform a cross-validation procedure without volume interpolation"
-msgstr ""
-"Effectue une procédure de validation croisée sans interpolation de volume"
+msgstr "Effectue une procédure de validation croisée sans interpolation de volume"
#: ../vector/v.vol.rst/main.c:467
msgid "Smoothing must be a positive value"
@@ -33622,8 +31472,7 @@
#: ../vector/v.vol.rst/main.c:473
msgid "Both crossvalidation options (-c, cvdev) must be specified"
-msgstr ""
-"Vous devez spécifier les deux options de validation croisée (-c, cvdev)"
+msgstr "Vous devez spécifier les deux options de validation croisée (-c, cvdev)"
#: ../vector/v.vol.rst/main.c:475
msgid "Both crossvalidation and deviations file specified"
@@ -33650,8 +31499,7 @@
# c-format
#: ../vector/v.vol.rst/user1.c:126
#, fuzzy
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
msgstr "Type de colonne (%s) non géré"
#: ../vector/v.to.rast3/main.c:45
@@ -33659,12 +31507,8 @@
msgstr ""
#: ../vector/v.to.rast3/main.c:46
-msgid ""
-"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
-"raster map layer."
-msgstr ""
-"Convertit une couche vecteur GRASS binaire (points seulement) en couche "
-"raster 3D GRASS"
+msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
+msgstr "Convertit une couche vecteur GRASS binaire (points seulement) en couche raster 3D GRASS"
#: ../vector/v.to.rast3/main.c:59
msgid "Column name (type must be numeric)"
@@ -33725,8 +31569,7 @@
#: ../vector/v.label.sa/labels.c:229
#, c-format
-msgid ""
-"Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
+msgid "Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
msgstr ""
# c-format
@@ -33753,17 +31596,13 @@
msgstr "Taille de la bordure (seulement pour la sortie ps.map)"
#: ../vector/v.label.sa/main.c:207
-msgid ""
-"Numeric column to give precedence in case of overlapping labels. The label "
-"with a smaller weight is hidden."
+msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
msgstr ""
#: ../vector/v.label.sa/font.c:55
#, fuzzy, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s : impossible de lire le fichier de définition FreeType; on utilise les "
-"paramètres par défaut"
+msgstr "%s : impossible de lire le fichier de définition FreeType; on utilise les paramètres par défaut"
#: ../vector/v.label.sa/font.c:61
#, fuzzy, c-format
@@ -33777,11 +31616,8 @@
#: ../vector/v.in.db/main.c:55
#, fuzzy
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"Créer de nouveaux objets vecteurs (points) à partir de la table de la base "
-"de données contenant les coordonnées."
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr "Créer de nouveaux objets vecteurs (points) à partir de la table de la base de données contenant les coordonnées."
#: ../vector/v.in.db/main.c:59
msgid "Input table name"
@@ -33818,14 +31654,11 @@
#: ../vector/v.in.db/main.c:98
#, fuzzy
msgid "Use imported table as attribute table for new map"
-msgstr ""
-"Nom de la couche de points vecteurs en entrée pour laquelle éditer la table "
-"attributaire"
+msgstr "Nom de la couche de points vecteurs en entrée pour laquelle éditer la table attributaire"
#: ../vector/v.in.db/main.c:137
#, fuzzy, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
msgstr "La table vectorielle cible <'%s'> existe déjà."
#: ../vector/v.in.db/main.c:180
@@ -33848,19 +31681,13 @@
msgstr "%d points écrits dans la couche vecteur"
#: ../vector/v.surf.idw/main.c:86
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
-"Interpolation de surface à partir de données vecteur point par pondération "
-"de la distance inverse au carré (IDSW)."
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Interpolation de surface à partir de données vecteur point par pondération de la distance inverse au carré (IDSW)."
#: ../vector/v.surf.idw/main.c:95
#, fuzzy
msgid "If set to 0, z coordinates are used (3D vector only)"
-msgstr ""
-"seulement)"
#: ../vector/v.surf.idw/main.c:98 ../vector/v.surf.idw/main.c:106
#, fuzzy
@@ -33870,17 +31697,14 @@
#: ../vector/v.surf.idw/main.c:104
#, fuzzy
msgid "Attribute table column with values to interpolate"
-msgstr ""
-"couche>0)"
#: ../vector/v.surf.idw/main.c:105
msgid "Required if layer > 0"
msgstr ""
#: ../vector/v.surf.idw/main.c:122
-msgid ""
-"Power parameter; greater values assign greater influence to closer points"
+msgid "Power parameter; greater values assign greater influence to closer points"
msgstr ""
#: ../vector/v.surf.idw/main.c:127
@@ -33890,12 +31714,8 @@
#: ../vector/v.surf.idw/main.c:128
#, fuzzy
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
-msgstr ""
-"Ne pas indexer les points par cellule raster (plus lent, mais utilise moins "
-"de mémoireet inclue les points extérieurs à la région dans l'interpolation)"
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
+msgstr "Ne pas indexer les points par cellule raster (plus lent, mais utilise moins de mémoireet inclue les points extérieurs à la région dans l'interpolation)"
#: ../vector/v.surf.idw/main.c:147
msgid "No attribute column specified"
@@ -33942,9 +31762,7 @@
#: ../vector/v.hull/main.c:286
#, fuzzy
msgid "Use all vector points (do not limit to current region)"
-msgstr ""
-"La couche vectorielle de départ %s ne contient aucun point dans la région "
-"courante"
+msgstr "La couche vectorielle de départ %s ne contient aucun point dans la région courante"
#: ../vector/v.hull/main.c:291
msgid "Create a 'flat' 2D hull even if the input is 3D points"
@@ -33990,9 +31808,7 @@
#: ../vector/v.out.dxf/write_dxf.c:23
#, fuzzy, c-format
msgid "The file '%s' already exists and will be overwritten."
-msgstr ""
-"écrasé!\n"
#: ../vector/v.out.dxf/write_dxf.c:27
#, fuzzy, c-format
@@ -34007,9 +31823,7 @@
#: ../vector/v.drape/main.c:168
#, fuzzy
msgid "Converts vector map to 3D by sampling of elevation raster map."
-msgstr ""
-"Convertit une couche vecteur 2D en couche vecteur 3D en rééchantillonnant le "
-"raster d'altitude.Par défaut, en rééchantillonnant au plus proche voisin"
+msgstr "Convertit une couche vecteur 2D en couche vecteur 3D en rééchantillonnant le raster d'altitude.Par défaut, en rééchantillonnant au plus proche voisin"
#: ../vector/v.drape/main.c:180
#, fuzzy
@@ -34050,8 +31864,7 @@
msgstr ""
#: ../vector/v.drape/main.c:425
-msgid ""
-"No features drapped. Check Your computational region and input raster map."
+msgid "No features drapped. Check Your computational region and input raster map."
msgstr ""
# c-format
@@ -34099,11 +31912,8 @@
#: ../vector/v.net.path/main.c:65
#, fuzzy
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
-msgstr ""
-"Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les "
-"prendre à partirde la ligne de commande"
+msgid "Name of file containing start and end points. If not given, read from stdin"
+msgstr "Nom du fichier contenant les commandes graphiques, s'il n'y en a pas, les prendre à partirde la ligne de commande"
#: ../vector/v.net.path/main.c:92
#, fuzzy
@@ -34111,10 +31921,7 @@
msgstr "Distance maximale du point au réseau"
#: ../vector/v.net.path/main.c:93
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
msgstr ""
#: ../vector/v.net.path/main.c:106
@@ -34203,9 +32010,7 @@
#: ../vector/v.to.rast/support.c:173
#, fuzzy, c-format
msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
-msgstr ""
-"Erreur dans la colonne de définition de couleur (%s), entité surfacique %d "
-"avec la catégorie %d: code couleur [%s]"
+msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d: code couleur [%s]"
#: ../vector/v.to.rast/support.c:176
msgid "Color set to [200:200:200]"
@@ -34214,9 +32019,7 @@
#: ../vector/v.to.rast/support.c:181
#, fuzzy, c-format
msgid "Error in color definition column (%s), with cat %d"
-msgstr ""
-"avec la catégorie %d"
+msgstr "Erreur dans la colonne de définition de couleur (%s), entité surfacique %d avec la catégorie %d"
#: ../vector/v.to.rast/support.c:273
msgid "Label column was not specified, no labels will be written"
@@ -34329,10 +32132,7 @@
#: ../vector/v.to.rast/main.c:62
#, fuzzy
-msgid ""
-"attr;read values from attribute table;cat;use category values;val;use value "
-"specified by value option;z;use z coordinate (points or contours only);dir;"
-"output as flow direction (lines only)"
+msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
msgstr ""
"Valeurs raster en entrée :\n"
"\t\tattr - valeur de la table attributaire en lecture\n"
@@ -34349,9 +32149,7 @@
#: ../vector/v.to.rast/main.c:77
#, fuzzy
msgid "Name of color definition column (with RRR:GGG:BBB entries)"
-msgstr ""
-"Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -"
-"a)"
+msgstr "Nom de la colonne de définition de couleur (pour l'utilisation d'un drapeau -a)"
#: ../vector/v.to.rast/main.c:83
#, fuzzy
@@ -34369,9 +32167,7 @@
#: ../vector/v.to.rast/main.c:118
msgid "Column parameter cannot be combined with use of category values option"
-msgstr ""
-"Le paramètre de colonne ne peut pas être combiner avec l'option de valeurs "
-"de catégories"
+msgstr "Le paramètre de colonne ne peut pas être combiner avec l'option de valeurs de catégories"
#: ../vector/v.to.rast/main.c:123
msgid "Column parameter cannot be combined with use of value option"
@@ -34379,9 +32175,7 @@
#: ../vector/v.to.rast/main.c:128
msgid "Column parameter cannot be combined with use of z coordinate"
-msgstr ""
-"Le paramètre de colonne ne peut être combiné avec l'utilisation de "
-"coordonnées z"
+msgstr "Le paramètre de colonne ne peut être combiné avec l'utilisation de coordonnées z"
#: ../vector/v.to.rast/main.c:134
#, fuzzy, c-format
@@ -34421,8 +32215,7 @@
msgstr "%d points sans catégorie"
#: ../vector/v.out.vtk/writeVTK.c:188
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
msgstr ""
#: ../vector/v.out.vtk/writeVTK.c:623
@@ -34521,12 +32314,8 @@
#: ../db/drivers/ogr/describe.c:157
#, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-"colonne '%s', de type 'string': largeur inconnue -> enregistrée comme "
-"varchar(250) des données peuvent être tronquées"
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
+msgstr "colonne '%s', de type 'string': largeur inconnue -> enregistrée comme varchar(250) des données peuvent être tronquées"
#: ../db/drivers/mysql/cursor.c:46
msgid "Cannot allocate cursor."
@@ -34598,15 +32387,11 @@
#: ../db/drivers/mysql/parse.c:71 ../db/drivers/postgres/parse.c:55
msgid "'user' in database definition is not supported, use db.login"
-msgstr ""
-"'utilisateur'('user') n'est pas géré dans la définition des bases de "
-"données, utiliser db.login"
+msgstr "'utilisateur'('user') n'est pas géré dans la définition des bases de données, utiliser db.login"
#: ../db/drivers/mysql/parse.c:75 ../db/drivers/postgres/parse.c:59
msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
-"'mot de passe'('password') n'est pas géré dans la définition des bases de "
+msgstr "'mot de passe'('password') n'est pas géré dans la définition des bases de données, utiliser db.login"
#: ../db/drivers/mysql/parse.c:79
msgid "Unknown option in database definition for "
@@ -34619,12 +32404,8 @@
#: ../db/drivers/mysql/describe.c:126
#, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
-"colonne '%s' : type BIGINT (entier large) enregistré comme entier (4 octets) "
-"des données peuvent avoir été endommagées"
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgstr "colonne '%s' : type BIGINT (entier large) enregistré comme entier (4 octets) des données peuvent avoir été endommagées"
#: ../db/drivers/mysql/select.c:43
msgid "Cannot select data: \n"
@@ -34650,30 +32431,18 @@
#: ../db/drivers/postgres/describe.c:116
#, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
-msgstr ""
-"colonne '%s' : type int8 (entier large) enregistré comme entier (4 octets) "
+msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
+msgstr "colonne '%s' : type int8 (entier large) enregistré comme entier (4 octets) des données peuvent avoir été endommagées"
#: ../db/drivers/postgres/describe.c:120
#, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
-"colonne '%s' : type character varying enregistré comme varchar(250) des "
-"données peuvent être tronquées"
+msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
+msgstr "colonne '%s' : type character varying enregistré comme varchar(250) des données peuvent être tronquées"
#: ../db/drivers/postgres/describe.c:126
#, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
-"colonne '%s' : type bool (booléen) enregistré comme char(1) avec '0' (faux) "
-"ou '1' (vrai)"
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
+msgstr "colonne '%s' : type bool (booléen) enregistré comme char(1) avec '0' (faux) ou '1' (vrai)"
# c-format
#: ../db/drivers/sqlite/db.c:85
@@ -34747,8 +32516,7 @@
#: ../db/base/connect.c:47
#, fuzzy
msgid "Prints/sets general DB connection for current mapset and exits."
-msgstr ""
-"Affiche/configure la connexion à la base de données du jeu de données courant"
+msgstr "Affiche/configure la connexion à la base de données du jeu de données courant"
#: ../db/base/connect.c:51
#, fuzzy
@@ -34767,18 +32535,13 @@
#: ../db/base/connect.c:75
#, fuzzy
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
-msgstr ""
-"Schéma de la base de données. Ne pas utiliser cette option si le pilote ou "
-"le serveur ne gèrent pas les schémas de BD."
+msgid "Do not use this option if schemas are not supported by driver/database server"
+msgstr "Schéma de la base de données. Ne pas utiliser cette option si le pilote ou le serveur ne gèrent pas les schémas de BD."
#: ../db/base/connect.c:85
#, fuzzy
msgid "Default group of database users to which select privilege is granted"
-msgstr ""
-"Groupe d'utilisateurs par défaut de la base de données qui ont le privilège "
-"SELECT."
+msgstr "Groupe d'utilisateurs par défaut de la base de données qui ont le privilège SELECT."
#: ../db/base/connect.c:121
#, fuzzy
@@ -34860,9 +32623,7 @@
#: ../db/base/execute.c:119
#, fuzzy
msgid "If not given or '-' read from standard input"
-msgstr ""
#: ../db/base/execute.c:134
msgid "Ignore SQL errors and continue"
@@ -34871,8 +32632,7 @@
#: ../db/base/describe.c:109
#, fuzzy
msgid "Print column names only instead of full column descriptions"
-msgstr ""
-"afficher uniquement le nom des colonnes, au lieu de la description complète"
+msgstr "afficher uniquement le nom des colonnes, au lieu de la description complète"
#: ../db/base/describe.c:114
#, fuzzy
@@ -34891,13 +32651,8 @@
#: ../db/base/copy.c:40
#, fuzzy
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-"Copier une table. Vous pouvez soit utiliser 'from_table' (avec une clause "
-"'where' optionnelle)ou l'option 'select', mais pas simultanément "
-"'from_table' et 'select'."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr "Copier une table. Vous pouvez soit utiliser 'from_table' (avec une clause 'where' optionnelle)ou l'option 'select', mais pas simultanément 'from_table' et 'select'."
#: ../db/base/copy.c:46
msgid "Input driver name"
@@ -34927,8 +32682,7 @@
#, fuzzy
msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
msgstr ""
-"Clause \"select\" complète (seulement si from_table et where n'ont pas été "
-"utilisés), ex:\n"
+"Clause \"select\" complète (seulement si from_table et where n'ont pas été utilisés), ex:\n"
"\t\tSELECT dedek FROM starobince WHERE obec = 'Frimburg'"
#: ../db/base/copy.c:88
@@ -34965,9 +32719,7 @@
#: ../db/base/databases.c:92
msgid "List all databases for a given driver and location."
-msgstr ""
-"Lister toutes les bases de données pour un pilote et un Secteur (location) "
-"donnés."
+msgstr "Lister toutes les bases de données pour un pilote et un Secteur (location) donnés."
#: ../db/base/select.c:101
#, fuzzy, c-format
@@ -34986,9 +32738,7 @@
#: ../db/base/select.c:207
#, fuzzy
msgid "For example: 'select * from rybniky where kapri = 'hodne'"
-msgstr ""
-"Clause SQL 'select', par exemple: 'select * from rybniky where kapri = "
-"'hodne''"
+msgstr "Clause SQL 'select', par exemple: 'select * from rybniky where kapri = 'hodne''"
#: ../db/base/select.c:212
#, fuzzy
@@ -35015,8 +32765,7 @@
#: ../db/db.login/main.c:44
msgid "Sets user/password for driver/database."
-msgstr ""
-"Définir utilisateurs/mot de passe pour le pilote de la base de données."
+msgstr "Définir utilisateurs/mot de passe pour le pilote de la base de données."
#: ../db/db.login/main.c:60
#, fuzzy
@@ -35077,12 +32826,8 @@
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
#, fuzzy
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-"Importer les fichiers pays US-NGA GEOnet Names Server (GNS) dans une couche "
-"de points vectoriels GRASS"
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
+msgstr "Importer les fichiers pays US-NGA GEOnet Names Server (GNS) dans une couche de points vectoriels GRASS"
#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
@@ -35132,12 +32877,8 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
#, fuzzy
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygons "
-"and uploads statistics to new attribute columns."
-msgstr ""
-"Calcule des statistiques univariées à partir d'une couche raster GRASS basée "
-"sur des objets vecteurs"
+msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
+msgstr "Calcule des statistiques univariées à partir d'une couche raster GRASS basée sur des objets vecteurs"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
#, fuzzy
@@ -35155,9 +32896,7 @@
msgstr "Nom de la couche vecteur"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use"
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use"
msgstr ""
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
@@ -35172,9 +32911,7 @@
#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:1
msgid "Export display monitor to a GpsDrive compatible backdrop image"
-msgstr ""
-"Exporter le moniteur d'affichage vers une image compatible avec un récepteur "
-"GPS"
+msgstr "Exporter le moniteur d'affichage vers une image compatible avec un récepteur GPS"
#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:2
#, fuzzy
@@ -35193,9 +32930,7 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:1
#, fuzzy
msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"Mèle les composantes de couleurs de deux couches rasters en fonction d'un "
-"ratio donné"
+msgstr "Mèle les composantes de couleurs de deux couches rasters en fonction d'un ratio donné"
#: ../locale/scriptstrings/r.blend_to_translate.c:3
msgid "Name of first raster map for blending"
@@ -35209,8 +32944,7 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:5
#, fuzzy
msgid "Base name for red, green and blue output maps containing the blend"
-msgstr ""
-"Nom de base pour les couches de sortie rouge, vert, bleu contenant le mélange"
+msgstr "Nom de base pour les couches de sortie rouge, vert, bleu contenant le mélange"
#: ../locale/scriptstrings/r.blend_to_translate.c:6
msgid "Percentage weight of first map for color blending"
@@ -35252,9 +32986,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
#, fuzzy
msgid "Name of attribute column to use for thematic display (must be numeric)"
-msgstr ""
-"Colonne attributaire à utiliser pour l'affichage thématique (doit être "
-"numérique)"
+msgstr "Colonne attributaire à utiliser pour l'affichage thématique (doit être numérique)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
msgid "Type of thematic display"
@@ -35267,16 +32999,12 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:14
#, fuzzy
msgid "Break points for custom breaks option"
-msgstr ""
-"Points de rupture pour l'option de rupture personnalisée. Valeurs séparées "
-"par des espaces (0 10 20 30 ...)"
+msgstr "Points de rupture pour l'option de rupture personnalisée. Valeurs séparées par des espaces (0 10 20 30 ...)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:15
#, fuzzy
msgid "Separate values by spaces (0 10 20 30 ...)"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
msgid "Vector point icon for point data"
@@ -35290,13 +33018,11 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
#, fuzzy
msgid "Minimum icon size/line width for graduated points/lines)"
-msgstr ""
-"Taille maximale de l'icone/largeur de ligne pour les points gradués/lignes)"
+msgstr "Taille maximale de l'icone/largeur de ligne pour les points gradués/lignes)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:24
msgid "Maximum icon size/line width for graduated points and lines"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
msgid "Number of classes for interval theme (integer)"
@@ -35310,9 +33036,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:29
#, fuzzy
msgid "Select 'single_color' for graduated point/line display"
-msgstr ""
-"Schéma de couleur pour la cartographie en couleurs graduelles (choisissez "
-"'couleur simple' pour l'affichage point gradué/ligne)"
+msgstr "Schéma de couleur pour la cartographie en couleurs graduelles (choisissez 'couleur simple' pour l'affichage point gradué/ligne)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
#, fuzzy
@@ -35322,10 +33046,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:32
#, fuzzy
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
-msgstr ""
-"Couleur pour les lignes graduées ou les contours de points/entités "
-"surfaciques (nom de couleur GRASS ou triplet R:G:B). Fixer le schéma de "
-"couleur pour couleur simple."
+msgstr "Couleur pour les lignes graduées ou les contours de points/entités surfaciques (nom de couleur GRASS ou triplet R:G:B). Fixer le schéma de couleur pour couleur simple."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
#, fuzzy
@@ -35335,32 +33056,23 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:35
#, fuzzy
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
#, fuzzy
msgid "Beginning color for custom color gradient"
-msgstr ""
-"Couleur de départ pour le gardient de couleur personnalisé. Doit être "
-"exprimé sous forme de triplet R:G:B."
+msgstr "Couleur de départ pour le gardient de couleur personnalisé. Doit être exprimé sous forme de triplet R:G:B."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
#, fuzzy
msgid "Must be expressed as R:G:B triplet"
-msgstr ""
-"Couleur de fin pour le gradient de couleur personnalisé. Doit être exprimé "
-"sous forme de triplet R:G:B."
+msgstr "Couleur de fin pour le gradient de couleur personnalisé. Doit être exprimé sous forme de triplet R:G:B."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
#, fuzzy
msgid "Ending color for custom color gradient"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:59
@@ -35376,9 +33088,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
msgid "Save thematic map commands to group file for GIS Manager"
-msgstr ""
-"Sauvegarder les commandes de cartographie thématique dans le fichier de "
-"groupe dans le Gestionnaire SIG"
+msgstr "Sauvegarder les commandes de cartographie thématique dans le fichier de groupe dans le Gestionnaire SIG"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
@@ -35390,22 +33100,16 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:49
#, fuzzy
msgid "Root for the name of psmap instruction files to be in current directory"
-msgstr ""
-"Racine du nom du fichier d'instruction psmat dans le répertoire courant (si "
-"non indiqué, aucun fichier d'instruction psmap ne sera créé)"
+msgstr "Racine du nom du fichier d'instruction psmat dans le répertoire courant (si non indiqué, aucun fichier d'instruction psmap ne sera créé)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
#, fuzzy
msgid "If not set, no psmap instruction files will be created)"
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
msgid "Name of group file where thematic map commands will be saved"
-msgstr ""
-"Nom du fichier de groupe où les commandes de cartographie thématique seront "
-"sauvegardées"
+msgstr "Nom du fichier de groupe où les commandes de cartographie thématique seront sauvegardées"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:54
#, fuzzy
@@ -35414,15 +33118,11 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:56
msgid "Only draw fills (no outlines) for areas and points"
-msgstr ""
-"Ne dessiner que le remplissage (sans contours) pour les entités surfaciques "
-"et les points"
+msgstr "Ne dessiner que le remplissage (sans contours) pour les entités surfaciques et les points"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:58
msgid "Update color values to GRASSRGB column in attribute table"
-msgstr ""
-"Mettre à jour les valeurs de couleurs de la colonne GRASSRGB dans la table "
-"attributaire"
+msgstr "Mettre à jour les valeurs de couleurs de la colonne GRASSRGB dans la table attributaire"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:60
msgid "Output legend for GIS Manager (for scripting use only)"
@@ -35440,9 +33140,7 @@
#: ../locale/scriptstrings/db.dropcol_to_translate.c:4
#, fuzzy
msgid "Table from which to drop attribute column"
-msgstr ""
-"attributaire"
#: ../locale/scriptstrings/db.dropcol_to_translate.c:5
#, fuzzy
@@ -35451,8 +33149,7 @@
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-"Crée une couche de relief estompé à partir d'une couche d'altitude (MNT)."
+msgstr "Crée une couche de relief estompé à partir d'une couche d'altitude (MNT)."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
#: ../locale/scriptstrings/r.plane_to_translate.c:2
@@ -35483,15 +33180,12 @@
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
msgid "Scale factor for converting horizontal units to elevation units"
-msgstr ""
-"Facteur d'échelle pour convertir les unités horizontales en unités d'altitude"
+msgstr "Facteur d'échelle pour convertir les unités horizontales en unités d'altitude"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
#, fuzzy
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
-msgstr ""
-"Fixer le facteur d'échelle (s'applique au Secteur en lat./long. seulement)"
+msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+msgstr "Fixer le facteur d'échelle (s'applique au Secteur en lat./long. seulement)"
#: ../locale/scriptstrings/d.redraw_to_translate.c:1
#, fuzzy
@@ -35534,12 +33228,8 @@
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
#, fuzzy
-msgid ""
-"The database must be in form printed by v.db.connect -g, i.e. with "
-"substituted variables"
-msgstr ""
-"Nom de l'ancienne base de données, la base de données doit être sous à la "
-"forme affichée par v.db.connect -c'est-à-dire en substituant les variables"
+msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
+msgstr "Nom de l'ancienne base de données, la base de données doit être sous à la forme affichée par v.db.connect -c'est-à-dire en substituant les variables"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
msgid "Name of new database"
@@ -35555,9 +33245,7 @@
#: ../locale/scriptstrings/d.out.png_to_translate.c:1
msgid "Saves active display monitor to PNG file in home directory"
-msgstr ""
-"Sauvegarder l'affichage du moniteur actif en fichier PNG dans le répertoire "
-"home"
+msgstr "Sauvegarder l'affichage du moniteur actif en fichier PNG dans le répertoire home"
#: ../locale/scriptstrings/d.out.png_to_translate.c:2
#: ../locale/scriptstrings/d.out.file_to_translate.c:2
@@ -35611,9 +33299,7 @@
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
#, fuzzy
msgid "Also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-"importer aussi la couche de qualité (couche du statut SM) et couche filtre "
-"NDVI"
+msgstr "importer aussi la couche de qualité (couche du statut SM) et couche filtre NDVI"
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
@@ -35621,9 +33307,7 @@
#: ../locale/scriptstrings/d.polar_to_translate.c:1
msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-"Trace un diagramme polaire angulaire pour l'aspect (exposition) ou les "
-"directions du courant"
+msgstr "Trace un diagramme polaire angulaire pour l'aspect (exposition) ou les directions du courant"
#: ../locale/scriptstrings/d.polar_to_translate.c:2
#, fuzzy
@@ -35650,9 +33334,7 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
#, fuzzy
msgid "Joins a database table to a vector map table."
-msgstr ""
-"nom de la table attributaire existante (par défaut : nom de la couche "
-"vecteur)"
+msgstr "nom de la table attributaire existante (par défaut : nom de la couche vecteur)"
#: ../locale/scriptstrings/v.db.join_to_translate.c:3
#, fuzzy
@@ -35670,9 +33352,7 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:6
#, fuzzy
msgid "Vector map to which to join other table"
-msgstr ""
-"attributaire"
#: ../locale/scriptstrings/v.db.join_to_translate.c:7
#, fuzzy
@@ -35743,11 +33423,8 @@
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:9
#, fuzzy
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed"
-msgstr ""
-"option de création du pilote de format de sortie. De multiples options "
-"peuvent être disponibles"
+msgid "Creation option to the output format driver. Multiple options may be listed"
+msgstr "option de création du pilote de format de sortie. De multiples options peuvent être disponibles"
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:10
#, fuzzy
@@ -35757,12 +33434,8 @@
#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
#, fuzzy
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr ""
-"Calcule des statistiques univariées sur la colonne sélectionnée dans une "
-"table de couche vecteur."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgstr "Calcule des statistiques univariées sur la colonne sélectionnée dans une table de couche vecteur."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:3
@@ -35779,9 +33452,7 @@
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:5
#, fuzzy
msgid "Column on which to calculate statistics (must be numeric)"
-msgstr ""
-"numérique)"
# c-format
#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
@@ -35841,9 +33512,7 @@
#: ../locale/scriptstrings/d.slide.show_to_translate.c:4
#, fuzzy
msgid "Map prefix. Specify character(s) to view selected maps only"
-msgstr ""
-"préfixe de couche. Spécifier les caractère(s) pour voir les couches "
-"sélectionnées seulement"
+msgstr "préfixe de couche. Spécifier les caractère(s) pour voir les couches sélectionnées seulement"
#: ../locale/scriptstrings/d.slide.show_to_translate.c:5
#, fuzzy
@@ -35858,9 +33527,7 @@
#: ../locale/scriptstrings/d.slide.show_to_translate.c:7
#, fuzzy
msgid "Mapsets to use. Specify multiple mapsets comma separated"
-msgstr ""
-"Jeux de données à utiliser. Spécifier de multiples jeux de données en les "
-"séparant par des virgules"
+msgstr "Jeux de données à utiliser. Spécifier de multiples jeux de données en les séparant par des virgules"
#: ../locale/scriptstrings/d.slide.show_to_translate.c:8
#, fuzzy
@@ -35874,9 +33541,7 @@
#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
#, fuzzy
msgid "Create a 3D line from 3 column data"
-msgstr ""
#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
#, fuzzy
@@ -35918,12 +33583,8 @@
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
#, fuzzy
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Reclasser une couche raster plus grande ou plus petite que la taille "
-"spécifiée par l'utilisateur (en hectares)"
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Reclasser une couche raster plus grande ou plus petite que la taille spécifiée par l'utilisateur (en hectares)"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
#, fuzzy
@@ -35933,9 +33594,7 @@
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
#, fuzzy
msgid "Lesser value option that sets the <= area size limit [hectares]"
-msgstr ""
-"option valeur 'plus petite que' <= pour la taille limite de surface "
-"[hectares]"
+msgstr "option valeur 'plus petite que' <= pour la taille limite de surface [hectares]"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
@@ -35946,16 +33605,12 @@
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
#, fuzzy
msgid "Greater value option that sets the >= area size limit [hectares]"
-msgstr ""
-"option valeur 'plus grande que' >= pour la taille limite de surface "
-"[hectares]"
+msgstr "option valeur 'plus grande que' >= pour la taille limite de surface [hectares]"
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:1
#, fuzzy
msgid "Calculate new raster map from a r.mapcalc expression."
-msgstr ""
-"r.mapcalculator - calcule une nouvelle couche raster à partir d'une "
-"expression r.mapcalc"
+msgstr "r.mapcalculator - calcule une nouvelle couche raster à partir d'une expression r.mapcalc"
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:2
#, fuzzy
@@ -36011,9 +33666,7 @@
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
#, fuzzy
msgid "Imports attribute tables in various formats."
-msgstr ""
-"vecteur)"
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
#, fuzzy
@@ -36081,8 +33734,7 @@
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:8
msgid "Preserve relative colors, adjust brightness only"
-msgstr ""
-"Préserver les nuances de couleurs relatives, ajuster seulement la luminosité"
+msgstr "Préserver les nuances de couleurs relatives, ajuster seulement la luminosité"
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
msgid "Reset to standard color range"
@@ -36096,12 +33748,8 @@
#: ../locale/scriptstrings/i.spectral_to_translate.c:1
#, fuzzy
-msgid ""
-"Displays spectral response at user specified locations for an imagery group "
-"or a list of raster maps."
-msgstr ""
-"afficher la réponse spectrale à des emplacements précisés par l'utilisateur "
-"dans un groupe ou dans des images"
+msgid "Displays spectral response at user specified locations for an imagery group or a list of raster maps."
+msgstr "afficher la réponse spectrale à des emplacements précisés par l'utilisateur dans un groupe ou dans des images"
#: ../locale/scriptstrings/i.spectral_to_translate.c:2
msgid "imagery, raster, multispectral"
@@ -36150,18 +33798,13 @@
msgstr "Etiquette avec coordonnées à la place d'un nombre"
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
+msgid "Export a raster map to a text file as x,y,z values based on cell centers."
msgstr ""
#: ../locale/scriptstrings/r.plane_to_translate.c:1
#, fuzzy
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Créer une couche plane raster en fonction de l'angle (inclinaison), de "
-"l'aspect/exposition (azimut), et un point"
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr "Créer une couche plane raster en fonction de l'angle (inclinaison), de l'aspect/exposition (azimut), et un point"
#: ../locale/scriptstrings/r.plane_to_translate.c:3
#, fuzzy
@@ -36210,9 +33853,7 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
#, fuzzy
msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr ""
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
#, fuzzy
@@ -36224,9 +33865,7 @@
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:10
#, fuzzy
msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
-"Nom de la nouvelle couche vecteur (ne rien mettre pour l'affichage sur "
-"stdout)"
+msgstr "Nom de la nouvelle couche vecteur (ne rien mettre pour l'affichage sur stdout)"
#: ../locale/scriptstrings/d.monsize_to_translate.c:1
msgid "Selects/starts specified monitor at specified size"
@@ -36247,9 +33886,7 @@
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
#, fuzzy
msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr ""
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
#, fuzzy
@@ -36258,12 +33895,8 @@
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
#, fuzzy
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-"Charger des Waypoints, Routes et Tracks à partir d'un récepteur GPS Garmin "
-"dans une couche vecteur."
+msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+msgstr "Charger des Waypoints, Routes et Tracks à partir d'un récepteur GPS Garmin dans une couche vecteur."
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
@@ -36303,8 +33936,7 @@
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:8
#, fuzzy
msgid "Do not attempt projection transform from WGS84"
-msgstr ""
-"Ne pas essayer de faire une transformation de projection à partir de WGS84"
+msgstr "Ne pas essayer de faire une transformation de projection à partir de WGS84"
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:12
#, fuzzy
@@ -36313,12 +33945,8 @@
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
#, fuzzy
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
-msgstr ""
-"r.in.aster - georéférencement, recalage, et import d'images Terra-ASTER et "
-"de MNT en utilisant gdalwarp"
+msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
+msgstr "r.in.aster - georéférencement, recalage, et import d'images Terra-ASTER et de MNT en utilisant gdalwarp"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
#, fuzzy
@@ -36327,17 +33955,12 @@
#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
-msgstr ""
-"Type de traitement d'image ASTER (niveau 1A, niveau 1B, ou MNT relatif)"
+msgstr "Type de traitement d'image ASTER (niveau 1A, niveau 1B, ou MNT relatif)"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
#, fuzzy
-msgid ""
-"L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
-"single band"
-msgstr ""
-"canal L1A ou L1B à traduire (1, 2,3n,3b,4-14). Il n'est possible de traduire "
-"qu'un seul canal"
+msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
+msgstr "canal L1A ou L1B à traduire (1, 2,3n,3b,4-14). Il n'est possible de traduire qu'un seul canal"
#: ../locale/scriptstrings/db.droptable_to_translate.c:1
#, fuzzy
@@ -36369,8 +33992,7 @@
#: ../locale/scriptstrings/d.out.file_to_translate.c:1
#, fuzzy
msgid "Saves the contents of the active display monitor to a graphics file."
-msgstr ""
-"Sauvegarder le moniteur actif en fichier graphique dans le répertoire home"
+msgstr "Sauvegarder le moniteur actif en fichier graphique dans le répertoire home"
#: ../locale/scriptstrings/d.out.file_to_translate.c:3
#, fuzzy
@@ -36416,9 +34038,7 @@
#: ../locale/scriptstrings/d.out.file_to_translate.c:14
#, fuzzy
msgid "(10=smallest/worst, 100=largest/best)"
-msgstr ""
-"Taille/qualité pour les fichiers JPEG (10=plus petit/très dégradée, 100=plus "
-"grande/moins dégradée)"
+msgstr "Taille/qualité pour les fichiers JPEG (10=plus petit/très dégradée, 100=plus grande/moins dégradée)"
#: ../locale/scriptstrings/d.out.file_to_translate.c:16
#, fuzzy
@@ -36451,8 +34071,7 @@
msgstr ""
#: ../locale/scriptstrings/d.out.file_to_translate.c:24
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
msgstr ""
#: ../locale/scriptstrings/d.out.file_to_translate.c:26
@@ -36512,19 +34131,13 @@
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
#, fuzzy
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"ajouter une ou plusieurs colonnes à la table attributaire connectée à une "
-"couche vecteur donnée"
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "ajouter une ou plusieurs colonnes à la table attributaire connectée à une couche vecteur donnée"
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
#, fuzzy
msgid "Name of vector map for which to edit attribute table"
-msgstr ""
-"attributaire"
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:4
#, fuzzy
@@ -36534,9 +34147,7 @@
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:11
#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
-msgid ""
-"number determines which table to use."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
msgstr ""
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:6
@@ -36545,26 +34156,18 @@
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:7
#, fuzzy
-msgid ""
-"Data types depend on database backend, but all support VARCHAR(), INT, "
-"DOUBLE PRECISION and DATE"
-msgstr ""
-"nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base de "
-"données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE/REAL et DATE)"
+msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
+msgstr "nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base de données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE/REAL et DATE)"
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
#, fuzzy
msgid "Updates a column in the attribute table connected to a vector map."
-msgstr ""
-"permet d'affecter une nouvelle valeur à la colonne de la table attributaire "
-"connectée à la table"
+msgstr "permet d'affecter une nouvelle valeur à la colonne de la table attributaire connectée à la table"
#: ../locale/scriptstrings/v.db.update_to_translate.c:3
#, fuzzy
msgid "Vector map to edit the attribute table for"
-msgstr ""
-"attributaire"
#: ../locale/scriptstrings/v.db.update_to_translate.c:4
msgid "Layer to which the table to be changed is connected"
@@ -36582,9 +34185,7 @@
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
#, fuzzy
msgid "Varchar values must be in single quotes, e.g. 'grass'"
-msgstr ""
-"nouvelle valeur à affecter à la colonne (les valeurs varchar doivent être "
-"entre simples guillemets, par exemple : 'grass')"
+msgstr "nouvelle valeur à affecter à la colonne (les valeurs varchar doivent être entre simples guillemets, par exemple : 'grass')"
#: ../locale/scriptstrings/v.db.update_to_translate.c:8
#, fuzzy
@@ -36597,17 +34198,13 @@
#: ../locale/scriptstrings/v.db.update_to_translate.c:10
#, fuzzy
-msgid ""
-"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
-"col2>1)"
+msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
msgstr "Conditions WHERE de la requête SQL sans le mot clef 'where'"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
#, fuzzy
msgid "Exports attribute tables into various formats."
-msgstr ""
-"vecteur)"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
#, fuzzy
@@ -36625,8 +34222,7 @@
msgstr "format OGR"
#: ../locale/scriptstrings/v.colors_to_translate.c:1
-msgid ""
-"Set color rules for features in a vector using a numeric attribute column."
+msgid "Set color rules for features in a vector using a numeric attribute column."
msgstr ""
#: ../locale/scriptstrings/v.colors_to_translate.c:2
@@ -36666,8 +34262,7 @@
#: ../locale/scriptstrings/v.colors_to_translate.c:15
#, fuzzy
msgid "Dummy raster map name containing color rules for use with d.legend"
-msgstr ""
-"Couche raster contenant les valeurs utilisées pour la longueur des flèches"
+msgstr "Couche raster contenant les valeurs utilisées pour la longueur des flèches"
#: ../locale/scriptstrings/v.colors_to_translate.c:16
msgid "Use with the -s flag (using this option implies -s)"
@@ -36680,11 +34275,8 @@
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
#, fuzzy
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
-"convertit toutes les anciennes couches vectorielles GRASS (versions "
-"antérieures à 5.7) du jeu de données courant au format récent"
+msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgstr "convertit toutes les anciennes couches vectorielles GRASS (versions antérieures à 5.7) du jeu de données courant au format récent"
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
#, fuzzy
@@ -36699,9 +34291,7 @@
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
#, fuzzy
msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-"Remplir les zones sans données des couches rasters en utilisant "
-"l'interpolation par splines v.surf.rst"
+msgstr "Remplir les zones sans données des couches rasters en utilisant l'interpolation par splines v.surf.rst"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
#, fuzzy
@@ -36716,9 +34306,7 @@
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
#, fuzzy
msgid "Name for output raster map with nulls filled by interpolation"
-msgstr ""
-"Couche raster de sortie où remplacer les nulls par interpolation des valeurs "
-"voisines"
+msgstr "Couche raster de sortie où remplacer les nulls par interpolation des valeurs voisines"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
msgid "Spline tension parameter"
@@ -36775,12 +34363,8 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
#, fuzzy
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"crée et ajoute une nouvelle table attributaire à une couche donnée vecteur "
-"existante"
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "crée et ajoute une nouvelle table attributaire à une couche donnée vecteur existante"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
msgid "Vector map for which to add new attribute table"
@@ -36788,8 +34372,7 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
-"Nom de la nouvelle table attributaire (par défaut: nouvelle couche vecteur)"
+msgstr "Nom de la nouvelle table attributaire (par défaut: nouvelle couche vecteur)"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
msgid "Layer where to add new attribute table"
@@ -36797,27 +34380,18 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
#, fuzzy
-msgid ""
-"Name and type of the new column(s) (types depend on database backend, but "
-"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-msgstr ""
+msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
#, fuzzy
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
+msgid "Renames a column in the attribute table connected to a given vector map."
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
#, fuzzy
msgid "Vector map for which to rename attribute column"
-msgstr ""
-"attributaire"
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:4
#, fuzzy
@@ -36831,9 +34405,7 @@
#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:1
#, fuzzy
msgid "Calculates new grid3D volume from r3.mapcalc expression."
-msgstr ""
#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:2
#, fuzzy
@@ -36891,8 +34463,7 @@
#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
#, fuzzy
msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-"Charge les valeurs vecteurs dans la table aux positions des points vecteurs"
+msgstr "Charge les valeurs vecteurs dans la table aux positions des points vecteurs"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
#, fuzzy
@@ -36930,9 +34501,7 @@
#: ../locale/scriptstrings/db.test_to_translate.c:1
msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Tester le pilote de base de données, la base de données doit exister et "
-"connectée par db.connect"
+msgstr "Tester le pilote de base de données, la base de données doit exister et connectée par db.connect"
#: ../locale/scriptstrings/db.test_to_translate.c:3
msgid "Test name"
@@ -36940,12 +34509,8 @@
#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
#, fuzzy
-msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr ""
+msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
msgid "run non-interactively"
@@ -36985,8 +34550,7 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:1
msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-"Convertit les coordonnées d'une projection à une autre (interface de cs2cs)."
+msgstr "Convertit les coordonnées d'une projection à une autre (interface de cs2cs)."
#: ../locale/scriptstrings/m.proj_to_translate.c:2
#, fuzzy
@@ -37029,22 +34593,16 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:13
msgid "Use LL WGS84 as input and current location as output projection"
-msgstr ""
-"Utiliser LL WGS84 en entrée et le secteur courant comme projection en sortie"
+msgstr "Utiliser LL WGS84 en entrée et le secteur courant comme projection en sortie"
#: ../locale/scriptstrings/m.proj_to_translate.c:15
msgid "Use current location as input and LL WGS84 as output projection"
-msgstr ""
-"Utiliser le secteur courant en entrée et LL WGS84 comme projection en sortie"
+msgstr "Utiliser le secteur courant en entrée et LL WGS84 comme projection en sortie"
#: ../locale/scriptstrings/m.proj_to_translate.c:17
#, fuzzy
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
-msgstr ""
-"Sortie long/lat en degrés décimaux et les autres projections avec beaucoup "
-"de décimales"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
+msgstr "Sortie long/lat en degrés décimaux et les autres projections avec beaucoup de décimales"
#: ../locale/scriptstrings/m.proj_to_translate.c:19
#, fuzzy
@@ -37052,20 +34610,16 @@
msgstr "Numéro de colonne pour les ordonnées dans le fichier en entrée"
#: ../locale/scriptstrings/m.proj_to_translate.c:21
-msgid ""
-"Script style output in CSV format respecting the field separator settings"
+msgid "Script style output in CSV format respecting the field separator settings"
msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:23
msgid "Verbose mode (print projection parameters and filenames to stderr)"
-msgstr ""
-"Mode détaillé (affiche les paramètres de projection et les noms de fichiers "
-"vers stderr)"
+msgstr "Mode détaillé (affiche les paramètres de projection et les noms de fichiers vers stderr)"
#: ../locale/scriptstrings/i.oif_to_translate.c:1
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
-"Calcule la table Facteur-Index-Optimum pour les canaux 1-5, & 7 de LANDSAT TM"
+msgstr "Calcule la table Facteur-Index-Optimum pour les canaux 1-5, & 7 de LANDSAT TM"
#: ../locale/scriptstrings/i.oif_to_translate.c:2
#, fuzzy
@@ -37098,18 +34652,13 @@
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
#, fuzzy
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
+msgid "Drops a column from the attribute table connected to a given vector map."
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
#, fuzzy
msgid "Vector map for which to drop attribute column"
-msgstr ""
-"attributaire"
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
#, fuzzy
@@ -37124,9 +34673,7 @@
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
#, fuzzy
msgid "Removes existing attribute table of a vector map."
-msgstr ""
-"vecteur)"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
msgid "Force removal (required for actual deletion of table)"
@@ -37140,9 +34687,7 @@
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
#, fuzzy
msgid "Name of existing attribute table (default: vector map name)"
-msgstr ""
-"vecteur)"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
msgid "Layer from which to drop linked attribute table"
@@ -37164,12 +34709,8 @@
#, fuzzy
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-"Télécharger des Waypoints, Routes, et Tracks depuis un récepteur GPS ou un "
-"fichier GPS ASCII dans une couche vectorielle."
+msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+msgstr "Télécharger des Waypoints, Routes, et Tracks depuis un récepteur GPS ou un fichier GPS ASCII dans une couche vectorielle."
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:4
#, fuzzy
@@ -37199,20 +34740,15 @@
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:11
#, fuzzy
msgid "Format of GPS input data (use gpsbabel supported formats)"
-msgstr ""
-"Format de données GPS en entrée (utiliser les formats gérés par gpsbabel)"
+msgstr "Format de données GPS en entrée (utiliser les formats gérés par gpsbabel)"
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:12
#, fuzzy
-msgid ""
-"Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-msgstr ""
-"projection des données en entrées (utiliser les options de PROJ.4), si rien "
-"n'est indiqué Lat/Lon WGS84 sera utilisée"
+msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
+msgstr "projection des données en entrées (utiliser les options de PROJ.4), si rien n'est indiqué Lat/Lon WGS84 sera utilisée"
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
msgstr ""
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:2
@@ -37268,8 +34804,7 @@
#: ../locale/scriptstrings/d.correlate_to_translate.c:1
#, fuzzy
msgid "Prints a graph of the correlation between raster maps (in pairs)."
-msgstr ""
-"Affiche un graphe de corrélation entre les couches de données (par paires)"
+msgstr "Affiche un graphe de corrélation entre les couches de données (par paires)"
#: ../locale/scriptstrings/d.correlate_to_translate.c:2
#, fuzzy
@@ -37290,9 +34825,7 @@
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
#, fuzzy
msgid "Mosaics up to four images, extending the color table."
-msgstr ""
-"Faire une mosaïque comprenant jusqu'à 4 images et étendre la table de "
-"couleurs; créer une couche *.mosaic"
+msgstr "Faire une mosaïque comprenant jusqu'à 4 images et étendre la table de couleurs; créer une couche *.mosaic"
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
#, fuzzy
@@ -37327,9 +34860,7 @@
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:1
#, fuzzy
msgid "calculates univariate statistics from a GRASS raster map"
-msgstr ""
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:3
msgid "extended statistics (quartiles and percentile)"
@@ -37341,12 +34872,8 @@
msgstr "Centile à calculer (requiert le drapeau -e)"
#: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Produit des tuiles de la projection source pour l'utilisation dans la région "
-"et la projection cible."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr "Produit des tuiles de la projection source pour l'utilisation dans la région et la projection cible."
#: ../locale/scriptstrings/r.tileset_to_translate.c:2
#, fuzzy
@@ -37362,11 +34889,8 @@
msgstr "Produit une requête vers un serveur cartographique en sortie"
#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
-"Nom de la région à utiliser à la place de la région courante pour l'emprise "
-"et la résolution"
+msgid "Name of region to use instead of current region for bounds and resolution"
+msgstr "Nom de la région à utiliser à la place de la région courante pour l'emprise et la résolution"
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
#, fuzzy
@@ -37426,8 +34950,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
msgid "Skip to downloading (to resume downloads faster)"
-msgstr ""
-"Passer directement au téléchargement (pour finir le téléchargement plus vite)"
+msgstr "Passer directement au téléchargement (pour finir le téléchargement plus vite)"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
@@ -37445,9 +34968,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
#, fuzzy
msgid "Clean existing data out of download directory"
-msgstr ""
-"Nettoyer les données existantes qui se trouvent dans le répertoire de "
-"téléchargement"
+msgstr "Nettoyer les données existantes qui se trouvent dans le répertoire de téléchargement"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
@@ -37508,9 +35029,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
#, fuzzy
msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
-"Région désignée pour laquelle demander les données. La région courante est "
-"utilisée si rien d'autre n'est précisée."
+msgstr "Région désignée pour laquelle demander les données. La région courante est utilisée si rien d'autre n'est précisée."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
msgid "Folder to save downloaded data to"
@@ -37588,12 +35107,8 @@
msgstr "préfixe de couche raster TC en sortie"
#: ../locale/scriptstrings/d.split_to_translate.c:1
-msgid ""
-"Divides active display into two frames & displays maps/executes commands in "
-"each frame."
-msgstr ""
-"Divise l'affichage actif en deux cadres & affiche des couches/exécute des "
-"commandes dans chaque cadre."
+msgid "Divides active display into two frames & displays maps/executes commands in each frame."
+msgstr "Divise l'affichage actif en deux cadres & affiche des couches/exécute des commandes dans chaque cadre."
#: ../locale/scriptstrings/d.split_to_translate.c:3
msgid "Enter raster map to display in 1st frame"
@@ -37632,9 +35147,7 @@
#: ../locale/scriptstrings/v.krige.py_to_translate.c:4
#, fuzzy
msgid "Name of attribute column with numerical value to be interpolated"
-msgstr ""
-"Colonne de la table attributaire avec les valeurs à interpoler (si la "
-"couche>0)"
+msgstr "Colonne de la table attributaire avec les valeurs à interpoler (si la couche>0)"
#: ../locale/scriptstrings/v.krige.py_to_translate.c:6
msgid "If omitted, will be <input name>_kriging"
@@ -37693,11 +35206,8 @@
msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr ""
-"Transformée de Brovey pour fusionner les canaux multispectraux et "
-"panchromatique à haute résolution"
+msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr "Transformée de Brovey pour fusionner les canaux multispectraux et panchromatique à haute résolution"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
#, fuzzy
@@ -37755,9 +35265,7 @@
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads, installs extensions from GRASS Addons SVN repository into local "
-"GRASS installation or removes installed extensions."
+msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:3
@@ -37803,12 +35311,8 @@
#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
#, fuzzy
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Aucune table attributaire trouvée -> on utilise les identifiants de "
-"catégories comme attributs"
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Aucune table attributaire trouvée -> on utilise les identifiants de catégories comme attributs"
#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
#, fuzzy
@@ -37850,10 +35354,34 @@
msgstr "Raster d'altitude pour extraire les valeurs de hauteur"
#, fuzzy
-#~ msgid "Watershed basin analysis program"
-#~ msgstr "Programme d'analyse de bassin versant."
+msgid "Watershed basin analysis program"
+msgstr "Programme d'analyse de bassin versant."
#, fuzzy
+msgid "Solar elevation in degrees"
+msgstr "Fichier raster d'altitude"
+#, fuzzy
+msgid "Allows to join a table to a vector map table."
+#, fuzzy
+msgid "Allows to update a column in the attribute table connected to a vector map."
+#, fuzzy
+msgid "Name of real-sky beam radiation coefficient input raster map [-]"
+msgstr "Couche raster du coefficient de rayonnement en plein ciel [-]"
+#, fuzzy
+msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
+msgstr "Couche raster du coefficient de rayonnement diffus en plein ciel [-]"
+#, fuzzy
+msgid "Name of the Mannings n value"
+msgstr "Nom du fichier raster source"
+#, fuzzy
#~ msgid "Group input"
#~ msgstr "Groupe en entrée"
@@ -37866,10 +35394,6 @@
#~ msgstr "sous-groupe <%s> non trouvé"
#, fuzzy
-#~ msgid "Solar elevation in degrees"
-#~ msgstr "Fichier raster d'altitude"
-#, fuzzy
#~ msgid "Unknown production date (defined by '%s')"
#~ msgstr "Option inconnue dans la définition de base de données pour "
@@ -37888,46 +35412,20 @@
#~ msgstr "Lignes %d étiquettées"
#, fuzzy
-#~ msgid "Allows to join a table to a vector map table."
-#~ msgstr ""
-#~ "nom de la table attributaire existante (par défaut : nom de la couche "
-#~ "vecteur)"
-#, fuzzy
-#~ msgid ""
-#~ "Allows to update a column in the attribute table connected to a vector "
-#~ "map."
-#~ msgstr ""
-#~ "permet d'affecter une nouvelle valeur à la colonne de la table "
-#~ "attributaire connectée à la table"
-#, fuzzy
#~ msgid "Column to query"
#~ msgstr "Couche raster à requèter"
-#, fuzzy
-#~ msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-#~ msgstr "Couche raster du coefficient de rayonnement en plein ciel [-]"
-#, fuzzy
-#~ msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
-#~ msgstr ""
-#~ "Couche raster du coefficient de rayonnement diffus en plein ciel [-]"
#~ msgid "Entering script mode ..."
#~ msgstr "Entrant dans le mode script..."
#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr ""
-#~ "couche d'entrée : altitude sur lesquelles sont basée l'étude entière"
+#~ msgstr "couche d'entrée : altitude sur lesquelles sont basée l'étude entière"
#~ msgid "Input map: locations of real depressions"
#~ msgstr "couche d'entrée : emplacement des dépressions réelles"
#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr ""
-#~ "couche ou valeur d'entrée : pourcentage de terrain impacté par le "
-#~ "glissement, pour USLE"
+#~ msgstr "couche ou valeur d'entrée : pourcentage de terrain impacté par le glissement, pour USLE"
#~ msgid "Output map: drainage direction"
#~ msgstr "Couche de sortie : direction de l'écoulement"
@@ -37936,8 +35434,7 @@
#~ msgstr "Couche de sortie : segments de cours d'eau"
#~ msgid "Input value: maximum length of surface flow, for USLE"
-#~ msgstr ""
-#~ "Valeur d'entrée : longueur maximum d'un écoulement de surface, pour USLE"
+#~ msgstr "Valeur d'entrée : longueur maximum d'un écoulement de surface, pour USLE"
#~ msgid "(i) Elevation map"
#~ msgstr "(i) couche d'altitudes"
@@ -37961,17 +35458,13 @@
#~ msgstr "(i) OPTIONNEL Sortie pour un pas temporel donné"
#~ msgid "(i) OPTIONAL Output for given topographic index class"
-#~ msgstr ""
-#~ "(i)\tOPTIONNEL sortie pour une classe de valeurs topographiques indexées "
-#~ "données"
+#~ msgstr "(i)\tOPTIONNEL sortie pour une classe de valeurs topographiques indexées données"
#~ msgid "Name of existing raster map containing elevation surface"
#~ msgstr "Nom de la couche raster contenant les informations d'altitude"
#~ msgid "Output aspect direction format (agnps, answers, or grass)"
-#~ msgstr ""
-#~ "Format de la direction de la couche d'aspect en sortie (agnps, answers, "
-#~ "ou grass)"
+#~ msgstr "Format de la direction de la couche d'aspect en sortie (agnps, answers, ou grass)"
#, fuzzy
#~ msgid "Reading map..."
@@ -38043,12 +35536,8 @@
#~ msgid "Reading raster map <%s in %s> ..."
#~ msgstr "Lecteur du fichier raster..."
-#~ msgid ""
-#~ "File containing mapping instructions (or use input=- to enter from "
-#~ "keyboard)"
-#~ msgstr ""
-#~ "Fichier contenant les instructions de mise en page cartographique (ou "
-#~ "utilisez input=- pour les saisir à partir du clavier)"
+#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
+#~ msgstr "Fichier contenant les instructions de mise en page cartographique (ou utilisez input=- pour les saisir à partir du clavier)"
#, fuzzy
#~ msgid ""
@@ -38091,13 +35580,10 @@
#~ msgstr "couche d'entrée : quantité de ruissellement par cellule"
#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr ""
-#~ "couche d'entrée : terrain bloquant l'écoulement de surface, pour USLE"
+#~ msgstr "couche d'entrée : terrain bloquant l'écoulement de surface, pour USLE"
#~ msgid "Output map: number of cells that drain through each cell"
-#~ msgstr ""
-#~ "Couche de sortie : nombre de cellules qui s'écoulent dans d'autres "
-#~ "cellules"
+#~ msgstr "Couche de sortie : nombre de cellules qui s'écoulent dans d'autres cellules"
#~ msgid "Output map: unique label for each watershed basin"
#~ msgstr "Couche de sortie : étiquette unique pour chaque bassin versant"
@@ -38109,9 +35595,7 @@
#~ msgstr "Couche de sortie : pratique pour visualiser les résultats"
#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
-#~ msgstr ""
-#~ "Couche de sortie : facteur de longueur de la pente et d'escarpement (LS) "
-#~ "pour USLE"
+#~ msgstr "Couche de sortie : facteur de longueur de la pente et d'escarpement (LS) pour USLE"
#~ msgid "Output map: slope steepness (S) factor for USLE"
#~ msgstr "Couche de sortie : facteur d'escarpement (S) pour USLE "
@@ -38139,8 +35623,7 @@
#~ msgstr "(i) Fichier de paramètres TOPMODEL"
#~ msgid "(i) Rainfall and potential evapotranspiration data file"
-#~ msgstr ""
-#~ "(i) Fichier de données de précipitations et d'évapo-transpiration prévue"
+#~ msgstr "(i) Fichier de données de précipitations et d'évapo-transpiration prévue"
#~ msgid ""
#~ "Convert on the fly, use less disk space\n"
@@ -38164,9 +35647,7 @@
#, fuzzy
#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr ""
-#~ "Produit une couche raster où les aires contiguës ont été agrandies d'une "
-#~ "cellule."
+#~ msgstr "Produit une couche raster où les aires contiguës ont été agrandies d'une cellule."
#~ msgid "Reports statistics for raster map layers."
#~ msgstr "Statistique de couches raster."
@@ -38179,19 +35660,14 @@
#~ msgstr "Coordonnée est"
#~ msgid "Stream width (in meters). Default is raster cell width"
-#~ msgstr ""
-#~ "Largeur du courant (en mètres). Largeur de cellule raster par défaut"
+#~ msgstr "Largeur du courant (en mètres). Largeur de cellule raster par défaut"
#~ msgid "Converts a raster map into a vector map layer."
#~ msgstr "Convertit une couche raster en couche vectorielle"
#, fuzzy
-#~ msgid ""
-#~ "Creates a new map layer whose category values are based upon a "
-#~ "reclassification of the categories in an existing raster map layer."
-#~ msgstr ""
-#~ "Crée une nouvelle couche dont les catégories sont basées sur la "
-#~ "reclassification des catégories d'une couche raster existante."
+#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
+#~ msgstr "Crée une nouvelle couche dont les catégories sont basées sur la reclassification des catégories d'une couche raster existante."
#, fuzzy
#~ msgid "Data range is %.7g to %.7g\n"
@@ -38243,10 +35719,6 @@
#~ msgstr "Nom du nouveau fichier raster"
#, fuzzy
-#~ msgid "Name of the Mannings n value"
-#~ msgstr "Nom du fichier raster source"
-#, fuzzy
#~ msgid "Output transport capacity raster map [kg/ms]"
#~ msgstr "Nom du fichier raster en sortie pour l'aspect"
@@ -38287,8 +35759,7 @@
#~ msgstr "Fichier raster en sortie pour la pente"
#, fuzzy
-#~ msgid ""
-#~ "Name of raster map with given starting point(s) (at least 1 cell > 0)"
+#~ msgid "Name of raster map with given starting point(s) (at least 1 cell > 0)"
#~ msgstr "Couche raster avec le germe (au moins 1 cellule > 0)"
#~ msgid "Output flowline vector map"
@@ -38309,20 +35780,15 @@
#, fuzzy
#~ msgid "The output cell map <%s.%d> has values outside the 0-255 range."
-#~ msgstr ""
-#~ "La couche de sortie <%s.%d> possède des valeurs en dehors de l'intervalle "
-#~ "0-255.\n"
+#~ msgstr "La couche de sortie <%s.%d> possède des valeurs en dehors de l'intervalle 0-255.\n"
#, fuzzy
#~ msgid "Reading raster maps in group <%s> ..."
#, fuzzy
-#~ msgid ""
-#~ "List paper formats ( name width height left right top bottom(margin) )"
-#~ msgstr ""
-#~ "Afficher le format papier (nom largeur hauteur gauche droite haut bas "
-#~ "(marges) )"
+#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
+#~ msgstr "Afficher le format papier (nom largeur hauteur gauche droite haut bas (marges) )"
#~ msgid "PostScript output file"
#~ msgstr "couche PostScript en sortie"
@@ -38331,8 +35797,7 @@
#~ msgstr "Des données existent au-delà de l'instruction finale 'end'!"
#, fuzzy
-#~ msgid ""
-#~ "Name of table created for output when the distance to all flag is used"
+#~ msgid "Name of table created for output when the distance to all flag is used"
#~ msgstr "Nom de la couche raster dont on veut rééchelonner les valeurs"
#, fuzzy
@@ -38344,8 +35809,7 @@
#~ msgstr "couche raster source"
#, fuzzy
-#~ msgid ""
-#~ "Converts GRASS vector map to one of the supported OGR vector formats."
+#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
#~ msgstr "Convertir vers un des formats vecteurs gérés par OGR"
#, fuzzy
@@ -38357,9 +35821,7 @@
#~ msgstr "nom du fichier contenant une commande SQL"
#~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-#~ msgstr ""
-#~ "Faire une mosaïque comprenant jusqu'à 4 images et étendre la table de "
-#~ "couleurs; créer une couche *.mosaic"
+#~ msgstr "Faire une mosaïque comprenant jusqu'à 4 images et étendre la table de couleurs; créer une couche *.mosaic"
#~ msgid "1st map for mosaic (top of image stack)."
#~ msgstr "1ère couche pour la mosaïque (au somment de la pile d'images)"
@@ -38372,3 +35834,30 @@
#~ msgid "4th map for mosaic."
#~ msgstr "4ème couche pour la mosaïque."
+#, fuzzy
+#~ msgid "Name of the Manning's n value"
+#~ msgstr "Nom du fichier raster source"
+#, fuzzy
+#~ msgid "Displays spectral response at user specified locations in group or images."
+#~ msgstr "afficher la réponse spectrale à des emplacements précisés par l'utilisateur dans un groupe ou dans des images"
+#, fuzzy
+#~ msgid "Write output to PNG image"
+#~ msgstr "Écraser et réécrire le fichier de sortie"
+#, fuzzy
+#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
+#~ msgstr "Valeur de catégorie à utiliser comme MASK (format: 1 2 3 jusqu'à 7 *)"
+#, fuzzy
+#~ msgid "Prints a graph of the correlation between data layers (in pairs)."
+#~ msgstr "Affiche un graphe de corrélation entre les couches de données (par paires)"
+#~ msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
+#~ msgstr "Les coordonnées écran pour le coin supérieur gauche de l'étiquette ([0,0] est le coin supérieurgauche du cadre graphique)"
+#, fuzzy
+#~ msgid "Subgroup <%s> not found in current mapset"
+#~ msgstr "couche vecteur <%s> introuvable"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_fr.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_fr.po 2013-10-30 21:32:06 UTC (rev 58125)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_fr.po 2013-10-30 21:41:04 UTC (rev 58126)
@@ -10,7 +10,7 @@
"Project-Id-Version: grasswxpy_fr\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2013-10-30 22:18+0100\n"
-"PO-Revision-Date: 2013-08-12 07:27+0100\n"
+"PO-Revision-Date: 2013-10-25 09:48+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: français <grass-translations at lists.osgeo.org>\n"
"Language: fr\n"
@@ -48,8 +48,7 @@
#: ../gui/wxpython/nviz/tools.py:239
msgid "Adjusts the distance and angular perspective of the image viewpoint"
-msgstr ""
-"Ajuster la distance et l'angle de perspective de l'image au point de vue"
+msgstr "Ajuster la distance et l'angle de perspective de l'image au point de vue"
#: ../gui/wxpython/nviz/tools.py:244 ../gui/wxpython/nviz/preferences.py:68
msgid "Perspective:"
@@ -64,12 +63,8 @@
msgstr "Inclinaison :"
#: ../gui/wxpython/nviz/tools.py:263
-msgid ""
-"Adjusts the viewing height above the surface (angle of view automatically "
-"adjusts to maintain the same center of view)"
-msgstr ""
-"Ajuster la hauteur de vue (l'angle de vue s'ajuste automatiquement pour "
-"garder le même centre de la vue)"
+msgid "Adjusts the viewing height above the surface (angle of view automatically adjusts to maintain the same center of view)"
+msgstr "Ajuster la hauteur de vue (l'angle de vue s'ajuste automatiquement pour garder le même centre de la vue)"
#: ../gui/wxpython/nviz/tools.py:268
msgid "Adjusts the relative height of features above the plane of the surface"
@@ -98,12 +93,8 @@
msgstr "curseur"
#: ../gui/wxpython/nviz/tools.py:301
-msgid ""
-"Allows you to select a point on the surface that becomes the new center of "
-"view. Click on the button and then on the surface."
-msgstr ""
-"Permet de sélectionner un point sur la surface qui deviendra le nouveau "
-"centre de la vue. Cliquer sur le bouton puis sur la surface."
+msgid "Allows you to select a point on the surface that becomes the new center of view. Click on the button and then on the surface."
+msgstr "Permet de sélectionner un point sur la surface qui deviendra le nouveau centre de la vue. Cliquer sur le bouton puis sur la surface."
#: ../gui/wxpython/nviz/tools.py:307
msgid "center"
@@ -118,12 +109,8 @@
msgstr "nord"
#: ../gui/wxpython/nviz/tools.py:317
-msgid ""
-"Sets the viewer directly over the scene's center position. This top view "
-"orients approximately north south."
-msgstr ""
-"Définir la vue directement au dessus du centre de la scène. Cette vue du "
-"haut est orientée approximativement nord-sud."
+msgid "Sets the viewer directly over the scene's center position. This top view orients approximately north south."
+msgstr "Définir la vue directement au dessus du centre de la scène. Cette vue du haut est orientée approximativement nord-sud."
#: ../gui/wxpython/nviz/tools.py:321
msgid "reset"
@@ -143,13 +130,8 @@
msgstr "Couleur d'arrière-plan :"
#: ../gui/wxpython/nviz/tools.py:384
-msgid ""
-"Press 'Record' button and start changing the view. It is recommended to use "
-"fly-through mode (Map Display toolbar) to achieve smooth motion."
-msgstr ""
-"Appuyez sur le bouton 'Enregistrer' et commencez à changer la vue. Il est "
-"recommandé d'utiliser le mode survol (barre d'outils d'affichage) pour "
-"obtenir un déplacement fluide."
+msgid "Press 'Record' button and start changing the view. It is recommended to use fly-through mode (Map Display toolbar) to achieve smooth motion."
+msgstr "Appuyez sur le bouton 'Enregistrer' et commencez à changer la vue. Il est recommandé d'utiliser le mode survol (barre d'outils d'affichage) pour obtenir un déplacement fluide."
#: ../gui/wxpython/nviz/tools.py:395
msgid "Record"
@@ -213,11 +195,8 @@
msgstr "Préfix :"
#: ../gui/wxpython/nviz/tools.py:482
-msgid ""
-"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
-msgstr ""
-"Les noms de fichiers générés ressembleront à ceci : prefix_1.ppm, prefix_2."
-"ppm, ..."
+msgid "Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+msgstr "Les noms de fichiers générés ressembleront à ceci : prefix_1.ppm, prefix_2.ppm, ..."
#: ../gui/wxpython/nviz/tools.py:483
msgid "File format:"
@@ -447,12 +426,8 @@
msgstr "Effectue une rotation sur l'axe horizontal du plan de coupe"
#: ../gui/wxpython/nviz/tools.py:1037
-msgid ""
-"Sets the Z coordinate of the current cutting plane (only meaningful when "
-"tilt is not 0)"
-msgstr ""
-"Définit la coordonnée Z du plan de coupe actuel (n'a de sens que si "
-"l'inclinaison n'est pas à 0)"
+msgid "Sets the Z coordinate of the current cutting plane (only meaningful when tilt is not 0)"
+msgstr "Définit la coordonnée Z du plan de coupe actuel (n'a de sens que si l'inclinaison n'est pas à 0)"
#: ../gui/wxpython/nviz/tools.py:1089 ../gui/wxpython/menustrings.py:4
#: ../gui/wxpython/menustrings.py:858
@@ -664,9 +639,7 @@
#: ../gui/wxpython/nviz/tools.py:1963
msgid "Do you want to record new animation without saving the previous one?"
-msgstr ""
-"Voulez-vous enregistrer une nouvelle animation sans sauvegarder la "
-"précédente ?"
+msgstr "Voulez-vous enregistrer une nouvelle animation sans sauvegarder la précédente ?"
#: ../gui/wxpython/nviz/tools.py:1966
msgid "Animation already axists"
@@ -836,12 +809,8 @@
msgstr "Ajuster la distance et la direction au point de vue"
#: ../gui/wxpython/nviz/tools.py:4902
-msgid ""
-"Adjusts the light direction. Click and drag the puck to change the light "
-"direction."
-msgstr ""
-"Ajuster la direction de la lumière. Cliquez et déplacez le point pour "
-"changer l'origine de la lumière."
+msgid "Adjusts the light direction. Click and drag the puck to change the light direction."
+msgstr "Ajuster la direction de la lumière. Cliquez et déplacez le point pour changer l'origine de la lumière."
#: ../gui/wxpython/nviz/preferences.py:31
msgid "3D view settings"
@@ -849,8 +818,7 @@
#: ../gui/wxpython/nviz/preferences.py:48
msgid "Revert settings to default, changes are not applied"
-msgstr ""
-"Revenir aux réglages par défaut, les changements ne seront pas appliqués"
+msgstr "Revenir aux réglages par défaut, les changements ne seront pas appliqués"
#: ../gui/wxpython/nviz/preferences.py:71
#: ../gui/wxpython/nviz/preferences.py:134
@@ -928,16 +896,8 @@
msgstr "Paramètres de vue 3D enregistrés dans le fichier %s."
#: ../gui/wxpython/nviz/wxnviz.py:32 ../gui/wxpython/wxplot/profile.py:30
-msgid ""
-"This module requires the NumPy module, which could not be imported. It "
-"probably is not installed (it's not part of the standard Python "
-"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
-"information on downloading source or binaries."
-msgstr ""
-"Ce module requiert le module NumPy, qui n'a pas pu êter importé. Il n'est "
-"probablement pas installé (n'est pas compris dans la distribution standard "
-"Python). Voir le site Numeric Python (http://numpy.scipy.org) pour "
-"télécharger les binaires ou le code source."
+msgid "This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries."
+msgstr "Ce module requiert le module NumPy, qui n'a pas pu êter importé. Il n'est probablement pas installé (n'est pas compris dans la distribution standard Python). Voir le site Numeric Python (http://numpy.scipy.org) pour télécharger les binaires ou le code source."
#: ../gui/wxpython/nviz/wxnviz.py:49
#, python-format
@@ -961,23 +921,13 @@
msgstr "carte raster 3d <%s> non trouvée"
#: ../gui/wxpython/nviz/mapwindow.py:207
-#, fuzzy
-msgid ""
-"Opening 3D view was not successful. Please try to change the value of depth "
-"buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
-msgstr ""
-"Le lancement de la vue 3D a échoué. Essayez de modifier la valeur de tampon "
-"d'affichage dans Paramètres > Préférences > onglet Fenêtre de carte > "
-"Paramètres d'affichage avancés"
+msgid "Opening 3D view was not successful. Please try to change the value of depth buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
+msgstr "Le lancement de la vue 3D a échoué. Essayez de modifier la taille du tampon d'affichage dans Paramètres > Préférences > onglet Fenêtre de carte > Paramètres d'affichage avancés puis redémarrer l'interface."
#: ../gui/wxpython/nviz/mapwindow.py:544
#, python-format
-msgid ""
-"Image is too large, your OpenGL implementation supports maximum texture size "
-"%d px."
-msgstr ""
-"L'image est trop grande, votre installation OpenGL supporte une taille de "
-"texture d'un maximum de %d pixels."
+msgid "Image is too large, your OpenGL implementation supports maximum texture size %d px."
+msgstr "L'image est trop grande, votre installation OpenGL supporte une taille de texture d'un maximum de %d pixels."
#: ../gui/wxpython/nviz/mapwindow.py:806
#: ../gui/wxpython/mapdisp/mapwindow.py:1123
@@ -1183,9 +1133,7 @@
#: ../gui/wxpython/lmgr/frame.py:360 ../gui/wxpython/gis_set.py:452
msgid "Do you want to set the default region extents and resolution now?"
-msgstr ""
-"Voulez-vous définir les limites et la résolution la région par défaut "
-"maintenant ?"
+msgstr "Voulez-vous définir les limites et la résolution la région par défaut maintenant ?"
#: ../gui/wxpython/lmgr/frame.py:362 ../gui/wxpython/gis_set.py:454
#, python-format
@@ -1220,9 +1168,7 @@
#: ../gui/wxpython/lmgr/frame.py:619
msgid "Editing is allowed only for vector maps from the current mapset."
-msgstr ""
-"L'édition n'est permise que pour des cartes vectorielles du jeux de cartes "
-"actuel."
+msgstr "L'édition n'est permise que pour des cartes vectorielles du jeux de cartes actuel."
#: ../gui/wxpython/lmgr/frame.py:634
msgid "Choose script file to run"
@@ -1239,12 +1185,8 @@
#: ../gui/wxpython/lmgr/frame.py:654
#, python-format
-msgid ""
-"Script <%s> is not executable. Do you want to set the permissions that "
-"allows you to run this script (note that you must be the owner of the file)?"
-msgstr ""
-"Le script <%s> n'est pas exécutable. Voulez-vous définir les permissions "
-"d'exécution du script (vous devez être l'utilisateur propriétaire) ?"
+msgid "Script <%s> is not executable. Do you want to set the permissions that allows you to run this script (note that you must be the owner of the file)?"
+msgstr "Le script <%s> n'est pas exécutable. Voulez-vous définir les permissions d'exécution du script (vous devez être l'utilisateur propriétaire) ?"
#: ../gui/wxpython/lmgr/frame.py:659
msgid "Set permission?"
@@ -1256,12 +1198,8 @@
#: ../gui/wxpython/lmgr/frame.py:679
#, python-format
-msgid ""
-"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
-"directory to GRASS_ADDON_PATH?"
-msgstr ""
-"Le dossier '%s' n'est pas définit dans GRASS_ADDON_PATH. Voulez-vous ajouter "
-"ce dossier à GRASS_ADDON_PATH ?"
+msgid "Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this directory to GRASS_ADDON_PATH?"
+msgstr "Le dossier '%s' n'est pas définit dans GRASS_ADDON_PATH. Voulez-vous ajouter ce dossier à GRASS_ADDON_PATH ?"
#: ../gui/wxpython/lmgr/frame.py:682
msgid "Update Addons path?"
@@ -1322,12 +1260,8 @@
msgstr "Plateforme"
#: ../gui/wxpython/lmgr/frame.py:864
-msgid ""
-"Current workspace is not empty. Do you want to store current settings to "
-"workspace file?"
-msgstr ""
-"L'espace de travail n'est pas vide. Voulez-vous enregistrer les paramètres "
-"actuels dans un fichier ?"
+msgid "Current workspace is not empty. Do you want to store current settings to workspace file?"
+msgstr "L'espace de travail n'est pas vide. Voulez-vous enregistrer les paramètres actuels dans un fichier ?"
#: ../gui/wxpython/lmgr/frame.py:867
msgid "Create new workspace?"
@@ -1369,9 +1303,7 @@
#: ../gui/wxpython/lmgr/frame.py:1098 ../gui/wxpython/lmgr/frame.py:1114
#, python-format
msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-"Le fichier d'environnement <%s> existe déjà. Voulez-vous écraser ce "
-"fichier ?"
+msgstr "Le fichier d'environnement <%s> existe déjà. Voulez-vous écraser ce fichier ?"
#: ../gui/wxpython/lmgr/frame.py:1100 ../gui/wxpython/lmgr/frame.py:1117
#: ../gui/wxpython/menustrings.py:9
@@ -1394,8 +1326,7 @@
#: ../gui/wxpython/lmgr/frame.py:1195
#, python-format
msgid "GRASS GIS Map Display: %(name)s - Location: %(loc)s"
-msgstr ""
-"SIG GRASS - Moniteur d'affichage des cartes : %(name)s - Secteur : %(loc)s"
+msgstr "SIG GRASS - Moniteur d'affichage des cartes : %(name)s - Secteur : %(loc)s"
#: ../gui/wxpython/lmgr/frame.py:1410
msgid "Nothing to import. No WMS layer selected."
@@ -1415,12 +1346,8 @@
msgstr "Type de couche <%s> non pris en charge"
#: ../gui/wxpython/lmgr/frame.py:1675
-msgid ""
-"Note that cell values can only be displayed for regions of less than 10,000 "
-"cells."
-msgstr ""
-"A noter que les valeurs des cellules ne peuvent être affichées que pour les "
-"régions de moins de 10 000 cellules."
+msgid "Note that cell values can only be displayed for regions of less than 10,000 cells."
+msgstr "A noter que les valeurs des cellules ne peuvent être affichées que pour les régions de moins de 10 000 cellules."
#: ../gui/wxpython/lmgr/frame.py:1757
#, python-format
@@ -1435,9 +1362,7 @@
#: ../gui/wxpython/lmgr/frame.py:1760
msgid "Do you want to remove selected map layer(s) from layer tree?"
-msgstr ""
-"Voulez-vous retirer la(les) carte(s) sélectionnée(s) de l'arborescence des "
-"couches ?"
+msgstr "Voulez-vous retirer la(les) carte(s) sélectionnée(s) de l'arborescence des couches ?"
#: ../gui/wxpython/lmgr/frame.py:1764
msgid "Remove map layer"
@@ -1458,14 +1383,8 @@
msgstr "Message"
#: ../gui/wxpython/lmgr/frame.py:1870
-msgid ""
-"Display resolution is currently not constrained to computational settings. "
-"It's suggested to constrain map to region geometry. Do you want to constrain "
-"the resolution?"
-msgstr ""
-"La résolution de l'affichage n'est actuellement pas restreint aux limite de "
-"la région de calculs. Il est suggéré de restreindre les cartes aux limites "
-"de la région. Voulez-vous restreindre la résolution ?"
+msgid "Display resolution is currently not constrained to computational settings. It's suggested to constrain map to region geometry. Do you want to constrain the resolution?"
+msgstr "La résolution de l'affichage n'est actuellement pas restreint aux limite de la région de calculs. Il est suggéré de restreindre les cartes aux limites de la région. Voulez-vous restreindre la résolution ?"
#: ../gui/wxpython/lmgr/frame.py:1879
msgid "Constrain map to region geometry?"
@@ -1551,8 +1470,7 @@
#: ../gui/wxpython/lmgr/toolbars.py:97
msgid "Remove selected map layer(s) from layer tree"
-msgstr ""
-"Supprimer la(les) carte(s) sélectionnée(s) de l'arborescence des couches"
+msgstr "Supprimer la(les) carte(s) sélectionnée(s) de l'arborescence des couches"
#: ../gui/wxpython/lmgr/toolbars.py:134
msgid "Import/link raster or vector data"
@@ -1707,8 +1625,7 @@
#: ../gui/wxpython/lmgr/layertree.py:161
#, python-format
msgid "GRASS GIS Map Display: %(id)d - Location: %(loc)s"
-msgstr ""
-"SIG GRASS - Moniteur d'affichage des cartes : %(id)d - Secteur : %(loc)s"
+msgstr "SIG GRASS - Moniteur d'affichage des cartes : %(id)d - Secteur : %(loc)s"
#: ../gui/wxpython/lmgr/layertree.py:171
msgid "Map Layers"
@@ -1742,8 +1659,7 @@
#: ../gui/wxpython/lmgr/layertree.py:364
msgid "Set computational region from selected map(s)"
-msgstr ""
-"Définir la région calculée à partir de la(des) carte(s) sélectionnée(s)"
+msgstr "Définir la région calculée à partir de la(des) carte(s) sélectionnée(s)"
#: ../gui/wxpython/lmgr/layertree.py:376 ../gui/wxpython/lmgr/layertree.py:449
msgid "Export"
@@ -1784,9 +1700,7 @@
#: ../gui/wxpython/lmgr/layertree.py:445
msgid "Set computational region from selected map(s) (ignore NULLs)"
-msgstr ""
-"Définir la région de calcul à partir de la(des) carte(s) sélectionnée(s) "
-"(ignore les NULLs)"
+msgstr "Définir la région de calcul à partir de la(des) carte(s) sélectionnée(s) (ignore les NULLs)"
#: ../gui/wxpython/lmgr/layertree.py:457 ../gui/wxpython/menustrings.py:717
msgid "Histogram"
@@ -1828,9 +1742,7 @@
#: ../gui/wxpython/lmgr/layertree.py:591
msgid "Unable to display histogram of raster map. No map name defined."
-msgstr ""
-"Impossible d'afficher l'histogramme de carte raster. Pas de nom de carte "
-"définit."
+msgstr "Impossible d'afficher l'histogramme de carte raster. Pas de nom de carte définit."
#: ../gui/wxpython/lmgr/layertree.py:671
#, python-format
@@ -2010,12 +1922,8 @@
msgstr "Assistant de création de secteur"
#: ../gui/wxpython/gis_set.py:145
-msgid ""
-"Start location wizard. After location is created successfully, GRASS session "
-"is started."
-msgstr ""
-"Lancement de l'assistant. Une fois qu'un secteur est créé, la session GRASS "
-"sera lancée."
+msgid "Start location wizard. After location is created successfully, GRASS session is started."
+msgstr "Lancement de l'assistant. Une fois qu'un secteur est créé, la session GRASS sera lancée."
#: ../gui/wxpython/gis_set.py:149
msgid "Rename mapset"
@@ -2043,9 +1951,7 @@
#: ../gui/wxpython/gis_set.py:216 ../gui/wxpython/gis_set.py:659
msgid "Unable to set GRASS database. Check your locale settings."
-msgstr ""
-"Impossible de déterminer la base de données GRASS. Vérifiez vos paramètres "
-"de langue."
+msgstr "Impossible de déterminer la base de données GRASS. Vérifiez vos paramètres de langue."
#: ../gui/wxpython/gis_set.py:234
#, fuzzy, python-format
@@ -2064,12 +1970,8 @@
#: ../gui/wxpython/gis_set.py:421
-msgid ""
-"Do you want to import <%(name)s> to the newly created location? The "
-"location's default region will be set from this imported map."
-msgstr ""
-"Voulez-vous importer la source de données <%(name)s> pour créer le secteur ? "
-"la région par défaut sera alignée sur la carte importée."
+msgid "Do you want to import <%(name)s> to the newly created location? The location's default region will be set from this imported map."
+msgstr "Voulez-vous importer la source de données <%(name)s> pour créer le secteur ? la région par défaut sera alignée sur la carte importée."
#: ../gui/wxpython/gis_set.py:426
#, fuzzy
@@ -2098,8 +2000,7 @@
"\n"
"This mapset cannot be renamed."
msgstr ""
-"Le jeu de cartes <PERMANENT> est requis pour qu'un secteur GRASS soit "
-"valide.\n"
+"Le jeu de cartes <PERMANENT> est requis pour qu'un secteur GRASS soit valide.\n"
"\n"
"Ce jeu de cartes ne peut être renommé."
@@ -2172,24 +2073,20 @@
"\n"
"This mapset cannot be deleted."
msgstr ""
-"valide.\n"
"\n"
"Ce jeu de cartes ne peut être supprimé."
#: ../gui/wxpython/gis_set.py:609
#, python-format
msgid ""
-"Do you want to continue with deleting mapset <%(mapset)s> from location <"
-"%(location)s>?\n"
+"Do you want to continue with deleting mapset <%(mapset)s> from location <%(location)s>?\n"
"\n"
"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
msgstr ""
-"Voulez-vous vraiment supprimer le jeu de cartes <%(mapset)s> du secteur <"
-"%(location)s>?\n"
+"Voulez-vous vraiment supprimer le jeu de cartes <%(mapset)s> du secteur <%(location)s>?\n"
"\n"
-"TOUTES LES CARTES incluses dans ce jeu de cartes seront DÉFINITIVEMENT "
-"SUPPRIMÉES !"
+"TOUTES LES CARTES incluses dans ce jeu de cartes seront DÉFINITIVEMENT SUPPRIMÉES !"
#: ../gui/wxpython/gis_set.py:614
msgid "Delete selected mapset"
@@ -2240,16 +2137,14 @@
"\n"
"Concurrent use not allowed.\n"
"\n"
-"Do you want to try to remove .gislock (note that you need permission for "
-"this operation) and continue?"
+"Do you want to try to remove .gislock (note that you need permission for this operation) and continue?"
msgstr ""
"GRASS s'exécute déjà dans le jeu de cartes <%(mapset)s> sélectionné\n"
"(fichier %(lock)s détecté).\n"
"\n"
"L'accès concurrent n'est pas autorisé.\n"
"\n"
-"Souhaitez-vous essayer de supprimer .gislock (notez qu'il vous faut disposer "
-"de droits pour cette opération) et continuer ?"
+"Souhaitez-vous essayer de supprimer .gislock (notez qu'il vous faut disposer de droits pour cette opération) et continuer ?"
#: ../gui/wxpython/gis_set.py:849 ../gui/wxpython/gis_set.py:861
msgid "Lock file found"
@@ -2259,13 +2154,11 @@
msgid ""
"ARE YOU REALLY SURE?\n"
"\n"
-"If you really are running another GRASS session doing this could corrupt "
-"your data. Have another look in the processor manager just to be sure..."
+"If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
msgstr ""
"ÊTES-VOUS VRAIMENT SÛR ?\n"
"\n"
-"Si vous avez une autre session GRASS en cours, vous risquez de corrompre vos "
-"données. Vérifiez dans votre gestionnaire de tâches pour en être sûr ..."
+"Si vous avez une autre session GRASS en cours, vous risquez de corrompre vos données. Vérifiez dans votre gestionnaire de tâches pour en être sûr ..."
#: ../gui/wxpython/gis_set.py:872
#, python-format
@@ -2280,13 +2173,8 @@
#: ../gui/wxpython/gis_set.py:922
#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for location or mapset. Please use only "
-"ASCII characters excluding %(chars)s and space."
-msgstr ""
-"le nom <%(name)s> n'ets pas un nom valide pour un secteur ou un jeu de "
-"cartes. Merci de n'utiliser que des caractères ASCII sans %(chars)s ni "
-"espaces."
+msgid "Name <%(name)s> is not a valid name for location or mapset. Please use only ASCII characters excluding %(chars)s and space."
+msgstr "le nom <%(name)s> n'ets pas un nom valide pour un secteur ou un jeu de cartes. Merci de n'utiliser que des caractères ASCII sans %(chars)s ni espaces."
#: ../gui/wxpython/gis_set.py:925
msgid "Invalid name"
@@ -2297,14 +2185,8 @@
msgstr "Démarrage de GRASS pour la première fois"
#: ../gui/wxpython/gis_set.py:990
-msgid ""
-"GRASS needs a directory in which to store its data. Create one now if you "
-"have not already done so. A popular choice is \"grassdata\", located in your "
-"home directory."
-msgstr ""
-"GRASS nécéssite un dossier dans lequel enregistrer ses données. Créez en un "
-"si vous ne l'avez pas déjà fait. Un choix populaire est « grassdata », dans "
-"votre dossier personnel."
+msgid "GRASS needs a directory in which to store its data. Create one now if you have not already done so. A popular choice is \"grassdata\", located in your home directory."
+msgstr "GRASS nécéssite un dossier dans lequel enregistrer ses données. Créez en un si vous ne l'avez pas déjà fait. Un choix populaire est « grassdata », dans votre dossier personnel."
#: ../gui/wxpython/dbmgr/manager.py:145
msgid "Loading data..."
@@ -2312,12 +2194,8 @@
#: ../gui/wxpython/dbmgr/manager.py:152
#, python-format
-msgid ""
-"Attribute table <%s> not found. For creating the table switch to 'Manage "
-"layers' tab."
-msgstr ""
-"Table d'attributs <%s> non trouvée. Pour créer la table passer à l'onglet "
-"'Gérer les couches'."
+msgid "Attribute table <%s> not found. For creating the table switch to 'Manage layers' tab."
+msgstr "Table d'attributs <%s> non trouvée. Pour créer la table passer à l'onglet 'Gérer les couches'."
#: ../gui/wxpython/dbmgr/manager.py:163
#, python-format
@@ -2329,9 +2207,9 @@
msgstr "Ne peut afficher que 256 colonnes."
#: ../gui/wxpython/dbmgr/manager.py:247
-#, fuzzy, python-format
+#, python-format
msgid "Inconsistent number of columns in the table <%(table)s>."
-msgstr "Nombre de colonnes non valide dans la table <%(table)s>."
+msgstr "Nombre de colonnes invalide dans la table <%(table)s>."
#: ../gui/wxpython/dbmgr/manager.py:257
msgid "Viewing limit: 100000 records."
@@ -2351,21 +2229,16 @@
# Conserver le sigle GUI me semble plus clair pour l'utilisateur que sa traduction française (IGU) peu voire pas usitée.
#: ../gui/wxpython/dbmgr/manager.py:304
msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
-msgstr ""
-"Valeur impossible à décoder. Fixer l'encodage dans les préférences du GUI "
-"('Attributs')"
+msgstr "Valeur impossible à décoder. Fixer l'encodage dans les préférences du GUI ('Attributs')"
#: ../gui/wxpython/dbmgr/manager.py:313
#, python-format
msgid ""
-"Error loading attribute data. Record number: %(rec)d. Unable to convert "
-"value '%(val)s' in key column (%(key)s) to integer.\n"
+"Error loading attribute data. Record number: %(rec)d. Unable to convert value '%(val)s' in key column (%(key)s) to integer.\n"
"\n"
"Details: %(detail)s"
msgstr ""
-"Erreur au chargement des données attributaires. Numéro d'enregistrement "
-"%(rec)d. Impossible de convertir la valeur '%(val)s' dans la colonne clé "
-"(%(key)s) en nombre entier.\n"
+"Erreur au chargement des données attributaires. Numéro d'enregistrement %(rec)d. Impossible de convertir la valeur '%(val)s' dans la colonne clé (%(key)s) en nombre entier.\n"
"\n"
"Détails: %(detail)s"
@@ -2423,13 +2296,8 @@
#: ../gui/wxpython/dbmgr/manager.py:602
#, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. You can "
-"define new connection in 'Manage layers' tab."
-msgstr ""
-"La connexion à une base de données n'est pas définie dans le fichier DB pour "
-"la carte vecteur <%s>. Vous pouvez définir une nouvelle connexion dans "
-"l'onglet 'Gérer les couches'."
+msgid "Database connection for vector map <%s> is not defined in DB file. You can define new connection in 'Manage layers' tab."
+msgstr "La connexion à une base de données n'est pas définie dans le fichier DB pour la carte vecteur <%s>. Vous pouvez définir une nouvelle connexion dans l'onglet 'Gérer les couches'."
#: ../gui/wxpython/dbmgr/manager.py:628
msgid "Browse data"
@@ -2453,8 +2321,7 @@
#: ../gui/wxpython/dbmgr/manager.py:691
msgid "Attribute data - right-click to edit/manage records"
-msgstr ""
-"Données attributaires - clic droit pour éditer/gérer les enregistrements"
+msgstr "Données attributaires - clic droit pour éditer/gérer les enregistrements"
#: ../gui/wxpython/dbmgr/manager.py:704 ../gui/wxpython/dbmgr/manager.py:844
#: ../gui/wxpython/dbmgr/manager.py:2321 ../gui/wxpython/dbmgr/manager.py:2451
@@ -2595,12 +2462,8 @@
#: ../gui/wxpython/dbmgr/manager.py:1188
#, python-format
-msgid ""
-"Selected data records (%d) will be permanently deleted from table. Do you "
-"want to delete them?"
-msgstr ""
-"Les enregistrements sélectionnés (%d) vont être définitivement supprimés de "
-"la table. Souhaitez-vous les supprimer ?"
+msgid "Selected data records (%d) will be permanently deleted from table. Do you want to delete them?"
+msgstr "Les enregistrements sélectionnés (%d) vont être définitivement supprimés de la table. Souhaitez-vous les supprimer ?"
#: ../gui/wxpython/dbmgr/manager.py:1191 ../gui/wxpython/dbmgr/manager.py:1237
#: ../gui/wxpython/gmodeler/dialogs.py:864
@@ -2609,18 +2472,13 @@
#: ../gui/wxpython/dbmgr/manager.py:1234
#, python-format
-msgid ""
-"All data records (%d) will be permanently deleted from table. Do you want to "
-"delete them?"
-msgstr ""
-"Tous les enregistrements (%d) seront définitivement supprimés de la table. "
-"Souhaitez-vous les supprimer ?"
+msgid "All data records (%d) will be permanently deleted from table. Do you want to delete them?"
+msgstr "Tous les enregistrements (%d) seront définitivement supprimés de la table. Souhaitez-vous les supprimer ?"
#: ../gui/wxpython/dbmgr/manager.py:1392
#, python-format
msgid "Record with category number %d already exists in the table."
-msgstr ""
-"L'enregistrement portant la catégorie numéro %d existe déjà dans la table."
+msgstr "L'enregistrement portant la catégorie numéro %d existe déjà dans la table."
#: ../gui/wxpython/dbmgr/manager.py:1402
#, python-format
@@ -2660,21 +2518,13 @@
#: ../gui/wxpython/dbmgr/manager.py:1632
#, python-format
-msgid ""
-"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
-"exists in the table <%(table)s>."
-msgstr ""
-"Impossible de renommer la colonne <%(column)s> en <%(columnTo)s>. La "
-"colonne existe déjà dans la table <%(table)s>."
+msgid "Unable to rename column <%(column)s> to <%(columnTo)s>. Column already exists in the table <%(table)s>."
+msgstr "Impossible de renommer la colonne <%(column)s> en <%(columnTo)s>. La colonne existe déjà dans la table <%(table)s>."
#: ../gui/wxpython/dbmgr/manager.py:1648
#, python-format
-msgid ""
-"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
-"%(table)s>."
-msgstr ""
-"Impossible de renommer la colonne. La colonnes<%(column)s> n'existe pas dans "
-"la table <%(table)s>."
+msgid "Unable to rename column. Column <%(column)s> doesn't exist in the table <%(table)s>."
+msgstr "Impossible de renommer la colonne. La colonnes<%(column)s> n'existe pas dans la table <%(table)s>."
#: ../gui/wxpython/dbmgr/manager.py:1675
msgid "Drop selected column"
@@ -2686,12 +2536,8 @@
#: ../gui/wxpython/dbmgr/manager.py:1693
#, python-format
-msgid ""
-"Selected column '%s' will PERMANENTLY removed from table. Do you want to "
-"drop the column?"
-msgstr ""
-"Les colonnes sélectionnées '%s' seront DÉFINITIVEMENT supprimées de la "
-"table. Souhaitez-vous supprimer ces colonnes ?"
+msgid "Selected column '%s' will PERMANENTLY removed from table. Do you want to drop the column?"
+msgstr "Les colonnes sélectionnées '%s' seront DÉFINITIVEMENT supprimées de la table. Souhaitez-vous supprimer ces colonnes ?"
#: ../gui/wxpython/dbmgr/manager.py:1696 ../gui/wxpython/dbmgr/manager.py:1733
msgid "Drop column(s)"
@@ -2706,8 +2552,7 @@
msgstr ""
"Les colonnes sélectionnées\n"
"%s\n"
-"seront DÉFINITIVEMENT supprimées de la table. Souhaitez-vous supprimer ces "
-"colonnes ?"
+"seront DÉFINITIVEMENT supprimées de la table. Souhaitez-vous supprimer ces colonnes ?"
#: ../gui/wxpython/dbmgr/manager.py:1768
msgid "Unable to add column to the table. No column name defined."
@@ -2794,12 +2639,8 @@
msgstr "Clé"
#: ../gui/wxpython/dbmgr/manager.py:2397
-msgid ""
-"Unknown default DB connection. Please define DB connection using db.connect "
-"module."
-msgstr ""
-"Connexion DB par défaut inconnue. Merci de définir une connexion DB en "
-"utilisant le module db.connect."
+msgid "Unknown default DB connection. Please define DB connection using db.connect module."
+msgstr "Connexion DB par défaut inconnue. Merci de définir une connexion DB en utilisant le module db.connect."
#: ../gui/wxpython/dbmgr/manager.py:2416
msgid "Add layer"
@@ -2872,25 +2713,17 @@
#: ../gui/wxpython/dbmgr/manager.py:2895
msgid "Unable to create new table. Table name or key column name is missing."
-msgstr ""
-"Impossible de créer la nouvelle table. Il manque le nom de la table ou de la "
-"colonne clé."
+msgstr "Impossible de créer la nouvelle table. Il manque le nom de la table ou de la colonne clé."
#: ../gui/wxpython/dbmgr/manager.py:2901
#, python-format
msgid "Unable to create new table. Table <%s> already exists in the database."
-msgstr ""
-"Impossible de créer la nouvelle table. La table <%s> existe déjà dans la "
-"base."
+msgstr "Impossible de créer la nouvelle table. La table <%s> existe déjà dans la base."
#: ../gui/wxpython/dbmgr/manager.py:2938
#, python-format
-msgid ""
-"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
-"exists."
-msgstr ""
-"Impossible d'ajouter la nouvelle couche à la carte vecteur <%(vector)s>. La "
-"couche %(layer)d existe déjà."
+msgid "Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already exists."
+msgstr "Impossible d'ajouter la nouvelle couche à la carte vecteur <%(vector)s>. La couche %(layer)d existe déjà."
#: ../gui/wxpython/dbmgr/sqlbuilder.py:68
#, python-format
@@ -2981,13 +2814,11 @@
msgid ""
"No attribute table found.\n"
"\n"
-"Do you want to create a new attribute table and defined a link to vector map "
-"<%s>?"
+"Do you want to create a new attribute table and defined a link to vector map <%s>?"
msgstr ""
"Pas de table attributaire trouvée.\n"
"\n"
-"Voulez-vous créer une nouvelle table attributaire et la lier au vecteur <"
-"%s> ?"
+"Voulez-vous créer une nouvelle table attributaire et la lier au vecteur <%s> ?"
#: ../gui/wxpython/dbmgr/dialogs.py:74
msgid "Create table?"
@@ -3028,8 +2859,7 @@
#: ../gui/wxpython/dbmgr/dialogs.py:226
#, python-format
msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
-msgstr ""
-"Colonne<%(col)s> : La valeur '%(value)s' doit être entrée comme %(type)s."
+msgstr "Colonne<%(col)s> : La valeur '%(value)s' doit être entrée comme %(type)s."
#: ../gui/wxpython/dbmgr/dialogs.py:426
msgid "Unknown"
@@ -3076,11 +2906,8 @@
#: ../gui/wxpython/gui_core/preferences.py:90
#: ../gui/wxpython/wxplot/dialogs.py:381 ../gui/wxpython/wxplot/dialogs.py:765
#: ../gui/wxpython/gcp/manager.py:2371
-msgid ""
-"Apply and save changes to user settings file (default for next sessions)"
-msgstr ""
-"Appliquer et enregistrer les changements dans le fichier de configuration "
-"personnel (valeurs par défaut pour la prochaine session)"
+msgid "Apply and save changes to user settings file (default for next sessions)"
+msgstr "Appliquer et enregistrer les changements dans le fichier de configuration personnel (valeurs par défaut pour la prochaine session)"
#: ../gui/wxpython/gui_core/preferences.py:93
#: ../gui/wxpython/psmap/dialogs.py:354 ../gui/wxpython/wxplot/dialogs.py:383
@@ -3134,9 +2961,7 @@
#: ../gui/wxpython/gui_core/preferences.py:329
msgid "Automatically copy selected text to clipboard (in Command console)"
-msgstr ""
-"Copier automatiquement le texte dans le bloc-notes (dans la console de "
-"commande)"
+msgstr "Copier automatiquement le texte dans le bloc-notes (dans la console de commande)"
#: ../gui/wxpython/gui_core/preferences.py:344
msgid "Workspace settings"
@@ -3155,13 +2980,8 @@
msgstr "Sauvegarder la configuration de fenêtre actuelle comme défaut"
#: ../gui/wxpython/gui_core/preferences.py:377
-msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
-msgstr ""
-"Sauvegarder position et taille actuelles de la fenêtre de gestionnaire de "
-"couches et de la (des) fenêtre(s) d'affichage de carte ; utiliser par défaut "
-"pour les sessions suivantes."
+msgid "Save current position and size of Layer Manager window and opened Map Display window(s) and use as default for next sessions."
+msgstr "Sauvegarder position et taille actuelles de la fenêtre de gestionnaire de couches et de la (des) fenêtre(s) d'affichage de carte ; utiliser par défaut pour les sessions suivantes."
#: ../gui/wxpython/gui_core/preferences.py:405
#: ../gui/wxpython/gui_core/preferences.py:577
@@ -3370,21 +3190,15 @@
#: ../gui/wxpython/gui_core/preferences.py:1111
msgid ""
"\n"
-"Note: This only controls the coordinates displayed in the lower-left of the "
-"Map Display\n"
-"window's status bar. It is purely cosmetic and does not affect the working "
-"location's\n"
-"projection in any way. You will need to enable the Projection check box in "
-"the drop-down\n"
+"Note: This only controls the coordinates displayed in the lower-left of the Map Display\n"
+"window's status bar. It is purely cosmetic and does not affect the working location's\n"
+"projection in any way. You will need to enable the Projection check box in the drop-down\n"
"menu located at the bottom of the Map Display window.\n"
msgstr ""
"\n"
-"Note : Ceci contrôle uniquement les coordonnées affichées dans le coin "
-"inférieur gauche\n"
-" de la fenêtre de Carte. L'effet est purement cosméthique et n'affecte pas "
-"la projection\n"
-" du secteur d'aucune manière. Vous devrez cocher la case Projection dans le "
-"menu déroulant\n"
+"Note : Ceci contrôle uniquement les coordonnées affichées dans le coin inférieur gauche\n"
+" de la fenêtre de Carte. L'effet est purement cosméthique et n'affecte pas la projection\n"
+" du secteur d'aucune manière. Vous devrez cocher la case Projection dans le menu déroulant\n"
" en bas de la fenêtre de carte.\n"
#: ../gui/wxpython/gui_core/preferences.py:1126
@@ -3401,12 +3215,8 @@
msgstr "Fichier EPSG :"
#: ../gui/wxpython/gui_core/preferences.py:1174
-msgid ""
-"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
-"directly."
-msgstr ""
-"Charger les codes EPSG (patience), entrer le code EPSG ou insérer la chaîne "
-"Proj.4 directement."
+msgid "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string directly."
+msgstr "Charger les codes EPSG (patience), entrer le code EPSG ou insérer la chaîne Proj.4 directement."
#: ../gui/wxpython/gui_core/preferences.py:1182
msgid "&Load EPSG codes"
@@ -3504,8 +3314,7 @@
#: ../gui/wxpython/gui_core/menu.py:206
msgid "You must run this command from the menu or command line"
-msgstr ""
-"Vous devez exécuter cette commande depuis le menu ou la ligne de commande"
+msgstr "Vous devez exécuter cette commande depuis le menu ou la ligne de commande"
#: ../gui/wxpython/gui_core/menu.py:268 ../gui/wxpython/gui_core/ghelp.py:174
#: ../gui/wxpython/gui_core/goutput.py:705
@@ -3913,12 +3722,8 @@
msgstr "Fermer la boîte de dialogue après exécution"
#: ../gui/wxpython/gui_core/forms.py:515
-msgid ""
-"Close dialog when command is successfully finished. Change this settings in "
-"Preferences dialog ('Command' tab)."
-msgstr ""
-"Fermer la fenêtre de dialogue quand la commande se termine avec succès. "
-"Modifier ce réglage dans les Préférences (onglet 'Commande')."
+msgid "Close dialog when command is successfully finished. Change this settings in Preferences dialog ('Command' tab)."
+msgstr "Fermer la fenêtre de dialogue quand la commande se termine avec succès. Modifier ce réglage dans les Préférences (onglet 'Commande')."
#: ../gui/wxpython/gui_core/forms.py:686
#, python-format
@@ -4043,13 +3848,8 @@
msgstr "Fichier &Log"
#: ../gui/wxpython/gui_core/goutput.py:270
-#, fuzzy
-msgid ""
-"Toggle to save list of executed commands into a file; content saved when "
-"switching off."
-msgstr ""
-"Activer pour enregistrer dans un fichier la liste des commandes exécutées; "
-"le contenu sera enregistré à la désactivation."
+msgid "Toggle to save list of executed commands into a file; content saved when switching off."
+msgstr "Basculer l'enregistrement de la liste des commandes exécutées dans le fichier; le contenu est enregistré lorsque désactivé."
#: ../gui/wxpython/gui_core/goutput.py:488
#: ../gui/wxpython/gui_core/goutput.py:790
@@ -4065,12 +3865,8 @@
#: ../gui/wxpython/gui_core/goutput.py:526
#, python-format
-msgid ""
-"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
-"layer instead."
-msgstr ""
-"La commande '%s' n'est pas encore implantée dans wxGUI. Essayez plutôt de "
-"l'ajouter en tant que couche de commande."
+msgid "Command '%s' not yet implemented in the WxGUI. Try adding it as a command layer instead."
+msgstr "La commande '%s' n'est pas encore implantée dans wxGUI. Essayez plutôt de l'ajouter en tant que couche de commande."
#: ../gui/wxpython/gui_core/goutput.py:568
#, python-format
@@ -4083,8 +3879,7 @@
"impossible de lancer la commande :\n"
"%(cmd)s\n"
"\n"
-"Option <%(opt)s> : la lecture depuis l'entrée standard n'est pas prise en "
-"charge par wxGUI"
+"Option <%(opt)s> : la lecture depuis l'entrée standard n'est pas prise en charge par wxGUI"
#: ../gui/wxpython/gui_core/goutput.py:658
#: ../gui/wxpython/gui_core/goutput.py:808
@@ -4139,11 +3934,8 @@
msgstr "%(min)d min %(sec)d sec"
#: ../gui/wxpython/gui_core/goutput.py:861
-msgid ""
-"Please note that the data are left in inconsistent state and may be corrupted"
-msgstr ""
-"Veuillez noter que les données sont laissées dans un état inconsitant et "
-"peuvent être corrompues"
+msgid "Please note that the data are left in inconsistent state and may be corrupted"
+msgstr "Veuillez noter que les données sont laissées dans un état inconsitant et peuvent être corrompues"
#: ../gui/wxpython/gui_core/goutput.py:863
msgid "Command aborted"
@@ -4161,9 +3953,7 @@
#: ../gui/wxpython/gui_core/mapdisp.py:84 ../gui/wxpython/core/render.py:432
#, python-format
msgid "GRASS module '%s' not found. Unable to start map display window."
-msgstr ""
-"Module GRASS '%s' introuvable. Impossible de démarrer la fenêtre d'affichage "
-"des cartes."
+msgstr "Module GRASS '%s' introuvable. Impossible de démarrer la fenêtre d'affichage des cartes."
#: ../gui/wxpython/gui_core/dialogs.py:114
msgid "Type of element:"
@@ -4215,12 +4005,8 @@
#: ../gui/wxpython/gui_core/dialogs.py:384
#, python-format
-msgid ""
-"Vector map <%s> already exists in the current mapset. Do you want to "
-"overwrite it?"
-msgstr ""
-"La carte vecteur <%s> existe déjà dans le jeu de cartes courant. Voulez-"
-"vous l'écraser ?"
+msgid "Vector map <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgstr "La carte vecteur <%s> existe déjà dans le jeu de cartes courant. Voulez-vous l'écraser ?"
#: ../gui/wxpython/gui_core/dialogs.py:387
msgid "Overwrite?"
@@ -4244,12 +4030,8 @@
msgstr "Taille et position"
#: ../gui/wxpython/gui_core/dialogs.py:534
-msgid ""
-"Click and drag on the map display to set legend size and position and then "
-"press OK"
-msgstr ""
-"Cliquer et déplacer dans la fenêtre de carte pour définir la taille et la "
-"position de la légende, puis appuyer sur OK."
+msgid "Click and drag on the map display to set legend size and position and then press OK"
+msgstr "Cliquer et déplacer dans la fenêtre de carte pour définir la taille et la position de la légende, puis appuyer sur OK."
#: ../gui/wxpython/gui_core/dialogs.py:544
#, python-format
@@ -4266,8 +4048,7 @@
"Define raster map name for legend in properties dialog."
msgstr ""
"\n"
-"Définir le nom de la carte 'raster' pour créer la légende dans la boîte de "
-"dialogue des propriétés."
+"Définir le nom de la carte 'raster' pour créer la légende dans la boîte de dialogue des propriétés."
#: ../gui/wxpython/gui_core/dialogs.py:599
#, python-format
@@ -4305,14 +4086,11 @@
#: ../gui/wxpython/gui_core/dialogs.py:889
msgid "Close dialog, changes are not applied"
-msgstr ""
-"Fermer la boîte de dialogue, les modifications ne seront pas appliquées"
+msgstr "Fermer la boîte de dialogue, les modifications ne seront pas appliquées"
#: ../gui/wxpython/gui_core/dialogs.py:930
msgid "Select the group you want to edit or enter name of new group:"
-msgstr ""
-"Sélectionner le groupe que vous voulez modifier ou entrez le nom d'un "
-"nouveau groupe :"
+msgstr "Sélectionner le groupe que vous voulez modifier ou entrez le nom d'un nouveau groupe :"
#: ../gui/wxpython/gui_core/dialogs.py:941
msgid "Layers in selected group:"
@@ -4337,8 +4115,7 @@
#: ../gui/wxpython/gui_core/dialogs.py:1017
#, python-format
msgid "Group <%s> was changed, do you want to apply changes?"
-msgstr ""
-"Le groupe <%s> a été modifié, voulez-vous enregistrer les modifications ?"
+msgstr "Le groupe <%s> a été modifié, voulez-vous enregistrer les modifications ?"
#: ../gui/wxpython/gui_core/dialogs.py:1019
msgid "Unapplied changes"
@@ -4640,12 +4417,8 @@
msgstr "Importation et maillage de points ASCII x,y,z"
#: ../gui/wxpython/menustrings.py:33
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
-"Créer une carte raster à partir d'un assemblage d'un lot de coordonnées en "
-"utilisant des statistiques univariées."
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
+msgstr "Créer une carte raster à partir d'un assemblage d'un lot de coordonnées en utilisant des statistiques univariées."
#: ../gui/wxpython/menustrings.py:34
msgid "ASCII grid import"
@@ -4676,12 +4449,8 @@
msgstr "Importer une grille ASCII ESRI"
#: ../gui/wxpython/menustrings.py:41
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-"map layer."
-msgstr ""
-"Convertir un fichier raster ESRI ARC/INFO ASCII (GRID) en carte raster "
-"(binaire)."
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+msgstr "Convertir un fichier raster ESRI ARC/INFO ASCII (GRID) en carte raster (binaire)."
#: ../gui/wxpython/menustrings.py:42
msgid "GRIDATB.FOR import"
@@ -4689,8 +4458,7 @@
#: ../gui/wxpython/menustrings.py:43
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
-msgstr ""
-"Importer un fichier carte GRIDATB.FOR (TOPMODEL) vers une carte raster GRASS"
+msgstr "Importer un fichier carte GRIDATB.FOR (TOPMODEL) vers une carte raster GRASS"
#: ../gui/wxpython/menustrings.py:44
msgid "Matlab 2D array import"
@@ -4721,12 +4489,8 @@
msgstr "Importer un Terra ASTER HDF"
#: ../gui/wxpython/menustrings.py:51
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
-msgstr ""
-"Géoréférencer, rectifier et importer une image Terra-ASTER et ses DEM's "
-"associés avec gdalwarp."
+msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
+msgstr "Géoréférencer, rectifier et importer une image Terra-ASTER et ses DEM's associés avec gdalwarp."
#: ../gui/wxpython/menustrings.py:52
msgid "WMS import"
@@ -4758,9 +4522,7 @@
#: ../gui/wxpython/menustrings.py:60
msgid "Creates a vector map from ASCII points file or ASCII vector file."
-msgstr ""
-"Crée une carte vecteur depuis un fichier de points ASCII ou un fichier "
-"vecteur ASCII."
+msgstr "Crée une carte vecteur depuis un fichier de points ASCII ou un fichier vecteur ASCII."
#: ../gui/wxpython/menustrings.py:61
msgid "ASCII points as a vector lines"
@@ -4780,16 +4542,11 @@
#: ../gui/wxpython/menustrings.py:65
msgid "Historical GRASS vector import (all maps)"
-msgstr ""
-"Import de cartes vecteurs ancienne version de GRASS (toutes les cartes)"
+msgstr "Import de cartes vecteurs ancienne version de GRASS (toutes les cartes)"
#: ../gui/wxpython/menustrings.py:66
-msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr ""
-"Convertir toutes les cartes vectorielles en ancien format GRASS du jeux de "
-"cartes courant vers le nouveau format."
+msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
+msgstr "Convertir toutes les cartes vectorielles en ancien format GRASS du jeux de cartes courant vers le nouveau format."
#: ../gui/wxpython/menustrings.py:67
msgid "DXF import"
@@ -4820,24 +4577,16 @@
msgstr "Importer depuis un GPS Garmin"
#: ../gui/wxpython/menustrings.py:74
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-"Télécharger des waypoints, routes, traces depuis un récepteur GPS garmin "
-"vers une carte vectorielle."
+msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+msgstr "Télécharger des waypoints, routes, traces depuis un récepteur GPS garmin vers une carte vectorielle."
#: ../gui/wxpython/menustrings.py:75
msgid "GPSBabel GPS import"
msgstr "Import GPS depuis GPSBabel"
#: ../gui/wxpython/menustrings.py:76
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-"Importer des waypoints, routes, et traces depuis un récepteur GPS ou un "
-"fichier GPS vers une carte vectorielle."
+msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+msgstr "Importer des waypoints, routes, et traces depuis un récepteur GPS ou un fichier GPS vers une carte vectorielle."
#: ../gui/wxpython/menustrings.py:77
msgid "Geonames import"
@@ -4845,20 +4594,15 @@
#: ../gui/wxpython/menustrings.py:78
msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr ""
-"Importer des fichiers de pays geonames.org vers une carte vecteur de points."
+msgstr "Importer des fichiers de pays geonames.org vers une carte vecteur de points."
#: ../gui/wxpython/menustrings.py:79
msgid "GEOnet import"
msgstr "Importer depuis GEOnet"
#: ../gui/wxpython/menustrings.py:80
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-"Importer un fichier de pays US-NGA GEOnet Names Server (GNS) vers une carte "
-"vecteur de points."
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
+msgstr "Importer un fichier de pays US-NGA GEOnet Names Server (GNS) vers une carte vecteur de points."
#: ../gui/wxpython/menustrings.py:81
msgid "Matlab array or Mapgen format import"
@@ -4877,22 +4621,16 @@
msgstr "Importer un ASCII 3D"
-msgid ""
-"Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-msgstr ""
-"Convertit un fichier texte raster ASCII 3D en carte raster 3D (binaire)"
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+msgstr "Convertit un fichier texte raster ASCII 3D en carte raster 3D (binaire)"
#: ../gui/wxpython/menustrings.py:86
msgid "Vis5D import"
msgstr "Importer en Vis5D"
#: ../gui/wxpython/menustrings.py:87
-msgid ""
-"Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 "
-"time step)."
-msgstr ""
-"Importer un fichier 3D Vis5D (i.e. fichier V5D avec 1 variable et 1 pas de "
-"temps)."
+msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
+msgstr "Importer un fichier 3D Vis5D (i.e. fichier V5D avec 1 variable et 1 pas de temps)."
#: ../gui/wxpython/menustrings.py:88
msgid "Import database table"
@@ -4931,11 +4669,8 @@
msgstr "Export en points ASCII x,y,z"
#: ../gui/wxpython/menustrings.py:97
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"Exporte une carte raster en fichier texte comme valeurs x,y,z en se fondant "
-"sur le centre des cellules."
+msgid "Export a raster map to a text file as x,y,z values based on cell centers."
+msgstr "Exporte une carte raster en fichier texte comme valeurs x,y,z en se fondant sur le centre des cellules."
#: ../gui/wxpython/menustrings.py:98
msgid "ESRI ASCII grid export"
@@ -4990,24 +4725,16 @@
msgstr "Exporter en PPM"
#: ../gui/wxpython/menustrings.py:111
-msgid ""
-"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
-"the currently defined region."
-msgstr ""
-"Convertit une carte raster GRASS en fichier image PPM à la résolution de la "
-"région courante."
+msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
+msgstr "Convertit une carte raster GRASS en fichier image PPM à la résolution de la région courante."
#: ../gui/wxpython/menustrings.py:112
msgid "PPM from RGB export"
msgstr "Export PPM depuis RVB"
#: ../gui/wxpython/menustrings.py:113
-msgid ""
-"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-"resolution of the CURRENTLY DEFINED REGION."
-msgstr ""
-"Convertit 3 cartes raster (R,V,B) en fichier image PPM à la résolution de la "
-"RÉGION COURANTE."
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+msgstr "Convertit 3 cartes raster (R,V,B) en fichier image PPM à la résolution de la RÉGION COURANTE."
#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:133
msgid "POV-Ray export"
@@ -5022,12 +4749,8 @@
msgstr "Export TIFF"
#: ../gui/wxpython/menustrings.py:117
-msgid ""
-"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-"resolution of the currently defined region."
-msgstr ""
-"Exporte une carte raster en fichier image TIFFbit à la résolution de la "
-"région courante. "
+msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
+msgstr "Exporte une carte raster en fichier image TIFFbit à la résolution de la région courante. "
#: ../gui/wxpython/menustrings.py:118
msgid "VRML export"
@@ -5035,8 +4758,7 @@
#: ../gui/wxpython/menustrings.py:119
msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-msgstr ""
-"Exporte une carte raster vers le langage Virtual Reality Modeling (VRML)"
+msgstr "Exporte une carte raster vers le langage Virtual Reality Modeling (VRML)"
#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:137
#: ../gui/wxpython/menustrings.py:144
@@ -5062,8 +4784,7 @@
#: ../gui/wxpython/menustrings.py:126
#, fuzzy
msgid "Converts to one of the supported OGR vector formats."
-msgstr ""
-"Convertir une carte vecteur vers un des formats pris en charge par OGR."
+msgstr "Convertir une carte vecteur vers un des formats pris en charge par OGR."
#: ../gui/wxpython/menustrings.py:127
msgid "ASCII points/GRASS ASCII vector export"
@@ -5071,8 +4792,7 @@
#: ../gui/wxpython/menustrings.py:128
msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-msgstr ""
-"Convertir une carte vecteur binaire GRASS en carte vecteur ASCII GRASS."
+msgstr "Convertir une carte vecteur binaire GRASS en carte vecteur ASCII GRASS."
#: ../gui/wxpython/menustrings.py:129
msgid "DXF export"
@@ -5087,11 +4807,8 @@
msgstr "Exporter vers des formats GPS avec GPSBABEL"
#: ../gui/wxpython/menustrings.py:132
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-msgstr ""
-"Exporte une carte vecteur vers un récepteur GPS ou vers un fichier au format "
-"reconnu par GpsBabel."
+msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgstr "Exporte une carte vecteur vers un récepteur GPS ou vers un fichier au format reconnu par GpsBabel."
#: ../gui/wxpython/menustrings.py:134
msgid "Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y"
@@ -5151,14 +4868,11 @@
#: ../gui/wxpython/menustrings.py:151
msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
-msgstr ""
-"Lier des données prises en charge par GDAL en tant que pseudocarte raster."
+msgstr "Lier des données prises en charge par GDAL en tant que pseudocarte raster."
#: ../gui/wxpython/menustrings.py:153
msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
-msgstr ""
-"Crée une nouvelle pseudo carte vecteur comme lien vers une couche prise en "
-"charge par OGR."
+msgstr "Crée une nouvelle pseudo carte vecteur comme lien vers une couche prise en charge par OGR."
#: ../gui/wxpython/menustrings.py:154
msgid "Manage maps and volumes"
@@ -5169,14 +4883,8 @@
msgstr "Copier"
#: ../gui/wxpython/menustrings.py:156
-msgid ""
-"Copies available data files in the user's current mapset search path and "
-"location to the appropriate element directories under the user's current "
-"mapset."
-msgstr ""
-"Copier les fichiers de données disponibles dans le chemin de recherche et le "
-"Secteur vers le répertoire approprié sous le jeu de données courant de "
-"l'utilisateur."
+msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
+msgstr "Copier les fichiers de données disponibles dans le chemin de recherche et le Secteur vers le répertoire approprié sous le jeu de données courant de l'utilisateur."
#: ../gui/wxpython/menustrings.py:157
msgid "List"
@@ -5184,33 +4892,23 @@
#: ../gui/wxpython/menustrings.py:158
msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr ""
-"Lister les fichiers de base de données GRASS disponibles du type spécifié "
-"par l'utilisateur."
+msgstr "Lister les fichiers de base de données GRASS disponibles du type spécifié par l'utilisateur."
#: ../gui/wxpython/menustrings.py:159
msgid "List filtered"
msgstr "Liste filtrée"
#: ../gui/wxpython/menustrings.py:160
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"par l'utilisateur en utilisant un modèle de recherche."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "Lister les fichiers de base de données GRASS disponibles du type spécifié par l'utilisateur en utilisant un modèle de recherche."
#: ../gui/wxpython/menustrings.py:162
msgid "Renames data base element files in the user's current mapset."
-msgstr ""
-"Renommer les fichiers éléments de la base de données dans le jeu de données "
-"courant de l'utilisateur"
+msgstr "Renommer les fichiers éléments de la base de données dans le jeu de données courant de l'utilisateur"
#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:166
msgid "Removes data base element files from the user's current mapset."
-msgstr ""
-"Supprimer les fichiers éléments de base de données du jeu de données courant "
-"de l'utilisateur"
+msgstr "Supprimer les fichiers éléments de base de données du jeu de données courant de l'utilisateur"
#: ../gui/wxpython/menustrings.py:165
msgid "Delete filtered"
@@ -5236,8 +4934,7 @@
#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:303
msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr ""
-"Convertir des tranches de cartes raster 2D en une carte volumique raster 3D. "
+msgstr "Convertir des tranches de cartes raster 2D en une carte volumique raster 3D. "
#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:304
msgid "Raster 2.5D to volume"
@@ -5245,8 +4942,7 @@
#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:305
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-"Crée un volume 3D à partir de cartes raster 2D d'altitude et de valeurs."
+msgstr "Crée un volume 3D à partir de cartes raster 2D d'altitude et de valeurs."
#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:579
msgid "Vector to raster"
@@ -5261,12 +4957,8 @@
msgstr "Vectorielle vers volume"
#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:582
-msgid ""
-"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
-"raster map layer."
-msgstr ""
-"Convertir une carte vecteur binaire GRASS (uniquement des points) en carte "
-"raster 3D GRASS."
+msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
+msgstr "Convertir une carte vecteur binaire GRASS (uniquement des points) en carte raster 3D GRASS."
#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:583
msgid "2D vector to 3D vector"
@@ -5337,12 +5029,8 @@
msgstr "Gisement/distance vers coordonnées"
#: ../gui/wxpython/menustrings.py:195
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
-msgstr ""
-"Un utilitaire simple pour convertir des mesures de gisements et distances "
-"vers des coordonnées et vice-versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgstr "Un utilitaire simple pour convertir des mesures de gisements et distances vers des coordonnées et vice-versa."
#: ../gui/wxpython/menustrings.py:197
msgid "Launch Cartographic Composer"
@@ -5394,8 +5082,7 @@
#: ../gui/wxpython/menustrings.py:210
msgid "Set/unset access to other mapsets in current location"
-msgstr ""
-"Active/désactive l'accès aux autres jeux de données dans le secteur courant"
+msgstr "Active/désactive l'accès aux autres jeux de données dans le secteur courant"
#: ../gui/wxpython/menustrings.py:211
msgid "User access"
@@ -5403,9 +5090,7 @@
#: ../gui/wxpython/menustrings.py:212
msgid "Controls access to the current mapset for other users on the system."
-msgstr ""
-"Contrôle l'accès au jeu de cartes courant pour les autres utilisateurs du "
-"système."
+msgstr "Contrôle l'accès au jeu de cartes courant pour les autres utilisateurs du système."
#: ../gui/wxpython/menustrings.py:213
msgid "Change working environment"
@@ -5437,8 +5122,7 @@
#: ../gui/wxpython/menustrings.py:220 ../gui/wxpython/menustrings.py:222
msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr ""
-"Affiche et modifie les réglages de variables GRASS de l'utilisateur courant."
+msgstr "Affiche et modifie les réglages de variables GRASS de l'utilisateur courant."
#: ../gui/wxpython/menustrings.py:221
msgid "Change settings"
@@ -5462,9 +5146,7 @@
#: ../gui/wxpython/menustrings.py:228
msgid "Creates new mapset in the current location, changes current mapset."
-msgstr ""
-"Crée un nouveau jeux de cartes dans le secteur de travail courant, et change "
-"le jeux de cartes courant."
+msgstr "Crée un nouveau jeux de cartes dans le secteur de travail courant, et change le jeux de cartes courant."
#: ../gui/wxpython/menustrings.py:229
#, fuzzy
@@ -5485,20 +5167,15 @@
#: ../gui/wxpython/menustrings.py:233
msgid "Print projection information (in conventional GRASS format)."
-msgstr ""
-"Imprimer les informations de projection (dans le format GRASS conventionnel)."
+msgstr "Imprimer les informations de projection (dans le format GRASS conventionnel)."
#: ../gui/wxpython/menustrings.py:234
msgid "Manage projections"
msgstr "Gérer les projections"
#: ../gui/wxpython/menustrings.py:235
-msgid ""
-"Prints and manipulates GRASS projection information files (in various co-"
-"ordinate system descriptions)."
-msgstr ""
-"Affiche et modifie les fichiers de projection de GRASS (dans divers systèmes "
-"de coordonnées)."
+msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
+msgstr "Affiche et modifie les fichiers de projection de GRASS (dans divers systèmes de coordonnées)."
#: ../gui/wxpython/menustrings.py:236
msgid "Change projection for current location"
@@ -5515,8 +5192,7 @@
# L'usage en traduction française semble être de conserver les anglicismes frontend et backend
#: ../gui/wxpython/menustrings.py:239
msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-"Convertir les coordonnées d'une projection à une autre (frontend cs2cs)."
+msgstr "Convertir les coordonnées d'une projection à une autre (frontend cs2cs)."
#: ../gui/wxpython/menustrings.py:240
msgid "Addons extensions"
@@ -5553,8 +5229,7 @@
#: ../gui/wxpython/menustrings.py:248
msgid "User GUI preferences (display font, commands, digitizer, etc.)"
-msgstr ""
-"Préférences utilisateur GUI (police d'affichage, commandes, numériseur, etc.)"
+msgstr "Préférences utilisateur GUI (police d'affichage, commandes, numériseur, etc.)"
#: ../gui/wxpython/menustrings.py:249
msgid "&Raster"
@@ -5569,13 +5244,8 @@
msgstr "Numériser un raster (requiert XTerm)"
#: ../gui/wxpython/menustrings.py:252
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
-msgstr ""
-"Outil interactif utilisé pour dessiner et sauvegarder des objets vectoriels "
-"dans un moniteur graphique, en utilisant un dispositif de pointage (souris) "
-"et sauver dans une carte raster."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
+msgstr "Outil interactif utilisé pour dessiner et sauvegarder des objets vectoriels dans un moniteur graphique, en utilisant un dispositif de pointage (souris) et sauver dans une carte raster."
#: ../gui/wxpython/menustrings.py:253
msgid "Compress/decompress"
@@ -5607,8 +5277,7 @@
#: ../gui/wxpython/menustrings.py:260
msgid "Produces the quantization file for a floating-point map."
-msgstr ""
-"Produit le fichier de quantification pour une carte en virgule flottante."
+msgstr "Produit le fichier de quantification pour une carte en virgule flottante."
#: ../gui/wxpython/menustrings.py:261
msgid "Timestamp"
@@ -5624,9 +5293,7 @@
#: ../gui/wxpython/menustrings.py:264
msgid "Resamples raster map layers to a coarser grid using aggregation."
-msgstr ""
-"Ré-échantillonner une carte raster avec un maillage plus grossier en "
-"procédant par agrégation."
+msgstr "Ré-échantillonner une carte raster avec un maillage plus grossier en procédant par agrégation."
#: ../gui/wxpython/menustrings.py:265
msgid "Resample using multiple methods"
@@ -5634,9 +5301,7 @@
#: ../gui/wxpython/menustrings.py:266
msgid "Resamples raster map layers to a finer grid using interpolation."
-msgstr ""
-"Ré-échantillonner la carte raster avec un maillage plus fin en procédant par "
-"interpolation"
+msgstr "Ré-échantillonner la carte raster avec un maillage plus fin en procédant par interpolation"
#: ../gui/wxpython/menustrings.py:267
msgid "Resample using nearest neighbor"
@@ -5651,14 +5316,8 @@
msgstr "Ré-échantillonner par les splines avec tension"
#: ../gui/wxpython/menustrings.py:270
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"Ré-interpole et en option calcule une analyse topographique d'une carte "
-"raster (éventuellement à une résolution différente) en utilisant les splines "
-"régulées avec tension et lissage."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr "Ré-interpole et en option calcule une analyse topographique d'une carte raster (éventuellement à une résolution différente) en utilisant les splines régulées avec tension et lissage."
# Pour désigner les support files, je propose la traduction fichiers de maintenance. Guère d'autre idée pour englober à la fois la dimension historique du fichier, méta-infos, lien vers un éventuel autre raster...
#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:544
@@ -5668,9 +5327,7 @@
#: ../gui/wxpython/menustrings.py:272
msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"Permet la création et/ou la modification de fichiers de maintenance de "
-"cartes raster."
+msgstr "Permet la création et/ou la modification de fichiers de maintenance de cartes raster."
#: ../gui/wxpython/menustrings.py:273
msgid "Update map statistics"
@@ -5693,12 +5350,8 @@
msgstr "Mosaïquer"
#: ../gui/wxpython/menustrings.py:278
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Produit une mosaïque de la projection source pour utilisation dans la région "
-"et projection de destination."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr "Produit une mosaïque de la projection source pour utilisation dans la région et projection de destination."
#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:563
msgid "Manage colors"
@@ -5718,9 +5371,7 @@
#: ../gui/wxpython/menustrings.py:283
msgid "Set color rules based on stddev from a map's mean value."
-msgstr ""
-"Définir les règles de couleurs depuis l'écart-type des valeurs moyennes "
-"d'une carte."
+msgstr "Définir les règles de couleurs depuis l'écart-type des valeurs moyennes d'une carte."
#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:566
msgid "Color rules"
@@ -5744,32 +5395,23 @@
#: ../gui/wxpython/menustrings.py:289
msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"Mélange les composantes de couleur de deux cartes raster d'un ratio donné."
+msgstr "Mélange les composantes de couleur de deux cartes raster d'un ratio donné."
#: ../gui/wxpython/menustrings.py:290
msgid "Create RGB"
msgstr "Créer RVB"
#: ../gui/wxpython/menustrings.py:291
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-"Combine des cartes raster rouge, vert et bleu en une unique carte raster "
-"composite."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
+msgstr "Combine des cartes raster rouge, vert et bleu en une unique carte raster composite."
#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:713
msgid "RGB to HIS"
msgstr "RVB vers TSV"
#: ../gui/wxpython/menustrings.py:293
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-"Génère des cartes raster rouge, vert et bleu en combinant des valeurs de "
-"teinte, saturation, valeur (TSV) de cartes raster indiquées par "
-"l'utilisateur."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Génère des cartes raster rouge, vert et bleu en combinant des valeurs de teinte, saturation, valeur (TSV) de cartes raster indiquées par l'utilisateur."
#: ../gui/wxpython/menustrings.py:294
msgid "Query raster maps"
@@ -5781,8 +5423,7 @@
#: ../gui/wxpython/menustrings.py:296
msgid "Queries raster map layers on their category values and category labels."
-msgstr ""
-"Interroger des cartes raster sur leurs valeurs de catégories et d'étiquettes."
+msgstr "Interroger des cartes raster sur leurs valeurs de catégories et d'étiquettes."
#: ../gui/wxpython/menustrings.py:297
msgid "Query colors by value"
@@ -5797,12 +5438,8 @@
msgstr "Zone tampon raster"
#: ../gui/wxpython/menustrings.py:307
-msgid ""
-"Creates a raster map layer showing buffer zones surrounding cells that "
-"contain non-NULL category values."
-msgstr ""
-"Crée une carte raster montrant des zones tampons entourant des cellules "
-"contenant des valeurs de catégorie non-NULL."
+msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Crée une carte raster montrant des zones tampons entourant des cellules contenant des valeurs de catégorie non-NULL."
#: ../gui/wxpython/menustrings.py:308
msgid "Concentric circles"
@@ -5810,9 +5447,7 @@
#: ../gui/wxpython/menustrings.py:309
msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-"Crée une carte raster contenant des cercles concentriques autour d'un point "
-"donné."
+msgstr "Crée une carte raster contenant des cercles concentriques autour d'un point donné."
#: ../gui/wxpython/menustrings.py:310
msgid "Closest points"
@@ -5820,9 +5455,7 @@
#: ../gui/wxpython/menustrings.py:311
msgid "Locates the closest points between objects in two raster maps."
-msgstr ""
-"Localise les points de plus grande proximité entre objets de deux cartes "
-"raster."
+msgstr "Localise les points de plus grande proximité entre objets de deux cartes raster."
#: ../gui/wxpython/menustrings.py:313
msgid "Creates a MASK for limiting raster operation."
@@ -5845,28 +5478,16 @@
msgstr "Fenêtre mouvante"
#: ../gui/wxpython/menustrings.py:318
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"Rend la catégorie de chaque cellule une fontion des valeurs de catégorie des "
-"cellules voisines, et enregistre la nouvelle valeur dans une carte raster de "
-"sortie."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr "Rend la catégorie de chaque cellule une fontion des valeurs de catégorie des cellules voisines, et enregistre la nouvelle valeur dans une carte raster de sortie."
#: ../gui/wxpython/menustrings.py:319
msgid "Neighborhood points"
msgstr "Points voisins"
#: ../gui/wxpython/menustrings.py:320
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map layer."
-msgstr ""
-"Rend la valeur de chaque cellule une fonction des valeurs d'attributs des "
-"points ou centroids voisins, et enregistre la nouvelle valeur de cellule "
-"dans une carte raster de sortie."
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map layer."
+msgstr "Rend la valeur de chaque cellule une fonction des valeurs d'attributs des points ou centroids voisins, et enregistre la nouvelle valeur de cellule dans une carte raster de sortie."
#: ../gui/wxpython/menustrings.py:321
msgid "Overlay rasters"
@@ -5877,35 +5498,24 @@
msgstr "Produit en croix"
#: ../gui/wxpython/menustrings.py:323
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-"Crée un produit croisé des valeurs de catégories de multiples cartes raster."
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr "Crée un produit croisé des valeurs de catégories de multiples cartes raster."
#: ../gui/wxpython/menustrings.py:324
msgid "Raster series"
msgstr "Série raster"
#: ../gui/wxpython/menustrings.py:325
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"Rend la valeur de sortie des cellules une foncton des valeurs des cellules "
-"correspondantes dans les cartes raster d'entrée."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Rend la valeur de sortie des cellules une foncton des valeurs des cellules correspondantes dans les cartes raster d'entrée."
#: ../gui/wxpython/menustrings.py:326
msgid "Patch raster maps"
msgstr "Combiner des cartes raster"
#: ../gui/wxpython/menustrings.py:327
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Crée une carte raster composite en utilisant les valeurs connues d'une (ou "
-"plusieurs) carte pour remplir les zones de \"no data\" d'une autre carte."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "Crée une carte raster composite en utilisant les valeurs connues d'une (ou plusieurs) carte pour remplir les zones de \"no data\" d'une autre carte."
#: ../gui/wxpython/menustrings.py:328
msgid "Statistical overlay"
@@ -5932,11 +5542,8 @@
msgstr "Carte des ombres"
#: ../gui/wxpython/menustrings.py:334
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
-msgstr ""
-"Calcule les zones d'ombre depuis la position du soleil et une carte "
-"d'altitude."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
+msgstr "Calcule les zones d'ombre depuis la position du soleil et une carte d'altitude."
#: ../gui/wxpython/menustrings.py:335
msgid "Terrain analysis"
@@ -5948,38 +5555,23 @@
#: ../gui/wxpython/menustrings.py:337
msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-"Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
+msgstr "Créer une couche vecteur GRASS avec les contours d'une couche raster GRASS."
#: ../gui/wxpython/menustrings.py:338
msgid "Cost surface"
msgstr "Surface de coût"
#: ../gui/wxpython/menustrings.py:339
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Crée une carte raster montrant le coût cumulé d'un déplacement entre "
-"différents points sur une carte raster d'altitude dont les valeurs de "
-"catégories représentent un coût."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Crée une carte raster montrant le coût cumulé d'un déplacement entre différents points sur une carte raster d'altitude dont les valeurs de catégories représentent un coût."
#: ../gui/wxpython/menustrings.py:340
msgid "Cumulative movement costs"
msgstr "Coûts de déplacement cumulés"
#: ../gui/wxpython/menustrings.py:341
-msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
-msgstr ""
-"Crée une carte raster montrant le coût anisotropique cumulé d'un déplacement "
-"entre différents points sur la combinaison d'une carte raster d'altitude "
-"dont les valeurs de catégories représentent l'altitude et d'une carte raster "
-"dont les valeurs de cellule représentent un coût de frottement."
+msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
+msgstr "Crée une carte raster montrant le coût anisotropique cumulé d'un déplacement entre différents points sur la combinaison d'une carte raster d'altitude dont les valeurs de catégories représentent l'altitude et d'une carte raster dont les valeurs de cellule représentent un coût de frottement."
#: ../gui/wxpython/menustrings.py:342
msgid "Least cost route or flow"
@@ -5987,8 +5579,7 @@
#: ../gui/wxpython/menustrings.py:343
msgid "Traces a flow through an elevation model on a raster map."
-msgstr ""
-"Trace un écoulement à travers un modèle d'altitude sur une carte raster."
+msgstr "Trace un écoulement à travers un modèle d'altitude sur une carte raster."
#: ../gui/wxpython/menustrings.py:344
msgid "Shaded relief"
@@ -6003,12 +5594,8 @@
msgstr "Pente et exposition"
#: ../gui/wxpython/menustrings.py:347
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Génère des cartes raster de pente, exposition, courbure et dérivées "
-"partielles à partir d'une carte raster d'altitude."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Génère des cartes raster de pente, exposition, courbure et dérivées partielles à partir d'une carte raster d'altitude."
#: ../gui/wxpython/menustrings.py:348
msgid "Terrain parameters"
@@ -6041,8 +5628,7 @@
#: ../gui/wxpython/menustrings.py:355
#, fuzzy
msgid "Generates a raster map of distance to features in input raster map."
-msgstr ""
-"Génère une carte raster de distance à des objets dans la carte en entrée."
+msgstr "Génère une carte raster de distance à des objets dans la carte en entrée."
#: ../gui/wxpython/menustrings.py:356
msgid "Horizon angle"
@@ -6061,12 +5647,8 @@
msgstr "Agglomérer"
#: ../gui/wxpython/menustrings.py:360
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Reclasser les données dans une couche raster en regroupant les cellules qui "
-"forment des zones physiques discrètes."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Reclasser les données dans une couche raster en regroupant les cellules qui forment des zones physiques discrètes."
#: ../gui/wxpython/menustrings.py:361
msgid "Grow"
@@ -6074,9 +5656,7 @@
#: ../gui/wxpython/menustrings.py:362
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"Produit une couche raster où les surfaces contiguës ont été agrandies d'une "
-"cellule."
+msgstr "Produit une couche raster où les surfaces contiguës ont été agrandies d'une cellule."
#: ../gui/wxpython/menustrings.py:363
msgid "Thin"
@@ -6084,9 +5664,7 @@
#: ../gui/wxpython/menustrings.py:364
msgid "Thins non-zero cells that denote linear features in a raster map."
-msgstr ""
-"\"Amincit\" les cellules de valeur non-nulles qui semblent appartenir à des "
-"entités linéaires dans une couche raster."
+msgstr "\"Amincit\" les cellules de valeur non-nulles qui semblent appartenir à des entités linéaires dans une couche raster."
#: ../gui/wxpython/menustrings.py:365
msgid "Hydrologic modeling"
@@ -6114,12 +5692,8 @@
msgstr "Carte sans dépressions ni lignes de flux"
#: ../gui/wxpython/menustrings.py:371
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"Filtrer et générer une couche d'altitude sans dépressions et une couche de "
-"direction d'écoulement depuis une couche d'altitude donnée."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr "Filtrer et générer une couche d'altitude sans dépressions et une couche de direction d'écoulement depuis une couche d'altitude donnée."
#: ../gui/wxpython/menustrings.py:372
msgid "Flow accumulation"
@@ -6168,12 +5742,8 @@
msgstr "Modélisation d'hydro-géologie"
#: ../gui/wxpython/menustrings.py:383
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
-msgstr ""
-"Calcul numérique pour les eaux souterraines transitoires, confinées et non "
-"confinées, en deux dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
+msgstr "Calcul numérique pour les eaux souterraines transitoires, confinées et non confinées, en deux dimensions."
#: ../gui/wxpython/menustrings.py:384
msgid "SIMWE Overland flow modeling"
@@ -6188,12 +5758,8 @@
msgstr "Modélisation SIMWE des flux de sédiments"
#: ../gui/wxpython/menustrings.py:387
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
-msgstr ""
-"Simulation de transport de sédiments et d'érosion/sédimentation avec la "
-"méthode SIMWE."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+msgstr "Simulation de transport de sédiments et d'érosion/sédimentation avec la méthode SIMWE."
#: ../gui/wxpython/menustrings.py:388
msgid "Topographic index map"
@@ -6201,9 +5767,7 @@
#: ../gui/wxpython/menustrings.py:389
msgid "Creates topographic index map from elevation raster map."
-msgstr ""
-"Créer une carte d'index topographique à partir d'une carte raster "
-"d'altitudes."
+msgstr "Créer une carte d'index topographique à partir d'une carte raster d'altitudes."
#: ../gui/wxpython/menustrings.py:390
msgid "TOPMODEL simulation"
@@ -6222,50 +5786,32 @@
msgstr "Paramètrage (requiert XTerm)"
#: ../gui/wxpython/menustrings.py:394
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
-msgstr ""
-"Outil interactif utiliser pour paramétrer l'échantillonnage et l'analyse qui "
-"sera utilisée par les autres programmes r.le ."
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
+msgstr "Outil interactif utiliser pour paramétrer l'échantillonnage et l'analyse qui sera utilisée par les autres programmes r.le ."
#: ../gui/wxpython/menustrings.py:395
msgid "Analyze landscape"
msgstr "Analyse de paysage"
#: ../gui/wxpython/menustrings.py:396
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
-msgstr ""
-"Contient un jeu de mesures des attributs, diversité, texture, juuxtaposition "
-"et angle."
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
+msgstr "Contient un jeu de mesures des attributs, diversité, texture, juuxtaposition et angle."
#: ../gui/wxpython/menustrings.py:397
msgid "Analyze patches"
msgstr "Analyser les parcelles"
#: ../gui/wxpython/menustrings.py:398
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
-"Calculer les attributs, taille de patch, taille intérieure, forme, dimension "
-"fractale, et périmètre d'un jeux de patchs dans un paysage."
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
+msgstr "Calculer les attributs, taille de patch, taille intérieure, forme, dimension fractale, et périmètre d'un jeux de patchs dans un paysage."
#: ../gui/wxpython/menustrings.py:399
msgid "Summary and display (requires XTerm)"
msgstr "Résumé et affichage (requiert XTerm)"
#: ../gui/wxpython/menustrings.py:400
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
-msgstr ""
-"Affiche les limites de chaque patch de r.le et montre comment la limite ets "
-"tracée, affiche les attributs, taille, périmètre, indice de forme pour "
-"chaque patch et enregistre les données dans un fichier de sortie."
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
+msgstr "Affiche les limites de chaque patch de r.le et montre comment la limite ets tracée, affiche les attributs, taille, périmètre, indice de forme pour chaque patch et enregistre les données dans un fichier de sortie."
#: ../gui/wxpython/menustrings.py:401
msgid "Landscape patch analysis"
@@ -6284,11 +5830,8 @@
msgstr "Densité du bord"
#: ../gui/wxpython/menustrings.py:405
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Calcule l'index de densité de bords d'une carte raster, à l'aide d'un "
-"algorithme des 4 voisins les plus proches."
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr "Calcule l'index de densité de bords d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:406
msgid "Contrast weighted edge density"
@@ -6296,21 +5839,15 @@
#: ../gui/wxpython/menustrings.py:407
msgid "Calculates contrast weighted edge density index on a raster map"
-msgstr ""
-"Calculer l'index de densité de bords pondérée par le contraste sur une carte "
-"raster"
+msgstr "Calculer l'index de densité de bords pondérée par le contraste sur une carte raster"
#: ../gui/wxpython/menustrings.py:408
msgid "Patch area mean"
msgstr "Surface moyenne des patch"
#: ../gui/wxpython/menustrings.py:409
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
-"Calculer l'index de taille moyenne de patch d'une carte raster, à l'aide "
-"d'un algorithme des 4 voisins les plus proches."
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
+msgstr "Calculer l'index de taille moyenne de patch d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:410
msgid "Patch area range"
@@ -6334,30 +5871,23 @@
#: ../gui/wxpython/menustrings.py:415
msgid "Calculates coefficient of variation of patch area on a raster map"
-msgstr ""
-"Calculer le coefficient de variation des taille de patch d'une carte raster."
+msgstr "Calculer le coefficient de variation des taille de patch d'une carte raster."
#: ../gui/wxpython/menustrings.py:416
msgid "Patch density"
msgstr "Module de densité"
#: ../gui/wxpython/menustrings.py:417
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Calculer l'index de densité de patch d'une carte raster, à l'aide d'un "
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr "Calculer l'index de densité de patch d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:418
msgid "Patch number"
msgstr "Module nombre"
#: ../gui/wxpython/menustrings.py:419
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
-"Calculer l'index du nombre de patch d'une carte raster, à l'aide d'un "
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr "Calculer l'index du nombre de patch d'une carte raster, à l'aide d'un algorithme des 4 voisins les plus proches."
#: ../gui/wxpython/menustrings.py:420
msgid "Dominance's diversity"
@@ -6404,42 +5934,24 @@
msgstr "Taux de propagation"
#: ../gui/wxpython/menustrings.py:432
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
-msgstr ""
-"Génère trois ou quatre couches raster montrant 1) la la vitesse de "
-"propagation de base (ROS), 2) la propagation maximale, 3) la direction dela "
-"propagation maximale, et en option 4) la distance potentielle maximale de "
-"propagation."
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
+msgstr "Génère trois ou quatre couches raster montrant 1) la la vitesse de propagation de base (ROS), 2) la propagation maximale, 3) la direction dela propagation maximale, et en option 4) la distance potentielle maximale de propagation."
#: ../gui/wxpython/menustrings.py:433
msgid "Least-cost spread paths"
msgstr "Propagation par chemins de moindre coût "
#: ../gui/wxpython/menustrings.py:434
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Trace de façon récursive le plus court chemin vers les cellules pour "
-"lequelles le coût cumulé est déterminé."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "Trace de façon récursive le plus court chemin vers les cellules pour lequelles le coût cumulé est déterminé."
#: ../gui/wxpython/menustrings.py:435
msgid "Anisotropic spread simulation"
msgstr "Simulation de diffusion anisotrope"
#: ../gui/wxpython/menustrings.py:436
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr ""
-"Simule une propagation elliptique anisotropique sur une fenêtre graphique et "
-"génère une couche raster du temps cumulé de propagation, à partir de couches "
-"raster contenant des taux (ROS), directions, et origine des propagations."
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
+msgstr "Simule une propagation elliptique anisotropique sur une fenêtre graphique et génère une couche raster du temps cumulé de propagation, à partir de couches raster contenant des taux (ROS), directions, et origine des propagations."
#: ../gui/wxpython/menustrings.py:437
msgid "Change category values and labels"
@@ -6458,12 +5970,8 @@
msgstr "Reclasser en fonction de la taille"
#: ../gui/wxpython/menustrings.py:441
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Reclasser une carte raster pour une taille supérieure ou égale à la taille "
-"spécifiée par l'utilisateur (en hectares)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Reclasser une carte raster pour une taille supérieure ou égale à la taille spécifiée par l'utilisateur (en hectares)."
#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:648
msgid "Reclassify"
@@ -6495,12 +6003,8 @@
msgstr "Recalculer l'échelle des valeurs par histogramme"
#: ../gui/wxpython/menustrings.py:449
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-"Rééchelonne l'histogramme sur l'étendue des valeurs de catégories de la "
-"couche raster."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr "Rééchelonne l'histogramme sur l'étendue des valeurs de catégories de la couche raster."
#: ../gui/wxpython/menustrings.py:450
msgid "Generate random cells"
@@ -6512,20 +6016,15 @@
#: ../gui/wxpython/menustrings.py:452
msgid "Generates random cell values with spatial dependence."
-msgstr ""
-"Génère des valeurs de cellules aléatoires avec une dépendance spatiale."
+msgstr "Génère des valeurs de cellules aléatoires avec une dépendance spatiale."
#: ../gui/wxpython/menustrings.py:453
msgid "Random cells and vector points"
msgstr "Cellules aléatoires et points vectoriels"
#: ../gui/wxpython/menustrings.py:454
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Créer une carte raster ou une carte vectorielle de points contenant des "
-"points dispersés de manière aléatoire."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Créer une carte raster ou une carte vectorielle de points contenant des points dispersés de manière aléatoire."
#: ../gui/wxpython/menustrings.py:455
msgid "Generate surfaces"
@@ -6544,48 +6043,29 @@
msgstr "Surface avec un noyau de densité gaussienne"
#: ../gui/wxpython/menustrings.py:459
-msgid ""
-"Generates a raster density map from vector point data using a moving kernel "
-"or optionally generates a vector density map on a vector network."
-msgstr ""
-"Génère une carte raster de densité à partir de données vecteurs points en "
-"utilisant un noyau mouvant et optionnellement génère une carte de densité "
-"sur un réseau vectoriel."
+msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
+msgstr "Génère une carte raster de densité à partir de données vecteurs points en utilisant un noyau mouvant et optionnellement génère une carte de densité sur un réseau vectoriel."
#: ../gui/wxpython/menustrings.py:460
msgid "Gaussian deviates surface"
msgstr "Déviance gaussienne de surface"
#: ../gui/wxpython/menustrings.py:461
-msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
-msgstr ""
-"Produit une carte raster d'écarts gaussiens où la moyenne et l'écart-type "
-"peuvent être définis par l'utilisateur. Utilise un générateur de nombre "
-"aléatoire gaussien."
+msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
+msgstr "Produit une carte raster d'écarts gaussiens où la moyenne et l'écart-type peuvent être définis par l'utilisateur. Utilise un générateur de nombre aléatoire gaussien."
# Dip traduit ici pendage, en référence à la terminologie des géologues.
#: ../gui/wxpython/menustrings.py:463
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Crée une carte raster plane définie par un pendage (inclinaison), une "
-"orientation (azimuth) et un point."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr "Crée une carte raster plane définie par un pendage (inclinaison), une orientation (azimuth) et un point."
#: ../gui/wxpython/menustrings.py:464
msgid "Random deviates surface"
msgstr "Déviance aléatoire de surface"
#: ../gui/wxpython/menustrings.py:465
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
-msgstr ""
-"Produit une couche raster de données aléatoires uniformément réparties dans "
-"un gamme donnée par l'utilisateur."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
+msgstr "Produit une couche raster de données aléatoires uniformément réparties dans un gamme donnée par l'utilisateur."
#: ../gui/wxpython/menustrings.py:466
msgid "Random surface with spatial dependence"
@@ -6613,8 +6093,7 @@
#: ../gui/wxpython/menustrings.py:472
msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr ""
-"Interpolation spline bicubique ou bilinéaire avec régularisation de Tykhonov."
+msgstr "Interpolation spline bicubique ou bilinéaire avec régularisation de Tykhonov."
#: ../gui/wxpython/menustrings.py:473
msgid "IDW from raster points"
@@ -6626,8 +6105,7 @@
#: ../gui/wxpython/menustrings.py:475
msgid "IDW from raster points (alternate method for sparse points)"
-msgstr ""
-"IDW depuis des points raster (méthode alternative pour points clairsemés)"
+msgstr "IDW depuis des points raster (méthode alternative pour points clairsemés)"
#: ../gui/wxpython/menustrings.py:476
msgid "Surface generation program."
@@ -6638,12 +6116,8 @@
msgstr "IDW de points vecteur"
#: ../gui/wxpython/menustrings.py:478
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
-"Interpolation de surface à partir de données vecteur point par pondération "
-"de la distance inverse au carré (IDSW)."
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Interpolation de surface à partir de données vecteur point par pondération de la distance inverse au carré (IDSW)."
#: ../gui/wxpython/menustrings.py:479
msgid "Raster contours"
@@ -6658,14 +6132,8 @@
msgstr "Splines régulées avec tension"
#: ../gui/wxpython/menustrings.py:482
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
-msgstr ""
-"Approximation spatiale et analyse topographique depuis des données points ou "
-"isolines au format vecteur vers un raster en nombre flottants, en utilisant "
-"des splines régulées avec tension."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr "Approximation spatiale et analyse topographique depuis des données points ou isolines au format vecteur vers un raster en nombre flottants, en utilisant des splines régulées avec tension."
#: ../gui/wxpython/menustrings.py:483
msgid "Ordinary or block kriging"
@@ -6681,8 +6149,7 @@
#: ../gui/wxpython/menustrings.py:486
msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-"Remplir les zones sans données de la carte raster par interpolation spline."
+msgstr "Remplir les zones sans données de la carte raster par interpolation spline."
#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:764
msgid "Report and statistics"
@@ -6701,12 +6168,8 @@
msgstr "Gérer les informations de catégories"
#: ../gui/wxpython/menustrings.py:491
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
-msgstr ""
-"Gérer les valeurs de catégories et les étiquettes associées aux cartes "
-"raster spécifiées."
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr "Gérer les valeurs de catégories et les étiquettes associées aux cartes raster spécifiées."
#: ../gui/wxpython/menustrings.py:492
msgid "General statistics"
@@ -6730,8 +6193,7 @@
#: ../gui/wxpython/menustrings.py:497
msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-"Afficher la liste des valeurs de catégories trouvées dans une carte raster."
+msgstr "Afficher la liste des valeurs de catégories trouvées dans une carte raster."
#: ../gui/wxpython/menustrings.py:498
msgid "Sum category values"
@@ -6755,12 +6217,8 @@
msgstr "Statistiques pour des amas de cellules"
#: ../gui/wxpython/menustrings.py:503
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
-msgstr ""
-"Calcul le volume de données en amas et produit (en option) une couche "
-"vectorielle de points contenant les centroïdes de ces amas."
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Calcul le volume de données en amas et produit (en option) une couche vectorielle de points contenant les centroïdes de ces amas."
#: ../gui/wxpython/menustrings.py:504
msgid "Total corrected area"
@@ -6771,11 +6229,8 @@
msgstr "Estimation des surfaces pour les rasters."
#: ../gui/wxpython/menustrings.py:507
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
-msgstr ""
-"Calculer les statistiques univariées pour les cellules non nulles de la "
-"carte raster."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
+msgstr "Calculer les statistiques univariées pour les cellules non nulles de la carte raster."
#: ../gui/wxpython/menustrings.py:508
msgid "Sample transects"
@@ -6783,29 +6238,22 @@
#: ../gui/wxpython/menustrings.py:509
msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Affiche en sortie les valeurs de carte raster suivant une(des) ligne(s) "
-"définie(s) par l'utilisateur."
+msgstr "Affiche en sortie les valeurs de carte raster suivant une(des) ligne(s) définie(s) par l'utilisateur."
#: ../gui/wxpython/menustrings.py:510
msgid "Sample transects (bearing/distance)"
msgstr "Exemple de transects (parcours/distance)"
#: ../gui/wxpython/menustrings.py:511
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-"Affiche en sortie les valeurs de carte raster suivant un(des) transect(s) "
-"défini(s) par l'utilisateur."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgstr "Affiche en sortie les valeurs de carte raster suivant un(des) transect(s) défini(s) par l'utilisateur."
#: ../gui/wxpython/menustrings.py:512
msgid "Covariance/correlation"
msgstr "Covariance/corrélation"
#: ../gui/wxpython/menustrings.py:513
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
msgstr "Sortir la matrice de covariance/corrélation pour des"
#: ../gui/wxpython/menustrings.py:514
@@ -6814,19 +6262,15 @@
#: ../gui/wxpython/menustrings.py:515
msgid "Calculates linear regression from two raster maps: y = a + b*x."
-msgstr ""
-"Calcule une régression linéaire depuis deux cartes raster : y = a + b*x."
+msgstr "Calcule une régression linéaire depuis deux cartes raster : y = a + b*x."
#: ../gui/wxpython/menustrings.py:516
msgid "Mutual category occurrences"
msgstr "Occurences mutelles de catégories"
#: ../gui/wxpython/menustrings.py:517
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr ""
-"Tabuler les occurences mutuelles (coincidence) des catégories de deux rasters"
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgstr "Tabuler les occurences mutuelles (coincidence) des catégories de deux rasters"
#: ../gui/wxpython/menustrings.py:518
msgid "&Vector"
@@ -6853,12 +6297,8 @@
msgstr "Éditer une carte vecteur (de façon non interactive)"
#: ../gui/wxpython/menustrings.py:525
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-"Édite une carte vecteur, permet d'ajouter, supprimer et modifier les objets "
-"vectoriels sélectionnés."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr "Édite une carte vecteur, permet d'ajouter, supprimer et modifier les objets vectoriels sélectionnés."
#: ../gui/wxpython/menustrings.py:526
msgid "Convert object types"
@@ -6882,12 +6322,8 @@
msgstr "Fusionner des contours"
#: ../gui/wxpython/menustrings.py:531
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Fusionne des contours entre surfaces adjacentes partageant un attribut ou "
-"une catégorie commun(e)."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Fusionne des contours entre surfaces adjacentes partageant un attribut ou une catégorie commun(e)."
#: ../gui/wxpython/menustrings.py:532
msgid "Create 3D vector over raster"
@@ -6895,9 +6331,7 @@
#: ../gui/wxpython/menustrings.py:533
msgid "Converts vector map to 3D by sampling of elevation raster map."
-msgstr ""
-"Convertit une carte vecteur en 3D par échantillonnage d'altitude d'une carte "
-"raster."
+msgstr "Convertit une carte vecteur en 3D par échantillonnage d'altitude d'une carte raster."
#: ../gui/wxpython/menustrings.py:534
msgid "Extrude 3D vector map"
@@ -6921,21 +6355,15 @@
#: ../gui/wxpython/menustrings.py:539
msgid "Create optimally placed labels for vector map(s)"
-msgstr ""
-"Créer des étiquettes placées de manière optimale pour une(des) carte(s) "
-"vecteur"
+msgstr "Créer des étiquettes placées de manière optimale pour une(des) carte(s) vecteur"
#: ../gui/wxpython/menustrings.py:540
msgid "Reposition vector map"
msgstr "Repositionner une carte vecteur"
#: ../gui/wxpython/menustrings.py:541
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
-msgstr ""
-"Réalise une transformation affine (translation, échelle et rotation, ou "
-"points d'amer) de carte vecteur."
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
+msgstr "Réalise une transformation affine (translation, échelle et rotation, ou points d'amer) de carte vecteur."
#: ../gui/wxpython/menustrings.py:542
msgid "Reproject vector map"
@@ -6943,8 +6371,7 @@
#: ../gui/wxpython/menustrings.py:543
msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-"Re-projette une carte vecteur depuis un secteur dans le secteur courant."
+msgstr "Re-projette une carte vecteur depuis un secteur dans le secteur courant."
#: ../gui/wxpython/menustrings.py:545
msgid "Updates vector map metadata."
@@ -6968,9 +6395,7 @@
#: ../gui/wxpython/menustrings.py:550
msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr ""
-"Reconstruire la topologie de toutes les cartes vectorielles dans le jeux de "
-"cartes courant."
+msgstr "Reconstruire la topologie de toutes les cartes vectorielles dans le jeux de cartes courant."
#: ../gui/wxpython/menustrings.py:551
msgid "Build polylines"
@@ -6994,9 +6419,7 @@
#: ../gui/wxpython/menustrings.py:556
msgid "Creates points/segments from input vector lines and positions."
-msgstr ""
-"Crée des points/segments à partir de lignes vectorielles et positions en "
-"entrée."
+msgstr "Crée des points/segments à partir de lignes vectorielles et positions en entrée."
#: ../gui/wxpython/menustrings.py:557
msgid "Clean vector map"
@@ -7023,11 +6446,8 @@
msgstr "Ajoute les centroïdes manquants aux contours fermés."
#: ../gui/wxpython/menustrings.py:565
-msgid ""
-"Set color rules for features in a vector using a numeric attribute column."
-msgstr ""
-"Fixe les règles de coloration pour les objets d'une carte vecteur via une "
-"colonne attributaire numérique."
+msgid "Set color rules for features in a vector using a numeric attribute column."
+msgstr "Fixe les règles de coloration pour les objets d'une carte vecteur via une colonne attributaire numérique."
#: ../gui/wxpython/menustrings.py:567
msgid "Interactive management of vector color tables."
@@ -7062,34 +6482,24 @@
msgstr "Sélection par attribut"
#: ../gui/wxpython/menustrings.py:575
-msgid ""
-"Selects vector objects from an existing vector map and creates a new map "
-"containing only the selected objects."
-msgstr ""
-"Sélectionner les objets vectoriels d'une carte raster existante et créer une "
-"nouvelle carte contenant seulement ces objets sélectionnés."
+msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
+msgstr "Sélectionner les objets vectoriels d'une carte raster existante et créer une nouvelle carte contenant seulement ces objets sélectionnés."
#: ../gui/wxpython/menustrings.py:576
msgid "Spatial query"
msgstr "Requête spatiale"
#: ../gui/wxpython/menustrings.py:577
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-"Sélectionne des objets d'une carte vecteur (A) par des objets d'une autre "
-"carte vecteur (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr "Sélectionne des objets d'une carte vecteur (A) par des objets d'une autre carte vecteur (B)."
#: ../gui/wxpython/menustrings.py:587
msgid "Buffer vectors"
msgstr "Vecteurs tampons"
#: ../gui/wxpython/menustrings.py:588
-msgid ""
-"Creates a buffer around features of given type (areas must contain centroid)."
-msgstr ""
-"Crée un tampon autour d'objet d'un type donné (les surfaces doivent contenir "
-"un centroïde)."
+msgid "Creates a buffer around features of given type (areas must contain centroid)."
+msgstr "Crée un tampon autour d'objet d'un type donné (les surfaces doivent contenir un centroïde)."
#: ../gui/wxpython/menustrings.py:589
msgid "Lidar analysis"
@@ -7108,24 +6518,16 @@
msgstr "Détecter intérieurs"
#: ../gui/wxpython/menustrings.py:593
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
-msgstr ""
-"Détermination des contours de bâtiments et algorithme d'agrandissement de la "
-"région pour déterminer les bâtiments à l'intérieur"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
+msgstr "Détermination des contours de bâtiments et algorithme d'agrandissement de la région pour déterminer les bâtiments à l'intérieur"
#: ../gui/wxpython/menustrings.py:594
msgid "Correct and reclassify objects"
msgstr "Corriger et classifier les objets"
#: ../gui/wxpython/menustrings.py:595
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
-msgstr ""
-"Correction de la sortie de v.lidar.growing. Il s'agit du dernier des trois "
-"algorithms pour le filtrage LIDAR."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
+msgstr "Correction de la sortie de v.lidar.growing. Il s'agit du dernier des trois algorithms pour le filtrage LIDAR."
#: ../gui/wxpython/menustrings.py:596
msgid "Linear referencing"
@@ -7145,45 +6547,31 @@
#: ../gui/wxpython/menustrings.py:600
msgid "Creates stationing from input lines, and linear reference system"
-msgstr ""
-"Créer des placement à partir de lignes, et d'un système de référence linéaire"
+msgstr "Créer des placement à partir de lignes, et d'un système de référence linéaire"
#: ../gui/wxpython/menustrings.py:601
msgid "Create points/segments"
msgstr "Créer points/segments"
#: ../gui/wxpython/menustrings.py:602
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-"Créer des points/segments à partir des lignes en entrée, un système de "
-"référence linéaire et des positions lues depuis l'entrée standard ou un "
-"fichier."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr "Créer des points/segments à partir des lignes en entrée, un système de référence linéaire et des positions lues depuis l'entrée standard ou un fichier."
#: ../gui/wxpython/menustrings.py:603
msgid "Find line id and offset"
msgstr "Trouver l'id de ligne et le décalage"
#: ../gui/wxpython/menustrings.py:604
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
-msgstr ""
-"Trouvez l'id de ligne et le km réel pour les points donnés de la carte "
-"vectorielle en utilisant un système de référence linéaire"
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
+msgstr "Trouvez l'id de ligne et le km réel pour les points donnés de la carte vectorielle en utilisant un système de référence linéaire"
#: ../gui/wxpython/menustrings.py:605
msgid "Nearest features"
msgstr "Objets les plus proches"
#: ../gui/wxpython/menustrings.py:606
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-"Trouve l'élément de la carte \"vers\" le plus proche des éléments de la "
-"carte \"depuis\"."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr "Trouve l'élément de la carte \"vers\" le plus proche des éléments de la carte \"depuis\"."
#: ../gui/wxpython/menustrings.py:607
msgid "Network analysis"
@@ -7203,9 +6591,7 @@
#: ../gui/wxpython/menustrings.py:611
msgid "Allocate subnets for nearest centres (direction from centre)."
-msgstr ""
-"Allouer des sous-réseaux pour les centres les plus proches (direction depuis "
-"le centre)."
+msgstr "Allouer des sous-réseaux pour les centres les plus proches (direction depuis le centre)."
#: ../gui/wxpython/menustrings.py:612
msgid "Split net"
@@ -7228,11 +6614,8 @@
msgstr "Plus court chemin pour un jeu d'objets"
#: ../gui/wxpython/menustrings.py:617
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
-msgstr ""
-"Calcule la plus courte distance via le réseau entre les jeux d'objets donnés."
+msgid "Computes shortest distance via the network between the given sets of features."
+msgstr "Calcule la plus courte distance via le réseau entre les jeux d'objets donnés."
#: ../gui/wxpython/menustrings.py:618
msgid "Shortest path using timetables"
@@ -7248,8 +6631,7 @@
#: ../gui/wxpython/menustrings.py:621
msgid "Computes the shortest path between all pairs of nodes in the network."
-msgstr ""
-"Calcule le plus court chemin entre toutes les paires de nœuds du réseau."
+msgstr "Calcule le plus court chemin entre toutes les paires de nœuds du réseau."
#: ../gui/wxpython/menustrings.py:622
msgid "Visibility network"
@@ -7281,8 +6663,7 @@
#: ../gui/wxpython/menustrings.py:629
msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr ""
-"Calcule la connectivité des sommets entre deux jeux de noeuds d'un réseau."
+msgstr "Calcule la connectivité des sommets entre deux jeux de noeuds d'un réseau."
#: ../gui/wxpython/menustrings.py:630
msgid "Components"
@@ -7297,12 +6678,8 @@
msgstr "Centralité"
#: ../gui/wxpython/menustrings.py:633
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
-msgstr ""
-"Calcule les degré, centralité, intermédiarité, proximité et vecteur propre "
-"des mesures de centralité d'un réseau."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
+msgstr "Calcule les degré, centralité, intermédiarité, proximité et vecteur propre des mesures de centralité d'un réseau."
#: ../gui/wxpython/menustrings.py:634
msgid "Steiner tree"
@@ -7326,9 +6703,7 @@
#: ../gui/wxpython/menustrings.py:639
msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
-"Créer un cycle connectant les noeud donnés (problème du voyageur de "
-"commerce)."
+msgstr "Créer un cycle connectant les noeud donnés (problème du voyageur de commerce)."
#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:641
msgid "Overlay vector maps"
@@ -7344,9 +6719,7 @@
#: ../gui/wxpython/menustrings.py:644
msgid "Create a new vector map layer by combining other vector map layers."
-msgstr ""
-"Créer une nouvelle carte vecteur en combinant d'autres couches de cartes "
-"vecteur."
+msgstr "Créer une nouvelle carte vecteur en combinant d'autres couches de cartes vecteur."
#: ../gui/wxpython/menustrings.py:645
msgid "Change attributes"
@@ -7358,31 +6731,19 @@
#: ../gui/wxpython/menustrings.py:647
msgid "Attach, delete or report vector categories to map geometry."
-msgstr ""
-"Attache, supprime ou rend compte de catégories à la géométrie de carte "
-"vecteur."
+msgstr "Attache, supprime ou rend compte de catégories à la géométrie de carte vecteur."
#: ../gui/wxpython/menustrings.py:649
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"Change les valeurs de catégorie pour une carte vecteur existante en fonction "
-"des résultats de requêtes SQL ou d'un valeur dans une colonne de table "
-"attributaire."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr "Change les valeurs de catégorie pour une carte vecteur existante en fonction des résultats de requêtes SQL ou d'un valeur dans une colonne de table attributaire."
#: ../gui/wxpython/menustrings.py:651
msgid "Update area attributes from raster"
msgstr "Mise à jour des attributs surfaciques à partir d'une carte raster"
#: ../gui/wxpython/menustrings.py:652
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygons "
-"and uploads statistics to new attribute columns."
-msgstr ""
-"Calculer les statistiques univariées d'une carte raster, basé sur des "
-"polygones vectoriels et ajouter les statistiques dans des nouvelles colonnes "
-"attributaires."
+msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
+msgstr "Calculer les statistiques univariées d'une carte raster, basé sur des polygones vectoriels et ajouter les statistiques dans des nouvelles colonnes attributaires."
#: ../gui/wxpython/menustrings.py:653
msgid "Update point attributes from areas"
@@ -7390,9 +6751,7 @@
#: ../gui/wxpython/menustrings.py:654
msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-"Ajouter dans la table les valeurs de vecteur à la position des points du "
-"vecteur."
+msgstr "Ajouter dans la table les valeurs de vecteur à la position des points du vecteur."
#: ../gui/wxpython/menustrings.py:655
msgid "Update database values from vector"
@@ -7408,9 +6767,7 @@
#: ../gui/wxpython/menustrings.py:658
msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-"Ajouter dans la table les valeurs de raster à la position des points du "
-"vecteur."
+msgstr "Ajouter dans la table les valeurs de raster à la position des points du vecteur."
#: ../gui/wxpython/menustrings.py:659
msgid "Sample raster neighborhood around points"
@@ -7418,8 +6775,7 @@
#: ../gui/wxpython/menustrings.py:660
msgid "Samples a raster map at vector point locations."
-msgstr ""
-"Échantillonne une carte raster au droit des points d'une carte vecteur."
+msgstr "Échantillonne une carte raster au droit des points d'une carte vecteur."
#: ../gui/wxpython/menustrings.py:661
msgid "Generate area for current region"
@@ -7446,24 +6802,16 @@
msgstr "Triangles de Delaunay"
#: ../gui/wxpython/menustrings.py:667
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"Crée une triangulation de Delaunay à partir d'une carte vecteur contenant "
-"des points ou centroïdes."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr "Crée une triangulation de Delaunay à partir d'une carte vecteur contenant des points ou centroïdes."
#: ../gui/wxpython/menustrings.py:668
msgid "Voronoi diagram/Thiessen polygons"
msgstr "Diagramme de Voronoï/polygones de Thiessen"
#: ../gui/wxpython/menustrings.py:669
-msgid ""
-"Creates a Voronoi diagram from an input vector map containing points or "
-"centroids."
-msgstr ""
-"Crée un diagramme de Voronoï à partir d'une carte vecteur contenant des "
-"points ou centroïdes."
+msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+msgstr "Crée un diagramme de Voronoï à partir d'une carte vecteur contenant des points ou centroïdes."
#: ../gui/wxpython/menustrings.py:670
msgid "Generate grid"
@@ -7482,11 +6830,8 @@
msgstr "Générer à partir d'une base de données"
#: ../gui/wxpython/menustrings.py:674
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"Crée une nouvelle carte vecteur (points) à partir d'une table de base de "
-"données contenant des coordonnées."
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr "Crée une nouvelle carte vecteur (points) à partir d'une table de base de données contenant des coordonnées."
#: ../gui/wxpython/menustrings.py:675
msgid "Generate points along lines"
@@ -7494,9 +6839,7 @@
#: ../gui/wxpython/menustrings.py:676
msgid "Create points along input lines in new vector with 2 layers."
-msgstr ""
-"Créer des points le long de lignes dans une nouvelle carte vecteur à deux "
-"couches."
+msgstr "Créer des points le long de lignes dans une nouvelle carte vecteur à deux couches."
#: ../gui/wxpython/menustrings.py:677
msgid "Generate random points"
@@ -7512,8 +6855,7 @@
#: ../gui/wxpython/menustrings.py:680
msgid "Random location perturbations of GRASS vector points"
-msgstr ""
-"Modifie de manière aléatoire la position des points dans un fichier vectoriel"
+msgstr "Modifie de manière aléatoire la position des points dans un fichier vectoriel"
#: ../gui/wxpython/menustrings.py:681
msgid "Remove outliers in point sets"
@@ -7549,9 +6891,7 @@
#: ../gui/wxpython/menustrings.py:689
msgid "Classifies attribute data, e.g. for thematic mapping"
-msgstr ""
-"Classifier les données attributaires, par exemple pour une cartographie "
-"thématique"
+msgstr "Classifier les données attributaires, par exemple pour une cartographie thématique"
#: ../gui/wxpython/menustrings.py:690
msgid "Report topology by category"
@@ -7566,21 +6906,15 @@
msgstr "Statistiques univariées pour des points"
#: ../gui/wxpython/menustrings.py:693
-msgid ""
-"Calculates univariate statistics for attribute. Variance and standard "
-"deviation is calculated only for points if specified."
-msgstr ""
-"Calcule les statistiques univariées pour les attributs. La variance et "
-"l'écart-type sont calculés uniquement pour les points."
+msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
+msgstr "Calcule les statistiques univariées pour les attributs. La variance et l'écart-type sont calculés uniquement pour les points."
#: ../gui/wxpython/menustrings.py:694
msgid "Univariate statistics for attribute columns"
msgstr "Statistiques univariées pour les colonnes d'attributs"
#: ../gui/wxpython/menustrings.py:695
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
msgstr "Calcule les statistiques univariées sur la colonne sélectionnée."
#: ../gui/wxpython/menustrings.py:696
@@ -7631,9 +6965,7 @@
#: ../gui/wxpython/menustrings.py:707
#, fuzzy
msgid "Mosaics up to four images, extending the color table."
-msgstr ""
-"Créer une mosaïque jusqu'à 4 images et étend la table de couleurs; créer une "
-"carte *.mosaic"
+msgstr "Créer une mosaïque jusqu'à 4 images et étend la table de couleurs; créer une carte *.mosaic"
#: ../gui/wxpython/menustrings.py:708
msgid "Manage image colors"
@@ -7652,32 +6984,20 @@
msgstr "TSV vers RVB"
#: ../gui/wxpython/menustrings.py:712
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
-msgstr ""
-"Transforme une carte raster de l'espace colorimétrique TSV (Teinte-"
-"Saturation-Valeur) vers l'espace colorimétrique RVB (Rouge-Vert-Bleu)."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
+msgstr "Transforme une carte raster de l'espace colorimétrique TSV (Teinte-Saturation-Valeur) vers l'espace colorimétrique RVB (Rouge-Vert-Bleu)."
#: ../gui/wxpython/menustrings.py:714
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
-msgstr ""
-"Transforme une carte raster de l'espace colorimétrique RVB (Rouge-Vert-Bleu) "
-"vers l'espace colorimétrique TSV (Teinte-Saturation-Valeur)."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
+msgstr "Transforme une carte raster de l'espace colorimétrique RVB (Rouge-Vert-Bleu) vers l'espace colorimétrique TSV (Teinte-Saturation-Valeur)."
#: ../gui/wxpython/menustrings.py:715
msgid "Rectify image or raster"
msgstr "Rectifier une image ou une carte raster"
#: ../gui/wxpython/menustrings.py:716
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-"Redresse une image en calculant une transformation de coordonnées pour "
-"chaque pixel de l'image basée sur des points de contrôle."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr "Redresse une image en calculant une transformation de coordonnées pour chaque pixel de l'image basée sur des points de contrôle."
#: ../gui/wxpython/menustrings.py:718
msgid "Generate histogram of image"
@@ -7688,22 +7008,16 @@
msgstr "Réponse spectrale"
#: ../gui/wxpython/menustrings.py:720
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-"Affiche la réponse spectrale d'une position données pour un groupe ou une "
-"image."
+msgid "Displays spectral response at user specified locations in group or images."
+msgstr "Affiche la réponse spectrale d'une position données pour un groupe ou une image."
#: ../gui/wxpython/menustrings.py:721
msgid "Brovey sharpening"
msgstr "Transformée de Brovey"
#: ../gui/wxpython/menustrings.py:722
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr ""
-"Transformation de Brovey pour fusionner des canaux multispectraux et "
-"panchromatique haute résolution."
+msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr "Transformation de Brovey pour fusionner des canaux multispectraux et panchromatique haute résolution."
#: ../gui/wxpython/menustrings.py:723
msgid "Classify image"
@@ -7714,12 +7028,8 @@
msgstr "Regroupement pour classification non-supervisée"
#: ../gui/wxpython/menustrings.py:725
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
-msgstr ""
-"Générer les signatures spectrales pour l'occupation des sols dans une image, "
-"à l'aide d'un algorithme de regroupement."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
+msgstr "Générer les signatures spectrales pour l'occupation des sols dans une image, à l'aide d'un algorithme de regroupement."
#: ../gui/wxpython/menustrings.py:726
msgid "Input for supervised MLC"
@@ -7742,12 +7052,8 @@
msgstr "Entrée interactive pour une classification supervisée (requiert Xterm)"
#: ../gui/wxpython/menustrings.py:731
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
-msgstr ""
-"Générer les signatures spectrales d'une image en permettant à l'utilisateur "
-"de décrire les régions d'intérêt."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
+msgstr "Générer les signatures spectrales d'une image en permettant à l'utilisateur de décrire les régions d'intérêt."
#: ../gui/wxpython/menustrings.py:732
msgid "Input for supervised SMAP"
@@ -7762,12 +7068,8 @@
msgstr "Classification par le maximum séquentiel à postériori (SMAP)"
#: ../gui/wxpython/menustrings.py:735
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
-"Effectue une classification d'image contextuelle, en utilisant l'estimation "
-"du maximum séquentiel à postériori (SMAP)."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
+msgstr "Effectue une classification d'image contextuelle, en utilisant l'estimation du maximum séquentiel à postériori (SMAP)."
#: ../gui/wxpython/menustrings.py:736
msgid "Filter image"
@@ -7779,9 +7081,7 @@
#: ../gui/wxpython/menustrings.py:738
msgid "Zero-crossing \"edge detection\" raster function for image processing."
-msgstr ""
-"Fonction raster de \"détection des bords\" sans croisement pour l'analyse "
-"d'images."
+msgstr "Fonction raster de \"détection des bords\" sans croisement pour l'analyse d'images."
#: ../gui/wxpython/menustrings.py:739
msgid "Matrix/convolving filter"
@@ -7836,12 +7136,8 @@
msgstr "Valeur numérique Landsat vers radiance/réflectance."
#: ../gui/wxpython/menustrings.py:752
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+."
-msgstr ""
-"Calculer la radiance ou la réflectance \"top-of-atmosphere\" et la "
-"température pour les images Landsat MSS/TM/ETM+."
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
+msgstr "Calculer la radiance ou la réflectance \"top-of-atmosphere\" et la température pour les images Landsat MSS/TM/ETM+."
#: ../gui/wxpython/menustrings.py:753
msgid "Landsat cloud cover assessment"
@@ -7849,9 +7145,7 @@
#: ../gui/wxpython/menustrings.py:754
msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr ""
-"Effecture une évaluation automatique de la couverture nuageuse (ACCA) pour "
-"Landsat TM/ETM+."
+msgstr "Effecture une évaluation automatique de la couverture nuageuse (ACCA) pour Landsat TM/ETM+."
#: ../gui/wxpython/menustrings.py:755
msgid "Modis quality control"
@@ -7887,8 +7181,7 @@
#: ../gui/wxpython/menustrings.py:763
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr ""
-"Transformation de Tasseled cap (Kauth Thomas) pour les données LANDSAT-TM"
+msgstr "Transformation de Tasseled cap (Kauth Thomas) pour les données LANDSAT-TM"
#: ../gui/wxpython/menustrings.py:765
msgid "Bit pattern comparison "
@@ -7903,12 +7196,8 @@
msgstr "Analyse Kappa"
#: ../gui/wxpython/menustrings.py:768
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"Calcule la matrice de confusion et les paramètres kappa pour l'évaluation "
-"de l'exactitude des résultats de classification."
+msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr "Calcule la matrice de confusion et les paramètres kappa pour l'évaluation de l'exactitude des résultats de classification."
#: ../gui/wxpython/menustrings.py:769
msgid "OIF for LandSat TM"
@@ -7916,9 +7205,7 @@
#: ../gui/wxpython/menustrings.py:770
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
-"Calcule la table de facteur d'index optimal pour les bandes 1-5 et 7 de "
-"Landsat TM."
+msgstr "Calcule la table de facteur d'index optimal pour les bandes 1-5 et 7 de Landsat TM."
#: ../gui/wxpython/menustrings.py:771
msgid "V&olumes"
@@ -7965,32 +7252,20 @@
msgstr "Coupe transversale"
#: ../gui/wxpython/menustrings.py:785
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map."
-msgstr ""
-"Créer une carte raster 2D de coupe transversale depuis une carte raster 3D, "
-"basée sur une carte d'altitudes en 2D."
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
+msgstr "Créer une carte raster 2D de coupe transversale depuis une carte raster 3D, basée sur une carte d'altitudes en 2D."
#: ../gui/wxpython/menustrings.py:787
-msgid ""
-"Calculates numerically transient, confined groundwater flow in three "
-"dimensions."
-msgstr ""
-"Calcul numérique des flux d'eaux souterraines transitoire et confinées, en "
-"trois dimensions."
+msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
+msgstr "Calcul numérique des flux d'eaux souterraines transitoire et confinées, en trois dimensions."
#: ../gui/wxpython/menustrings.py:788
msgid "Interpolate volume from points"
msgstr "Interpoler un volume depuis des points."
#: ../gui/wxpython/menustrings.py:789
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
-msgstr ""
-"Interpoler des données points vers une carte raster 3D, en utilisant "
-"l'algorithme des splines régulées avec tension (RST)."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
+msgstr "Interpoler des données points vers une carte raster 3D, en utilisant l'algorithme des splines régulées avec tension (RST)."
#: ../gui/wxpython/menustrings.py:790
msgid "Report and Statistics"
@@ -8017,12 +7292,8 @@
msgstr "Statistiques univariées pour les volumes"
#: ../gui/wxpython/menustrings.py:796
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
-msgstr ""
-"Calculer les statistiques univariées pour les valeurs 3D non-nulles d'une "
-"carte raster 3D."
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
+msgstr "Calculer les statistiques univariées pour les valeurs 3D non-nulles d'une carte raster 3D."
#: ../gui/wxpython/menustrings.py:797
msgid "&Database"
@@ -8074,9 +7345,7 @@
#: ../gui/wxpython/menustrings.py:809
msgid "Prints/sets general DB connection for current mapset and exits."
-msgstr ""
-"Afficher/définir les connexions base de données pour le jeux de carte actuel "
-"puis quitter."
+msgstr "Afficher/définir les connexions base de données pour le jeux de carte actuel puis quitter."
#: ../gui/wxpython/menustrings.py:810
msgid "Login"
@@ -8116,9 +7385,7 @@
#: ../gui/wxpython/menustrings.py:819
msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Tester un pilote de base de données ; la base doit exister et être connectée "
-"via db.connect"
+msgstr "Tester un pilote de base de données ; la base doit exister et être connectée via db.connect"
#: ../gui/wxpython/menustrings.py:821
msgid "Query any table"
@@ -8126,9 +7393,7 @@
#: ../gui/wxpython/menustrings.py:822
msgid "Selects data from attribute table (performs SQL query statement(s))."
-msgstr ""
-"Sélectionne des données d'une table attributaire (exécute des expressions "
-"SQL)."
+msgstr "Sélectionne des données d'une table attributaire (exécute des expressions SQL)."
#: ../gui/wxpython/menustrings.py:825
msgid "SQL statement"
@@ -8147,12 +7412,8 @@
msgstr "Nouvelle table"
#: ../gui/wxpython/menustrings.py:829
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"Créée et connecte une table attributaire à une couche donnée d'une carte "
-"vecteur existante."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "Créée et connecte une table attributaire à une couche donnée d'une carte vecteur existante."
#: ../gui/wxpython/menustrings.py:830
msgid "Remove table"
@@ -8168,45 +7429,31 @@
#: ../gui/wxpython/menustrings.py:833
msgid "Allows to join a table to a vector map table."
-msgstr ""
-"Permet de joindre une table à la table attributaire d'une carte vecteur."
+msgstr "Permet de joindre une table à la table attributaire d'une carte vecteur."
#: ../gui/wxpython/menustrings.py:834
msgid "Add columns"
msgstr "Ajouter des colonnes"
#: ../gui/wxpython/menustrings.py:835
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Ajoute une ou des colonnes à la table attributaire connectée à une carte "
-"vecteur donnée."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "Ajoute une ou des colonnes à la table attributaire connectée à une carte vecteur donnée."
#: ../gui/wxpython/menustrings.py:837
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
-"Supprime une colonne d'une table attributaire connectée à une carte vecteur "
-"donnée."
+msgid "Drops a column from the attribute table connected to a given vector map."
+msgstr "Supprime une colonne d'une table attributaire connectée à une carte vecteur donnée."
#: ../gui/wxpython/menustrings.py:839
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Renomme une colonne dans une table attributaire connectée à une carte "
-"vecteur donnée."
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "Renomme une colonne dans une table attributaire connectée à une carte vecteur donnée."
#: ../gui/wxpython/menustrings.py:840
msgid "Change values"
msgstr "Changer les valeurs"
#: ../gui/wxpython/menustrings.py:841
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
-"Permet de mettre à jour une colonne dans une table attributaire connectée à "
-"une carte vecteur."
+msgid "Allows to update a column in the attribute table connected to a vector map."
+msgstr "Permet de mettre à jour une colonne dans une table attributaire connectée à une carte vecteur."
#: ../gui/wxpython/menustrings.py:842
msgid "Reconnect vectors to database"
@@ -8222,9 +7469,7 @@
#: ../gui/wxpython/menustrings.py:845
msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Afficher/définir les connexions base de données pour la table d'attributs de "
-"la carte vecteur."
+msgstr "Afficher/définir les connexions base de données pour la table d'attributs de la carte vecteur."
#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:898
msgid "&Help"
@@ -8411,9 +7656,7 @@
#: ../gui/wxpython/psmap/frame.py:232
msgid "Program ps2pdf is not available. Please install it first to create PDF."
-msgstr ""
-"Le programme ps2pdf n'est pas disponible. Merci de l'installer pour "
-"permettre la création de fichiers PDF."
+msgstr "Le programme ps2pdf n'est pas disponible. Merci de l'installer pour permettre la création de fichiers PDF."
#: ../gui/wxpython/psmap/frame.py:276
msgid "Generating PDF..."
@@ -8448,8 +7691,7 @@
"\n"
" %s"
msgstr ""
-"permettre la création de fichiers PDF.\n"
+"Le programme ps2pdf n'est pas disponible. Merci de l'installer pour permettre la création de fichiers PDF.\n"
"\n"
" %s"
@@ -8467,8 +7709,7 @@
#: ../gui/wxpython/psmap/frame.py:350
msgid "Preview is not available probably due to missing Ghostscript."
-msgstr ""
-"L'aperçu n'est pas disponible, probablement parce qu'il manque Ghostscript."
+msgstr "L'aperçu n'est pas disponible, probablement parce qu'il manque Ghostscript."
#: ../gui/wxpython/psmap/frame.py:352
msgid "Please follow instructions on GRASS Trac Wiki."
@@ -8514,13 +7755,8 @@
"\n"
#: ../gui/wxpython/psmap/frame.py:1058 ../gui/wxpython/gmodeler/frame.py:717
-msgid ""
-"This program is free software under the GNU General Public License(>=v2). "
-"Read the file COPYING that comes with GRASS for details."
-msgstr ""
-"Ce programme est un logiciel libre placé sous la licence GNU General Public "
-"License (>=v2). Lisez le fichier COPYING fourni avec GRASS pour plus de "
-"détails."
+msgid "This program is free software under the GNU General Public License(>=v2). Read the file COPYING that comes with GRASS for details."
+msgstr "Ce programme est un logiciel libre placé sous la licence GNU General Public License (>=v2). Lisez le fichier COPYING fourni avec GRASS pour plus de détails."
#: ../gui/wxpython/psmap/frame.py:1366
msgid "Click and drag to resize object"
@@ -8669,27 +7905,18 @@
#: ../gui/wxpython/psmap/instructions.py:811
#: ../gui/wxpython/psmap/instructions.py:1693
#, python-format
-msgid ""
-"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
-"which is required by module ps.map."
-msgstr ""
-"Les caractères en position %s ne sont pas pris en charge par l'encodage "
-"ISO-8859-1 (Latin 1) requis pour le module ps.map."
+msgid "Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
+msgstr "Les caractères en position %s ne sont pas pris en charge par l'encodage ISO-8859-1 (Latin 1) requis pour le module ps.map."
#: ../gui/wxpython/psmap/instructions.py:815
#: ../gui/wxpython/psmap/instructions.py:1697
-msgid ""
-"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
-"required by module ps.map."
-msgstr ""
-"Tous les caractères ne sont pas supportés par l'encodage ISO-8859-1 (Latin "
-"1) requis pour le module ps.map."
+msgid "Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
+msgstr "Tous les caractères ne sont pas supportés par l'encodage ISO-8859-1 (Latin 1) requis pour le module ps.map."
#: ../gui/wxpython/psmap/instructions.py:931
#, python-format
msgid "Failed to read instruction %(inst)s: file %(file)s not found."
-msgstr ""
-"Échec à la lecture de l'instruction %(inst)s : fichier %(file)s non trouvé."
+msgstr "Échec à la lecture de l'instruction %(inst)s : fichier %(file)s non trouvé."
#: ../gui/wxpython/psmap/toolbars.py:52
msgid "Generate text file with mapping instructions"
@@ -8808,7 +8035,6 @@
msgstr "La position est données :"
#: ../gui/wxpython/psmap/dialogs.py:221
-#, fuzzy
msgid "relative to paper"
msgstr "par rapport au papier"
@@ -9113,8 +8339,7 @@
#: ../gui/wxpython/psmap/dialogs.py:1675
msgid "Database connection is not defined in DB file."
-msgstr ""
-"La connexion à la base de données n'est pas définie dans le fichier DB."
+msgstr "La connexion à la base de données n'est pas définie dans le fichier DB."
#: ../gui/wxpython/psmap/dialogs.py:1676
msgid "Select layer:"
@@ -9186,8 +8411,7 @@
#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
msgid "Type filename or click browse to choose file"
-msgstr ""
-"Taper un nom de fichier ou cliquer sur Parcourir pour choisir un fichier"
+msgstr "Taper un nom de fichier ou cliquer sur Parcourir pour choisir un fichier"
#: ../gui/wxpython/psmap/dialogs.py:1972 ../gui/wxpython/psmap/dialogs.py:2161
msgid "Choose a file"
@@ -9353,8 +8577,7 @@
#: ../gui/wxpython/psmap/dialogs.py:2728
msgid "Leave the edit field empty, to use default values."
-msgstr ""
-"Laisser vide le champ d'édition afin d'utiliser les valeurs par défaut."
+msgstr "Laisser vide le champ d'édition afin d'utiliser les valeurs par défaut."
#: ../gui/wxpython/psmap/dialogs.py:2750
msgid ""
@@ -9626,9 +8849,7 @@
#: ../gui/wxpython/gcp/mapdisplay.py:456 ../gui/wxpython/mapdisp/frame.py:575
#: ../gui/wxpython/gmodeler/frame.py:550
msgid "Choose a file name to save the image (no need to add extension)"
-msgstr ""
-"Choisissez un nom de fichier pour enregistrer l'image (extension non "
-"nécessaire)"
+msgstr "Choisissez un nom de fichier pour enregistrer l'image (extension non nécessaire)"
#: ../gui/wxpython/modules/histogram.py:449 ../gui/wxpython/wxplot/base.py:484
#: ../gui/wxpython/gcp/mapdisplay.py:489 ../gui/wxpython/mapdisp/frame.py:608
@@ -9660,13 +8881,8 @@
msgstr "Se connecter au serveur"
#: ../gui/wxpython/modules/ogc_services.py:167
-#, fuzzy
-msgid ""
-"The 'xml2' parser is required, please install it first. You may also try "
-"running r.in.wms directly from the command line."
-msgstr ""
-"Le parseur 'xml2' est requis, merci de l'installer en premier. Vous pouvez "
-"aussi essayer de lancer r.in.wms depuis la ligne de commande."
+msgid "The 'xml2' parser is required, please install it first. You may also try running r.in.wms directly from the command line."
+msgstr "L'outil 'xml2' est requis, merci de commencer par l'installer. Vous pouvez aussi essayer de lancer r.in.wms directement depuis la ligne de commande."
#: ../gui/wxpython/modules/ogc_services.py:251
msgid "Layer / Style"
@@ -9896,9 +9112,7 @@
#: ../gui/wxpython/modules/colorrules.py:401
msgid "Type filename or click to choose file and load color table"
-msgstr ""
-"Entrer un nom de fichier ou cliquer sur Parcourir pour charger une table de "
-"couleur"
+msgstr "Entrer un nom de fichier ou cliquer sur Parcourir pour charger une table de couleur"
#: ../gui/wxpython/modules/colorrules.py:407
msgid "Choose file to save color table"
@@ -9906,9 +9120,7 @@
#: ../gui/wxpython/modules/colorrules.py:408
msgid "Type filename or click to choose file and save color table"
-msgstr ""
-"Entrer un nom de fichier ou cliquer sur Parcourir pour enregistrer une table "
-"de couleur"
+msgstr "Entrer un nom de fichier ou cliquer sur Parcourir pour enregistrer une table de couleur"
#: ../gui/wxpython/modules/colorrules.py:417
#, fuzzy
@@ -9938,9 +9150,7 @@
#: ../gui/wxpython/modules/colorrules.py:522
msgid "Show preview of map (current Map Display extent is used)."
-msgstr ""
-"Affiche un aperçu de la carte (l'étendue de la fenêtre de cartes actuelle "
-"sera utilisée)."
+msgstr "Affiche un aperçu de la carte (l'étendue de la fenêtre de cartes actuelle sera utilisée)."
#: ../gui/wxpython/modules/colorrules.py:552
msgid "No valid color rules given."
@@ -9953,8 +9163,7 @@
#: ../gui/wxpython/modules/colorrules.py:712
#, python-format
msgid "Invalid rule value '%s'. Unable to apply color table."
-msgstr ""
-"Valeur '%s' de règle non valide. Impossible d'appliquer la table de couleur."
+msgstr "Valeur '%s' de règle non valide. Impossible d'appliquer la table de couleur."
#: ../gui/wxpython/modules/colorrules.py:790
msgid "Create new color table for raster map"
@@ -9971,9 +9180,7 @@
#: ../gui/wxpython/modules/colorrules.py:873
#, python-format
msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
-msgstr ""
-"Saisir les valeurs de catégorie ou le pourcentage (%(range)s = %(min)d-"
-"%(max)d)"
+msgstr "Saisir les valeurs de catégorie ou le pourcentage (%(range)s = %(min)d-%(max)d)"
#: ../gui/wxpython/modules/colorrules.py:961
msgid "Create new color rules for vector map"
@@ -10040,13 +9247,8 @@
#: ../gui/wxpython/modules/colorrules.py:1131
#, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. Do you "
-"want to create and connect new attribute table?"
-msgstr ""
-"La connexion à une base de données pour la carte vecteur <%s> n'est pas "
-"définie dans le fichier DB. Voulez-vous créer et connecter une nouvelle "
-"table d'attributs ?"
+msgid "Database connection for vector map <%s> is not defined in DB file. Do you want to create and connect new attribute table?"
+msgstr "La connexion à une base de données pour la carte vecteur <%s> n'est pas définie dans le fichier DB. Voulez-vous créer et connecter une nouvelle table d'attributs ?"
#: ../gui/wxpython/modules/colorrules.py:1134
msgid "No database connection defined"
@@ -10054,21 +9256,13 @@
#: ../gui/wxpython/modules/colorrules.py:1206
#, python-format
-msgid ""
-"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Color rules "
-"cannot be edited."
-msgstr ""
-"La carte sélectionnée <%(map)s> n'est pas dans le jeux de cartes courant <"
-"%(mapset)s>. Les règles de couleur ne peuvent pas être modifiées."
+msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Color rules cannot be edited."
+msgstr "La carte sélectionnée <%(map)s> n'est pas dans le jeux de cartes courant <%(mapset)s>. Les règles de couleur ne peuvent pas être modifiées."
#: ../gui/wxpython/modules/colorrules.py:1211
#, python-format
-msgid ""
-"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
-"table cannot be edited."
-msgstr ""
-"%(mapset)s>. La table d'attributs ne peut pas être modifiée."
+msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute table cannot be edited."
+msgstr "La carte sélectionnée <%(map)s> n'est pas dans le jeux de cartes courant <%(mapset)s>. La table d'attributs ne peut pas être modifiée."
#: ../gui/wxpython/modules/colorrules.py:1353
#, python-format
@@ -10081,13 +9275,8 @@
#: ../gui/wxpython/modules/colorrules.py:1446
#, python-format
-msgid ""
-"Number of loaded records reached %d, displaying all the records will be time-"
-"consuming and may lead to computer freezing, do you still want to continue?"
-msgstr ""
-"Le nombre d'enregistrements est de %d, afficher tous les enregistrements "
-"serait très long et peut provoquer un gel de l'ordinateur. Voulez-vous "
-"continuer ?"
+msgid "Number of loaded records reached %d, displaying all the records will be time-consuming and may lead to computer freezing, do you still want to continue?"
+msgstr "Le nombre d'enregistrements est de %d, afficher tous les enregistrements serait très long et peut provoquer un gel de l'ordinateur. Voulez-vous continuer ?"
#: ../gui/wxpython/modules/colorrules.py:1450
msgid "Too many records"
@@ -10133,9 +9322,7 @@
#: ../gui/wxpython/modules/extensions.py:95
msgid "Fetch list of available modules from GRASS Addons SVN repository"
-msgstr ""
-"Récupérer la liste des modules disponibles depuis le dépôt svn des GRASS "
-"AddOns"
+msgstr "Récupérer la liste des modules disponibles depuis le dépôt svn des GRASS AddOns"
#: ../gui/wxpython/modules/extensions.py:98
msgid "&Install"
@@ -10151,9 +9338,7 @@
#: ../gui/wxpython/modules/extensions.py:186
msgid "Fetch list of available extensions by clicking on 'Fetch' button"
-msgstr ""
-"Récupérer la liste des extensions disponibles en cliquant sur le bouton "
-"'Récupérer'"
+msgstr "Récupérer la liste des extensions disponibles en cliquant sur le bouton 'Récupérer'"
#: ../gui/wxpython/modules/extensions.py:194
#, python-format
@@ -10162,9 +9347,7 @@
#: ../gui/wxpython/modules/extensions.py:207
msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
-msgstr ""
-"Récupération de la liste des modules à partir du svn GRASS AddOns (soyez "
-"patient)..."
+msgstr "Récupération de la liste des modules à partir du svn GRASS AddOns (soyez patient)..."
#: ../gui/wxpython/modules/extensions.py:386
msgid "Uninstall GRASS Addons extensions"
@@ -10408,13 +9591,8 @@
#: ../gui/wxpython/location_wizard/wizard.py:159
#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for location. Please use only ASCII "
-"characters excluding %(chars)s and space."
-msgstr ""
-"Le nom <%(name)s> n'est pas un nom valide pour un secteur. Merci de "
-"n'utiliser que des caractères ASCII à l'exclusion de %(chars)s et des "
-"espaces."
+msgid "Name <%(name)s> is not a valid name for location. Please use only ASCII characters excluding %(chars)s and space."
+msgstr "Le nom <%(name)s> n'est pas un nom valide pour un secteur. Merci de n'utiliser que des caractères ASCII à l'exclusion de %(chars)s et des espaces."
#: ../gui/wxpython/location_wizard/wizard.py:162
msgid "Invalid location name"
@@ -10434,12 +9612,8 @@
msgstr "Impossible de créer le secteur"
#: ../gui/wxpython/location_wizard/wizard.py:205
-msgid ""
-"Title of the location is limited only to one line and 256 characters. The "
-"rest of the text will be ignored."
-msgstr ""
-"Le titre de secteur est limité à une ligne et 256 caractères. Le reste du "
-"texte sera ignoré."
+msgid "Title of the location is limited only to one line and 256 characters. The rest of the text will be ignored."
+msgstr "Le titre de secteur est limité à une ligne et 256 caractères. Le reste du texte sera ignoré."
#: ../gui/wxpython/location_wizard/wizard.py:212
msgid "Choose method for creating a new location"
@@ -10455,9 +9629,7 @@
#: ../gui/wxpython/location_wizard/wizard.py:224
msgid "Read projection and datum terms from a georeferenced data file"
-msgstr ""
-"Lire la projection et les termes du datum depuis un fichier de "
-"géréférencement"
+msgstr "Lire la projection et les termes du datum depuis un fichier de géréférencement"
#: ../gui/wxpython/location_wizard/wizard.py:227
msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
@@ -10465,9 +9637,7 @@
#: ../gui/wxpython/location_wizard/wizard.py:230
msgid "Specify projection and datum terms using custom PROJ.4 parameters"
-msgstr ""
-"Spécifier la projection et les termes du datum en utilisant des paramètres "
-"PROJ.4 personnalisés"
+msgstr "Spécifier la projection et les termes du datum en utilisant des paramètres PROJ.4 personnalisés"
#: ../gui/wxpython/location_wizard/wizard.py:233
msgid "Create a generic Cartesian coordinate system (XY)"
@@ -10574,9 +9744,8 @@
#: ../gui/wxpython/location_wizard/wizard.py:1185
#: ../gui/wxpython/location_wizard/wizard.py:1242
-#, fuzzy
msgid "Select Well Known Text (WKT) .prj file"
-msgstr "Sélectionner le fichier .prj Well Known Text (WKT)"
+msgstr "Sélectionner le fichier Well Known Text (WKT) .prj"
#: ../gui/wxpython/location_wizard/wizard.py:1190
msgid "WKT .prj file:"
@@ -10637,7 +9806,6 @@
msgstr "Projection :"
#: ../gui/wxpython/location_wizard/wizard.py:1640
-#, fuzzy
msgid ""
"PROJ.4 definition:\n"
" (non-definitive)"
@@ -10679,13 +9847,8 @@
#: ../gui/wxpython/location_wizard/wizard.py:2011
#, python-format
-msgid ""
-"Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will "
-"need to change the default GIS data directory in the GRASS startup screen."
-msgstr ""
-"Le secteur <%(loc)s> va être créé dans le répertoire SIG <%(dir)s>. Il vous "
-"faudra changer le répertoire SIG par défaut dans l'écran de démarrage de "
-"GRASS."
+msgid "Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will need to change the default GIS data directory in the GRASS startup screen."
+msgstr "Le secteur <%(loc)s> va être créé dans le répertoire SIG <%(dir)s>. Il vous faudra changer le répertoire SIG par défaut dans l'écran de démarrage de GRASS."
#: ../gui/wxpython/location_wizard/wizard.py:2016
msgid "New GIS data directory"
@@ -10905,8 +10068,7 @@
#: ../gui/wxpython/wxplot/profile.py:264
msgid "You must draw a transect to profile in the map display window."
-msgstr ""
-"Vous devez dessiner un transect dans la fenêtre d'affichage des cartes."
+msgstr "Vous devez dessiner un transect dans la fenêtre d'affichage des cartes."
#: ../gui/wxpython/wxplot/profile.py:265
msgid "Nothing to profile"
@@ -10914,8 +10076,7 @@
#: ../gui/wxpython/wxplot/profile.py:333
msgid "Choose prefix for file(s) where to save profile values..."
-msgstr ""
-"Choisir le préfixe des fichiers où enregistrer les valeurs du profil ..."
+msgstr "Choisir le préfixe des fichiers où enregistrer les valeurs du profil ..."
#: ../gui/wxpython/wxplot/profile.py:335
msgid "Comma separated value (*.csv)|*.csv"
@@ -11061,9 +10222,7 @@
#: ../gui/wxpython/wxplot/dialogs.py:378 ../gui/wxpython/wxplot/dialogs.py:764
msgid "Apply changes for the current session and close dialog"
-msgstr ""
-"Appliquer les changements pour la session courante et fermer la boite de "
-"dialogue"
+msgstr "Appliquer les changements pour la session courante et fermer la boite de dialogue"
#: ../gui/wxpython/wxplot/dialogs.py:434
#, python-format
@@ -11118,11 +10277,8 @@
msgstr "Échelle"
#: ../gui/wxpython/wxplot/dialogs.py:662
-msgid ""
-"Automatic axis scaling, custom max and min, or scale matches data range (min)"
-msgstr ""
-"Échelle de l'axe automatique, min et max personnalisés, ou échelle "
-"correspondant aux données (min)"
+msgid "Automatic axis scaling, custom max and min, or scale matches data range (min)"
+msgstr "Échelle de l'axe automatique, min et max personnalisés, ou échelle correspondant aux données (min)"
#: ../gui/wxpython/wxplot/dialogs.py:667
msgid "Custom min"
@@ -11187,15 +10343,11 @@
#: ../gui/wxpython/gcp/manager.py:383
msgid "You must select a valid location before selecting a mapset"
-msgstr ""
-"Vous devez sélectionner un secteur valide avant de sélectionner un jeu de "
-"cartes"
+msgstr "Vous devez sélectionner un secteur valide avant de sélectionner un jeu de cartes"
#: ../gui/wxpython/gcp/manager.py:396
msgid "You must select a valid location and mapset in order to continue"
-msgstr ""
-"Vous devez sélectionner un secteur et un jeu de cartes valides pour pouvoir "
-"continuer"
+msgstr "Vous devez sélectionner un secteur et un jeu de cartes valides pour pouvoir continuer"
#: ../gui/wxpython/gcp/manager.py:415
msgid "Select image/map group to georectify"
@@ -11223,9 +10375,7 @@
#: ../gui/wxpython/gcp/manager.py:521
msgid "You must select a valid image/map group in order to continue"
-msgstr ""
-"Vous devez sélectionner un groupe d'images ou de cartes valides pour pouvoir "
-"continuer"
+msgstr "Vous devez sélectionner un groupe d'images ou de cartes valides pour pouvoir continuer"
#: ../gui/wxpython/gcp/manager.py:528
msgid "You must enter an map name extension in order to continue"
@@ -11233,8 +10383,7 @@
#: ../gui/wxpython/gcp/manager.py:594
msgid "Select maps to display for ground control point (GCP) creation"
-msgstr ""
-"Sélectionner les cartes à afficher pour la création des points de contrôle"
+msgstr "Sélectionner les cartes à afficher pour la création des points de contrôle"
#: ../gui/wxpython/gcp/manager.py:602 ../gui/wxpython/gcp/manager.py:2559
msgid "Select source map to display:"
@@ -11318,14 +10467,12 @@
#: ../gui/wxpython/gcp/manager.py:1304
msgid ""
-"Insufficient points defined and active (checked) for selected rectification "
-"method.\n"
+"Insufficient points defined and active (checked) for selected rectification method.\n"
"3+ points needed for 1st order,\n"
"6+ points for 2nd order, and\n"
"10+ points for 3rd order."
msgstr ""
-"Pas assez de points définis et activés pour la méthode de rectification "
-"choisie.\n"
+"Pas assez de points définis et activés pour la méthode de rectification choisie.\n"
"3 points ou + nécessaires pour le 1er ordre,\n"
"7 points ou + nécessaires pour le 2ème ordre, et\n"
"10 points ou + nécessaires pour le 3ème ordre."
@@ -11346,11 +10493,8 @@
#: ../gui/wxpython/gcp/manager.py:1442
#, python-format
-msgid ""
-"Vector map <%s> already exists. Change extension name and georectify again."
-msgstr ""
-"La carte vecteur <%s> existe déjà. Changez le suffixe et géoréférencez à "
-"nouveau."
+msgid "Vector map <%s> already exists. Change extension name and georectify again."
+msgstr "La carte vecteur <%s> existe déjà. Changez le suffixe et géoréférencez à nouveau."
#: ../gui/wxpython/gcp/manager.py:1452
msgid "For all vector maps georectified successfully,"
@@ -11549,9 +10693,7 @@
#: ../gui/wxpython/gcp/manager.py:2774
#, python-format
msgid "GCP Manager settings saved to file '%s'."
-msgstr ""
-"Paramètres du gestionnaire de points de contrôle enregistrés dans le fichier "
-"'%s'."
+msgstr "Paramètres du gestionnaire de points de contrôle enregistrés dans le fichier '%s'."
msgid "GRASS GIS Manage Ground Control Points"
@@ -11668,9 +10810,7 @@
#: ../gui/wxpython/mapdisp/frame.py:662
msgid "No raster or vector map layer selected for querying."
-msgstr ""
-"Pas de carte rater ou couche de carte vecteur sélectionnée pour "
-"interrogation."
+msgstr "Pas de carte rater ou couche de carte vecteur sélectionnée pour interrogation."
#: ../gui/wxpython/mapdisp/frame.py:743
#, python-format
@@ -11814,11 +10954,8 @@
msgstr "Déplacer avec la souris pour faire pivoter la scène 3D"
#: ../gui/wxpython/mapdisp/toolbars.py:57
-msgid ""
-"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
-msgstr ""
-"Déplacer avec la souris, appuyer sur Ctrl pour les différents modes, ou Maj "
-"pour accélérer"
+msgid "Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
+msgstr "Déplacer avec la souris, appuyer sur Ctrl pour les différents modes, ou Maj pour accélérer"
#: ../gui/wxpython/mapdisp/toolbars.py:59
msgid "Click mouse to zoom"
@@ -11839,15 +10976,8 @@
msgstr "Raison : %s"
#: ../gui/wxpython/mapdisp/toolbars.py:90
-msgid ""
-"Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
-"(hopefully this will be fixed soon). Please keep an eye out for updated "
-"versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
-msgstr ""
-"Notez que le mode de vue 3D de wxGUI est actuellement indisponible sur MS "
-"Windows (cela sera prochainement résolu). Merci de garder un œil sur les "
-"mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"NVIZ"
-"\", accessible depuis le menu Fichier."
+msgid "Note that the wxGUI's 3D view mode is currently disabled on MS Windows (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
+msgstr "Notez que le mode de vue 3D de wxGUI est actuellement indisponible sur MS Windows (cela sera prochainement résolu). Merci de garder un œil sur les mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"NVIZ\", accessible depuis le menu Fichier."
#: ../gui/wxpython/mapdisp/toolbars.py:98
#: ../gui/wxpython/vdigit/toolbars.py:695
@@ -11859,15 +10989,8 @@
msgstr "La numérisation de vector n'est pas disponible"
#: ../gui/wxpython/mapdisp/toolbars.py:107
-msgid ""
-"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
-"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
-"In the meantime you can use \"v.digit\" from the Develop Vector menu."
-msgstr ""
-"Notez que le module de digitalisation de wxGUI est actuellement indisponible "
-"(en espérant que cela soit prochainement résolu). Merci de garder un œil sur "
-"les mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"v."
-"digit\", accessible depuis le menu Vecteur."
+msgid "Note that the wxGUI's vector digitizer is currently disabled (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"v.digit\" from the Develop Vector menu."
+msgstr "Notez que le module de digitalisation de wxGUI est actuellement indisponible (en espérant que cela soit prochainement résolu). Merci de garder un œil sur les mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"v.digit\", accessible depuis le menu Vecteur."
#: ../gui/wxpython/mapdisp/statusbar.py:357
msgid "Render"
@@ -11886,54 +11009,32 @@
msgstr "Afficher les limites de calculs"
#: ../gui/wxpython/mapdisp/statusbar.py:392
-msgid ""
-"Show/hide computational region extent (set with g.region). Display region "
-"drawn as a blue box inside the computational region, computational region "
-"inside a display region as a red box)."
-msgstr ""
-"Afficher/cacher les limites de la région de calcul (définie avec g.region). "
-"Région de l'affichage dessinée comme rectangle bleu à l'intérieur de la "
-"région de calcul, région de calcul comme rectangle rouge à l'intérieur de la "
-"région de l'affichage."
+msgid "Show/hide computational region extent (set with g.region). Display region drawn as a blue box inside the computational region, computational region inside a display region as a red box)."
+msgstr "Afficher/cacher les limites de la région de calcul (définie avec g.region). Région de l'affichage dessinée comme rectangle bleu à l'intérieur de la région de calcul, région de calcul comme rectangle rouge à l'intérieur de la région de l'affichage."
#: ../gui/wxpython/mapdisp/statusbar.py:432
msgid "Display mode"
msgstr "Mode d'affichage"
#: ../gui/wxpython/mapdisp/statusbar.py:439
-msgid ""
-"Align region extent based on display size from center point. Default value "
-"for new map displays can be set up in 'User GUI settings' dialog."
-msgstr ""
-"Aligner l'étendue de la région sur la taille de l'affichage depuis le point "
-"central. La valeur par défaut pour les nouveaux affichages peut être définie "
-"dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
+msgid "Align region extent based on display size from center point. Default value for new map displays can be set up in 'User GUI settings' dialog."
+msgstr "Aligner l'étendue de la région sur la taille de l'affichage depuis le point central. La valeur par défaut pour les nouveaux affichages peut être définie dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
#: ../gui/wxpython/mapdisp/statusbar.py:452
msgid "Display resolution"
msgstr "Résolution de l'affichage"
#: ../gui/wxpython/mapdisp/statusbar.py:459
-msgid ""
-"Constrain display resolution to computational region settings. Default value "
-msgstr ""
-"Contraindre la résolution d'affichage aux réglages de région calculée. La "
-"valeur par défaut pour les nouveaux affichages de cartes peut être réglée "
+msgid "Constrain display resolution to computational region settings. Default value for new map displays can be set up in 'User GUI settings' dialog."
+msgstr "Contraindre la résolution d'affichage aux réglages de région calculée. La valeur par défaut pour les nouveaux affichages de cartes peut être réglée dans la boîte de dialogue 'Paramètres de l'interface utilisateur'"
#: ../gui/wxpython/mapdisp/statusbar.py:483
msgid "Map scale"
msgstr "Échelle de la carte"
#: ../gui/wxpython/mapdisp/statusbar.py:497
-msgid ""
-"As everyone's monitors and resolutions are set differently these values are "
-"not true map scales, but should get you into the right neighborhood."
-msgstr ""
-"Étant donné que tous les moniteurs et les résolutions sont réglés "
-"différemment, ces valeurs ne sont pas des échelles réelles mais restent "
-"proches de la réalité."
+msgid "As everyone's monitors and resolutions are set differently these values are not true map scales, but should get you into the right neighborhood."
+msgstr "Étant donné que tous les moniteurs et les résolutions sont réglés différemment, ces valeurs ne sont pas des échelles réelles mais restent proches de la réalité."
#: ../gui/wxpython/mapdisp/statusbar.py:550
msgid "Go to"
@@ -11957,13 +11058,8 @@
msgstr "Utiliser une projection définie"
#: ../gui/wxpython/mapdisp/statusbar.py:695
-msgid ""
-"Reproject coordinates displayed in the statusbar. Projection can be defined "
-"in GUI preferences dialog (tab 'Projection')"
-msgstr ""
-"Re-projeter les coordonnées affichées dans la barre d'état. La projection "
-"peut être définie dans les préférences de l'interface utilisateur (onglet "
-"'Affichage de la carte')"
+msgid "Reproject coordinates displayed in the statusbar. Projection can be defined in GUI preferences dialog (tab 'Projection')"
+msgstr "Re-projeter les coordonnées affichées dans la barre d'état. La projection peut être définie dans les préférences de l'interface utilisateur (onglet 'Affichage de la carte')"
#: ../gui/wxpython/mapdisp/statusbar.py:720
msgid "MASK"
@@ -12050,14 +11146,8 @@
#: ../gui/wxpython/vdigit/wxdisplay.py:869
#, python-format
-msgid ""
-"Topology for vector map <%s> is not available. Topology is required by "
-"digitizer. Do you want to rebuild topology (takes some time) and open the "
-"vector map for editing?"
-msgstr ""
-"La topologie pour la carte vecteur <%s> n'est pas disponible. La topologie "
-"est requise pour la digitalisation. Voulez-vous reconstruire la topologie "
-"(peut prendre du temps) et ouvrir la carte vecteur pour édition ?"
+msgid "Topology for vector map <%s> is not available. Topology is required by digitizer. Do you want to rebuild topology (takes some time) and open the vector map for editing?"
+msgstr "La topologie pour la carte vecteur <%s> n'est pas disponible. La topologie est requise pour la digitalisation. Voulez-vous reconstruire la topologie (peut prendre du temps) et ouvrir la carte vecteur pour édition ?"
#: ../gui/wxpython/vdigit/wxdisplay.py:873
msgid "Topology missing"
@@ -12069,9 +11159,7 @@
#: ../gui/wxpython/vdigit/preferences.py:56
msgid "Close dialog and save changes to user settings file"
-msgstr ""
-"Fermer la boîte de dialogue et sauvegarder les modifications dans le fichier "
-"de réglages utilisateur"
+msgstr "Fermer la boîte de dialogue et sauvegarder les modifications dans le fichier de réglages utilisateur"
#: ../gui/wxpython/vdigit/preferences.py:148
msgid "Snapping"
@@ -12114,11 +11202,8 @@
msgstr "Ne sélectionner que les objets inclus dans la boîte de sélection"
#: ../gui/wxpython/vdigit/preferences.py:220
-msgid ""
-"By default are selected all features overlapping selection bounding box "
-msgstr ""
-"Par défaut sont sélectionnés tous les objets intersectant la boîte de "
-"sélection"
+msgid "By default are selected all features overlapping selection bounding box "
+msgstr "Par défaut sont sélectionnés tous les objets intersectant la boîte de sélection"
#: ../gui/wxpython/vdigit/preferences.py:223
msgid "Check for duplicates"
@@ -12229,12 +11314,8 @@
msgstr "périmètre"
#: ../gui/wxpython/vdigit/preferences.py:484
-msgid ""
-"Note: These settings are stored in the workspace not in the vector digitizer "
-"preferences."
-msgstr ""
-"Note : ces réglages sont stockés dans l'espace de travail, non dans les "
-"préférences du module de numérisation."
+msgid "Note: These settings are stored in the workspace not in the vector digitizer preferences."
+msgstr "Note : ces réglages sont stockés dans l'espace de travail, non dans les préférences du module de numérisation."
#: ../gui/wxpython/vdigit/preferences.py:512
msgid "Digitize new line segment"
@@ -12303,9 +11384,7 @@
#: ../gui/wxpython/vdigit/preferences.py:598
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
-msgstr ""
-"Le seuil de magnétisme vaut %(value).1f %(units)s (fondé sur la résolution "
-"calculée)"
+msgstr "Le seuil de magnétisme vaut %(value).1f %(units)s (fondé sur la résolution calculée)"
#: ../gui/wxpython/vdigit/preferences.py:654
#, python-format
@@ -12346,16 +11425,12 @@
#: ../gui/wxpython/vdigit/wxdigit.py:89
#, python-format
msgid "Unable to start database driver <%s>. Operation canceled."
-msgstr ""
-"Impossible de démarrer le pilote de base de données <%s>. Opération annulée."
+msgstr "Impossible de démarrer le pilote de base de données <%s>. Opération annulée."
#: ../gui/wxpython/vdigit/wxdigit.py:97
#, python-format
-msgid ""
-"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
-msgstr ""
-"Impossible d'ouvrir la base de données <%(db)s> avec le pilote <"
-"%(driver)s> . Opération annulée."
+msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+msgstr "Impossible d'ouvrir la base de données <%(db)s> avec le pilote <%(driver)s> . Opération annulée."
#: ../gui/wxpython/vdigit/wxdigit.py:105
#, python-format
@@ -12397,9 +11472,7 @@
#: ../gui/wxpython/vdigit/toolbars.py:88 ../gui/wxpython/vdigit/toolbars.py:91
#: ../gui/wxpython/vdigit/toolbars.py:112
msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
-msgstr ""
-"Gauche : nouveau point ; Ctrl+gauche : annuler le dernier point ; Droite : "
-"fermer la ligne"
+msgstr "Gauche : nouveau point ; Ctrl+gauche : annuler le dernier point ; Droite : fermer la ligne"
#: ../gui/wxpython/vdigit/toolbars.py:90
msgid "Digitize new boundary"
@@ -12410,12 +11483,8 @@
msgstr "Numériser un nouveau centroïde"
#: ../gui/wxpython/vdigit/toolbars.py:96
-msgid ""
-"Digitize new area (composition of boundaries without category and one "
-"centroid with category)"
-msgstr ""
-"Numériser une nouvelle surface (composée d'un contour sans catégorie et d'un "
-"centroïde avec catégorie)"
+msgid "Digitize new area (composition of boundaries without category and one centroid with category)"
+msgstr "Numériser une nouvelle surface (composée d'un contour sans catégorie et d'un centroïde avec catégorie)"
#: ../gui/wxpython/vdigit/toolbars.py:99
msgid "Add new vertex"
@@ -12428,8 +11497,7 @@
#: ../gui/wxpython/vdigit/toolbars.py:121
#: ../gui/wxpython/vdigit/toolbars.py:130
msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
-msgstr ""
-"Gauche : Sélectionner ; Ctrl+Gauche : Dé-sélectionner : Droite : Confirmer"
+msgstr "Gauche : Sélectionner ; Ctrl+Gauche : Dé-sélectionner : Droite : Confirmer"
#: ../gui/wxpython/vdigit/toolbars.py:102
msgid "Delete feature(s)"
@@ -12573,9 +11641,7 @@
#: ../gui/wxpython/vdigit/toolbars.py:740
#, python-format
msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
-msgstr ""
-"Merci de patienter, fermeture et reconstruction de la topologie de la carte "
-"vecteur <%s>..."
+msgstr "Merci de patienter, fermeture et reconstruction de la topologie de la carte vecteur <%s>..."
#: ../gui/wxpython/vdigit/toolbars.py:750
#, python-format
@@ -12598,9 +11664,7 @@
#: ../gui/wxpython/vdigit/mapwindow.py:502
msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
-msgstr ""
-"Pas d'action. Choisissez l'outil approprié depuis la barre d'outil de "
-"numérisation."
+msgstr "Pas d'action. Choisissez l'outil approprié depuis la barre d'outil de numérisation."
#: ../gui/wxpython/vdigit/mapwindow.py:992
msgid "Z bulk-labeling dialog"
@@ -12714,8 +11778,7 @@
#: ../gui/wxpython/gmodeler/frame.py:240
msgid "Do you want to store current model settings to model file?"
-msgstr ""
-"Voulez-vous enregistrer les paramètres du modèle courants dans un fichier ?"
+msgstr "Voulez-vous enregistrer les paramètres du modèle courants dans un fichier ?"
#: ../gui/wxpython/gmodeler/frame.py:246
msgid "Quit Graphical Modeler"
@@ -12740,12 +11803,8 @@
msgstr "%d cartes supprimées du jeu de cartes courant"
#: ../gui/wxpython/gmodeler/frame.py:341 ../gui/wxpython/gmodeler/frame.py:456
-msgid ""
-"Current model is not empty. Do you want to store current settings to model "
-"file?"
-msgstr ""
-"le modèle courant n'est pas vide. Voulez-vous enregistrer les paramètres "
-"courants dans un fichier ?"
+msgid "Current model is not empty. Do you want to store current settings to model file?"
+msgstr "le modèle courant n'est pas vide. Voulez-vous enregistrer les paramètres courants dans un fichier ?"
#: ../gui/wxpython/gmodeler/frame.py:344 ../gui/wxpython/gmodeler/frame.py:459
msgid "Create new model?"
@@ -12763,8 +11822,7 @@
#: ../gui/wxpython/gmodeler/frame.py:396 ../gui/wxpython/gmodeler/frame.py:433
#, python-format
msgid "Model file <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-"Le fichier de modèle <%s> existe déjà. Voulez-vous écraser ce fichier ?"
+msgstr "Le fichier de modèle <%s> existe déjà. Voulez-vous écraser ce fichier ?"
#: ../gui/wxpython/gmodeler/frame.py:406 ../gui/wxpython/gmodeler/frame.py:446
#, python-format
@@ -12952,12 +12010,8 @@
msgstr "Enegistrer le fichier"
#: ../gui/wxpython/gmodeler/frame.py:1623
-msgid ""
-"Python script is locally modificated. Refresh will discard all changes. Do "
-"you really want to continue?"
-msgstr ""
-"Le script Python a été modifié manuellement. La mise à jour écrasera toutes "
-"les modifications. Voulez-vous vraiment continuer ?"
+msgid "Python script is locally modificated. Refresh will discard all changes. Do you really want to continue?"
+msgstr "Le script Python a été modifié manuellement. La mise à jour écrasera toutes les modifications. Voulez-vous vraiment continuer ?"
#: ../gui/wxpython/gmodeler/frame.py:1626
msgid "Update"
@@ -13240,12 +12294,8 @@
#: ../gui/wxpython/gmodeler/dialogs.py:861
#, python-format
-msgid ""
-"Selected data records (%d) will permanently deleted from table. Do you want "
-"to delete them?"
-msgstr ""
-"Les enregistrements sélectionnés (%d) vont être définitivement supprimés de "
-"la table. Souhaitez-vous les supprimer ?"
+msgid "Selected data records (%d) will permanently deleted from table. Do you want to delete them?"
+msgstr "Les enregistrements sélectionnés (%d) vont être définitivement supprimés de la table. Souhaitez-vous les supprimer ?"
#: ../gui/wxpython/gmodeler/dialogs.py:918
msgid "Normalize"
@@ -13273,16 +12323,12 @@
#: ../gui/wxpython/core/render.py:419
msgid "GISBASE not set. You must be in GRASS GIS to run this program."
-msgstr ""
-"GISBASE non définie. Vous devez être dans GRASS GIS pou exécuter ce "
-"programme."
+msgstr "GISBASE non définie. Vous devez être dans GRASS GIS pou exécuter ce programme."
#: ../gui/wxpython/core/render.py:464
#, python-format
msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
-msgstr ""
-"Erreur : impossible d'ouvrir '%(file)s'. Raison : %(ret)s. Sortie de "
-"wxGUI.\n"
+msgstr "Erreur : impossible d'ouvrir '%(file)s'. Raison : %(ret)s. Sortie de wxGUI.\n"
#: ../gui/wxpython/core/render.py:568
#, fuzzy, python-format
@@ -13305,12 +12351,8 @@
msgstr "Impossible de zoomer sur la carte vecteur <%s>."
#: ../gui/wxpython/core/render.py:649
-msgid ""
-"Unable to get current geographic extent. Force quiting wxGUI. Please "
-"manually run g.region to fix the problem."
-msgstr ""
-"Impossible d'obtenir l’extension géographique courante. Sortie forcée de "
-"wxGUI. Merci d'exécuter manuellement g.region pour résoudre ce problème."
+msgid "Unable to get current geographic extent. Force quiting wxGUI. Please manually run g.region to fix the problem."
+msgstr "Impossible d'obtenir l’extension géographique courante. Sortie forcée de wxGUI. Merci d'exécuter manuellement g.region pour résoudre ce problème."
#: ../gui/wxpython/core/render.py:932
#, python-format
@@ -13515,8 +12557,7 @@
"\n"
"Number of skipped lines: %(line)d"
msgstr ""
-"Certaines lignes ont été sautées à la lecture des réglages du fichier <"
-"%(file)s>.\n"
+"Certaines lignes ont été sautées à la lecture des réglages du fichier <%(file)s>.\n"
"Voir la fenêtre 'Sortie de commande' pour des détails.\n"
"\n"
"Nombre de lignes sautées : %(line)d"
@@ -13543,28 +12584,20 @@
msgid "Unable to exectute command: '%s'"
msgstr "Impossible d'exécuter la commande : '%s'"
+msgid "Limit 100000 records."
+msgstr "Limite 100000 enregistrement"
#~ msgid "Display on surface(s):"
#~ msgstr "Afficher sur la surface :"
-#~ msgid "Limit 100000 records."
-#~ msgstr "Limite 100000 enregistrement"
+#~ msgid "Field separator must be ASCII character not <%s> (use e.g. ';', '&', '#')"
+#~ msgstr "Le séparateur de champ doit être un caractères ASCII et pas <%s> (utiliser par exemple ';', '&', '#')"
-#~ msgid ""
-#~ "Field separator must be ASCII character not <%s> (use e.g. ';', '&', '#')"
-#~ msgstr ""
-#~ "Le séparateur de champ doit être un caractères ASCII et pas <%s> "
-#~ "(utiliser par exemple ';', '&', '#')"
#~ msgid "Field separator:"
#~ msgstr "Séparateur de champ :"
-#~ msgid ""
-#~ "Inconsistent number of columns in the table <%(table)s>. Try to change "
-#~ "field separator in GUI Settings, Attributes tab, Data browser section."
-#~ msgstr ""
-#~ "Nombre de colonnes de la table <%(table)s> non valide. Essayez de "
-#~ "modifier le séparateur de champs dans les paramètres de l'interface, "
-#~ "onglet Attributs, Naviguateur de données."
+#~ msgid "Inconsistent number of columns in the table <%(table)s>. Try to change field separator in GUI Settings, Attributes tab, Data browser section."
+#~ msgstr "Nombre de colonnes de la table <%(table)s> non valide. Essayez de modifier le séparateur de champs dans les paramètres de l'interface, onglet Attributs, Naviguateur de données."
#~ msgid "Select WKT or PRJ file"
#~ msgstr "Choisir un fichier WKT ou PRJ"
@@ -13584,11 +12617,8 @@
#~ msgid "Delete selected map layer"
#~ msgstr "Supprimer la carte sélectionnée"
-#~ msgid ""
-#~ "Attempt to import data source <%(name)s> as raster or vector failed. "
-#~ msgstr ""
-#~ "L'import de la source de données <%(name)s> en tant que raster ou vecteur "
-#~ "a échoué."
+#~ msgid "Attempt to import data source <%(name)s> as raster or vector failed. "
+#~ msgstr "L'import de la source de données <%(name)s> en tant que raster ou vecteur a échoué."
#~ msgid "Raster data source <%(name)s> imported successfully."
#~ msgstr "Import de la carte raster <%(name)s> réussit."
@@ -13599,37 +12629,20 @@
#~ msgid "Version"
#~ msgstr "Version"
-#~ msgid ""
-#~ "Converts co-ordinate system descriptions (i.e. projection information) "
-#~ "between various formats (including GRASS format)."
-#~ msgstr ""
-#~ "Convertit les descriptions de systèmes de coordonnées (c.-à-d. les "
-#~ "informations de projection) entre divers formats (dont le format GRASS)."
+#~ msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+#~ msgstr "Convertit les descriptions de systèmes de coordonnées (c.-à-d. les informations de projection) entre divers formats (dont le format GRASS)."
-#~ msgid ""
-#~ "Takes vector stream data, transforms it to raster and subtracts depth "
-#~ "from the output DEM."
-#~ msgstr ""
-#~ "Prends les données vectorielles de cours d'eau, les transforme en raster, "
-#~ "et soustrait la profondeur du modèle de terrain en sortie."
+#~ msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+#~ msgstr "Prends les données vectorielles de cours d'eau, les transforme en raster, et soustrait la profondeur du modèle de terrain en sortie."
-#~ msgid ""
-#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
-#~ "densities (upslope areas) from a raster digital elevation model (DEM)."
-#~ msgstr ""
-#~ "Constructin de courbes de terrain (lignes du courant), longueur des "
-#~ "courants, et densité de lignes de courants (surfaces amont) à partir d'un "
-#~ "modèle numérique d'altitudes (MNA) raster."
+#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
+#~ msgstr "Constructin de courbes de terrain (lignes du courant), longueur des courants, et densité de lignes de courants (surfaces amont) à partir d'un modèle numérique d'altitudes (MNA) raster."
#~ msgid "Watershed basin creation program."
#~ msgstr "Création de bassin versant."
-#~ msgid ""
-#~ "Creates a new map layer whose category values are based upon a "
-#~ "reclassification of the categories in an existing raster map layer."
-#~ msgstr ""
-#~ "Créer une nouvelle carte dont les valeurs de catégories sont basées sur "
-#~ "une reclassification des catégories d'une carte raster existante."
+#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
+#~ msgstr "Créer une nouvelle carte dont les valeurs de catégories sont basées sur une reclassification des catégories d'une carte raster existante."
#~ msgid "Histogram text settings"
#~ msgstr "Paramètre de texte"
@@ -13643,12 +12656,8 @@
#~ msgid "ERROR: Mapset <%s> not found"
#~ msgstr "ERREUR : Jeu de cartes <%s> non trouvé"
-#~ msgid ""
-#~ "Do you want to import data source <%(name)s> to created location? Default "
-#~ "region will be set to match imported map."
-#~ msgstr ""
-#~ "Voulez-vous importer la source de données <%(name)s> pour créer le "
-#~ "secteur ? la région par défaut sera alignée sur la carte importée."
+#~ msgid "Do you want to import data source <%(name)s> to created location? Default region will be set to match imported map."
+#~ msgstr "Voulez-vous importer la source de données <%(name)s> pour créer le secteur ? la région par défaut sera alignée sur la carte importée."
#~ msgid "Import data"
#~ msgstr "Importer des données"
@@ -13681,17 +12690,14 @@
#~ "Déplacer l'objet échelle avec la souris.\n"
#~ "Double-clic pour modifier les options."
-#~ msgid ""
-#~ "Converts GRASS vector map to one of the supported OGR vector formats."
-#~ msgstr ""
-#~ "Convertir une carte vecteur vers un des formats pris en charge par OGR."
+#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
+#~ msgstr "Convertir une carte vecteur vers un des formats pris en charge par OGR."
#~ msgid "Converts a raster map into a vector map layer."
#~ msgstr "Convertit une carte raster en carte vecteur."
#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr ""
-#~ "Génère une carte raster de distance à des objets dans la carte en entrée."
+#~ msgstr "Génère une carte raster de distance à des objets dans la carte en entrée."
#~ msgid "Watershed basin analysis program."
#~ msgstr "Analyse de bassin versant."
@@ -13703,9 +12709,7 @@
#~ msgstr "Crée des lignes parallèles aux lignes vectorielles d'entrée."
#~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-#~ msgstr ""
-#~ "Créer une mosaïque jusqu'à 4 images et étend la table de couleurs; créer "
-#~ "une carte *.mosaic"
+#~ msgstr "Créer une mosaïque jusqu'à 4 images et étend la table de couleurs; créer une carte *.mosaic"
#~ msgid "Comp. region"
#~ msgstr "Région de calcul"
