[GRASS-SVN] r62688 - grass-addons/grass7/vector/v.class.ml
Sun Nov 9 10:19:12 PST 2014
Author: zarch
Date: 2014-11-09 10:19:12 -0800 (Sun, 09 Nov 2014)
New Revision: 62688
   grass-addons/grass7/vector/v.class.ml/ml_classifiers.py
   grass-addons/grass7/vector/v.class.ml/ml_functions.py
   grass-addons/grass7/vector/v.class.ml/npy2table.py
   grass-addons/grass7/vector/v.class.ml/sqlite2npy.py
   grass-addons/grass7/vector/v.class.ml/training_extraction.py
   grass-addons/grass7/vector/v.class.ml/v.class.ml.py
v.class.ml: fix bugs
Modified: grass-addons/grass7/vector/v.class.ml/ml_classifiers.py
--- grass-addons/grass7/vector/v.class.ml/ml_classifiers.py	2014-11-09 18:08:55 UTC (rev 62687)
+++ grass-addons/grass7/vector/v.class.ml/ml_classifiers.py	2014-11-09 18:19:12 UTC (rev 62688)
@@ -23,9 +23,9 @@
 from sklearn import metrics
-from grass.pygrass.messages import Messenger
+from grass.pygrass.messages import get_msgr
-MSGR = Messenger()
+MSGR = get_msgr()
 try:
     import mlpy
Modified: grass-addons/grass7/vector/v.class.ml/ml_functions.py
--- grass-addons/grass7/vector/v.class.ml/ml_functions.py	2014-11-09 18:08:55 UTC (rev 62687)
+++ grass-addons/grass7/vector/v.class.ml/ml_functions.py	2014-11-09 18:19:12 UTC (rev 62688)
@@ -71,8 +71,8 @@
     cls['t_acc'] = metrics.accuracy_score(sol, pred, normalize=True)
     lab = [labels[key] for key in clsses]
-    cls['report'] = metrics.classification_report(sol, pred, lab)
-    cls['confusion'] = metrics.confusion_matrix(sol, pred, lab)
+    cls['report'] = metrics.classification_report(sol, pred, target_names=lab)
+    cls['confusion'] = metrics.confusion_matrix(sol, pred)
     c_acc = []
     for c in clsses:
         indx = (sol == c).nonzero()
@@ -106,7 +106,7 @@
     cls['pred_stop'] = time.time()
     print_test(cls, save=report)
     report.write('\n' + cls['report'])
-    report.write('\n' + cls['confusion'])
+    report.write('\n' + str(cls['confusion']))
     np.save(cls['name'] + '.npy', cls['predict'])
@@ -136,7 +136,7 @@
 def optimize_training(cls, tdata, tclss, labels,
-                      scaler=None, num=None, maxiterations=1000):
+                      scaler=None, decmp=None, num=None, maxiterations=1000):
     best = cls.copy()
     best['c_acc_mean'] = 0
     means = []
@@ -144,11 +144,19 @@
     for i in range(maxiterations):  # TODO: use multicore
         #msgr.percent(i, maxiterations, 1)
         Xt, Yt = balance(tdata, tclss, num)
+        stdata = None
+        sXt = None
         if scaler:
             scaler.fit(Xt, Yt)
             sXt = scaler.transform(Xt)
             stdata = scaler.transform(tdata)
-        else:
+        if decmp:
+            sXt = sXt if sXt else Xt
+            stdata = stdata if stdata else tdata
+            decmp.fit(sXt)
+            sXt = decmp.transform(sXt)
+            stdata = decmp.transform(stdata)
+        if scaler is None and decmp is None:
             sXt, stdata = Xt, tdata
         test_classifier(cls, sXt, Yt, stdata, tclss, labels, verbose=False)
         if cls['c_acc_mean'] > best['c_acc_mean']:
@@ -197,15 +205,13 @@
     fig.savefig("bv__%s.%s" % (name.replace(" ", "_"), fmt), **kwargs)
-def plot_confusion_matrix(cm, labels, name, fmt='png', **kwargs):
-    conf = cm.sum(axis=2)
-    conf /= conf.sum(axis=1)
+def plot_confusion_matrix(cnf, labels, name, fmt='png', **kwargs):
     fig, ax = plt.subplots(figsize=(6, 5))
-    img = ax.imshow(conf, cmap=CMAP)
+    img = ax.imshow(cnf, interpolation='nearest', cmap=CMAP)
     fig.colorbar(img)
     ticks = range(len(labels))
     ax.set_xticks(ticks)
-    ax.set_xticklabels(labels)
+    ax.set_xticklabels(labels, rotation=90)
     ax.xaxis.set_ticks_position("bottom")
     ax.set_yticks(ticks)
     ax.set_yticklabels(labels)
@@ -287,7 +293,6 @@
     train_errors, test_errors, scores, cms = [], [], [], []
     lk = {l: {k: [] for k in keys} for l in clss}
     clf = cls['classifier'](**cls['kwargs'])
-    import ipdb; ipdb.set_trace()
     for train, test in cv:
         X_train, y_train = tdata[train], tclss[train]
         X_test, y_test = tdata[test], tclss[test]
@@ -302,13 +307,13 @@
         test_errors.append(1 - test_score)
         y_pred = clf.predict(X_test)
-        cms.append(confusion_matrix(y_test, y_pred, lbs))
+        cms.append(confusion_matrix(y_test, y_pred))
         # get probability
         proba = clf.predict_proba(X_test)
         # compute score for each class VS rest
         for idx, label in enumerate(clss):
             fpr, tpr, roc_thr = roc_curve(y_test, proba[:, idx], label)
-            precision, recall, pr_thr = prc(y_test, proba[:, idx], label)
+            precision, recall, pr_thr = prc(y_test==label, proba[:, idx], label)
             lk[label]['fprs'].append(fpr)
             lk[label]['tprs'].append(tpr)
             lk[label]['roc_scores'].append(auc(fpr, tpr))
@@ -338,15 +343,18 @@
                  lk[cl]['tprs'][median],
                  lk[cl]['roc_scores'][median],
                  name=name, label=labels[cl])
-    plot_confusion_matrix(cls['confusion matrix'],
+    cnf = np.array(cls['confusion matrix'], dtype=np.float)
+    sc = cnf.sum(axis=0)
+    norm = sc / sc.sum(axis=1)[:, None]
+    plot_confusion_matrix(norm,
                           labels=[labels[cl] for cl in clss],
-                          name=cls['name'])
+                          name=cls['name'], **kwargs)
 def explorer_clsfiers(clsses, Xd, Yd, labels, indexes=None, n_folds=5,
                       bv=False, extra=False):
     gen = zip(indexes, clsses) if indexes else enumerate(clsses)
-    cv = StratifiedKFold(Yd, n_folds=n_folds)
+    cv = StratifiedKFold(Yd, n_folds=n_folds, shuffle=True)
     fmt = '%5d %-30s %6.4f %6.4f %6.4f %6.4f'
     res = []
     kw = dict(bbox_inches="tight", dpi=300)
@@ -377,13 +385,11 @@
                                    train_clr='b', test_clr='r', alpha=0.2,
                                    fmt='png', **kw)
             if extra:
                 extra_analysis(cls, Xd, Yd, labels)
                 plot_extra(cls, labels, **kw)
             with open("%s.pkl" % cls['name'].replace(' ', '_'), 'wb') as pkl:
                 pk.dump(cls, pkl)
         except:
-            #import ipdb; ipdb.set_trace()
             #print('problem with: %s' % cls['name'])
             pass
     return np.array(res, dtype=SCORES_DTYPE)
@@ -406,9 +412,10 @@
 def plot_grid(grid, save=''):
-    C = grid.param_grid['C']
-    gamma = grid.param_grid['gamma']
-    kernels = grid.param_grid['kernel']
+    C = grid.param_grid.get('C', 0)
+    gamma = grid.param_grid.get('gamma', 0)
+    kernels = grid.param_grid.get('kernel', 0)
+    degrees = grid.param_grid.get('degree', None)
     for kernel in kernels:
         scores = [x[1] for x in grid.grid_scores_ if x[0]['kernel'] == kernel]
         scores = np.array(scores).reshape(len(C), len(gamma))
@@ -423,8 +430,7 @@
         ax.set_xticklabels(gamma, rotation=45)
         ax.set_yticks(np.arange(len(C)))
         ax.set_yticklabels(C)
-#        if kernel == 'poly':
-#            import ipdb; ipdb.set_trace()
         ic, igamma = np.unravel_index(np.argmax(scores), scores.shape)
         ax.plot(igamma, ic, 'r.')
         best = scores[ic, igamma]
@@ -439,7 +445,7 @@
 def explore_SVC(Xt, Yt, n_folds=3, n_jobs=1, **kwargs):
-    cv = StratifiedKFold(y=Yt, n_folds=n_folds)
+    cv = StratifiedKFold(y=Yt, n_folds=n_folds, shuffle=True)
     grid = GridSearchCV(SVC(), param_grid=kwargs, cv=cv, n_jobs=n_jobs,
                         verbose=2)
     grid.fit(Xt, Yt)
Modified: grass-addons/grass7/vector/v.class.ml/npy2table.py
--- grass-addons/grass7/vector/v.class.ml/npy2table.py	2014-11-09 18:08:55 UTC (rev 62687)
+++ grass-addons/grass7/vector/v.class.ml/npy2table.py	2014-11-09 18:19:12 UTC (rev 62688)
@@ -32,11 +32,17 @@
     table.conn.commit()
-def export2onesqlite(table, cats, *clsses):
+def export2onesqlite(table, cats, update='', *clsses):
     cur = table.conn.cursor()
-    print("Insert data")
-    table.insert(zip(cats, *clsses), cursor=cur, many=True)
-    cur.close()
+    if update:
+        print("Update table inserting classification data")
+        print(update)
+        clsses.append(cats)
+        table.execute(update, many=True, values=zip(*clsses))
+    else:
+        print("Insert data")
+        table.insert(zip(cats, *clsses), cursor=cur, many=True)
+        cur.close()
     table.conn.commit()
@@ -59,7 +65,8 @@
 def export_results(vect_name, results, cats, rlayer,
-                   training=None, cols=None, overwrite=False, pkl=None):
+                   training=None, cols=None, overwrite=False, append=False,
+                   pkl=None):
     if pkl:
         res = open(pkl, 'w')
         pickle.dump(results, res)
@@ -68,21 +75,33 @@
     # check if the link already exist
     with Vector(vect_name, mode='r') as vct:
         link = vct.dblinks.by_name(rlayer)
-        mode = 'r' if link else 'rw'
+        mode = 'r' if link else 'w'
     print("Opening vector <%s>" % vect_name)
     with Vector(vect_name, mode=mode) as vect:
         if cols:
             cols.insert(0, COLS[0])
             tab = link.table() if link else Table(rlayer, vect.table.conn)
-            if tab.exist():
-                print("Table <%s> already exist, will be removed." % tab.name)
-                tab.drop(force=overwrite)
-            print("Ceating a new table <%s>." % rlayer)
-            tab.create(cols)
-            export2onesqlite(tab, cats, *[cls['predict'] for cls in results])
-            if mode == 'rw':
+            if tab.exist() and append:
+                columns_to_up = []
+                # add the column to the table
+                for cname, ctype in cols:
+                    columns_to_up.append("%s=?" % cname)
+                    if cname not in tab.columns:
+                        tab.columns.add(cname, ctype)
+                upsql = "UPDATE %s SET %s WHERE %s=%s"
+                up = upsql % (tab.name, ','.join(columns_to_up), tab.key, '?')
+            else:
+                if tab.exist():
+                    print("Table <%s> already exist, will be removed." % tab.name)
+                    tab.drop(force=True)
+                print("Ceating a new table <%s>." % rlayer)
+                tab.create(cols)
+                up = ''
+            export2onesqlite(tab, cats.astype(int), up,
+                             *[cls['predict'].astype(int) for cls in results])
+            if mode == 'w':
                 nlyr = len(vect.dblinks) + 1
                 link = Link(nlyr, tab.name, tab.name)
                 vect.dblinks.add(link)
Modified: grass-addons/grass7/vector/v.class.ml/sqlite2npy.py
--- grass-addons/grass7/vector/v.class.ml/sqlite2npy.py	2014-11-09 18:08:55 UTC (rev 62687)
+++ grass-addons/grass7/vector/v.class.ml/sqlite2npy.py	2014-11-09 18:19:12 UTC (rev 62688)
@@ -17,7 +17,7 @@
 FTDATA = 'training_data.npy'
-def cpdata(shape, iterator, msg=''):
+def cpdata(shape, iterator, dtype=float, msg=''):
     """Avoid to create a python list and then convert the python list to a
     numpy array. This function instantiate statically a numpy array and then
     fill the numpy array with the data coming from the generator to reduce
@@ -26,7 +26,7 @@
     #msgr = ???
     #msgr.message(msg)
     print(msg)
-    dt = np.zeros(shape)
+    dt = np.empty(shape, dtype=dtype)
     for i, data in enumerate(iterator):
         #msgr.percent(i, nrows, 2)
         dt[i] = data
@@ -80,10 +80,10 @@
         dta = cpdata(shape, data.execute(slct_data), msg=slct_data)
         # extract the cats
-        slct_cats = "SELECT {cat} FROM {tname};".format(cat=data.key,
-                                                        tname=data.name)
+        slct_cats = "SELECT {cat} FROM {tname};".format(cat=trng.key,
+                                                        tname=trng.name)
         cats = cpdata((n_data, ), (c[0] for c in data.execute(slct_cats)),
-                      msg=slct_cats)
+                      dtype=int, msg=slct_cats)
         # cats = np.array([c[0] for c in data.execute(slct_cats)])
         # training samples
Modified: grass-addons/grass7/vector/v.class.ml/training_extraction.py
--- grass-addons/grass7/vector/v.class.ml/training_extraction.py	2014-11-09 18:08:55 UTC (rev 62687)
+++ grass-addons/grass7/vector/v.class.ml/training_extraction.py	2014-11-09 18:19:12 UTC (rev 62688)
@@ -159,6 +159,7 @@
     msgr = get_msgr()
     tname, tmset = tvect.split('@') if '@' in tvect else (tvect, '')
     vname, vmset = vect.split('@') if '@' in vect else (vect, '')
     with VectorTopo(tname, tmset, mode='r') as trn:
         with VectorTopo(vname, vmset, mode='r') as vct:
             layer_num, layer_name = get_layer_num_name(vct, tlayer)
@@ -167,7 +168,7 @@
             seg_area = Area(c_mapinfo=vct.c_mapinfo)
             n_areas = trn.number_of('areas')
             # check/remove/create a new table
-            table, create_link = make_new_table(vct, layer_name)
+            table, create_link = make_new_table(vct, layer_name, force=True)
             find_lines(table, [l for l in trn.viter('lines')], vct)
             # find and save all the segments
             find_area(table, trn.viter('areas', idonly=True),
Modified: grass-addons/grass7/vector/v.class.ml/v.class.ml.py
--- grass-addons/grass7/vector/v.class.ml/v.class.ml.py	2014-11-09 18:08:55 UTC (rev 62687)
+++ grass-addons/grass7/vector/v.class.ml/v.class.ml.py	2014-11-09 18:19:12 UTC (rev 62688)
@@ -209,7 +209,7 @@
 #%end
 #%option
 #%  key: posinf
-#%  type: double
+#%  type: string
 #%  multiple: yes
 #%  description: Key:Value or Numpy funtion to use to substitute posinf values
 #%  required: no
@@ -256,6 +256,14 @@
 #%  answer: linear,poly,rbf,sigmoid
 #%end
 #%option
+#%  key: svc_poly_range
+#%  type: string
+#%  multiple: yes
+#%  description: polynomial order list to explore SVC domain
+#%  required: no
+#%  answer:
+#%end
+#%option
 #%  key: svc_n_jobs
 #%  type: integer
 #%  multiple: no
@@ -346,6 +354,10 @@
 #%  key: d
 #%  description: Explore the SVC domain
 #%end
+#%flag
+#%  key: a
+#%  description: append the classification results
+#%end
 from __future__ import (absolute_import, division, print_function,
                         unicode_literals)
@@ -420,7 +432,8 @@
 def get_colors(vtraining):
-    with Vector(vtraining, mode='r') as vct:
+    vect, mset = vtraining.split('@') if '@' in vtraining else (vtraining, '')
+    with Vector(vect, mapset=mset, mode='r') as vct:
         cur = vct.table.execute('SELECT cat, color FROM %s;' % vct.name)
         return dict([c for c in cur.fetchall()])
@@ -457,12 +470,13 @@
     if report:
         indent = '    '
         tot = len(array)
-        for key in special:
+        for k in special:
             fmt = '- %15s (%3d/%d, %4.3f%%)'
-            strs = [fmt % (col, cnt, tot, cnt/float(tot)*100)
-                    for col, cnt in zip(cols[np.array(sp[key])], cntr[key])]
-            print('%s:\n%s' % (key, indent), ('\n%s' % indent).join(strs),
-                  sep='')
+            if sp[k]:
+                strs = [fmt % (col, cnt, tot, cnt/float(tot)*100)
+                        for col, cnt in zip(cols[np.array(sp[k])], cntr[k])]
+                print('%s:\n%s' % (k, indent), ('\n%s' % indent).join(strs),
+                      sep='')
     return sp
@@ -495,12 +509,12 @@
     indexes = None
     vect = opt['vector']
     vtraining = opt['vtraining'] if opt['vtraining'] else None
-    scaler = None
+    scaler, decmp = None, None
     vlayer = opt['vlayer'] if opt['vlayer'] else vect + '_stats'
     tlayer = opt['tlayer'] if opt['tlayer'] else vect + '_training'
     rlayer = opt['rlayer'] if opt['rlayer'] else vect + '_results'
-    labels = extract_classes(vtraining, vlayer)
+    labels = extract_classes(vtraining, 1)
     pprint(labels)
     if opt['scalar']:
@@ -509,15 +523,16 @@
                                 with_std='with_std' in scapar)
     if opt['decomposition']:
-        decmp, params = (opt['decomposition'].split('|')
-                         if '|' in opt['decomposition']
-                         else (opt['decomposition'], ''))
+        dec, params = (opt['decomposition'].split('|')
+                       if '|' in opt['decomposition']
+                       else (opt['decomposition'], ''))
         kwargs = ({k: v for k, v in (p.split('=') for p in params.split(','))}
                   if params else {})
-        dec = DECMP[decmp](**kwargs)
+        decmp = DECMP[dec](**kwargs)
     # if training extract training
     if vtraining and flg['e']:
-        msgr.message("Extract training from: <%s>." % vtraining)
+        msgr.message("Extract training from: <%s> to <%s>." % (vtraining, vect))
         extract_training(vect, vtraining, tlayer)
         flg['n'] = True
@@ -565,9 +580,23 @@
     # Substitute (skip cat column)
     Xt, rules_vals = substitute(Xt, rules, cols[1:])
+    Xtoriginal = Xt
+    # scale the data
+    if scaler:
+        msgr.message("Scaling the training data set.")
+        scaler.fit(Xt, Yt)
+        Xt = scaler.transform(Xt)
+    # decompose data
+    if decmp:
+        msgr.message("Decomposing the training data set.")
+        decmp.fit(Xt)
+        Xt = decmp.transform(Xt)
     # Feature importances with forests of trees
     if flg['f']:
+        np.save('training_transformed.npy', Xt)
         importances(Xt, Yt, cols[1:],
                     csv=opt['imp_csv'], img=opt['imp_fig'],
                     # default parameters to save the matplotlib figure
@@ -581,7 +610,7 @@
         msgr.message("Find the optimum training set.")
         best, Xbt, Ybt = optimize_training(cls, Xt, Yt,
                                            labels, #{v: k for k, v in labels.items()},
-                                           scaler,
+                                           scaler, decmp,
                                            num=num, maxiterations=1000)
         msg = "    - save the optimum training data set to: %s."
         msgr.message(msg % opt['npy_btdata'])
@@ -610,17 +639,27 @@
         Xbt = scaler.transform(Xbt)
     if flg['d']:
-        C_range = [float(c) for c in opt['svc_c_range'].split(',')]
-        gamma_range = [float(g) for g in opt['svc_gamma_range'].split(',')]
-        kernel_range = [str(s) for s in opt['svc_kernel_range'].split(',')]
-        poly_range = [int(i) for i in opt['poly_range'].split(',')]
+        C_range = [float(c) for c in opt['svc_c_range'].split(',') if c]
+        gamma_range = [float(g) for g in opt['svc_gamma_range'].split(',') if g]
+        kernel_range = [str(s) for s in opt['svc_kernel_range'].split(',') if s]
+        poly_range = [int(i) for i in opt['svc_poly_range'].split(',') if i]
+        allkwargs = dict(C=C_range, gamma=gamma_range,
+                         kernel=kernel_range, degree=poly_range)
+        kwargs = {}
+        for k in allkwargs:
+            if allkwargs[k]:
+                kwargs[k] = allkwargs[k]
         msgr.message("Exploring the SVC domain.")
-        grid = explore_SVC(Xbt, Ybt, n_folds=3, n_jobs=int(opt['svc_n_jobs']),
-                           C=C_range, gamma=gamma_range, kernel=kernel_range)
+        grid = explore_SVC(Xbt, Ybt, n_folds=5, n_jobs=int(opt['svc_n_jobs']),
+                           **kwargs)
         import pickle
-        pkl = open('grid.pkl', 'w')
+        krnlstr = '_'.join(s for s in opt['svc_kernel_range'].split(',') if s)
+        pkl = open('grid%s.pkl' % krnlstr, 'w')
         pickle.dump(grid, pkl)
         pkl.close()
+#        pkl = open('grid.pkl', 'r')
+#        grid = pickle.load(pkl)
+#        pkl.close()
         plot_grid(grid, save=opt['svc_img'])
     # test the accuracy of different classifiers
@@ -628,7 +667,7 @@
         # test different classifiers
         msgr.message("Exploring different classifiers.")
         msgr.message("cls_id   cls_name          mean     max     min     std")
         res = explorer_clsfiers(classifiers, Xt, Yt, labels=labels,
                                 indexes=indexes, n_folds=5,
                                 bv=flg['v'], extra=flg['x'])
@@ -639,27 +678,43 @@
     if flg['c']:
         # classify
-        cols = []
         data = np.load(opt['npy_data'])
-        pprint(rules_vals)
-        # Substitute (skip cat column)
-        data = substitute(data, rules_vals, cols[1:])
+        indx = np.load(opt['npy_index'])
-        msgr.message("Scaling the whole data set.")
-        data = scaler.transform(data) if scaler else data
+        # Substitute using column values
+        data, dummy = substitute(data, rules, cols[1:])
+        Xt = data[indx]
+        if scaler:
+            msgr.message("Scaling the whole data set.")
+            data = scaler.transform(data)
+        if decmp:
+            decmp.fit(Xt)
+            msgr.message("Decompose the whole data set.")
+            data = decmp.transform(data)
         cats = np.load(opt['npy_cats'])
+        np.save('data_filled_scaled.npy', data)
+        tcols = []
         for cls in classifiers:
-            run_classifier(cls, Xbt, Ybt, Xt, Yt, labels, data,
-                           save=opt['report_class'])
-            cols.append((cls['name'], 'INTEGER'))
+            report = (open(opt['report_class'], "w")
+                      if opt['report_class'] else sys.stdout)
+            run_classifier(cls, Xt, Yt, Xt, Yt, labels, data,
+                           report=report)
+            tcols.append((cls['name'], 'INTEGER'))
-#        import pickle
-#        res = open('res.pkl', 'r')
-#        classifiers = pickle.load(res)
+        import pickle
+        with open('classification_results.pkl', 'w') as res:
+	      pickle.dump(classifiers, res)
+        #classifiers = pickle.load(res)
         msgr.message("Export the results to layer: <%s>" % str(rlayer))
-        export_results(vect, classifiers, cats, rlayer, vtraining, cols,
-                       overwrite(), pkl='res.pkl')
+        export_results(vect, classifiers, cats, rlayer, vtraining, tcols,
+                       overwrite(), pkl='res.pkl', append=flg['a'])
 #        res.close()
     if flg['r']:
@@ -673,15 +728,15 @@
             rasters = [c for c in tab.columns]
             rasters.remove(tab.key)
         v2rst = Module('v.to.rast')
         rclrs = Module('r.colors')
         for rst in rasters:
             v2rst(input=vect, layer=rlayer, type='area',
-                  use='attr', attrcolumn=rst, output=opt['rst_names'] % rst,
-                  rows=4096 * 4, overwrite=overwrite())
+                  use='attr', attrcolumn=rst.encode(),
+                  output=(opt['rst_names'] % rst).encode(),
+                  memory=1000, overwrite=overwrite())
             if rules:
-                rclrs(map=rst, rules='-', stdin_=rules)
+                rclrs(map=rst.encode(), rules='-', stdin_=rules)
 if __name__ == "__main__":
