[GRASS-SVN] r62689 - grass-addons/grass7/vector/v.stats
Sun Nov 9 10:22:26 PST 2014
Author: zarch
Date: 2014-11-09 10:22:26 -0800 (Sun, 09 Nov 2014)
New Revision: 62689
   grass-addons/grass7/vector/v.stats/imp_csv.py
   grass-addons/grass7/vector/v.stats/v.stats.py
   grass-addons/grass7/vector/v.stats/vstats.py
v.stats: bug fix and improvement
Modified: grass-addons/grass7/vector/v.stats/imp_csv.py
--- grass-addons/grass7/vector/v.stats/imp_csv.py	2014-11-09 18:19:12 UTC (rev 62688)
+++ grass-addons/grass7/vector/v.stats/imp_csv.py	2014-11-09 18:22:26 UTC (rev 62689)
@@ -38,31 +38,23 @@
 SKIPSHP = ['area_id', ]
-#SKIPSHP = ['areas', 'red__n', 'red__min', 'red__max', 'red__range', 'red__sum',
-#           'red__mean', 'red__stddev', 'red__variance', 'red__cf_var',
-#           'red__first_quartile', 'red__median', 'red__third_quartile',
-#           'red__percentile_90', 'green__n', 'green__min', 'green__max',
-#           'green__range', 'green__mean', 'green__stddev', 'green__variance',
-#           'green__cf_var', 'green__sum', 'green__first_quartile',
-#           'green__median', 'green__third_quartile', 'green__percentile_90',
-#           'blue__n', 'blue__min', 'blue__max', 'blue__range', 'blue__mean',
-#           'blue__stddev', 'blue__variance', 'blue__cf_var', 'blue__sum',
-#           'blue__first_quartile', 'blue__median', 'blue__third_quartile',
-#           'blue__percentile_90']
-def getrow(shpdata, rstdata, dim):
-    drow = np.zeros((dim, ))
+def getrow(shpdata, rstdata, cols):
+    drow = np.zeros((len(cols), ))
     lenght = len(shpdata)
-    for i, rows in enumerate(zip(shpdata, *[rst[:, 1:] for rst in rstdata])):
+    for i, rows in enumerate(zip(shpdata, *rstdata)):
         glg.G_percent(i, lenght, 2)
         start = 0
         for row in rows:
             end = start + row.shape[0]
+            #print('---')
+            #for c, r in zip(cols[start:end], row):
+            #    print(c[0], r)
             drow[start:end] = row
             start = end
+        #import ipdb; ipdb.set_trace()
         yield drow
@@ -91,7 +83,8 @@
                 skipshp=None, skiprst=None,
                 shpcat=0, rstcat=0,
                 allshpn=ALLSHPN, allrstn=ALLRSTN,
-                allshpt=ALLSHPT, allrstt=ALLRSTT, overwrite=False):
+                allshpt=ALLSHPT, allrstt=ALLRSTT, overwrite=False,
+                separator=';'):
     prefixes = prefixes if prefixes else [csv[:-4] for csv in rstcsv]
     skipshp = skipshp if skipshp else []
     skiprst = skiprst if skiprst else []
@@ -100,65 +93,61 @@
     print("Start loading data from:")
     print("    - %s." % shpcsv, end='')
-    shpdata = np.genfromtxt(shpcsv, delimiter=';', names=True,
-                            usecols=useshpcols,
+    shpdata = np.genfromtxt(shpcsv, delimiter=separator, usecols=useshpcols,
                             dtype=getcols(allshpn, allshpt, skipshp))
     shpdata.sort(order='cat')
+    # remove negative categories
+    shpdata = shpdata[shpdata['cat'] > 0]
     print(' Done.')
     rstdata = []
     for rst in rstcsv:
         print("    - %s." % rst, end='')
-        rstdata.append(np.genfromtxt(rst, delimiter='|', names=True,
-                                     usecols=userstcols,
-                                     missing_values=('nan', '-nan'),
-                                     dtype=getcols(allrstn, allrstt,
-                                                   userstcols)))
-        rstdata[-1].sort(order='zone')
+        rstd = np.genfromtxt(rst, delimiter=separator, names=True,
+                             usecols=userstcols,
+                             missing_values=('nan', '-nan'),
+                             dtype=getcols(allrstn, allrstt, skiprst))
+        rstd.sort(order='zone')
+        rstdata.append(rstd[rstd['zone'] > 0])
         print(' Done.')
+    npz = 'csvfile.npz'
+    print("Save arrays to: %s" % npz)
+    kwargs = {shpcsv: shpdata}
+    for csv, rst in zip(rstcsv, rstdata):
+        kwargs[csv] = rst
+    np.savez_compressed(npz, **kwargs)
     print("Cheking categories and zones correspondance:")
     for i, rst in enumerate(rstdata):
         print("    - <%s>." % rstcsv[i], end='')
 #        if rstcsv[i] == 'median5_contr.csv':
-#            import ipdb; ipdb.set_trace()
         if not (shpdata['cat'] == rst['zone']).all():
             msg = "The categories and the zones are not equal, in <%s>"
             raise ValueError(msg % rstcsv[i])
         print(' Ok.')
     print("Conversion from record array to array")
-    shpdata = np.array(shpdata.tolist())
+    newdtype = np.dtype([(n, '<f8') for n in shpdata.dtype.names])
+    shpdata = shpdata.astype(newdtype).view('<f8').reshape((len(shpdata), -1))
     print('.', end='')
-        rstdata[i] = np.array(rst.tolist())
+        # convert to <f8 and remove the first column with the zones
+        newdtype = np.dtype([(n, '<f8') for n in rst.dtype.names][1:])
+        rstdata[i] = rst.astype(newdtype).view('<f8').reshape((len(rst), -1))
         print('.', end='')
     print('Done.')
     # create the new table
     if tab.exist():
         tab.drop(force=True)
     cols = gettablecols(prefixes, allshpn, allshpt, skipshp,
-                        allrstn, allrstt, skiprst)
+                        # remove zone from raster
+                        allrstn[1:], allrstt[1:], skiprst)
     tab.create(cols)
     cur = tab.conn.cursor()
     print("Merge shape table with raster csv.")
-    tab.insert(getrow(shpdata, rstdata, len(cols)), cursor=cur, many=True)
+    tab.insert(getrow(shpdata, rstdata, cols), cursor=cur, many=True)
     tab.conn.commit()
     print("%d rows inserted." % tab.n_rows())
     return tab
-#link = None
-#with VectorTopo(VSEG, mode='r') as vect:
-#    #link = update_cols(vect.table, CSV, PREFIX, allcsvcols=ALL,
-#    #                   skipcsv=SKIPCSV, skipshp=SKIPSHP)
-#    link = update_cols(vect.table, ECSV, PREFIX, allcsvcols=ALL,
-#                       skipcsv=SKIPCSV, skipshp=ESKIPSHP)
-#    link.layer = vect.layer + 1
-#with Vector(VSEG, mode='rw') as vect:
-#    link = Link(layer=NEW_LAYER, name=NEW_NAME_LAYER, table=NEW_TABLE_NAME)
-#    vect.dblinks.add(link)
Modified: grass-addons/grass7/vector/v.stats/v.stats.py
--- grass-addons/grass7/vector/v.stats/v.stats.py	2014-11-09 18:19:12 UTC (rev 62688)
+++ grass-addons/grass7/vector/v.stats/v.stats.py	2014-11-09 18:22:26 UTC (rev 62689)
@@ -3,7 +3,7 @@
-# MODULE:	    i.segment.hierarchical
+# MODULE:	    v.stats
 # AUTHOR(S):   Pietro Zambelli (University of Trento)
@@ -67,7 +67,7 @@
 #%  multiple: yes
 #%  description: Skip shape columns
 #%  required: no
-#%  answer: label,non_null_cells,null_cells,mean_of_abs,sum,sum_abs
+#%  answer: label,all_cells,non_null_cells,null_cells,mean_of_abs,sum,sum_abs
 #%end
 #%option
 #%  key: shpcsv
@@ -113,19 +113,27 @@
 #%  multiple: no
 #%  required: no
 #%end
+#%option
+#%  key: separator
+#%  type: string
+#%  description: New vector layer that will be add to the vector map
+#%  multiple: no
+#%  required: no
+#%  answer: ;
+#%end
+#%option
+#%  key: nprocs
+#%  type: integer
+#%  description: Number of process that will be used
+#%  multiple: no
+#%  required: no
+#%  answer: 1
+#%end
 #%flag
 #%  key: r
 #%  description: Read from existing CSV files
 #%end
-# convert segments to vector
-r.to.vect input=seg_0.05 at pietro output=seg005 type=area
-v.category input=seg005 layer=1,2,3,4,5 output=seg_005 type=area option=transfer
-v.to.rast input=seg_005 output=vseg_005
 import sys
 import os
@@ -161,6 +169,7 @@
     rstcsv = (opt['rstcsv'].split(',') if opt['rstcsv']
               else [split(rst)[0] + '.csv' for rst in rasters])
     zones = opt['zones'] if opt['zones'] else vname + '_zones'
+    nprocs = int(opt.get('nprocs', 1))
     if rasters:
         if rprefix and len(rasters) != len(rprefix):
             raise
@@ -176,25 +185,26 @@
                     else vname + '_stats')
     newtabname = opt['newtabname'] if opt['newtabname'] else vname + '_stats'
     rstpercentile = float(opt['rstpercentile'])
+    separator = opt.get('separator', ';')
     # compute
     if not os.path.exists(shpcsv):
-        get_shp_csv(opt['vector'], shpcsv, overwrite)
+        get_shp_csv(opt['vector'], shpcsv, overwrite, separator)
     if not get_mapset_raster(zones):
         get_zones(opt['vector'], zones, layer)
     if not rstcsv or not os.path.exists(rstcsv[0]):
-        get_rst_csv(rasters, zones, rstcsv, rstpercentile, overwrite)
+        get_rst_csv(rasters, zones, rstcsv, rstpercentile, overwrite,
+                    nprocs, separator)
     newlink = Link(newlayer, newlayername, newtabname)
     newtab = newlink.table()
     with Vector(vname, vmset, mode='r', layer=layer) as vct:
         mode = 'r' if newlink in vct.dblinks else 'rw'
     with VectorTopo(vname, vmset, mode=mode, layer=layer) as vct:
-        update_cols(newtab, shpcsv, rstcsv, prefixes, skipshp, skiprst)
+        update_cols(newtab, shpcsv, rstcsv, prefixes, skipshp, skiprst, separator=separator)
         if mode == 'rw':
             # add the new link
Modified: grass-addons/grass7/vector/v.stats/vstats.py
--- grass-addons/grass7/vector/v.stats/vstats.py	2014-11-09 18:19:12 UTC (rev 62688)
+++ grass-addons/grass7/vector/v.stats/vstats.py	2014-11-09 18:22:26 UTC (rev 62689)
@@ -6,15 +6,15 @@
 from __future__ import print_function, division
 import os
-from grass.pygrass.modules import Module
+from grass.pygrass.modules import Module, ParallelModuleQueue
-def get_shp_csv(vector, csv=None, overwrite=False):
+def get_shp_csv(vector, csv=None, overwrite=False, separator=';'):
     vasts = Module('v.area.stats')
     csv = vector + '.csv' if csv is None else csv
     if os.path.exists(csv) and overwrite:
         os.remove(csv)
-    vasts(map=vector, output=csv, overwrite=overwrite)
+    vasts(map=vector, output=csv, overwrite=overwrite, separator=separator)
     return csv
@@ -24,13 +24,14 @@
     rclr = Module("r.colors", map=zones, color="random")
-def get_rst_csv(rasters, zones, csvfiles, percentile=90., overwrite=False):
-    procs = []
+def get_rst_csv(rasters, zones, csvfiles, percentile=90., overwrite=False,
+                nprocs=1, separator=';'):
+    queue = ParallelModuleQueue(nprocs=nprocs)
     for rast, csv in zip(rasters, csvfiles):
-        procs.append(Module('r.univar2', map=rast, zones=zones,
-                            percentile=percentile, output=csv,
-                            overwrite=overwrite, flags='e', finish_=False))
+        print(rast, csv)
+        queue.put(Module('r.univar2', map=rast, zones=zones,
+                         percentile=percentile, output=csv, separator=separator,
+                         overwrite=overwrite, flags='et', run_=False))
     # wait the end of all process
-    for proc in procs:
-        proc.popen.wait()
+    queue.wait()
     return csvfiles
