[GRASS-SVN] r64025 - grass/trunk/raster3d/r3.info
Fri Jan 9 00:37:34 PST 2015
Author: neteler
Date: 2015-01-09 00:37:34 -0800 (Fri, 09 Jan 2015)
New Revision: 64025
Added:
   grass/trunk/raster3d/r3.info/main.c
Removed:
   grass/trunk/raster3d/r3.info/r3.info.main.c
r3.info: 3d cell -> raster_3d in msg; use standard filename
Copied: grass/trunk/raster3d/r3.info/main.c (from rev 63994, grass/trunk/raster3d/r3.info/r3.info.main.c)
--- grass/trunk/raster3d/r3.info/main.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.info/main.c	2015-01-09 08:37:34 UTC (rev 64025)
@@ -0,0 +1,496 @@
+* MODULE:       r3.info
+* AUTHOR(S):    Roman Waupotitsch, Michael Shapiro, Helena Mitasova, Bill Brown,
+*               Lubos Mitas, Jaro Hofierka
+* PURPOSE:      Outputs basic information about a user-specified 3D raster map layer.
+* COPYRIGHT:    (C) 2005 by the GRASS Development Team
+*               This program is free software under the GNU General Public
+*               License (>=v2). Read the file COPYING that comes with GRASS
+*               for details.
+/* \todo
+ *    History support still not full implemented.
+ *    Only parts of the timestep functionality are implemented, the timzone is missed ;).
+/*local prototype */
+int format_double(double value, char *buf);
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/raster3d.h>
+#include <grass/glocale.h>
+#define printline(x) fprintf (out," | %-74.74s |\n",x)
+#define divider(x) \
+    fprintf (out," %c",x);\
+    for (i = 0; i < 76; i++)\
+        fprintf(out,"-");\
+    fprintf (out,"%c\n",x)
+#define TMP_LENGTH 100
+static char *name;
+int main(int argc, char *argv[])
+    const char *mapset;
+    char *line = NULL;
+    char tmp1[TMP_LENGTH], tmp2[TMP_LENGTH], tmp3[TMP_LENGTH];
+    char timebuff[256];
+    int i;
+    FILE *out;
+    RASTER3D_Region cellhd;
+    RASTER3D_Map *g3map;
+    struct Categories cats;
+    struct History hist;
+    struct TimeStamp ts;
+    int head_ok;
+    int cats_ok;
+    int hist_ok;
+    int time_ok = 0, first_time_ok = 0, second_time_ok = 0;
+    struct Option *opt1;
+    struct Flag *rflag;
+    struct Flag *gflag;
+    struct Flag *hflag;
+    int data_type;
+    struct GModule *module;
+    double dmin, dmax;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("raster3d"));
+    G_add_keyword(_("metadata"));
+    G_add_keyword(_("extent"));
+    G_add_keyword(_("voxel"));
+    module->description =
+	_("Outputs basic information about a user-specified 3D raster map layer.");
+    opt1 = G_define_standard_option(G_OPT_R3_MAP);
+    gflag = G_define_flag();
+    gflag->key = 'g';
+    gflag->description = _("Print raster3d information in shell style");
+    rflag = G_define_flag();
+    rflag->key = 'r';
+    rflag->description = _("Print range in shell style only");
+    hflag = G_define_flag();
+    hflag->key = 'h';
+    hflag->description = _("Print raster history instead of info");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    name = G_store(opt1->answer);
+    mapset = G_find_raster3d(name, "");
+    if (mapset == NULL)
+	G_fatal_error(_("3D Raster map <%s> not found"), name);
+    /*We need to open the map */
+    g3map =
+	Rast3d_open_cell_old(name, mapset, RASTER3D_DEFAULT_WINDOW,
+			RASTER3D_TILE_SAME_AS_FILE, RASTER3D_NO_CACHE);
+    if (NULL == g3map)
+	G_fatal_error(_("Unable to open 3D raster map <%s>"), name);
+    /*Get the maptype */
+    data_type = Rast3d_file_type_map(g3map);
+    head_ok = Rast3d_read_region_map(name, mapset, &cellhd) >= 0;
+    hist_ok = Rast3d_read_history(name, mapset, &hist) >= 0;
+    cats_ok = Rast3d_read_cats(name, mapset, &cats) >= 0;
+    /*Check the Timestamp */
+    time_ok = G_read_raster3d_timestamp(name, mapset, &ts) > 0;
+    /*Check for valid entries, show none if no entire available! */
+    if (time_ok) {
+	if (ts.count > 0)
+	    first_time_ok = 1;
+	if (ts.count > 1)
+	    second_time_ok = 1;
+    out = stdout;
+    /*Show the info if no flag is set */
+    if (!rflag->answer && !gflag->answer && !hflag->answer) {
+	divider('+');
+	if (G_asprintf(&line, "Layer:    %-29.29s  Date: %s", name,
+		       hist_ok ? Rast_get_history(&hist, HIST_MAPID) : "??") > 0)
+	    printline(line);
+	else
+	    G_fatal_error(_("Cannot allocate memory for string"));
+	if (G_asprintf(&line, "Mapset:   %-29.29s  Login of Creator: %s", mapset,
+	     hist_ok ? Rast_get_history(&hist, HIST_CREATOR) : "??") > 0)
+	    printline(line);
+	else
+	if (G_asprintf(&line, "Location: %s", G_location()) > 0)
+	    printline(line);
+	else
+	if (G_asprintf(&line, "DataBase: %s", G_gisdbase()) > 0)
+	    printline(line);
+	else
+	if (G_asprintf(&line, "Title:    %s",
+                hist_ok ? Rast_get_history(&hist, HIST_TITLE) : "??") > 0)
+	    printline(line);
+	else
+	if (G_asprintf(&line, "Units:    %s", Rast3d_get_unit(g3map)))
+	    printline(line);
+	else
+	if (G_asprintf(&line, "Vertical unit: %s", Rast3d_get_vertical_unit(g3map)))
+	    printline(line);
+	else
+	/*This shows the TimeStamp */
+	if (time_ok && (first_time_ok || second_time_ok)) {
+	    G_format_timestamp(&ts, timebuff);
+	    /*Create the r.info timestamp string */
+	    if (G_asprintf(&line, "Timestamp: %s", timebuff) > 0)
+		printline(line);
+	    else
+	else {
+	    if (G_asprintf(&line, "Timestamp: none") > 0)
+		printline(line);
+	    else
+	divider('|');
+	printline("");
+	if (cats_ok) {
+	    format_double((double)cats.num, tmp1);
+	if (G_asprintf(&line, "  Type of Map:  %-20.20s Number of Categories: %-9s",
+	     "raster_3d", cats_ok ? tmp1 : "??") > 0)
+	    printline(line);
+	else
+	if (G_asprintf(&line, "  Data Type:    %s",
+		       (data_type == FCELL_TYPE ? "FCELL" :
+			(data_type == DCELL_TYPE ? "DCELL" : "??"))) > 0)
+	    printline(line);
+	else
+	if (head_ok) {
+	    if (G_asprintf(&line, "  Rows:         %d", cellhd.rows) > 0)
+		printline(line);
+	    else
+	    if (G_asprintf(&line, "  Columns:      %d", cellhd.cols) > 0)
+		printline(line);
+	    else
+	    if (G_asprintf(&line, "  Depths:       %d", cellhd.depths) > 0)
+		printline(line);
+	    else
+	    if (G_asprintf
+		(&line, "  Total Cells:  %ld",
+		 (long)cellhd.rows * cellhd.cols * cellhd.depths) > 0)
+		printline(line);
+	    else
+            double totalSize = 0;
+            for(i = 0; i < g3map->nTiles; i++)
+                totalSize += g3map->tileLength[i];
+	    if (G_asprintf(&line, "  Total size:           %ld Bytes",
+                (long)(totalSize)) > 0)
+		printline(line);
+	    else
+	    if (G_asprintf(&line, "  Number of tiles:      %d",
+                g3map->nTiles) > 0)
+		printline(line);
+	    else
+	    if (G_asprintf(&line, "  Mean tile size:       %ld Bytes",
+                (long)(totalSize/g3map->nTiles)) > 0)
+		printline(line);
+	    else
+            int tileSize = 0;
+            if(data_type == FCELL_TYPE)
+                tileSize = sizeof(FCELL) * g3map->tileX * g3map->tileY *
+                        ((RASTER3D_Map* )g3map)->tileZ;
+            if(data_type == DCELL_TYPE)
+                tileSize = sizeof(DCELL) * g3map->tileX * g3map->tileY *
+                        g3map->tileZ;
+	    if (G_asprintf(&line, "  Tile size in memory:  %ld Bytes",
+                (long)(tileSize)) > 0)
+		printline(line);
+	    else
+	    if (G_asprintf(&line, "  Number of tiles in x, y and  z:   %d, %d, %d",
+                                  g3map->nx, g3map->ny,
+                                  g3map->nz) > 0)
+		printline(line);
+	    else
+	    if (G_asprintf(&line, "  Dimension of a tile in x, y, z:   %d, %d, %d",
+                                  g3map->tileX, g3map->tileY,
+                                  g3map->tileZ) > 0)
+		printline(line);
+	    else
+            printline("");
+	    if (G_asprintf
+		(&line, "       Projection: %s (zone %d)",
+		 G_database_projection_name(), G_zone()) > 0)
+		printline(line);
+	    else
+	    G_format_northing(cellhd.north, tmp1, cellhd.proj);
+	    G_format_northing(cellhd.south, tmp2, cellhd.proj);
+	    G_format_resolution(cellhd.ns_res, tmp3, cellhd.proj);
+	    if (G_asprintf
+		(&line, "           N: %10s    S: %10s   Res: %5s", tmp1,
+		 tmp2, tmp3) > 0)
+		printline(line);
+	    else
+	    G_format_easting(cellhd.east, tmp1, cellhd.proj);
+	    G_format_easting(cellhd.west, tmp2, cellhd.proj);
+	    G_format_resolution(cellhd.ew_res, tmp3, cellhd.proj);
+	    if (G_asprintf
+		(&line, "           E: %10s    W: %10s   Res: %5s", tmp1,
+		 tmp2, tmp3) > 0)
+		printline(line);
+	    else
+	    format_double(cellhd.top, tmp1);
+	    format_double(cellhd.bottom, tmp2);
+	    format_double(cellhd.tb_res, tmp3);
+	    if (G_asprintf
+		(&line, "           T: %10s    B: %10s   Res: %5s", tmp1,
+		 tmp2, tmp3) > 0)
+		printline(line);
+	    else
+	    if (0 == Rast3d_range_load(g3map))
+		G_fatal_error(_("Unable to read range of 3D raster map <%s>"), name);
+	    Rast3d_range_min_max(g3map, &dmin, &dmax);
+            if(dmin != dmin)
+                sprintf(tmp1, "%s", "NULL");
+            else
+	        format_double(dmin, tmp1);
+            if(dmax != dmax)
+                sprintf(tmp2, "%s", "NULL");
+            else
+	        format_double(dmax, tmp2);
+	    if (G_asprintf
+		(&line, "  Range of data:   min = %10s max = %10s", tmp1,
+		 tmp2) > 0)
+		printline(line);
+	    else
+	printline("");
+	if (hist_ok) {
+	    printline("  Data Source:");
+	    if (G_asprintf(&line, "   %s", Rast_get_history(&hist, HIST_DATSRC_1)) > 0)
+		printline(line);
+	    else
+	    if (G_asprintf(&line, "   %s", Rast_get_history(&hist, HIST_DATSRC_2)) > 0)
+		printline(line);
+	    else
+	    printline("");
+	    printline("  Data Description:");
+	    if (G_asprintf(&line, "   %s", Rast_get_history(&hist, HIST_KEYWRD)) > 0)
+		printline(line);
+	    else
+	    printline("");
+	    if (Rast_history_length(&hist)) {
+		printline("  Comments:  ");
+		for (i = 0; i < Rast_history_length(&hist); i++)
+		    if (G_asprintf(&line, "   %s", Rast_history_line(&hist, i)) > 0)
+			printline(line);
+		    else
+	    printline("");
+	divider('+');
+	fprintf(out, "\n");
+    else {/* Print information in shell style*/
+	if (gflag->answer) {
+	    sprintf(tmp1, "%f", cellhd.north);
+	    sprintf(tmp2, "%f", cellhd.south);
+	    G_trim_decimal(tmp1);
+	    G_trim_decimal(tmp2);
+	    fprintf(out, "north=%s\n", tmp1);
+	    fprintf(out, "south=%s\n", tmp2);
+	    sprintf(tmp1, "%f", cellhd.east);
+	    sprintf(tmp2, "%f", cellhd.west);
+	    fprintf(out, "east=%s\n", tmp1);
+	    fprintf(out, "west=%s\n", tmp2);
+	    fprintf(out, "bottom=%g\n", cellhd.bottom);
+	    fprintf(out, "top=%g\n", cellhd.top);
+	    fprintf(out, "nsres=%s\n", tmp3);
+	    fprintf(out, "ewres=%s\n", tmp3);
+	    fprintf(out, "tbres=%g\n", cellhd.tb_res);
+	    fprintf(out, "rows=%d\n", cellhd.rows);
+	    fprintf(out, "cols=%d\n", cellhd.cols);
+	    fprintf(out, "depths=%d\n", cellhd.depths);
+	    fprintf(out, "datatype=\"%s\"\n",
+		    data_type == FCELL_TYPE ? "FCELL" :
+		    data_type == DCELL_TYPE ? "DCELL" :
+		fprintf(out, "timestamp=\"%s\"\n", timebuff);
+	    else {
+		fprintf(out, "timestamp=\"none\"\n");
+	    fprintf(out, "units=\"%s\"\n", Rast3d_get_unit(g3map));
+	    fprintf(out, "vertical_units=\"%s\"\n", Rast3d_get_vertical_unit(g3map));
+	    fprintf(out, "tilenumx=%d\n", g3map->nx);
+	    fprintf(out, "tilenumy=%d\n", g3map->ny);
+	    fprintf(out, "tilenumz=%d\n", g3map->nz);
+	    fprintf(out, "tiledimx=%d\n", g3map->tileX);
+	    fprintf(out, "tiledimy=%d\n", g3map->tileY);
+	    fprintf(out, "tiledimz=%d\n", g3map->tileZ);
+	if (rflag->answer) {
+            if(dmin != dmin)
+	        fprintf(out, "min=NULL\n");
+            else
+	        fprintf(out, "min=%f\n", dmin);
+            if(dmax != dmax)
+	        fprintf(out, "max=NULL\n");
+            else
+	        fprintf(out, "max=%f\n", dmax);
+	if (hflag->answer) {
+	    if (hist_ok) {
+		fprintf(out, "Title:\n");
+		fprintf(out, "   %s\n", Rast_get_history(&hist, HIST_TITLE));
+		fprintf(out, "Data Source:\n");
+		fprintf(out, "   %s\n", Rast_get_history(&hist, HIST_DATSRC_1));
+		fprintf(out, "   %s\n", Rast_get_history(&hist, HIST_DATSRC_2));
+		fprintf(out, "Data Description:\n");
+		fprintf(out, "   %s\n", Rast_get_history(&hist, HIST_KEYWRD));
+		    fprintf(out, "Comments:\n");
+			fprintf(out, "   %s\n", Rast_history_line(&hist, i));
+	    else {
+		G_fatal_error(_("Error while reading history file"));
+    /*Close the opened map */
+    if (!Rast3d_close(g3map))
+	G_fatal_error(_("Unable to close 3D raster map <%s>"), name);
+    return 0;
+    sprintf(buf, "%.8f", value);
+    G_trim_decimal(buf);
+    return 0;
Deleted: grass/trunk/raster3d/r3.info/r3.info.main.c
--- grass/trunk/raster3d/r3.info/r3.info.main.c	2015-01-09 08:35:55 UTC (rev 64024)
+++ grass/trunk/raster3d/r3.info/r3.info.main.c	2015-01-09 08:37:34 UTC (rev 64025)
@@ -1,496 +0,0 @@
-* MODULE:       r3.info
-* AUTHOR(S):    Roman Waupotitsch, Michael Shapiro, Helena Mitasova, Bill Brown,
-*               Lubos Mitas, Jaro Hofierka
-* PURPOSE:      Outputs basic information about a user-specified 3D raster map layer.
-* COPYRIGHT:    (C) 2005 by the GRASS Development Team
-*               This program is free software under the GNU General Public
-*               License (>=v2). Read the file COPYING that comes with GRASS
-*               for details.
-/* \todo
- *    History support still not full implemented.
- *    Only parts of the timestep functionality are implemented, the timzone is missed ;).
-/*local prototype */
-int format_double(double value, char *buf);
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/raster3d.h>
-#include <grass/glocale.h>
-#define printline(x) fprintf (out," | %-74.74s |\n",x)
-#define divider(x) \
-    fprintf (out," %c",x);\
-    for (i = 0; i < 76; i++)\
-        fprintf(out,"-");\
-    fprintf (out,"%c\n",x)
-#define TMP_LENGTH 100
-static char *name;
-int main(int argc, char *argv[])
-    const char *mapset;
-    char *line = NULL;
-    char tmp1[TMP_LENGTH], tmp2[TMP_LENGTH], tmp3[TMP_LENGTH];
-    char timebuff[256];
-    int i;
-    FILE *out;
-    RASTER3D_Region cellhd;
-    RASTER3D_Map *g3map;
-    struct Categories cats;
-    struct History hist;
-    struct TimeStamp ts;
-    int head_ok;
-    int cats_ok;
-    int hist_ok;
-    int time_ok = 0, first_time_ok = 0, second_time_ok = 0;
-    struct Option *opt1;
-    struct Flag *rflag;
-    struct Flag *gflag;
-    struct Flag *hflag;
-    int data_type;
-    struct GModule *module;
-    double dmin, dmax;
-    G_gisinit(argv[0]);
-    module = G_define_module();
-    G_add_keyword(_("raster3d"));
-    G_add_keyword(_("metadata"));
-    G_add_keyword(_("extent"));
-    G_add_keyword(_("voxel"));
-    module->description =
-	_("Outputs basic information about a user-specified 3D raster map layer.");
-    opt1 = G_define_standard_option(G_OPT_R3_MAP);
-    gflag = G_define_flag();
-    gflag->key = 'g';
-    gflag->description = _("Print raster3d information in shell style");
-    rflag = G_define_flag();
-    rflag->key = 'r';
-    rflag->description = _("Print range in shell style only");
-    hflag = G_define_flag();
-    hflag->key = 'h';
-    hflag->description = _("Print raster history instead of info");
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
-    name = G_store(opt1->answer);
-    mapset = G_find_raster3d(name, "");
-    if (mapset == NULL)
-	G_fatal_error(_("3D Raster map <%s> not found"), name);
-    /*We need to open the map */
-    g3map =
-	Rast3d_open_cell_old(name, mapset, RASTER3D_DEFAULT_WINDOW,
-			RASTER3D_TILE_SAME_AS_FILE, RASTER3D_NO_CACHE);
-    if (NULL == g3map)
-	G_fatal_error(_("Unable to open 3D raster map <%s>"), name);
-    /*Get the maptype */
-    data_type = Rast3d_file_type_map(g3map);
-    head_ok = Rast3d_read_region_map(name, mapset, &cellhd) >= 0;
-    hist_ok = Rast3d_read_history(name, mapset, &hist) >= 0;
-    cats_ok = Rast3d_read_cats(name, mapset, &cats) >= 0;
-    /*Check the Timestamp */
-    time_ok = G_read_raster3d_timestamp(name, mapset, &ts) > 0;
-    /*Check for valid entries, show none if no entire available! */
-    if (time_ok) {
-	if (ts.count > 0)
-	    first_time_ok = 1;
-	if (ts.count > 1)
-	    second_time_ok = 1;
-    out = stdout;
-    /*Show the info if no flag is set */
-    if (!rflag->answer && !gflag->answer && !hflag->answer) {
-	divider('+');
-	if (G_asprintf(&line, "Layer:    %-29.29s  Date: %s", name,
-		       hist_ok ? Rast_get_history(&hist, HIST_MAPID) : "??") > 0)
-	    printline(line);
-	else
-	    G_fatal_error(_("Cannot allocate memory for string"));
-	if (G_asprintf(&line, "Mapset:   %-29.29s  Login of Creator: %s", mapset,
-	     hist_ok ? Rast_get_history(&hist, HIST_CREATOR) : "??") > 0)
-	    printline(line);
-	else
-	if (G_asprintf(&line, "Location: %s", G_location()) > 0)
-	    printline(line);
-	else
-	if (G_asprintf(&line, "DataBase: %s", G_gisdbase()) > 0)
-	    printline(line);
-	else
-	if (G_asprintf(&line, "Title:    %s",
-                hist_ok ? Rast_get_history(&hist, HIST_TITLE) : "??") > 0)
-	    printline(line);
-	else
-	if (G_asprintf(&line, "Units:    %s", Rast3d_get_unit(g3map)))
-	    printline(line);
-	else
-	if (G_asprintf(&line, "Vertical unit: %s", Rast3d_get_vertical_unit(g3map)))
-	    printline(line);
-	else
-	/*This shows the TimeStamp */
-	if (time_ok && (first_time_ok || second_time_ok)) {
-	    G_format_timestamp(&ts, timebuff);
-	    /*Create the r.info timestamp string */
-	    if (G_asprintf(&line, "Timestamp: %s", timebuff) > 0)
-		printline(line);
-	    else
-	else {
-	    if (G_asprintf(&line, "Timestamp: none") > 0)
-		printline(line);
-	    else
-	divider('|');
-	printline("");
-	if (cats_ok) {
-	    format_double((double)cats.num, tmp1);
-	if (G_asprintf(&line, "  Type of Map:  %-20.20s Number of Categories: %-9s",
-	     "3d cell", cats_ok ? tmp1 : "??") > 0)
-	    printline(line);
-	else
-	if (G_asprintf(&line, "  Data Type:    %s",
-		       (data_type == FCELL_TYPE ? "FCELL" :
-			(data_type == DCELL_TYPE ? "DCELL" : "??"))) > 0)
-	    printline(line);
-	else
-	if (head_ok) {
-	    if (G_asprintf(&line, "  Rows:         %d", cellhd.rows) > 0)
-		printline(line);
-	    else
-	    if (G_asprintf(&line, "  Columns:      %d", cellhd.cols) > 0)
-		printline(line);
-	    else
-	    if (G_asprintf(&line, "  Depths:       %d", cellhd.depths) > 0)
-		printline(line);
-	    else
-	    if (G_asprintf
-		(&line, "  Total Cells:  %ld",
-		 (long)cellhd.rows * cellhd.cols * cellhd.depths) > 0)
-		printline(line);
-	    else
-            double totalSize = 0;
-            for(i = 0; i < g3map->nTiles; i++)
-                totalSize += g3map->tileLength[i];
-	    if (G_asprintf(&line, "  Total size:           %ld Bytes",
-                (long)(totalSize)) > 0)
-		printline(line);
-	    else
-	    if (G_asprintf(&line, "  Number of tiles:      %d",
-                g3map->nTiles) > 0)
-		printline(line);
-	    else
-	    if (G_asprintf(&line, "  Mean tile size:       %ld Bytes",
-                (long)(totalSize/g3map->nTiles)) > 0)
-		printline(line);
-	    else
-            int tileSize = 0;
-            if(data_type == FCELL_TYPE)
-                tileSize = sizeof(FCELL) * g3map->tileX * g3map->tileY *
-                        ((RASTER3D_Map* )g3map)->tileZ;
-            if(data_type == DCELL_TYPE)
-                tileSize = sizeof(DCELL) * g3map->tileX * g3map->tileY *
-                        g3map->tileZ;
-	    if (G_asprintf(&line, "  Tile size in memory:  %ld Bytes",
-                (long)(tileSize)) > 0)
-		printline(line);
-	    else
-	    if (G_asprintf(&line, "  Number of tiles in x, y and  z:   %d, %d, %d",
-                                  g3map->nx, g3map->ny,
-                                  g3map->nz) > 0)
-		printline(line);
-	    else
-	    if (G_asprintf(&line, "  Dimension of a tile in x, y, z:   %d, %d, %d",
-                                  g3map->tileX, g3map->tileY,
-                                  g3map->tileZ) > 0)
-		printline(line);
-	    else
-            printline("");
-	    if (G_asprintf
-		(&line, "       Projection: %s (zone %d)",
-		 G_database_projection_name(), G_zone()) > 0)
-		printline(line);
-	    else
-	    G_format_northing(cellhd.north, tmp1, cellhd.proj);
-	    G_format_northing(cellhd.south, tmp2, cellhd.proj);
-	    G_format_resolution(cellhd.ns_res, tmp3, cellhd.proj);
-	    if (G_asprintf
-		(&line, "           N: %10s    S: %10s   Res: %5s", tmp1,
-		 tmp2, tmp3) > 0)
-		printline(line);
-	    else
-	    G_format_easting(cellhd.east, tmp1, cellhd.proj);
-	    G_format_easting(cellhd.west, tmp2, cellhd.proj);
-	    G_format_resolution(cellhd.ew_res, tmp3, cellhd.proj);
-	    if (G_asprintf
-		(&line, "           E: %10s    W: %10s   Res: %5s", tmp1,
-		 tmp2, tmp3) > 0)
-		printline(line);
-	    else
-	    format_double(cellhd.top, tmp1);
-	    format_double(cellhd.bottom, tmp2);
-	    format_double(cellhd.tb_res, tmp3);
-	    if (G_asprintf
-		(&line, "           T: %10s    B: %10s   Res: %5s", tmp1,
-		 tmp2, tmp3) > 0)
-		printline(line);
-	    else
-	    if (0 == Rast3d_range_load(g3map))
-		G_fatal_error(_("Unable to read range of 3D raster map <%s>"), name);
-	    Rast3d_range_min_max(g3map, &dmin, &dmax);
-            if(dmin != dmin)
-                sprintf(tmp1, "%s", "NULL");
-            else
-	        format_double(dmin, tmp1);
-            if(dmax != dmax)
-                sprintf(tmp2, "%s", "NULL");
-            else
-	        format_double(dmax, tmp2);
-	    if (G_asprintf
-		(&line, "  Range of data:   min = %10s max = %10s", tmp1,
-		 tmp2) > 0)
-		printline(line);
-	    else
-	printline("");
-	if (hist_ok) {
-	    printline("  Data Source:");
-	    if (G_asprintf(&line, "   %s", Rast_get_history(&hist, HIST_DATSRC_1)) > 0)
-		printline(line);
-	    else
-	    if (G_asprintf(&line, "   %s", Rast_get_history(&hist, HIST_DATSRC_2)) > 0)
-		printline(line);
-	    else
-	    printline("");
-	    printline("  Data Description:");
-	    if (G_asprintf(&line, "   %s", Rast_get_history(&hist, HIST_KEYWRD)) > 0)
-		printline(line);
-	    else
-	    printline("");
-	    if (Rast_history_length(&hist)) {
-		printline("  Comments:  ");
-		for (i = 0; i < Rast_history_length(&hist); i++)
-		    if (G_asprintf(&line, "   %s", Rast_history_line(&hist, i)) > 0)
-			printline(line);
-		    else
-	    printline("");
-	divider('+');
-	fprintf(out, "\n");
-    else {/* Print information in shell style*/
-	if (gflag->answer) {
-	    sprintf(tmp1, "%f", cellhd.north);
-	    sprintf(tmp2, "%f", cellhd.south);
-	    G_trim_decimal(tmp1);
-	    G_trim_decimal(tmp2);
-	    fprintf(out, "north=%s\n", tmp1);
-	    fprintf(out, "south=%s\n", tmp2);
-	    sprintf(tmp1, "%f", cellhd.east);
-	    sprintf(tmp2, "%f", cellhd.west);
-	    fprintf(out, "east=%s\n", tmp1);
-	    fprintf(out, "west=%s\n", tmp2);
-	    fprintf(out, "bottom=%g\n", cellhd.bottom);
-	    fprintf(out, "top=%g\n", cellhd.top);
-	    fprintf(out, "nsres=%s\n", tmp3);
-	    fprintf(out, "ewres=%s\n", tmp3);
-	    fprintf(out, "tbres=%g\n", cellhd.tb_res);
-	    fprintf(out, "rows=%d\n", cellhd.rows);
-	    fprintf(out, "cols=%d\n", cellhd.cols);
-	    fprintf(out, "depths=%d\n", cellhd.depths);
-	    fprintf(out, "datatype=\"%s\"\n",
-		    data_type == FCELL_TYPE ? "FCELL" :
-		    data_type == DCELL_TYPE ? "DCELL" :
-		fprintf(out, "timestamp=\"%s\"\n", timebuff);
-	    else {
-		fprintf(out, "timestamp=\"none\"\n");
-	    fprintf(out, "units=\"%s\"\n", Rast3d_get_unit(g3map));
-	    fprintf(out, "vertical_units=\"%s\"\n", Rast3d_get_vertical_unit(g3map));
-	    fprintf(out, "tilenumx=%d\n", g3map->nx);
-	    fprintf(out, "tilenumy=%d\n", g3map->ny);
-	    fprintf(out, "tilenumz=%d\n", g3map->nz);
-	    fprintf(out, "tiledimx=%d\n", g3map->tileX);
-	    fprintf(out, "tiledimy=%d\n", g3map->tileY);
-	    fprintf(out, "tiledimz=%d\n", g3map->tileZ);
-	if (rflag->answer) {
-            if(dmin != dmin)
-	        fprintf(out, "min=NULL\n");
-            else
-	        fprintf(out, "min=%f\n", dmin);
-            if(dmax != dmax)
-	        fprintf(out, "max=NULL\n");
-            else
-	        fprintf(out, "max=%f\n", dmax);
-	if (hflag->answer) {
-	    if (hist_ok) {
-		fprintf(out, "Title:\n");
-		fprintf(out, "   %s\n", Rast_get_history(&hist, HIST_TITLE));
-		fprintf(out, "Data Source:\n");
-		fprintf(out, "   %s\n", Rast_get_history(&hist, HIST_DATSRC_1));
-		fprintf(out, "   %s\n", Rast_get_history(&hist, HIST_DATSRC_2));
-		fprintf(out, "Data Description:\n");
-		fprintf(out, "   %s\n", Rast_get_history(&hist, HIST_KEYWRD));
-		    fprintf(out, "Comments:\n");
-			fprintf(out, "   %s\n", Rast_history_line(&hist, i));
-	    else {
-		G_fatal_error(_("Error while reading history file"));
-    /*Close the opened map */
-    if (!Rast3d_close(g3map))
-	G_fatal_error(_("Unable to close 3D raster map <%s>"), name);
-    return 0;
-    sprintf(buf, "%.8f", value);
-    G_trim_decimal(buf);
-    return 0;
