[GRASS-SVN] r64026 - in grass/trunk/raster3d: r3.flow r3.gradient r3.in.ascii r3.in.bin r3.in.v5d r3.info r3.mask r3.mkdspf r3.neighbors r3.null r3.out.ascii r3.out.bin r3.out.netcdf r3.out.v5d r3.out.vtk r3.stats r3.support r3.timestamp
Fri Jan 9 00:59:16 PST 2015
Author: neteler
Date: 2015-01-09 00:59:16 -0800 (Fri, 09 Jan 2015)
New Revision: 64026
Added:
   grass/trunk/raster3d/r3.timestamp/main.c
Removed:
   grass/trunk/raster3d/r3.timestamp/r3.timestamp.main.c
   grass/trunk/raster3d/r3.flow/main.c
   grass/trunk/raster3d/r3.flow/test_main.c
   grass/trunk/raster3d/r3.gradient/main.c
   grass/trunk/raster3d/r3.in.ascii/main.c
   grass/trunk/raster3d/r3.in.bin/main.c
   grass/trunk/raster3d/r3.in.v5d/main.c
   grass/trunk/raster3d/r3.info/main.c
   grass/trunk/raster3d/r3.mask/main.c
   grass/trunk/raster3d/r3.mkdspf/main.c
   grass/trunk/raster3d/r3.neighbors/main.c
   grass/trunk/raster3d/r3.null/main.c
   grass/trunk/raster3d/r3.out.ascii/main.c
   grass/trunk/raster3d/r3.out.bin/main.c
   grass/trunk/raster3d/r3.out.netcdf/main.c
   grass/trunk/raster3d/r3.out.v5d/main.c
   grass/trunk/raster3d/r3.out.vtk/main.c
   grass/trunk/raster3d/r3.stats/main.c
   grass/trunk/raster3d/r3.support/main.c
r3.*: keyword standardization; minor compiler warnings fixed; use standard file name for main.c of r3.timestamp
Modified: grass/trunk/raster3d/r3.flow/main.c
--- grass/trunk/raster3d/r3.flow/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.flow/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -177,8 +177,8 @@
     G_gisinit(argv[0]);
     module = G_define_module();
     G_add_keyword(_("raster3d"));
+    G_add_keyword(_("hydrology"));
     G_add_keyword(_("voxel"));
-    G_add_keyword(_("flowline"));
     module->description =
 	_("Computes 3D flow lines and 3D flow accumulation.");
Modified: grass/trunk/raster3d/r3.flow/test_main.c
--- grass/trunk/raster3d/r3.flow/test_main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.flow/test_main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -41,8 +41,8 @@
     G_gisinit(argv[0]);
     module->description = _("Testing flow lines.");
     test_opt = G_define_option();
Modified: grass/trunk/raster3d/r3.gradient/main.c
--- grass/trunk/raster3d/r3.gradient/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.gradient/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -41,8 +41,8 @@
+    G_add_keyword(_("gradient"));
-    G_add_keyword(_("gradient"));
 	_("Computes gradient of a 3D raster map "
 	  "and outputs gradient components as three 3D raster maps.");
Modified: grass/trunk/raster3d/r3.in.ascii/main.c
--- grass/trunk/raster3d/r3.in.ascii/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.in.ascii/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -204,6 +204,7 @@
+#undef MAX
 #define MAX(a,b) (a > b ? a : b)
 void
@@ -310,8 +311,8 @@
     G_gisinit(argv[0]);
+    G_add_keyword(_("import"));
-    G_add_keyword(_("import"));
     G_add_keyword(_("conversion"));
     G_add_keyword("ASCII");
Modified: grass/trunk/raster3d/r3.in.bin/main.c
--- grass/trunk/raster3d/r3.in.bin/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.in.bin/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -251,6 +251,7 @@
+	G_add_keyword(_("voxel"));
 			_("Imports a binary raster file into a GRASS 3D raster map.");
Modified: grass/trunk/raster3d/r3.in.v5d/main.c
--- grass/trunk/raster3d/r3.in.v5d/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.in.v5d/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -34,6 +34,7 @@
 #include <grass/raster3d.h>
 #include <grass/glocale.h>
+#undef MAX
@@ -175,6 +176,7 @@
     G_gisinit(argv[0]);
 	_("Import 3-dimensional Vis5D files.");
Modified: grass/trunk/raster3d/r3.info/main.c
--- grass/trunk/raster3d/r3.info/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.info/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -74,8 +74,8 @@
     G_add_keyword(_("metadata"));
     G_add_keyword(_("extent"));
-    G_add_keyword(_("voxel"));
 	_("Outputs basic information about a user-specified 3D raster map layer.");
Modified: grass/trunk/raster3d/r3.mask/main.c
--- grass/trunk/raster3d/r3.mask/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.mask/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -41,6 +41,7 @@
+#undef MAX
 static void makeMask(char *name, d_Mask * maskRules)
Modified: grass/trunk/raster3d/r3.mkdspf/main.c
--- grass/trunk/raster3d/r3.mkdspf/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.mkdspf/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -77,6 +77,7 @@
+    G_add_keyword(_("display"));
 	_("Creates a display file from an existing 3D raster map according to specified threshold levels.");
Modified: grass/trunk/raster3d/r3.neighbors/main.c
--- grass/trunk/raster3d/r3.neighbors/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.neighbors/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -207,6 +207,7 @@
     G_add_keyword(_("algebra"));
     G_add_keyword(_("statistics"));
     G_add_keyword(_("aggregation"));
     G_add_keyword(_("neighbor"));
Modified: grass/trunk/raster3d/r3.null/main.c
--- grass/trunk/raster3d/r3.null/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.null/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -24,6 +24,7 @@
+#undef MAX
@@ -183,6 +184,7 @@
     G_gisinit(argv[0]);
+    G_add_keyword(_("null data"));
 	_("Explicitly create the 3D NULL-value bitmap file.");
Modified: grass/trunk/raster3d/r3.out.ascii/main.c
--- grass/trunk/raster3d/r3.out.ascii/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.out.ascii/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -23,6 +23,7 @@
+#undef MAX
 /* structs */
@@ -299,8 +300,8 @@
     G_gisinit(argv[0]);
+    G_add_keyword(_("export"));
-    G_add_keyword(_("export"));
Modified: grass/trunk/raster3d/r3.out.bin/main.c
--- grass/trunk/raster3d/r3.out.bin/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.out.bin/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -204,6 +204,7 @@
 	module->description = _("Exports a GRASS 3D raster map to a binary array.");
 	/* Define the different options */
Modified: grass/trunk/raster3d/r3.out.netcdf/main.c
--- grass/trunk/raster3d/r3.out.netcdf/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.out.netcdf/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -586,6 +586,7 @@
     G_add_keyword(_("netCDF"));
     module->description = _("Export a 3D raster map as netCDF file.");
     /* Get parameters from user */
Modified: grass/trunk/raster3d/r3.out.v5d/main.c
--- grass/trunk/raster3d/r3.out.v5d/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.out.v5d/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -23,6 +23,7 @@
+#undef MAX
 /* structs */
@@ -281,8 +282,8 @@
     G_gisinit(argv[0]);
 	_("Exports GRASS 3D raster map to 3-dimensional Vis5D file.");
Modified: grass/trunk/raster3d/r3.out.vtk/main.c
--- grass/trunk/raster3d/r3.out.vtk/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.out.vtk/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -374,8 +374,8 @@
     G_add_keyword("VTK");
         _("Converts 3D raster maps into the VTK-ASCII format.");
Modified: grass/trunk/raster3d/r3.stats/main.c
--- grass/trunk/raster3d/r3.stats/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.stats/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -47,6 +47,7 @@
     module->description = _("Generates volume statistics for 3D raster maps.");
Modified: grass/trunk/raster3d/r3.support/main.c
--- grass/trunk/raster3d/r3.support/main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.support/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -48,8 +48,9 @@
     module->description = _("Allows creation and/or modification of "
-			    "raster3d map layer support files.");
+			    "3D raster map layer support files.");
     raster = G_define_standard_option(G_OPT_R3_MAP);
Copied: grass/trunk/raster3d/r3.timestamp/main.c (from rev 63994, grass/trunk/raster3d/r3.timestamp/r3.timestamp.main.c)
--- grass/trunk/raster3d/r3.timestamp/main.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.timestamp/main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -0,0 +1,93 @@
+ * MODULE:       r3.timestamp
+ * AUTHOR(S):    Michael Pelizzari <michael.pelizzari lmco.com>
+ *                     (original contributor)
+ *               Glynn Clements <glynn gclements.plus.com> Markus Neteler <neteler itc.it>
+ * PURPOSE:      Stamps raster3d files with date and time.
+ * COPYRIGHT:    (C) 2001-2006 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+/* based on r.timestamp by Michael Shapiro and v.timestamp by Markus Neteler:
+ * Stamps raster3d files with date and time.  This main.c is linked to functions
+ * currently residing in lib/gis/timestamp.c
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/raster3d.h>
+#include <grass/glocale.h>
+int main(int argc, char *argv[])
+    struct Option *map, *date;
+    struct TimeStamp ts;
+    char *name;
+    const char *mapset;
+    int modify;
+    struct GModule *module;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("raster3d"));
+    G_add_keyword(_("timestamp"));
+    module->description =
+	_("Print/add/remove a timestamp for a 3D raster map");
+    map = G_define_standard_option(G_OPT_R3_MAP);
+    date = G_define_option();
+    date->key = "date";
+    date->key_desc = "timestamp";
+    date->required = NO;
+    date->type = TYPE_STRING;
+    date->description = _("Datetime, datetime1/datetime2, or none");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    name = map->answer;
+    modify = date->answer != NULL;
+    if (modify)
+	mapset = G_find_raster3d(name, G_mapset());
+    else
+	mapset = G_find_raster3d(name, "");
+    if (mapset == NULL) {
+	G_fatal_error(_("3D raster map <%s> not found"), name);
+    if (!modify) {
+	if (G_read_raster3d_timestamp(name, mapset, &ts) == 1) {
+	    G_write_timestamp(stdout, &ts);
+	    exit(EXIT_SUCCESS);
+	else
+    if (strcmp(date->answer, "none") == 0) {
+	G_remove_raster3d_timestamp(name);
+    if(G_scan_timestamp(&ts, date->answer) != 1)
+        G_fatal_error(_("Timestamp format is invalid"));
+    G_write_raster3d_timestamp(name, &ts);
Deleted: grass/trunk/raster3d/r3.timestamp/r3.timestamp.main.c
--- grass/trunk/raster3d/r3.timestamp/r3.timestamp.main.c	2015-01-09 08:37:34 UTC (rev 64025)
+++ grass/trunk/raster3d/r3.timestamp/r3.timestamp.main.c	2015-01-09 08:59:16 UTC (rev 64026)
@@ -1,92 +0,0 @@
- * MODULE:       r3.timestamp
- * AUTHOR(S):    Michael Pelizzari <michael.pelizzari lmco.com>
- *                     (original contributor)
- *               Glynn Clements <glynn gclements.plus.com> Markus Neteler <neteler itc.it>
- * PURPOSE:      Stamps raster3d files with date and time.
- * COPYRIGHT:    (C) 2001-2006 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
-/* based on r.timestamp by Michael Shapiro and v.timestamp by Markus Neteler:
- * Stamps raster3d files with date and time.  This main.c is linked to functions
- * currently residing in lib/gis/timestamp.c
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/raster3d.h>
-#include <grass/glocale.h>
-int main(int argc, char *argv[])
-    struct Option *map, *date;
-    struct TimeStamp ts;
-    char *name;
-    const char *mapset;
-    int modify;
-    struct GModule *module;
-    G_gisinit(argv[0]);
-    module = G_define_module();
-    G_add_keyword(_("raster3d"));
-    module->description =
-	_("Print/add/remove a timestamp for a 3D raster map");
-    map = G_define_standard_option(G_OPT_R3_MAP);
-    date = G_define_option();
-    date->key = "date";
-    date->key_desc = "timestamp";
-    date->required = NO;
-    date->type = TYPE_STRING;
-    date->description = _("Datetime, datetime1/datetime2, or none");
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
-    name = map->answer;
-    modify = date->answer != NULL;
-    if (modify)
-	mapset = G_find_raster3d(name, G_mapset());
-    else
-	mapset = G_find_raster3d(name, "");
-    if (mapset == NULL) {
-	G_fatal_error(_("3D raster map <%s> not found"), name);
-    if (!modify) {
-	if (G_read_raster3d_timestamp(name, mapset, &ts) == 1) {
-	    G_write_timestamp(stdout, &ts);
-	    exit(EXIT_SUCCESS);
-	else
-    if (strcmp(date->answer, "none") == 0) {
-	G_remove_raster3d_timestamp(name);
-    if(G_scan_timestamp(&ts, date->answer) != 1)
-        G_fatal_error(_("Timestamp format is invalid"));
-    G_write_raster3d_timestamp(name, &ts);
