[GRASS-SVN] r70365 - grass/trunk/gui/wxpython/lmgr
Fri Jan 13 12:01:38 PST 2017
Author: martinl
Date: 2017-01-13 12:01:38 -0800 (Fri, 13 Jan 2017)
New Revision: 70365
   grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI: 'Align computation region to selected map' add to the layer menu
       partly reverts r70276
       see discussion at https://lists.osgeo.org/pipermail/grass-dev/2017-January/083867.html
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py	2017-01-13 15:13:30 UTC (rev 70364)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py	2017-01-13 20:01:38 UTC (rev 70365)
@@ -424,7 +424,7 @@
         if not hasattr(self, "popupID"):
             self.popupID = dict()
             for key in (
-                    'remove', 'rename', 'opacity', 'nviz', 'zoom', 'region',
+                    'remove', 'rename', 'opacity', 'nviz', 'zoom', 'region', 'align',
                     'export', 'attr', 'edit', 'save_ws', 'bgmap', 'topo', 'meta',
                     'null', 'zoom1', 'color', 'colori', 'hist', 'univar', 'prof',
                     'properties', 'sql', 'copy', 'report', 'export-pg',
@@ -535,27 +535,19 @@
                     wx.EVT_MENU,
                     self.OnSetCompRegFromMap,
                     id=self.popupID['region'])
-            elif not same:
-                align = True
-                nrast = 0
-                for layer in selected:
-                    if self.GetLayerInfo(layer, key='type') == 'raster':
-                        nrast += 1
-                    if self.GetLayerInfo(layer, key='type') not in ('raster', 'vector'):
-                        align = False
-                        break
-                if align and nrast == 1:
+                # raster align
+                if ltype and ltype == "raster" and len(selected) == 1:
                     item = wx.MenuItem(
                         self.popupMenu,
-                        id=self.popupID['region'],
-                        text=_("Set computational region from selected vector(s) align to raster"))
+                        id=self.popupID['align'],
+                        text=_("Align computational region to selected map"))
                     item.SetBitmap(MetaIcon(img='region').GetBitmap(self.bmpsize))
                     self.popupMenu.AppendItem(item)
                     self.Bind(
                         wx.EVT_MENU,
-                        self.OnSetCompRegFromMap,
-                        id=self.popupID['region'])
+                        self.OnAlignCompRegToRaster,
+                        id=self.popupID['align'])
         # vector layers (specific items)
         if ltype and ltype == "vector" and numSelected == 1:
@@ -922,7 +914,7 @@
         self._giface.RunCmd(cmd)
     def OnSetCompRegFromMap(self, event):
-        """Set computational region from selected raster/vector map
+        """Set computational region from selected raster/vector map(s)
         rast = []
         vect = []
@@ -942,16 +934,13 @@
                     rast.append(rname)
         kwargs = {}
-        if vect and len(rast) == 1:
-            kwargs['align'] = ','.join(rast)
-        elif rast:
+        if rast:
             kwargs['raster'] = ','.join(rast)
         if vect:
             kwargs['vector'] = ','.join(vect)
         if rast3d:
             kwargs['raster_3d'] = ','.join(rast3d)
-        # print output to command log area
         if kwargs:
             if UserSettings.Get(group='general',
                                 key='region', subkey=['resAlign', 'enabled']):
@@ -964,6 +953,29 @@
         # re-render map display
         self._giface.GetMapWindow().UpdateMap(render=False)
+    def OnAlignCompRegToRaster(self, event):
+        """Align computational region to selected raster map
+        selected = self.GetSelections()
+        if len(selected) != 1 or \
+           self.GetLayerInfo(selected[0], key='type') != 'raster':
+            return
+        kwargs = {'align': self.GetLayerInfo(selected[0],
+                                             key='maplayer').GetName()
+        if UserSettings.Get(group='general',
+                            key='region', subkey=['resAlign', 'enabled']):
+            kwargs['flags'] = 'a'
+        # command must run in main thread otherwise it can be
+        # launched after rendering is done (region extent will
+        # remain untouched)
+        RunCommand('g.region', **kwargs)
+        # re-render map display
+        self._giface.GetMapWindow().UpdateMap(render=False)
     def OnProfile(self, event):
         """Plot profile of given raster map layer"""
         mapLayer = self.GetLayerInfo(self.layer_selected, key='maplayer')
