[GRASS-SVN] r70402 - in grass/branches/releasebranch_7_2/gui/wxpython: core gui_core lmgr
svn_grass at osgeo.org
Sat Jan 21 08:32:00 PST 2017
Author: martinl
Date: 2017-01-21 08:32:00 -0800 (Sat, 21 Jan 2017)
New Revision: 70402
grass/branches/releasebranch_7_2/gui/wxpython/core/settings.py
grass/branches/releasebranch_7_2/gui/wxpython/gui_core/preferences.py
grass/branches/releasebranch_7_2/gui/wxpython/lmgr/layertree.py
wxGUI: 'Align computation region to selected map' add to the layer menu
see discussion at https://lists.osgeo.org/pipermail/grass-dev/2017-January/083867.html
wxGUI: add 'Align region to resolution' option to preferences
(merge r70365, r70243 from trunk)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/core/settings.py
--- grass/branches/releasebranch_7_2/gui/wxpython/core/settings.py 2017-01-20 00:24:25 UTC (rev 70401)
+++ grass/branches/releasebranch_7_2/gui/wxpython/core/settings.py 2017-01-21 16:32:00 UTC (rev 70402)
@@ -11,7 +11,7 @@
from core.settings import UserSettings
@endcode
-(C) 2007-2016 by the GRASS Development Team
+(C) 2007-2017 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -104,6 +104,12 @@
'enabled': False
+ # region
+ 'region': {
+ 'resAlign': {
+ 'enabled' : False
'manager': {
# show opacity level widget
Modified: grass/branches/releasebranch_7_2/gui/wxpython/gui_core/preferences.py
--- grass/branches/releasebranch_7_2/gui/wxpython/gui_core/preferences.py 2017-01-20 00:24:25 UTC (rev 70401)
+++ grass/branches/releasebranch_7_2/gui/wxpython/gui_core/preferences.py 2017-01-21 16:32:00 UTC (rev 70402)
@@ -14,7 +14,7 @@
- preferences::MapsetAccess
- preferences::CheckListMapset
-(C) 2007-2014 by the GRASS Development Team
@@ -57,7 +57,7 @@
"""Base preferences dialog"""
def __init__(self, parent, giface, settings, title=_("User settings"),
- size=(500, 475),
+ size=(-1, 500),
style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
self.parent = parent # ModelerFrame
self.title = title
@@ -453,6 +453,41 @@
border=5)
border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
+ # region
+ box = wx.StaticBox(
+ parent=panel,
+ id=wx.ID_ANY,
+ label=" %s " %
+ _("Region settings"))
+ sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ gridSizer = wx.GridBagSizer(hgap=3, vgap=3)
+ row = 0
+ resAlign = wx.CheckBox(parent=panel, id=wx.ID_ANY, label=_(
+ "Align region to resolution"), name='IsChecked')
+ resAlign.SetValue(
+ self.settings.Get(
+ group='general',
+ key='region',
+ subkey=[
+ 'resAlign',
+ 'enabled']))
+ self.winId['general:region:resAlign:enabled'] = resAlign.GetId()
+ gridSizer.Add(resAlign,
+ pos=(row, 0), span=(1, 2))
+ gridSizer.AddGrowableCol(0)
+ sizer.Add(
+ gridSizer,
+ proportion=1,
+ flag=wx.ALL | wx.EXPAND,
+ border=5)
+ border.Add(sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
panel.SetSizer(border)
return panel
Modified: grass/branches/releasebranch_7_2/gui/wxpython/lmgr/layertree.py
--- grass/branches/releasebranch_7_2/gui/wxpython/lmgr/layertree.py 2017-01-20 00:24:25 UTC (rev 70401)
+++ grass/branches/releasebranch_7_2/gui/wxpython/lmgr/layertree.py 2017-01-21 16:32:00 UTC (rev 70402)
@@ -423,7 +423,7 @@
if not hasattr(self, "popupID"):
self.popupID = dict()
for key in (
- 'remove', 'rename', 'opacity', 'nviz', 'zoom', 'region',
+ 'remove', 'rename', 'opacity', 'nviz', 'zoom', 'region', 'align',
'export', 'attr', 'edit', 'save_ws', 'bgmap', 'topo', 'meta',
'null', 'zoom1', 'color', 'colori', 'hist', 'univar', 'prof',
'properties', 'sql', 'copy', 'report', 'export-pg',
@@ -534,6 +534,19 @@
wx.EVT_MENU,
self.OnSetCompRegFromMap,
id=self.popupID['region'])
+ # raster align
+ if ltype and ltype == "raster" and len(selected) == 1:
+ item = wx.MenuItem(
+ self.popupMenu,
+ id=self.popupID['align'],
+ text=_("Align computational region to selected map"))
+ item.SetBitmap(MetaIcon(img='region').GetBitmap(self.bmpsize))
+ self.popupMenu.AppendItem(item)
+ self.Bind(
+ wx.EVT_MENU,
+ self.OnAlignCompRegToRaster,
+ id=self.popupID['align'])
# vector layers (specific items)
if ltype and ltype == "vector" and numSelected == 1:
@@ -906,7 +919,7 @@
self._giface.RunCmd(cmd)
def OnSetCompRegFromMap(self, event):
- """Set computational region from selected raster/vector map
+ """Set computational region from selected raster/vector map(s)
rast = []
vect = []
@@ -933,8 +946,10 @@
if rast3d:
kwargs['raster_3d'] = ','.join(rast3d)
- # print output to command log area
if kwargs:
+ if UserSettings.Get(group='general',
+ key='region', subkey=['resAlign', 'enabled']):
+ kwargs['flags'] = 'a'
# command must run in main thread otherwise it can be
# launched after rendering is done (region extent will
# remain untouched)
@@ -943,6 +958,29 @@
# re-render map display
self._giface.GetMapWindow().UpdateMap(render=False)
+ def OnAlignCompRegToRaster(self, event):
+ """Align computational region to selected raster map
+ selected = self.GetSelections()
+ if len(selected) != 1 or \
+ self.GetLayerInfo(selected[0], key='type') != 'raster':
+ return
+ kwargs = {'align': self.GetLayerInfo(selected[0],
+ key='maplayer').GetName()
+ # command must run in main thread otherwise it can be
+ # launched after rendering is done (region extent will
+ # remain untouched)
+ RunCommand('g.region', **kwargs)
+ # re-render map display
+ self._giface.GetMapWindow().UpdateMap(render=False)
def OnProfile(self, event):
"""Plot profile of given raster map layer"""
mapLayer = self.GetLayerInfo(self.layer_selected, key='maplayer')
