[GRASS-SVN] r73148 - in grass-addons/grass7/vector: . v.rast.bufferstats
Thu Aug 23 13:21:11 PDT 2018
Author: sbl
Date: 2018-08-23 13:21:11 -0700 (Thu, 23 Aug 2018)
New Revision: 73148
Added:
   grass-addons/grass7/vector/v.rast.bufferstats/
   grass-addons/grass7/vector/v.rast.bufferstats/Makefile
   grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.html
   grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.py
Add v.rast.bufferstats
Added: grass-addons/grass7/vector/v.rast.bufferstats/Makefile
--- grass-addons/grass7/vector/v.rast.bufferstats/Makefile	                        (rev 0)
+++ grass-addons/grass7/vector/v.rast.bufferstats/Makefile	2018-08-23 20:21:11 UTC (rev 73148)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.rast.bufferstats
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.rast.bufferstats/Makefile
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-makefile
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
Added: grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.html
--- grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.html	2018-08-23 20:21:11 UTC (rev 73148)
@@ -0,0 +1,62 @@
+<h2>DESCRIPTION:</h2>
+<p>The module <em>v.rast.bufferstats</em> computes statistics from multiple input raster
+maps within (multiple) buffers around selected geometries in the input vector map.<br>
+Available statistics are either</p>
+<ol type="a">
+<li>statistics provided by <em>r.univar</em> or</li>
+<li>if the <em>t-flag</em> is checked - area of, number of and/or the most frequent (mode) raster categories
+within the buffers using <em>r.stats</em>.</li>
+</ol>
+<p>If <em>output</em> option is specified table output is produced with the following column order:<br>
+cat | prefix | buffer| statistic/measure | value<br>
+separated by the selected separator.</p>
+<div id="note">
+<h2>NOTE</h2>
+<p>The module temporarily modifies the computational region. The region is set to the
+extent of the respecive buffers, while the alignement of the current region is kept.</p>
+</div>
+<div id="examples">
+<h2>EXAMPLES</h2>
+<div class="code"><pre>
+g.region -p raster=elevation,geology_30m
+v.clip --o -r input=bridges output=bridges_wake
+# Tabulate area of land cover map
+g.region -p raster=elevation,geology_30m align=geology_30m
+v.rast.bufferstats -t input=bridges_wake raster=geology_30m buffers=100,250,500 column_prefix=geology
+# Compute terrain statistics
+g.region -p raster=elevation,geology_30m align=elevation
+r.slope.aspect elevation=elevation slope=slope aspect=aspect
+v.rast.bufferstats input= raster=altitude,slope,aspect buffers=100,250,500 column_prefix=altitude,slope,aspect methods=minimum,maximum,average,stddev percentile=5,95
+</pre></div>
+</div>
+<div id="known issues">
+<h2>KNOWN ISSUES</h2>
+<p>In order to avoid topological issues with overlapping buffers, the module loops over the
+input geometries. However, this comes at costs with regards to performance.
+For a larger number of geometries in the vector map, it can be therefore more appropriate to
+compute neighborhood statistics with <em>r.neighbors</em> and to extract (<em>v.what.rast</em>,
+<em>r.what</em>) or aggregate (<em>v.rast.stats</em>) from those maps with neighborhood statistics.</p>
+</div>
+<div id="seealso">
+<h2>SEE ALSO</h2>
+<a href="r.univar.html">r.univar</a>
+<a href="r.stats.html">r.stats</a>
+<a href="v.rast.stats.html">v.rast.stats</a>
+</div>
+<div id="author">
+<h2>AUTHOR</h2>
+Stefan Blumentrath, Norwegian Institute for Nature Research, Oslo, Norway
+</div>
Property changes on: grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.html
## -0,0 +1 ##
+text/html
Added: svn:keywords
## -0,0 +1 ##
+Author Date Id
## -0,0 +1 ##
+native
Added: grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.py
--- grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.py	                        (rev 0)
+++ grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.py	2018-08-23 20:21:11 UTC (rev 73148)
@@ -0,0 +1,620 @@
+#!/usr/bin/env python
+MODULE:    v.rast.bufferstats
+AUTHOR(S): Stefan Blumentrath < stefan.blumentrath AT nina.no>
+           With lots of inspiration from v.what.rast.buffer by
+           Hamish Bowman, Dunedin, New Zealand
+PURPOSE:   Calculates statistics of raster map(s) for buffers around vector geometries.
+COPYRIGHT: (C) 2018 by the GRASS Development Team
+           This program is free software under the GNU General Public
+           License (>=v2). Read the file COPYING that comes with GRASS
+           for details.
+To Dos:
+- consider adding distance weights
+- add neighborhood stats ???
+- silence r.category
+- add where clause
+#%option G_OPT_DB_WHERE
+#% required: no
+#%end
+    where = options['where']
+#%Module
+#% label: Calculates statistics of raster map(s) for buffers around vector geometries.
+#% keyword: vector
+#% keyword: raster
+#% keyword: buffer
+#% keyword: statistics
+#%End
+#%option G_OPT_V_INPUT
+#% description: Vector map containing geometries to compute buffer statistics for
+#%end
+#%option G_OPT_R_INPUTS
+#% key: raster
+#% description: Raster map(s) to calculate statistics from
+#% multiple: yes
+#% required : yes
+#%end
+#%option
+#% key: buffers
+#% type: integer
+#% description: Buffer distance(s) in map units
+#% multiple: yes
+#% required : yes
+#%end
+#%option
+#% key: type
+#% type:string
+#% description: Vector type to work on
+#% options: points,lines,areas
+#% answer: points,lines,areas
+#% multiple: yes
+#% required: yes
+#%end
+## ,centroid not supported in pygrass
+#%option G_OPT_V_FIELD
+#% required: no
+#%end
+#%option
+#% key: column_prefix
+#% type: string
+#% description: Column prefix for new attribute columns
+#% required : yes
+#% multiple: yes
+#%end
+#%option
+#% key: methods
+#% type: string
+#% description: The methods to use
+#% required: no
+#% multiple: yes
+#% options: number,number_null,minimum,maximum,range,sum,average,average_abs,stddev,variance,coeff_var,first_quartile,median,third_quartile
+#% answer: number,number_null,minimum,maximum,range,sum,average,average_abs,stddev,variance,coeff_var,first_quartile,median,third_quartile
+#%end
+#%option
+#% key: percentile
+#% type: integer
+#% description: Percentile to calculate
+#% options: 0-100
+#% required : no
+#%end
+#%flag
+#% key: t
+#% description: Tabulate area within buffers for categories in raster map(s)
+#%end
+#%flag
+#% key: u
+#% description: Update columns if they already exist
+#%end
+#%option G_OPT_F_OUTPUT
+#% description: Name for output file (if "-" output to stdout)
+#% required: no
+#%end
+#%option G_OPT_F_SEP
+#% description: Field separator in output file
+#% answer: |
+#% required: no
+#%end
+import sys
+import os
+import atexit
+import math
+from subprocess import PIPE
+import grass.script as grass
+from grass.pygrass.vector import VectorTopo
+from grass.pygrass.raster.abstract import RasterAbstractBase
+from grass.pygrass.gis import Mapset
+from grass.pygrass.vector.geometry import Boundary
+from grass.pygrass.vector.geometry import Centroid
+from grass.pygrass.gis.region import Region
+#from grass.pygrass.vector.table import *
+from grass.pygrass.modules.interface.module import Module
+from itertools import chain
+if not "GISBASE" in os.environ.keys():
+    grass.message("You must be in GRASS GIS to run this program.")
+    sys.exit(1)
+TMP_MAPS = []
+def cleanup():
+    """Remove temporary data
+    #remove temporary region file
+    try:
+        grass.run_command('g.remove', flags='f', name=TMP_MAPS,
+                          quiet=True, type=['vector', 'raster'],
+                          stderr=os.devnull, stdout_=os.devnull)
+    except:
+        pass
+    try:
+        grass.run_command('g.remove', flags='f', name='MASK',
+                          quiet=True, type='raster',
+    except:
+        pass
+def align_current(region, bbox):
+    """Align current region to bounding box
+    :param region: PyGRASS Region object
+    :param bbox: PyGRASS Bbox object
+    :returns: adjusted PyGRASS Region object
+    :type region: PyGRASS Region object
+    :type bbox: PyGRASS Bbox object
+    :rtype: dict
+    :Example:
+    >>> align_current(region, bbox)
+    region
+    north = region.north
+    east = region.east
+    west = region.west
+    south = region.south
+    nsres = region.nsres
+    ewres = region.ewres
+    region.north = north - (math.floor((north - bbox.north) / nsres)
+                            * nsres)
+    region.south = south - (math.ceil((south - bbox.south) / nsres)
+                            * nsres)
+    region.east = east - (math.floor((east - bbox.east) / ewres)
+                          * ewres)
+    region.west = west - (math.ceil((west - bbox.west) / ewres)
+                          * ewres)
+    return region
+def random_name(length):
+    """Generate a random name of length "length" starting with a letter
+    :param length: length of the random name to generate
+    :returns: String with a random name of length "length" starting with a letter
+    :type length: int
+    :rtype: string
+    :Example:
+    >>> random_name(12)
+    'MxMa1kAS13s9'
+    import string
+    import random
+    chars = string.ascii_uppercase + string.ascii_lowercase + string.digits
+    randomname = '1'
+    while randomname[0].isdigit():
+        randomname = ''.join(random.choice(chars) for _ in range(length))
+    return randomname
+def raster_type(raster):
+    """Check raster map type (int or double) and return categories for int maps
+    :param raster: name of the raster map to check
+    :returns: string with raster map type and list of categories with lables
+    :type raster: string
+    :rtype: string
+    :rtype: list
+    :Example:
+    >>> raster_type('elevation')
+    'double precision', []
+    rcats = []
+    try:
+        rcats = grass.read_command('r.category', map=raster,
+                                   quiet=True).rstrip('\n').split('\n')
+        rmap_type = 'int'
+    except:
+        pass
+    if len(rcats) == 0:
+        rmap_type = 'double precision'
+    return rmap_type, rcats
+def main():
+    in_vector = options['input'].split('@')[0]
+    if len(options['input'].split('@')) > 1:
+        in_mapset = options['input'].split('@')[1]
+    else:
+        in_mapset = None
+    raster_maps = options['raster'].split(',')   # raster file(s) to extract from
+    output = options['output']
+    methods = tuple(options['methods'].split(','))
+    percentile = None if options['percentile'] == '' else map(float, options['percentile'].split(','))
+    column_prefix = tuple(options['column_prefix'].split(','))
+    buffers = options['buffers'].split(',')
+    types = options['type'].split(',')
+    layer = options['layer']
+    sep = options['separator']
+    update = flags['u']
+    tabulate = flags['t']
+    # Do checks using pygrass
+    for rmap in raster_maps:
+        r_map = RasterAbstractBase(rmap)
+        if not r_map.exist():
+            grass.fatal('Could not find raster map {}.'.format(rmap))
+    m_map = RasterAbstractBase('MASK')
+    if m_map.exist():
+        grass.fatal("Please remove MASK first")
+    invect = VectorTopo(in_vector)
+    if not invect.exist():
+        grass.fatal("Vector file {} does not exist".format(in_vector))
+    if output:
+        if output == '-':
+            out = None
+        else:
+            out = open(output, 'w')
+    # Check if input map is in current mapset (and thus editable)
+    if in_mapset and unicode(in_mapset) != unicode(Mapset()):
+        grass.fatal("Input vector map is not in current mapset and cannot be modified. \
+                    Please consider copying it to current mapset.".format(output))
+    buffers = []
+    for buf in options['buffers'].split(','):
+        try:
+            b = float(buf)
+            if b.is_integer():
+                buffers.append(int(b))
+            else:
+                buffers.append(b)
+        except:
+            grass.fatal('')
+        if b < 0:
+            grass.fatal("Negative buffer distance not supported!")
+    ### Define column types depenting on statistic, map type and
+    ### DB backend (SQLite supports only double and not real)
+    # int: statistic produces allways integer precision
+    # double: statistic produces allways floating point precision
+    # map_type: precision f statistic depends on map type
+    int_dict = {'number': (0, 'int', 'n'),
+                'number_null': (1, 'int', 'null_cells'),
+                'minimum': (3, 'map_type', 'min'),
+                'maximum': (4, 'map_type', 'max'),
+                'range': (5, 'map_type', 'range'),
+                'average': (6, 'double', 'mean'),
+                'average_abs': (7, 'double', 'mean_of_abs'),
+                'stddev': (8, 'double', 'stddev'),
+                'variance': (9, 'double', 'variance'),
+                'coeff_var': (10, 'double', 'coeff_var'),
+                'sum': (11, 'map_type', 'sum'),
+                'first_quartile': (12, 'map_type', 'first_quartile'),
+                'median': (13, 'map_type', 'median'),
+                'third_quartile': (14, 'map_type', 'third_quartile'),
+                'percentile': (15, 'map_type', 'percentile')}
+    if len(raster_maps) != len(column_prefix):
+        grass.fatal('Number of maps and number of column prefixes has to be equal!')
+    # Generate list of required column names and types
+    col_names = []
+    col_types = []
+    for p in column_prefix:
+        rmaptype, rcats = raster_type(raster_maps[column_prefix.index(p)])
+        for b in buffers:
+            b_str = unicode(b).replace('.', '_')
+            if tabulate:
+                if rmaptype == 'double precision':
+                    grass.fatal('{} has floating point precision. Can only tabulate integer maps'.format(raster_maps[column_prefix.index(p)]))
+                col_names.append('{}_{}_b{}'.format(p, 'ncats', b_str))
+                col_types.append('int')
+                col_names.append('{}_{}_b{}'.format(p, 'mode', b_str))
+                col_names.append('{}_{}_b{}'.format(p, 'null', b_str))
+                col_types.append('double precision')
+                col_names.append('{}_{}_b{}'.format(p, 'area_tot', b_str))
+                for rcat in rcats:
+                    col_names.append('{}_{}_b{}'.format(p, rcat.split('\t')[0], b_str))
+            else:
+                for m in methods:
+                    col_names.append('{}_{}_b{}'.format(p, int_dict[m][2], b_str))
+                    col_types.append(rmaptype if int_dict[m][1] == 'map_type' else int_dict[m][1])
+                if percentile:
+                    for perc in percentile:
+                        col_names.append('{}_percentile_{}_b{}'.format(p,
+        int(perc) if (perc).is_integer() else perc,
+        b_str))
+    # Open input vector map
+    in_vect = VectorTopo(in_vector, layer=layer)
+    in_vect.open(mode='r')
+    # Get name for temporary map
+    tmp_map = random_name(21)
+    TMP_MAPS.append(tmp_map)
+    # Setup stats collectors
+    if tabulate:
+        # Collector for raster category statistics
+        stats = Module('r.stats', run_=False, stdout_=PIPE)
+        stats.inputs.sort = 'desc'
+        stats.inputs.null_value = 'null'
+        stats.flags.a = True
+        stats.flags.quiet = True
+    else:
+        # Collector for univariat statistics
+        univar = Module('r.univar', run_=False, stdout_=PIPE)
+        univar.inputs.separator = sep
+        univar.flags.g = True
+        univar.flags.quiet = True
+        # Add extended statistics if requested
+        if set(methods).intersection(set(['first_quartile',
+                                          'median', 'third_quartile'])):
+            univar.flags.e = True
+        if percentile is not None:
+            univar.inputs.percentile = percentile
+    # Check if attribute table exists
+    if not output:
+        if not in_vect.table:
+            grass.fatal('No attribute table found for vector map {}'.format(in_vect))
+        # Modify table as needed
+        tab = in_vect.table
+        tab_name = tab.name
+        tab_cols = tab.columns
+        # Add required columns
+        existing_cols = list(set(tab_cols.names()).intersection(col_names))
+        if len(existing_cols) > 0:
+            if not update:
+                grass.fatal('Column(s) {} already exist! Please use the u-flag \
+                            if you want to update values in those columns'.format(','.join(existing_cols)))
+            else:
+                grass.warning('Column(s) {} already exist!'.format(','.join(existing_cols)))
+        for e in existing_cols:
+            idx = col_names.index(e)
+            del col_names[idx]
+            del col_types[idx]
+        tab_cols.add(col_names, col_types)
+        conn = tab.conn
+        cur = conn.cursor()
+        sql_str_start = 'UPDATE {} SET '.format(tab_name)
+    # Get computational region
+    #grass.use_temp_region()
+    r = Region()
+    #r.read()
+    # Adjust region extent to buffer around geometry
+    #reg = deepcopy(r)
+    # Create iterator for geometries of all selected types
+    geoms = chain()
+    geoms_n = 0
+    n_geom = 1
+    for geom_type in types:
+        geoms_n += in_vect.number_of(geom_type)
+        if in_vect.number_of(geom_type) > 0:
+            geoms = chain(in_vect.viter(geom_type))
+    # Loop over geometries
+    for geom in geoms:
+        # Get cat
+        cat = geom.cat
+        # Give progress information
+        grass.percent(n_geom, geoms_n, 1)
+        n_geom = n_geom + 1
+        # Add where clause to UPDATE statement
+        sql_str_end = ' WHERE cat = {};'.format(cat)
+        # Loop over ser provided buffer distances
+        for buf in buffers:
+            b_str = unicode(buf).replace('.', '_')
+            # Buffer geometry
+            if buf <= 0:
+                buffer_geom = geom
+            else:
+                buffer_geom = geom.buffer(buf)
+            # Create temporary vector map with buffered geometry
+            tmp_vect = VectorTopo(tmp_map, quiet=True)
+            tmp_vect.open(mode='w')
+            #print(int(cat))
+            tmp_vect.write(Boundary(points=buffer_geom[0].to_list()))
+            # , c_cats=int(cat), set_cats=True
+            tmp_vect.write(Centroid(x=buffer_geom[1].x,
+                                    y=buffer_geom[1].y), cat=int(cat))
+            # How to silence VectorTopo???
+            # Save current stdout
+            #original = sys.stdout
+            #f = open(os.devnull, 'w')
+            #with open('output.txt', 'w') as f:
+            #sys.stdout = io.BytesIO()
+            #sys.stdout.fileno() = os.devnull
+            #sys.stderr = f
+            #os.environ.update(dict(GRASS_VERBOSE='0'))
+            tmp_vect.close(build=False)
+            grass.run_command('v.build', map=tmp_map, quiet=True)
+            #os.environ.update(dict(GRASS_VERBOSE='1'))
+            #reg = Region()
+            #reg.read()
+            #r.from_vect(tmp_map)
+            r = align_current(r, buffer_geom[0].bbox())
+            r.set_current()
+            # Check if the following is needed
+            #grass.run_command('g.region', vector=tmp_map)
+            # Create a MASK from buffered geometry
+            grass.run_command('v.to.rast', input=tmp_map,
+                              output='MASK', use='val',
+                              value=int(cat), quiet=True)
+            #reg.write()
+            updates = []
+            # Compute statistics for every raster map
+            for rm in range(len(raster_maps)):
+                rmap = raster_maps[rm]
+                prefix = column_prefix[rm]
+                if tabulate:
+                    # Get statistics on occurrence of raster categories within buffer
+                    stats.inputs.input = rmap
+                    stats.run()
+                    t_stats = stats.outputs['stdout'].value.rstrip(os.linesep).replace(' ', '_b{} = '.format(b_str)).split(os.linesep)
+                    if t_stats[0].split('_b{} = '.format(b_str))[0].split('_')[-1] != 'null':
+                        mode = t_stats[0].split('_b{} = '.format(b_str))[0].split('_')[-1]
+                    elif len(t_stats) == 1:
+                        mode = 'NULL'
+                    else:
+                        mode = t_stats[1].split('_b{} = '.format(b_str))[0].split('_')[-1]
+                    if not output:
+                        updates.append('\t{}_{}_b{} = {}'.format(prefix, 'ncats', b_str, len(t_stats)))
+                        updates.append('\t{}_{}_b{} = {}'.format(prefix, 'mode', b_str, mode))
+                        area_tot = 0
+                        for l in t_stats:
+                            updates.append('\t{}_{}'.format(prefix, l))
+                            if l.split('_b{} ='.format(b_str))[0].split('_')[-1] != 'null':
+                                area_tot = area_tot + float(l.split('= ')[1])
+                        updates.append('\t{}_{}_b{} = {}'.format(prefix, 'area_tot', b_str, area_tot))
+                    else:
+                        out_str = '{1}{0}{2}{0}{3}{0}{4}{0}{5}{6}'.format(sep, cat, prefix, buffer, 'ncats', len(t_stats), os.linesep)
+                        out_str += '{1}{0}{2}{0}{3}{0}{4}{0}{5}{6}'.format(sep, cat, prefix, buffer, 'mode', mode, os.linesep)
+                        area_tot = 0
+                        for l in t_stats:
+                            rcat = l.split('_b{} ='.format(b_str))[0].split('_')[-1]
+                            area = l.split('= ')[1]
+                            out_str += '{1}{0}{2}{0}{3}{0}{4}{0}{5}{6}'.format(sep, cat, prefix, buffer, 'area {}'.format(rcat), area, os.linesep)
+                            if rcat != 'null':
+                        out_str += '{1}{0}{2}{0}{3}{0}{4}{0}{5}{6}'.format(sep, cat, prefix, buffer, 'area_tot', area_tot, os.linesep)
+                        if output == '-':
+                            print(out_str.rstrip(os.linesep))
+                        else:
+                            out.write(out_str)
+                else:
+                    # Get univariate statistics within buffer
+                    univar.inputs.map = rmap
+                    univar.run()
+                    u_stats = univar.outputs['stdout'].value.rstrip(os.linesep).replace('=', '_b{} = '.format(b_str)).split(os.linesep)
+                    # Test i u_stats is empty and give warning
+                    if (percentile and len(u_stats) <= 14) or (univar.flags.e and len(u_stats) <= 13) or len(u_stats) <= 12:
+                        grass.warning('No data within buffer {} around geometry {}'.format(buf, cat))
+                        break
+                    # Extract statistics for selected methods
+                    for m in methods:
+                        if not output:
+                            # Add to list of UPDATE statements
+        u_stats[int_dict[m][0]]))
+                        else:
+                            out_str = '{1}{0}{2}{0}{3}{0}{4}{0}{5}'.format(sep, cat, prefix, buf, m, u_stats[int_dict[m][0]].split('= ')[1])
+                            if output == '-':
+                                print(out_str)
+                            else:
+                    if percentile:
+                        perc_count = 0
+                            if not output:
+                                updates.append('{}_percentile_{}_b{} = {}'.format(p,
+        b_str, u_stats[15+perc_count].split('= ')[1]))
+                            else:
+                                out_str = '{1}{0}{2}{0}{3}{0}{4}{0}{5}'.format(sep, cat, prefix, buffer, 'percentile_{}'.format(int(perc) if (perc).is_integer() else perc), u_stats[15+perc_count].split('= ')[1])
+                                if output == '-':
+                                    print(out_str)
+                                else:
+                            perc_count = perc_count + 1
+            if not output and len(updates) > 0:
+                cur.execute('{}{}{}'.format(sql_str_start,
+                                            ',\n'.join(updates),
+                                            sql_str_end))
+            # Remove temporary maps
+            #, stderr=os.devnull, stdout_=os.devnull)
+            grass.run_command('g.remove', flags='f', type='raster',
+                              name='MASK', quiet=True)
+            grass.run_command('g.remove', flags='f', type='vector',
+                              name=tmp_map, quiet=True)
+        if not output:
+            conn.commit()
+    # Close cursor and DB connection
+    if not output:
+        cur.close()
+        conn.close()
+    elif output != "-":
+        # write results to file
+        out.close()
+    elif output and output == "-":
+        # write results to STDOUT
+        pass
+    grass.vector.vector_history(in_vector)
+    cleanup()
+# Run the module
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    sys.exit(main())
Property changes on: grass-addons/grass7/vector/v.rast.bufferstats/v.rast.bufferstats.py
Added: svn:executable
## -0,0 +1 ##
## -0,0 +1 ##
+text/x-python
## -0,0 +1 ##
+native
