[GRASS-SVN] r73149 - grass/trunk/gui/wxpython
Thu Aug 23 18:26:58 PDT 2018
Author: wenzeslaus
Date: 2018-08-23 18:26:58 -0700 (Thu, 23 Aug 2018)
New Revision: 73149
   grass/trunk/gui/wxpython/gis_set.py
wxGUI/startup: window titles should use title case (plus doc)
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py	2018-08-23 20:21:11 UTC (rev 73148)
+++ grass/trunk/gui/wxpython/gis_set.py	2018-08-24 01:26:58 UTC (rev 73149)
@@ -253,8 +253,16 @@
         self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
     def _set_properties(self, version, revision):
-        """Set frame properties"""
-        self.SetTitle(_("GRASS GIS %s startup%s") % (version, revision))
+        """Set frame properties
+        :param version: Version in the form of X.Y.Z
+        :param revision: Version control revision with leading space
+        *revision* should be an empty string in case of release and
+        otherwise it needs a leading space to be separated from the rest
+        of the title.
+        self.SetTitle(_("GRASS GIS %s Startup%s") % (version, revision))
         self.SetIcon(wx.Icon(os.path.join(globalvar.ICONDIR, "grass.ico"),
                              wx.BITMAP_TYPE_ICO))
