[GRASS-SVN] r72070 - in grass/trunk/raster/r.texture: . testsuite
Thu Jan 11 05:29:13 PST 2018
Author: lucadelu
Date: 2018-01-11 05:29:13 -0800 (Thu, 11 Jan 2018)
New Revision: 72070
Added:
   grass/trunk/raster/r.texture/testsuite/
   grass/trunk/raster/r.texture/testsuite/test_texture.py
r.texture: added tests, thanks to Sunveer Singh during Google Code-in 2017
Added: grass/trunk/raster/r.texture/testsuite/test_texture.py
--- grass/trunk/raster/r.texture/testsuite/test_texture.py	                        (rev 0)
+++ grass/trunk/raster/r.texture/testsuite/test_texture.py	2018-01-11 13:29:13 UTC (rev 72070)
@@ -0,0 +1,75 @@
+Name:       r.texture test
+Purpose:    Tests r.texture and its flags/options.
+Author:     Sunveer Singh, Google Code-in 2017
+Copyright:  (C) 2017 by Sunveer Singh and the GRASS Development Team
+Licence:    This program is free software under the GNU General Public
+	            License (>=v2). Read the file COPYING that comes with GRASS
+	            for details.
+from grass.gunittest.case import TestCase
+class TestRasterreport(TestCase):
+    input = "lsat7_2002_80"
+    @classmethod
+    def setUpClass(cls):
+        cls.use_temp_region()
+        cls.runModule("g.region", raster=cls.input)
+    @classmethod
+    def tearDownClass(cls):
+        cls.del_temp_region()
+        cls.runModule('g.remove', flags='f', type='raster', name="asm_ASM")
+        cls.runModule('g.remove', flags='f', type='raster', name='corr_Corr')
+        cls.runModule('g.remove', flags='f', type='raster', name='sa_SA')
+        cls.runModule('g.remove', flags='f', type='raster', name='var_Var')
+        cls.runModule('g.remove', flags='f', type='raster', name='idm_IDM')
+    def test_asm(self):
+        """Testing method asm"""
+        asm_ASM='asm_ASM'
+        string="""min=1
+        max=1
+        cells=1000246"""
+        self.assertModule('r.texture', input=self.input, output='asm', method='asm')
+        self.assertRasterFitsUnivar(asm_ASM,
+	                            reference=string, precision=2)
+    def test_corr(self):
+        """Testing method corr"""
+        corr_output='corr_Corr'
+        string="""min=1
+        max=1
+        cells=1000246"""
+        self.assertModule('r.texture', input=self.input, output='corr', method='corr')
+        self.assertRasterFitsUnivar(corr_output,
+    def test_sa(self):
+        """Testing method sa"""
+        sa_SA='sa_SA'
+        string="""min=95.95
+        max=2942.79
+        cells=1000246"""
+        self.assertModule('r.texture', input=self.input, output='sa', method='sa')
+        self.assertRasterFitsUnivar(sa_SA,
+    def test_var(self):
+        """Testing method var"""
+        var_output='var_Var'
+        self.assertModule('r.texture', input=self.input, output='var', method='var')
+        self.assertRasterMinMax(map=var_output, refmin=0, refmax=9843.07,
+	                        msg="var_Var in degrees must be between 0.74 and 9843.07")
+    def test_idm(self):
+        """Testing method idm"""
+        idm_IDM='idm_IDM'
+        self.assertModule('r.texture', input=self.input, output='idm', method='idm')
+        self.assertRasterMinMax(map=idm_IDM, refmin=0, refmax=9843.07,
+	                        msg="idm_IDM_IDM in degrees must be between 0.74 and 9843.07")
+if __name__ == '__main__':
+    from grass.gunittest.main import test
+    test()
Property changes on: grass/trunk/raster/r.texture/testsuite/test_texture.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
