[GRASS-SVN] r72071 - grass/branches/releasebranch_7_4/scripts/r.fillnulls
Thu Jan 11 06:25:42 PST 2018
Author: marisn
Date: 2018-01-11 06:25:42 -0800 (Thu, 11 Jan 2018)
New Revision: 72071
   grass/branches/releasebranch_7_4/scripts/r.fillnulls/r.fillnulls.py
r.fillnulls: Fix RST segmax/npmin logic. (backport of r72029)
Modified: grass/branches/releasebranch_7_4/scripts/r.fillnulls/r.fillnulls.py
--- grass/branches/releasebranch_7_4/scripts/r.fillnulls/r.fillnulls.py	2018-01-11 13:29:13 UTC (rev 72070)
+++ grass/branches/releasebranch_7_4/scripts/r.fillnulls/r.fillnulls.py	2018-01-11 14:25:42 UTC (rev 72071)
@@ -340,8 +340,11 @@
             # Avoid v.surf.rst warnings
             if pointsnumber < segmax:
-                npmin = pointsnumber + 1
-                segmax = pointsnumber
+                use_npmin = pointsnumber
+                use_segmax = pointsnumber * 2
+            else:
+                use_npmin = npmin
+                use_segmax = segmax
             # launch v.surf.rst
             tmp_rmaps.append(holename + '_dem')
@@ -349,7 +352,7 @@
                 grass.run_command('v.surf.rst', quiet=quiet,
                                   input=holename, elev=holename + '_dem',
                                   tension=tension, smooth=smooth,
-                                  segmax=segmax, npmin=npmin)
+                                  segmax=use_segmax, npmin=use_npmin)
             except CalledModuleError:
                 # GTC Hole is NULL area in a raster map
                 grass.fatal(_("Failed to fill hole %s") % cat)
