[GRASS-SVN] r74374 - grass/trunk/scripts/g.extension
Sat Apr 13 20:41:04 PDT 2019
Author: annakrat
Date: 2019-04-13 20:41:04 -0700 (Sat, 13 Apr 2019)
New Revision: 74374
   grass/trunk/scripts/g.extension/g.extension.py
g.extension: avoid python requests import, see #3179
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py	2019-04-13 19:41:59 UTC (rev 74373)
+++ grass/trunk/scripts/g.extension/g.extension.py	2019-04-14 03:41:04 UTC (rev 74374)
@@ -138,17 +138,9 @@
 import xml.etree.ElementTree as etree
 from distutils.dir_util import copy_tree
+from six.moves.urllib.request import urlopen, urlretrieve, ProxyHandler, build_opener, install_opener
+from six.moves.urllib.error import HTTPError, URLError
-try:
-    from urllib2 import HTTPError, URLError, ProxyHandler, build_opener
-    from urllib import urlopen, urlretrieve
-except ImportError:
-    # there is also HTTPException, perhaps change to list
-    from urllib.error import HTTPError, URLError
-    from urllib.request import urlopen, urlretrieve, ProxyHandler, build_opener
-import requests
 # Get the XML parsing exceptions to catch. The behavior changed with Python 2.7
 # and ElementTree 1.3.
 from xml.parsers import expat  # TODO: works for any Python?
@@ -172,16 +164,10 @@
         return etree.fromstring(file_.read())
-def etree_fromurl(url, proxies=None):
+def etree_fromurl(url):
     """Create XML element tree from a given URL"""
-    if proxies:
-        proxy_handler = ProxyHandler(PROXIES)
-        opener = build_opener(proxy_handler)
-        with opener.open(url) as file_:
-            return etree.fromstring(file_.read())
-    else:
-        file_ = urlopen(url)
+    file_ = urlopen(url)
+    return etree.fromstring(file_.read())
 def check_progs():
@@ -357,7 +343,7 @@
     tdict = dict()
     url = url + "toolboxes.xml"
     try:
-        tree = etree_fromurl(url, proxies=PROXIES)
+        tree = etree_fromurl(url)
         for tnode in tree.findall('toolbox'):
             mlist = list()
             clist = list()
@@ -387,7 +373,7 @@
     try:
             if name == tnode.get('code'):
                 for mnode in tnode.findall('task'):
@@ -462,7 +448,7 @@
     file_url = url + "modules.xml"
     grass.debug("url=%s" % file_url, 1)
     try:
-        tree = etree_fromurl(file_url, proxies=PROXIES)
+        tree = etree_fromurl(file_url)
     except ETREE_EXCEPTIONS:
         grass.warning(_("Unable to parse '%s'. Trying to scan"
                         " SVN repository (may take some time)...") % file_url)
@@ -529,9 +515,7 @@
         file_url = '%s/%s' % (url, modclass)
         grass.debug("url = %s" % file_url, debug=2)
         try:
-            file_ = opener.open(url)
         except (HTTPError, IOError, OSError):
             grass.debug(_("Unable to fetch '%s'") % file_url, debug=1)
             continue
@@ -563,9 +547,7 @@
     # construct a full URL of a file
     url = '%s/%s' % (url, 'gui/wxpython')
     grass.debug("url = %s" % url, debug=2)
     if not file_:
         grass.warning(_("Unable to fetch '%s'") % url)
         return
@@ -730,7 +712,7 @@
     data = dict()
     try:
             clist = list()
             for cnode in tnode.findall('correlate'):
@@ -815,7 +797,7 @@
     data = {}
     bin_list = []
     try:
     except (HTTPError, URLError, IOError, OSError) as error:
         grass.error(_("Unable to read addons metadata file"
                       " from the remote server: {0}").format(error))
@@ -1109,15 +1091,12 @@
     elif source in ['remote_zip', 'official']:
         # we expect that the module.zip file is not by chance in the archive
         zip_name = os.path.join(tmpdir, 'extension.zip')
-        ses = requests.Session()
-        if 'PROXIES' in globals():
-            ses.proxies = PROXIES
-        res = ses.get(url, stream=True)
-        if str(res.status_code) != '200':
+        try:
+            response = urlopen(url)
+        except URLError:
             grass.fatal(_("Extension <%s> not found") % name)
-        zipcontent = res.content
-        with open(zip_name, "wb") as f:
-            f.write(zipcontent)
+        with open(zip_name, 'wb') as out_file:
+            shutil.copyfileobj(response, out_file)
         extract_zip(name=zip_name, directory=directory, tmpdir=tmpdir)
         fix_newlines(directory)
     elif source.startswith('remote_') and \
@@ -1691,7 +1670,7 @@
             try:
                 open_url = urlopen('http://' + url)
                 open_url.close()
-                url_validted = True
+                url_validated = True
             except:
                 pass
             try:
@@ -1744,6 +1723,9 @@
         PROXIES = {}
         for ptype, purl in (p.split('=') for p in options['proxy'].split(',')):
             PROXIES[ptype] = purl
+        proxy = ProxyHandler(PROXIES)
+        opener = build_opener(proxy)
+        install_opener(opener)
     # define path
     options['prefix'] = resolve_install_prefix(path=options['prefix'],
