GRASS Wish List
Ronald Thomas ront at niwot.CFNR.ColoState.EDU
Thu Sep 9 08:30:29 EDT 1993
Adding to Craig's (caa at noaacrd.colorado.edu) list;
A version of v.cutter that simply uses the current REGION as the
'cutting' template: sort of a "v.resample".
     A vector/raster coincidence tool, or a vector line/polygon
coincidence tool; that would report the distance (length) of a
vector through a polygon/area, giving individual segments and an
accumulative total.  Also, a tool that would measure length of a vector
over elevation gains & losses, giving a TRUE(r) distance reading.
     A /dig_hist directory and associated files, accessible
through v.support, which carry the history of a vector map on to
the /hist directory when rasterized, and "cats" the history of 2
or more files when they are "patched" or otherwise combined in
vector or raster format.  A list of procedures performed, such a
"reclass of XXXXX" or "created by v.patch" would be attached to
the history in addition to being sent to the TITLE field.
     A beefed up rewrite of the SCS contributed program,
v.report, that fixes peculiarities of the current program; in
particular, its reliance on a sequential  category file (currently, no
breaks in assigned attribute #'s allowed), and its faulty 'perimeter'
function.
     An improvement to i.composite that allows it to assign
colors to the range of histogram values of a TM band, rather than
the actual values (an adaption of i.grey.scale?).  ERDAS features
this, and it produces cleaner visuals of imagery.
   Ronald Thomas                         ^  ront at meeker.cfnr.colostate.edu
    Natural Resource Spec. (GIS)         ^
     Resource Management Division        ^   Phone: 303-586-3565  x285
      Rocky Mountain National Park       ^          700-323-7285  (FTS)
       Estes Park, CO  80517             ^
