Problems with recompiling ps.map
N R A nra at cix.compulink.co.uk
Tue May 10 17:52:00 EDT 1994
Can someone explain to me - fairly simply as I'm not too sure what I'm
doing - why I can't get my altered version of ps.map to work. This is
even more bewildering when my previous change (decreased line thickness)
seemed to work ?
I've found three 'ps.map' files
- one in GRASS/bin - identical in size to all the other programs - 24576
bytes- one each in GRASS/etc/bin/alpha/cmd and GRASS/etc/bin/alpha/inter
- much bigger
When I run 'gamke4.1' in the src/alpha/../ps.map directory, I find the
/cmd version has been updated, but when I run ps.map from in grass, I
don't see the changes I've made.
Sorry if this isn't too clear - I'm not too clear myself  8-(
Thanks for any help,
Steve Culshaw
NRA North West
e-mail : nra at cix.compulink.co.uk (use this for general usage)
or         sculshaw at cix.compulink.co.uk (Private - only checked at best
biweekly)
