Problems with recompiling ps.map
Malcolm Williamson malcolm at cast.uark.edu
Tue May 10 16:46:51 EDT 1994
Steve Culshaw writes:
> Can someone explain to me - fairly simply as I'm not too sure what I'm
> doing - why I can't get my altered version of ps.map to work. This is
> even more bewildering when my previous change (decreased line thickness)
> seemed to work ?
> I've found three 'ps.map' files
> - one in GRASS/bin - identical in size to all the other programs - 24576
> bytes- one each in GRASS/etc/bin/alpha/cmd and GRASS/etc/bin/alpha/inter
> - much bigger
> When I run 'gamke4.1' in the src/alpha/../ps.map directory, I find the
> /cmd version has been updated, but when I run ps.map from in grass, I
> don't see the changes I've made.
Steve,
Assuming that you're leaving GRASS up and running while you compile your
altered program, you probably need to execute the "rehash" command from your
GRASS window before you attempt to run the altered ps.map.
Let me know if this doesn't do the trick.
Malcolm D. Williamson - Research Assistant       E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
