[GRASS5] Re: license issues
Bruce_Byars at baylor.edu Bruce_Byars at baylor.edu
Wed Dec 15 10:06:13 EST 1999
I am searching for a complete list (including the nets stuff that Ranjan
and
I used).  Somewhere Steve and I made a list a while back.  I should have
it off one of the backup tapes shortly.
Bruce
Markus Neteler wrote:
> Hi all!
> It seems we can proceed quickly here on the license issue
> (and we should!):
> >Proposed action: (from Bernhard)
> >        - Move modules with licensing problem to src.license_problem
> >                until we clarify it for the next releases
> Good idea. I start today.
> >        - Replace code for the math routines.
> O.k. this is more work. Suggestion:
>  - move critical modules to src.license_problem
>  - replace critical library routines in a second step
>    As this are only a few this may not be such urgent.
> >        - Replace LZW with a better compression
> Suggestion:
> - Step1
>  Replace the critical file
>   src/libes/gis/lzw.c
>  with another routine but *identical* funtion headers.
>  This is not a nice programming habit, but can be done rather
>  quickly. Then publish again to remove critical source code
>  from internet.
> - Step2
>  Replace the LZW-stuff totally. Needs more work.
> >        - Replace gif with libungif for reading and add png as better
> >          image format.
> Should be possible.
> >        - Find the persons who contributed the code and ask in the
> >          Case of MIPS, University of Illinois and DEC.
> Bill, Helena? Do you remember those CERL people? Did CERL have
> contracts which might be valid?
> Best regards
>  Markus
> If you want to unsubscribe from GRASS Development
> Team internal mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
> length: 1773
> max: 0
length: 2788
max: 0
