[GRASS5] GRASS test suite started...
Markus Neteler neteler at geog.uni-hannover.de
Sat Aug 26 19:35:13 EDT 2000
On Sat, Aug 26, 2000 at 11:31:49AM -0600, John Huddleston wrote:
> What is the path to the file, Markus?
Sorry! It is in the main directory.
Markus
> ----- Original Message -----
> From: "Markus Neteler" <neteler at geog.uni-hannover.de>
> To: "grass5 developers list" <grass5 at geog.uni-hannover.de>
> Sent: Saturday, August 26, 2000 9:10 AM
> Subject: [GRASS5] GRASS test suite started...
> > Hi there,
> > just now I have added a preliminary script for
> > GRASS functionality testing into CVS.
> > "testgrass.sh"
> > Just run it. It is shell based and creates itself
> > a GRASS database/location/mapset with random name
> > and UTM projection.
> > The only test I have added up to now is the
> > "r.mapcalc -129 bug".
> > If you think, this makes sense, please extend the
> > script. What could be done:
> > * generate vector map, convert to sites and raster,
> >   convert back, compare.
> > * generate raster map, run statistics on it like
> >   r.stats, r.mapcalc, r.average, r.neighbors etc. etc
> >   and compare the results.
> > .. something like that.
> > Cheers
> >  Markus
> > Dipl.-Geogr. Markus Neteler *  University of Hannover
> > Institute of Physical Geography and Landscape Ecology
> > Schneiderberg 50 * D-30167 Hannover * Germany
> > Tel: ++49-(0)511-762-4494  Fax: -3984
> > If you want to unsubscribe from GRASS Development Team mailing list write
> to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
> If you want to unsubscribe from GRASS Development Team mailing list write to:
