[GRASS5] GRASS test suite started...
John Huddleston jhudd at lamar.colostate.edu
Sat Aug 26 13:31:49 EDT 2000
What is the path to the file, Markus?
----- Original Message -----
From: "Markus Neteler" <neteler at geog.uni-hannover.de>
To: "grass5 developers list" <grass5 at geog.uni-hannover.de>
Sent: Saturday, August 26, 2000 9:10 AM
Subject: [GRASS5] GRASS test suite started...
> Hi there,
> just now I have added a preliminary script for
> GRASS functionality testing into CVS.
> "testgrass.sh"
> Just run it. It is shell based and creates itself
> a GRASS database/location/mapset with random name
> and UTM projection.
> The only test I have added up to now is the
> "r.mapcalc -129 bug".
> If you think, this makes sense, please extend the
> script. What could be done:
> * generate vector map, convert to sites and raster,
>   convert back, compare.
> * generate raster map, run statistics on it like
>   r.stats, r.mapcalc, r.average, r.neighbors etc. etc
>   and compare the results.
> .. something like that.
> Cheers
>  Markus
> Dipl.-Geogr. Markus Neteler *  University of Hannover
> Institute of Physical Geography and Landscape Ecology
> Schneiderberg 50 * D-30167 Hannover * Germany
> Tel: ++49-(0)511-762-4494  Fax: -3984
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
