[GRASS5] Cygwin build of Grass5
John Huddleston jhudd at lamar.colostate.edu
Sat Aug 26 13:31:06 EDT 2000
Eric,
I was wondering when someone was going to get around
to asking me "how" it is done for Cygwin.  It's not easy.
I've added Gmakefiles throughout all my directory
structure and in case that doesn't work I have buildcyg.sh
shell scripts to allow me to remember what needs to be
done.
The latest Cygwin 1.1.2 is very much like "Unix" in its
operation.  Probably the biggest hurdle is putting all the
other public domain libraries and include files into the
/usr/local area.  See the src/CMD/head/os_specific
cygwin32 file.    Once those have been built the compiles
work OK.  The only other gotcha is that file names in upper
case are seen as lower case.
I offered to help Markus get the configure script working
and autoconf; however, I also am finishing up a PhD
at CSU in Civil Engineering.   I will have more time
after next may.   Concentrate on the configure script
rather than a makefile, then tweak the Makefile.in
I'd be glad to be a testing agent for now.
John Huddleston
----- Original Message -----
To: <grass5 at geog.uni-hannover.de>
Sent: Friday, August 25, 2000 10:27 AM
Subject: Re: [GRASS5] Cygwin build of Grass5
> Could you send me a log of the make/install process? I'd
> like to add cygwin support to the experimental Makefile
> tweaking I've been working on lately.
> John Huddleston wrote:
> > To Grass list,
> > There is a new build of the grass5 binaries for Windows
> > NT running the Cygwin shell.  It is over 33MB.  (Markus,
> > it is already uploaded, name grass-000821.zip)
> > Every time I rebuild I try to add more of the code.   This
> > build includes most of grass5 from the cvs with some
> > small exceptions such as rim, postgres, etc.
> > John Huddleston, P.E.
> > Computer Engineer
> > USDA - NRCS
> > John.Huddleston at usda.gov
> > If you want to unsubscribe from GRASS Development Team mailing list
write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
> | Eric B. Mitchell         mailto:emitchell at altaira.com |
> | tel: (301) 809 - 3534    Altair Aerospace Corporation |
> | tel: (800) 7 - ALTAIR    4201 Northview Dr. Suite 410 |
> | fax: (301) 805 - 8122    Bowie, MD  20716             |
>               ,___
>           /"\  / o=\  /"""---===/
>          /   \_/  \__/   ---===/
>          |    //\   || /""TT""/ //\   || ||""\
>          |   //  \  ||    ||   //  \  || ||__/
>          |  file://--==\ |L--/ ||  file://--==\ || || "=,
>            \____---===/
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
If you want to unsubscribe from GRASS Development Team mailing list write to:
