[GRASS5] XDRLIB make variable
Justin Hickey jhickey at impact1.hpcc.nectec.or.th
Wed Aug 2 14:43:46 EDT 2000
Hello all
XDRLIB is used as a member of a LIBES variable definition in several
Gmakefiles. Then LIBES is used as a target and this can cause some problems on
SGI machines. The XDRLIB variable is defined as -lsun on an SGI. Thus, it does
not make sense to have -lsun as a target. What I would like to know is whether
or not XDRLIB is defined similarly on other platforms? That is, is the XDRLIB
variable -l<something> on most platforms, or can it be a path to a library
which the Gmakefile can recompile (similar to other grass libraries like
GISLIB)? If XDRLIB is always something like -lsun then it should not appear as
a target and should be removed from the LIBES variable definition. To check
this simply look in the file src/CMD/head/head.
Any information will be greatly appreciated and thank you for your time.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
