[GRASS5] XDRLIB make variable
John Huddleston jhudd at lamar.colostate.edu
Wed Aug 2 08:20:09 EDT 2000
Justin,
See the src/CMD/head/os_specific directory.  When you do
the configure, it will copy either sgi or sgi5 to head.
The windows XDRLIB is -lrpclib
John Huddleston
----- Original Message -----
From: Justin Hickey <jhickey at impact1.hpcc.nectec.or.th>
To: <grass5 at geog.uni-hannover.de>
Sent: Wednesday, August 02, 2000 12:43 PM
Subject: [GRASS5] XDRLIB make variable
> Hello all
> XDRLIB is used as a member of a LIBES variable definition in several
> Gmakefiles. Then LIBES is used as a target and this can cause some
problems on
> SGI machines. The XDRLIB variable is defined as -lsun on an SGI. Thus, it
does
> not make sense to have -lsun as a target. What I would like to know is
whether
> or not XDRLIB is defined similarly on other platforms? That is, is the
XDRLIB
> variable -l<something> on most platforms, or can it be a path to a library
> which the Gmakefile can recompile (similar to other grass libraries like
> GISLIB)? If XDRLIB is always something like -lsun then it should not
appear as
> a target and should be removed from the LIBES variable definition. To
check
> this simply look in the file src/CMD/head/head.
> Any information will be greatly appreciated and thank you for your time.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do.  ---Anonymous
> Jazz and Trek Rule!!!
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
