[GRASS5] Makefile/autoconf progress! (libs as shared libraries)
Eric Mitchell emitchell at altaira.com
Tue Aug 1 18:30:28 EDT 2000
I once wrote:
> > Also, splitting grass into at least "libs" and "programs"
> > will make this a lot easier, as explicit references to
> > which directories contain which libraries can be dropped,
> > in favor of referring to a single $GISBASE/$ARCH/lib
> > directory.
Or, I can just dump the libs into a common temporary
directory in the build tree with minimal effort, which
also works well (added that last night, during a fit
of insomnia).  This means that tying a makefile
variable to a library location is no longer necessary.
This means that you can just say "-lgis" instead of
"$(GISLIB)".  In and of itself, that's not that big a
deal, but it also means that if the location of
libgis.(a|so) moves, you don't have to update the link
lines for building programs, nor change the definition
of the library in whichever included makefile it's
currently defined in.
> > Additional thoughts? concerns? ideas?
> Check out the glib, gtk+, gimp configure procedures.
> They might provide additional inspiration on how to
> modularize the process. Especially check the glib-config
> and gtk-config programms. :)
>         Bernhard
Or my own esound-config, for that matter. =)  The *-config
technique for dependencies is one that works well with
autoconf, but requires the programmer of a module know
how to wire it into autoconf, and write the .m4 checks
for it as well.  The gnome-config script is even more
complex, but handles multiple library requirements fairly
well.  The current makefile setup I'm working with would
require no such autoconf mastery, provided you ran make
from within a grass shell.  Obviously, compiling grass
itself would not need to be done from within a shell, but
the "core" grass package can find everything it needs
from $(SRCDIR).  Additional modules can find everything
they need from $GISBASE.  I'll post a tarball of whatever
I have available on Friday PM (US time) for comments.
-- ebm
| Eric B. Mitchell         mailto:emitchell at altaira.com |
| tel: (301) 809 - 3534    Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR    4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122    Bowie, MD  20716             |
              ,___
          /"\  / o=\  /"""---===/
         /   \_/  \__/   ---===/
         |    //\   || /""TT""/ //\   || ||""\
         |   //  \  ||    ||   //  \  || ||__/
         |  //--==\ |L--/ ||  //--==\ || || "=,
           \____---===/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
