[GRASS5] New MacOS X compilation errors
Andreas Lange Andreas.Lange at Rhein-Main.de
Wed Nov 22 17:46:56 EST 2000
Hi Jeshua,
how did you do the update? Via CVS?
Jeshua Lacock wrote:
> OK, I updated the source and ran gmake5.
> And I got a bunch or errors like: SWITCHER.c:1396: illegal expression, found `>>'
That looks to me as if there have been conflicts during the CVS-merge
operation. You can tell that by looking at the first line of the CVS
output logging that starts with a "C" in that case.
If you are confused by this and don't know what to do, please do the
following:
Remove all source files that you edited by hand, but don't delete the
CVS-directories.
E. g.:
cd src/display/decices/XDRIVER
find . -name *.c -exec rm -f {} \;
And after that do a "cvs update" from this directory to get all source
files again.
If you know which are the offending files, only remove them.
I would suggest that you do not edit the source files unless you really
know what you are doing there.
> So, I edited the SWITCHER.c file and deleted the lines that were  <<<<<<<<, =========. >>>>>>> and deleted the old malloc statements to get to the next step.
That are the conflicting lines.
> Then, I ran gmake5 again to get these errors:
> SWITCHER.c: In function `xalloc':
> SWITCHER.c:1369: conflicting types for `malloc'
> /System/Library/Frameworks/System.framework/Headers/bsd/stdlib.h:121: previous declaration of `malloc'
> SWITCHER.c:1369: warning: extern declaration of `malloc' doesn't match global one
> SWITCHER.c:1369: conflicting types for `realloc'
> /System/Library/Frameworks/System.framework/Headers/bsd/stdlib.h:125: previous declaration of `realloc'
> SWITCHER.c:1369: warning: extern declaration of `realloc' doesn't match global one
> make[1]: *** [OBJ.powerpc-apple-darwin1.2/SWITCHER.o] Error 1
> make: *** [all] Error 2
> So then I edited SWITHCER.c again and deleted line 1369 (where mallox and realloc were re-defined).
This line is commented in my local copy of the CVS source.
Maybe you deleted the line from the CVS update and left the old version.
> Raster.c: In function `Raster_int':
> Raster.c:83: warning: assignment from incompatible pointer type
> Raster.c:85: warning: assignment from incompatible pointer type
That has nothing to do with the error.
> /usr/bin/ld: Undefined symbols:
> __XErrorFunction
> __XIOErrorFunction
> __Xdebug
> make[1]: *** [/usr/local/grass-5.0b/driver/XDRIVER] Error 1
> At which point I get stumped! (Heeeeelp!)
Obviously the X Window libraries are missing/not found.
Did you run ./configure _before_ you installed the X Libraries?
Then simply re-run ./configure (with the same parameters than the first
time) and re-run make and make install from the top source directory.
Please mail again if you have problems. But don't expect me to answer
immediately.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
