[GRASS5] Cleaning and merging v.in.dxf, v.in.dxf2
Andreas Lange Andreas.Lange at Rhein-Main.de
Thu Apr 19 05:34:03 EDT 2001
Hi Michel, Hi Markus,
please do not remove the dig_ascii directory or change v.in/out.ascii,
as some (many?) scripts rely on writing to/reading from dig_ascii. This
should be done with GRASSS 5.1, but not yet.
cu,
Andreas
Michel Wurtz wrote:
> Conclusion :
> 1- The dig_ascii directory seems only usefull for v.out.dxf, which
> should be rewritten to read binary vector files.  After that,
> v.[in|out].ascii should write anywhere (same thing as other import/
> export programs), and act as a general utility.
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
