[GRASS5] Environment variable listings...
Glynn Clements glynn.clements at virgin.net
Fri Aug 10 07:39:49 EDT 2001
Eric G. Miller wrote:
> Do you think people would find it useful if g.gisenv could list all of
> the known environment variables with a bit of information about them?
> I've hacked my copy of g.gisenv to do this via an "-l" flag.  Output is
> like:
[snip]
> Seems it's never easy enough to figure out what environment variables
> are available for controlling behaviors...  Developer's can easily add
> to the struct array if there's a module that recognizes a certain
> variable and it's not yet "registered".
> Opinions?
Adding this to g.gisenv might further confuse users regarding the
distinction between GRASS variables ($GISRC) and environment variables
(getenv()). It might be better to have a separate program.
Glynn Clements <glynn.clements at virgin.net>
