[GRASS5] WARNING: CVS broken
Bernhard Reiter bernhard at intevation.de
Thu Aug 16 13:12:55 EDT 2001
On Thu, Aug 16, 2001 at 06:42:02PM +0200, Markus Neteler wrote:
> > > Dear developers, please check if your changes are present
> > > in current CVS.
> Is there any way to cvs diff the wrong release branch and the active
> one to find the mis-checked modules?
Well hmm yes,
it probably can be done using the right cvs commands.
For sure it works if you checkout both trees and run a
diff -ru on them. :)
(Using -z4 is your friend then...)
	Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project                                         (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
FSF Europe                                            	  (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010816/0ea66020/attachment.bin
