[GRASS5] WARNING: CVS broken
Glynn Clements glynn.clements at virgin.net
Thu Aug 16 15:42:54 EDT 2001
Bernhard Reiter wrote:
> > > > Dear developers, please check if your changes are present
> > > > in current CVS.
> > Is there any way to cvs diff the wrong release branch and the active
> > one to find the mis-checked modules?
> Well hmm yes,
> it probably can be done using the right cvs commands.
> For sure it works if you checkout both trees and run a
> diff -ru on them. :)
That should be equivalent to:
	cvs diff -r <rev1> -r <rev2>
Glynn Clements <glynn.clements at virgin.net>
