[GRASS5] More notes on BUGS list...
Markus Neteler neteler at geog.uni-hannover.de
Sat Jan 13 04:40:44 EST 2001
Hi Eric,
On Fri, Jan 12, 2001 at 11:01:33PM -0800, Eric G . Miller wrote:
> Going through BUGS list again...
> d.param.scale:
>   Removed?  Related to removal of optri?
Not removed, but moved due to usage of copyrighted "numerical recipes"
functions. It is in src.nonGPL/display/d.param.scale/
Later on, if David's src/libes/gmath/ is finished, we can replace the NR
stuff by gmath functions and move d.param.scale back to standard path. Maybe
gmath is already sufficient for d.param.scale, I didn't investigate.
> d.rast.edit:
>   Seems to edit floating point just fine.
I see, so we can remove this one.
> d.sites.qual:
>   Can we get some decision about whether this is or isn't a BUG.
>   (I vote that it isn't).
Removed.
> g.select.pg:
>   Think I fixed all that a few weeks back...
Ah yes - removed.
> i.tape.tm.fast:
>   Think it's fixed, but I can't really test without tape drive and TM
>   imagery.  It get's past segfault in interactive...
Thanks for this fix. Even I cannot test it but I'll remove the report.
> r.in.hdf/r.out.hdf:
>   I didn't see anything in the hdf dirs indicating any version for hdf5.
>   I'd recommend not including the HDF5 library with GRASS sources should
>   such a thing ever come to be.  Such a thing should just use the shared
>   library (if present, else no compile).
That's right. It's only HDF4.3 in the sources and 3.2.
I propose to remove HDF4.3 from GRASS (except r.in.hdf/r.out.hdf) as it was
never working and is already outdated.
> r.los:
>   Should we just have it exit for lat/lon rasters/databases?  I'm not
>   sure how to handle the metrics (what would the elevation units be?).
I don't know what to do here.
(But such lat/long exit can be found at
 src/raster/r.surf.idw2/cmd/main.c)
> r.null:
>   I still think the behavior about reclass maps is right.
O.k.
Eric, may I ask you to add your hints to the html/html/r.null.html?
Then we can remove them from BUGS.
> r.out.tiff:
>   The -t flag problem should be fixed now.  The NULL color thing is
>   kind of fixed.  This module really needs a ground up rewrite.
Yes, both tested. Thanks! - removed.
> r.rescale:
>   Agree with Andreas on Zero vs. NULL thing.
Andreas, will you implement the "-z" as written in BUGS?
> That's enough for now ;)
Definitely! Thanks for your work, Eric,
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
